- May 18, 2025
- 11
- 1
- Indiana, USA
- C?ID=619839
Sunday,18,May,2025,13:52:40:16594
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: 1VWCN7A3XDC026915 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A3XDC026915 Mileage: 238520km-148209miles
52-Door Elect, Pass. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H23 9982
Revision: 71H23--- Serial number: CVN: D240C61F5C3E0D04
Coding: 001D0012042400008000
Shop #: WSC 03340 444 12345
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B24E91853E1ADF29A8-806E
VINID: 0669D3787443A144C008624114C7C0464E
5169 - Manifold Pressure / Boost Sensor (G31)
P0238 00 [10100111] - Signal too High
Mileage: 238525 km
Date: 2025.05.18.
Time: 02:30:41
Engine speed: 0.00 /min
Coolant temperature: 20 °C
Intake air temperature: -40 °C
Voltage terminal 30: 11.360 V
Charge air pressure: actual value: 3000 hPa
Engine status: COENG_READY
5282 - Intake Air Temp. Sensor (G42)
P0113 00 [10100111] - Signal too High
Mileage: 238525 km
Date: 2025.05.18.
Time: 02:30:41
Exhaust gas temperature sensor 4: 21.9 °C
Specified value of low pressure exhaust flap: 100.00 %
Actual value of low pressure exhaust flap: 106.45 %
Low-pressure exhaust flap: offset closed: 1.14 %
Low-pressure exhaust flap: status-Bits 0-7: 55
Low-pressure exhaust flap: status-Bits 0-7: 0
Low-pressure exhaust flap: status-Bits 0-7: 11
Exhaust flap: actual value: 4535.6 mV
Readiness: 0 0 0 1 1
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9436
Revision: 05551213 Serial number: 00001207030631
Shop #: WSC 09003 957 00200
VCID: 24163264C2DFF20ACB2-8070
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: C54BC0F549240000A31403E5921E0042A71000
VCID: 7DA027000DF563C2E4C-8028
Reset counter: 18
Mileage: 238525 km
Date: 2019.09.24.
Time: 02:39:24
Count: 7
Count: 13
Count: 20480
Count: 128
Count: 30720
Count: 255
Reset counter: 20
Mileage: 238525 km
Date: 2019.10.03.
Time: 00:00:32
Count: 2
Count: 12
Count: 20992
Count: 16390
Count: 48384
Count: 768
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 085 0902
Revision: 00085000 Serial number: 0173106923 Dataset Number: 5K0116v____ 560E
Coding: 130C0C
ROD: EV_KESSYPQ35G_A02_VW41.rod
VCID: 3436C2247EBF628A5B2-8060
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.03.
Time: 02:57:43
65813 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:44:47
1057287 - Antenna for Keyless Entry System; Passenger Side
B1170 11 [00001000] - Short to Ground
Reset counter: 60
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [00001000] - Open Circuit
Reset counter: 58
Mileage: 238525 km
Date: 2025.05.03.
Time: 03:09:27
1057803 - Antenna for Keyless Entry System in Trunk
B1173 13 [00001001] - Open Circuit
Reset counter: 20
Mileage: 238525 km
Date: 2025.05.03.
Time: 02:39:12
Part No SW: 561 907 044 M HW: 561 907 044 M
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0010001012
VCID: 21183B70D14DE722A04-8074
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0168
Revision: BL121001
Coding: 6F200E1B982B08D408880201360085480071008645A005F0648060009C70
VCID: 74B602243EBF228A9B2-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 310512 05 54 0403
Coding: 22300A
13 Faults Found:
Fault Status: 00101011
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:10:38
Term 15 Off
Voltage: 12.20 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:44:30
Voltage: 8.50 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:45:30
Voltage: 8.35 V
Fault Status: 00101001
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:11:37
Term 15 Off
Voltage: 12.20 V
Reset counter: 21
Mileage: 238525 km
Date: 2019.10.09.
Time: 00:08:23
Voltage: 11.90 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:11:30
Term 15 Off
Voltage: 12.15 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:11:30
Term 15 Off
Voltage: 12.15 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 18
Mileage: 238525 km
Date: 2019.09.24.
Time: 02:39:17
Voltage: 11.50 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:43:39
Voltage: 8.75 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:07:04
Term 15 Off
Voltage: 12.25 V
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:10:38
Term 15 Off
Voltage: 12.20 V
02743 - Bulb for Brake/Turn Signal Light; Right
Reset counter: 18
Mileage: 238525 km
Date: 2019.09.24.
Time: 02:39:16
Voltage: 11.35 V
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 18
Mileage: 238525 km
Date: 2019.09.24.
Time: 02:39:16
Voltage: 11.35 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM03HEX0 Dataset Number: 560003v__A_ 0124
Coding: 00004D48
Shop #: WSC 13576 002 1048576
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBC0D4857190152660-803A
Serial number: 6940000Y120000HVSE0H
Coding: 303047
Serial number: 3572MSME3A29756BZZZ3
Serial number: 3582MSME4B333668ZZZ
Serial number: 3516KSME5C441F1DZZZ1
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME05251B1DZZZS
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME1013541CZZZL
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME670B4A1CZZZ3
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:40:34
B10B4 00 [00001000] - Function Restriction due to Undervoltage
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:39:50
B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:38:53
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120718301735
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA027000D7563C2E4C-8028
Component: E221__MFL-YVJ H06 0022
Coding: E20000
114178 - Function Restricted due to Insufficient Voltage
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:47:21
136194 - Supply voltage
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:46:27
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 E HW: 561 920 970 E
Component: KOMBI H07 0705
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1C660A84F62FCACA732-8048
[Supply voltage too low]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:44:59
Part No SW: 7N0 907 530 T HW: 7N0 907 530 K
Component: J533 Gateway H40 1632
Revision: H40 Serial number: 29071203291286
Coding: 461000
VCID: 41D89BF0318DC722C04-8014
Fault Status: 00110100
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:11:27
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 01:11:27
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:46:11
Component: IMMO H07 0705
Coding: 000007
VCID: 6A8A1C5C6CFBE47A31E-803E
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000146513002
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW41.rod
VCID: 2F3CCD4897994152260-807A
[Under voltage (continued)]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:42:08
ELV State: 0C
Information Clamps: 77 60
CoCo State: B0 01
WFS State: 67 1A
Vehicle speed: 0.00 km/h
Voltage: 4B
[Under voltage (temporary)]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.03.
Time: 02:39:20
ELV State: 0C
Information Clamps: 77 64
CoCo State: F0 01
WFS State: 67 1A
Vehicle speed: 327.25 km/h
Voltage: 49
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662893504
Coding: 010100
VCID: 2A0ADC5CACFB247AF1E-807E
Reset counter: 61
Reset counter: 61
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000032423518
Coding: 00581B0000000000000021010100202020202120202020
VCID: 609E7E749A47AE2AEFA-8034
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:45:28
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 G HW: 3C0 035 684 G
Component: RNS-MID H02 3696
Revision: AB001001 Serial number: VWZ6Z7M5197063
Coding: 04090042010000A6000B
VCID: 270C2568BFE91912EE0-8072
Fault Frequency: 32
Reset counter: 21
Mileage: 238520 km
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:41:19
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:39:21
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0005236908
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
65537 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Passenger DCU Time-out]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 01:11:27
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 61
65793 - Supply voltage
[Front DCU undervoltage]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:45:40
131584 - Motor for Rear Window Regulator
B11EE 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 18
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 290 3305
Revision: 00H22000
VCID: 372CF528634989927E0-8062
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.5 V
PD
Temperature: 33.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0029315 Dataset Number: 560050v____ 5604
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 65906F6085E5CB021CC-8030
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:44:09
Part No SW: 7N0 907 532 HW: 7N0 907 530 K
Component: EZE_2 H40 1632
Coding: 01030108
VCID: 6FBC0D4857990152660-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011214402405
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0005233470
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D600780ED35C3C284C-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Reset counter: 61
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:44:58
Reset counter: 18
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:41:19
Reset counter: 61
Mileage: 238525 km
Date: 2019.10.09.
Time: 14:39:21
Fault Frequency: 32
Reset counter: 21
Mileage: 238520 km
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663149216 Dataset Number: 7P6035730K 0001
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002_VW25.rod
VCID: 3A2AEC1C5CDB94FA81E-806E
[Terminal 30: lower limit value not reached]
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:45:47
Reset counter: 61
Mileage: 238525 km
Date: 2025.05.18.
Time: 14:45:41
End----(Elapsed Time: 01:27, VBatt start/end: 11.4V/11.3V. VIgn 11.4V)-----
------------------------------53 Faults Found------------------------------
Here is the auto scan..
Back story, I changed injectors due to loss of power and throttle response. figured it was time anyways. I replaced injectors and went ahead and replaced valve cover gasket and new but used valve cover. went to code injectors and i got injector 1 coded just fine. With that said no other injector would code. Kept the injector coding the saME as old ones. started the vechile, it took awhile it would turn over and start thenn stumble and eventually die. after serveral attempts of starting the vechile it would idle but rough then clear up. would put the car in drive and it would fall on its face and jerk without moving i would hit throttle while in drive with no response it would eventually die. Car in park with foot on accelerator engine would sound fine. No glow plug light flashing and the car wont even start! any help would be appreciated thank you. also change fuel filter.
