2006 VW Beetle P0332
   #21
rvralph64
Fresno, CA, USA
C?ID=566690
Ok, I will do that. It might a few days until I get back.
   #22
I don't have a scope or is that a function in VCDS?
Yup, start logging various data, much like you logged the timing retardation. Hit the space bar to insert a marker in your log when the problem occurs.
rvralph64
Fresno, CA, USA
C?ID=566690
I have the log file ready to send but what't the best way to send it? If I copy and paste it looks all scrambled so there must be a better way?
   #25
rvralph64
Fresno, CA, USA
C?ID=566690
I also just ran the autoscan and noticed that the G66 fault has returned. No MIL warning light on dash.
Monday,26,May,2025,13:41:46:07661
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: 3VWSF31Y96M303780   License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWSF31Y96M303780   Mileage: 230300km-143101miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 B    HW: Hardware No
   Component: NB/C R5 AT      G   7615
   Revision: --------    Serial number: VWZ5Z0E7248079
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 2809E8896EE2C59AE7B-513C
   VINID: 0E69E35830692467430031C80042D560E0
000818 - Knock Sensor 2 (G66)
               P0332 - 002 - Signal too Low - Intermittent
                    Mileage: 230284 km
                    RPM: 2165 /min
                    Load: 41.6 %
                    Speed: 109.0 km/h
                    Temperature: 86.0°C
                    Temperature: 35.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
Readiness: 0100 1100
   Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
   Component: AQ 250 6F           0759
   Revision: 00H27000    Serial number:
   Coding: 0000008
   VCID: 78A9F8C9FEC2951AB7B-513C
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 382938C9BE42551A77B-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AL
   Component: 01 AIRBAG VW71      0711
   Coding: 0012337
   VCID: 015F952DAD18D4D2805-513C
   Subsystem 1 - Part No: 1C0 959 339 F
   Component: BF-Gewichtsens. 006 0007
Address 17: Instruments        Labels: None
   Part No: 1C0 920 501 P
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11234
   Shop #: WSC 22539
   VCID: 2517E1BD1CF0D8F2DCD-4B00
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 09149
   VCID: 70B9C0E993B2CD5A7FB-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 501 P    HW: 1C0 920 501 P
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0E7248079
   Shop #: WSC 41876 001 1048576
   VCID: 2517E1BD19F0D8F2DCD-513C
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255 C
   Component:  VSG  NBC           3601
   VCID: 40D95029E6921DDACFB-513C
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: 3B2327C58A747E029A9-4B00
   Subsystem 1 - Part No: 1Y1959801C
   Component: 6J Tõrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802D
   Component: 6J Tõrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tõrsteuer.HL KLO 0005
   Subsystem 4 - Part No: 1Y0959812
   Component: 6J Tõrsteuer.HR KLO 0005
End----(Elapsed Time: 03:49, VBatt start/end: 11.4V/11.6V. VIgn 11.5V)-----
-------------------------------1 Fault Found-------------------------------
Here is the data from the log file.
I don't know what you did to make such a mess of that log, but it's not legible.
Either post the original .CSV text (open the file with Notepad rather than a spreadsheet) or upload it to Google Sheets, share it properly, and post a link.
rvralph64
Fresno, CA, USA
C?ID=566690
Sunday,25,May,2025,11:52:53:07661-VCID:2809E8896EE2C59AE7B-513C,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
07K 906 032 B,ADVMB,NB/C R5 AT      G   7615,
,,G002,F3,G006,F2,G010,F2,G030,F0,G041,F0,G062,F2,G063,F1,G063,F2,G107,F1,G166,F0,G000,F0,G000,F0,
Marker,TIME,Group 2 - Field 3,TIME,Group 6 - Field 2,TIME,Group 10 - Field 2,TIME,Group 30 - Field 0,TIME,Group 41 - Field 0,TIME,Group 62 - Field 2,TIME,Group 63 - Field 1,TIME,Group 63 - Field 2,TIME,Group 107 - Field 1,TIME,Group 166 - Field 0,,,,,
,STAMP,Intake Air Mass,STAMP,Intake Air - Temperature,STAMP,Throttle Drive - Angle Sensor 1,STAMP,Bank 1 - Sensor 1,STAMP,Resistance - Bank 1 Sensor 1,STAMP,Throttle Position - Sensor (G79),STAMP,Accelerator Pedal - Position Sensor 2,STAMP,Kick-Down - Switch,STAMP,Oxygen Sensor - Control Bank 1,STAMP,Bank 1 Voltage - of Oxygen Sensors,,,,,
,, g/s,,°C,, %,,,, ohms,, %,, %,,,, %,,,,,,,
,2.17,4.53,2.45,44.0,0.22,3.5,0.51,   00011,0.79,295,1.06,14.5,1.34,91.0,1.34, ,1.62,-2.3,1.89,0.984,,,,,
,4.60,4.50,4.86,44.0,2.73,3.5,2.99,   00011,3.26,296,3.53,14.5,3.80,91.0,3.80, ,4.07,-2.3,4.33,0.992,,,,,
,7.09,4.44,7.36,44.0,5.14,3.5,5.42,   00011,5.71,295,5.99,14.5,6.27,91.0,6.27, ,6.54,-2.3,6.81,0.992,,,,,
,9.57,4.47,9.84,44.0,7.64,3.5,7.92,   00011,8.20,296,8.47,14.5,8.75,91.0,8.75, ,9.04,1.6,9.31,0.992,,,,,
,12.00,4.47,12.28,44.0,10.11,3.5,10.39,   00011,10.67,295,10.92,14.5,11.20,91.0,11.20, ,11.46,1.6,11.72,0.992,,,,,
,14.44,4.44,14.71,44.0,12.56,3.9,12.83,   00011,13.09,295,13.36,14.5,13.63,91.0,13.63, ,13.91,1.6,14.17,0.992,,,,,
,16.93,4.44,17.22,44.0,15.00,3.5,15.28,   00011,15.55,295,15.82,14.5,16.10,91.0,16.10, ,16.38,1.6,16.65,0.992,,,,,
,19.43,4.44,19.72,44.0,17.51,3.5,17.78,   00011,18.06,296,18.33,14.5,18.60,91.0,18.60, ,18.88,0.8,19.15,0.984,,,,,
,21.98,5.28,22.27,44.0,20.00,4.3,20.29,   00011,20.58,296,20.86,14.5,21.14,91.0,21.14, ,21.42,0.8,21.70,0.984,,,,,
,24.52,5.50,24.80,44.0,22.55,4.7,22.83,   00011,23.11,295,23.39,14.5,23.67,91.0,23.67, ,23.95,-2.3,24.23,0.992,,,,,
,26.95,5.39,27.23,44.0,25.07,4.3,25.33,   00011,25.60,296,25.87,14.5,26.15,91.0,26.15, ,26.41,-3.1,26.68,0.992,,,,,
,29.43,5.44,29.69,44.0,27.52,4.3,27.80,   00011,28.07,295,28.33,14.5,28.60,91.0,28.60, ,28.87,-2.3,29.15,1.000,,,,,
,31.86,5.44,32.14,44.0,29.96,4.3,30.23,   00011,30.52,295,30.78,14.5,31.04,91.0,31.04, ,31.31,-1.6,31.58,1.000,,,,,
,34.36,5.44,34.63,44.0,32.42,4.7,32.71,   00011,32.98,295,33.25,14.5,33.54,91.0,33.54, ,33.80,-1.6,34.08,1.000,,,,,
,36.84,5.44,37.11,44.0,34.90,4.7,35.18,   00011,35.44,295,35.72,14.5,36.00,91.0,36.00, ,36.28,2.3,36.57,0.992,,,,,
,39.27,5.47,39.54,44.0,37.39,4.7,37.66,   00011,37.94,295,38.20,14.5,38.48,91.0,38.48, ,38.73,2.3,39.00,0.992,,,,,
,41.78,5.53,42.05,44.0,39.81,4.7,40.09,   00011,40.37,294,40.65,14.5,40.93,91.0,40.93, ,41.22,2.3,41.49,0.992,,,,,
,44.18,5.36,44.46,45.0,42.31,4.7,42.58,   00011,42.84,294,43.11,14.5,43.38,91.0,43.38, ,43.64,2.3,43.90,0.992,,,,,
,46.71,5.31,46.98,45.0,44.74,4.7,45.04,   00011,45.31,294,45.59,14.5,45.87,91.0,45.87, ,46.15,2.3,46.43,0.992,,,,,
,49.16,5.44,49.42,45.0,47.27,4.7,47.55,   00011,47.82,295,48.09,14.5,48.36,91.0,48.36, ,48.63,-1.6,48.89,1.000,,,,,
,51.65,5.44,51.94,45.0,49.69,4.7,49.97,   00011,50.25,294,50.54,14.5,50.81,91.0,50.81, ,51.09,-1.6,51.37,0.984,,,,,
,54.17,8.67,54.45,45.0,52.22,4.7,52.50,   00011,52.79,295,53.06,25.4,53.34,91.0,53.34, ,53.62,3.1,53.90,0.984,,,,,
,56.69,5.11,56.96,45.0,54.73,6.3,55.01,   00011,55.30,296,55.57,14.5,55.84,91.0,55.84, ,56.12,5.5,56.41,0.977,,,,,
,59.15,11.97,59.41,45.0,57.23,4.7,57.51,   00011,57.79,295,58.06,18.4,58.34,91.0,58.34, ,58.62,-2.3,58.88,0.992,,,,,
,61.58,22.97,61.86,45.0,59.68,12.5,59.94,   00011,60.21,298,60.47,32.4,60.74,91.0,60.74, ,61.02,3.9,61.30,1.008,,,,,
,64.06,30.31,64.34,44.0,62.14,13.7,62.42,   00011,62.70,299,62.96,36.3,63.23,91.0,63.23, ,63.50,7.0,63.78,0.984,,,,,
,66.46,51.69,66.74,44.0,64.60,21.2,64.87,   00011,65.13,299,65.40,41.4,65.66,91.0,65.66, ,65.93,7.8,66.18,0.969,,,,,
,69.00,16.33,69.29,45.0,67.02,20.8,67.31,   00010,67.60,293,67.88,34.0,68.15,91.0,68.15, ,68.43,5.5,68.71,0.977,,,,,
,71.48,5.50,71.76,45.0,69.54,6.3,69.81,   00011,70.08,287,70.37,20.7,70.65,91.0,70.65, ,70.92,0.8,71.20,1.008,,,,,
,73.98,5.22,74.25,45.0,72.04,5.1,72.32,   00011,72.59,294,72.86,15.2,73.15,91.0,73.15, ,73.42,1.6,73.70,0.992,,,,,
,76.41,17.47,76.67,45.0,74.52,4.7,74.79,   00011,75.06,293,75.34,28.1,75.61,91.0,75.61, ,75.88,-0.8,76.14,0.992,,,,,
,78.92,17.28,79.19,45.0,76.95,14.1,77.23,   00011,77.52,298,77.81,31.3,78.08,91.0,78.08, ,78.36,0.0,78.64,1.016,,,,,
,81.35,8.17,81.62,45.0,79.45,10.6,79.72,   00011,79.99,296,80.25,26.2,80.52,91.0,80.52, ,80.80,0.8,81.08,1.023,,,,,
,83.87,7.08,84.16,45.0,81.90,6.3,82.18,   00011,82.45,293,82.73,22.7,83.01,91.0,83.01, ,83.31,2.3,83.59,0.992,,,,,
,86.40,9.19,86.67,45.0,84.44,8.2,84.72,   00011,85.00,294,85.28,27.3,85.58,91.0,85.58, ,85.85,1.6,86.12,0.984,,,,,
,88.87,10.06,89.14,45.0,86.95,6.3,87.23,   00011,87.51,294,87.77,25.8,88.04,91.0,88.04, ,88.32,0.8,88.59,0.969,,,,,
,91.35,11.97,91.62,45.0,89.42,8.6,89.70,   00011,89.99,295,90.27,25.8,90.56,91.0,90.56, ,90.82,1.6,91.08,0.992,,,,,
,93.81,7.08,94.08,45.0,91.89,9.8,92.18,   00011,92.44,297,92.71,26.2,92.98,91.0,92.98, ,93.25,3.9,93.53,1.023,,,,,
,96.28,6.86,96.57,45.0,94.36,8.2,94.63,   00011,94.92,295,95.20,23.8,95.46,91.0,95.46, ,95.73,4.7,96.01,1.000,,,,,
,98.76,6.08,99.03,45.0,96.82,5.5,97.10,   00011,97.36,295,97.64,21.9,97.92,91.0,97.92, ,98.21,0.8,98.49,0.984,,,,,
,101.24,9.36,101.52,45.0,99.31,5.5,99.57,   00011,99.85,296,100.13,25.0,100.41,91.0,100.41, ,100.68,-3.9,100.96,0.961,,,,,
,103.70,7.97,103.97,45.0,101.79,8.2,102.08,   00011,102.35,297,102.62,24.2,102.90,91.0,102.90, ,103.17,-3.1,103.44,1.008,,,,,
,106.15,14.19,106.44,45.0,104.23,8.6,104.50,   00011,104.77,296,105.04,28.9,105.33,91.0,105.33, ,105.60,-2.3,105.87,1.023,,,,,
,108.59,18.06,108.85,45.0,106.70,11.8,106.98,   00011,107.25,298,107.52,32.0,107.78,91.0,107.78, ,108.05,0.8,108.32,1.008,,,,,
,111.05,9.56,111.32,45.0,109.12,8.2,109.39,   00011,109.66,295,109.94,25.8,110.22,91.0,110.22, ,110.50,2.3,110.78,0.992,,,,,
,113.52,9.72,113.80,45.0,111.59,7.1,111.86,   00011,112.13,294,112.40,25.4,112.68,91.0,112.68, ,112.95,0.8,113.23,0.961,,,,,
,116.01,9.92,116.28,45.0,114.07,8.2,114.34,   00011,114.62,295,114.90,25.8,115.17,91.0,115.17, ,115.45,1.6,115.73,0.969,,,,,
,118.52,12.72,118.78,45.0,116.56,8.2,116.84,   00011,117.13,295,117.40,26.6,117.67,91.0,117.67, ,117.95,1.6,118.24,0.945,,,,,
,120.95,12.19,121.24,45.0,119.05,11.4,119.32,   00011,119.58,295,119.85,28.9,120.13,91.0,120.13, ,120.40,3.1,120.67,0.977,,,,,
,123.42,6.06,123.70,45.0,121.52,7.8,121.79,   00011,122.06,294,122.33,21.5,122.60,91.0,122.60, ,122.88,5.5,123.15,0.977,,,,,
,125.92,5.97,126.20,45.0,123.97,5.5,124.25,   00011,124.53,292,124.81,14.5,125.07,91.0,125.07, ,125.37,4.7,125.65,0.945,,,,,
,128.38,20.36,128.64,45.0,126.46,8.2,126.75,   00011,127.02,297,127.29,28.5,127.57,91.0,127.57, ,127.85,0.0,128.11,1.031,,,,,
,130.79,14.67,131.07,45.0,128.91,15.3,129.17,   00011,129.44,298,129.70,28.9,129.97,91.0,129.97, ,130.24,0.8,130.52,1.016,,,,,
,133.23,11.00,133.51,45.0,131.35,12.5,131.62,   00011,131.89,297,132.15,28.1,132.42,91.0,132.42, ,132.69,0.8,132.96,1.008,,,,,
,135.69,7.92,135.95,45.0,133.79,5.9,134.08,   00011,134.36,292,134.63,21.9,134.89,91.0,134.89, ,135.16,7.0,135.42,0.977,,,,,
,138.16,6.67,138.42,45.0,136.22,9.0,136.49,   00011,136.76,291,137.04,25.8,137.32,91.0,137.32, ,137.59,1.6,137.88,1.031,,,,,
,140.59,5.83,140.89,45.0,138.69,5.5,138.96,   00011,139.22,294,139.49,17.2,139.76,91.0,139.76, ,140.04,3.9,140.31,0.961,,,,,
,143.09,4.19,143.39,45.0,141.16,5.5,141.43,   00011,141.70,294,141.98,14.5,142.26,91.0,142.26, ,142.53,3.1,142.81,0.961,,,,,
,145.56,3.28,145.84,45.0,143.66,3.1,143.94,   00011,144.21,294,144.47,14.5,144.74,91.0,144.74, ,145.01,2.3,145.29,0.953,,,,,
,148.06,4.17,148.34,45.0,146.12,3.1,146.40,   00011,146.67,294,146.96,14.5,147.24,91.0,147.24, ,147.52,-2.3,147.79,0.945,,,,,
,150.54,4.61,150.81,45.0,148.62,3.9,148.90,   00011,149.17,295,149.46,14.5,149.74,91.0,149.74, ,150.01,-6.3,150.27,0.977,,,,,
,153.04,4.67,153.31,45.0,151.08,3.9,151.36,   00011,151.65,294,151.92,14.5,152.21,91.0,152.21, ,152.49,-6.3,152.77,0.992,,,,,
,155.52,13.92,155.79,45.0,153.59,3.9,153.86,   00011,154.15,295,154.42,20.3,154.69,91.0,154.69, ,154.96,-5.5,155.25,1.008,,,,,
,158.01,29.67,158.29,45.0,156.07,10.6,156.35,   00010,156.64,299,156.91,36.7,157.18,91.0,157.18, ,157.46,0.0,157.74,1.016,,,,,
,160.51,55.36,160.79,44.0,158.57,25.5,158.85,   00010,159.14,304,159.41,41.8,159.68,91.0,159.68, ,159.96,4.7,160.23,0.945,,,,,
,163.00,50.00,163.27,44.0,161.07,29.0,161.35,   00010,161.63,296,161.90,42.2,162.18,91.0,162.18, ,162.47,-1.6,162.73,0.977,,,,,
,165.50,26.33,165.78,43.0,163.54,55.3,163.82,   00011,164.09,294,164.38,37.9,164.66,91.0,164.66, ,164.94,-0.8,165.22,0.938,,,,,
,167.96,24.69,168.23,44.0,166.06,17.3,166.33,   00011,166.60,288,166.87,34.4,167.13,91.0,167.13, ,167.40,-10.9,167.68,0.977,,,,,
,170.43,9.53,170.70,44.0,168.51,17.6,168.79,   00011,169.06,293,169.33,33.2,169.61,91.0,169.61, ,169.88,-10.2,170.15,0.992,,,,,
,172.92,3.44,173.20,45.0,170.98,4.7,171.26,   00011,171.53,289,171.81,14.5,172.09,91.0,172.09, ,172.38,-8.6,172.65,1.016,,,,,
,175.39,3.03,175.67,45.0,173.48,2.7,173.76,   00011,174.04,293,174.31,14.5,174.58,91.0,174.58, ,174.85,-7.8,175.12,1.008,,,,,
,177.89,2.94,178.16,45.0,175.95,2.4,176.23,   00011,176.50,295,176.78,14.5,177.06,91.0,177.06, ,177.35,-7.8,177.62,1.000,,,,,
,180.31,3.22,180.58,45.0,178.43,2.4,178.70,   00011,178.96,294,179.23,14.5,179.49,91.0,179.49, ,179.75,-6.3,180.03,1.000,,,,,
,182.80,3.50,183.07,45.0,180.86,2.7,181.15,   00011,181.42,295,181.69,14.5,181.97,91.0,181.97, ,182.25,-2.3,182.53,0.992,,,,,
,185.27,4.42,185.54,45.0,183.33,3.1,183.60,   00011,183.89,295,184.17,14.5,184.45,91.0,184.45, ,184.71,-3.1,184.99,1.000,,,,,
,187.75,4.50,188.02,45.0,185.82,3.5,186.10,   00011,186.39,296,186.68,14.5,186.95,91.0,186.95, ,187.22,-2.3,187.48,1.000,,,,,
,190.21,4.67,190.48,45.0,188.29,3.9,188.58,   00011,188.84,296,189.12,14.5,189.39,91.0,189.39, ,189.66,-1.6,189.93,1.008,,,,,
,192.68,4.67,192.97,45.0,190.76,3.9,191.03,   00011,191.30,295,191.57,14.5,191.86,91.0,191.86, ,192.13,-0.8,192.40,1.000,,,,,
,195.20,4.86,195.48,45.0,193.25,4.3,193.52,   00011,193.79,295,194.08,14.5,194.37,91.0,194.37, ,194.65,-4.7,194.94,0.992,,,,,
,197.67,4.83,197.93,45.0,195.75,4.3,196.02,   00011,196.29,296,196.55,14.5,196.82,91.0,196.82, ,197.09,-4.7,197.38,1.000,,,,,
,200.17,4.86,200.44,45.0,198.20,4.3,198.48,   00011,198.76,295,199.04,14.5,199.31,91.0,199.31, ,199.59,-3.9,199.87,1.000,,,,,
,202.62,4.94,202.89,45.0,200.72,4.3,201.00,   00011,201.27,295,201.54,14.5,201.80,91.0,201.80, ,202.07,-3.1,202.34,1.000,,,,,
,205.12,4.83,205.39,45.0,203.18,4.3,203.45,   00011,203.74,295,204.02,14.5,204.29,91.0,204.29, ,204.56,-3.1,204.84,1.000,,,,,
,207.59,4.94,207.86,45.0,205.68,4.3,205.96,   00011,206.22,295,206.49,14.5,206.76,91.0,206.76, ,207.03,1.6,207.31,1.000,,,,,
,210.05,4.86,210.33,45.0,208.14,4.3,208.43,   00011,208.71,296,208.98,14.5,209.24,91.0,209.24, ,209.51,1.6,209.78,0.992,,,,,
,212.50,4.81,212.77,45.0,210.61,4.3,210.89,   00011,211.18,294,211.45,14.5,211.70,91.0,211.70, ,211.98,1.6,212.24,0.992,,,,,
,214.99,4.83,215.27,45.0,213.05,4.3,213.33,   00011,213.60,295,213.88,14.5,214.18,91.0,214.18, ,214.44,1.6,214.71,0.992,,,,,
,217.44,4.83,217.71,45.0,215.54,4.3,215.81,   00011,216.08,296,216.34,14.5,216.61,91.0,216.61, ,216.88,0.8,217.17,0.992,,,,,
,219.93,4.86,220.21,45.0,218.00,4.3,218.28,   00011,218.56,295,218.83,14.5,219.10,91.0,219.10, ,219.38,1.6,219.67,0.984,,,,,
,222.43,15.42,222.71,45.0,220.48,4.3,220.76,   00011,221.04,294,221.32,19.5,221.59,91.0,221.59, ,221.87,-3.9,222.15,0.984,,,,,
,224.97,20.44,225.24,45.0,222.98,14.1,223.26,   00010,223.54,300,223.83,35.9,224.11,91.0,224.11, ,224.39,0.0,224.68,1.008,,,,,
,227.43,15.42,227.70,45.0,225.50,12.5,225.77,   00011,226.04,297,226.31,30.5,226.59,91.0,226.59, ,226.87,-0.8,227.16,0.969,,,,,
,229.93,3.14,230.21,45.0,227.98,4.7,228.26,   00011,228.55,292,228.83,14.5,229.11,91.0,229.11, ,229.38,3.9,229.65,0.977,,,,,
,232.40,24.39,232.67,45.0,230.48,4.3,230.76,   00011,231.04,292,231.31,24.6,231.60,91.0,231.60, ,231.87,0.8,232.13,0.969,,,,,
,234.86,32.19,235.14,44.0,232.96,20.4,233.23,   00011,233.52,304,233.78,39.1,234.05,91.0,234.05, ,234.32,-2.3,234.59,0.977,,,,,
,237.34,33.78,237.61,44.0,235.43,22.0,235.70,   00011,235.98,296,236.24,36.7,236.51,91.0,236.51, ,236.78,-6.3,237.06,0.961,,,,,
,239.81,23.83,240.10,45.0,237.89,22.4,238.18,   00011,238.45,294,238.71,35.9,238.98,91.0,238.98, ,239.25,-9.4,239.53,1.016,,,,,
,242.29,12.64,242.56,45.0,240.37,13.3,240.64,   00011,240.92,291,241.19,29.3,241.47,91.0,241.47, ,241.76,-6.3,242.02,1.023,,,,,
,244.75,5.44,245.02,45.0,242.83,6.7,243.10,   00011,243.38,291,243.65,14.5,243.94,91.0,243.94, ,244.21,-3.1,244.48,1.047,,,,,
,247.21,4.39,247.49,45.0,245.29,4.7,245.57,   00011,245.84,292,246.11,14.5,246.38,91.0,246.38, ,246.65,0.0,246.94,1.016,,,,,
,249.70,2.97,249.96,45.0,247.76,3.1,248.04,   00011,248.31,293,248.58,14.5,248.85,91.0,248.85, ,249.12,-0.8,249.40,0.953,,,,,
,252.15,3.31,252.45,45.0,250.22,2.4,250.49,   00011,250.76,294,251.04,14.5,251.32,91.0,251.32, ,251.59,-2.3,251.87,0.992,,,,,
,254.64,3.17,254.92,45.0,252.72,2.4,252.99,   00011,253.26,294,253.54,14.5,253.80,91.0,253.80, ,254.08,-1.6,254.36,0.977,,,,,
,257.12,4.14,257.40,45.0,255.21,3.9,255.47,   00011,255.74,295,256.01,14.5,256.29,91.0,256.29, ,256.56,-1.6,256.84,0.992,,,,,
,259.62,4.36,259.90,45.0,257.70,3.5,257.97,   00011,258.25,295,258.53,14.5,258.80,91.0,258.80, ,259.07,-0.8,259.34,1.008,,,,,
,262.09,4.47,262.37,45.0,260.17,3.5,260.45,   00011,260.73,296,261.01,14.5,261.27,91.0,261.27, ,261.54,-3.9,261.81,1.008,,,,,
,264.56,4.50,264.84,45.0,262.65,3.5,262.92,   00011,263.21,295,263.49,14.5,263.76,91.0,263.76, ,264.02,-3.1,264.29,1.000,,,,,
,267.07,4.50,267.33,45.0,265.11,3.5,265.39,   00011,265.67,296,265.96,14.5,266.24,91.0,266.24, ,266.52,-2.3,266.80,1.000,,,,,
,269.56,4.58,269.81,45.0,267.61,3.5,267.89,   00011,268.17,296,268.46,14.5,268.74,91.0,268.74, ,269.01,-2.3,269.28,1.000,,,,,
,272.01,4.64,272.29,45.0,270.09,3.5,270.35,   00011,270.64,296,270.92,14.5,271.19,91.0,271.19, ,271.46,-1.6,271.74,1.000,,,,,
,274.53,10.83,274.81,45.0,272.57,3.5,272.85,   00011,273.13,296,273.40,14.5,273.69,91.0,273.69, ,273.97,0.8,274.25,0.906,,,,,
,277.01,25.47,277.29,45.0,275.08,13.3,275.36,   00010,275.63,299,275.91,36.3,276.19,91.0,276.19, ,276.46,0.8,276.74,0.984,,,,,
,279.47,18.22,279.74,45.0,277.57,17.3,277.84,   00011,278.11,300,278.38,30.9,278.65,91.0,278.65, ,278.95,-3.9,279.20,0.977,,,,,
,281.96,16.31,282.25,45.0,280.01,11.8,280.29,   00011,280.57,293,280.84,28.5,281.12,91.0,281.12, ,281.40,-6.3,281.69,0.992,,,,,
,284.46,44.11,284.73,45.0,282.53,18.8,282.81,   00010,283.08,297,283.35,39.1,283.62,91.0,283.62, ,283.90,0.0,284.18,1.023,,,,,
,286.94,27.00,287.21,45.0,285.00,31.8,285.27,   00011,285.54,299,285.81,37.9,286.09,91.0,286.09, ,286.37,-0.8,286.65,0.945,,,,,
,289.37,3.64,289.64,45.0,287.47,5.9,287.74,   00010,288.01,289,288.27,14.5,288.54,91.0,288.54, ,288.81,-2.3,289.09,1.016,,,,,
,291.84,31.47,292.11,45.0,289.93,5.5,290.21,   00010,290.49,289,290.75,34.8,291.02,91.0,291.02, ,291.29,0.8,291.56,0.992,,,,,
,294.31,38.92,294.60,45.0,292.39,71.8,292.68,   00011,292.95,301,293.23,41.4,293.49,91.0,293.49, ,293.76,0.0,294.03,1.008,,,,,
,296.83,16.33,297.10,45.0,294.86,25.5,295.14,   00010,295.42,295,295.71,30.9,295.99,91.0,295.99, ,296.27,2.3,296.55,0.992,,,,,
,299.32,27.81,299.60,45.0,297.36,12.9,297.63,   00011,297.92,292,298.21,33.6,298.47,91.0,298.47, ,298.75,0.0,299.03,0.969,,,,,
,301.79,43.94,302.06,45.0,299.86,93.3,300.13,   00011,300.42,299,300.69,43.0,300.96,91.0,300.96, ,301.24,0.8,301.51,1.008,,,,,
,304.21,48.61,304.49,45.0,302.33,100.0,302.59,   00011,302.86,299,303.13,44.1,303.39,91.0,303.39, ,303.67,0.8,303.94,0.961,,,,,
,306.66,33.28,306.94,45.0,304.76,28.6,305.04,   00010,305.33,294,305.60,34.8,305.86,91.0,305.86, ,306.13,-3.1,306.39,0.977,,,,,
,309.15,42.06,309.44,44.0,307.21,39.6,307.48,   00011,307.77,294,308.04,42.6,308.32,91.0,308.32, ,308.60,-0.8,308.87,0.992,,,,,
,311.65,7.14,311.94,45.0,309.71,40.8,309.98,   00011,310.26,296,310.54,18.8,310.83,91.0,310.83, ,311.11,0.0,311.38,0.992,,,,,
,314.14,13.69,314.41,45.0,312.21,5.5,312.48,   00011,312.76,290,313.05,18.8,313.32,91.0,313.32, ,313.58,3.1,313.86,0.984,,,,,
,316.63,93.72,316.89,43.0,314.69,38.0,314.95,   00010,315.23,299,315.51,61.3,315.79,91.0,315.79, ,316.06,0.0,316.35,0.992,,,,,
,319.07,68.36,319.34,42.0,317.17,100.0,317.43,   00011,317.70,299,317.99,46.1,318.27,91.0,318.27, ,318.53,0.0,318.80,0.891,,,,,
,321.58,52.03,321.85,42.0,319.62,100.0,319.90,   00011,320.19,294,320.47,46.1,320.75,91.0,320.75, ,321.03,2.3,321.31,0.961,,,,,
,324.03,30.97,324.30,42.0,322.12,70.6,322.40,   00011,322.68,293,322.96,34.4,323.22,91.0,323.22, ,323.49,3.1,323.75,0.992,,,,,
,326.49,47.31,326.75,42.0,324.58,23.9,324.85,   00011,325.11,293,325.39,48.8,325.68,91.0,325.68, ,325.96,2.3,326.22,0.977,,,,,
,328.91,36.42,329.18,41.0,327.02,100.0,327.29,   00011,327.55,291,327.82,45.7,328.09,91.0,328.09, ,328.37,3.9,328.65,0.883,,,,,
,331.38,8.94,331.65,42.0,329.46,15.3,329.72,   00010,330.00,289,330.28,25.8,330.57,91.0,330.57, ,330.85,-1.6,331.12,1.008,,,,,
,333.87,7.53,334.14,42.0,331.92,7.5,332.21,   00011,332.49,289,332.77,14.5,333.05,91.0,333.05, ,333.32,0.0,333.59,1.991,,,,,
,336.33,11.42,336.61,42.0,334.42,6.7,334.70,   00010,334.98,296,335.24,14.5,335.53,91.0,335.53, ,335.80,0.0,336.06,1.538,,,,,
,338.79,40.47,339.07,42.0,336.88,23.9,337.15,   01010,337.43,301,337.70,39.1,337.97,91.0,337.97, ,338.24,3.1,338.51,0.961,,,,,
,341.27,30.47,341.53,41.0,339.35,83.1,339.63,   00011,339.90,300,340.18,37.5,340.46,91.0,340.46, ,340.73,3.9,341.00,0.977,,,,,
,343.74,20.19,344.00,41.0,341.80,20.0,342.07,   00011,342.35,294,342.64,35.9,342.92,91.0,342.92, ,343.21,-0.8,343.47,0.945,,,,,
,346.18,12.06,346.47,42.0,344.27,11.4,344.54,   00011,344.82,293,345.11,20.3,345.38,91.0,345.38, ,345.64,3.9,345.91,1.023,,,,,
,348.69,18.67,348.97,42.0,346.74,7.1,347.01,   00011,347.29,294,347.58,28.5,347.86,91.0,347.86, ,348.13,3.9,348.40,0.961,,,,,
,351.15,23.94,351.42,41.0,349.25,17.6,349.53,   00011,349.81,297,350.08,35.5,350.35,91.0,350.35, ,350.61,0.8,350.88,0.977,,,,,
,353.62,13.81,353.90,41.0,351.71,13.3,351.98,   00011,352.27,293,352.55,29.3,352.82,91.0,352.82, ,353.08,-2.3,353.35,0.961,,,,,
,356.09,20.17,356.37,42.0,354.17,6.7,354.45,   00011,354.73,293,355.00,20.7,355.27,91.0,355.27, ,355.54,2.3,355.81,0.992,,,,,
,358.59,32.75,358.86,40.0,356.64,18.4,356.92,   00011,357.22,298,357.50,35.5,357.77,91.0,357.77, ,358.04,-3.9,358.31,0.984,,,,,
,361.03,36.67,361.31,39.0,359.14,22.0,359.41,   00011,359.68,297,359.95,37.5,360.21,91.0,360.21, ,360.49,-3.9,360.76,0.992,,,,,
,363.53,11.22,363.81,39.0,361.59,24.7,361.86,   00011,362.13,299,362.42,31.3,362.70,91.0,362.70, ,362.97,-2.3,363.26,0.969,,,,,
,366.03,23.44,366.32,40.0,364.07,7.5,364.36,   00011,364.64,292,364.92,22.3,365.20,91.0,365.20, ,365.47,0.8,365.74,0.984,,,,,
,368.54,34.83,368.82,39.0,366.60,18.0,366.87,   00010,367.15,297,367.43,35.5,367.72,91.0,367.72, ,367.99,-1.6,368.27,0.984,,,,,
,371.04,8.42,371.33,39.0,369.10,22.7,369.38,   00010,369.65,296,369.93,14.5,370.22,91.0,370.22, ,370.49,-1.6,370.76,1.055,,,,,
,373.50,29.11,373.77,39.0,371.61,7.1,371.88,   00010,372.14,284,372.41,21.1,372.67,91.0,372.67, ,372.94,0.0,373.21,0.992,,,,,
,376.01,35.28,376.30,39.0,374.04,24.7,374.33,   01010,374.61,300,374.88,38.3,375.15,91.0,375.15, ,375.43,3.9,375.71,0.961,,,,,
,378.49,23.50,378.77,39.0,376.57,23.1,376.85,   00011,377.11,295,377.38,32.8,377.65,91.0,377.65, ,377.93,-3.9,378.21,0.969,,,,,
,380.93,22.56,381.20,39.0,379.04,15.3,379.30,   00011,379.57,295,379.83,36.7,380.10,91.0,380.10, ,380.37,0.8,380.65,0.945,,,,,
,383.42,35.03,383.70,39.0,381.49,17.3,381.77,   00011,382.05,295,382.33,35.9,382.60,91.0,382.60, ,382.87,0.0,383.15,1.000,,,,,
,385.89,39.03,386.17,39.0,383.99,23.1,384.26,   00011,384.52,296,384.79,36.3,385.06,91.0,385.06, ,385.34,0.0,385.61,1.016,,,,,
,388.36,68.36,388.63,38.0,386.45,26.3,386.73,   00011,387.00,297,387.27,55.1,387.55,91.0,387.55, ,387.83,-0.8,388.10,0.992,,,,,
,390.86,62.97,391.13,37.0,388.90,100.0,389.17,   00011,389.45,297,389.73,48.8,390.02,91.0,390.02, ,390.29,5.5,390.58,0.821,,,,,
,393.34,9.72,393.62,38.0,391.40,36.5,391.68,   00011,391.95,295,392.23,25.4,392.52,91.0,392.52, ,392.79,0.0,393.06,0.984,,,,,
,395.81,8.83,396.09,39.0,393.90,7.8,394.17,   00010,394.45,279,394.73,14.5,394.99,91.0,394.99, ,395.27,0.0,395.54,1.991,,,,,
,398.28,8.58,398.56,39.0,396.38,7.8,396.65,   00010,396.91,294,397.18,14.5,397.45,91.0,397.45, ,397.73,0.0,398.01,1.991,,,,,
,400.82,8.47,401.09,39.0,398.84,7.5,399.13,   00010,399.41,295,399.69,15.2,399.97,91.0,399.97, ,400.25,0.0,400.53,1.991,,,,,
,403.26,65.53,403.54,38.0,401.35,28.6,401.62,   01010,401.88,310,402.15,55.9,402.42,91.0,402.42, ,402.70,2.3,402.97,0.984,,,,,
,405.75,69.58,406.02,37.0,403.81,100.0,404.07,   00011,404.35,302,404.63,62.1,404.91,91.0,404.91, ,405.18,3.9,405.46,0.969,,,,,
,408.18,12.78,408.44,37.0,406.30,100.0,406.56,   00011,406.83,293,407.10,30.1,407.36,91.0,407.36, ,407.63,0.0,407.91,0.891,,,,,
,410.69,10.36,410.97,38.0,408.71,8.2,408.99,   01010,409.29,287,409.56,16.0,409.84,91.0,409.84, ,410.12,3.9,410.40,0.992,,,,,
,413.15,8.86,413.44,39.0,411.24,7.8,411.50,   00010,411.78,283,412.05,14.5,412.32,91.0,412.32, ,412.60,0.0,412.87,1.991,,,,,
,415.64,18.28,415.91,39.0,413.71,7.8,413.99,   01010,414.27,310,414.55,30.5,414.83,91.0,414.83, ,415.11,3.1,415.37,0.938,,,,,
,418.14,51.58,418.41,37.0,416.18,17.6,416.46,   01011,416.74,300,417.02,54.7,417.30,91.0,417.30, ,417.58,2.3,417.86,0.961,,,,,
,420.61,82.00,420.90,36.0,418.68,100.0,418.94,   00011,419.21,300,419.48,61.7,419.77,91.0,419.77, ,420.06,0.0,420.33,0.844,,,,,
,423.10,10.53,423.36,37.0,421.17,11.0,421.45,   00010,421.73,293,422.00,14.5,422.28,91.0,422.28, ,422.54,0.0,422.83,1.078,,,,,
,425.51,8.67,425.78,38.0,423.63,8.2,423.89,   01011,424.16,290,424.43,14.5,424.70,91.0,424.70, ,424.97,0.0,425.24,1.991,,,,,
,427.90,13.69,428.16,38.0,426.04,7.8,426.30,   01010,426.56,310,426.83,22.7,427.10,91.0,427.10, ,427.37,4.7,427.63,0.953,,,,,
,430.37,23.42,430.64,38.0,428.43,9.8,428.70,   01011,428.98,296,429.28,27.0,429.54,91.0,429.54, ,429.81,2.3,430.09,0.953,,,,,
,432.82,28.47,433.09,37.0,430.92,19.6,431.21,   01011,431.47,301,431.74,35.5,432.01,91.0,432.01, ,432.27,0.8,432.54,0.977,,,,,
,435.28,47.86,435.57,37.0,433.36,20.8,433.64,   00011,433.92,297,434.21,38.7,434.47,91.0,434.47, ,434.74,0.8,435.01,1.008,,,,,
,437.75,64.92,438.03,36.0,435.85,99.6,436.13,   00011,436.41,299,436.68,52.0,436.95,91.0,436.95, ,437.21,1.6,437.48,1.008,,,,,
,440.27,12.61,440.54,36.0,438.31,100.0,438.59,   00011,438.87,297,439.15,39.5,439.43,91.0,439.43, ,439.72,0.0,440.00,0.938,,,,,
,442.71,9.89,442.99,37.0,440.81,9.0,441.07,   00011,441.36,284,441.62,14.5,441.89,91.0,441.89, ,442.16,0.0,442.43,0.945,,,,,
,445.20,11.25,445.47,37.0,443.28,7.8,443.57,   00010,443.84,284,444.12,14.5,444.41,91.0,444.41, ,444.67,0.0,444.94,1.538,,,,,
,447.64,28.64,447.91,37.0,445.74,12.9,446.01,   01011,446.30,295,446.57,34.0,446.84,91.0,446.84, ,447.11,3.1,447.38,0.953,,,,,
,450.13,30.28,450.40,36.0,448.18,6.7,448.46,   01010,448.73,296,449.02,30.9,449.31,91.0,449.31, ,449.59,1.6,449.86,1.008,,,,,
,452.58,44.69,452.85,36.0,450.68,26.7,450.94,   00011,451.21,300,451.48,41.8,451.77,91.0,451.77, ,452.04,2.3,452.31,1.000,,,,,
,455.09,91.53,455.38,36.0,453.12,90.2,453.40,   00011,453.67,298,453.95,53.1,454.23,91.0,454.23, ,454.51,3.9,454.81,0.945,,,,,
,457.58,12.39,457.85,36.0,455.65,100.0,455.92,   00011,456.20,298,456.46,34.4,456.74,91.0,456.74, ,457.01,0.0,457.30,0.813,,,,,
,460.04,9.50,460.31,36.0,458.11,7.8,458.38,   01010,458.66,286,458.93,14.5,459.22,91.0,459.22, ,459.49,2.3,459.77,0.945,,,,,
,462.53,8.50,462.81,37.0,460.58,7.8,460.85,   00010,461.12,279,461.40,14.5,461.68,91.0,461.68, ,461.97,0.0,462.25,1.991,,,,,
,464.98,17.14,465.26,37.0,463.07,7.5,463.35,   00010,463.61,298,463.88,20.3,464.15,91.0,464.15, ,464.43,0.0,464.71,0.984,,,,,
,467.48,40.94,467.76,36.0,465.56,14.5,465.84,   01011,466.11,300,466.38,34.0,466.65,91.0,466.65, ,466.93,3.9,467.21,0.945,,,,,
,469.99,99.64,470.26,35.0,468.03,49.4,468.31,   00011,468.60,301,468.87,68.4,469.16,91.0,469.16, ,469.43,7.0,469.72,1.031,,,,,
,472.44,17.94,472.71,36.0,470.52,94.9,470.79,   00010,471.05,291,471.33,28.5,471.61,91.0,471.61, ,471.89,1.6,472.18,0.953,,,,,
,474.88,9.17,475.16,36.0,472.98,12.9,473.24,   00011,473.50,291,473.78,14.5,474.06,91.0,474.06, ,474.33,-2.3,474.61,0.961,,,,,
,477.38,8.25,477.66,36.0,475.43,7.5,475.71,   00010,476.00,287,476.28,14.5,476.55,91.0,476.55, ,476.83,0.0,477.10,1.991,,,,,
,479.86,19.72,480.14,36.0,477.93,8.2,478.21,   01010,478.48,312,478.75,25.8,479.02,91.0,479.02, ,479.29,2.3,479.58,0.930,,,,,
,482.35,35.86,482.62,36.0,480.42,20.4,480.70,   01011,480.98,300,481.25,35.2,481.52,91.0,481.52, ,481.79,0.0,482.08,0.961,,,,,
,484.83,34.47,485.10,36.0,482.90,31.4,483.18,   00011,483.47,299,483.73,38.3,484.00,91.0,484.00, ,484.27,3.1,484.54,0.984,,,,,
,487.27,46.89,487.54,35.0,485.37,19.6,485.65,   00010,485.92,294,486.19,37.1,486.46,91.0,486.46, ,486.72,3.9,487.00,0.977,,,,,
,489.72,47.22,489.99,35.0,487.84,99.6,488.11,   00011,488.39,297,488.66,52.3,488.93,91.0,488.93, ,489.19,2.3,489.46,0.969,,,,,
,492.15,40.92,492.43,34.0,490.25,100.0,490.52,   00011,490.79,295,491.05,51.6,491.33,91.0,491.33, ,491.60,3.1,491.87,0.797,,,,,
,494.63,9.08,494.90,36.0,492.71,16.9,492.99,   00011,493.26,291,493.54,25.0,493.82,91.0,493.82, ,494.09,-2.3,494.35,1.008,,,,,
,497.13,14.42,497.40,36.0,495.18,7.5,495.46,   00010,495.75,286,496.03,14.5,496.31,91.0,496.31, ,496.59,0.0,496.86,1.094,,,,,
,499.60,48.61,499.87,36.0,497.68,17.3,497.95,   01011,498.22,295,498.49,35.2,498.76,91.0,498.76, ,499.04,2.3,499.32,0.953,,,,,
,502.11,17.47,502.38,34.0,500.16,100.0,500.44,   00011,500.72,295,501.00,39.1,501.28,91.0,501.28, ,501.56,0.0,501.85,0.961,,,,,
,504.61,18.78,504.88,35.0,502.65,14.1,502.93,   00011,503.20,290,503.48,29.7,503.76,91.0,503.76, ,504.04,3.1,504.34,0.984,,,,,
,507.09,14.64,507.36,36.0,505.15,7.1,505.44,   00011,505.72,292,506.00,14.5,506.28,91.0,506.28, ,506.55,-0.8,506.82,1.000,,,,,
,509.61,55.56,509.87,35.0,507.63,14.5,507.90,   00011,508.19,296,508.47,52.0,508.75,91.0,508.75, ,509.03,1.6,509.31,0.984,,,,,
,512.08,88.64,512.36,34.0,510.15,100.0,510.43,   00011,510.70,302,510.98,55.1,511.27,91.0,511.27, ,511.55,3.1,511.82,0.945,,,,,
,514.54,9.36,514.80,34.0,512.63,100.0,512.90,   00011,513.18,297,513.45,28.1,513.72,91.0,513.72, ,514.00,0.0,514.27,0.977,,,,,
,517.00,19.17,517.28,36.0,515.08,7.8,515.36,   00011,515.64,290,515.92,23.4,516.20,91.0,516.20, ,516.47,0.8,516.74,0.953,,,,,
,519.50,8.72,519.78,36.0,517.56,16.5,517.84,   00011,518.11,293,518.38,20.7,518.67,91.0,518.67, ,518.95,-1.6,519.24,0.992,,,,,
,522.00,29.08,522.27,36.0,520.05,9.4,520.32,   00011,520.61,295,520.89,32.0,521.17,91.0,521.17, ,521.45,-1.6,521.73,1.023,,,,,
,524.46,55.83,524.74,34.0,522.53,20.4,522.80,   00011,523.07,299,523.36,44.5,523.62,91.0,523.62, ,523.90,0.8,524.18,0.969,,,,,
,526.93,98.42,527.20,34.0,525.01,100.0,525.28,   00011,525.55,302,525.82,61.3,526.08,91.0,526.08, ,526.36,5.5,526.64,0.836,,,,,
,529.36,11.72,529.62,34.0,527.48,31.0,527.73,   00011,528.00,298,528.27,30.5,528.53,91.0,528.53, ,528.80,0.0,529.07,0.930,,,,,
,531.79,9.22,532.07,36.0,529.89,7.8,530.16,   00011,530.43,290,530.71,19.5,530.98,91.0,530.98, ,531.25,1.6,531.52,0.984,,,,,
,534.25,12.53,534.52,36.0,532.37,8.6,532.63,   00011,532.89,292,533.16,24.6,533.43,91.0,533.43, ,533.71,0.0,533.99,0.992,,,,,
,536.72,34.39,536.99,35.0,534.79,14.9,535.07,   00011,535.37,296,535.64,34.4,535.92,91.0,535.92, ,536.19,3.1,536.46,0.992,,,,,
,539.16,27.94,539.43,34.0,537.25,24.3,537.52,   00011,537.79,297,538.07,35.5,538.34,91.0,538.34, ,538.64,0.8,538.90,0.977,,,,,
,541.65,23.64,541.92,34.0,539.70,16.5,539.98,   00011,540.26,295,540.55,30.5,540.81,91.0,540.81, ,541.08,-5.5,541.36,0.961,,,,,
,544.16,18.36,544.43,35.0,542.20,15.3,542.49,   00011,542.77,296,543.04,30.1,543.32,91.0,543.32, ,543.59,-6.3,543.88,0.969,,,,,
,546.64,47.64,546.91,34.0,544.70,14.1,544.98,   00010,545.25,295,545.53,43.8,545.82,91.0,545.82, ,546.10,-1.6,546.38,1.008,,,,,
,549.10,48.64,549.37,34.0,547.18,100.0,547.45,   00011,547.73,299,548.00,44.9,548.28,91.0,548.28, ,548.56,0.0,548.83,0.977,,,,,
,551.56,101.97,551.84,34.0,549.65,100.0,549.92,   00011,550.20,297,550.46,66.4,550.73,91.0,550.73, ,551.00,0.8,551.28,0.992,,,,,
,554.04,11.67,554.32,34.0,552.13,19.2,552.40,   00010,552.69,288,552.95,14.5,553.22,91.0,553.22, ,553.49,0.0,553.76,1.991,,,,,
,556.51,8.19,556.79,36.0,554.59,7.8,554.88,   01011,555.15,292,555.44,14.5,555.71,91.0,555.71, ,555.97,0.0,556.24,1.991,,,,,
,558.98,9.14,559.26,36.0,557.07,7.1,557.34,   00010,557.63,294,557.89,14.5,558.16,91.0,558.16, ,558.43,0.0,558.71,1.991,,,,,
,561.47,8.81,561.74,36.0,559.52,7.8,559.79,   01011,560.07,297,560.34,22.3,560.63,91.0,560.63, ,560.92,4.7,561.20,0.945,,,,,
,563.91,8.56,564.18,36.0,562.01,7.5,562.27,   01011,562.54,295,562.81,19.1,563.09,91.0,563.09, ,563.37,3.1,563.65,0.930,,,,,
,566.38,20.22,566.66,36.0,564.45,9.0,564.73,   01011,565.01,293,565.28,30.9,565.56,91.0,565.56, ,565.85,0.0,566.12,0.945,,,,,
,568.91,23.94,569.18,35.0,566.93,9.8,567.20,   00011,567.49,297,567.77,36.3,568.05,91.0,568.05, ,568.33,0.8,568.61,0.984,,,,,
,571.36,15.92,571.64,35.0,569.45,15.3,569.71,   00011,569.98,298,570.24,31.3,570.54,91.0,570.54, ,570.81,-4.7,571.09,0.914,,,,,
,573.81,26.28,574.08,35.0,571.93,8.6,572.18,   00011,572.46,295,572.72,30.9,572.99,91.0,572.99, ,573.27,-3.1,573.55,1.008,,,,,
,576.28,31.22,576.55,34.0,574.35,18.4,574.64,   00011,574.91,297,575.18,35.2,575.46,91.0,575.46, ,575.74,0.0,576.01,0.984,,,,,
,578.75,18.78,579.03,35.0,576.81,13.7,577.08,   00011,577.35,295,577.64,30.5,577.91,91.0,577.91, ,578.18,-1.6,578.47,0.977,,,,,
,581.25,20.89,581.53,35.0,579.30,14.5,579.57,   00011,579.85,294,580.13,30.5,580.41,91.0,580.41, ,580.69,-2.3,580.97,0.969,,,,,
,583.73,18.42,584.01,34.0,581.81,16.9,582.09,   00011,582.36,296,582.63,31.6,582.91,91.0,582.91, ,583.18,2.3,583.46,0.969,,,,,
,586.23,25.11,586.51,34.0,584.29,10.6,584.58,   00011,584.86,292,585.14,30.5,585.42,91.0,585.42, ,585.68,3.1,585.96,0.984,,,,,
,588.73,35.39,589.01,34.0,586.79,14.9,587.08,   00011,587.36,295,587.64,32.8,587.93,91.0,587.93, ,588.19,1.6,588.46,1.008,,,,,
,591.24,28.25,591.51,34.0,589.28,25.1,589.56,   00011,589.84,296,590.13,33.6,590.42,91.0,590.42, ,590.70,3.9,590.97,0.969,,,,,
,593.71,11.14,593.98,34.0,591.79,14.9,592.06,   00011,592.34,295,592.63,28.9,592.91,91.0,592.91, ,593.18,-0.8,593.44,0.953,,,,,
,596.17,25.97,596.46,34.0,594.26,8.6,594.53,   00011,594.80,292,595.07,31.3,595.34,91.0,595.34, ,595.62,2.3,595.89,1.008,,,,,
,598.64,33.56,598.92,34.0,596.74,18.4,597.02,   00011,597.29,297,597.55,33.6,597.81,91.0,597.81, ,598.09,3.1,598.36,1.000,,,,,
,601.14,30.14,601.42,34.0,599.21,21.2,599.49,   00011,599.77,297,600.05,32.8,600.32,91.0,600.32, ,600.58,-1.6,600.85,0.984,,,,,
,603.64,21.92,603.93,34.0,601.71,20.0,601.99,   00011,602.26,295,602.55,31.6,602.81,91.0,602.81, ,603.08,-4.7,603.35,0.984,,,,,
,606.18,29.25,606.45,34.0,604.21,11.8,604.50,   00011,604.78,293,605.06,30.9,605.34,91.0,605.34, ,605.62,-3.9,605.90,1.000,,,,,
,608.69,26.11,608.96,34.0,606.73,19.2,607.01,   00011,607.29,297,607.57,32.4,607.86,91.0,607.86, ,608.14,-1.6,608.41,0.984,,,,,
,611.15,18.25,611.44,34.0,609.24,12.5,609.51,   00011,609.79,294,610.06,27.7,610.33,91.0,610.33, ,610.60,-3.9,610.88,1.008,,,,,
,613.63,48.44,613.90,34.0,611.71,25.5,611.98,   00010,612.27,298,612.54,47.3,612.82,91.0,612.82, ,613.09,3.9,613.36,0.984,,,,,
,616.12,13.92,616.40,34.0,614.19,44.3,614.47,   00011,614.75,295,615.03,66.4,615.31,91.0,615.31, ,615.58,0.0,615.85,1.445,,,,,
3,618.61,14.28,618.89,34.0,616.69,11.4,616.96,   00010,617.23,287,617.50,65.2,617.77,91.0,617.77, ,618.05,0.0,618.33,1.991,,,,,
,621.06,51.69,621.34,34.0,621.61,18.8,621.89,   01010,619.70,295,619.97,32.8,620.25,91.0,620.25, ,620.51,0.0,620.79,0.906,,,,,
,623.53,13.36,623.81,34.0,624.09,10.6,624.38,   00010,622.17,295,622.47,57.0,622.72,91.0,622.72, ,622.99,0.0,623.26,1.991,,,,,
,626.37,57.17,626.66,34.0,626.94,11.8,627.23,   00010,624.66,298,625.26,14.5,625.53,91.0,625.53, ,625.82,3.9,626.09,0.930,,,,,
,628.92,11.67,629.25,34.0,629.52,9.4,629.87,   01010,627.51,299,627.79,57.8,628.08,91.0,628.08, ,628.36,6.3,628.64,1.304,,,,,
,631.56,61.78,631.85,33.0,632.13,10.6,632.41,   00010,630.14,297,630.43,55.9,630.72,91.0,630.72, ,630.99,1.6,631.27,0.906,,,,,
,634.07,12.22,634.36,34.0,634.64,9.8,634.93,   00010,632.69,298,632.98,46.9,633.24,91.0,633.24, ,633.53,0.0,633.81,1.125,,,,,
,636.61,54.72,636.89,34.0,637.18,24.7,637.46,   00010,635.21,281,635.50,40.6,635.78,91.0,635.78, ,636.06,0.8,636.34,0.945,,,,,
,639.12,8.97,639.41,34.0,639.69,40.4,639.95,   00010,637.73,297,638.01,51.6,638.30,91.0,638.30, ,638.56,3.1,638.84,0.938,,,,,
,641.61,19.92,641.89,34.0,642.17,9.8,642.44,   01010,640.23,289,640.51,59.0,640.79,91.0,640.79, ,641.06,0.0,641.32,0.922,,,,,
,644.11,49.44,644.38,34.0,644.64,97.3,644.92,   01011,642.71,288,642.99,19.5,643.26,91.0,643.26, ,643.55,0.0,643.83,0.938,,,,,
,646.62,11.81,646.90,34.0,647.19,8.6,647.46,   00011,645.20,299,645.47,53.5,645.77,91.0,645.77, ,646.06,0.0,646.34,0.883,,,,,
,649.14,49.19,649.41,33.0,649.69,100.0,649.97,   00011,647.74,291,648.01,43.8,648.29,91.0,648.29, ,648.58,0.0,648.86,0.906,,,,,
,651.62,73.97,651.89,33.0,652.17,100.0,652.45,   00011,650.24,296,650.51,53.9,650.79,91.0,650.79, ,651.08,3.1,651.35,0.899,,,,,
,654.09,11.22,654.37,33.0,654.63,7.8,654.91,   00011,652.72,296,653.00,32.4,653.27,91.0,653.27, ,653.54,0.0,653.83,0.977,,,,,
,656.62,9.31,656.90,34.0,657.19,6.7,657.48,   00011,655.20,289,655.49,23.4,655.76,91.0,655.76, ,656.03,0.0,656.32,0.984,,,,,
,659.17,7.00,659.44,34.0,659.72,5.9,660.00,   00010,657.76,293,658.04,14.5,658.32,91.0,658.32, ,658.61,0.0,658.90,1.991,,,,,
,661.69,6.33,661.98,35.0,662.28,5.5,662.55,   00010,660.28,296,660.56,14.5,660.84,91.0,660.84, ,661.13,0.0,661.41,1.991,,,,,
,664.24,5.97,664.53,35.0,664.82,5.1,665.11,   00010,662.84,297,663.11,14.5,663.39,91.0,663.39, ,663.67,0.0,663.94,1.991,,,,,
,666.78,5.25,667.06,35.0,667.36,4.7,667.62,   00010,665.40,298,665.68,14.5,665.95,91.0,665.95, ,666.23,0.0,666.50,1.991,,,,,
,669.34,4.50,669.62,36.0,669.91,3.5,670.20,   01010,667.89,297,668.18,14.5,668.47,91.0,668.47, ,668.76,0.0,669.05,1.991,,,,,
,671.93,3.47,672.21,36.0,672.48,2.7,672.77,   01011,670.49,304,670.78,14.5,671.07,91.0,671.07, ,671.34,0.0,671.64,1.047,,,,,
,674.45,3.33,674.73,37.0,675.00,2.7,675.29,   01011,673.06,295,673.35,14.5,673.64,91.0,673.64, ,673.91,3.1,674.18,0.945,,,,,
,676.97,27.06,677.26,36.0,677.54,12.9,677.82,   01011,675.57,296,675.84,27.3,676.13,91.0,676.13, ,676.40,0.8,676.68,0.914,,,,,
,679.51,40.08,679.80,34.0,680.09,25.5,680.38,   00011,678.09,300,678.38,34.4,678.68,91.0,678.68, ,678.96,3.9,679.22,0.969,,,,,
,682.10,51.08,682.39,34.0,682.69,100.0,682.97,   00011,680.68,301,680.95,62.9,681.22,91.0,681.22, ,681.51,4.7,681.81,0.961,,,,,
,684.70,11.44,684.98,34.0,685.25,7.1,685.53,   00010,683.26,299,683.54,32.0,683.83,91.0,683.83, ,684.11,0.0,684.40,0.938,,,,,
,687.24,3.69,687.52,35.0,687.81,2.4,688.10,   01011,685.82,280,686.10,14.5,686.39,91.0,686.39, ,686.68,0.0,686.95,1.008,,,,,
,689.84,3.06,690.12,36.0,690.42,2.4,690.69,   01011,688.39,292,688.69,14.5,688.98,91.0,688.98, ,689.26,0.0,689.55,0.914,,,,,
,692.40,3.56,692.69,37.0,692.98,3.1,693.28,   00011,690.96,293,691.25,14.5,691.53,91.0,691.53, ,691.82,-3.1,692.11,0.945,,,,,
,694.96,4.33,695.25,37.0,695.52,3.5,695.78,   00011,693.56,294,693.82,14.5,694.09,91.0,694.09, ,694.38,-5.5,694.67,0.984,,,,,
,697.53,4.61,697.82,36.0,698.11,3.9,698.38,   00011,696.07,294,696.36,14.5,696.65,91.0,696.65, ,696.94,-2.3,697.23,0.977,,,,,
,700.07,4.50,700.36,36.0,700.65,3.9,700.95,   00011,698.68,295,698.94,14.5,699.23,91.0,699.23, ,699.50,-3.1,699.80,0.977,,,,,
,702.63,4.72,702.93,36.0,703.21,3.9,703.48,   00011,701.23,296,701.50,14.5,701.80,91.0,701.80, ,702.08,-7.0,702.37,0.984,,,,,
,705.21,4.67,705.49,36.0,705.77,3.9,706.05,   00011,703.78,295,704.07,14.5,704.36,91.0,704.36, ,704.65,-6.3,704.92,0.992,,,,,
,707.72,4.86,707.99,36.0,708.25,3.9,708.52,   00011,706.32,294,706.61,14.5,706.89,91.0,706.89, ,707.17,-6.3,707.45,0.992,,,,,
14,710.18,4.75,710.46,36.0,710.74,3.9,711.01,   00011,708.79,297,709.05,14.5,709.33,91.0,709.33, ,709.61,-4.7,709.89,1.008,,,,,
22,712.67,4.89,712.95,36.0,713.21,3.9,713.49,   00011,711.29,296,711.57,14.5,711.84,91.0,711.84, ,712.12,0.0,712.40,1.008,,,,,
,715.12,4.86,715.40,36.0,715.68,3.9,715.98,   00011,713.77,295,714.03,14.5,714.30,91.0,714.30, ,714.57,1.6,714.85,1.008,,,,,
,717.62,4.78,717.90,36.0,718.20,3.9,718.46,   00011,716.26,295,716.53,14.5,716.80,91.0,716.80, ,717.07,2.3,717.35,0.992,,,,,
,720.08,5.03,720.35,36.0,720.62,3.9,720.90,   00011,718.72,296,718.99,14.5,719.26,91.0,719.26, ,719.54,3.1,719.81,0.992,,,,,
23,722.56,4.78,722.85,37.0,723.11,3.9,723.38,   00011,721.20,295,721.48,14.5,721.75,91.0,721.75, ,722.02,3.9,722.29,0.992,,,,,
,725.05,4.89,725.32,37.0,725.59,3.5,725.87,   00011,723.65,294,723.92,14.5,724.20,91.0,724.20, ,724.48,0.0,724.77,0.992,,,,,
26,727.54,4.89,727.81,37.0,728.08,3.5,728.35,   00011,726.16,295,726.43,14.5,726.72,91.0,726.72, ,726.99,0.0,727.27,0.992,,,,,
,730.02,4.89,730.30,37.0,730.58,3.5,730.86,   00011,728.62,296,728.89,14.5,729.17,91.0,729.17, ,729.45,0.0,729.75,0.992,,,,,
,732.51,5.00,732.78,37.0,733.06,3.9,733.33,   00011,731.14,296,731.41,14.5,731.68,91.0,731.68, ,731.95,-0.8,732.22,0.992,,,,,
,735.01,4.83,735.27,37.0,735.54,3.5,735.80,   00011,733.61,295,733.89,14.5,734.17,91.0,734.17, ,734.44,3.1,734.72,0.992,,,,,
,737.49,4.94,737.75,37.0,738.02,3.5,738.30,   00011,736.08,295,736.35,14.5,736.63,91.0,736.63, ,736.92,3.1,737.20,1.000,,,,,
,739.99,4.86,740.25,37.0,740.52,3.9,740.78,   00011,738.57,295,738.85,14.5,739.13,91.0,739.13, ,739.42,3.1,739.70,0.992,,,,,
,742.45,4.86,742.74,37.0,743.00,3.9,743.27,   00011,741.05,294,741.32,14.5,741.60,91.0,741.60, ,741.89,2.3,742.17,0.984,,,,,
Sunday,25,May,2025,12:05:46:07661-VCID:2809E8896EE2C59AE7B-513C,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,1.85,4.89,2.12,38.0,2.38,3.9,0.20,   00011,0.47,295,0.75,14.5,1.03,91.0,1.03, ,1.29,1.6,1.57,0.984,,,,,
,4.32,5.03,4.58,38.0,4.85,3.9,2.65,   00011,2.93,295,3.23,14.5,3.50,91.0,3.50, ,3.78,-2.3,4.04,0.984,,,,,
,6.79,4.94,7.07,38.0,7.34,3.9,5.12,   00011,5.40,296,5.68,14.5,5.97,91.0,5.97, ,6.24,-2.3,6.51,0.992,,,,,
,9.24,5.03,9.52,38.0,9.80,3.9,7.61,   00011,7.88,296,8.16,14.5,8.44,91.0,8.44, ,8.71,-2.3,8.97,0.992,,,,,
,11.72,4.97,11.99,38.0,12.25,3.9,10.06,   00011,10.35,295,10.62,14.5,10.91,91.0,10.91, ,11.18,-1.6,11.44,0.992,,,,,
,14.14,4.97,14.42,38.0,14.70,3.9,12.52,   00011,12.79,295,13.06,14.5,13.33,91.0,13.33, ,13.60,-1.6,13.87,0.992,,,,,
,16.68,5.06,16.96,39.0,17.24,3.9,14.98,   00011,15.26,296,15.55,14.5,15.84,91.0,15.84, ,16.11,-2.3,16.39,0.992,,,,,
,19.13,4.94,19.40,39.0,19.67,3.9,17.52,   00011,17.79,295,18.06,14.5,18.33,91.0,18.33, ,18.60,1.6,18.87,0.992,,,,,
,21.57,4.89,21.84,39.0,22.10,3.9,19.95,   00011,20.22,296,20.49,14.5,20.76,91.0,20.76, ,21.02,2.3,21.31,0.992,,,,,
,24.05,5.00,24.34,39.0,24.62,3.9,22.37,   00011,22.64,295,22.92,14.5,23.21,91.0,23.21, ,23.49,1.6,23.77,0.992,,,,,
,26.50,4.89,26.78,39.0,27.05,3.9,24.90,   00011,25.16,296,25.43,14.5,25.70,91.0,25.70, ,25.96,1.6,26.23,0.992,,,,,
,28.97,4.92,29.25,39.0,29.52,3.9,27.33,   00011,27.61,295,27.88,14.5,28.15,91.0,28.15, ,28.43,1.6,28.70,0.984,,,,,
,31.48,5.03,31.74,39.0,32.01,3.9,29.79,   00011,30.08,294,30.37,14.5,30.65,91.0,30.65, ,30.92,-2.3,31.20,0.984,,,,,
,33.93,4.92,34.20,39.0,34.49,3.9,32.27,   00011,32.54,296,32.83,14.5,33.10,91.0,33.10, ,33.37,-2.3,33.65,0.992,,,,,
,36.37,5.03,36.65,39.0,36.93,3.9,34.75,   00011,35.02,294,35.28,14.5,35.56,91.0,35.56, ,35.83,-2.3,36.09,0.984,,,,,
,38.87,5.11,39.16,39.0,39.44,3.9,37.20,   00011,37.48,294,37.76,14.5,38.04,91.0,38.04, ,38.32,-2.3,38.60,0.992,,,,,
,41.37,4.94,41.65,39.0,41.92,3.9,39.72,   00011,39.99,295,40.26,14.5,40.54,91.0,40.54, ,40.83,-2.3,41.09,0.992,,,,,
Sunday,25,May,2025,12:08:01:07661-VCID:2809E8896EE2C59AE7B-513C,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,1.03,4.89,1.31,42.0,1.59,3.9,1.86,   00011,2.13,295,2.39,14.5,0.19,91.0,0.19, ,0.47,-2.3,0.75,0.992,,,,,
,3.52,4.92,3.80,42.0,4.08,3.9,4.37,   00011,4.64,295,4.91,14.5,2.67,91.0,2.67, ,2.95,-2.3,3.23,0.984,,,,,
,6.00,4.94,6.28,42.0,6.56,3.9,6.83,   00011,7.12,296,7.40,14.5,5.18,91.0,5.18, ,5.45,-2.3,5.73,0.992,,,,,
,8.46,4.89,8.73,42.0,9.00,3.5,9.28,   00011,9.56,295,9.82,14.5,7.66,91.0,7.66, ,7.93,-2.3,8.19,0.992,,,,,
,10.93,4.92,11.21,42.0,11.48,3.9,11.74,   00011,12.01,295,12.28,14.5,10.09,91.0,10.09, ,10.36,-1.6,10.64,1.000,,,,,
,13.39,4.92,13.67,42.0,13.92,3.9,14.20,   00011,14.46,295,14.74,14.5,12.55,91.0,12.55, ,12.82,-2.3,13.12,0.992,,,,,
,15.85,4.89,16.12,42.0,16.41,3.9,16.68,   00011,16.96,295,17.24,14.5,15.02,91.0,15.02, ,15.28,2.3,15.56,0.992,,,,,
,18.34,4.89,18.62,42.0,18.91,3.9,19.18,   00011,19.46,295,19.73,14.5,17.51,91.0,17.51, ,17.79,1.6,18.07,0.992,,,,,
,20.85,4.81,21.12,42.0,21.41,3.9,21.69,   00011,21.97,294,22.24,14.5,20.01,91.0,20.01, ,20.29,2.3,20.57,0.992,,,,,
,23.34,4.86,23.62,43.0,23.90,3.9,24.16,   00011,24.43,295,24.70,14.5,22.51,91.0,22.51, ,22.79,1.6,23.07,0.992,,,,,
,25.82,4.86,26.09,43.0,26.38,3.9,26.64,   00011,26.90,294,27.16,14.5,24.98,91.0,24.98, ,25.26,-2.3,25.54,0.984,,,,,
,28.26,4.94,28.54,43.0,28.81,3.9,29.10,   00011,29.37,295,29.64,14.5,27.43,91.0,27.43, ,27.70,-2.3,27.98,0.992,,,,,
,30.75,11.28,31.04,43.0,31.30,23.1,31.58,   00011,31.85,306,32.11,36.3,29.91,91.0,29.91, ,30.19,0.0,30.47,0.883,,,,,
,33.22,38.92,33.50,42.0,33.78,21.2,34.06,   00011,34.34,300,34.63,36.7,32.38,91.0,32.38, ,32.67,6.3,32.95,0.984,,,,,
,35.71,35.56,35.98,42.0,36.25,24.7,36.53,   00011,36.81,297,37.10,41.0,34.90,91.0,34.90, ,35.17,-2.3,35.44,0.977,,,,,
,38.22,45.94,38.51,42.0,38.77,99.2,39.04,   00011,39.31,296,39.58,45.3,37.38,91.0,37.38, ,37.66,3.9,37.95,0.992,,,,,
,40.70,55.50,40.96,43.0,41.22,100.0,41.50,   00011,41.78,295,42.05,47.3,39.86,91.0,39.86, ,40.14,5.5,40.43,0.961,,,,,
,43.14,71.03,43.41,44.0,43.69,100.0,43.96,   00011,44.24,293,44.51,44.9,42.33,91.0,42.33, ,42.60,6.3,42.87,0.992,,,,,
,45.62,62.97,45.90,44.0,46.19,100.0,46.45,   00011,46.72,291,46.99,59.4,44.79,91.0,44.79, ,45.07,3.1,45.35,0.953,,,,,
,48.09,67.22,48.37,44.0,48.65,100.0,48.94,   00011,49.22,290,49.50,18.0,47.26,91.0,47.26, ,47.54,3.9,47.82,0.922,,,,,
,50.60,7.25,50.86,44.0,51.14,6.3,51.43,   01010,51.69,298,51.96,41.4,49.77,91.0,49.77, ,50.04,0.0,50.32,1.991,,,,,
,53.04,72.19,53.31,43.0,53.59,99.6,53.87,   00011,54.16,302,54.44,71.9,52.22,91.0,52.22, ,52.49,1.6,52.76,0.945,,,,,
,55.51,76.17,55.79,42.0,56.06,20.4,56.34,   00010,56.63,298,56.90,24.6,54.71,91.0,54.71, ,54.97,5.5,55.24,0.875,,,,,
,57.98,8.28,58.26,43.0,58.53,6.7,58.81,   00011,59.09,291,59.36,21.5,57.17,91.0,57.17, ,57.44,3.1,57.71,0.984,,,,,
,60.46,41.64,60.72,43.0,60.99,95.3,61.26,   00010,61.52,300,61.79,71.9,59.63,91.0,59.63, ,59.90,5.5,60.17,0.899,,,,,
,62.89,72.92,63.17,42.0,63.46,10.6,63.74,   00010,64.00,289,64.28,14.5,62.06,91.0,62.06, ,62.34,5.5,62.61,0.852,,,,,
,65.39,10.19,65.67,42.0,65.96,7.1,66.24,   01011,66.51,292,66.78,25.8,64.56,91.0,64.56, ,64.84,0.0,65.11,1.164,,,,,
,67.87,42.17,68.15,42.0,68.41,96.5,68.68,   00011,68.95,296,69.22,70.7,67.04,91.0,67.04, ,67.31,3.9,67.58,0.914,,,,,
,70.33,89.86,70.60,41.0,70.90,26.3,71.18,   00010,71.47,298,71.74,14.5,69.49,91.0,69.49, ,69.77,4.7,70.05,0.844,,,,,
,72.82,11.03,73.11,42.0,73.38,7.5,73.65,   01011,73.94,294,74.21,27.3,72.00,91.0,72.00, ,72.27,0.0,72.55,1.991,,,,,
,75.31,52.81,75.58,42.0,75.85,98.8,76.11,   00010,76.38,299,76.65,34.8,74.50,91.0,74.50, ,74.78,3.9,75.05,0.938,,,,,
,77.76,9.83,78.04,41.0,78.33,7.1,78.61,   00011,78.89,289,79.17,44.1,76.94,91.0,76.94, ,77.21,0.0,77.49,0.899,,,,,
,80.26,54.72,80.54,41.0,80.83,100.0,81.11,   00010,81.39,296,81.66,44.9,79.46,91.0,79.46, ,79.72,0.8,79.99,0.945,,,,,
,82.77,18.28,83.03,40.0,83.30,8.6,83.57,   00011,83.84,287,84.12,19.9,81.94,91.0,81.94, ,82.20,1.6,82.48,0.797,,,,,
,85.24,47.33,85.50,40.0,85.77,99.2,86.04,   00010,86.31,295,86.59,62.9,84.40,91.0,84.40, ,84.68,0.0,84.95,0.945,,,,,
,87.70,37.19,87.98,39.0,88.24,9.0,88.51,   00010,88.78,291,89.04,14.5,86.88,91.0,86.88, ,87.16,4.7,87.43,0.750,,,,,
,90.14,48.83,90.42,39.0,90.70,77.3,90.95,   00011,91.23,299,91.49,66.4,89.31,91.0,89.31, ,89.58,0.0,89.86,1.000,,,,,
,92.58,97.94,92.85,39.0,93.12,100.0,93.39,   00011,93.67,299,93.95,37.9,91.75,91.0,91.75, ,92.02,3.1,92.29,0.953,,,,,
,95.02,13.31,95.28,39.0,95.55,7.8,95.81,   01010,96.08,284,96.35,14.5,94.22,91.0,94.22, ,94.48,0.0,94.75,0.906,,,,,
,97.46,12.75,97.73,39.0,98.01,29.4,98.29,   00010,98.58,297,98.85,50.0,96.62,91.0,96.62, ,96.90,3.9,97.19,0.961,,,,,
,99.94,55.19,100.21,39.0,100.48,100.0,100.76,   00011,101.04,299,101.32,65.6,99.11,91.0,99.11, ,99.38,2.3,99.65,0.977,,,,,
,102.44,102.50,102.70,39.0,102.98,20.4,103.26,   00010,103.53,298,103.80,19.9,101.59,91.0,101.59, ,101.87,6.3,102.16,0.789,,,,,
,104.89,10.11,105.17,39.0,105.46,7.8,105.72,   00011,105.99,290,106.26,21.1,104.07,91.0,104.07, ,104.34,2.3,104.62,0.945,,,,,
,107.38,16.86,107.66,39.0,107.93,10.6,108.21,   00011,108.47,295,108.74,63.3,106.53,91.0,106.53, ,106.81,0.0,107.09,0.977,,,,,
,109.85,99.56,110.12,39.0,110.39,100.0,110.65,   00011,110.92,302,111.18,45.3,109.01,91.0,109.01, ,109.28,0.8,109.56,0.852,,,,,
,112.29,28.14,112.57,39.0,112.86,14.1,113.14,   00011,113.42,288,113.69,25.8,111.47,91.0,111.47, ,111.74,3.1,112.01,0.844,,,,,
,114.79,9.78,115.07,39.0,115.34,8.2,115.62,   00011,115.90,293,116.19,23.0,113.96,91.0,113.96, ,114.23,0.8,114.51,1.016,,,,,
,117.29,9.53,117.57,39.0,117.84,9.4,118.12,   00010,118.40,295,118.66,59.8,116.47,91.0,116.47, ,116.73,0.8,117.01,1.000,,,,,
,119.79,101.11,120.07,39.0,120.35,100.0,120.62,   00011,120.90,302,121.19,50.4,118.93,91.0,118.93, ,119.23,2.3,119.50,0.922,,,,,
,122.28,53.94,122.56,39.0,122.84,9.8,123.13,   00010,123.41,294,123.68,20.3,121.47,91.0,121.47, ,121.74,0.0,122.01,0.750,,,,,
,124.76,9.78,125.03,39.0,125.31,8.2,125.60,   00011,125.87,292,126.14,29.7,123.95,91.0,123.95, ,124.22,0.0,124.49,1.008,,,,,
,127.24,49.69,127.51,39.0,127.78,95.3,128.06,   00010,128.32,299,128.59,66.8,126.42,91.0,126.42, ,126.70,2.3,126.98,1.000,,,,,
,129.73,53.75,130.00,38.0,130.28,13.3,130.56,   00010,130.85,300,131.12,26.6,128.88,91.0,128.88, ,129.16,7.8,129.44,0.789,,,,,
,132.26,48.50,132.54,39.0,132.80,75.7,133.07,   00011,133.34,299,133.62,59.0,131.40,91.0,131.40, ,131.69,2.3,131.97,0.922,,,,,
,134.74,70.78,135.01,38.0,135.28,100.0,135.56,   00011,135.84,291,136.12,40.6,133.90,91.0,133.90, ,134.17,2.3,134.46,0.922,,,,,
,137.25,15.83,137.53,38.0,137.81,9.4,138.09,   00011,138.36,290,138.64,47.7,136.41,91.0,136.41, ,136.69,0.0,136.97,0.782,,,,,
,139.73,56.64,140.00,38.0,140.28,100.0,140.56,   00011,140.84,291,141.11,60.9,138.92,91.0,138.92, ,139.20,0.8,139.47,0.961,,,,,
,142.24,20.67,142.51,37.0,142.80,10.2,143.08,   00010,143.36,283,143.64,14.5,141.39,91.0,141.39, ,141.67,0.0,141.95,0.805,,,,,
,144.72,10.00,144.99,39.0,145.25,8.2,145.52,   01011,145.79,291,146.08,14.5,143.91,91.0,143.91, ,144.17,0.0,144.44,1.000,,,,,
,147.20,8.89,147.48,39.0,147.76,7.5,148.03,   00010,148.30,297,148.57,14.5,146.36,91.0,146.36, ,146.64,0.0,146.92,1.991,,,,,
,149.65,8.56,149.94,39.0,150.22,7.5,150.51,   00010,150.78,299,151.05,14.5,148.83,91.0,148.83, ,149.10,0.0,149.37,1.991,,,,,
,152.15,8.11,152.42,39.0,152.70,7.8,152.99,   01010,153.27,316,153.55,60.5,151.32,91.0,151.32, ,151.59,0.0,151.87,1.991,,,,,
,154.67,98.28,154.95,38.0,155.24,100.0,155.51,   00011,155.79,304,156.05,39.1,153.83,91.0,153.83, ,154.11,2.3,154.39,0.977,,,,,
,157.15,11.11,157.42,37.0,157.70,8.2,158.00,   00011,158.28,287,158.55,16.0,156.32,91.0,156.32, ,156.59,0.8,156.87,0.945,,,,,
,159.64,9.03,159.92,39.0,160.20,7.8,160.47,   00010,160.75,282,161.04,14.5,158.82,91.0,158.82, ,159.09,7.0,159.37,0.992,,,,,
,162.12,8.17,162.39,39.0,162.67,27.5,162.95,   01010,163.21,305,163.48,58.6,161.31,91.0,161.31, ,161.59,0.0,161.85,1.991,,,,,
,164.56,96.47,164.84,37.0,165.12,100.0,165.40,   00011,165.69,302,165.97,44.1,163.74,91.0,163.74, ,164.01,1.6,164.28,0.945,,,,,
,167.09,13.47,167.37,37.0,167.65,6.7,167.92,   01010,168.20,290,168.48,27.0,166.26,91.0,166.26, ,166.54,0.0,166.82,0.883,,,,,
,169.60,49.00,169.88,37.0,170.15,96.5,170.41,   00011,170.68,297,170.95,68.4,168.78,91.0,168.78, ,169.04,2.3,169.32,1.000,,,,,
,172.07,101.56,172.33,37.0,172.61,15.3,172.88,   00010,173.16,296,173.43,14.5,171.23,91.0,171.23, ,171.53,0.8,171.80,0.867,,,,,
,174.53,9.44,174.80,37.0,175.08,7.8,175.35,   00011,175.64,290,175.91,14.5,173.70,91.0,173.70, ,173.96,0.0,174.25,1.047,,,,,
,176.99,13.39,177.27,38.0,177.56,40.8,177.81,   01010,178.09,301,178.37,60.9,176.18,91.0,176.18, ,176.45,0.0,176.71,1.304,,,,,
,179.46,91.58,179.75,37.0,180.03,19.2,180.30,   00010,180.58,299,180.85,17.6,178.64,91.0,178.64, ,178.92,4.7,179.19,0.867,,,,,
,181.93,10.14,182.20,37.0,182.48,7.8,182.78,   01011,183.04,292,183.32,27.7,181.11,91.0,181.11, ,181.38,0.0,181.65,1.242,,,,,
,184.42,48.89,184.70,37.0,184.98,98.8,185.26,   00011,185.56,299,185.85,63.7,183.59,91.0,183.59, ,183.87,2.3,184.15,0.977,,,,,
,186.96,102.97,187.23,36.0,187.51,25.5,187.78,   00010,188.06,300,188.32,14.5,186.13,91.0,186.13, ,186.41,5.5,186.68,0.852,,,,,
,189.43,11.67,189.72,37.0,190.01,9.0,190.28,   01011,190.54,294,190.83,14.5,188.61,91.0,188.61, ,188.88,0.0,189.15,1.991,,,,,
,191.93,8.11,192.22,38.0,192.50,7.1,192.79,   00010,193.05,295,193.32,14.5,191.10,91.0,191.10, ,191.39,0.0,191.66,1.991,,,,,
,194.43,8.03,194.72,39.0,195.00,7.1,195.28,   00010,195.54,297,195.81,30.9,193.60,91.0,193.60, ,193.87,0.0,194.15,1.991,,,,,
,196.90,51.42,197.18,37.0,197.46,99.2,197.73,   01011,198.02,301,198.30,29.7,196.09,91.0,196.09, ,196.36,1.6,196.63,0.953,,,,,
,199.42,10.06,199.69,37.0,199.97,7.8,200.24,   01010,200.52,283,200.78,22.3,198.58,91.0,198.58, ,198.86,0.0,199.14,0.922,,,,,
,201.89,49.11,202.16,37.0,202.44,92.9,202.72,   01010,203.00,302,203.29,53.5,201.06,91.0,201.06, ,201.33,3.9,201.61,0.867,,,,,
,204.37,31.22,204.64,36.0,204.93,9.4,205.20,   00011,205.47,294,205.74,16.0,203.57,91.0,203.57, ,203.83,0.8,204.10,0.860,,,,,
,206.83,9.75,207.09,37.0,207.37,7.8,207.64,   00011,207.91,292,208.18,22.7,206.02,91.0,206.02, ,206.30,0.0,206.57,1.000,,,,,
,209.30,25.58,209.57,37.0,209.85,62.7,210.12,   00010,210.41,302,210.69,14.5,208.47,91.0,208.47, ,208.75,0.8,209.04,0.969,,,,,
,211.78,9.42,212.04,37.0,212.32,7.1,212.60,   00010,212.88,282,213.15,14.5,210.97,91.0,210.97, ,211.24,3.1,211.51,1.039,,,,,
,214.25,8.11,214.53,38.0,214.80,7.1,215.07,   00010,215.34,297,215.62,14.5,213.44,91.0,213.44, ,213.72,0.0,213.99,1.991,,,,,
,216.71,7.67,216.97,38.0,217.24,6.7,217.51,   00010,217.80,298,218.07,16.0,215.91,91.0,215.91, ,216.17,0.0,216.44,1.991,,,,,
,219.17,40.33,219.44,38.0,219.71,89.8,219.98,   01010,220.26,307,220.55,64.5,218.34,91.0,218.34, ,218.62,0.0,218.91,1.164,,,,,
,221.65,84.50,221.92,36.0,222.20,8.2,222.49,   00010,222.76,294,223.03,14.5,220.82,91.0,220.82, ,221.09,3.9,221.37,1.016,,,,,
,224.12,8.64,224.39,37.0,224.67,6.7,224.94,   00011,225.21,291,225.48,19.5,223.30,91.0,223.30, ,223.56,7.8,223.84,1.000,,,,,
,226.58,41.44,226.86,37.0,227.14,91.4,227.43,   00011,227.70,301,227.98,61.3,225.74,91.0,225.74, ,226.02,6.3,226.31,0.930,,,,,
,229.06,95.08,229.34,36.0,229.61,20.4,229.89,   00010,230.17,297,230.44,14.5,228.24,91.0,228.24, ,228.51,3.1,228.78,0.852,,,,,
,231.51,11.69,231.78,37.0,232.05,7.8,232.33,   01011,232.60,294,232.87,14.5,230.71,91.0,230.71, ,230.98,0.0,231.24,1.991,,,,,
,233.93,12.47,234.22,37.0,234.49,11.0,234.77,   00011,235.05,297,235.31,36.7,233.13,91.0,233.13, ,233.40,4.7,233.67,1.000,,,,,
,236.41,72.97,236.69,37.0,236.97,99.6,237.25,   00011,237.54,299,237.81,40.2,235.59,91.0,235.59, ,235.86,1.6,236.14,0.977,,,,,
,238.90,12.83,239.18,36.0,239.45,13.3,239.72,   01010,239.99,291,240.25,14.5,238.07,91.0,238.07, ,238.36,0.0,238.63,0.914,,,,,
,241.35,8.36,241.64,37.0,241.91,7.5,242.17,   00011,242.44,293,242.71,14.5,240.52,91.0,240.52, ,240.79,0.0,241.08,0.992,,,,,
,243.84,44.89,244.10,37.0,244.36,97.6,244.63,   01010,244.90,298,245.18,54.7,242.98,91.0,242.98, ,243.26,0.0,243.55,0.953,,,,,
,246.30,87.36,246.59,36.0,246.85,12.9,247.12,   00010,247.40,300,247.67,14.5,245.46,91.0,245.46, ,245.73,3.9,246.01,0.828,,,,,
,248.77,9.42,249.04,37.0,249.32,7.5,249.59,   01011,249.86,292,250.13,14.5,247.95,91.0,247.95, ,248.24,0.0,248.50,1.055,,,,,
,251.23,7.69,251.51,37.0,251.80,6.7,252.09,   00010,252.37,295,252.66,18.4,250.40,91.0,250.40, ,250.67,0.0,250.95,1.991,,,,,
,253.76,29.22,254.02,37.0,254.29,37.6,254.56,   01010,254.84,303,255.12,72.3,252.94,91.0,252.94, ,253.22,0.0,253.49,1.070,,,,,
,256.20,93.78,256.48,36.0,256.75,13.3,257.03,   00010,257.31,301,257.58,14.5,255.39,91.0,255.39, ,255.66,3.1,255.93,0.828,,,,,
,258.65,9.97,258.92,36.0,259.20,7.1,259.49,   01011,259.77,293,260.04,14.5,257.85,91.0,257.85, ,258.12,0.0,258.38,1.991,,,,,
,261.12,7.67,261.39,37.0,261.67,6.7,261.94,   00010,262.22,292,262.51,14.5,260.31,91.0,260.31, ,260.57,5.5,260.84,1.484,,,,,
,263.59,28.75,263.86,37.0,264.14,71.0,264.42,   01010,264.71,304,264.99,70.7,262.79,91.0,262.79, ,263.06,0.0,263.32,1.187,,,,,
,266.09,90.61,266.35,36.0,266.62,38.4,266.88,   00010,267.14,292,267.41,14.5,265.26,91.0,265.26, ,265.54,7.0,265.80,1.023,,,,,
,268.47,11.22,268.74,36.0,269.01,7.1,269.29,   01011,269.56,294,269.83,14.5,267.67,91.0,267.67, ,267.95,0.0,268.21,1.991,,,,,
,270.91,7.86,271.18,37.0,271.47,6.7,271.75,   01010,272.03,299,272.30,33.2,270.11,91.0,270.11, ,270.37,4.7,270.64,0.938,,,,,
,273.40,44.97,273.68,36.0,273.97,98.0,274.25,   01011,274.53,295,274.81,52.3,272.57,91.0,272.57, ,272.84,1.6,273.13,0.977,,,,,
,275.94,25.83,276.21,36.0,276.47,9.8,276.75,   00011,277.02,293,277.29,14.5,275.09,91.0,275.09, ,275.38,5.5,275.66,0.735,,,,,
,278.39,9.47,278.66,37.0,278.93,7.1,279.20,   01011,279.48,290,279.76,14.5,277.56,91.0,277.56, ,277.84,0.0,278.13,1.125,,,,,
,280.87,8.31,281.14,37.0,281.41,48.2,281.68,   00010,281.95,302,282.23,58.6,280.03,91.0,280.03, ,280.31,3.9,280.59,1.000,,,,,
,283.34,92.11,283.64,36.0,283.92,12.2,284.21,   00010,284.49,303,284.76,14.5,282.51,91.0,282.51, ,282.78,1.6,283.06,0.844,,,,,
,285.88,8.47,286.15,36.0,286.42,7.1,286.70,   01011,286.98,292,287.25,17.6,285.03,91.0,285.03, ,285.31,0.0,285.60,1.140,,,,,
,288.37,19.17,288.64,37.0,288.93,61.2,289.20,   01010,289.47,303,289.75,64.1,287.53,91.0,287.53, ,287.81,5.5,288.10,0.930,,,,,
,290.88,93.00,291.15,36.0,291.41,19.2,291.70,   00010,291.98,304,292.25,21.5,290.04,91.0,290.04, ,290.32,0.0,290.60,0.844,,,,,
,293.37,8.56,293.65,36.0,293.93,7.1,294.21,   00011,294.47,292,294.74,41.4,292.52,91.0,292.52, ,292.80,2.3,293.08,1.000,,,,,
,295.87,53.28,296.12,36.0,296.40,100.0,296.67,   00011,296.93,299,297.21,63.3,295.01,91.0,295.01, ,295.29,2.3,295.58,0.961,,,,,
,298.34,85.86,298.61,36.0,298.88,16.9,299.16,   00010,299.42,299,299.69,42.2,297.50,91.0,297.50, ,297.78,1.6,298.06,0.867,,,,,
,300.80,101.03,301.07,36.0,301.34,100.0,301.62,   00011,301.91,293,302.20,24.6,299.97,91.0,299.97, ,300.25,3.1,300.53,0.883,,,,,
,303.30,10.67,303.56,36.0,303.84,39.6,304.10,   00010,304.38,290,304.66,62.1,302.47,91.0,302.47, ,302.75,0.8,303.03,0.945,,,,,
,305.78,98.22,306.06,36.0,306.35,100.0,306.63,   00011,306.89,298,307.17,30.9,304.94,91.0,304.94, ,305.22,1.6,305.50,0.969,,,,,
,308.23,9.03,308.51,36.0,308.80,7.5,309.06,   01010,309.33,297,309.60,14.5,307.43,91.0,307.43, ,307.69,0.0,307.96,0.992,,,,,
,310.69,8.97,310.96,36.0,311.23,7.1,311.51,   00010,311.79,284,312.06,14.5,309.88,91.0,309.88, ,310.16,3.9,310.43,0.984,,,,,
,313.20,7.64,313.46,37.0,313.72,6.7,313.99,   00010,314.26,296,314.53,14.5,312.34,91.0,312.34, ,312.62,0.0,312.92,1.991,,,,,
,315.65,7.00,315.92,37.0,316.21,6.3,316.48,   00010,316.77,297,317.05,14.5,314.81,91.0,314.81, ,315.09,0.0,315.38,1.991,,,,,
,318.13,38.89,318.40,36.0,318.67,97.6,318.96,   01010,319.23,302,319.49,44.9,317.33,91.0,317.33, ,317.60,0.0,317.87,0.961,,,,,
,320.59,11.83,320.86,36.0,321.14,9.0,321.42,   00010,321.70,282,321.97,14.5,319.77,91.0,319.77, ,320.05,0.0,320.32,0.766,,,,,
,323.06,7.83,323.34,36.0,323.61,16.9,323.90,   01010,324.16,293,324.44,29.7,322.24,91.0,322.24, ,322.51,0.0,322.78,1.070,,,,,
,325.53,25.72,325.80,36.0,326.08,13.3,326.36,   01011,326.64,296,326.93,34.4,324.71,91.0,324.71, ,324.98,2.3,325.25,0.961,,,,,
,328.04,11.17,328.32,36.0,328.60,20.8,328.87,   00010,329.13,295,329.40,35.5,327.20,91.0,327.20, ,327.48,2.3,327.75,1.000,,,,,
,330.50,39.44,330.79,36.0,331.06,9.0,331.34,   00010,331.60,293,331.86,16.0,329.67,91.0,329.67, ,329.93,2.3,330.23,0.992,,,,,
,332.92,7.36,333.20,36.0,333.47,6.3,333.74,   00011,334.02,294,334.28,30.1,332.13,91.0,332.13, ,332.39,9.4,332.67,1.023,,,,,
,335.35,39.83,335.63,36.0,335.90,20.4,336.18,   00011,336.47,298,336.73,32.0,334.55,91.0,334.55, ,334.82,2.3,335.08,0.969,,,,,
,337.84,23.67,338.11,36.0,338.39,22.0,338.66,   00010,338.93,297,339.22,36.7,337.01,91.0,337.01, ,337.29,1.6,337.56,1.016,,,,,
,340.31,30.61,340.59,36.0,340.88,27.5,341.16,   00010,341.43,296,341.69,44.1,339.48,91.0,339.48, ,339.76,5.5,340.04,0.992,,,,,
,342.78,38.08,343.06,36.0,343.33,5.9,343.60,   00010,343.87,294,344.16,18.4,341.97,91.0,341.97, ,342.24,2.3,342.51,1.008,,,,,
,345.30,15.17,345.58,36.0,345.85,25.5,346.11,   00010,346.39,298,346.66,51.6,344.44,91.0,344.44, ,344.73,1.6,345.01,1.023,,,,,
,347.76,73.19,348.03,36.0,348.32,100.0,348.58,   00011,348.85,301,349.12,51.6,346.93,91.0,346.93, ,347.20,4.7,347.49,0.961,,,,,
,350.23,10.61,350.50,36.0,350.78,7.8,351.06,   00011,351.34,288,351.61,14.5,349.39,91.0,349.39, ,349.67,0.0,349.95,0.875,,,,,
,352.70,8.44,352.96,36.0,353.24,7.5,353.51,   00011,353.78,291,354.06,14.5,351.88,91.0,351.88, ,352.16,2.3,352.43,0.984,,,,,
,355.18,7.53,355.45,36.0,355.71,6.7,355.98,   01010,356.25,303,356.53,32.8,354.33,91.0,354.33, ,354.61,0.0,354.90,1.991,,,,,
,357.61,45.03,357.90,36.0,358.18,97.6,358.46,   01010,358.74,301,359.02,24.6,356.79,91.0,356.79, ,357.06,1.6,357.33,0.961,,,,,
,360.10,8.53,360.36,36.0,360.64,7.1,360.90,   00011,361.20,291,361.47,14.5,359.31,91.0,359.31, ,359.56,0.8,359.83,1.023,,,,,
,362.55,7.39,362.81,36.0,363.09,6.3,363.37,   00010,363.66,295,363.94,14.5,361.75,91.0,361.75, ,362.03,0.0,362.29,1.991,,,,,
,365.06,6.03,365.34,37.0,365.62,5.1,365.91,   00010,366.17,297,366.45,14.5,364.21,91.0,364.21, ,364.49,0.0,364.78,1.991,,,,,
,367.55,5.42,367.82,37.0,368.10,4.7,368.37,   00010,368.65,298,368.92,19.1,366.73,91.0,366.73, ,367.03,0.0,367.28,1.991,,,,,
,370.05,17.44,370.33,37.0,370.60,33.3,370.86,   01010,371.13,303,371.40,44.9,369.20,91.0,369.20, ,369.48,0.0,369.77,1.078,,,,,
,372.52,47.42,372.79,36.0,373.06,38.8,373.34,   00010,373.61,300,373.89,21.9,371.67,91.0,371.67, ,371.95,3.1,372.23,0.969,,,,,
,374.96,7.56,375.23,36.0,375.52,5.5,375.79,   00011,376.06,292,376.34,21.5,374.16,91.0,374.16, ,374.43,3.1,374.69,1.039,,,,,
,377.46,12.00,377.72,36.0,377.99,5.5,378.26,   00011,378.53,294,378.82,34.4,376.63,91.0,376.63, ,376.91,1.6,377.18,1.000,,,,,
,379.90,13.72,380.17,36.0,380.45,5.5,380.72,   00011,381.00,293,381.28,14.5,379.10,91.0,379.10, ,379.37,0.0,379.63,1.016,,,,,
,382.37,5.67,382.64,37.0,382.92,4.7,383.19,   00011,383.47,294,383.75,14.5,381.57,91.0,381.57, ,381.84,3.9,382.10,1.000,,,,,
,384.87,5.42,385.13,37.0,385.40,11.4,385.67,   00010,385.95,296,386.20,34.4,384.03,91.0,384.03, ,384.30,3.9,384.58,0.984,,,,,
,387.31,23.31,387.57,36.0,387.87,19.2,388.14,   00011,388.40,298,388.67,39.1,386.48,91.0,386.48, ,386.75,-2.3,387.03,0.984,,,,,
,389.77,30.25,390.04,36.0,390.34,55.3,390.62,   00011,390.89,297,391.17,32.0,388.94,91.0,388.94, ,389.22,1.6,389.50,0.984,,,,,
,392.30,18.58,392.58,36.0,392.84,18.8,393.10,   00010,393.39,296,393.64,35.9,391.45,91.0,391.45, ,391.73,2.3,392.01,0.977,,,,,
,394.72,52.14,394.99,36.0,395.26,65.9,395.54,   00011,395.82,301,396.10,42.2,393.91,91.0,393.91, ,394.19,3.1,394.45,0.984,,,,,
,397.21,9.44,397.47,36.0,397.74,18.8,398.01,   00010,398.29,295,398.58,46.9,396.37,91.0,396.37, ,396.65,2.3,396.94,0.867,,,,,
,399.67,51.75,399.94,36.0,400.21,100.0,400.48,   00011,400.76,298,401.03,71.5,398.85,91.0,398.85, ,399.12,3.1,399.40,1.023,,,,,
,402.14,110.47,402.41,35.0,402.68,19.6,402.97,   00010,403.25,288,403.53,25.8,401.30,91.0,401.30, ,401.57,7.0,401.87,0.984,,,,,
,404.63,12.42,404.90,36.0,405.17,6.7,405.45,   00011,405.73,292,406.00,35.5,403.81,91.0,403.81, ,404.09,0.0,404.36,0.984,,,,,
,407.12,48.42,407.40,36.0,407.67,99.2,407.96,   00011,408.23,293,408.49,55.1,406.28,91.0,406.28, ,406.56,0.8,406.84,0.992,,,,,
,409.56,93.39,409.83,35.0,410.12,21.6,410.40,   00010,410.67,304,410.93,18.8,408.76,91.0,408.76, ,409.02,4.7,409.29,0.821,,,,,
,412.03,8.53,412.28,36.0,412.56,14.9,412.82,   00010,413.09,293,413.36,42.2,411.20,91.0,411.20, ,411.47,3.1,411.75,1.023,,,,,
,414.47,47.14,414.74,36.0,415.00,100.0,415.27,   00011,415.55,297,415.83,51.6,413.64,91.0,413.64, ,413.93,2.3,414.21,0.977,,,,,
,416.92,49.11,417.19,36.0,417.46,100.0,417.75,   00011,418.03,295,418.31,59.4,416.12,91.0,416.12, ,416.39,1.6,416.66,0.969,,,,,
,419.43,101.81,419.69,35.0,419.96,99.6,420.23,   00011,420.51,294,420.78,34.0,418.60,91.0,418.60, ,418.88,5.5,419.16,0.828,,,,,
,421.90,10.56,422.17,36.0,422.42,7.8,422.70,   00011,422.97,287,423.25,19.1,421.06,91.0,421.06, ,421.34,0.0,421.61,0.961,,,,,
,424.37,28.67,424.64,36.0,424.91,30.6,425.19,   00010,425.47,297,425.75,39.8,423.53,91.0,423.53, ,423.81,0.8,424.08,0.969,,,,,
,426.85,19.11,427.12,36.0,427.38,8.6,427.65,   00010,427.92,290,428.20,22.3,426.03,91.0,426.03, ,426.30,2.3,426.57,0.992,,,,,
,429.29,13.89,429.56,36.0,429.84,17.3,430.11,   00010,430.39,297,430.65,37.5,428.46,91.0,428.46, ,428.73,6.3,428.99,1.000,,,,,
,431.73,45.78,432.01,36.0,432.29,95.7,432.58,   00011,432.86,301,433.14,34.4,430.92,91.0,430.92, ,431.19,2.3,431.46,1.008,,,,,
,434.21,9.42,434.49,36.0,434.76,7.5,435.04,   00011,435.32,292,435.60,14.5,433.41,91.0,433.41, ,433.67,0.0,433.94,0.930,,,,,
,436.71,7.61,436.99,36.0,437.25,6.7,437.52,   00010,437.79,296,438.07,19.9,435.87,91.0,435.87, ,436.16,0.0,436.44,1.991,,,,,
,439.19,15.69,439.46,36.0,439.73,7.5,440.01,   01011,440.28,297,440.56,21.9,438.34,91.0,438.34, ,438.62,0.0,438.92,1.031,,,,,
,441.68,8.00,441.94,36.0,442.21,6.3,442.48,   00010,442.74,283,443.01,14.5,440.84,91.0,440.84, ,441.12,4.7,441.42,0.992,,,,,
,444.13,6.64,444.41,36.0,444.66,5.9,444.93,   00010,445.20,296,445.48,14.5,443.28,91.0,443.28, ,443.57,0.0,443.85,1.991,,,,,
,446.59,13.97,446.87,36.0,447.16,19.6,447.43,   01010,447.70,299,447.97,71.1,445.75,91.0,445.75, ,446.03,0.0,446.32,1.101,,,,,
,449.09,102.69,449.37,36.0,449.66,29.8,449.92,   00010,450.19,294,450.46,14.5,448.25,91.0,448.25, ,448.53,2.3,448.81,1.023,,,,,
,451.56,7.42,451.82,36.0,452.11,5.9,452.39,   01010,452.67,305,452.94,14.5,450.73,91.0,450.73, ,451.00,0.0,451.28,1.991,,,,,
,454.05,6.92,454.33,36.0,454.60,5.1,454.87,   01010,455.14,283,455.39,14.5,453.22,91.0,453.22, ,453.50,5.5,453.78,0.961,,,,,
,456.49,11.86,456.79,36.0,457.06,8.2,457.33,   01011,457.61,291,457.89,40.2,455.68,91.0,455.68, ,455.95,0.0,456.22,1.250,,,,,
,458.99,26.89,459.25,36.0,459.52,15.3,459.80,   01010,460.07,297,460.36,29.7,458.16,91.0,458.16, ,458.45,0.8,458.72,0.977,,,,,
,461.43,12.47,461.71,36.0,461.99,14.1,462.26,   00011,462.54,296,462.83,31.6,460.63,91.0,460.63, ,460.90,2.3,461.17,1.000,,,,,
,463.95,14.50,464.24,36.0,464.50,10.2,464.77,   00010,465.04,296,465.32,44.1,463.10,91.0,463.10, ,463.39,0.0,463.68,0.992,,,,,
,466.44,68.08,466.72,36.0,467.00,100.0,467.27,   00011,467.54,302,467.80,28.5,465.60,91.0,465.60, ,465.87,0.8,466.16,1.023,,,,,
,468.90,11.03,469.18,36.0,469.45,10.2,469.73,   00011,470.02,289,470.30,55.5,468.07,91.0,468.07, ,468.34,1.6,468.62,0.953,,,,,
,471.39,68.69,471.69,35.0,471.95,100.0,472.23,   00011,472.51,295,472.79,38.3,470.57,91.0,470.57, ,470.84,2.3,471.12,0.914,,,,,
,473.87,34.00,474.13,35.0,474.41,15.7,474.70,   00011,474.98,290,475.24,28.1,473.07,91.0,473.07, ,473.33,0.8,473.60,0.782,,,,,
,476.32,14.69,476.60,36.0,476.88,34.5,477.16,   00010,477.44,296,477.71,66.0,475.51,91.0,475.51, ,475.78,-2.3,476.05,0.977,,,,,
,478.81,79.83,479.08,35.0,479.35,40.4,479.61,   00010,479.88,291,480.16,14.5,477.99,91.0,477.99, ,478.26,3.9,478.55,0.867,,,,,
,481.26,8.06,481.54,36.0,481.82,6.7,482.09,   00011,482.36,291,482.63,48.0,480.44,91.0,480.44, ,480.71,4.7,480.98,1.031,,,,,
,483.71,74.58,483.98,35.0,484.26,100.0,484.55,   00011,484.82,299,485.08,54.7,482.90,91.0,482.90, ,483.17,3.1,483.44,0.938,,,,,
,486.18,13.72,486.45,35.0,486.73,8.2,487.02,   00010,487.29,283,487.55,14.5,485.35,91.0,485.35, ,485.62,0.0,485.90,0.704,,,,,
,488.66,8.69,488.95,36.0,489.24,7.1,489.52,   01011,489.79,292,490.06,14.5,487.82,91.0,487.82, ,488.09,0.0,488.37,0.992,,,,,
,491.20,5.92,491.47,36.0,491.74,4.7,492.02,   00010,492.29,294,492.56,14.5,490.34,91.0,490.34, ,490.62,0.0,490.91,1.991,,,,,
,493.68,2.67,493.95,37.0,494.24,3.9,494.52,   01010,494.80,304,495.07,14.5,492.84,91.0,492.84, ,493.12,0.0,493.39,1.991,,,,,
,496.14,3.78,496.43,39.0,496.72,2.7,496.98,   01011,497.24,296,497.51,14.5,495.33,91.0,495.33, ,495.60,0.0,495.87,0.945,,,,,
,498.61,3.44,498.89,39.0,499.17,2.7,499.45,   01011,499.73,296,500.00,14.5,497.78,91.0,497.78, ,498.06,1.6,498.33,0.945,,,,,
,501.10,3.25,501.37,39.0,501.64,2.7,501.92,   00011,502.19,296,502.47,14.5,500.29,91.0,500.29, ,500.56,1.6,500.84,0.945,,,,,
,503.57,3.14,503.85,39.0,504.15,2.7,504.43,   00011,504.71,296,504.98,14.5,502.75,91.0,502.75, ,503.04,0.0,503.31,0.984,,,,,
,506.11,3.86,506.38,40.0,506.65,4.7,506.93,   00011,507.22,296,507.48,14.5,505.27,91.0,505.27, ,505.54,-3.9,505.83,0.961,,,,,
,508.57,4.75,508.85,39.0,509.12,3.9,509.40,   00011,509.69,296,509.97,14.5,507.75,91.0,507.75, ,508.02,-6.3,508.29,0.977,,,,,
,511.08,4.83,511.35,39.0,511.62,3.9,511.90,   00011,512.17,295,512.46,14.5,510.24,91.0,510.24, ,510.51,-6.3,510.80,0.992,,,,,
,513.58,4.89,513.86,39.0,514.14,3.9,514.41,   00011,514.68,295,514.95,14.5,512.73,91.0,512.73, ,513.01,-5.5,513.29,1.000,,,,,
,516.07,5.00,516.33,38.0,516.60,4.3,516.87,   00011,517.15,295,517.42,14.5,515.24,91.0,515.24, ,515.51,-1.6,515.78,0.992,,,,,
,518.54,4.97,518.80,38.0,519.07,4.3,519.34,   00011,519.62,295,519.88,14.5,517.70,91.0,517.70, ,517.99,-1.6,518.27,0.992,,,,,
,520.96,5.06,521.24,38.0,521.51,4.3,521.78,   00011,522.06,295,522.35,14.5,520.15,91.0,520.15, ,520.41,-1.6,520.68,0.992,,,,,
,523.47,5.11,523.75,38.0,524.03,4.3,524.32,   00011,524.60,294,524.87,14.5,522.63,91.0,522.63, ,522.91,-0.8,523.19,0.992,,,,,
,525.95,5.19,526.22,38.0,526.50,4.3,526.77,   00011,527.04,295,527.31,14.5,525.13,91.0,525.13, ,525.40,-0.8,525.67,0.984,,,,,
,528.42,5.25,528.70,38.0,528.97,4.3,529.23,   00011,529.51,295,529.78,14.5,527.58,91.0,527.58, ,527.86,-0.8,528.14,0.992,,,,,
,530.86,5.31,531.15,38.0,531.43,4.3,531.71,   00011,532.00,295,532.27,14.5,530.03,91.0,530.03, ,530.31,-4.7,530.58,0.992,,,,,
,533.36,5.39,533.63,38.0,533.89,4.3,534.16,   00011,534.43,294,534.72,14.5,532.54,91.0,532.54, ,532.81,-3.9,533.08,1.000,,,,,
,535.82,5.36,536.10,38.0,536.37,4.3,536.65,   00011,536.93,296,537.23,14.5,535.00,91.0,535.00, ,535.27,-3.1,535.55,1.008,,,,,
,538.32,5.50,538.58,38.0,538.85,4.3,539.12,   00011,539.40,295,539.68,14.5,537.50,91.0,537.50, ,537.78,-0.8,538.05,1.016,,,,,
,540.78,5.44,541.05,38.0,541.32,4.3,541.59,   00011,541.87,296,542.15,14.5,539.97,91.0,539.97, ,540.24,0.0,540.52,1.008,,,,,
,543.26,5.39,543.53,38.0,543.81,7.8,544.09,   00010,544.38,296,544.66,30.5,542.44,91.0,542.44, ,542.72,5.5,542.98,1.016,,,,,
,545.73,19.33,546.01,37.0,546.29,19.6,546.58,   00010,546.86,302,547.13,27.3,544.93,91.0,544.93, ,545.19,3.1,545.47,1.023,,,,,
,548.24,19.00,548.51,37.0,548.78,11.8,549.06,   00011,549.34,294,549.63,16.8,547.40,91.0,547.40, ,547.67,1.6,547.96,1.000,,,,,
,550.72,6.92,550.99,38.0,551.27,4.7,551.54,   00011,551.81,293,552.09,18.4,549.91,91.0,549.91, ,550.18,10.2,550.45,1.016,,,,,
,553.20,21.14,553.47,38.0,553.75,24.3,554.04,   00010,554.32,301,554.59,37.1,552.36,91.0,552.36, ,552.64,3.1,552.93,0.945,,,,,
,555.68,36.56,555.96,37.0,556.24,46.7,556.52,   00010,556.80,299,557.08,27.0,554.85,91.0,554.85, ,555.12,1.6,555.39,1.023,,,,,
,558.17,15.75,558.44,38.0,558.72,24.3,559.01,   00010,559.27,295,559.54,43.0,557.35,91.0,557.35, ,557.62,1.6,557.89,0.992,,,,,
,560.60,11.17,560.88,39.0,561.16,3.9,561.44,   00010,561.73,290,562.02,14.5,559.81,91.0,559.81, ,560.07,0.0,560.33,1.023,,,,,
,563.12,3.19,563.41,39.0,563.69,2.7,563.95,   00011,564.23,293,564.50,14.5,562.31,91.0,562.31, ,562.58,5.5,562.85,1.023,,,,,
,565.60,3.17,565.86,39.0,566.13,2.4,566.40,   00011,566.68,294,566.97,14.5,564.77,91.0,564.77, ,565.05,7.0,565.33,0.977,,,,,
,568.07,3.00,568.34,41.0,568.62,2.4,568.90,   00011,569.17,294,569.45,14.5,567.26,91.0,567.26, ,567.53,3.9,567.80,0.984,,,,,
,570.55,3.31,570.83,41.0,571.10,4.3,571.36,   00011,571.63,295,571.89,14.5,569.74,91.0,569.74, ,570.02,0.8,570.28,0.961,,,,,
,572.96,4.31,573.24,41.0,573.51,3.5,573.77,   00011,574.05,296,574.32,14.5,572.16,91.0,572.16, ,572.43,0.0,572.69,0.961,,,,,
,575.42,4.17,575.71,41.0,575.98,3.9,576.25,   00011,576.52,296,576.79,14.5,574.59,91.0,574.59, ,574.87,-0.8,575.14,0.984,,,,,
,577.88,4.44,578.15,41.0,578.42,3.5,578.70,   00011,578.99,296,579.26,14.5,577.06,91.0,577.06, ,577.34,-0.8,577.62,0.977,,,,,
,580.35,5.47,580.62,40.0,580.89,6.3,581.18,   00011,581.45,297,581.73,14.5,579.53,91.0,579.53, ,579.82,0.0,580.08,0.891,,,,,
,582.83,3.92,583.11,39.0,583.38,3.9,583.65,   00011,583.92,295,584.18,14.5,582.01,91.0,582.01, ,582.29,3.1,582.56,0.984,,,,,
,585.29,4.67,585.55,40.0,585.83,3.9,586.09,   00011,586.37,296,586.64,14.5,584.45,91.0,584.45, ,584.72,0.0,585.00,0.977,,,,,
,587.75,4.58,588.02,39.0,588.30,3.5,588.57,   00011,588.86,296,589.13,14.5,586.92,91.0,586.92, ,587.19,-0.8,587.47,0.977,,,,,
,590.25,4.61,590.53,39.0,590.80,3.5,591.07,   00011,591.35,295,591.62,14.5,589.41,91.0,589.41, ,589.68,-1.6,589.97,0.977,,,,,
,592.76,4.47,593.04,40.0,593.33,4.7,593.59,   00011,593.86,294,594.13,14.5,591.90,91.0,591.90, ,592.18,-6.3,592.46,0.977,,,,,
,595.25,4.50,595.53,40.0,595.79,3.5,596.07,   00010,596.33,295,596.60,27.3,594.40,91.0,594.40, ,594.68,-4.7,594.97,1.008,,,,,
,597.70,22.97,597.98,39.0,598.26,14.9,598.55,   00011,598.83,301,599.11,35.9,596.87,91.0,596.87, ,597.15,1.6,597.43,0.969,,,,,
,600.20,27.11,600.49,39.0,600.75,10.6,601.03,   00010,601.30,296,601.57,16.8,599.39,91.0,599.39, ,599.66,4.7,599.92,1.016,,,,,
,602.67,3.64,602.95,39.0,603.24,2.7,603.52,   00011,603.79,292,604.06,14.5,601.84,91.0,601.84, ,602.12,0.8,602.40,1.023,,,,,
,605.16,3.53,605.43,41.0,605.70,2.4,605.97,   00011,606.25,293,606.54,31.3,604.34,91.0,604.34, ,604.63,1.6,604.90,1.000,,,,,
,607.63,14.08,607.90,41.0,608.16,20.0,608.43,   00010,608.70,299,608.98,28.1,606.81,91.0,606.81, ,607.10,1.6,607.36,0.961,,,,,
,610.07,21.64,610.34,40.0,610.60,11.8,610.87,   00011,611.13,296,611.40,32.8,609.25,91.0,609.25, ,609.53,4.7,609.80,0.984,,,,,
,612.50,21.17,612.79,40.0,613.07,12.9,613.34,   00011,613.61,294,613.89,28.5,611.67,91.0,611.67, ,611.95,1.6,612.22,0.984,,,,,
,615.01,16.92,615.29,40.0,615.56,14.1,615.82,   00011,616.09,295,616.36,16.8,614.17,91.0,614.17, ,614.44,4.7,614.72,0.984,,,,,
,617.45,3.58,617.73,40.0,618.00,2.7,618.28,   00011,618.55,293,618.82,14.5,616.63,91.0,616.63, ,616.90,2.3,617.18,1.008,,,,,
,619.92,3.39,620.20,41.0,620.46,7.1,620.73,   00011,621.01,294,621.31,30.9,619.10,91.0,619.10, ,619.38,3.9,619.66,1.000,,,,,
,622.39,29.47,622.66,41.0,622.93,17.6,623.21,   00011,623.48,301,623.76,23.4,621.58,91.0,621.58, ,621.86,0.0,622.13,0.992,,,,,
,624.85,11.06,625.12,41.0,625.40,11.4,625.68,   00011,625.95,296,626.23,25.0,624.06,91.0,624.06, ,624.31,3.9,624.58,1.023,,,,,
,627.36,21.61,627.63,41.0,627.89,14.9,628.16,   00011,628.43,298,628.70,29.3,626.51,91.0,626.51, ,626.80,3.1,627.08,1.016,,,,,
,629.83,21.64,630.11,41.0,630.38,24.3,630.65,   00010,630.93,297,631.20,34.8,628.98,91.0,628.98, ,629.27,3.9,629.56,0.984,,,,,
,632.31,15.61,632.59,41.0,632.87,7.8,633.15,   00010,633.42,291,633.70,18.4,631.48,91.0,631.48, ,631.75,2.3,632.03,1.008,,,,,
,634.82,6.25,635.10,42.0,635.38,11.8,635.65,   00010,635.91,293,636.18,34.8,633.98,91.0,633.98, ,634.25,5.5,634.53,1.016,,,,,
,637.24,12.78,637.51,42.0,637.78,7.1,638.07,   00011,638.35,293,638.63,23.8,636.45,91.0,636.45, ,636.71,3.9,636.98,0.977,,,,,
,639.70,29.47,639.97,42.0,640.25,11.0,640.54,   00010,640.83,295,641.12,14.5,638.90,91.0,638.90, ,639.16,4.7,639.43,0.938,,,,,
,642.22,3.28,642.50,42.0,642.78,2.7,643.05,   00011,643.33,293,643.61,14.5,641.39,91.0,641.39, ,641.67,7.0,641.95,1.031,,,,,
,644.70,3.17,644.97,43.0,645.25,2.4,645.54,   00011,645.80,294,646.07,14.5,643.90,91.0,643.90, ,644.18,6.3,644.45,0.984,,,,,
,647.14,2.94,647.42,44.0,647.68,2.4,647.97,   00011,648.24,296,648.53,25.8,646.33,91.0,646.33, ,646.61,3.9,646.89,0.953,,,,,
,649.65,19.36,649.93,44.0,650.21,28.2,650.50,   00010,650.79,303,651.06,37.1,648.81,91.0,648.81, ,649.09,-0.8,649.37,0.938,,,,,
,652.16,40.94,652.43,42.0,652.71,26.3,652.98,   00011,653.26,298,653.56,33.6,651.34,91.0,651.34, ,651.62,1.6,651.89,1.008,,,,,
,654.61,18.58,654.88,42.0,655.15,6.3,655.43,   00010,655.70,290,655.98,19.5,653.81,91.0,653.81, ,654.08,0.0,654.35,0.984,,,,,
,657.09,6.31,657.37,43.0,657.65,5.5,657.92,   00011,658.20,294,658.49,14.5,656.27,91.0,656.27, ,656.55,0.8,656.82,1.031,,,,,
,659.59,5.97,659.87,43.0,660.14,5.1,660.42,   00011,660.71,293,660.97,15.6,658.77,91.0,658.77, ,659.04,3.1,659.32,0.984,,,,,
,662.07,6.53,662.34,43.0,662.63,10.6,662.90,   00011,663.16,294,663.43,31.6,661.24,91.0,661.24, ,661.51,-0.8,661.78,0.961,,,,,
,664.51,21.83,664.78,43.0,665.07,15.7,665.34,   00011,665.61,297,665.89,33.2,663.70,91.0,663.70, ,663.98,0.0,664.24,0.984,,,,,
,666.98,7.97,667.24,43.0,667.51,5.5,667.78,   00011,668.06,293,668.34,19.5,666.16,91.0,666.16, ,666.43,-1.6,666.70,1.031,,,,,
,669.43,9.47,669.70,43.0,669.96,11.0,670.23,   00011,670.50,296,670.78,24.2,668.61,91.0,668.61, ,668.89,4.7,669.16,1.000,,,,,
,671.87,7.33,672.15,43.0,672.42,9.4,672.68,   00011,672.95,296,673.22,27.7,671.06,91.0,671.06, ,671.34,4.7,671.62,1.000,,,,,
,674.33,12.22,674.59,43.0,674.86,8.2,675.13,   00011,675.41,294,675.68,25.0,673.51,91.0,673.51, ,673.79,1.6,674.07,0.953,,,,,
,676.80,11.72,677.07,43.0,677.35,7.8,677.63,   00011,677.90,295,678.18,26.2,675.98,91.0,675.98, ,676.26,1.6,676.53,1.023,,,,,
,679.30,14.06,679.58,43.0,679.86,9.8,680.14,   00011,680.41,294,680.68,27.3,678.46,91.0,678.46, ,678.74,3.1,679.01,0.969,,,,,
,681.80,11.17,682.08,43.0,682.35,7.8,682.62,   00011,682.91,295,683.18,29.7,680.96,91.0,680.96, ,681.24,4.7,681.51,1.000,,,,,
,684.26,11.19,684.55,43.0,684.84,7.8,685.13,   00011,685.39,295,685.66,26.2,683.44,91.0,683.44, ,683.71,0.0,683.98,0.992,,,,,
,686.76,10.61,687.05,43.0,687.34,5.9,687.63,   00011,687.91,295,688.19,21.9,685.93,91.0,685.93, ,686.20,0.8,686.48,0.992,,,,,
,689.28,6.44,689.57,44.0,689.84,8.6,690.13,   00011,690.40,295,690.66,27.3,688.46,91.0,688.46, ,688.73,2.3,689.01,1.000,,,,,
,691.75,10.83,692.03,43.0,692.32,7.1,692.60,   00011,692.88,294,693.15,26.6,690.93,91.0,690.93, ,691.20,-3.1,691.48,0.984,,,,,
,694.21,13.78,694.48,43.0,694.75,9.0,695.03,   00011,695.32,293,695.59,19.9,693.41,91.0,693.41, ,693.68,1.6,693.94,0.992,,,,,
,696.69,6.17,696.97,43.0,697.24,5.5,697.51,   00011,697.78,294,698.06,14.5,695.86,91.0,695.86, ,696.15,6.3,696.41,1.016,,,,,
,699.13,5.36,699.40,44.0,699.67,4.7,699.94,   00011,700.22,294,700.50,14.5,698.33,91.0,698.33, ,698.60,5.5,698.87,0.969,,,,,
,701.61,3.22,701.88,44.0,702.16,2.4,702.43,   00011,702.72,295,703.00,14.5,700.78,91.0,700.78, ,701.06,0.0,701.34,0.906,,,,,
,704.12,2.97,704.38,45.0,704.64,2.7,704.91,   00011,705.18,294,705.44,14.5,703.28,91.0,703.28, ,703.57,-4.7,703.83,0.945,,,,,
,706.51,3.61,706.79,45.0,707.09,2.7,707.34,   00011,707.61,295,707.88,14.5,705.71,91.0,705.71, ,705.97,-3.9,706.24,0.969,,,,,
,708.95,5.47,709.22,45.0,709.49,4.7,709.75,   00011,710.02,299,710.29,29.3,708.16,91.0,708.16, ,708.42,-4.7,708.69,0.984,,,,,
,711.42,15.06,711.70,44.0,711.98,12.2,712.27,   00011,712.54,297,712.83,14.5,710.58,91.0,710.58, ,710.85,0.0,711.14,0.984,,,,,
,713.93,3.00,714.20,44.0,714.47,2.7,714.74,   00011,715.01,294,715.29,14.5,713.10,91.0,713.10, ,713.37,3.1,713.65,1.031,,,,,
,716.37,4.11,716.65,44.0,716.92,3.5,717.20,   00011,717.47,295,717.74,14.5,715.55,91.0,715.55, ,715.83,0.0,716.09,0.953,,,,,
,718.83,3.83,719.10,45.0,719.37,2.7,719.64,   00011,719.92,294,720.20,14.5,718.01,91.0,718.01, ,718.29,-1.6,718.56,0.977,,,,,
,721.32,3.58,721.60,45.0,721.88,2.4,722.16,   00011,722.43,296,722.71,14.5,720.48,91.0,720.48, ,720.76,-2.3,721.03,0.977,,,,,
,723.78,1.08,724.07,45.0,724.35,5.1,724.62,   00011,724.89,296,743.26,0.10,722.98,91.0,722.98, ,723.24,-3.1,723.51,0.977,,,,,
Dr Sheldon
Windsor UK
C?ID=334979
F My ole boots !!
You made a right pigs ear of that !
   #29
rvralph64
Fresno, CA, USA
C?ID=566690
ok. let me try google sheets link.
   #33
rvralph64
Fresno, CA, USA
C?ID=566690
If you see a high number of markers it is because I was trying to raise the screen brightness.
   #34
rvralph64
Fresno, CA, USA
C?ID=566690
Were you able to open the file? The last one was sent without password.
   #35
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
2006 and 2007 2.5L engines are know for stretch chain problem, so if the chain and guides never been replaced I will not be surprised at 140K that you have this problem.
   #36
rvralph64
Fresno, CA, USA
C?ID=566690
Ok. That makes sense regarding the G66 fault. Ok. I guess I better check it out. Thanks for the heads up. If you're right, I'm lucky I didn't damage the engine. I will open it up to check it. Would I be able to see that by removing the valve cover?
   #37
rvralph64
Fresno, CA, USA
C?ID=566690
Looks like I need to remove the trans axle to replace the timing chain but in the meantime I will remove the inspection cover to look at the timing chain.
   #38
rvralph64
Fresno, CA, USA
C?ID=566690
I removed the inspection cover and the timing chain looks good. It's nice and tight, no broken guides and it idles nice and smooth. I'm wondering if the data I sent showed any problems with the variable timing solenoid not advancing the timing?
   #39
rvralph64
Fresno, CA, USA
C?ID=566690
There are two problems. One is the G66 knock sensor low voltage signal and the second is when cruising at highway speed it occasionally fails to respond when you step on gas pedal to accelerate and it lacks power. This situation is random and only occasional otherwise it runs great 95% of the time but something is wrong. I checked the fuel pressure and I get 40psi and it holds residual pressure 20psi for at least 20 minutes after engine shutdown. When it the power loss happens, I don't have to turn the engine off, I just let off the gas pedal and it recovers on its own. I can accelerate like normal, it kicks down the transmission and runs great. Again, it's unpredictable when it happens but if you had to pass another car, it could be dangerous if it fails to respond.
   #40
rvralph64
Fresno, CA, USA
C?ID=566690
Was the file accessible? I have been reading through the report and the time stamp on row 257. I see a big drop off in MAF sensor with a drop in the throttle drive angle. The O2 sensor is fluctuating and not steady which to means it's responding to the fuel/air as it should.
My interpretation is that the throttle position sensor is not reporting back the true position of the gas pedal. It's intermittent but very noticeable when it does it because I get no acceleration. The auto scan does not report anything but the G66 knock sensor signal too low or intermittent. If the G66 were to be intermittent, would it cause it go into limp mode without giving me CEL? The engine idles very smooth, and when it is running normally, the acceleration is strong. There's no abnormal noises coming from engine either.
