Mk6 GLI LED Taillight Retrofit and Coding
jbarth09
C?ID=186457
I currently own a 2013 mk6 GLI Autobahn W/nav.
I am attempting to retrofit the VW OEM LED Taillights that come on the 2013 Hybrid model and now the 2013.5 and on GLI. I have purchased them from here
http://forums.vwvortex.com/showthread.php?5980996-Jetta-LED-Taillights-with-Adapter-Harness
In the thread it explains to code byte 18 to 53 which for me lead to Errors. From my research I have found that everyone that has successfully done this retrofit has a CECM with a part number ending in 86. I have discovered that mine ends in 87. Below is the autoscan of just the 09 Central Electronics.
Tuesday,06,May,2014,19:14:20:56121
VCDS Version: Release 12.12.2
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 087 T    HW: 5K0 937 087 T
  Component and/or Version: BCM PQ35 H    021 0068
           Software Coding: 6F200ABF942F0EC40088008300000BC44704B40856808DB2E4  866000A040
            Work Shop Code: WSC 20312 444 85794
                      VCID: 46ADB6F2F17CD42EE1B-8013
I have tried changing byte 18 to B4 which works with no errors but the lights don't behave as intended. It's the closest but the lights don't get to their full brightness and the running lights across the top and bottom of the lights come on faintly. Here is an image for reference of the design.
Here is the behavior I am getting.
https://www.youtube.com/watch?v=FjIGdqJKsYA
I realize the cameras will typically cause the LED's to flicker. However, I believe intended behavior is to have the C shaped lights come on without the LED "Lines" while the headlight switch is in the off position. The "lines" on the LED's are to come on in the parking light and on position of the headlight switch. Indicators are the C Shaped lights as well.
I can get a full autoscan really really soon. Just wanted to get this up.
Any assistance with this to get the behavior correct would be greatly appreciate.
Jonathan
jbarth09
C?ID=186457
Data version: 20140212
Thursday,08,May,2014,13:26:18:56121
Chassis Type: AJ (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4C 4F
          52 55 56 62 72
VIN: 3VW467AJ7DM426929
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 906 027 FH    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 07 4351
   Revision: P3H07---    Serial number:
   Coding: 0403010A1C070160
   Shop #: WSC 00066 000 00000
   VCID: 76CD0632011C04AEB1B-8023
Readiness: 0100 0100
   Part No SW: 02E 300 058 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3519
   Revision: 05651213    Serial number: 00001211202272
   Shop #: WSC 02069 000 90108
   VCID: 256F117EEC3A3F36C81-8070
   Revision: 00H31001
   Coding: A14B600C49248000851406E692220141B71C00
   Shop #: WSC 20312 444 85794
   VCID: 7DDF191EE42A57F6F01-8028
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0194478623
   Coding: 030C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 3449FC3A9FE056BE4FF-8061
   Part No SW: 3AA 907 044 AN    HW: 3AA 907 044 AN
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010001002
   Shop #: WSC 00066 123 00122
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7CD9141AF7305EFEC7F-8029
   Part No SW: 5K0 937 087 T    HW: 5K0 937 087 T
   Component: BCM PQ35 H    021 0068
   Revision: BK021001
   Coding: 6F200ABF942F0EC400880083000009C44704B40856808DB2E4866000A040
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM0373B4
   Coding: 00004A34
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40A1A0EADB58FA1EDB7-8015
   Serial number: 6940000Y130000PP0U08
   Coding: 303041
   Serial number: 3572MSME74227475ZZZV
   Serial number: 3582MSME61117576ZZZS
   Serial number: 3516KSME7E4A6721ZZZ/
   Serial number: 3526KSME0B4B6B21ZZZ-
   Serial number: 3556LSME6D0D1720ZZZ-
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME711A1720ZZZO
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20121203301222
   Coding: 001A140000
   Shop #: WSC 00066 000 00208
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DDF191EEC2A57F6F01-8028
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0032
   Coding: 830000
   Part No SW: 5C6 920 972 B    HW: 5C6 920 972 B
   Component: KOMBI         H07 0705
   Coding: 071E01
   Shop #: WSC 00066 000 00122
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 2D7FE95E7CCA0776001-8078
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 03011303290567
   Coding: 351002
   VCID: 76CD0632C11C04AEB1B-8023
   Component: IMMO          H07 0705
   Coding: 000007
   Shop #: WSC 45681 000 1048576
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF5A2420DA4504EA53-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000015995002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041F02A6BF86A9E2B7-8065
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7663998420
   Coding: 020100
   VCID: 2A75E2424524104EE53-807F
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H58 0319
   Serial number: VWZAZ2M0026352
   Coding: 04090041010000000000100A
   Shop #: WSC 01383 790 50316
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 256F117E243A3F36C81-8070
   Component: NAR_V3_(0037)  0037
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0006017539
   Coding: 0004B5
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: DB9BF786D2FE39C62E5-808E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007405495
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 3753CB364696BDA66AD-8062
Address 47: Sound System (R12)       Labels: 3T0-035-456.clb
   Part No: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0016988
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 266D1672593C342EC1B-8073
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030100
   VCID: EFC3B3563E46B566F2D-80BA
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Coding: 180000
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0006059175
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: DC99F49AD7F03EFE27F-8089
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1508
   Serial number: 00000007440636
   Coding: 000490
Address 55: Xenon Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 081000010A000200
   Shop #: WSC 00066 123 12345
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 3753CB368E96BDA66AD-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo links  H02 0010
   Coding: 860000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo rechts  H02 0010
   Coding: 860000
here is my full autoscan.
