Caddy 06 ABS failure after bad battery
Timpan929
Sweden
C?ID=555733
Hello guys, have some wierd problems with an caddy 06, after a bad battery abs module got many faults, and the front left sensor saying its bad but have changed it, the sensor showing all kinds of values on standstill, and the speedometer is going up and down, have cleand the connection and there ia power to it,
First time posting hopefully i dint do it wrong please tell if so
Sunday,18,May,2025,12:04:31:34315
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2KZ6X009766   License Plate: WZH089
Mileage: 324050km-201355mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 69
VIN: WV1ZZZ2KZ6X009766   Mileage: 324050km-201355miles
Address 01: Engine        Labels: 036-906-032-AXP.lbl
   Part No SW: 036 906 032 BD    HW: xxxxxxxxxxx
   Component: BOSCH ME7.5.10      7295
   Revision: --------    Serial number: VWZ7Z0E2242799
   Coding: 0000031
   Shop #: WSC 35110 377 00162
   VCID: 53F36E4B97FD2822B21-8006
   VINID: 9E606AAAA09BA86A000091C6180EA7C242
28793 - No Communication with ABS Brake Control Module
            U0121 - 008 -  - Intermittent - MIL ON
16885 - Vehicle Speed Sensor
            P0501 - 004 - Implausible Signal - MIL ON
29087 - Implausible Data Received from ABS Control Module
            U0415 - 008 -  - Intermittent
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.clb
   Part No: 1K0 907 379 P
   Coding: 0017106
   VCID: 3FDB52FB0B75DC42669-806A
9 Faults Found:
01312 - Powertrain Data Bus
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
01130 - ABS Operation
00003 - Control Module
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000005019156
   Coding: 088CCF030004100000000000000000000008FB075C
   Shop #: WSC 35110 377 08192
   VCID: 2A0D13AFE0F749EA217-807E
   Subsystem 1 - Part No: 2K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 176
                    Mileage: 324057 km
                    Voltage: 13.50 V
01800 - Light Switch (E1)
                    Reset counter: 176
                    Mileage: 324057 km
                    Voltage: 12.10 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD075VS.
   Coding: 0012345
   VCID: 7DA7E8F341F90E52345-8028
   Part No SW: 1K0 953 549 AE    HW: 1K0 953 549 AE
   Component: Lenksäulenmodul 034 0070
   Coding: 0000002
   VCID: 75B7F0D379C956127C5-8020
   Part No: 2K0 920 842
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0017101
   Shop #: WSC 80093 222 69422
   VCID: 6695A79F346FAD8AC5F-8032
            013 - Check DTC Memory
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010560705C5
   Coding: 3D0F4140079000
                    Reset counter: 176
                    Mileage: 324057 km
                    Time: 02:34:10
   Component: IMMO            VDD 1012
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2315
   Coding: 0000048
   VCID: 363537DF244F1D0AB5F-8062
Address 44: Steering Assist        Labels: None
   Part No: 1K1 909 144 B
   Component: EPS_ZFLS Kl.5   D04 1606
00625 - Vehicle Speed Signal
                    Mileage: 4040 km
                    Temperature: 10.0°C
                    Voltage: 14.40 V
                    Voltage: 14.20 V
   Part No: 1K0 959 433 AK
   Coding: 00890C087F2D8405484A016010C0
   VCID: 79AFFCE355D1327218D-802C
   Part No: 1T0 959 702 B
   Coding: 0000048
   VCID: 372B3ADB2345E402AE9-8062
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No: 1K0 035 186 P
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2E1322415
   Coding: 0020200
   VCID: 33330ECB373D0822921-8066
Address 69: Trailer
End----(Elapsed Time: 00:58, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Address 03: DTCs cleared
Address 01: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 44: DTCs cleared
