See attached the scan, i just bought this MK7 GOLF R wagon which has a few little issues however i'm working through them. One I am struggling with is the catalytic readiness - Failed or incomplete on the readiness test.
It has an ECE approved Bull X downpipe which I also have on my MK7 GTI and it's never thrown any faults up. Any ideas on how I can get this to pass emissions at TUV as I understand even with ECE approval if it fails the readiness it's a failure regardless.
Friday,16,May,2025,19:23:54:38129
VCDS Version: 25.3.1.0 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWZZZAUZGP519233 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 20 22 2B 42 44 47 52
55 5F A9
VIN: WVWZZZAUZGP519233 Mileage: 157842km-98078miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: BFD91E73
Coding: 091D00122466050B3000
Shop #: WSC 00028 028 00071
ASAM Dataset: EV_ECM20TFS0205G0906259J 001002
ROD: EV_ECM20TFS0205G0906259J.rod
VCID: 3533F05E25C839B26CD-8060
VINID: 9E69EAAAA465A978050490830C3E8336FD
15446 - Blocking Valve for Coolant (N82)
P1889 00 [00101111] - Open or Short to Ground
Mileage: 157787 km
Date: 2025.05.14
Time: 19:32:04
Engine speed: 0.00 /min
Coolant temperature: 95 C
Intake air temperature: 37 C
Voltage terminal 30: 12.285 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 96 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.934 V
FAC_TPS_1_SAE: 15.625000 %
FUP_H_SAE: 11390.0 kPa
14916 - Catalyst System; Bank 1
P0420 00 [10101111] - Efficiency Below Threshold
Mileage: 157788 km
Date: 2025.05.14
Time: 19:34:20
Engine speed: 2038.75 /min
Normed load value: 36.9 %
Vehicle speed: 67 km/h
Coolant temperature: 98 C
Intake air temperature: 27 C
Voltage terminal 30: 13.984 V
Engine: operating status: PL
TEMP_CAT_UP_1_SAE: 617.9 C
Cat. ageing: bank 1: actual: 1.859
LAMB_DELTA_I_LAM_ADJ[1]: -0.00031
Lambda probes actual: bank1: 0.9033
VLS_DOWN_SAE[1]: 0.920 V
T_AST_SAE: 130 s
Part No SW: 0D9 300 020 M HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4913
Revision: 06253104 Serial number: TFK01506110030 CVN: 0000B41A
Shop #: WSC 00028 028 00067
ROD: EV_TCMDQ250021.rod
VCID: 1F1F32F6B73493E2961-804A
12 Faults Found:
21153 - Gear 1
P072C 00 [00000010] - Not Selectable
21154 - Gear 2
P072D 00 [00000010] - Not Selectable
21155 - Gear 3
P072E 00 [00000010] - Not Selectable
21156 - Gear 4
P072F 00 [00000010] - Not Selectable
21157 - Gear 5
P073A 00 [00000010] - Not Selectable
21158 - Gear 6
P073B 00 [00000010] - Not Selectable
21159 - Gear R
P072B 00 [00000010] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [00000010] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [00000010] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [00000010] - Implausible Signal
21207 - Pressure Control Solenoid 3
P0797 00 [00000010] - Stuck ON
10906 - Cooling Oil Valve
P179D 00 [00000010] - Electrical Malfunction
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61795000003297
Coding: 04FA6BA1542129750779070341C66920D62A94E0E08296F7184250F8C208
VCID: 7AA923624C5616CAC1F-802E
Revision: 00021000 Serial number: 0372080133 Dataset Number: 5G2IJ1v____ 0004
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A29E3620CD6D6CA81F-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 02020024200100011005000000101002
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A8913223CF6A64A31F-803E
Air quality sensor:
328196 - Motor for Right Temperature Flap
B108D 71 [00001001] - Actuator Stuck
Reset counter: 63
Mileage: 157691 km
Date: 2025.05.13
Time: 17:30:27
Voltage terminal 30: 12.6 V
Outside temperature: 25.0 C
Inside temperature: 34.2 C
Right temperature flap: actual value: 60
Right temperature flap: actual value: 15.5 %
Temperature door right - Specified value: 23
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86582906152179 Dataset Number: 5G9063v____ 0001
Coding: 00511B46C24102F30BA44080B11C07281800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 03575E863B9C5702929-8056
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150619 043 0551
Serial number: 150622231726
Component: RLHS 037 0059
Serial number: S5Y15M06D30H23M57S42
Coding: 90A8DD
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY1515321VV
Serial number: 00000000000032737506
Sunroof control module:
Subsystem 5 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST000DHZE700000
Coding: 191900
Roof shade control module:
Subsystem 6 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST000DI03Y00000
Coding: 191900
Humidity sensor: interior:
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 64
Mileage: 157838 km
Date: 2025.05.16
Time: 19:01:34
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.5 V
Outside temperature: 17.5 C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39311518201369 Dataset Number: 5G0039v__A_ 0023
Coding: 0071151011
VCID: 43D79E867B1C9702D29-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 06061503210762 Dataset Number: 5g0114v____ 1026
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
1050 - Transmission in Limp Mode
P305B 00 [00001000] - -
Reset counter: 99
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:54
Control Module temperature: 43 C
Voltage terminal 15: 12.4 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s
1043 - Automatic Distance Control
B10E7 F0 [00001000] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 99
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:54
Voltage terminal 15: 12.3 V
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 24051541350411 Dataset Number: 5G0532v____ 0043
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 372FFA563FC4CBA27E1-8062
198659 - Front Left Ride-Height Sensor
C1034 07 [00001001] - Mechanical Failure
Fault Frequency: 8
Reset counter: 64
Mileage: 157692 km
Date: 2025.05.13
Time: 17:32:34
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR0VNFP Dataset Number: 5G0003v____ 0094
Shop #: WSC 00028 028 00054
VCID: 7F5FD276577433E2F61-802A
Left seat belt tensioner:
Component: BeltPretRevFL H36 0350
Serial number: 34169667B30061580598
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H36 0350
Serial number: 34169668B30061570459
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 706 15
Serial number: 357670000008A275351Q
Subsystem 4 - Part No SW: ----------- HW: 480 001 906 15
Serial number: 3586700000063328051E
Subsystem 5 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 3516502C11C52F3182CA
Subsystem 6 - Part No SW: ----------- HW: 480 402 306 15
Serial number: 35265029D1C52F323169
Subsystem 7 - Part No SW: ----------- HW: 480 402 906 15
Serial number: 3556502B31C52F33C34E
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150628400694
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 73B70E466B3C6782829-8026
Part No SW: 5G1 920 758 A HW: 5G1 920 758 A
Component: KOMBI 302 6420
Coding: 07AD10183F80000801886A011400000000000000
VCID: 2D03D83ECD98717214D-8078
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 26061510802158 Dataset Number: 5G0067V____ 2215
Coding: 030100043F085900FB00027E9C0F00010001050000000000000000000000
GVL: 01D43C1000000700400C90000000CC0000000000000000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 75B3305E654879B2ACD-8020
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001210790095253
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 4189377103
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02018864727264565625393E01
Shop #: WSC 22335 005 1048576
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B07D626F38C7F420A9-807E
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00019.05.15 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 46D18792482EA22AF57-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000165493005
Coding: 5D00000000000000
VCID: 3435CD5A2EB220BA5B3-8060
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000155764032 Dataset Number: 5G0222v____ 0067
Coding: 003F1220D000028000001000
VCID: 47CF8A964F24BB220E1-8012
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000009510656
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Dataset Number: 5G0074v____ 0980
Coding: 8103
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0110
Revision: 00000001 Serial number: VWZ8Z1FBA009W9D Dataset Number: 5G0050v____ 0213
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
VCID: 6D83183E0D18B17254D-8038
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000156153903 Dataset Number: 5G0157v____ 0063
Coding: 003F1020DE00028000801000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000009502932
Coding: 090000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: -------------- Dataset Number: 5G0036v____ 0021
Coding: 06A202000B010200
ROD: EV_HeadlRegulVWAFS_VW37.rod
VCID: 40DD918A6A0A8C1ACFB-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
13705990 - Databus
U1123 00 [10001001] - Received Error Message
[Fahrwerk_01: Fehlerwert im Signal FA_Hoehenwert_VL_01]
Fault Frequency: 8
Reset counter: 64
Mileage: 157692 km
Date: 2025.05.13
Time: 17:32:34
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 H HW: 3G0 035 043
Component: MU-H-N-EU H42 0317
Serial number: A599F0F7528629 Dataset Number: 5G0CV1v____ 0001
Coding: 027302010000000051110002000808001F0207F401200100DF
VCID: 211B340E8140A512A05-8074
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU302ACU
Subsystem 2 - Part No SW: V03 959 809 P HW: -----------
Component: ECE 2021/2022 --- 0192
Compact disc data bank:
Component: Gracenote2 --- 1011
13 Faults Found:
1585 - invalid data record
B2005 00 [00001001] - -
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1586 - invalid data record
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1587 - invalid data record
[Control module (data record download) - invalid data record for language]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1588 - invalid data record
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1589 - invalid data record
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1590 - invalid data record
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1592 - invalid data record
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1595 - invalid data record
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1652 - invalid data record
[Control module (data record download) - invalid data record for eco HMI]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1655 - invalid data record
[Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1656 - invalid data record
[Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1657 - invalid data record
[Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
1603 - invalid data record
[Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
Reset counter: 59
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:58
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150527200763
VCID: 2F3FC236C7940362261-807A
0006 - Actuator for Structural Accoustics
P193A 00 [00001000] - Open Circuit
Reset counter: 104
Mileage: 157690 km
Date: 2025.05.13
Time: 17:23:54
End----------(Elapsed Time: 02:16, VBatt start/end: 14.6V/14.5V)-----------
------------------------------34 Faults Found------------------------------
