Q7 B&O issue
nemduma
Azusa, CA, USA
C?ID=442266
2015 audi q7 prestige with B&O
Story (sorry for being long, I just want to describe the situation best)
I purchased the car a few months ago from an auction where it was sitting for 8-9 months (totally dead battery).
Upon receiving the car, I started to charge the battery and jump started the car, fired right up, pulled the codes, cleared them, some went away, some stayed, but the B&O was working.
When the car was fixed (front bumper and hood swapped) I washed the car, and that's when the shit hit the fan, leaking sunroof drain.
Everything seems fine, but it showed for the volume: "currently unavailable"
I was confused a bit, cos the battery was replaced and coded, and I thought it was problem, but the old (OEM varta) battery was put back, with the original coding...
Sent the unit out for repair (swapped over one from my old q7, it was somewhat working but showed "component protection active") .
Received the original now fixed B&O back, drain was cleaned, and a protective plastic shield was installed above, so no water can leak in....
Turned it on, it was working, sounded amazing, cleared the codes, all good. Next day showed it to the wife, she was happy too.
I was about to finish the PCV replacement, bleeding the coolant system, about to start the car, ignition on, and I briefly saw the "currently unavailable" message again.....
Pulled the codes and found these new ones:
Address 47: Sound System (J525) 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded
and
Address 19: CAN Gateway (J533) 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - -
I've cleared the codes, charged the battery, same.... B&O works, I can adjust the volume, but only half mode, driver side only.....
Looking for wisdom.
Thank you!
Friday,16,May,2025,21:30:27:01199
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WA1DGAFE5FD013151   License Plate: 2015HOEMBER
Mileage: 185990km-115568mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72
VIN: WA1DGAFE5FD013151   Mileage: 185990km-115568miles
47-Sound System -- Status: Not registered 0011
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
   Component: 3.0l V6 TFSI        0030
   Revision: --H08---    Serial number:
   Coding: 0121000A290F0928
   Shop #: WSC 31414 790 00001
   VCID: 36352FDAC447374A65B-8062
   VINID: 9D10545D159515650004304504342AD78B
Readiness: 0010 0101
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
   Component: AL1000 AISIN  002 2443
   Serial number:                CVN: 354289C1
   Coding: 001378
   Shop #: WSC 07308 004 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 3A2D3BEAFCDFD32A813-806E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099409
   VCID: 343115D2D23B255A5BF-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902176495
   Coding: 0000135
   Shop #: WSC 45464 001 1048576
   VCID: 2517F89669E14CD2DC1-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H05 0020
   Subsystem 2 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
02639 - Antenna Reader for Keyless Access Authorization
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:45
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
   Revision: 00---031    Serial number: 00000000456898
   Coding: 000CC026
   VCID: 2517F89665E14CD2DC1-8070
   Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0127580837
   Coding: 070000
   Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
   Serial number:           0127585175
   Coding: 070000
02874 - Control Module 2 for Central Convenience (J773)
                    Fault Status: 01101000
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:46
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0133123
   VCID: 6E85C7BAFC974F8A6DB-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961433200488
   Coding: 29011F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 343115D2DEBB255A5BF-8060
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH45 0230
   Revision: 09H45000    Serial number: 0038QD90EZ6S
   Coding: 0014131
   VCID: 2B030EAE0F057AA20A5-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME4D4A3E40R
   Subsystem 3 - Serial number: 6342QSME4D4A3C64W
   Subsystem 4 - Serial number: 6352QSME194C0648L
   Subsystem 5 - Serial number: 6362QSME104B31402
   Subsystem 6 - Serial number: 63734SME4F2C2F78N
   Subsystem 7 - Serial number: 63834SME4F2C3A42B
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026143060326
   Coding: 0012242
   VCID: 2809F1A21EF351BAE77-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2R40A4DF
   Coding: 8BD763040900CF05020205
   Shop #: WSC 12345 123 61029
   VCID: 44D145128E9B95DAEBF-8010
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M14B14001A
   Coding: 00C303
   VCID: 3FDB4AFEE77DF602B6D-806A
   Component: J367-BDM  H07 0125
   Serial number: 41328049184121128924
                    Reset counter: 12
                    Mileage: 185985 km
                    Date: 2025.05.16
                    Time: 21:16:22
                    Bin. Bits:    11111
                    Voltage: 13.10 V
                    Count: 7
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---011    Serial number: 00000030362746
   Coding: 0000006
   VCID: 6889B1A2DE7391BA277-803C
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:46
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:51
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000123997581
   Coding: 00581B00000011110000
   VCID: 323D13CA242F2B6A493-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E0507BA3C170F8A2DB-807A
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 3 - Serial number: 5F30.10.1400H03000AMS14409ÿ
   Subsystem 4 - Serial number: S14409ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000128925438
   Coding: 011F57205E40440004
   VCID: 48C95122B2B3B1BA077-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82009672970000
   Coding: 3569949
   VCID: 382921E2CE53C13A777-806C
                    Fault Status: 01101100
                    Reset counter: 12
                    Mileage: 185076 km
                    Date: 2013.02.27
                    Time: 00:00:52
   Part No SW: 4L0 035 466 A    HW: 4L0 035 466 A
   Component: BO Q7         H30 0110
   Revision: 07S00000    Serial number: 02111140008537
   Coding: 05000001
   VCID: 290FF4A609F968B2F89-807C
   Subsystem 1 - Part No SW: 4L0 910 465 A    HW: 4L0 035 465
   Component: BO Q7 SLAVE  H41 0780
   Serial number: 01011140021425
                    Fault Status: 01100010
                    Reset counter: 12
                    Mileage: 185985 km
                    Date: 2025.05.16
                    Time: 21:16:41
                    Voltage: 13.50 V
                    Temperature: 37.0°C
                    Bin. Bits: 00000100
                    Voltage: 13.50 V
                    Temperature: 37.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191078144
   Coding: 0693965
   VCID: 2313E68E67D5B2E2B25-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000205211
   Coding: 0012001
   VCID: 5EE5977A0C37DF0ADDB-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000127602152
   VCID: 47CB521EBFADBEC20ED-8012
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000031
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156L/0E8121545
   Coding: 020007010000000000
   VCID: 2411E5926EDBB5DACBF-8070
                    Reset counter: 50
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:07:53
                    Bin. Bits: 00000000 00101100
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 513KY0E7501614
   Coding: 180200060004E1EF51003F456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130LQ0E3211814
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002220029
   Component: CD-Database  5950
                    Fault Frequency: 8
                    Reset counter: 50
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:07:53
                    Bin. Bits: 10001100 10000000
                    Bin. Bits: 00000100 00001110
                    Bin. Bits: 00000000 00000000
                    Reset counter: 50
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:07:53
                    Bin. Bits: 00000001 00010000
                    Bin. Bits: 00000000 00000010
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000127811561
   Coding: 010E57204040230004
   VCID: 46D55F1AB8A7A7CAF5B-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000352580546
   Coding: 0200000000000000
   VCID: 313F1CC621291072309-8064
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0189012
   Coding: 020C010001000100010102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6E85C7BAF0174F8A6DB-803A
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81CDB2CA8BBD9A43F-8038
   Subsystem 3 - Serial number: RD03.12.14--H58001001A0209ÿ
   Subsystem 4 - Serial number: 1A0209ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0127897790----
   Coding: 0003595
   VCID: 2615FF9A14E747CAD5B-8072
   Component: J_245_EE16_SKB10H15 0220
   Component: J_394_EE16_SKB10H15 0220
   Component: J_392_EE16_SKB10H15 0220
02906 - Control Module for Sliding Roof; Rear (J392)
                    Fault Status: 01100101
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:41
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000127817314
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.1V)-----------
------------------------------11 Faults Found------------------------------
Saturday,17,May,2025,07:38:19:01199
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:45
   Coding: 000CC026
   Coding: 070000
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:46
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012242
   Coding: 00C303
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:34:21
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
   Coding: 0000006
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:46
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:51
   Coding: 0010001
   Coding: 3569949
                    Reset counter: 12
                    Mileage: 185076 km
                    Date: 2013.02.27
                    Time: 00:00:52
   Coding: 05000001
                    Reset counter: 12
                    Mileage: 185985 km
                    Date: 2025.05.16
                    Time: 21:16:41
                    Voltage: 13.50 V
                    Temperature: 37.0°C
                    Bin. Bits: 00000100
                    Voltage: 13.50 V
                    Temperature: 37.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Coding: 0693965
   Coding: 0012001
   Coding: 0000031
                    Reset counter: 52
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:34:01
                    Reset counter: 52
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:34:01
                    Reset counter: 52
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:34:01
   Coding: 0003595
                    Reset counter: 10
                    Mileage: 185973 km
                    Date: 2025.05.15
                    Time: 19:06:41
End----------(Elapsed Time: 02:15, VBatt start/end: 12.1V/12.1V)-----------
Ziddywerks
Northern NJ USA
C?ID=208579
It sounds like CP is active. Putting a shield above the unit is not a solution just like putting a bag around it so it can cook from the inside is also not a valid solution. Do it right and replace the drain hoses. I would also recommend a ringbreak test and possible that gateway is acting up, but ringbreak would be my approach.
nemduma
Azusa, CA, USA
C?ID=442266
Drain was cleaned, water drains down, no issues. the shield (thin plastic) is below the plastic trim piece where the drain lines, where the water would leak in if.....
Interesting about the CP, i thought it would show a different code.
How do I do the ring break test?
"Gateway is acting up" anything to do about it?
Thank you!
nemduma
Azusa, CA, USA
C?ID=442266
I installed a Fiber Bypass Loop
Address 19: CAN Gateway doesnt show any error
But
Address 47: Sound System (J525) the B&O upon reconnecting shows 2
and a new, Component Protection Active
Seems like I will have to take it to the dealer.
Thank you
Ziddywerks
Northern NJ USA
C?ID=208579
Where in the ring did you install it?
Crucial question as MOST bus is all daisy chained together If one modules goes down they all go down in a sense. It depends where its installed.
nemduma
Azusa, CA, USA
C?ID=442266
I removed the fiber optic cable off the AMP in the trunk, passenger side and used a loop
Sound System (J525) was removed from the list [47]
and 19: CAN Gateway (J533) didnt show any error
Sunday,18,May,2025,10:44:40:01199
VIN: WA1DGAFE5FD013151   License Plate: NO AMP
Mileage: 186000km-115575mi   Repair Order:
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 4C 4F 52 55
VIN: WA1DGAFE5FD013151   Mileage: 186000km-115575miles
Readiness: 0000 0001
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 09:01:08
   Coding: 000CC026
   Coding: 070000
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:49
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012242
   Coding: 00C303
   Coding: 0000006
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:49
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:54
   Coding: 0010001
   Coding: 3569949
                    Reset counter: 15
                    Mileage: 185076 km
                    Date: 2013.02.27
                    Time: 00:00:52
   Coding: 0693965
   Coding: 0012001
   Coding: 0000031
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:39:46
                    Fault Frequency: 9
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:39:46
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:39:46
   Coding: 0003595
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:44
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 15
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:22:48
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 15
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:22:48
End----(Elapsed Time: 02:13, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
But when I connected the AMP back
it showed right away 2 errors in Address 47: Sound System (J525)
(it was also marked as a Not registered 0011 in the Gateway Installation List)
and 19: CAN Gateway (J533) shows one error again:
Sunday,18,May,2025,10:51:02:01199
VIN: WA1DGAFE5FD013151   License Plate: CP
   Coding: 001378
   Revision: 00H02001
   Coding: 0099409
   Coding: 0000135
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 09:01:08
   Coding: 000CC026
   Coding: 070000
   Coding: 070000
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:49
   Coding: 0133123
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 29011F
   Coding: 0014131
   Coding: 0012242
   Coding: 00C303
                    Reset counter: 15
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:47:26
                    Bin. Bits:    10111
                    Voltage: 11.60 V
                    Count: 7
   Coding: 0000006
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:49
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:54
   Coding: 0010001
   Coding: 3569949
                    Reset counter: 15
                    Mileage: 185076 km
                    Date: 2013.02.27
                    Time: 00:00:52
   Coding: 05000001
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 09:00:37
                    Voltage: 13.70 V
                    Temperature: 22.0°C
                    Bin. Bits: 00000100
                    Voltage: 13.50 V
                    Temperature: 22.0°C
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
                    Reset counter: 15
                    Voltage: 11.80 V
                    Temperature: 22.0°C
                    Bin. Bits: 00000001
                    Voltage: 11.20 V
                    Temperature: 72.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Coding: 0693965
   Coding: 0012001
   Coding: 0000031
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:47:07
                    Fault Frequency: 11
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:47:07
                    Reset counter: 55
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:47:07
   Coding: 0003595
                    Reset counter: 12
                    Mileage: 185992 km
                    Date: 2025.05.17
                    Time: 07:37:44
                    Reset counter: 15
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:22:48
                    Reset counter: 15
                    Mileage: 186008 km
                    Date: 2025.05.18
                    Time: 10:22:48
End----(Elapsed Time: 02:16, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
------------------------------14 Faults Found------------------------------
Any advice? Thank you
Register 47-Sound System in the Gateway. I think the Gateway is the CP master and likely won't do a CP negotiation with a module that isn't registered.
Image IMG202505181048
Anything can happen to Auction vehicles ; I wonder if the AMP was swapped and a faulty one was placed in the vehicle.
nemduma
Azusa, CA, USA
C?ID=442266
Thank you! Ive managed to add it back, now works !!!!!!!! Thank you
nemduma
Azusa, CA, USA
C?ID=442266
It was working when I got the vehicle, for a short time, before I washed the car and rinsed the AMP :)
Ziddywerks
Northern NJ USA
C?ID=208579
Well If you must know J525 address 47 is the amp. So I don't see how it would work without it being registered in the vehicle. CP needed. I will say that the amp you got back from "repair" is not your amp but another one. This is why you need CP or data inside the amp was manipulated and it now needs CP. Often is the case with such repairs
nemduma
Azusa, CA, USA
C?ID=442266
Its the exact same unit. as I mention in my original post "Sent the unit out for repair (swapped over one from my old q7, it was somewhat working but showed "component protection active") ." Most likely that caused the issue
