Here is a virgin scan of my car. Hope it helps...
Sunday,29,November,2015,12:25:03:34677
VCDS Version: 15.7.1.0
Data version: 20150904
VIN: 3VW547AU0GM005nnn License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 32 3C 42 44 52 55 5F
75 A5 A9
VIN: 3VW547AU0GM005nnn Mileage: 10011km-6220miles
Address 01: Engine (J623-CXCB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091900322444002F1000
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
ROD: EV_ECM20TFS0205G0906259D_VW37.rod
VCID: 2F2ED828769A3946F4-807A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 51665000000053
Coding: 01FA6BA154200971007C020941C76880D62A9000408216B6144350D3C089
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 4BD6ACB8E2426566F8-801E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0369570949
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A38F97CBDD8ECEE53-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014200100000105000012111402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 42C8819CD508A42E0B-8016
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86581905152742
Coding: 00110A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00219
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7AB8397CFD582CEE13-802E
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150511 043 0581
Serial number: 150702164005
Slave 2:
Component: RLHS 037 0059
Serial number: S2Y15M05D13H18M37S03
Coding: 90A8DD
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03694815821801152210
Coding: 181803
Reset counter: 113
Mileage: 9964 km
Date: 2015.11.28
Time: 09:06:49
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431513902052
Coding: 0031165001
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 47DE9088FE2A8106DC-8012
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0400
Serial number: 09031503211887
Coding: 01004600FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
ROD: EV_ACCMRRBoschVW372_AU37.rod
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H16 0120
Serial number: 23051541350080
ROD: EV_DRCONTITEMIC.rod
VCID: 373EE0488ECAF186AC-8062
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR022PFG
Seat occupant detection; front passenger side:
Component: BF-Gewichtss. H11 0021
Serial number: IBH0000J15000320NX03
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 000 206 15
Serial number: 35700000000FA9A4E41$
Subsystem 3 - Part No SW: ----------- HW: 480 002 805 15
Serial number: 35800000000AA999749/
Subsystem 4 - Part No SW: ----------- HW: 480 401 905 15
Serial number: 3510002AB1A2DCD13157
Subsystem 5 - Part No SW: ----------- HW: 480 401 805 15
Serial number: 3520002A31A2DCD443CD
Subsystem 6 - Part No SW: ----------- HW: 480 402 605 15
Serial number: 3550002BD1B0CB3453DG
Subsystem 7 - Part No SW: ----------- HW: 480 402 605 15
Component: FrontSensor_P 001 6149
Serial number: 3560002BB1B0CB33A34A
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150523400998
Coding: 0C00
Shop #: WSC 66564 385 16448
ROD: EV_SMLSVALEOMQB.rod
VCID: 73A61458DA325DA650-8026
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 0BAD0912FD98CF0502886A0B5000000000000000
VCID: 2C14CF24478C425ED1-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 21051510001532
Coding: 0101000830085900FB00023B880F00000001050000000000000000000000
Shop #: WSC 00066 790 07029
ROD: EV_GatewConti.rod
VCID: 75A22A40D44643967E-8020
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H10 0040
Serial number: 29150000496150085124
Coding: 34FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000138082003
Coding: 5500000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3424D7449FBC1A9E89-8060
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00026.02.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0369578077
Coding: 02011103
ROD: EV_HREntryHella_SK37.rod
VCID: 3C34FF64B7ECD2DE41-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 15061506050BEX
Coding: 003E13200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 43C68498CA12AD2600-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001408039
Coding: 011000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9302
ROD: EV_SteerAssisMQB.rod
Component: TSG BFS 020 0041
Serial number: 110615060502XD
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001440394
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021203010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40CC8B94DB04B63E1D-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0241
Serial number: VWZAZ2R0243776
Coding: 027300020000000051220002001808001F0203F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71AA1E50A02E6FB6A2-8024
Media Player Position 1:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC0017U
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Shop #: WSC 00066 790 00322
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000359331
Coding: 0100000000020306000400010100000100
ROD: EV_MFKBoschAU370_AU37.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150512201147
VCID: 6B960C388202856698-803E
End-------------------------(Elapsed Time: 03:47)--------------------------
