- Apr 23, 2023
- 76
- 9
- Pennsylvania, USA
- C?ID=549110
So I set my service interval to 5k miles and it worked and notified me at 5k miles. I then used vcds to reset it and during the next 5k miles my abs pump failed and I replaced that 5 times until I figured out what was wrong. The problem was a bad connection on the back of the instrument cluster. I sprayed deoxit contact cleaner on it and it fixed the abs problem. In that repair time I did disconnect the battery. Fast forward to the 5k service point and the car did NOT NOTIFY ME.
Does the service reminder stop working if the battery is disconnected? Does it stop if the instrument cluster is dissconnected?.
I then changed my oil and used vcds to reset it via instruments (46?)and when doing it that way a certain sequence must be followed. I forget off the top of my head what the sequence is. So hypothetically as close as I can remember 42, 44, 43, 47, 45, 46, 49, 48. When I went to do that 2 of thoes 4x numbers, aka 42 and I think 46 gave errors. But I finished and the vcds said completed successfully...
There presently are zero errors on the vcds scan.
Any gurus have anything to assist?
