Hi,
Got a 2018 Tiguan with no sound from AM?FM or DAD due to no signal.
Three fault entries for antenna amplifier 1,2 and DAB 1
Does anyone know if theres one that does all three ? On the boot lid under the trims there are 4 antenna amps but im struggling to find which one does what.
Wednesday,11,June,2025,13:27:14:13861
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WVGZZZ5NZKW306189 License Plate:
Mileage: 186921km-116147mi Repair Order: Tiguan
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 22 29 39 42 44 4B 52 5F 75 A5
BB BC CA D6 D7
VIN: WVGZZZ5NZKW306189 Mileage: 186921km-116147miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 QT HW: 04L 907 309 P
Component: R4 2.0l TDI H25 6582
Revision: B4H25--- CVN: BEB663CA37C5C2A218229D33
Coding: 0125001203661D082000
ASAM Dataset: EV_ECM20TDI01104L906026QT 004006
ROD: EV_ECM20TDI01104L906026QT.rod
VCID: 0C467BF2D6C8353AE32-8058
VINID: 9E65EAAAA15EA9B9C300604824FC210570
Part No SW: 0GC 300 012 E HW: 0GC 927 711 H
Component: GSG DQ381 H06 2301
Revision: 00H06V08 CVN: 36DF74E8
ROD: EV_TCMDQ381061.rod
VCID: 25102E5655626472DCC-8070
No subsystems:
Part No SW: 5Q0 614 517 DE HW: 5Q0 614 517 AD
Component: ESC H25 0524
Revision: 00000000 Serial number: 61958000000100
Coding: 0AEE929A34200B724778070862CC4950492CD0E2E046927D38625078C22A420B002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 77AC341EBF4E26E2BE0-8022
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NC 907 044 H HW: 5NC 907 044 H
Component: AC Automat H35 4301
Revision: 20K09000 Serial number: 00000E00963369
Coding: 00120124202110011105100C0010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 46D289DA88248F6AF56-8012
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001820800636 Dataset Number: V03935309MV 0001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7DA026369D720CB2E4C-8028
Subsystem 1 - Part No SW: 5NC 955 119 A HW: 5NC 955 119 A Labels: 1KX-955-119.CLB
Component: 326 RL 020718 033 0372
Serial number: 00000001806270304563
Component: RLHS 052 0107
Serial number: S7Y18M08D06H01M32S57
Coding: 00A8DD
Serial number: 000000000ZY181970T57
Serial number: 00000000000099264553
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 E HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0160
Serial number: 0100200720180C200278
Part No SW: 3Q0 919 294 E HW: 3Q0 919 294
Component: PDC 8 Kanal H08 0046
Serial number: 001607187498040 Dataset Number: V03935296TM 0001
Coding: 0071451811
Shop #: WSC 41608 003 1048576
ASAM Dataset: EV_EPHBO18VW3260000 007021
ROD: EV_EPHBO18VW3260000.rod
VCID: 3B24E82EC3E6C2829A8-806E
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0233
Dataset Number: V03935279GP 0001
Coding: 320067C158FF8728749C8145804087
ROD: EV_ACCMRRCONTIVW376_002_VW37.rod
VCID: 3E22E13AD0F4D7AABD6-806A
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 119
Mileage: 186909 km
Date: 2025.05.28
Time: 09:36:45
Voltage terminal 15: 9.6 V
Control Module temperature: 14 ∞C
Longitudinal_acceleration_vehicle_reference: -0.03 m/s≤
Status_ACC_System: ACC_Init
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4EPT5+ Dataset Number: V03935268MW 0001
Coding: 98CCC0C00C0000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
VCID: 094842E6D9BA2012D84-805C
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 5NC857705C0211S01218
Coding: 80000D
Right seat belt tensioner:
Component: BeltPretRevFR 106 1040
Serial number: 5NC857706C0212S00173
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 008 18
Serial number: 35700000000636BCF33V
Subsystem 4 - Part No SW: ----------- HW: 480 001 008 18
Serial number: 35800000000536BCF33V
Subsystem 5 - Part No SW: ----------- HW: 480 401 608 18
Component: SideSensor_Dr 004 6149
Serial number: 3510001142B78F3373C0
Subsystem 6 - Part No SW: ----------- HW: 480 401 808 18
Component: SideSensor_Pr 004 6149
Serial number: 35200011A2B72204334H
Subsystem 7 - Part No SW: ----------- HW: 480 401 008 18
Component: FrontSensor_D 004 6149
Serial number: 3550001062B73AD5122X
Subsystem 8 - Part No SW: ----------- HW: 480 401 308 18
Component: PedP_Sensor_D 004 6149
Serial number: 22800010E2B76CF4F7AU
Subsystem 9 - Part No SW: ----------- HW: 480 401 308 18
Component: PedP_Sensor_P 004 6149
Serial number: 2290001302B78F33C260
Subsystem 10 - Part No SW: ----------- HW: 480 401 308 18
Component: PedP_Sensor_C 004 6149
Serial number: 23000010E2B76CF4F77K
Subsystem 11 - Part No SW: ----------- HW: 480 001 408 18
Serial number: I0M000000002BC70733%
Subsystem 12 - Part No SW: ----------- HW: 480 001 408 18
Serial number: I0N000000008AC707335
Part No SW: 5NA 920 791 C HW: 5NA 920 791 C
Component: KOMBI 403 4191
Coding: 27A400086F84060001886B031401000800000000
VCID: 43D490CEBB16BA42D28-8016
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008245090 Dataset Number: V03935286KX 0001
Coding: 030500045F087300FB17225E1A0F00010001070000000000000000000000
GVL: 01C63C0000000000408C80008000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D20E636DDF2CCB2A4C-8068
Generator:
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 1931820375802203FF2B
Coding: 2F0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 5242828604
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00005.07.18 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CC6BBF29648753A232-8018
16666 - Pump for Haldex Clutch
C1112 13 [00001000] - Open Circuit
Reset counter: 122
Mileage: 186909 km
Date: 2025.05.27
Time: 16:00:11
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D08ED6B5228472FCC-8010
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RH22424A Dataset Number: V03935278PU 0001
Coding: 003F0220D001048000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 44D693D2BE18BD7AEB2-8010
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Dataset Number: V03935287QL 0001
Coding: 91170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B4000EAB364AC2828-8026
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0342
Serial number: 23071811601535 Dataset Number: V03935275YQ 0001
Coding: 00000005090008CE00104F010A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002004
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3530FE16E5C214F26CC-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RGD04404 Dataset Number: V03935278PW 0001
Coding: 003F0020DC01048000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0890
Serial number: Dataset Number: V03935281HF 0001
Coding: 02730601FF00000051110101008808001F0500E6012000008E
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 323AC50A14AC03CA49E-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV1901456
Subsystem 2 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
0005 - Antenna Amplifier 1 for Radio
B126D 13 [00001001] - Open Circuit
Reset counter: 82
Mileage: 186921 km
Date: 2025.06.11
Time: 13:22:49
Voltage terminal 30: 14.3 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 20 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [00001001] - Open Circuit
Reset counter: 82
Mileage: 186921 km
Date: 2025.06.11
Time: 13:22:48
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 20 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
B1270 13 [00001001] - Open Circuit
Reset counter: 82
Mileage: 186921 km
Date: 2025.06.11
Time: 13:22:49
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 1.315712
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 15.435017
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0824
Revision: -------- Dataset Number: V03935287ZQ 0001
Coding: 02230601EA42380D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW25.rod
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 16081815K12566 Dataset Number: V03935276EA 0001
Coding: 0003070600000401000213448150A90094000E200040
VCID: 3C26EB32C6E8C5BA932-8068
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RGQ09488 Dataset Number: V03935278PX 0001
Coding: 002A00200100048000001000
VCID: 4EC2B1FA6054472A4D6-801A
Component: TSG HBFS003 0187
Serial number: YE007RGQ09251 Dataset Number: V03935278PZ 0001
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Dataset Number: V03935279TX 0001
Coding: 708040732602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B03E16A54254F2ACC-8020
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 005E5FC2EA80615A8FA-8054
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.1V)-----------
------------------------------5 Faults Found-------------------------------
