2017 Q7 — Steering Malfunction + No Backup Cam + Lighting Issues + U1123/U1400 Errors — Starts and Runs Fine
theautoconnect
Ocean Springs, MS, USA
C?ID=512317
Looking for some guidance on a 2017 Audi Q7 3.0T The car starts and runs perfectly, but I’m seeing the following symptoms:
Steering Malfunction warning — steering feels completely normal (not stiff, full assist present).- intermittent not always there when you crank it
Rear lighting issues — tail lamps work intermittently ; if taillights work then lower bumper lights out, if lower bumper lights work tail lights are out
Backup camera non-functional — "Cannot be reached" in scan.
Widespread U1123 Databus Errors and U1400 Voltage Too Low faults across numerous modules. Several freeze frames show voltage dipping to ~8–9V intermittently but not recently since car was dropped off last week
I am aware that this Q7 uses a multi-piece power distribution fuse block (Battery Positive Fuse Box, F176/F177/F178) integrated with the battery positive terminal — I have not inspected this yet but suspect it may be involved.
Before I start chasing individual components, does this pattern point more toward a battery/charging system issue, or should I prioritize inspecting that fuse block first? Any known/common failure patterns here on the Q7 MLBevo platform?
Full VCDS Auto-Scan attached. Appreciate any insights!
Friday,06,June,2025,08:37:41:59036
VCDS Version: 25.3.1.0 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WA1LAAF7XHD009209   License Plate: SILVERQ7
Mileage: 171532km-106585mi   Repair Order:
Chassis Type: F7-AU73 (8W8)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47
          50 52 5F 69 6C 6D 81 8B A5 BB BC CA CF D6 D7
VIN: WA1LAAF7XHD009209   Mileage: 171532km-106585miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
50-Seat Adj. 3rd row -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4M0 907 551 A    HW: 06E 907 425
   Component: 3.0l V6 TFSI  H10 0005
   Revision: --H10---    CVN: 08BDF7A0
   Coding: 2A2A00320576010D74280000000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
   ROD: EV_ECM30TFS021_AU73.rod
   VCID: 2D0C6687DDEF57A214D-8178
   VINID: 9D105C451587A1850000908024519BD18F
15244 - Supply Voltage 1 for Engine Actuators
          P0658 00 [01100000] - Too Low
17186 - Databus
          U1123 00 [00101000] - Received Error Message
                    Fault Frequency: 158
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:35:29
                    Engine speed: 680.00 /min
                    Normed load value: 23.1 %
                    Coolant temperature: 92  C
                    Intake air temperature: 59  C
                    Voltage terminal 30: 13.769 V
                    Unlearning counter according OBD: 10
                    Engine status: Idle
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: operated
                    Cruise control switch actuation-Large increment: Not operated
                    CCS Switch: ACC operating unit
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
15282 - Starter Will Not Turn
          P3054 00 [00100000] - Jammed or Electrical Malfunction
                    Mileage: 169453 km
                    Date: 2025.04.07
                    Time: 13:05:01
                    Engine speed: 0.00 /min
                    Coolant temperature: 28  C
                    Intake air temperature: 28  C
                    Voltage terminal 30: 8.730 V
                    Unlearning counter according OBD: 30
                    FAC_TPS_1_SAE: 28.906250 %
                    FUP_H_SAE: 1020.0 kPa
                    Charge press.: average: 1.004 bar
                    Engine status: Stop
                    Outside temperature: 30.0  C
                    T_AST_SAE: 0 s
                    Oxygen sensor 1 bank 1: raw value: 1.000 counts
17178 - Databus
          U1123 00 [00100000] - Received Error Message
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:09:59
                    Voltage terminal 30: 9.394 V
                    Engine status: Stop
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: Yes
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: Yes
                    Drivetrain coordinator: brake function status-ASP intervention: Yes
                    Drivetrain coordinator: brake function status-ADS intervention: Yes
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: Yes
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): Yes
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): Yes
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: Yes
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: Yes
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
19854 - Steering Column Control Module
          U0212 00 [00100000] - No Communications
24194 - PCV Valve Malfunction
          P052E 00 [01101101] - -
                    Fault Frequency: 15
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:36:43
                    Engine speed: 677.75 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 62  C
                    Intake air temperature: 25  C
                    Voltage terminal 30: 14.238 V
                    Air mass: 15.75000 kg/h
                    Pressure upstream of throttle valve: corrected: 0.993 bar
                    Charge press.: average: 0.389 bar
                    Throttle valve angle: 2.925
                    Ambient air pressure: 0.994 bar
                    Accelerator pedal position: 0.00 %
                    Outside temperature: 25.0  C
   Part No SW: 4M0 927 158 L    HW: 0D5 927 156 H
   Component: 0D5  30TSIUSA H03 1003
   Revision: --H03---    CVN: 3655CB50
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 3D2C56C70D8FC722A4D-8168
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
   Component: ESP9 Premium  H08 0521
   Dataset Number: 4M0909504G  0029 CVN: F1B6AFC9
   Coding: 28AA149C30A20A9F96A05891008652A2E6269A14280C50691A004A45676459
   Shop #: WSC 65154 002 1048576
   ASAM Dataset: EV_ESP9BOSCHAU736 011006
   ROD: EV_ESP9BOSCHAU736_AU73.rod
   VCID: 3FD02CCF0783D532B61-816A
352772 - System Voltage
          P0562 00 [01101000] - Too Low
                    Fault Frequency: 61
                    Mileage: 169207 km
                    Date: 2024.12.31
                    Time: 12:16:36
143360 - Function Restricted due to Insufficient Voltage
          U1400 00 [01101000] - -
          [Undervoltage_dectected_in_network]
                    Mileage: 169453 km
                    Date: 2025.04.05
                    Time: 12:27:30
331008 - Function Restricted due to Insufficient Voltage
          U1400 00 [00101000] - -
          [PBC_LOW_V_BAT]
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:09:43
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-BFS       008 0015
   Serial number: 00000186095603 Dataset Number: 4M0909866B  0013
   Coding: 000410000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
   VCID: 75BC8EE7753F5F62ACD-8120
          [supply_voltage_too_low_functional_limitation]
                    Reset counter: 166
                    Mileage: 170514 km
                    Date: 2025.05.08
                    Time: 12:29:49
   Part No SW: 4M0 820 043 AB    HW: 4M0 820 043 AB
   Component: Klima Zone 4  H52 0112
   Coding: 6608090C5544001110280180800000000000000000000000000000000000
   Shop #: WSC 28491 004 1048576
   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
   ROD: EV_AirCondiFrontBHTCAU736.rod
   VCID: 659CDEA7C59FAFE21CD-8130
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000750675
   Humidity sensor: exterior:
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: DC294018000000000001
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Dataset Number: 4M0909514M  0050
   Coding: 07500363E0691CCD010F8715583E1CB911033D01900000000000000020001A010869012B025509
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 0052EF333AFD6ACA8FB-8154
   Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
   Component: WWS536 160103  043 0893
   Serial number: 895553?0401600300598
   Coding: 1BC7F7
   Serial number: 61312336
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 21 01 2016  00218299
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0040
   Serial number: 0000009600335Z0GWG02
   Coding: 350000
   Garage door opener control head:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20160114080208 00040
   Subsystem 6 - Part No SW: 4M0 857 511 B    HW: 4M0 857 511 B
   Component: Y7_Innenspieg  H04 0002
   Serial number: GX1CE111011611520341
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4M0 947 135 AN    HW: 4M0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: Q00093290
   Subsystem 8 - Part No SW: 4M0 907 705 A    HW: 4M0 907 705 A
   Component: J866-EVLS-SG  H03 0060
   Serial number: WA122688000018313924
   Coding: 020100
   Subsystem 9 - Part No SW: 4M0 925 301 A    HW: 4M0 925 301 A
   Component: SL-Q7NF/AU736  H10 0013
   Serial number: 00000000000000034051
   Subsystem 10 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14CF34301497
   Subsystem 11 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14CF33100566
   Subsystem 12 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14CF34301495
   Subsystem 13 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14CF33100565
66680 - Databus
                    Reset counter: 186
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:08:37
                    average_Voltage_terminals: 8.80 V
                    Outside air temperature sensor-Outside air temperature on CAN: 35.00  C
                    interior_temperature: 49.50  C
                    Vehicle speed: 0.00 km/h
66681 - Databus
                    Reset counter: 186
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:08:37
                    Outside air temperature sensor-Outside air temperature on CAN: 35.50  C
196758 - Databus
                    Reset counter: 194
                    Mileage: 171530 km
                    Date: 2025.06.04
                    Time: 08:38:08
                    average_Voltage_terminals: 13.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 28.50  C
                    interior_temperature: 29.00  C
196868 - Supply Voltage for Parking Aid
          B1542 16 [00001000] - Voltage Too Low
                    Fault Frequency: 13
                    Reset counter: 196
                    Mileage: 169453 km
                    Date: 2025.04.04
                    Time: 20:13:53
                    average_Voltage_terminals: 8.70 V
                    Outside air temperature sensor-Outside air temperature on CAN: 28.00  C
                    interior_temperature: 36.00  C
                    Terminal activation-Terminal 75 status: OFF
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: OFF
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 E    HW: 4M0 907 561
   Component: LRR4          H08 0220
   Dataset Number: 4M0909863K  0025
   Coding: B4779FFA58FFEC09949880A5
   ASAM Dataset: EV_ACCBOSCHAU736 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 323675FBC4D1085A49F-8166
10 Faults Found:
0795 - Databus
          [FAULT_APS_RELEVANT_ERROR]
                    Reset counter: 174
                    Mileage: 171303 km
                    Date: 2025.05.14
                    Time: 08:54:19
                    Control Module temperature: 26  C
                    Voltage terminal 15: 9.9 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s
                    Status_ACC_System: ACC_Init
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Fault Frequency: 35
                    Reset counter: 196
                    Mileage: 169686 km
                    Date: 2025.05.02
                    Time: 15:25:28
                    Control Module temperature: 34  C
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 194
                    Mileage: 171530 km
                    Date: 2025.06.04
                    Time: 08:38:08
                    Control Module temperature: 30  C
                    Voltage terminal 15: 13.6 V
2115 - Databus
          [FAULT_HMS_FAILURESTATE]
                    Fault Frequency: 45
                    Reset counter: 196
                    Mileage: 169626 km
                    Date: 2025.04.29
                    Time: 09:05:13
                    Control Module temperature: 24  C
                    Voltage terminal 15: 10.0 V
1392 - Databus
          U1122 00 [00001000] - Implausible Message
          [FAULT_LRRS_SELFDIAG]
                    Reset counter: 190
                    Mileage: 170413 km
                    Date: 2025.05.05
                    Time: 13:31:08
                    Control Module temperature: 15  C
2062 - Databus
          [FAULT_MAINSWITCH_FAIL]
                    Fault Frequency: 57
                    Reset counter: 166
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:26:16
                    Control Module temperature: 79  C
                    Voltage terminal 15: 13.9 V
2127 - Databus
          [FAULT_OP_FAIL]
                    Reset counter: 166
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:26:16
1116 - Databus
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 166
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:26:17
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Fault Frequency: 27
                    Reset counter: 187
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:26:16
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Fault Frequency: 106
                    Reset counter: 197
                    Mileage: 169453 km
                    Date: 2025.04.04
                    Time: 20:14:00
                    Voltage terminal 15: 8.3 V
   Part No SW: 4M0 959 655 A    HW: 4M0 959 655 A
   Component: Airbag10.44   H61 0086
   Serial number: 003M5000ADMW Dataset Number: 4M0909602WP 0001
   Coding: AECCFCC000800000A0F00033C24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005.rod
   VCID: 392442D719A7FB02885-816C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 4M0857705E0040Q00526
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 4M0857706E0041Q01375
   Coding: 88001B
   Serial number: IBH0000J160004IBEB01
   Subsystem 4 - Part No SW: -----------    HW: 442 062 901 16
   Serial number: 3577Y00A31DE13E3B437
   Subsystem 5 - Part No SW: -----------    HW: 442 062 901 16
   Serial number: 3587Y00A31DE13E4B237
   Subsystem 6 - Part No SW: -----------    HW: 442 0B2 101 16
   Serial number: 35177000E294B6C8A7CW
   Subsystem 7 - Part No SW: -----------    HW: 442 0B2 101 16
   Serial number: 3527700BB1E4DF16313L
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 802 16
   Serial number: 35575009B1E4DF2543EY
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 802 16
   Serial number: 356750012293AF28994E
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 410 201 501 16
   Component: CentrSensorXY  1C8 0108
   Serial number: I0O7800C91E5C6C4919M
7 Faults Found:
          B10B4 00 [00001000] - Function Restriction due to Undervoltage
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:08:32
9776640 - Forward-Looking Safety System Function Restriction
          B152E 00 [00001000] - Under-Voltage
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:08:32
9859568 - Passenger Airbag Status Indicator
          B1671 F0 [00001000] - Function Restriction due to Under-Voltage
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:08:31
1060613 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
                    Fault Frequency: 95
                    Reset counter: 197
                    Mileage: 169514 km
                    Date: 2025.04.25
                    Time: 22:21:34
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Fault Frequency: 95
                    Reset counter: 197
                    Mileage: 169514 km
                    Date: 2025.04.25
                    Time: 22:21:34
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Fault Frequency: 95
                    Reset counter: 197
                    Mileage: 169514 km
                    Date: 2025.04.25
                    Time: 22:21:34
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Fault Frequency: 94
                    Reset counter: 197
                    Mileage: 169514 km
                    Date: 2025.04.25
                    Time: 22:21:34
   Part No SW: 4M0 907 129 GJ    HW: 4M0 907 129 GJ
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7EAE91CB40091C3AFD7-812A
6755072 - Cruise Control Switch
          B1154 96 [00001000] - Component Internal Failure
                    Reset counter: 166
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:27:08
                    Freeze_Frame_Lever_Cruise_Control-Operation_time_counter: 221070 min
                    Freeze_Frame_Lever_Cruise_Control-Voltage_12V: 13732.03 mV
                    Freeze_Frame_Lever_Cruise_Control-Voltage_12VS: 0.00 mV
                    Freeze_Frame_Lever_Cruise_Control-Voltage_5VS: 4957.03 mV
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Decelerate_Accelerate_Neutral_uncompensated: 0 bit
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Decelerate_Accelerate_uncompensated: 0 bit
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Main_Switch_uncompensated: 146 bit
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Resume_Cancel_Neutral_uncompensated: 0 bit
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Resume_Cancel_uncompensated: 125 bit
                    Freeze_Frame_Lever_Cruise_Control-Voltage_Set_Distance_Speedlimiter: 253 bit
   Part No SW: 4M0 920 890 A    HW: 4M0 920 890 A
   Component: FBenUSA       H13 0280
   Coding: 08C600C16C88D70502A3E9601800600000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU73.rod
   VCID: 2E0E618BD0E92CBA2D7-817A
13635840 - Supply voltage
          U1011 00 [00001000] - Voltage too Low
          [ECU voltage lower limit supply voltage permanent too low]
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:11:28
   Part No SW: 8W8 907 468     HW: 8W8 907 468
   Component: Gateway       H11 2079
   Revision: 3N070039    Serial number: 3983N060316206 Dataset Number: 4M0909515H  0061
   Coding: 0301000100000F4052070000005900305C120007008000000150000000000000
   GVL: 01503C0408000000C0FCC8000002C800100C2000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 0944F21709C72B82D85-815C
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0002
   Serial number: 20160208114629 00933
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 9731499203
1282 - Supply voltage
          [supply_voltage_lower_limit_value_fallen_below]
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:11:28
131689 - Rear View Camera System Control Module
          U104C 00 [00001001] - No communication
          [Timeout_Node_0x69_DiagAdress_6C_TopView]
                    Reset counter: 70
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:27:20
8519683 - Energy Management Active
          U140B 00 [00001000] - -
                    Fault Frequency: 154
                    Reset counter: 197
                    Mileage: 168545 km
                    Date: 2024.11.12
                    Time: 13:02:52
                    EM_vehicle_state: 00 00
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 4M0 919 158 C    HW: 4M0 919 158 C
   Component: Klima Zone 2  H52 0080
   Coding: 000000000000000100800080000000000000000000000000000000000000
   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
   ROD: EV_AirCondiFondBHTCAU736.rod
   VCID: 353C4EE735BF1F626CD-8160
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0023
   VCID: 78A287D3622D220AB7B-812C
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:11:28
0035 - Function Restricted due to Insufficient Voltage
          [functional limitation due to supply voltage - lower limit exceeded]
                    Fault Frequency: 18
                    Reset counter: 186
                    Mileage: 169209 km
                    Date: 2025.03.22
                    Time: 00:03:48
   Component: MEM-FS        008 0015
   Serial number: 00000186095314 Dataset Number: 4M0909856B  0013
   Coding: 001C1B000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
628992 - Development Code 3
          B2F03 00 [00100000] - -
          [limitation_functional_safety]
                    Reset counter: 183
                    Mileage: 171436 km
                    Date: 2025.05.25
                    Time: 14:11:29
                    Fault Frequency: 22
                    Reset counter: 190
                    Mileage: 169209 km
                    Date: 2025.03.22
                    Time: 00:03:22
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------    Dataset Number: 4M0909535K  0012
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 343A73E33EC5066A5B3-8160
1192210 - Databus
          [databus error value received - ESP_Systemstatus]
                    Fault Frequency: 11
                    Reset counter: 194
                    Mileage: 169207 km
                    Date: 2024.12.31
                    Time: 12:16:37
                    Control Module temperature: 23  C
                    Voltage terminal 30: 9.50 V
                    Terminal 15 status: OFF
                    Voltage terminal 15: Measuring value not available
267010 - Databus
          [FAULT_SLAVE]
                    Reset counter: 161
                    Mileage: 169453 km
                    Date: 2025.04.04
                    Time: 20:13:30
                    Control Module temperature: 33  C
                    Voltage terminal 30: 8.30 V
                    Terminal 15 status: On
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000185002494  Dataset Number: 4M0909872F  0027
   Coding: 005F9B005E001080000120B0
   VCID: 42D6253B7471B8DAD9F-8116
   Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H19 0004
   Serial number: 0000578811 Dataset Number: 4M0909852G  0021
   Coding: B0000101000101
   ASAM Dataset: EV_EPSVWBSAU736 008020
   ROD: EV_EPSVWBSAU736_008.rod
   VCID: 333870FF3BCB0152429-8166
16387 - Function Restricted due to Insufficient Voltage
          [Voltage_Condition_and_Check-Pre-steering_Voltage-Monitoring-Undervoltage]
                    Fault Frequency: 82
                    Reset counter: 197
                    Mileage: 169514 km
                    Date: 2025.04.25
                    Time: 22:21:34
                    FreezeFrame_mw_1209_Voltage-Terminal 30 power supply: 10.25 V
                    FreezeFrame_mw_1209_Voltage-Terminal 15 status: OFF
                    FreezeFrame_mw_1209_Voltage-Output stage voltage: 10.30 V
                    FreezeFrame_mw_1209_Voltage-Calculated battery current: 0.00 A
                    FreezeFrame_mw_1209_Voltage-Calculated power frame temperature: 0.00  C
                    FreezeFrame_mw_1209_Voltage-DC Link reference voltage ADC: 2.50 V
                    FreezeFrame_mw_1209_Voltage-Power steering active: Power steering passive
                    FreezeFrame_mw_1209_Voltage-Undervoltage Flag: No undervoltage condition
                    FreezeFrame_mw_1209_Voltage-UVD_KL30B flag: 00
                    FreezeFrame_mw_1209_Voltage-Voltage error information: 00 01
                    FreezeFrame_mw_1209_Voltage-Voltage status external: Voltage supply is too low torque assistance is not activated unless allready active
   Part No SW: 8W0 907 064 CD    HW: 8W0 907 064 D
   Component: BCM2 MLBevo   016 0344
   Dataset Number: 4M0909501VF 0001
   Coding: 01341E00490100C0650B80006E01580003024000000001502F0400000F04803F001E0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU73.rod
   Subsystem 1 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064903443
   Subsystem 2 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94053642
65539 - Function Restricted due to Insufficient Voltage
                    Reset counter: 186
                    Mileage: 171477 km
                    Date: 2025.05.29
                    Time: 13:20:53
                    Supply voltages-Terminal 30 power supply: 9.932 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 9.986 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 9.959 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0  C
                    general_additional_freeze_frame-interior_temperature: -50.0  C
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 0A 90 00 F8
                    defect_fusi_voltage_error_freeze_frame: 11110101 01000000 00000000 00000000
644353 - Bulb 2 for Brake/Tail/Turn Signal; Right
          B1431 13 [00001000] - Open Circuit
                    Reset counter: 170
                    Mileage: 169959 km
                    Date: 2025.05.03
                    Time: 14:08:59
                    Supply voltages-Terminal 30 power supply: 14.539 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.525 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.539 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 A0 94 00 E0
                    general_additional_freeze_frame-Vehicle speed: 126.04 km/h
                    light_freeze_frame: 11111111 11111111 11111111 11111111
65649 - Rear Lid Closed Sensor
          B146C 29 [00001001] - Signal Implausible
                    Fault Frequency: 21
                    Reset counter: 156
                    Mileage: 168546 km
                    Date: 2024.11.16
                    Time: 14:25:08
                    Supply voltages-Terminal 30 power supply: 14.674 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.688 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.633 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 8A 94 02 F8
   Part No SW: 4M0 035 223 A    HW: 4M0 035 223
   Component: MIB2_amp_PD   H02 0420
   Serial number: 00000000018144 Dataset Number: 4M1909510C  0008
   Coding: 0135060A008AF53AAF0000010000
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
   VCID: 21148AB7913783C2A05-8174
6693 - Databus
          U1121 00 [00011000] - Missing Message
          [Fahrzeugdaten f r GALA (Geschwindigkeit: Soundinfo): keine Kommunikation]
                    Reset counter: 184
                    Mileage: 169207 km
                    Date: 2024.12.26
                    Time: 15:37:14
                    Voltage terminal 30: 12.1 V
Address 50: Seat Adj. 3rd row (J857)       Labels:* None
   Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
   Component: MEM-SR3       008 0015
   Serial number: 00000185849277 Dataset Number: 4M0909467B  0014
   Coding: FF041020F1000000000F000000000900000021210900000000000000440000
   ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
   ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
   VCID: 3C2A5BC31695CE2A933-8168
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0050
   Serial number: 0000183777906  Dataset Number: 4M0909873E  0024
   VCID: 3E2E51CB0089DC3ABD7-816A
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 189
                    Mileage: 171528 km
                    Date: 2025.05.30
                    Time: 09:08:47
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 4M0 035 880 M    HW: 4M0 035 880
   Component: MU-P-LNS-US   051 0443
   Serial number: A289B0GB006690 Dataset Number: 4M0909545G  0034
   Coding: 013706020000000013220002041A00102F001BE501700104BE
   VCID: 363E49EB28B9147A657-8162
   Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
   Component: NAR 2016  --- 0048
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
   Component: AU536_DU_HIGH  H43 0008
   Serial number: AUZ8Z9FJ401HPT
   Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
   Component: ControlUnit_P  H14 0165
   Serial number: 10021600000000000084
   Compact disc data bank:
   Component: Gracenote2  --- 3007
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 70
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:26:40
                    Voltage terminal 30: 14.3 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 4M0 907 383 C    HW: 4M0 907 383
   Component: Anhaenger     H20 0214
   Revision: 9C001003    Serial number: 0392614106 Dataset Number: 4M0909527C  0022
   Coding: 0210000200000000
Address 6C: Back-up Cam.        Labels: None
   Part No SW: }      k     HW: 4M0 907 428
   ASAM Dataset:  H  ?ʲ )  j    5
 3      { Q
   ROD: N/A
   VCID: 0E4EC10B70A90CBA0D7-815A
No ASAM data for: " H  ?ʲ )  j    5
 3  " (AU73)
   Part No SW: 8W8 959 107     HW: 8W8 959 107
   Component: HDSG-Modul    H13 0153
   Revision: --------    Serial number: 30464489900000 Dataset Number: 4M0909541F  0022
   Coding: 00B0
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 065EF92B18D944FAB57-8152
0011 - Function Restricted due to Insufficient Voltage
                    Reset counter: 166
                    Mileage: 169688 km
                    Date: 2025.05.03
                    Time: 11:41:48
                    Voltage terminal 30: 9.98 V
   Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160108000772
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 261E99ABF81964FAD57-8172
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 4M0 907 541 E    HW: 4M0 907 541
   Dataset Number: 4M0909885H  0021
   ASAM Dataset: EV_ACC2BOSCHAU736 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 30327FF3CADD3A4A3FB-8164
                    Fault Frequency: 92
                    Reset counter: 197
                    Mileage: 169453 km
                    Date: 2025.04.04
                    Time: 20:14:00
                    Control Module temperature: 29  C
                    Voltage terminal 15: 8.4 V
   Part No SW: 4M0 907 217 D    HW: 4M0 907 217 A
   Component: BVS           H12 0042
   Dataset Number: 4M0909466J  0038
   Coding: 0407030600000201022023A7A50000B4B0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
   VCID: 2F307C8FD7E325B2261-817A
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 194
                    Mileage: 171530 km
                    Date: 2025.06.04
                    Time: 08:38:08
                    Control Module temperature: 31  C
                    Voltage terminal 15: 14.00 V
1123600 - Predictive Route Data
          B1630 02 [00001000] - Signal Failure
                    Reset counter: 167
                    Mileage: 171155 km
                    Date: 2025.05.09
                    Time: 18:35:58
                    Control Module temperature: 37  C
                    Voltage terminal 15: 14.20 V
1123960 - Databus
          [ESC_Bremsdruckgradient]
                    Reset counter: 194
                    Mileage: 171530 km
                    Date: 2025.06.04
                    Time: 08:38:08
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0050
   Serial number: 0000186436588  Dataset Number: 4M0909897E  0025
   Coding: 004F9B0000001080400020A0
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 41D42A377177A3C2C05-8114
   Component: TSG HBFS      009 0050
   Serial number: 0000186436590  Dataset Number: 4M0909896E  0025
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 70
                    Mileage: 168385 km
                    Date: 2024.10.11
                    Time: 16:32:33
   Part No SW: 4M0 907 594     HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Dataset Number: 4M0909469E  0013
   Coding: 208000053602
   VCID: 73B8B0FF7B4B4152829-8126
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 31347AF7C1D73342305-8164
1311234 - Control Module for Lane-Change Assist
          C1114 F3 [00001000] - Limited Visibility
                    Reset counter: 161
                    Mileage: 170464 km
                    Date: 2025.05.05
                    Time: 23:07:43
                    Voltage terminal 30: 14.50 V
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 4M0909471C  0011
   ROD: EV_LEDModLeftMELCOAU736_AU73.rod
   VCID: 167EA96B4879F47A457-8142
   Component: LED1R         H09 0003
   Dataset Number: 4M0909472C  0011
End----------(Elapsed Time: 03:06, VBatt start/end: 11.6V/14.0V)-----------
------------------------------57 Faults Found----------
I think so. Or possibly excessive resistance in connection somewhere; possibly even something like the battery's ground connection.
That's also quite curious. How did it get from 11.6 to 14V in the 3 minutes that it took to run that scan?
theautoconnect
C?ID=512317
Thanks for the insight — that makes sense. Regarding the voltage: I had just started the scan with the ignition on, then cranked the engine shortly after beginning to get the A/C running (it was a very hot day). So the voltage shown at the start (~11.6V) was just prior to start-up, and the 14V reading was once the alternator kicked in after the engine was running. Appreciate the help — I’ll start by checking battery condition, charging output under load, and inspecting the ground and main power distribution points, including the fuse block at the battery terminal.
theautoconnect
C?ID=512317
Quick update — we found an H7 non-AGM battery installed, which is incorrect for this vehicle. We replaced it with the proper H9 AGM, and that immediately cleared the Steering Malfunction warning. Most voltage-related faults have not reappeared since.
However, the rearview camera is still non-functional — scan still shows it as “Cannot be reached,” so we’re assuming the camera module may be faulty or disconnected, and we’ll be digging into that next.
As for the rear lighting, it's still acting erratically: sometimes the hatch-mounted tail lights work while the bumper-mounted lights are out, and other times it’s the reverse. We’re beginning to suspect a possible issue with a rear hatch position sensor or a fault related to the rear door electronics, but still need to do more investigation.
If anyone has run into similar behavior on the MLBevo Q7 platform, we’d appreciate any direction or known weak spots to check.
Tuesday,17,June,2025,07:30:25:59036
VCDS Version: 25.3.1.2 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250604 DS365.0
VIN: WA1LAAF7XHD009209   License Plate: Q7Q7Q7
Mileage: 171547km-106594mi   Repair Order:
VIN: WA1LAAF7XHD009209   Mileage: 171547km-106594miles
   VCID: 2D0C6687DDEF57A214F-8178
          P052E 00 [01100101] - -
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 16:53:01
                    Engine speed: 682.50 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 89  C
                    Intake air temperature: 49  C
                    Voltage terminal 30: 13.847 V
                    Air mass: 15.46875 kg/h
                    Pressure upstream of throttle valve: corrected: 1.029 bar
                    Charge press.: average: 0.418 bar
                    Throttle valve angle: 2.772
                    Ambient air pressure: 1.030 bar
                    Outside temperature: 37.0  C
Readiness: 1010 1101
   Coding: 100000
   VCID: 3D2C56C70D8FC722A4F-8168
   VCID: 3FD02CCF0783D532B63-816A
   VCID: 75BC8EE7753F5F62ACF-8120
   VCID: 659CDEA7C59FAFE21CF-8130
   VCID: 0052EF333AFD6ACA8F9-8154
   Coding: 1BC7F7
   Coding: 02006E
   Coding: 350000
   Coding: 030000
   Coding: 020100
   VCID: 323675FBC4D1085A49D-8166
   VCID: 392442D719A7FB02887-816C
   Coding: 88001B
   Coding: 88001B
   VCID: 7EAE91CB40091C3AFD5-812A
   VCID: 2E0E618BD0E92CBA2D5-817A
   VCID: 0944F21709C72B82D87-815C
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 16:51:50
8531970 - Quiescent Current
          U1406 00 [00001000] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 202
                    Mileage: 171547 km
                    Date: 2025.06.17
                    Time: 01:30:18
                    Total static current-current total quiescent current: 70 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
   VCID: 353C4EE735BF1F626CF-8160
   VCID: 78A287D3622D220AB79-812C
   Coding: 1EC002
   VCID: 343A73E33EC5066A5B1-8160
   VCID: 42D6253B7471B8DAD9D-8116
   VCID: 333870FF3BCB015242B-8166
   VCID: 21148AB7913783C2A07-8174
0527 - Subwoofer
          B106C 13 [00001001] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 23:26:21
                    Voltage terminal 30: 12.6 V
   VCID: 3C2A5BC31695CE2A931-8168
   VCID: 3E2E51CB0089DC3ABD5-816A
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 16:51:54
   VCID: 363E49EB28B9147A655-8162
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [00001001] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.17
                    Time: 07:26:48
                    Voltage terminal 30: 12.3 V
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 16:51:54
                    Voltage terminal 30: 14.2 V
 3      { Q
   ROD: N/A
   VCID: 0E4EC10B70A90CBA0D5-815A
 3  " (AU73)
   Coding: 00B0
   VCID: 065EF92B18D944FAB55-8152
   VCID: 261E99ABF81964FAD55-8172
   VCID: 30327FF3CADD3A4A3F9-8164
   VCID: 2F307C8FD7E325B2263-817A
   VCID: 41D42A377177A3C2C07-8114
                    Reset counter: 162
                    Mileage: 171547 km
                    Date: 2025.06.16
                    Time: 16:51:54
   VCID: 73B8B0FF7B4B415282B-8126
   Revision: --------
   Coding: 1EC002
   VCID: 31347AF7C1D73342307-8164
   VCID: 167EA96B4879F47A455-8142
   VCID: 167EA96B4809F47A455-8042
End----------(Elapsed Time: 03:05, VBatt start/end: 12.2V/12.1V)-----------
------------------------------8 Faults Found-------------------------------
VCDS talks to it:
3 { Q<br> ROD: N/A
No ASAM data for: " H ?ʲ ) j 5" (AU73)
But that looks all fouled up, i.e. faulty to me.
MasterTommy
Amsterdam
C?ID=295586
the taillight switchover to the bumper mounted backups is done based on if the tailgate is open or closed, the switch for this is located behind the flap in the floor where the tailgate latches on to. It’s a pretty common issue for debris to build up behind this flap which starts to interfere with the functioning of the switch and lead to the behavior you described. Usually sticking a vacuum in there and maybe using a brush to clean it will solves the issue. In rare cases you’ll need a new switch. There is also a TSB about this.
