Morning all, tried to do a scan on a 2015 2.0 litre match golf. Couldn't find it on the listing for the auto scan so used the 2014 onwards golf variant. Was this correct ? Thanks in advance.
Also, what are the exact results from [Options] -> [Test] with everything connected?If you click [Gateway Installation List], in the middle of the screen, what happens?
Hiya Boki, just a question with regards to the above, as I'm going to hopefully pick the car up on Saturday ( with a positive scan of course ) what should I see when pressing that button please ?If you click [Gateway Installation List], in the middle of the screen, what happens?
What should be the result of this please Uwe ?VCDS should do an Auto-Scan on that car using "Auto-Detect". If it doesn't, there's almost certainly something broken in that car.
Saturday,14,June,2025,10:46:40:21591
VCDS Version: 25.3.1.2 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250604 DS365.0
VIN: WVWZZZAUZFW353938 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFW353938 Mileage: 149360km-92808miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 8125
Revision: 83H22--- CVN: 06305156
Coding: 01190012034505082000
ASAM Dataset: EV_ECM20TDI01104L906021DS 002013
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79ACE467695C17B2C87-802C
VINID: 9E69EAAAA465A969C314324320CA1D4885
13 Faults Found:
17158 - Databus
U1123 00 [00100000] - Received Error Message
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [00100000] - -
U0428 00 [00100000] - -
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100000] - -
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [00100000] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
4713 - No Communication with ABS Brake Control Module
U0121 00 [00100000] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
4714 - Steering Column Control Module
U0212 00 [00100000] - No Communications
4715 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
4716 - No Communications with Parking Brake Control Module
U0128 00 [00100000] - -
4719 - Diagnostic Gateway
U0146 00 [00100000] - No Communications
4720 - Body Control Module (Central Electric 2)
U0141 00 [00100000] - No Communications
17262 - Terminal 30
U140A 00 [00100000] - Open Circuit
[Terminal 30Open circuit]
4629 - ECM Power Relay Load Circuit
P068A 00 [00100000] - Opens Too Early
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 61155000000155
Coding: 01FA8AA12425096F0780060341CB2980512490E0608294F314605078C002
VCID: 48CA51A36236BE3A079-801C
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 83
Mileage: 116556 km
Date: 2022.10.08
Time: 16:41:47
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00120104202100001000000000000000
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 3C223D7326EEE29A931-8068
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0137
Serial number: 01011512400441 Dataset Number: 5G0063v____ 0001
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA4F0777D742B92E4F-8028
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150423 042 0551
Serial number: 150429084937
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y15M05D05H01M45S07
Coding: 90A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150890NF4
Serial number: 00000000000032321236
12307 - License Plate Light
B12CA 01 [00001001] - Electrical Failure
Reset counter: 48
Mileage: 149107 km
Date: 2025.05.27
Time: 10:38:13
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.9 V
Outside temperature: 14.0 C
B1263 01 [00001001] - Electrical Failure
Fault Frequency: 69
Reset counter: 250
Mileage: 106616 km
Date: 2021.12.08
Time: 11:34:05
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
last_wakeup: g ltiges Funktelegramm
Voltage: 12.3 V
Outside temperature: 5.0 C
204546 - Remote key 2
B147A 18 [00001001] - Current Too Low
Reset counter: 49
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.3 V
Outside temperature: 7.5 C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391512502835 Dataset Number: 5G0039v__A_ 0020
Coding: 0071051001
VCID: 3D2430773DF4EB92A4F-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 18041503272805 Dataset Number: 5g0114v____ 1020
Coding: 00000300FE0739
VCID: 382A216312D6CEBA779-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0EMF50 Dataset Number: 5G0003v____ 0094
VCID: 7F580A7F77783982F63-802A
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B05051571111
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B07051510548
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 405 15
Serial number: 357670000005D285441R
Subsystem 4 - Part No SW: ----------- HW: 480 002 504 15
Serial number: 358670000001D48D141V
Subsystem 5 - Part No SW: ----------- HW: 480 402 404 15
Serial number: 3516502AB1A91E73A20E
Subsystem 6 - Part No SW: ----------- HW: 480 402 404 15
Serial number: 3526502C31A91E72837E
Subsystem 7 - Part No SW: ----------- HW: 480 402 704 15
Serial number: 3556502991A2DCD3F03U
Address 16: Steering wheel Labels:
VCID: 55F488D7AC0413D28CF-FFFE
Part No SW: 5G1 920 941 HW: 5G1 920 941
Component: KOMBI 203 5297
Coding: 27A419002780260001882A011400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009003
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 6696BF1B08E2884A155-8032
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [00001000] - -
[BAP_Audio_0x31 keine Kommunikation]
Fault Frequency: 8
Reset counter: 87
Mileage: 148257 km
Date: 2025.04.24
Time: 09:38:03
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 71
Mileage: 148257 km
Date: 2025.04.24
Time: 09:38:03
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component: GW MQB High 128 1204
Revision: -------- Serial number: 0003397823 Dataset Number: 5G0067v____ 2011
Coding: 030100040F087300EF00005C080F00010001050000000000000000000000
GVL: 01543C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 72BED34B342A64EA89D-8026
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150000886550025184
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 3089246603
Address 44: Steering Assist
Address 52: Door Elect, Pass.
End----(Elapsed Time: 01:38, VBatt start/end: 12.2V/12.2V. VIgn 0.0V)------
------------------------------19 Faults Found------------------------------
Saturday,21,June,2025,09:28:08:21591
VIN: License Plate: GM15XWR
Mileage: 92853 Repair Order:
The above is the first scan whereby I chose the Golf variant button.
This as suggested by yourselves on Saturday.....
Gateway Installation List: 5Q0 907 530 AC
Saturday,21,June,2025,09:34:06:21591
VIN: WVWZZZAUZFW353938 License Plate: GM15XWR
Mileage: 149436km-92855mi Repair Order:
Saturday,21,June,2025,09:37:30:21591
VIN: WVWZZZAUZFW353938 Mileage: 149436km-92855miles
Revision: 00001K06
Coding: 90A8DD
Coding: 0071051001
Coding: 333135
Coding: 333135
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 04051508490574
Coding: 0C00
ROD: EV_SMLSKLOMQB_017.rod
VCID: 7BA0FE6F636025A2DAB-802E
Generator:
Coding: 2CFFFF
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 130415BDC05739 Dataset Number: 5G0222v____ 0061
Coding: 00310220D001048000001000
VCID: 42DE438B440A946AD9D-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006060987
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Dataset Number: 5G0074v____ 0881
Coding: 8102
VCID: 43D0468F5B109D62D2B-8016
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 270415BCR02567 Dataset Number: 5G0157v____ 0057
Coding: 00310020DE01048000801000
VCID: 41DC4C87410C8F72C07-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006084562
Coding: 150000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 041 0421
Serial number: V5C00505152335 Dataset Number: 5G0CV1v____ 0001
Coding: 02730000FF00000021111201000800001F0100060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F18EAFF97389982963-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9RS208ZBE
End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
---------------------------No fault code found.----------------------------
