Brake Disc Wiper (BDW) change
nbdwt73
C?ID=248339
I have a 2014 Audi A7 TDI Prestige. I changed the brake pads to ceramic pads - love them. I have noticed that these pads have a slight burning smell after driving in the rain unlike the original equipment. I have looked at the ABS adaptation for Brake Disc Wiper (BDW) - the current setting is "normal"; I would like to try "low" or "off". After entering the ABS security code (accepted), then changing the BDW entry to something else (low or off) I get a security error - won't let me change it. Is it possible to change?
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAU2MAFC1EN075561   License Plate:
Mileage: 36047km-22398mi   Repair Order:
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90 AC
VIN: WAU2MAFC1EN075561   Mileage: 36047km-22398miles
Address 01: Engine (J623-CPNB)       Labels: 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0004
   Revision: 58H14---
   Coding: 1A2A4012056601050000
   Shop #: WSC 41776 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401N 001005
   ROD: EV_ECM30TDI0114G0907401N.rod
   VCID: 2E53450C71ED7C4EFF-807A
21378 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
                    Mileage: 35954 km
                    Date: 2015.11.27
                    Time: 17:31:37
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H16 1005
   Revision: --H16---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 3C777F44B7919EDE41-8068
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Component: ESP PREMIUM   H09 0450
   Coding: 27A79703E4E5E9C05B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   ROD: EV_ESPPremiAU57X_AU57.rod
   VCID: 3B757C58B29F99E648-806E
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
   Component: BCM2 2.0      H35 0510
   Coding: 0DAA2046000000000000
   VCID: 7CF7BF44FF115EDE01-8028
Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-4Z.clb
   Part No SW: 4G0 820 043 AF    HW: 4G0 820 043 AF
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 17101300040032
   Coding: 3603207A5D
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 63C5E4386AAF812620-8036
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001792118
   Coding: 02002091163C9FE2C1008884A0003928CF9CD308A6080225800008406000
   VCID: 6FED9808BE673546B4-803A
   Component: WWS57X 131001  H36 0080
   Coding: 0045F7
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 L    HW: 4G0 941 531 L
   Component: E1 - LDS  H07 0044
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061328802069
   Coding: A8EB04
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 71E99E70A05323B6A2-8024
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 285FB3145309227E35-807C
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003K43B
   Coding: 303145313131303031304A55304C34473853
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 336554789ACF51A690-8066
   Serial number: 6940000Y130000XZGX02
   Serial number: 3575HRB400650L5EKH61
   Serial number: 3585HRB400Q50N20AOA8
   Serial number: 3515JRB401050NQIT97L
   Serial number: 3525JRB400G50N8AB99
   Serial number: 3554VRB400650NI2N1HD
   Serial number: 3564VRB400650NI2Q9HP
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Revision: --------    Serial number: 90372MJG0006S
   Coding: 0000DC
   VCID: 377D606886B7BD86AC-8062
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 984 A    HW: 4G8 920 984 A
   Component: TDieUsaAccNv  H58 0621
   Revision: 29460233    Serial number: 658111013596012
   Coding: 0BC602060F53D705020100
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 346757649FC1569E89-8060
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001145492
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   ROD: EV_GatewPkoUDS.rod
   VCID: 72EB917CA55518AE5B-8026
   Serial number: 4216191603
   Voltage stabilizer:
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0088
   Serial number: 18101300040311
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 36636D6C89BD448EB7-8062
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 53
                    Mileage: 35179 km
                    Date: 2015.11.25
                    Time: 12:59:39
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000078113253
   Coding: C0581B008F006001000001010101102030303232203232
   VCID: 387F63548BA9B2FEA5-806C
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA820568N3
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0060
   Revision: 00H04000    Serial number: 6PZ 010 287-08
   Coding: 0000007
   VCID: 36636D6C41BD448EB7-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H04 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F16.10.1300H04000AMS14394ÿ
   Subsystem 4 - Serial number: S14394ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F57025E00628002000413
   VCID: 45811AA0CC5BDF162E-8010
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H39 0010
   Revision: 00001000    Serial number: 0015952690
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 326B517C65D558AE9B-8066
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0317714650
   Coding: 0126063A20FAF08580A00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Revision: CJ007001    Serial number: 00000000044495
   Coding: 030000
   VCID: 1D3192C0044BF7D656-8048
   Component: TSG BF        H03 0507
   Coding: 011F57025E00628002000402
   VCID: 46831DACF15DD40E27-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000845530
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2C574F0447F10E5ED1-8078
Address 55: Headlight Range (J431)       Labels: 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 131013-0004-092
   Coding: 1223A633701AA500
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
   Revision: AB001007    Serial number: 156J00D7922039
   Coding: 020007010000000001
   VCID: 2447A7242721C61E19-8070
   Part No SW: 4G0 035 746 H    HW: 4G0 035 746 E
   Component: H-BNT-NA      H40 0902
   Revision: --------    Serial number: 194JH0D7559957
   Coding: 090200040003EDEF7D16CB3E00000003100001000000000000
   VCID: 2C574F044FF10E5ED1-8078
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Component: CD-Database  5298
   Component: TSG HL        H03 0507
   Coding: 010F17024000628002000002
   VCID: 49991690E0433B76CA-801C
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0113571
   Coding: 0205000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
Address 6D: Trunk Elect. (----)       Labels: Redir Fail!
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 278301129
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 448707A4CF61E61E39-8010
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4G8 919 604 K    HW: 4G8 919 604 K
   Component: HeadUpDisplay 004 0201
   Coding: D60000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H10 0042
   Serial number: 0K84AE40102048
   Coding: 1411
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001323800244
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2643BD2C591D340E07-8072
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01010201
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X.rod
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121110137
   Coding: 03C198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 31695E7060D363B6E2-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 132000253
   ROD: EV_RDCMA00100.rod
   VCID: 2B554C1842FF0966D8-807E
Hmm.. We have access to an almost identical ABS module in an A6. Will try to remember to see what we can see.
Bump this thread in a few days if you don't hear anything back.
nbdwt73
C?ID=248339
Bump this thread
OK, confirmed, the security access in the pop-up doesn't unlock that channel. But the ubiquitous ABS one does. Try: 40168.
nbdwt73
C?ID=248339
I meant to say "thanks" for this... It worked...
