Good day, I have a very, very strange and unusual problem with my car. There are multiple errors that don’t make any sense to me. I think it would be best to start from the beginning, to explain how it all started.
Last year in October, the air conditioning started behaving strangely. At first, it wouldn’t blow any air at all. Then, after a week, it started working normally for a few days. After that, the passenger side began blowing cold air even though it was set to heat. Two days later, it returned to normal.
Shortly after that, a start-stop system error appeared on the display near the steering wheel. Then, five days later, a new yellow battery warning appeared, saying it wasn’t critical, but should be checked by a mechanic.
At that point, I started researching what the problem might be, and various potential issues came up. I tried disconnecting and reconnecting the cable that goes to the battery’s negative terminal sensor, and the yellow battery warning disappeared.
After all that, we tried to use the rear window defroster (which we normally don’t use), but it didn’t work.
I then bought three different diagnostic tools and replaced the sensor on the battery’s negative terminal, but the error about no communication with the sensor remained. In the meantime, the original battery completely failed. I installed a new Varta battery, but I can’t code it into the system, likely due to the same errors I’ll show later.
I tried testing the LIN wire on both the alternator and the sensor on the battery’s negative side — both are measuring 9.8V with the engine running but the car idling.
Another thing that I found very interesting: I removed the flap motor from the AC system (which was flagged as a mechanical fault), tested it outside its housing, and it worked fine. After reinstalling it, it worked normally for a few days, then the mechanical fault reappeared.
From what I can see, there are two persistent errors: one for basic settings, and another for the motor that brings in fresh air.
One more thing: last week, the flap motor on the driver’s side completely jammed — it wouldn’t respond no matter what I did. And now, all of a sudden, it’s working perfectly again.
Thanks in advance to everyone for any advice or help on what to do.
Sunday,18,May,2025,13:25:38:11961
VCDS Version: Release 25.3.1 (x64) Running on Windows 11 x64
Address 19: CAN Gateway Labels: None
Control Module Part Number: 8W7 907 468 E HW: 8W7 907 468 E
Component and/or Version: Gateway H42 0116
Software Coding: 03010001000006C041070000005900325C3A0007100000000175079E10000000
Work Shop Code: WSC 12345 123 61029
ASAM Dataset: EV_CGateCONTIAU491 003092 (AU49)
VCID: 4DC3B89DBD53F5F234D-8018
197149 - Generator
U1052 00 [00001001] - No Communication
[Break_Down_LIN_Communication_Alternator]
Reset counter: 109
Mileage: 164902 km
Date: 2025.05.17
Time: 21:34:39
197175 - Control unit for battery monitoring
U1050 00 [00001001] - No Communication
[Break_Down_LIN_Communication_Battery_Monitoring]
Reset counter: 109
Mileage: 164902 km
Date: 2025.05.17
Time: 21:34:39
Sunday,18,May,2025,15:52:25:11961
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
Gateway Installation List: 8W7 907 468 E
