Codes and errors after ABS module swap (2019 GTI)
woodardhsd
C?ID=66523
Been fighting brake issues since I've gotten this car, replaced almost every part trying to figure it out. Dealer finally agreed to order an ABS Module under warranty, but it's been 7 months since they ordered it, and still no updates as to when it will arrive. I decided to try the swap myself with a used module with the exact same part and SW numbers. Install went fine, but was unable to finish all the basic settings, and I have tons of error codes. The coding was easy, I just copied from an older autoscan. I was able to to the Brake Pressure sensor, and maybe the Steering angle sensor (it just said running, never said completed), but not the two acceleration sensors. Those are the two codes I have under ABS.
So I have 2 questions. Where do I go to perform the other 2 basic settings, and any clue about the ESP errors? Right now, I have no cruise control, front assist, TPMS, or traction control.
Original Autoscan from 18 months ago
Sunday,17,September,2023,10:59:56:24422
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: 3VW6T7AU3KM014337   License Plate: RABBIT
Mileage: 28378km-17633mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F
          A9 D6 D7
VIN: 3VW6T7AU3KM014337   Mileage: 28378km-17633miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DKFA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0007
   Revision: --H13---    CVN: 1BCB9B8F
   Coding: 092500124424012F1000
   Shop #: WSC 00066 790 00223
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001008
   ROD: EV_ECM20TFS0205G0906259Q_VW37.rod
   VCID: 3C213026B6EE518A133-8068
   VINID: 0E69C69074650DB7400440C31CDB5AD761
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V08    CVN: 7D6B3C51
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F24E5862FB5A557-8072
   No subsystems:
   Part No SW: 5Q0 614 517 FC    HW: 5Q0 614 517 BM
   Component: ESC           H45 0191
   Revision: 00000000    Serial number: 50109000000558
   Coding: 01FA6BA150212170807A020360CA6880D60A84014006167610415051D0894B0B0000000012121212B835351919323200
   Shop #: WSC 29752 006 1048576
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 77ABEF0ACF48B2D23E1-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0502699443 Dataset Number: V03935272HW 0001
   Coding: 132C0C0723
   Shop #: WSC 00066 790 00080
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34BDACB102E72529-8016
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110001000000000010004
   VCID: 4CC160E6E64EE10AA33-8018
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C8641601190555 Dataset Number: V03935284KM 0001
   Shop #: WSC 00066 790 00248
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BA3F33AF36096B25A9-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181117  043 0551
   Serial number: 97022066181130212740
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S3Y18M12D18H05M41S29
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300310120190C203674
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 59
                    Mileage: 28241 km
                    Date: 2023.09.01
                    Time: 15:18:54
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.7 V
                    Outside temperature: 25.5 °C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Dataset Number: V03935268ZK 0001
   Coding: 3500008101FFC728949C810500401600000000000000000004
   VCID: 44D148C6CE1E294A6B3-8010
   Serial number: 003GCR0AV2R% Dataset Number: V03935251DQ 0001
   VCID: 47CB5FCAFF2802528E1-8012
   Serial number: IBH00000000000AXLKDE
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 357000000001B5013632
   Subsystem 3 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 358000000007C961763O
   Subsystem 4 - Part No SW: -----------    HW: 480 401 409 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001022B70FA2960V
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001BB2BB7283071%
   Subsystem 6 - Part No SW: -----------    HW: 480 400 701 19
   Serial number: 35500012E2B805A462B3
   Subsystem 7 - Part No SW: -----------    HW: 480 400 701 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600012E2B805A463E8
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD091AA988CF0502882A095000000020000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F3B176A7798BA12A61-807A
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 9
                    Reset counter: 105
                    Mileage: 28268 km
                    Date: 2023.09.09
                    Time: 17:09:19
   Serial number: 25011900841218 Dataset Number: V03935293G0001
   Coding: 030100047F085900FB00006B1C0F00010001070000000000000000000000
   GVL: 01423C5000000600404C80000000C80000000000000200000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CA6EB012F31AED7-803A
   Generator:
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002662660028456
   Coding: 29FFFF
   Serial number: 2354736100
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 104
                    Mileage: 28241 km
                    Date: 2023.09.01
                    Time: 14:06:13
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000364470004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F111261ACACE2B05-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00027.11.18 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7E9E046AB7FAE9F-8006
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Reset counter: 104
                    Mileage: 28342 km
                    Date: 2023.09.14
                    Time: 20:01:31
   Serial number: 0501751725 Dataset Number: V03935270GQ 0001
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273D22ADF4588224D-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0502496943
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038902302292 Dataset Number: V03935287LD 0001
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4FFB77EA1758DA12C61-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001607647
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: V03935281SJ 0001
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F974960A66C5EADFB-8004
   Component: FCM MQB Low   002 0345
   Serial number: 19121800840780 Dataset Number: V03935284BB 0001
   Coding: 000000050900214A01110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3537250295C480C2ECD-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46035900301932 Dataset Number: V03935287LP 0001
   VCID: 4EC56AEE1052D31ACD7-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001608595
   Coding: 091000
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      695 8742
   Serial number: 13111800020002 Dataset Number: V03935281LR 0001
   Coding: 02730000BE00000041220001001000009F0003D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 70B9D416AA26E5EAFFB-8024
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181012202574
   VCID: 323D1E1E64AA97FAC9F-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2932B9DC64A2085-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 01:41, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Autoscan from today with new ABS modules:
Saturday,17,May,2025,14:06:23:24422
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
Mileage: 59771km-37139mi   Repair Order:
          A9 D6 D7
VIN: 3VW6T7AU3KM014337   Mileage: 59771km-37139miles
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C213026B6EE518A938-8068
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 59760 km
                    Date: 2025.05.17
                    Time: 03:17:50
                    Engine speed: 1920.75 /min
                    Coolant temperature: 42 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 10.722 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1000 0100
   Component: GSG DQ381     H06 2403
   Revision: 00H06V08    CVN: B0480D45
   VCID: 2615F24E5862FB5AD5C-8072
   No subsystems:
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 51489000000600
   Shop #: WSC 00066 790 00088
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 045188C68E9EE94AAB8-8050
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 165
                    Mileage: 59771 km
                    Date: 2025.05.17
                    Time: 03:31:37
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 165
                    Mileage: 59771 km
                    Date: 2025.05.17
                    Time: 03:31:37
   Coding: 132C0C0723
   VCID: 43D34BDACB102E72D22-8016
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [Function restriction due to temp low voltage]
                    Reset counter: 204
                    Mileage: 59760 km
                    Date: 2025.05.17
                    Time: 03:17:48
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    Control Module Voltage: 8.289 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Rear left door: closed
                    Rear right door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Revision: 00001K05
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4CC160E6E64EE10A238-8018
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F33AF36096B2DA2-802E
   Coding: 00A8DD
   VCID: 44D148C6CE1E294AEB8-8010
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 164
                    Mileage: 59760 km
                    Date: 2025.05.17
                    Time: 02:59:29
                    Control Module temperature: 45 °C
                    Voltage terminal 15: 11.7 V
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 164
                    Mileage: 59760 km
                    Date: 2025.05.17
                    Time: 02:59:26
                    Voltage terminal 15: 11.6 V
   VCID: 47CB5FCAFF2802520EA-8012
   Coding: 30305A
   VCID: 2F3B176A7798BA1226A-807A
   VCID: 6E85CA6EB012F31A6DC-803A
   Generator:
   Coding: 29FFFF
   VCID: 313F111261ACACE230E-8064
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Coding: 0001
   VCID: 52FD7E9E046AB7FA694-8006
   Coding: 01011103
   VCID: 3D273D22ADF45882A46-8068
   Coding: 010111
   VCID: 4FFB77EA1758DA1246A-801A
   Coding: 011000
   Coding: 811F0000
   VCID: 50F974960A66C5EA5F0-8004
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 165
                    Mileage: 59760 km
                    Date: 2025.05.17
                    Time: 02:59:26
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 37.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 7F
                    uioUdNotFilt_xdu16: 11.88 V
                    uAdSensI_SwitchedKl30_xdu16: 11.82 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   VCID: 3537250295C480C26C6-8060
   VCID: 4EC56AEE1052D31A4DC-801A
   Coding: 091000
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 70B9D416AA26E5EA7F0-8024
   VCID: 323D1E1E64AA97FA494-8066
   VCID: 392F2932B9DC64A288E-806C
End----------(Elapsed Time: 01:42, VBatt start/end: 12.2V/12.2V)-----------
------------------------------7 Faults Found-------------------------------
I would think it's:
IDE05146-ENG114972 -- Basic setting of ESP sensor unit
The fault codes in 01 and 13 are because you haven't got the ABS module happy yet.
woodardhsd
C?ID=66523
Thanks, Uwe. That seems to have done the trick. I was thinking the ESP adaptation was in 01 or 13 cause that's where the errors were, but it was in 03 ABS. I had to look through the list of basic settings several times before seeing it:banghead:. The TPMS light was still on, so I also performed TPMS reset to factory basic setting.
Gave it a quick drive and no lights came back in the dash. Hopefully one more brake bleed after a few ABS stops will have completely fixed my brake issues, fingers crossed. The pedal feel is already much better than it has ever been. Not sure what could have gone wrong in the old module hydraulically.
