2006 VW Beetle P0332
rvralph64
Fresno, CA, USA
C?ID=566690
I am hoping that someone knows the answer to this riddle. Knock Sensor 2 Signal too low- intemittent. I visibly checked the cables, sprayed connector cleaner on the contacts, cleaned and torqued the knock senor to 15ft lbs as per the manual and even replaced the knock sensor to be sure. I understand that the knock sensor generates AC current and the current output increases with the detection of pre-detonation occurances.
I did notice #3 wire on the car side of the connector with missing insulation but otherwise the wire checked fine for continuity between the connector point and the exposed wiring. This #3 wire I also determined to be the ground wire and #1-2 as being the AC power source wiring from the knock sensor. I had a passenger view the measuring block group #26 where I see knock sensor voltages that go up and down. There are only two knock sensors yet VCDS reports Voltages in Cyclinder 1, 2, 3 & 4 but obviously this is a 5 cylinder engine so there's probably another once if I keep looking. A snapshot of the voltages I see are as follows:
Cylinder 1 1.638V
Cylinder 2 .702V
Cylinder 3 1.638V
Cylinder 4 .819V
The engine idles nice and smooth but on occasion I get a lack of power when I step on the gas pedal to overtake someone on the highway. I suspect that this is when I get the error code or it could be unrelated?
Please see autoscan below and the immobilizer code is due to accidental use of an unprogrammed spare key.
Thursday,15,May,2025,14:45:35:07661
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: 3VWSF31Y96M303780   License Plate: 2006 LT BLUE
Mileage: 230110km-142983mi   Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWSF31Y96M303780   Mileage: 230110km-142983miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 B    HW: Hardware No
   Component: NB/C R5 AT      G   7615
   Revision: --------    Serial number: VWZ5Z0E7248079
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 2809E8896EE2C59AE7B-513C
   VINID: 0E69E35830692467430031C80042D560E0
000818 - Knock Sensor 2 (G66)
               P0332 - 002 - Signal too Low - Intermittent
                    Mileage: 230090 km
                    RPM: 2128 /min
                    Load: 39.6 %
                    Speed: 107.0 km/h
                    Temperature: 87.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
Readiness: 0000 0100
   Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
   Component: AQ 250 6F           0759
   Revision: 00H27000    Serial number:
   Coding: 0000008
   VCID: 78A9F8C9FEC2951AB7B-513C
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 382938C9BE42551A77B-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AL
   Component: 01 AIRBAG VW71      0711
   Coding: 0012337
   VCID: 015F952DAD18D4D2805-5160
   Subsystem 1 - Part No: 1C0 959 339 F
   Component: BF-Gewichtsens. 006 0007
Address 17: Instruments        Labels: None
   Part No: 1C0 920 501 P
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11234
   Shop #: WSC 22539
   VCID: 2517E1BD1CF0D8F2DCD-4B00
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 09149
   VCID: 70B9C0E993B2CD5A7FB-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 501 P    HW: 1C0 920 501 P
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0E7248079
   Shop #: WSC 41876 001 1048576
   VCID: 2517E1BD19F0D8F2DCD-5160
01176 - Key
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255 C
   Component:  VSG  NBC           3601
   VCID: 40D95029E6921DDACFB-513C
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: 3B2327C58A747E029A9-4B00
   Subsystem 1 - Part No: 1Y1959801C
   Component: 6J Tõrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802D
   Component: 6J Tõrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tõrsteuer.HL KLO 0005
   Subsystem 4 - Part No: 1Y0959812
   Component: 6J Tõrsteuer.HR KLO 0005
End----------(Elapsed Time: 03:49, VBatt start/end: 13.1V/13.1V)-----------
------------------------------2 Faults Found-------------------------------
MVB 026 has values for cylinder 1-4. MVB 027 has the cylinder 5.
What I'd be looking at to see if the power loss is related is MVBs 020 and 021, which have Ignition Angle Delay (timing retard based on the knock sensors). If the values in there grow much when the power loss happens, then you can be confident that it's related.
rvralph64
Fresno, CA, USA
C?ID=566690
Hello Uwe, I will check for the timing delay but just curious why or better yet how is it able to determine voltage output for each cylinder when it only has two sensors?
Because timing retardation is something that directly affects power output, whereas knock sensor voltage is quite difficult to interpret without engineering specs for the engine management, which we don't have.
Timing. It looks at the voltage(s) from the sensor(s) when a particular cylinder is firing.
Kinda like how the old GSM/TDMA cell phone systems allowed multiple calls using the same frequency.
rvralph64
Fresno, CA, USA
C?ID=566690
Ok, that makes sense. Thanks for explaining that. On a related note, if I am getting voltage readings, is there a reason why cylinders 1 & 3 are showing half the voltage of the others? The #2 knock sensor is brand new from a reputable parts store and the one that was originally on the car was new according to the previous owner. I repaired and cleared all the easy codes which one was no communication with the transmission module because the fuse was blown. The only thing remaining is this P0332 Knock sensor code. It's not a dead circuit because I am getting readings. I wire brushed the ground contact point for this wire harness and sprayed electrical contact cleaner on the connector for the #2 sensor. I'm thinking that perhaps something is impeding the voltage upstream to engine control module? A bad wire? There's only 3 wires and #3 is ground and it has zero impedence so that leaves two wires to trace.
I will get back to you on the timing delay readings.
rvralph64
Fresno, CA, USA
C?ID=566690
Is P0332 really a problem or just a warning? I don't get CEL on the dash and I would really like to resolve the isssue rather than ignore it if it doesn't matter.
Use the Generic OBD-II function in VCDS. Check [Mode 7] (Pending DTCs) and [Mode 3] (Current DTCs).
If those are clean, I wouldn't worry about it too much unless/until something shows up there -- especially since you're in California.
Then again, you do have a functional complaint (power loss under some circumstances), and it would be good to know if there's a correlation, no?
rvralph64
Fresno, CA, USA
C?ID=566690
I agree, I want to know why it's doing that. I use a cheap obdII scanner as I drive around to see when all the smog sensors are ready. It gives me PDTC but no check engine light.
rvralph64
Fresno, CA, USA
C?ID=566690
#7 confirms G66 #2 knock sensor low intermittent. #3 is clean no fault codes. The test drive results during power loss.
#1 0.0
#2 2.3
#3 0.0
#4 4.5
I did not go to group 21 to capture cylinder #5.
Should I be using the graph function and log to send you this data instead of taking video and writing down the results? Regarding the power loss, I am wondering if it's really a transmission lack of downshift issue? I don't know the history of the car so I was planning on changing out the transmission oil and filter anyways but I will do so and keep testing. The next time it goes sluggish on me, I'm going to switch over to manual mode and downshift it to see if that works.
Cylinder 1 1.638V
Cylinder 2 .702V
Cylinder 3 1.638V
Cylinder 4 .819V
#1 0.0
#2 2.3
#3 0.0
#4 4.5
Interesting that there seems to be an inverse correlation between knock sensor voltage and timing retardation. Of course these weren't taken at the same time, but still. That said, I don't really know how modern knock sensors work, or how to interpret those voltages.
That is certainly the preferred method.
rvralph64
Fresno, CA, USA
C?ID=566690
Ok. I will do that after I finish changing the transmission oil. It really needed it, it's very black!
rvralph64
Fresno, CA, USA
C?ID=566690
[Deleted -- illegible]
rvralph64
Fresno, CA, USA
C?ID=566690
I noticed the data got garbled.
Hopefully this works better.
Friday    16    May    2025    14:20:46:07661-VCID:2809E8896EE2C59AE7B-513C    VCDS Version: Release 25.3.1 (x64)    Data version: 20250408 DS365.0
07K 906 032 B    ADVMB    NB/C R5 AT      G   7615
        G020    F0    G020    F1    G020    F2    G020    F3    G021    F0    G000
Marker    TIME    Group 20 - Field 0    TIME    Group 20 - Field 1    TIME    Group 20 - Field 2    TIME    Group 20 - Field 3    TIME    Group 21 - Field 0
    STAMP    Cylinder 1 Ignition - Angle Delay    STAMP    Cylinder 2 Ignition - Angle Delay    STAMP    Cylinder 3 Ignition - Angle Delay    STAMP    Cylinder 4 Ignition - Angle Delay    STAMP    Cylinder 5 Ignition - Angle Delay
        °KW        °KW        °KW        °KW        °KW
    0.25    0.8    0.25    0.8    0.25    0.8    0.25    0.8    0.02    0.8
    0.8    0.8    0.8    0.8    0.8    0.8    0.8    0.8    0.52    0.8
    1.37    0.8    1.37    0.8    1.37    0.8    1.37    0.8    1.08    0.8
    1.93    0.8    1.93    0.8    1.93    0.8    1.93    0.8    1.65    0.8
    2.49    0.8    2.49    0.8    2.49    0.8    2.49    0.8    2.22    0.8
    3.05    0.8    3.05    0.8    3.05    0.8    3.05    0.8    2.77    0.8
    3.61    0.8    3.61    0.8    3.61    0.8    3.61    0.8    3.33    0.8
    4.14    0.8    4.14    0.8    4.14    0.8    4.14    0.8    3.87    0.8
    4.69    0.8    4.69    0.8    4.69    0.8    4.69    0.8    4.41    0.8
    5.25    0.8    5.25    0.8    5.25    0.8    5.25    0.8    4.97    0.8
    5.8    0.8    5.8    0.8    5.8    0.8    5.8    0.8    5.52    0.8
    6.35    0.8    6.35    0.8    6.35    0.8    6.35    0.8    6.08    0.8
    6.91    0.8    6.91    0.8    6.91    0.8    6.91    0.8    6.63    0.8
    7.47    0.8    7.48    0.8    7.48    0.8    7.48    0.8    7.19    0.8
    8.02    0.8    8.02    0.8    8.02    0.8    8.02    0.8    7.74    0.8
    8.57    0.8    8.57    0.8    8.57    0.8    8.57    0.8    8.3    0.8
    9.14    0.8    9.14    0.8    9.14    0.8    9.14    0.8    8.85    0.8
    9.69    0.8    9.69    0.8    9.69    0.8    9.69    0.8    9.42    0.8
    10.22    0.8    10.22    0.8    10.22    0.8    10.22    0.8    9.95    0.8
    10.77    0.8    10.77    0.8    10.77    0.8    10.77    0.8    10.49    0.8
    11.3    0.8    11.3    0.8    11.3    0.8    11.3    0.8    11.03    0.8
    11.83    0.8    11.83    0.8    11.83    0.8    11.83    0.8    11.56    0.8
    12.38    0.8    12.38    0.8    12.38    0.8    12.38    0.8    12.1    0.8
    12.92    0.8    12.92    0.8    12.92    0.8    12.92    0.8    12.66    0.8
    13.46    0.8    13.46    0.8    13.46    0.8    13.46    0.8    13.19    0.8
    14.02    0.8    14.02    0.8    14.02    0.8    14.02    0.8    13.74    0.8
    14.56    1.5    14.56    0    14.56    0    14.56    0    14.28    0.8
    15.12    1.5    15.12    0    15.12    0    15.12    0    14.84    5.3
    15.68    1.5    15.68    0    15.68    0    15.68    0    15.4    5.3
    16.24    1.5    16.24    0    16.24    0    16.24    0    15.96    5.3
    16.79    1.5    16.79    0    16.79    0    16.79    0    16.51    5.3
    17.35    0.8    17.35    0.8    17.35    0.8    17.35    0.8    17.07    5.3
    17.9    0.8    17.9    0.8    17.9    0.8    17.9    0.8    17.62    0.8
    18.46    0.8    18.46    0.8    18.46    0.8    18.46    0.8    18.18    0.8
    18.99    0.8    18.99    0.8    18.99    0.8    18.99    0.8    18.72    0.8
    19.52    1.5    19.52    0    19.52    0    19.52    0    19.25    5.3
    20.07    0.8    20.07    0    20.07    0    20.07    0    19.79    5.3
    20.63    0    20.63    0    20.63    0    20.63    0    20.36    5.3
    21.16    0    21.16    0    21.16    0    21.16    0    20.88    5.3
    21.71    0    21.71    0    21.71    0    21.71    0    21.44    5.3
    22.27    0    22.27    0    22.27    0    22.27    0    22    4.5
    22.83    0    22.83    0    22.83    0    22.83    0    22.54    4.5
    23.38    0    23.38    0    23.38    0    23.38    0    23.11    4.5
    23.95    0    23.95    0    23.95    0    23.95    0    23.66    4.5
    24.51    0    24.51    0    24.51    0    24.51    0    24.24    4.5
    25.05    0    25.05    0    25.05    0    25.05    0    24.79    4.5
    25.61    0    25.61    0    25.61    0    25.61    0    25.33    3.8
    26.16    0    26.16    0    26.16    0    26.16    0    25.89    3
    26.73    0    26.73    0    26.73    0    26.73    0    26.44    2.3
    27.28    0    27.28    0    27.28    0    27.28    0    27    1.5
    27.83    0    27.83    0    27.83    0    27.83    0    27.55    0.8
    28.38    0    28.38    0    28.38    0    28.38    0    28.11    0
    28.94    0    28.94    0    28.94    0    28.94    0    28.66    0
    29.49    0    29.49    0    29.49    0    29.49    0    29.23    0
    30.03    0    30.03    0    30.03    0    30.03    0    29.76    0
    30.58    0    30.58    0    30.58    0    30.58    0    30.3    0
    31.11    0    31.11    0    31.11    2.3    31.11    0    30.84    0
    31.66    0    31.66    0    31.66    2.3    31.66    0    31.38    0
    32.24    0    32.24    0    32.24    2.3    32.24    0    31.94    0
    32.79    0    32.79    0    32.79    0    32.79    0    32.51    0
    33.35    0    33.35    0    33.35    2.3    33.35    0    33.07    0
    33.91    0    33.91    0    33.91    2.3    33.91    0    33.63    0
    34.46    0    34.46    0    34.46    0    34.46    0    34.18    0
    35.02    0    35.02    0    35.02    0    35.02    0    34.74    0
    35.58    0    35.58    0    35.58    0    35.58    0    35.3    0
    36.13    0    36.13    0    36.13    0    36.13    0    35.85    0
    36.67    0    36.67    0    36.67    0    36.67    0    36.41    0
    37.2    0    37.2    0    37.2    0    37.2    0    36.94    0
    37.74    0    37.74    0    37.74    0    37.74    0    37.47    0
    38.31    0    38.31    0    38.31    0    38.31    0    38.02    0
    38.86    0    38.86    0    38.86    1.5    38.86    0    38.59    0
    39.39    0    39.39    0    39.39    0.8    39.39    0    39.12    0
    39.92    0    39.92    0    39.92    0    39.92    0    39.66    0
    40.45    0    40.45    0    40.45    0    40.45    0    40.19    0
    40.99    0    40.99    0    40.99    0    40.99    0    40.72    0
    41.53    0    41.53    0    41.53    0    41.53    0    41.27    0
    42.08    0    42.08    0    42.08    0    42.08    0    41.8    0
    42.64    0    42.64    0    42.64    0    42.64    0    42.37    0
    43.19    0    43.19    0    43.19    0    43.19    0    42.91    0
    43.73    0    43.73    0    43.73    0    43.73    0    43.45    0
    44.29    0    44.29    0    44.29    0    44.29    0    44.02    0
    44.85    0    44.85    0    44.85    0    44.85    0    44.57    0
    45.4    0    45.4    0    45.4    0    45.4    0    45.13    0
    45.94    0    45.94    0    45.94    0    45.94    0    45.67    0
    46.49    0    46.49    0    46.49    0    46.49    0    46.21    0
    47.04    0    47.04    0    47.04    0    47.04    0    46.77    0
    47.6    0    47.6    0    47.6    0    47.6    0    47.32    0
    48.15    0    48.15    0    48.15    0    48.15    0    47.87    0
    48.7    0    48.7    0    48.7    0    48.7    0    48.44    0
    49.27    0    49.27    0    49.27    0    49.27    0    48.98    0
    49.82    0    49.82    0    49.82    0    49.82    0    49.55    0
    50.35    0    50.35    0    50.35    0    50.35    0    50.08    0
    50.88    0    50.88    0    50.88    0    50.88    0    50.6    0
    51.44    0    51.44    0    51.44    0    51.44    0    51.15    0
    52    0    52    0    52    0    52    0    51.71    0
    52.56    0    52.56    0    52.56    0    52.56    0    52.27    0
    53.13    0    53.13    0    53.13    0    53.13    0    52.85    0
    53.65    0    53.65    0    53.65    0    53.65    0    53.38    0
    54.19    0    54.19    0    54.19    0    54.19    0    53.92    0
    54.77    0    54.77    0    54.77    0    54.77    0    54.47    0
    55.32    0    55.32    0    55.32    0    55.32    0    55.04    0
    55.87    0    55.87    0    55.87    0    55.87    0    55.59    0
    56.41    0    56.41    0    56.41    0    56.41    0    56.14    0
    56.98    0    56.98    0    56.98    0    56.98    0    56.69    0
    57.55    0    57.55    0    57.55    0    57.55    0    57.27    0
    58.09    0    58.09    0    58.09    0    58.09    0    57.82    0
    58.64    0    58.64    0    58.64    0    58.64    0    58.36    0
    59.17    0    59.17    0    59.17    0    59.17    0    58.9    0
    59.7    0    59.7    0    59.7    0    59.7    0    59.43    0
    60.24    0    60.24    0    60.24    0    60.24    0    59.97    0
    60.8    0    60.8    0    60.8    0    60.8    0    60.53    0
    61.36    0    61.36    0    61.36    0    61.36    0    61.08    0
    61.91    0    61.91    0    61.91    0    61.91    0    61.64    0
    62.45    0    62.45    0    62.45    0    62.45    0    62.19    0
    62.98    0    62.98    0    62.98    0    62.98    0    62.72    0
    63.53    0    63.53    0    63.53    0    63.53    0    63.26    0
    64.08    0    64.08    0    64.08    0    64.08    0    63.8    0
    64.63    0    64.63    0    64.63    0    64.63    0    64.35    0
    65.2    0    65.2    0    65.2    0    65.2    0    64.91    0
    65.76    0    65.76    0    65.76    0    65.76    0    65.48    0
    66.31    0    66.31    0    66.31    0    66.31    0    66.05    0
    66.84    0    66.84    0    66.84    0    66.84    0    66.58    0
    67.37    0    67.37    0    67.37    0    67.37    0    67.11    0
    67.91    0    67.91    0    67.91    0    67.91    0    67.64    0
    68.46    0    68.46    0    68.46    0    68.46    0    68.19    0
    69.02    0    69.02    0    69.02    0    69.02    0    68.74    0
    69.57    0    69.57    0    69.57    0    69.57    0    69.3    0
    70.14    0    70.14    0    70.14    0    70.14    0    69.85    1.5
    70.7    0    70.7    0    70.7    0    70.7    0    70.42    1.5
    71.24    0    71.24    0    71.24    0    71.24    2.3    70.97    3.8
    71.8    0    71.8    0    71.8    0    71.8    2.3    71.52    3.8
    72.35    0    72.35    0    72.35    0    72.35    2.3    72.07    3.8
    72.9    0    72.9    0    72.9    0    72.9    1.5    72.62    3.8
    73.47    0    73.47    0    73.47    0    73.47    0.8    73.19    3
    74.03    0    74.03    0    74.03    0    74.03    0    73.75    2.3
    74.58    0    74.58    0    74.58    0    74.58    0    74.31    1.5
    75.11    0    75.11    0    75.11    0    75.11    0    74.85    1.5
    75.65    0    75.65    0    75.65    0    75.65    0    75.38    0.8
    76.21    0    76.21    0    76.21    0    76.21    0    75.93    0
    76.77    0    76.77    0    76.77    0    76.77    0    76.49    0
    77.32    0    77.32    0    77.32    0    77.32    0    77.04    0
    77.85    0    77.85    0    77.85    0    77.85    0    77.58    0
    78.41    0    78.41    0    78.41    0    78.41    0    78.12    0
    78.97    0    78.97    0    78.97    0    78.97    0    78.69    0
    79.52    0    79.52    0    79.52    0    79.52    0    79.25    0
    80.06    0    80.06    0    80.06    0    80.06    0    79.79    0
    80.61    0    80.61    0    80.61    0    80.61    0    80.34    0
    81.17    0    81.17    0    81.17    0    81.17    0    80.9    0
    81.72    0    81.72    0    81.72    0    81.72    0    81.44    0
    82.29    0    82.29    0    82.29    0    82.29    0    82.01    0
    82.82    0    82.82    0    82.82    0    82.82    0    82.56    1.5
    83.36    0    83.36    0    83.36    0    83.36    0    83.09    0.8
    83.89    0    83.89    0    83.89    0    83.89    0    83.62    4.5
    84.44    0    84.44    0    84.44    0    84.44    0    84.16    4.5
    85.01    0    85.01    0    85.01    0    85.01    0    84.72    4.5
    85.56    0    85.56    0    85.56    0    85.56    0    85.3    0
    86.09    0    86.09    0    86.09    0    86.09    0    85.82    0
    86.63    0    86.63    0    86.63    0    86.63    0    86.36    0
    87.2    0    87.2    0    87.2    0    87.2    0    86.91    0
    87.75    0    87.75    0    87.75    0    87.75    0    87.48    0
    88.31    0    88.31    0    88.31    0    88.31    0    88.02    0
    88.86    0    88.86    0    88.86    0    88.86    0    88.58    0
    89.41    0    89.41    0    89.41    0    89.41    0    89.13    0
    89.97    0    89.97    0    89.97    0    89.97    0    89.69    4.5
    90.52    0    90.52    2.3    90.52    0    90.52    0    90.24    5.3
    91.09    0    91.09    2.3    91.09    2.3    91.09    0    90.81    5.3
    91.64    0    91.64    2.3    91.64    2.3    91.64    0    91.37    5.3
    92.19    0    92.19    2.3    92.19    2.3    92.19    2.3    91.91    5.3
    92.74    0    92.74    2.3    92.74    2.3    92.74    2.3    92.46    6.8
    93.3    0    93.3    1.5    93.3    2.3    93.3    2.3    93.04    6.8
    93.84    0    93.84    1.5    93.84    1.5    93.84    2.3    93.57    6.8
    94.38    0    94.38    1.5    94.38    0    94.38    2.3    94.11    6.8
    94.92    0    94.92    0    94.92    0    94.92    0    94.66    0
    95.46    0    95.46    0    95.46    0    95.46    0    95.19    0
    96.03    0    96.03    0    96.03    0    96.03    0    95.74    0
    96.59    0    96.59    1.5    96.59    0.8    96.59    2.3    96.31    0
    97.13    0    97.13    1.5    97.13    0    97.13    1.5    96.86    6
    97.68    0    97.68    0    97.68    0    97.68    0    97.41    5.3
    98.25    0    98.25    0    98.25    0    98.25    0    97.96    0
    98.78    0    98.78    0    98.78    0    98.78    0    98.51    0
    99.33    0    99.33    0    99.33    0    99.33    0    99.06    0
    99.88    0    99.88    0    99.88    0    99.88    0    99.6    0
    100.44    0    100.44    0    100.44    0    100.44    0    100.17    0
    100.99    0    100.99    0    100.99    0    100.99    0    100.71    0
    101.54    0    101.54    0    101.54    0    101.54    0    101.26    0
    102.1    0    102.1    0    102.1    0    102.1    0    101.82    0
    102.65    0    102.65    0    102.65    0    102.65    0    102.37    0
    103.22    0    103.22    0    103.22    0    103.22    0    102.93    0
    103.78    0    103.78    0    103.78    0    103.78    0    103.5    0
    104.34    0    104.34    0    104.34    0    104.34    0    104.06    0
    104.88    0    104.88    1.5    104.88    0    104.88    0.8    104.61    0
    105.43    0    105.43    0.8    105.43    0    105.43    0    105.15    3.8
    105.97    0    105.97    0    105.97    0    105.97    0    105.71    3
    106.53    0    106.53    0    106.53    0    106.53    0    106.25    2.3
    107.09    0    107.09    0    107.09    0    107.09    0    106.81    1.5
    107.65    0    107.65    0    107.65    0    107.65    0    107.36    0
    108.22    0    108.22    0    108.22    0    108.22    0    107.94    4.5
    108.77    0    108.77    0    108.77    0    108.77    0    108.5    3.8
    109.31    0    109.31    0    109.31    0    109.31    0    109.04    3
    109.87    0    109.87    0    109.87    0    109.87    0    109.59    2.3
    110.4    0    110.4    0    110.4    0    110.4    0    110.13    1.5
    110.95    0    110.95    0    110.95    0    110.95    0    110.67    3
    111.5    0    111.5    0    111.5    0    111.5    0    111.22    3
    112.07    0    112.07    0    112.07    0    112.07    0    111.79    3
    112.61    0    112.61    0    112.61    0    112.61    0    112.34    3
    113.16    0    113.16    0    113.16    0    113.16    0    112.88    3
    113.7    0    113.7    0    113.7    0    113.7    0    113.43    2.3
    114.25    0    114.25    0    114.25    0    114.25    0    113.97    2.3
    114.81    0    114.81    4.5    114.81    0    114.81    0    114.54    2.3
    115.37    0    115.37    4.5    115.37    0    115.37    0    115.08    4.5
    115.9    0    115.9    4.5    115.9    0    115.9    0    115.63    4.5
    116.45    0    116.45    4.5    116.45    0    116.45    0    116.18    4.5
    117    0    117    4.5    117    0    117    0    116.72    4.5
    117.55    0    117.55    4.5    117.55    0    117.55    0    117.28    4.5
    118.11    0    118.11    3.8    118.11    0    118.11    0    117.83    3.8
    118.65    0    118.65    3.8    118.65    0    118.65    0    118.38    3
    119.19    0    119.19    0    119.19    0    119.19    0    118.92    0
    119.73    0    119.73    0    119.73    0    119.73    0    119.45    0
    120.29    0    120.29    0    120.29    0    120.29    0    120.01    0
    120.83    0    120.83    3.8    120.83    0    120.83    0    120.55    3.8
    121.37    0    121.37    3.8    121.37    0    121.37    0    121.11    3
    121.91    0    121.91    0    121.91    0    121.91    0    121.64    0
    122.45    0    122.45    0    122.45    0    122.45    0    122.19    0
    122.99    0    122.99    0    122.99    0    122.99    0    122.72    0
    123.56    0    123.56    0    123.56    0    123.56    0    123.27    0
    124.12    0    124.12    0    124.12    0    124.12    0    123.84    0
    124.69    0    124.69    0    124.69    0    124.69    0    124.41    0
    125.24    0    125.24    0    125.24    0    125.24    0    124.96    0
    125.81    0    125.81    0    125.81    0    125.81    0    125.53    0
    126.37    0    126.37    0    126.37    0    126.37    0    126.09    0
    126.91    0    126.91    0    126.91    0    126.91    0    126.64    0
    127.44    0    127.44    0    127.44    0    127.44    0    127.17    0
    127.99    0    127.99    0    127.99    0    127.99    0    127.71    0
    128.54    0    128.54    3.8    128.54    0    128.54    0    128.27    0
    129.1    0    129.1    3    129.1    0    129.1    0    128.82    3.8
    129.67    0    129.67    2.3    129.67    0    129.67    0    129.39    3
    130.2    0    130.2    2.3    130.2    0    130.2    0    129.94    3
    130.74    0    130.74    1.5    130.74    0    130.74    0    130.47    2.3
    131.27    2.3    131.27    0.8    131.27    0    131.27    0    131    1.5
    131.82    2.3    131.82    0    131.82    0    131.82    0    131.54    0.8
    132.37    2.3    132.37    0    132.37    0    132.37    0    132.1    0
    132.92    2.3    132.92    0    132.92    0    132.92    2.3    132.65    0
    133.45    2.3    133.45    0    133.45    0    133.45    2.3    133.19    2.3
    133.99    2.3    133.99    0    133.99    0    133.99    2.3    133.72    2.3
    134.52    2.3    134.52    0    134.52    0    134.52    2.3    134.25    2.3
    135.07    1.5    135.07    0    135.07    0    135.07    2.3    134.79    2.3
    135.62    0.8    135.62    0    135.62    0    135.62    2.3    135.35    2.3
    136.18    0    136.18    0    136.18    0    136.18    0    135.9    1.5
    136.75    0    136.75    0    136.75    0    136.75    0    136.47    0
    137.29    0    137.29    0    137.29    0    137.29    0    137.02    0
    137.85    0    137.85    0    137.85    0    137.85    0    137.57    0
    138.4    0    138.4    0    138.4    0    138.4    0    138.12    0
    138.97    0    138.97    0    138.97    0    138.97    0    138.68    0
    139.52    0    139.52    0    139.52    0    139.52    0    139.24    0
    140.07    0    140.07    0    140.07    0    140.07    0    139.79    0
    140.61    0    140.61    0    140.61    0    140.61    0    140.34    0
    141.17    0    141.17    0    141.17    0    141.17    0    140.9    0
    141.72    0    141.72    0    141.72    0    141.72    0    141.44    0
    142.29    0    142.29    0    142.29    0    142.29    0    142    0
    142.83    0    142.83    0    142.83    0    142.83    0    142.55    0
    143.38    0    143.38    0    143.38    0    143.38    0    143.11    0
    143.95    0    143.95    0    143.95    0    143.95    0    143.66    0
    144.48    0    144.48    0    144.48    0    144.48    0    144.21    0
    145.04    0    145.04    0    145.04    0    145.04    0    144.75    0
    145.58    0    145.58    0    145.58    0    145.58    0    145.3    0
    146.13    0    146.13    0    146.13    0    146.13    0    145.86    0
    146.68    0    146.68    1.5    146.68    0    146.68    0.8    146.42    2.3
    147.22    0    147.22    0.8    147.22    0    147.22    0    146.95    1.5
    147.75    0    147.75    0    147.75    0    147.75    0    147.48    0.8
    148.29    0    148.29    0    148.29    0    148.29    0    148.02    0.8
    148.83    0    148.83    0    148.83    0    148.83    2.3    148.55    3
    149.38    0    149.38    0    149.38    0    149.38    2.3    149.1    3
    149.95    0    149.95    0    149.95    0    149.95    2.3    149.67    3
    150.48    0    150.48    0    150.48    2.3    150.48    2.3    150.22    3
    151.03    0    151.03    0    151.03    0    151.03    0    150.75    3
    151.58    0    151.58    0    151.58    0    151.58    0    151.31    0
    152.14    0    152.14    0    152.14    0    152.14    0    151.85    0
    152.67    0    152.67    0    152.67    0    152.67    0    152.4    0
    153.2    0    153.2    0    153.2    0    153.2    0    152.94    0
    153.74    0    153.74    0    153.74    0    153.74    0    153.47    0
    154.31    0    154.31    0    154.31    2.3    154.31    2.3    154.03    0
    154.85    0    154.85    0    154.85    2.3    154.85    1.5    154.58    2.3
    155.42    0    155.42    0    155.42    2.3    155.42    0.8    155.13    2.3
    155.96    0    155.96    0    155.96    2.3    155.96    0    155.69    2.3
    156.5    0    156.5    0    156.5    1.5    156.5    0    156.23    4.5
    157.05    0    157.05    0    157.05    1.5    157.05    0    156.78    4.5
    157.6    0    157.6    0    157.6    1.5    157.6    0    157.32    4.5
    158.15    0    158.15    0    158.15    1.5    158.15    0    157.87    4.5
    158.7    0    158.7    0    158.7    1.5    158.7    0    158.43    3.8
    159.24    0    159.24    0    159.24    0.8    159.24    0    158.97    3.8
    159.79    0    159.79    0    159.79    0.8    159.79    0    159.52    3.8
    160.35    0    160.35    0    160.35    0    160.35    0    160.07    0
    160.9    0    160.9    0    160.9    0    160.9    0    160.62    0
    161.47    0    161.47    0    161.47    0    161.47    0    161.18    0
    162    0    162    0    162    0    162    0    161.74    0
    162.53    0    162.53    0    162.53    0    162.53    0    162.27    0
    163.09    0    163.09    0    163.09    0    163.09    0    162.81    0
    163.65    0    163.65    0    163.65    0    163.65    0    163.37    0
    164.21    0    164.21    0    164.21    0.8    164.21    0    163.93    3.8
    164.76    0    164.76    0    164.76    0.8    164.76    0    164.48    3.8
    165.32    0    165.32    0    165.32    0.8    165.32    0    165.04    3.8
    165.87    0    165.87    0    165.87    0    165.87    0    165.59    3
    166.44    0    166.44    0    166.44    0    166.44    0    166.16    2.3
    166.99    0    166.99    0    166.99    2.3    166.99    0    166.72    3.8
    167.52    2.3    167.52    0    167.52    2.3    167.52    0    167.24    3.8
    168.07    2.3    168.07    0    168.07    2.3    168.07    0    167.79    3.8
    168.62    2.3    168.62    0    168.62    2.3    168.62    0    168.34    3.8
    169.18    2.3    169.18    0    169.18    2.3    169.18    0    168.89    3.8
    169.75    2.3    169.75    0    169.75    1.5    169.75    0    169.46    3
    170.31    1.5    170.31    0    170.31    1.5    170.31    0    170.03    3
    170.84    0    170.84    0    170.84    0    170.84    0    170.57    3
    171.38    0    171.38    0    171.38    0    171.38    0    171.1    0
    171.94    0    171.94    0    171.94    0    171.94    0    171.67    0
    172.49    0    172.49    0    172.49    0    172.49    0    172.21    0
    173.05    0    173.05    0    173.05    0    173.05    0    172.78    0
    173.58    0    173.58    0    173.58    0    173.58    0    173.31    0
    174.13    0    174.13    0    174.13    0    174.13    0    173.86    0
    174.68    0    174.68    0    174.68    0    174.68    0    174.41    0
    175.22    0    175.22    0    175.22    0    175.22    0    174.95    0
    175.77    0    175.77    0    175.77    0    175.77    0    175.5    0
    176.34    0    176.34    0    176.34    0    176.34    0    176.06    0
    176.9    0    176.9    0    176.9    0    176.9    0    176.62    0
    177.46    0    177.46    0    177.46    0    177.46    0    177.18    0
    178.02    0    178.02    0    178.02    0    178.02    0    177.74    0
    178.59    0    178.59    0    178.59    0    178.59    0    178.31    0
    179.15    0    179.15    0    179.15    0    179.15    0    178.87    0
    179.71    0    179.71    0    179.71    0    179.71    0    179.43    0
    180.27    0    180.27    0    180.27    0    180.27    0    179.99    0
    180.84    0    180.84    0    180.84    0    180.84    0    180.57    0
    181.4    0    181.4    0    181.4    0    181.4    0    181.12    0
    181.95    0    181.95    0    181.95    0    181.95    0    181.68    0
    182.49    0    182.49    0    182.49    0    182.49    0    182.22    0
    183.05    0    183.05    0    183.05    0    183.05    0    182.77    0
    183.58    0    183.58    0    183.58    0    183.58    0    183.31    0
    184.13    0    184.13    0    184.13    0    184.13    0    183.85    0
    184.67    0    184.67    0    184.67    0    184.67    0    184.4    0
    185.2    0    185.2    0    185.2    0    185.2    0    184.94    0
    185.73    0    185.73    0    185.73    0    185.73    0    185.47    0
    186.27    0    186.27    0    186.27    0    186.27    0    186    0
    186.82    0    186.82    0    186.82    0    186.82    0    186.55    0
    187.38    0    187.38    0    187.38    0    187.38    0    187.1    0
    187.93    0    187.93    0    187.93    0    187.93    0    187.66    0
    188.5    0    188.5    0    188.5    0    188.5    0    188.21    0
    189.03    0    189.03    0    189.03    0    189.03    0    188.76    0
    189.57    0    189.57    0    189.57    0    189.57    0    189.3    0
    190.13    0    190.13    0    190.13    0    190.13    0    189.85    0
    190.68    1.5    190.68    0    190.68    1.5    190.68    0    190.41    3
    191.25    1.5    191.25    0    191.25    1.5    191.25    0    190.96    3
    191.81    1.5    191.81    0    191.81    1.5    191.81    0    191.53    3
    192.37    1.5    192.37    0    192.37    1.5    192.37    0    192.09    3
    192.93    0.8    192.93    0    192.93    0.8    192.93    0    192.65    1.5
    193.49    0    193.49    0    193.49    0    193.49    0    193.21    0.8
    194.04    0    194.04    0    194.04    0    194.04    0    193.76    0.8
    194.58    0    194.58    0    194.58    0    194.58    0    194.31    0
    195.14    0    195.14    0    195.14    0    195.14    0    194.85    0
    195.68    0    195.68    0    195.68    0    195.68    0    195.41    0
    196.25    0    196.25    0    196.25    0    196.25    0    195.96    0
    196.79    0    196.79    0    196.79    0    196.79    0    196.53    0
    197.32    0    197.32    0    197.32    0    197.32    0    197.05    0
    197.87    0    197.87    0    197.87    0    197.87    0    197.6    0
    198.42    0    198.42    0    198.42    0    198.42    0    198.14    0
    198.98    0    198.98    0    198.98    2.3    198.98    0    198.7    0
    199.52    0    199.52    0    199.52    2.3    199.52    0    199.24    2.3
    200.06    0    200.06    0    200.06    2.3    200.06    0    199.78    2.3
    200.62    0    200.62    0    200.62    0    200.62    0    200.33    2.3
    201.16    0    201.16    0    201.16    0    201.16    0    200.89    0
    201.73    0    201.73    0    201.73    0    201.73    0    201.44    0
    202.28    0    202.28    0    202.28    0    202.28    0    202    0
    202.83    0    202.83    0    202.83    0    202.83    0    202.55    0
    203.38    0    203.38    0    203.38    0    203.38    0    203.12    0
    203.94    0    203.94    0    203.94    0    203.94    0    203.66    0
    204.5    0    204.5    0    204.5    0    204.5    0    204.22    0
    205.04    0    205.04    0    205.04    0    205.04    0    204.78    0
    205.58    0    205.58    0    205.58    0    205.58    0    205.31    0
    206.14    0    206.14    0    206.14    0    206.14    0    205.85    0
    206.7    0    206.7    0    206.7    0    206.7    0    206.41    0
    207.25    0    207.25    0    207.25    0    207.25    0    206.98    0
    207.78    0    207.78    0    207.78    0    207.78    0    207.51    0
    208.33    0    208.33    0    208.33    0    208.33    0    208.05    0
    208.89    0    208.89    0    208.89    0    208.89    0    208.61    0
    209.45    0    209.45    0    209.45    0    209.45    0    209.16    0
    210    0    210    0    210    0    210    0    209.73    0
    210.55    0    210.55    0    210.55    0    210.55    0    210.27    0
    211.11    0    211.11    0    211.11    0    211.11    0    210.83    0
    211.66    0    211.66    0    211.66    0    211.66    0    211.38    0
    212.21    0    212.21    0    212.21    0    212.21    0    211.93    0
    212.78    0    212.78    0    212.78    0    212.78    0    212.49    0
    213.33    0    213.33    0    213.33    0    213.33    0    213.05    0
    213.89    0    213.89    0    213.89    0    213.89    0    213.6    0
    214.43    0    214.43    0    214.43    0    214.43    0    214.16    0
    214.99    0    214.99    0    214.99    0    214.99    0    214.71    0
    215.54    0    215.54    0    215.54    0    215.54    0    215.27    0
    216.1    0    216.1    0    216.1    0    216.1    0    215.82    0
    216.67    0    216.67    0    216.67    0    216.67    0    216.39    0
    217.21    0    217.21    0    217.21    2.3    217.21    0    216.94    2.3
    217.76    0    217.76    0    217.76    2.3    217.76    0    217.49    2.3
    218.32    0    218.32    0    218.32    0    218.32    0    218.04    2.3
    218.86    0    218.86    0    218.86    0    218.86    0    218.59    0
    219.41    0    219.41    0    219.41    0    219.41    0    219.13    0
    219.96    0    219.96    0    219.96    0    219.96    0    219.68    0
    220.51    0    220.51    0    220.51    0    220.51    0    220.24    0
    221.07    0    221.07    0    221.07    0    221.07    0    220.79    0
    221.61    0    221.61    0    221.61    0    221.61    0    221.35    0
    222.16    0    222.16    0    222.16    0    222.16    0    221.89    0
    222.72    0    222.72    0    222.72    0    222.72    0    222.43    0
    223.28    0    223.28    0    223.28    0    223.28    0    223    0
    223.84    0    223.84    0    223.84    0    223.84    0    223.56    0
    224.41    0    224.41    0    224.41    0    224.41    0    224.12    0
    224.94    0    224.94    0    224.94    0    224.94    0    224.67    0
    225.49    0    225.49    0    225.49    0    225.49    0    225.21    0
    226.04    0    226.04    0    226.04    0    226.04    0    225.76    0
    226.57    0    226.57    0    226.57    0    226.57    0    226.3    0
    227.13    0    227.13    0    227.13    0    227.13    0    226.83    0
    227.68    0    227.68    0    227.68    0    227.68    0    227.4    0
    228.21    0    228.21    0    228.21    0    228.21    0    227.93    0
    228.75    0    228.75    0    228.75    0    228.75    0    228.47    0
    229.31    0    229.31    0    229.31    0    229.31    0    229.04    0
    229.87    0    229.87    0    229.87    0    229.87    0    229.58    0
    230.41    0    230.41    0    230.41    0    230.41    0    230.14    0
    230.96    0    230.96    0    230.96    0    230.96    0    230.7    0
    231.5    0    231.5    0    231.5    0    231.5    0    231.23    0
    232.05    0    232.05    0    232.05    0    232.05    0    231.77    0
    232.62    0    232.62    0    232.62    0    232.62    0    232.33    0
    233.17    0    233.17    0    233.17    0    233.17    0    232.9    0
    233.73    0    233.73    0    233.73    0    233.73    0    233.45    0
    234.26    0    234.26    0    234.26    0    234.26    0    233.99    0
    234.8    0    234.8    0    234.8    0    234.8    0    234.53    0
    235.37    0    235.37    0    235.37    0    235.37    0    235.08    0
    235.91    0    235.91    0    235.91    0    235.91    0    235.63    0
    236.47    0    236.47    0    236.47    0    236.47    0    236.19    0
    237.02    0    237.02    0    237.02    0    237.02    0    236.74    0
    237.59    0    237.59    0    237.59    0    237.59    0    237.31    0
    238.15    0    238.15    0    238.15    0    238.15    0    237.88    0
    238.68    0    238.68    0    238.68    0    238.68    0    238.42    0
    239.23    0    239.23    0    239.23    0    239.23    0    238.96    0
    239.76    0    239.76    0    239.76    0    239.76    0    239.5    0
    240.29    0    240.29    0    240.29    0    240.29    0    240.03    0
    240.86    0    240.86    0    240.86    0    240.86    0    240.57    0
    241.41    0    241.41    0    241.41    0    241.41    0    241.14    0
    241.96    0    241.96    0    241.96    0    241.96    0    241.69    0
    242.52    0    242.52    0    242.52    0    242.52    0    242.24    0
    243.09    0    243.09    0    243.09    0    243.09    0    242.81    0
    243.65    0    243.65    0    243.65    0    243.65    0    243.38    0
    244.21    0    244.21    0    244.21    0    244.21    0    243.93    0
    244.78    0    244.78    0    244.78    0    244.78    0    244.5    0
    245.31    0    245.31    0    245.31    0    245.31    0    245.05    0
    245.85    0    245.85    0    245.85    0    245.85    0    245.58    0
    246.39    0    246.39    0    246.39    0    246.39    0    246.13    0
    246.93    0    246.93    0    246.93    0    246.93    0    246.66    0
    247.5    0    247.5    0    247.5    0    247.5    0    247.21    0
    248.06    0    248.06    0    248.06    0    248.06    0    247.78    0
    248.62    0    248.62    0    248.62    0    248.62    0    248.34    0
    249.19    0    249.19    0    249.19    0    249.19    0    248.9    0
    249.72    0    249.72    0    249.72    0    249.72    0    249.45    0
    250.25    0    250.25    0    250.25    0    250.25    0    249.98    0
    250.79    0    250.79    0    250.79    0    250.79    0    250.52    0
    251.35    0    251.35    0    251.35    0    251.35    0    251.07    0
    251.9    0    251.9    0    251.9    0    251.9    0    251.62    0
    252.47    0    252.47    0    252.47    0    252.47    0    252.18    0
    253.02    0    253.02    0    253.02    0    253.02    0    252.75    0
    253.57    0    253.57    0    253.57    0    253.57    0    253.3    0
    254.1    0    254.1    0    254.1    0    254.1    0    253.83    0
    254.63    0    254.63    0    254.63    0    254.63    0    254.36    0
    255.18    0    255.18    0    255.18    0    255.18    0    254.91    0
    255.73    0    255.73    0    255.73    0    255.73    0    255.45    0
    256.28    0    256.28    0    256.28    0    256.28    0    256.01    0
    256.84    0    256.84    0    256.84    0    256.84    0    256.55    0
    257.4    0    257.4    0    257.4    0    257.4    0    257.11    0
    257.94    0    257.94    0    257.94    0    257.94    0    257.67    0
    258.5    0    258.5    0    258.5    0    258.5    0    258.22    0
    259.05    0    259.05    0    259.05    0    259.05    0    258.78    0
    259.61    0    259.61    0    259.61    0    259.61    0    259.33    0
    260.16    0    260.16    0    260.16    0    260.16    0    259.89    0
    260.72    0    260.72    0    260.72    0    260.72    0    260.44    0
    261.29    0    261.29    0    261.29    0    261.29    0    261    0
    261.85    0    261.85    0    261.85    0    261.85    0    261.57    0
    262.4    0    262.4    0    262.4    0    262.4    0    262.13    0
    262.94    0    262.94    0    262.94    0    262.94    0    262.67    0
    263.49    0    263.49    0    263.49    0    263.49    0    263.22    0
    264.04    0    264.04    0    264.04    0    264.04    0    263.77    0
    264.58    0    264.58    0    264.58    0    264.58    0    264.31    0
    265.13    0    265.13    0    265.13    0    265.13    0    264.86    0
    265.69    0    265.69    0    265.69    0    265.69    0    265.41    0
    266.26    0    266.26    0    266.26    0    266.26    0    265.98    0
    266.82    0    266.82    0    266.82    0    266.82    0    266.54    0
    267.38    0    267.38    0    267.38    0    267.38    0    267.1    0
    267.91    0    267.91    0    267.91    0    267.91    0    267.65    0
    268.47    0    268.47    0    268.47    0    268.47    0    268.19    0
    269    0    269    0    269    0    269    0    268.73    0
    269.54    0    269.54    0    269.54    0    269.54    0    269.27    0
    270.09    0    270.09    0    270.09    0    270.09    0    269.82    0
    270.64    0    270.64    0    270.64    0    270.64    0    270.36    0
    271.19    0    271.19    0    271.19    0    271.19    0    270.91    0
    271.75    0    271.75    0    271.75    0    271.75    0    271.46    0
    272.28    0    272.28    0    272.28    0    272.28    0    272.01    0
    272.81    0    272.81    0    272.81    0    272.81    0    272.55    0
    273.35    0    273.35    0    273.35    2.3    273.35    0    273.08    0
    273.9    0    273.9    0    273.9    1.5    273.9    0    273.63    2.3
    274.46    0    274.46    0    274.46    1.5    274.46    0    274.18    2.3
    275.02    0    275.02    0    275.02    1.5    275.02    0    274.74    1.5
    275.57    0    275.57    0    275.57    1.5    275.57    0    275.29    1.5
    276.12    0    276.12    0    276.12    1.5    276.12    0    275.85    1.5
    276.68    0    276.68    0    276.68    1.5    276.68    0    276.4    1.5
    277.25    0    277.25    0    277.25    1.5    277.25    0    276.96    1.5
    277.81    0    277.81    0    277.81    0.8    277.81    0    277.53    1.5
    278.34    0    278.34    0    278.34    0    278.34    0    278.08    1.5
    278.88    0    278.88    0    278.88    0    278.88    0    278.61    0.8
    279.43    0    279.43    0    279.43    0    279.43    0    279.15    0
    279.98    0    279.98    0    279.98    0    279.98    0    279.7    0
    280.54    0    280.54    0    280.54    0    280.54    0    280.26    0
    281.11    0    281.11    0    281.11    0    281.11    0    280.83    1.5
    281.65    0    281.65    0    281.65    0    281.65    0    281.38    0.8
    282.22    0    282.22    0    282.22    0    282.22    0    281.94    3
    282.75    0    282.75    0    282.75    0    282.75    0    282.49    3
    283.29    0    283.29    0    283.29    0    283.29    0    283.02    3
    283.83    0    283.83    0    283.83    0    283.83    0    283.57    3
    284.37    0    284.37    0    284.37    0    284.37    0    284.1    3
    284.92    0    284.92    0    284.92    0    284.92    0    284.65    2.3
    285.47    0    285.47    0    285.47    0    285.47    0    285.2    2.3
    286.04    0    286.04    0    286.04    0    286.04    0    285.76    2.3
    286.6    0    286.6    0    286.6    0    286.6    0    286.32    4.5
    287.12    0    287.12    0    287.12    0    287.12    0    286.85    4.5
    287.67    0    287.67    0    287.67    0    287.67    0    287.4    4.5
    288.22    0    288.22    0    288.22    0    288.22    0    287.94    4.5
    288.78    0    288.78    0    288.78    0    288.78    0    288.5    4.5
    289.34    0    289.34    2.3    289.34    0    289.34    0    289.05    4.5
    289.9    0    289.9    2.3    289.9    0    289.9    0    289.62    3.8
    290.43    0    290.43    0    290.43    0    290.43    0    290.16    3.8
    290.97    0    290.97    0    290.97    0    290.97    0    290.7    0
    291.52    0    291.52    0    291.52    0    291.52    0    291.25    0
    292.09    0    292.09    0    292.09    0    292.09    0    291.8    0
    292.65    0    292.65    0    292.65    0    292.65    0    292.38    0
    293.19    0    293.19    0    293.19    0    293.19    0    292.92    0
    293.74    0    293.74    0    293.74    0    293.74    0    293.47    0
    294.28    0    294.28    0    294.28    0    294.28    0    294.01    0
    294.81    0    294.81    0    294.81    0    294.81    0    294.54    0
    295.36    0    295.36    0    295.36    0    295.36    0    295.08    0
    295.93    0    295.93    0    295.93    0    295.93    0    295.63    0
    296.48    0    296.48    0    296.48    0    296.48    0    296.2    0
    297.03    0    297.03    0    297.03    0    297.03    0    296.76    0
    297.59    0    297.59    0    297.59    0    297.59    0    297.31    0
    298.16    0    298.16    0    298.16    0    298.16    0    297.87    0
    298.73    0    298.73    0    298.73    0    298.73    0    298.44    0
    299.29    0    299.29    0    299.29    0    299.29    0    299.01    0
    299.84    0    299.84    0    299.84    0    299.84    0    299.57    0
    300.37    0    300.37    0    300.37    0    300.37    0    300.11    0
    300.92    0    300.92    0    300.92    0    300.92    0    300.64    0
    301.46    0    301.46    0    301.46    0    301.46    0    301.19    0
    302.03    0    302.03    0    302.03    0    302.03    0    301.74    0
    302.56    0    302.56    0    302.56    0    302.56    0    302.3    0
    303.1    0    303.1    0    303.1    0    303.1    0    302.83    0
    303.66    0    303.66    0    303.66    0    303.66    0    303.38    0
    304.23    0    304.23    0    304.23    0    304.23    0    303.94    0
    304.79    0    304.79    0    304.79    0    304.79    0    304.51    0
    305.33    0    305.33    0    305.33    0    305.33    0    305.06    0
    305.86    0    305.86    0    305.86    0    305.86    0    305.6    0
    306.4    0    306.4    0    306.4    0    306.4    0    306.13    0
    306.97    0    306.97    0    306.97    0    306.97    0    306.68    0
    307.53    0    307.53    0    307.53    0    307.53    0    307.25    0
    308.09    0    308.09    0    308.09    0    308.09    0    307.81    0
    308.63    0    308.63    0    308.63    0    308.63    0    308.36    0
    309.18    0    309.18    0    309.18    0    309.18    0    308.9    0
    309.75    0    309.75    0    309.75    0    309.75    0    309.46    0
    310.3    0    310.3    0    310.3    0    310.3    0    310.03    0
    310.83    0    310.83    0    310.83    0    310.83    0    310.57    0
    311.37    0    311.37    0    311.37    0    311.37    0    311.1    0
    311.93    0    311.93    0    311.93    0    311.93    0    311.65    0
    312.48    0    312.48    0    312.48    0    312.48    0    312.21    0
    313.04    0    313.04    0    313.04    0    313.04    0    312.76    0
    313.6    0    313.6    0    313.6    0    313.6    0    313.33    0
    314.15    0    314.15    0    314.15    0    314.15    0    313.86    0
    314.7    0    314.7    0    314.7    0    314.7    0    314.43    0
    315.26    0    315.26    0    315.26    0    315.26    0    314.98    0
    315.8    0    315.8    0    315.8    0    315.8    0    315.53    0
    316.36    0    316.36    0    316.36    0    316.36    0    316.08    0
    316.91    0    316.91    0    316.91    0    316.91    0    316.63    0
    317.48    0    317.48    0    317.48    0    317.48    0    317.2    0
    318.02    0    318.02    0    318.02    0    318.02    0    317.75    0
    318.58    0    318.58    0    318.58    0    318.58    0    318.3    0
    319.13    0    319.13    0    319.13    0    319.13    0    318.86    0
    319.7    0    319.7    0    319.7    0    319.7    0    319.42    0
    320.24    0    320.24    0    320.24    0    320.24    0    319.97    0
    320.8    0    320.8    0    320.8    0    320.8    0    320.52    0
    321.37    0    321.37    0    321.37    0    321.37    0    321.09    0
    321.9    0    321.9    0    321.9    0    321.9    0    321.63    0
    322.44    0    322.44    0    322.44    0    322.44    0    322.18    0
    322.98    0    322.98    0    322.98    0    322.98    0    322.72    0
    323.52    0    323.52    0    323.52    0    323.52    0    323.25    0
    324.08    0    324.08    0    324.08    0    324.08    0    323.8    0
    324.64    0    324.64    0    324.64    0    324.64    0    324.37    0
    325.18    0    325.18    0    325.18    0    325.18    0    324.91    0
    325.72    0    325.72    0    325.72    0    325.72    0    325.45    0
    326.27    0    326.27    0    326.27    0    326.27    0    325.99    0
    326.84    0    326.84    0    326.84    0    326.84    0    326.56    0
    327.4    0    327.4    0    327.4    0    327.4    0    327.12    0
    327.95    0    327.95    0    327.95    0    327.95    0    327.68    0
    328.49    0    328.49    0    328.49    0    328.49    0    328.22    0
    329.06    0    329.06    0    329.06    0    329.06    0    328.77    0
    329.62    0    329.62    0    329.62    0    329.62    0    329.34    0
    330.18    0    330.18    0    330.18    0    330.18    0    329.9    0
    330.73    0    330.73    0    330.73    0    330.73    0    330.46    0
    331.27    0    331.27    0    331.27    0    331.27    0    331    0
    331.82    0    331.82    0    331.82    0    331.82    0    331.54    0
    332.38    0    332.38    0    332.38    0    332.38    0    332.1    0
    332.93    0    332.93    0    332.93    0    332.93    0    332.65    0
    333.47    0    333.47    0    333.47    0    333.47    0    333.2    0
    334.02    0    334.02    0    334.02    0    334.02    0    333.74    0
    334.55    0    334.55    0    334.55    0    334.55    0    334.28    0
    335.08    0    335.08    0    335.08    0    335.08    0    334.81    0
    335.63    0    335.63    0    335.63    0    335.63    0    335.35    0
    336.18    0    336.18    0    336.18    0    336.18    0    335.91    0
    336.74    0    336.74    0    336.74    0    336.74    0    336.46    0
    337.27    0    337.27    0    337.27    0    337.27    0    337    0
    337.82    0    337.82    0    337.82    0    337.82    0    337.54    0
    338.36    0    338.36    0    338.36    0    338.36    0    338.1    0
    338.93    0    338.93    0    338.93    0    338.93    0    338.65    0
    339.48    0    339.48    0    339.48    0    339.48    0    339.21    0
    340.03    0    340.03    0    340.03    0    340.03    0    339.76    0
    340.59    0    340.59    0    340.59    0    340.59    0    340.31    0
    341.14    0    341.14    0    341.14    0    341.14    0    340.87    0
    341.7    0    341.7    0    341.7    0    341.7    0    341.43    0
    342.26    0    342.26    0    342.26    0    342.26    0    341.98    0
    342.81    0    342.81    0    342.81    0    342.81    0    342.53    0
    343.37    0    343.37    0    343.37    0    343.37    0    343.09    0
    343.92    0    343.92    0    343.92    0    343.92    0    343.66    0
    344.49    0    344.49    0    344.49    0    344.49    0    344.21    0
    345.03    0    345.03    0    345.03    0    345.03    0    344.76    0
    345.58    0    345.58    0    345.58    0    345.58    0    345.3    0
    346.14    0    346.14    0    346.14    0    346.14    0    345.86    0
    346.68    0    346.68    0    346.68    0    346.68    0    346.4    0
    347.22    0    347.22    0    347.22    0    347.22    0    346.94    0
    347.78    0    347.78    0    347.78    0    347.78    0    347.52    0
    348.33    0    348.33    0    348.33    0    348.33    0    348.05    0
    348.89    0    348.89    0    348.89    0    348.89    0    348.62    0
    349.45    0    349.45    0    349.45    0    349.45    0    349.16    0
    349.99    0    349.99    0    349.99    0    349.99    0    349.72    0
    350.54    0    350.54    0    350.54    0    350.54    0    350.27    0
    351.08    0    351.08    0    351.08    0    351.08    0    350.81    0
    351.62    0    351.62    0    351.62    0    351.62    0    351.36    0
    352.16    0    352.16    0    352.16    0    352.16    0    351.89    0
    352.72    0    352.72    0    352.72    0    352.72    0    352.45    0
    353.28    0    353.28    0    353.28    0    353.28    0    353.01    0
    353.81    0    353.81    0    353.81    0    353.81    0    353.54    0
    354.35    0    354.35    0    354.35    0    354.35    0    354.08    0
    354.92    0    354.92    0    354.92    0    354.92    0    354.63    0
    355.47    0    355.47    0    355.47    0    355.47    0    355.19    0
    356    0    356    0    356    0    356    0    355.73    0
    356.55    0    356.55    0    356.55    0    356.55    0    356.27    0
    357.12    0    357.12    0    357.12    0    357.12    0    356.83    0
    357.68    0    357.68    0    357.68    0    357.68    0    357.4    0
    358.24    0    358.24    0    358.24    0    358.24    0    357.97    0
    358.8    0    358.8    0    358.8    0    358.8    0    358.53    0
    359.35    0    359.35    0    359.35    0    359.35    0    359.07    0
    359.91    0    359.91    0    359.91    0    359.91    0    359.63    0
    360.46    0    360.46    0    360.46    0    360.46    0    360.18    0
    361.02    0    361.02    0    361.02    0    361.02    0    360.74    0
    361.57    0    361.57    0    361.57    0    361.57    0    361.29    0
    362.13    0    362.13    0    362.13    0    362.13    0    361.85    0
    362.67    0    362.67    0    362.67    0    362.67    0    362.41    0
    363.22    0    363.22    0    363.22    0    363.22    0    362.94    0
    363.77    0    363.77    0    363.77    0    363.77    0    363.49    0
    364.32    0    364.32    0    364.32    0    364.32    0    364.04    0
    364.88    0    364.88    0    364.88    0    364.88    0    364.61    0
    365.43    0    365.43    0    365.43    0    365.43    0    365.16    0
    365.99    0    365.99    0    365.99    0    365.99    0    365.71    0
    366.56    0    366.56    0    366.56    0    366.56    0    366.28    0
    367.1    0    367.1    0    367.1    0    367.1    0    366.83    0
    367.65    0    367.65    0    367.65    0    367.65    0    367.37    0
    368.22    0    368.22    0    368.22    0    368.22    0    367.93    0
    368.78    0    368.78    0    368.78    0    368.78    0    368.5    0
    369.33    0    369.33    0    369.33    0    369.33    0    369.06    0
    369.86    0    369.86    0    369.86    0    369.86    0    369.6    0
    370.4    0    370.4    0    370.4    0    370.4    0    370.13    0
    370.95    0    370.95    0    370.95    0    370.95    0    370.68    0
    371.51    0    371.51    2.3    371.51    0    371.51    0    371.23    3.8
    372.08    0    372.08    2.3    372.08    0    372.08    0    371.79    3.8
    372.63    0    372.63    2.3    372.63    0    372.63    0    372.36    3.8
    373.19    0    373.19    1.5    373.19    0    373.19    0    372.9    3
    373.73    0    373.73    1.5    373.73    0    373.73    0    373.46    3
    374.29    0    374.29    1.5    374.29    0    374.29    0    374.01    3
    374.83    0    374.83    0.8    374.83    0    374.83    0    374.56    3
    375.38    0    375.38    0.8    375.38    0    375.38    0    375.11    2.3
    375.93    0    375.93    0    375.93    0    375.93    0    375.65    2.3
    376.48    0    376.48    0    376.48    0    376.48    0    376.21    1.5
    377.03    0    377.03    0    377.03    0    377.03    0    376.75    0
    377.58    0    377.58    0    377.58    0    377.58    0    377.3    0
    378.15    0    378.15    0    378.15    0    378.15    0    377.87    0
    378.71    0    378.71    0    378.71    0    378.71    0    378.44    0
    379.26    0    379.26    0    379.26    0    379.26    0    378.99    2.3
    379.81    0    379.81    0    379.81    0    379.81    0    379.53    1.5
    380.36    0    380.36    2.3    380.36    0    380.36    0    380.08    0.8
    380.91    0    380.91    2.3    380.91    0    380.91    0    380.63    3
    381.47    0    381.47    2.3    381.47    2.3    381.47    0    381.21    3
    382.02    0    382.02    2.3    382.02    2.3    382.02    0    381.75    3
    382.59    0    382.59    1.5    382.59    2.3    382.59    0    382.3    3
    383.15    0    383.15    1.5    383.15    2.3    383.15    0    382.87    3
    383.71    0    383.71    1.5    383.71    2.3    383.71    0    383.43    2.3
    384.25    0    384.25    1.5    384.25    1.5    384.25    0    383.98    2.3
    384.8    0    384.8    0    384.8    0    384.8    0    384.52    2.3
    385.35    0    385.35    0    385.35    0    385.35    0    385.08    0
    385.89    0    385.89    0    385.89    0    385.89    0    385.62    0
    386.45    0    386.45    0    386.45    0    386.45    0    386.16    0
    386.99    0    386.99    0    386.99    0    386.99    0    386.72    0
    387.55    0    387.55    0    387.55    0    387.55    0    387.27    0
    388.08    0    388.08    0    388.08    0    388.08    0    387.81    0
    388.61    0    388.61    0    388.61    0    388.61    0    388.34    0
    389.16    0    389.16    1.5    389.16    1.5    389.16    0    388.88    2.3
    389.71    0    389.71    0    389.71    0    389.71    0    389.44    2.3
    390.26    0    390.26    1.5    390.26    1.5    390.26    0    389.99    2.3
    390.82    0    390.82    1.5    390.82    1.5    390.82    0    390.54    2.3
    391.39    0    391.39    0.8    391.39    1.5    391.39    0    391.11    2.3
    391.93    0    391.93    0    391.93    1.5    391.93    0    391.65    2.3
    392.5    2.3    392.5    0    392.5    1.5    392.5    0    392.22    3.8
    393.03    2.3    393.03    2.3    393.03    3.8    393.03    0    392.77    3.8
    393.56    2.3    393.56    2.3    393.56    3.8    393.56    2.3    393.3    3.8
    394.09    2.3    394.09    2.3    394.09    3.8    394.09    2.3    393.83    3.8
    394.63    2.3    394.63    2.3    394.63    3.8    394.63    2.3    394.36    3.8
    395.18    1.5    395.18    2.3    395.18    3.8    395.18    2.3    394.9    3.8
    395.75    3.8    395.75    1.5    395.75    3    395.75    2.3    395.46    3
    396.31    3.8    396.31    1.5    396.31    3    396.31    1.5    396.03    3
    396.87    3.8    396.87    1.5    396.87    3    396.87    1.5    396.59    3
    397.43    3.8    397.43    1.5    397.43    3    397.43    1.5    397.15    3
    398    3.8    398    1.5    398    3    398    1.5    397.72    3
    398.54    3    398.54    0.8    398.54    2.3    398.54    1.5    398.27    2.3
    399.1    3    399.1    0.8    399.1    2.3    399.1    0.8    398.82    2.3
    399.65    3    399.65    0.8    399.65    2.3    399.65    0.8    399.37    2.3
    400.2    3    400.2    0.8    400.2    2.3    400.2    0.8    399.93    2.3
    400.76    3    400.76    0.8    400.76    2.3    400.76    0.8    400.48    1.5
    401.31    2.3    401.31    0    401.31    1.5    401.31    0.8    401.03    3.8
    401.87    2.3    401.87    0    401.87    1.5    401.87    0    401.58    3.8
    402.44    2.3    402.44    0    402.44    1.5    402.44    0    402.15    3.8
    402.99    2.3    402.99    0    402.99    1.5    402.99    0    402.72    3.8
    403.54    0    403.54    0    403.54    1.5    403.54    0    403.27    3
    404.08    0    404.08    0    404.08    0    404.08    0    403.81    0
    404.64    0    404.64    0    404.64    0    404.64    0    404.37    0
    405.19    0    405.19    0    405.19    0    405.19    0    404.91    0
    405.76    0    405.76    0    405.76    0    405.76    0    405.47    0
    406.32    0    406.32    0    406.32    0    406.32    0    406.04    0
    406.86    0    406.86    0    406.86    0    406.86    0    406.59    0
    407.39    0    407.39    0    407.39    0    407.39    0    407.12    0
    407.95    2.3    407.95    0    407.95    1.5    407.95    0    407.66    0
    408.5    2.3    408.5    0    408.5    1.5    408.5    0    408.23    3
    409.05    2.3    409.05    0    409.05    1.5    409.05    0    408.77    4.5
    409.61    1.5    409.61    0    409.61    0.8    409.61    0    409.34    4.5
    410.15    1.5    410.15    0    410.15    0.8    410.15    0    409.89    4.5
    410.69    1.5    410.69    0    410.69    0.8    410.69    0    410.42    4.5
    411.24    1.5    411.24    0    411.24    3    411.24    2.3    410.98    4.5
    411.8    1.5    411.8    0    411.8    3    411.8    2.3    411.52    4.5
    412.35    1.5    412.35    0    412.35    3    412.35    2.3    412.08    3.8
    412.91    0.8    412.91    0    412.91    3    412.91    2.3    412.63    3.8
    413.47    0.8    413.47    0    413.47    3    413.47    2.3    413.19    3.8
    414.01    0.8    414.01    0    414.01    2.3    414.01    1.5    413.75    3.8
    414.55    0.8    414.55    0    414.55    1.5    414.55    0.8    414.28    3.8
    415.11    0.8    415.11    0    415.11    0.8    415.11    0    414.83    3
    415.66    0    415.66    0    415.66    0    415.66    0    415.38    4.5
    416.21    0    416.21    0    416.21    0    416.21    0    415.94    4.5
    416.77    0    416.77    0    416.77    0    416.77    0    416.49    4.5
    417.34    0    417.34    0    417.34    0    417.34    0    417.06    4.5
    417.89    0    417.89    0    417.89    0    417.89    0    417.62    4.5
    418.42    0    418.42    0    418.42    0    418.42    0    418.15    4.5
    418.96    0    418.96    0    418.96    0    418.96    0    418.69    4.5
    419.52    0    419.52    2.3    419.52    0    419.52    2.3    419.24    3.8
    420.07    0    420.07    2.3    420.07    2.3    420.07    2.3    419.79    3
    420.62    0    420.62    2.3    420.62    2.3    420.62    2.3    420.34    5.3
    421.16    0    421.16    2.3    421.16    2.3    421.16    2.3    420.89    5.3
    421.69    0    421.69    2.3    421.69    2.3    421.69    2.3    421.42    5.3
    422.25    0    422.25    1.5    422.25    2.3    422.25    1.5    421.96    5.3
    422.81    0    422.81    1.5    422.81    1.5    422.81    1.5    422.53    5.3
    423.37    3    423.37    0.8    423.37    1.5    423.37    0.8    423.09    4.5
    423.93    3    423.93    3    423.93    1.5    423.93    3.8    423.65    4.5
    424.5    3    424.5    3    424.5    1.5    424.5    3.8    424.21    4.5
    425.03    3    425.03    3    425.03    1.5    425.03    3.8    424.77    4.5
    425.57    3    425.57    3    425.57    1.5    425.57    3.8    425.3    4.5
    426.11    3    426.11    3    426.11    1.5    426.11    3.8    425.84    4.5
    426.65    3    426.65    3    426.65    1.5    426.65    3.8    426.38    4.5
    427.19    3    427.19    3    427.19    1.5    427.19    3.8    426.92    6.8
    427.73    3    427.73    3    427.73    1.5    427.73    3.8    427.46    6.8
    428.3    3    428.3    3    428.3    0.8    428.3    3.8    428.01    6.8
    428.85    3    428.85    3    428.85    0    428.85    3.8    428.58    6.8
    429.38    2.3    429.38    0    429.38    0    429.38    0    429.11    6.8
    429.91    0    429.91    0    429.91    0    429.91    0    429.64    0
    430.46    0    430.46    0    430.46    0    430.46    0    430.18    0
    431.01    1.5    431.01    3    431.01    0    431.01    3.8    430.72    0
    431.55    0.8    431.55    3    431.55    0    431.55    3.8    431.29    6
    432.09    0    432.09    2.3    432.09    0    432.09    3    431.82    5.3
    432.64    0    432.64    1.5    432.64    0    432.64    2.3    432.37    4.5
    433.21    0    433.21    0.8    433.21    0    433.21    1.5    432.93    3.8
    433.76    12    433.76    12    433.76    12    433.76    12    433.5    3
    434.29    12    434.29    12    434.29    12    434.29    12    434.03    12
    434.82    12    434.82    12    434.82    12    434.82    12    434.56    12
    435.36    12    435.36    12    435.36    12    435.36    12    435.09    12
    435.91    0    435.91    0    435.91    0    435.91    0    435.64    12
    436.48    0    436.48    0    436.48    0    436.48    0    436.19    0
    437.04    12    437.04    12    437.04    12    437.04    12    436.76    0
    437.59    12    437.59    12    437.59    12    437.59    12    437.32    12
    438.14    12    438.14    12    438.14    12    438.14    12    437.86    12
    438.69    12    438.69    12    438.69    12    438.69    12    438.41    12
    439.25    12    439.25    12    439.25    12    439.25    12    438.97    12
    439.8    12    439.8    12    439.8    12    439.8    12    439.52    12
    440.37    12    440.37    12    440.37    12    440.37    12    440.08    12
    440.93    12    440.93    12    440.93    12    440.93    12    440.65    12
    441.49    12    441.49    12    441.49    12    441.49    12    441.21    12
    442.02    12    442.02    12    442.02    12    442.02    12    441.75    12
    442.58    0    442.58    0    442.58    0    442.58    0    442.3    0
    443.15    0    443.15    0    443.15    0    443.15    0    442.87    0
    443.71    0    443.71    0    443.71    0    443.71    0.8    443.43    0
    444.26    0    444.26    0    444.26    0    444.26    0    443.98    2.3
    444.8    0    444.8    0    444.8    0    444.8    0    444.52    1.5
    445.35    0    445.35    0    445.35    0    445.35    0    445.08    0
    445.91    0    445.91    0    445.91    0    445.91    0    445.63    0
    446.46    0    446.46    0    446.46    0    446.46    0    446.19    0
    447.02    0    447.02    0    447.02    0    447.02    0    446.76    0
    447.57    0    447.57    0    447.57    0    447.57    0    447.3    0
    448.13    0    448.13    0    448.13    0    448.13    0    447.85    0
    448.68    0    448.68    0    448.68    0    448.68    0    448.41    0
    449.24    0    449.24    0    449.24    0    449.24    0    448.96    1.5
    449.8    0    449.8    0    449.8    0    449.8    0    449.53    0.8
    450.36    0    450.36    0    450.36    0    450.36    0    450.07    0
    450.9    0    450.9    0    450.9    0    450.9    0    450.64    2.3
    451.44    0    451.44    0    451.44    0    451.44    2.3    451.17    2.3
    451.99    0    451.99    0    451.99    2.3    451.99    2.3    451.71    2.3
    452.56    0    452.56    0    452.56    2.3    452.56    2.3    452.28    4.5
    453.12    0    453.12    0    453.12    2.3    453.12    2.3    452.84    4.5
    453.68    0    453.68    0    453.68    2.3    453.68    2.3    453.4    4.5
    454.23    0    454.23    0    454.23    2.3    454.23    1.5    453.97    4.5
    454.77    0    454.77    0    454.77    1.5    454.77    1.5    454.5    4.5
    455.32    0    455.32    0    455.32    1.5    455.32    3.8    455.04    3.8
    455.87    0    455.87    0    455.87    1.5    455.87    3.8    455.6    3.8
    456.44    0    456.44    0    456.44    1.5    456.44    3.8    456.15    3.8
    456.99    0    456.99    0    456.99    1.5    456.99    3.8    456.72    3.8
    457.52    0    457.52    0    457.52    3.8    457.52    3.8    457.25    3.8
    458.07    0    458.07    0    458.07    3.8    458.07    3    457.79    6
    458.62    0    458.62    0    458.62    3.8    458.62    3    458.34    6
    459.18    0    459.18    0    459.18    3.8    459.18    3    458.9    6
    459.72    0    459.72    0    459.72    3.8    459.72    3    459.45    6
    460.27    0    460.27    0    460.27    3    460.27    3    459.99    6
    460.82    0    460.82    0    460.82    3    460.82    2.3    460.54    5.3
    461.36    0    461.36    0    461.36    3    461.36    2.3    461.08    5.3
    461.94    3    461.94    4.5    461.94    3    461.94    2.3    461.65    5.3
    462.47    3    462.47    4.5    462.47    3    462.47    2.3    462.2    5.3
    463    0    463    0    463    0    463    0    462.73    0
    463.56    0    463.56    0    463.56    0    463.56    0    463.28    0
    464.12    0    464.12    0    464.12    0    464.12    0    463.84    0
    464.67    3    464.67    4.5    464.67    3    464.67    2.3    464.4    0
    465.22    0    465.22    0    465.22    0    465.22    0    464.94    0
    465.77    0    465.77    0    465.77    0    465.77    0    465.5    0
    466.33    0    466.33    0    466.33    0    466.33    0    466.06    0
    466.88    0    466.88    0    466.88    0    466.88    0    466.6    0
    467.45    0    467.45    0    467.45    0    467.45    0    467.16    0
    468.01    0    468.01    0    468.01    0    468.01    0    467.73    0
    468.56    0    468.56    0    468.56    0    468.56    0    468.28    0
    469.1    0    469.1    0    469.1    0    469.1    0    468.83    0
    469.66    0    469.66    0    469.66    0    469.66    0    469.38    0
    470.23    0    470.23    0    470.23    0    470.23    0    469.95    0
    470.79    3    470.79    4.5    470.79    3    470.79    2.3    470.51    5.3
    471.33    3    471.33    4.5    471.33    2.3    471.33    2.3    471.06    5.3
    471.86    3    471.86    4.5    471.86    1.5    471.86    1.5    471.59    4.5
    472.41    3    472.41    4.5    472.41    0.8    472.41    0.8    472.13    3.8
    472.96    3    472.96    4.5    472.96    0    472.96    0    472.68    3
    473.52    3    473.52    4.5    473.52    0    473.52    0    473.24    2.3
    474.09    3    474.09    4.5    474.09    0    474.09    0    473.81    1.5
    474.65    3    474.65    4.5    474.65    0    474.65    0    474.37    0.8
    475.22    3    475.22    3.8    475.22    0    475.22    0    474.94    2.3
    475.78    2.3    475.78    3.8    475.78    0    475.78    0    475.5    2.3
    476.31    2.3    476.31    3.8    476.31    2.3    476.31    0    476.05    4.5
    476.86    2.3    476.86    3.8    476.86    2.3    476.86    0    476.59    4.5
    477.41    2.3    477.41    3.8    477.41    2.3    477.41    2.3    477.13    4.5
    477.94    2.3    477.94    3.8    477.94    2.3    477.94    2.3    477.67    4.5
    478.49    1.5    478.49    3    478.49    2.3    478.49    2.3    478.21    4.5
    479.04    0    479.04    0    479.04    0    479.04    0    478.76    0
    479.6    0    479.6    0    479.6    0    479.6    0    479.32    0
    480.16    0    480.16    0    480.16    0    480.16    0    479.87    0
    480.7    0    480.7    0    480.7    0    480.7    0    480.44    0
    481.24    0    481.24    0    481.24    0    481.24    0    480.97    0
    481.79    0    481.79    0    481.79    0    481.79    0    481.51    0
    482.33    0    482.33    0    482.33    0    482.33    0    482.07    0
    482.91    0    482.91    0    482.91    0    482.91    0    482.61    0
    483.44    0    483.44    0    483.44    0    483.44    0    483.17    0
    483.97    0    483.97    0    483.97    0    483.97    0    483.7    0
    484.54    0    484.54    0    484.54    0    484.54    0    484.26    0
    485.11    0    485.11    0    485.11    0    485.11    0    484.83    0
    485.66    1.5    485.66    2.3    485.66    1.5    485.66    2.3    485.38    3.8
    486.23    1.5    486.23    2.3    486.23    1.5    486.23    2.3    485.95    3
    486.76    0.8    486.76    1.5    486.76    1.5    486.76    2.3    486.49    3
    487.32    0    487.32    0    487.32    0    487.32    0    487.03    2.3
    487.86    0    487.86    0    487.86    0    487.86    0    487.58    0
    488.41    0    488.41    0    488.41    0    488.41    0    488.14    0
    488.97    0    488.97    0    488.97    0    488.97    0    488.69    0
    489.53    0    489.53    0.8    489.53    0    489.53    1.5    489.25    2.3
    490.09    0    490.09    0    490.09    0    490.09    0.8    489.81    1.5
    490.65    0    490.65    0    490.65    0    490.65    0    490.36    0.8
    491.21    0    491.21    0    491.21    0    491.21    0    490.93    0
    491.76    0    491.76    0    491.76    0    491.76    2.3    491.49    0
    492.3    0    492.3    0    492.3    0    492.3    2.3    492.03    0
    492.86    0    492.86    0    492.86    0    492.86    2.3    492.58    0
    493.41    0    493.41    0    493.41    0    493.41    2.3    493.14    0
    493.98    0    493.98    0    493.98    0    493.98    0    493.69    0
    494.54    0    494.54    0    494.54    0    494.54    0    494.26    0
    495.1    0    495.1    0    495.1    0    495.1    0    494.83    0
    495.66    0    495.66    0    495.66    0    495.66    0    495.38    0
    496.23    0    496.23    0    496.23    0    496.23    0    495.94    0
    496.78    0    496.78    0    496.78    0    496.78    0    496.51    0
    497.33    0    497.33    0    497.33    0    497.33    0    497.05    0
    497.86    0    497.86    0    497.86    0    497.86    0    497.59    0
    498.41    0    498.41    0    498.41    0    498.41    0    498.13    0
    498.95    0    498.95    0    498.95    0    498.95    0    498.69    0
    499.48    0    499.48    0    499.48    0    499.48    0    499.22    0
    500.02    0    500.02    0    500.02    0    500.02    0    499.75    0
    500.57    0    500.57    0    500.57    0    500.57    0    500.3    0
    501.13    0    501.13    0    501.13    0    501.13    0    500.85    0
    501.68    0    501.68    0    501.68    0    501.68    0    501.4    0
    502.24    0    502.24    0    502.24    0    502.24    0    501.96    0
    502.81    0    502.81    0    502.81    0    502.81    0    502.53    0
    503.36    0    503.36    0    503.36    0    503.36    0    503.08    0
    503.89    0    503.89    0    503.89    0    503.89    0    503.63    0
    504.42    0    504.42    0    504.42    0    504.42    0    504.16    0
    504.96    0    504.96    0    504.96    0    504.96    0    504.69    0
    505.52    0    505.52    0    505.52    0    505.52    0    505.24    0
    506.07    0    506.07    0    506.07    0    506.07    0    505.8    0
    506.64    0    506.64    0    506.64    0    506.64    0    506.36    0
    507.2    0    507.2    0    507.2    0    507.2    0    506.92    0
    507.76    0    507.76    0    507.76    0    507.76    0    507.48    0
    508.33    0    508.33    0    508.33    0    508.33    0    508.05    0
    508.89    0    508.89    0    508.89    0    508.89    0    508.61    0
    509.44    0    509.44    0    509.44    0    509.44    2.3    509.17    0
    509.99    0    509.99    0    509.99    0    509.99    1.5    509.72    0
    510.52    0    510.52    0    510.52    0    510.52    0.8    510.25    0
    511.07    0    511.07    0    511.07    0    511.07    0    510.79    0
    511.62    0    511.62    0    511.62    0    511.62    0    511.34    0
    512.19    0    512.19    0    512.19    0    512.19    0    511.9    2.3
    512.73    0    512.73    0    512.73    0    512.73    0    512.47    2.3
    513.29    0    513.29    0    513.29    0    513.29    0    513.01    2.3
    513.84    0    513.84    0    513.84    0    513.84    0    513.56    2.3
    514.4    0    514.4    0    514.4    0    514.4    0    514.12    2.3
    514.95    0    514.95    0    514.95    0    514.95    0    514.68    1.5
    515.5    0    515.5    0    515.5    0    515.5    0    515.22    0
    516.05    0    516.05    0    516.05    0    516.05    0    515.78    0
    516.61    0    516.61    0    516.61    0    516.61    0    516.34    0
    517.15    0    517.15    0    517.15    0    517.15    0    516.88    0
    517.69    0    517.69    0    517.69    0    517.69    0    517.42    0
    518.25    0    518.25    0    518.25    0    518.25    0    517.97    0
    518.8    0    518.8    0    518.8    0    518.8    0    518.52    0
    519.37    0    519.37    0    519.37    0    519.37    0    519.1    0
    519.93    0    519.93    0    519.93    0    519.93    0    519.65    0
    520.47    0    520.47    0    520.47    0    520.47    0    520.2    0
    521.02    0    521.02    0    521.02    0    521.02    0    520.75    0
    521.59    0    521.59    0    521.59    0    521.59    0    521.31    0
    522.13    0    522.13    0    522.13    0    522.13    0    521.86    0
    522.69    0    522.69    0    522.69    0    522.69    0    522.41    0
    523.24    0    523.24    0    523.24    0    523.24    0    522.96    0
    523.8    0    523.8    0    523.8    0    523.8    0    523.52    0
    524.35    0    524.35    0    524.35    0    524.35    0    524.09    0
    524.91    0    524.91    0    524.91    0    524.91    0    524.63    0
    525.46    0    525.46    0    525.46    0    525.46    0    525.19    0
    526.02    0    526.02    0    526.02    0    526.02    0    525.74    0
    526.57    0    526.57    0    526.57    0    526.57    0    526.29    0
    527.12    0    527.12    0    527.12    0    527.12    0    526.85    0
    527.66    0    527.66    0    527.66    0    527.66    0    527.39    0
    528.23    0    528.23    0    528.23    0    528.23    0    527.95    0
    528.79    0    528.79    0    528.79    0    528.79    0    528.51    0
    529.33    0    529.33    0    529.33    0    529.33    0    529.06    0
    529.88    0    529.88    0    529.88    0    529.88    0    529.6    0
    530.43    0    530.43    0    530.43    0    530.43    0    530.15    0
    530.99    0    530.99    0    530.99    0    530.99    0    530.71    0
    531.55    0    531.55    0    531.55    0    531.55    0    531.28    0
    532.09    0    532.09    0    532.09    0    532.09    0    531.83    0
    532.65    0    532.65    0    532.65    0    532.65    0    532.37    0
    533.21    0    533.21    0    533.21    0    533.21    0    532.93    0
    533.77    0    533.77    0    533.77    0    533.77    0    533.49    0
    534.32    0    534.32    0    534.32    0    534.32    0    534.04    0
    534.89    0    534.89    0    534.89    0    534.89    0    534.6    0
    535.44    0    535.44    0    535.44    0    535.44    0    535.17    0
    535.97    0    535.97    0    535.97    0    535.97    0    535.7    0
    536.53    0    536.53    0    536.53    0    536.53    0    536.24    0
    537.09    0    537.09    0    537.09    0    537.09    0    536.81    0
    537.65    0    537.65    0    537.65    0    537.65    0    537.37    0
    538.21    0    538.21    0    538.21    0    538.21    0    537.93    0
    538.76    0    538.76    0    538.76    0    538.76    0    538.48    0
    539.33    0    539.33    0    539.33    0    539.33    0    539.04    0
    539.88    0    539.88    0    539.88    0    539.88    0    539.61    0
    540.43    0    540.43    0    540.43    0    540.43    0    540.15    0
    540.99    0    540.99    0    540.99    0    540.99    0    540.71    0
    541.51    0    541.51    0    541.51    0    541.51    0    541.25    0
    542.06    0    542.06    0    542.06    0    542.06    0    541.78    0
    542.63    0    542.63    0    542.63    0    542.63    0    542.33    0
    543.17    0    543.17    0    543.17    0    543.17    0    542.89    0
    543.73    0    543.73    0    543.73    0    543.73    0    543.45    0
    544.28    0    544.28    0    544.28    0    544.28    0    544.01    0
    544.82    0    544.82    0    544.82    0    544.82    0    544.54    0
    545.37    0    545.37    0    545.37    0    545.37    0    545.08    0
    545.91    0    545.91    0    545.91    0    545.92    0    545.64    0
    546.48    0    546.48    0    546.48    0    546.48    0    546.19    0
    547.01    0    547.01    0    547.01    0    547.01    0    546.74    0
    547.54    0    547.54    0    547.54    0    547.54    0    547.28    0
    548.08    0    548.08    0    548.08    0    548.08    0    547.81    0
    548.63    0    548.63    0    548.63    0    548.63    0    548.37    0
    549.19    0    549.19    0    549.19    0    549.19    0    548.91    0
    549.74    0    549.74    0    549.74    0    549.74    0    549.47    0
    550.3    0    550.3    0    550.3    0    550.3    0    550.02    0
    550.88    0    550.88    0    550.88    0    550.88    0    550.58    0
    551.43    0    551.43    0    551.43    0    551.43    0    551.15    0
    551.98    0    551.98    0    551.98    0    551.98    0    551.71    0
    552.52    0    552.52    0    552.52    0    552.52    0    552.25    0
    553.07    0    553.07    0    553.07    0    553.07    0    552.8    0
    553.63    0    553.63    0    553.63    0    553.63    0    553.36    0
    554.19    0    554.19    0    554.19    0    554.19    0    553.91    0
    554.74    0    554.74    0    554.74    0    554.74    0    554.46    0
    555.3    0    555.3    0    555.3    0    555.3    0    555.02    0
    555.85    0    555.85    0    555.85    0    555.85    0    555.57    0
    556.42    0    556.42    0    556.42    0    556.42    0    556.14    0
    556.97    0    556.97    0    556.97    0    556.97    0    556.7    0
    557.52    0    557.52    0    557.52    0    557.52    0    557.24    0
    558.07    0    558.07    0    558.07    0    558.07    0    557.79    0
    558.64    0    558.64    0    558.64    0    558.64    0    558.37    0
    559.2    0    559.2    0    559.2    0    559.2    0    558.92    0
    559.75    0    559.75    0    559.75    0    559.75    0    559.48    0
    560.28    0    560.28    0    560.28    0    560.28    0    560.02    0
    560.81    0    560.81    0    560.81    0    560.81    0    560.55    0
    561.35    0    561.35    0    561.35    0    561.35    0    561.08    0
    561.9    0    561.9    0    561.9    0    561.9    0    561.62    0
    562.46    0    562.46    0    562.46    0    562.46    0    562.18    0
    563.01    0    563.01    0    563.01    0    563.01    0    562.74    0
    563.57    0    563.57    0    563.57    0    563.57    0    563.29    0
    564.14    0    564.14    0    564.14    0    564.14    0    563.86    0
    564.67    0    564.67    0    564.67    0    564.67    0    564.41    0
    565.21    0    565.21    0    565.21    0    565.21    0    564.94    0
    565.76    0    565.76    0    565.76    0    565.76    0    565.48    0
    566.33    0    566.33    0    566.33    0    566.33    0    566.05    0
    566.87    0    566.87    0    566.87    0    566.87    0    566.59    0
    567.43    0    567.43    0    567.43    0    567.43    0    567.16    0
    567.97    0    567.97    0    567.97    0    567.97    0    567.71    0
    568.51    0    568.51    0    568.51    0    568.51    0    568.24    1.5
    569.07    0    569.07    0    569.07    0    569.07    0    568.79    1.5
    569.62    0    569.62    0    569.62    0    569.62    0    569.34    0.8
    570.18    0    570.18    0    570.18    0    570.18    0    569.91    3
    570.73    0    570.73    0    570.73    0    570.73    0    570.46    3
    571.29    0    571.29    0    571.29    0    571.29    0    571    3
    571.84    0    571.84    0    571.84    0    571.84    0    571.57    3
    572.41    0    572.41    0    572.41    0    572.41    0    572.12    3
    572.95    0    572.95    0    572.95    0    572.95    0    572.68    3
    573.5    0    573.5    0    573.5    0    573.5    0    573.22    2.3
    574.05    0    574.05    0    574.05    0    574.05    0    573.77    5.3
    574.61    0    574.61    0    574.61    0    574.61    0    574.33    5.3
    575.18    0    575.18    0    575.18    0    575.18    0    574.91    5.3
    575.74    0    575.74    0    575.74    0    575.74    0    575.46    0
    576.3    0    576.3    0    576.3    0    576.3    0    576.02    0
    576.85    0    576.85    0    576.85    0    576.85    0    576.59    0
    577.4    0    577.4    0    577.4    0    577.4    0    577.12    5.3
    577.96    0    577.96    0    577.96    0    577.96    0    577.68    5.3
    578.52    0    578.52    0    578.52    0    578.52    0    578.24    5.3
    579.09    0    579.09    0    579.09    0    579.09    0    578.8    0
    579.62    0    579.62    0    579.62    0    579.62    0    579.36    0
    580.16    0    580.16    0    580.16    0    580.16    0    579.89    0
    580.69    0    580.69    0    580.69    0    580.69    0    580.43    0
    581.24    0    581.24    0    581.24    0    581.24    0    580.96    0
    581.8    0    581.8    0    581.8    0    581.8    0    581.52    0
    582.33    0    582.33    0    582.33    0    582.33    0    582.07    0
    582.88    2.3    582.88    0    582.88    0    582.88    2.3    582.6    0
    583.45    2.3    583.45    0    583.45    0    583.45    2.3    583.17    5.3
    584    2.3    584    0    584    0    584    2.3    583.73    5.3
    584.55    2.3    584.55    0    584.55    0    584.55    2.3    584.27    5.3
    585.1    2.3    585.1    0    585.1    2.3    585.1    2.3    584.82    4.5
    585.68    2.3    585.68    0    585.68    2.3    585.68    2.3    585.38    3.8
    586.23    1.5    586.23    0    586.23    2.3    586.23    1.5    585.95    3.8
    586.77    1.5    586.77    0    586.77    2.3    586.77    1.5    586.5    3.8
    587.32    1.5    587.32    0    587.32    1.5    587.32    1.5    587.05    3.8
    587.88    1.5    587.88    0    587.88    1.5    587.88    1.5    587.6    3
    588.45    1.5    588.45    0    588.45    1.5    588.45    1.5    588.16    5.3
    589.01    0.8    589.01    0    589.01    1.5    589.01    1.5    588.73    5.3
    589.56    0.8    589.56    0    589.56    1.5    589.56    0.8    589.3    5.3
    590.1    0    590.1    0    590.1    0    590.1    0    589.83    5.3
    590.65    0    590.65    0    590.65    0    590.65    0    590.38    0
    591.21    0    591.21    0    591.21    0    591.21    0    590.93    0
    591.78    0    591.78    0    591.78    0    591.78    0    591.5    0
    592.33    0    592.33    0    592.33    0    592.33    0    592.06    0
    592.86    0    592.86    0    592.86    0    592.86    0    592.6    0
    593.4    0    593.4    0    593.4    0    593.4    0    593.13    0
    593.95    0    593.95    0    593.95    0    593.95    0    593.67    0
    594.49    0    594.49    0    594.49    0    594.49    0    594.22    0
    595.04    0    595.04    0    595.04    0    595.04    0    594.76    0
    595.6    0    595.6    0    595.6    0    595.6    0    595.32    0
    596.15    0    596.15    0    596.15    0    596.15    0    595.87    0
    596.72    0    596.72    0    596.72    0    596.72    0    596.43    0
    597.25    0    597.25    0    597.25    0    597.25    0    596.99    0
    597.78    0    597.78    0    597.78    0    597.78    0    597.52    0
    598.32    0    598.32    0    598.32    0    598.32    0    598.05    0
    598.87    0    598.87    0    598.87    0    598.87    0    598.59    0
    599.43    0    599.43    0    599.43    0    599.43    0    599.15    0
    599.95    0    599.95    0    599.95    0    599.95    0    599.69    0
    600.51    0    600.51    0    600.51    0    600.51    0    600.23    0
    601.06    0    601.06    0    601.06    0    601.06    0    600.78    0
    601.61    0    601.61    0    601.61    0    601.61    0    601.34    0
    602.19    0    602.19    0    602.19    0    602.19    0    601.91    0
    602.71    0    602.71    0    602.71    0    602.71    0    602.45    0
    603.26    0    603.26    0    603.26    0    603.26    0    602.98    0
    603.79    0    603.79    0    603.79    0    603.79    0    603.53    0
    604.33    0    604.33    0    604.33    0    604.33    0    604.06    0
    604.88    0    604.88    0    604.88    0    604.88    0    604.61    0
    605.44    0    605.44    0    605.44    0    605.44    0    605.16    0
    606.01    0    606.01    0    606.01    0    606.01    0    605.72    0
    606.56    0    606.56    0    606.56    0    606.56    0    606.28    0
    607.1    0    607.1    0    607.1    0    607.1    0    606.82    0
    607.64    0    607.64    0    607.64    0    607.64    0    607.37    0
    608.22    0    608.22    0    608.22    0    608.22    0    607.93    0
    608.77    0    608.77    0    608.77    0    608.77    0    608.49    0
    609.34    0    609.34    0    609.34    0    609.34    0    609.06    0
    609.9    0    609.9    0    609.9    0    609.9    0    609.61    0
    610.46    0    610.46    0    610.46    0    610.46    0    610.18    0
    611    0    611    0    611    0    611    0    610.72    0
    611.55    0    611.55    0    611.55    0    611.55    0    611.27    0
    612.1    0    612.1    0    612.1    0    612.1    0    611.83    0
    612.66    0    612.66    0    612.66    0    612.66    0    612.38    0
    613.22    0    613.22    0    613.22    0    613.22    0    612.94    0
    613.77    0    613.77    0    613.77    0    613.77    0    613.49    0
    614.34    0    614.34    0    614.34    0    614.34    0    614.06    0
    614.9    0    614.9    0    614.9    0    614.9    0    614.62    0
    615.48    0    615.48    0    615.48    0    615.48    0    615.18    0
    616.01    0    616.01    0    616.01    0    616.01    0    615.75    0
    616.55    0    616.55    0    616.55    0    616.55    0    616.28    0
    617.1    0    617.1    0    617.1    0    617.1    0    616.82    0
    617.66    0    617.66    0    617.66    0    617.66    0    617.39    0
    618.21    0    618.21    0    618.21    0    618.21    0    617.93    0
    618.77    0.8    618.77    0    618.77    1.5    618.77    0.8    618.49    5.3
    619.32    0.8    619.32    0    619.32    1.5    619.32    0.8    619.04    5.3
    619.86    0.8    619.86    0    619.86    0.8    619.86    0.8    619.59    5.3
    620.39    0.8    620.39    0    620.39    0.8    620.39    0.8    620.12    4.5
    620.92    0.8    620.92    0    620.92    0.8    620.92    0.8    620.66    4.5
    621.46    0.8    621.46    0    621.46    0.8    621.46    0.8    621.19    4.5
    622.02    0    622.02    0    622.02    0.8    622.02    0.8    621.75    4.5
    622.57    0    622.57    0    622.57    0.8    622.57    0    622.3    4.5
    623.12    0    623.12    0    623.12    0    623.12    0    622.85    4.5
    623.68    0    623.68    0    623.68    0    623.68    0    623.4    3.8
    624.25    0    624.25    0    624.25    0    624.25    0    623.96    3
    624.81    0    624.81    0    624.81    0    624.81    0    624.53    4.5
    625.35    0    625.35    0    625.35    0    625.35    0    625.08    4.5
    625.88    0    625.88    0    625.88    0    625.88    0    625.61    4.5
    626.43    0    626.43    0    626.43    0    626.43    0    626.15    4.5
    626.96    0    626.96    0    626.96    0    626.96    0    626.69    4.5
    627.49    0    627.49    0    627.49    0    627.49    0    627.22    3.8
    628.04    0    628.04    0    628.04    0    628.04    0    627.76    3.8
    628.59    0    628.59    0    628.59    0    628.59    0    628.33    3.8
    629.15    0    629.15    0    629.15    0    629.15    0    628.87    3.8
    629.72    0    629.72    0    629.72    0    629.72    2.3    629.44    3.8
    630.27    0    630.27    4.5    630.27    2.3    630.27    2.3    630    5.3
    630.81    0    630.81    4.5    630.81    2.3    630.81    2.3    630.54    5.3
    631.35    0    631.35    4.5    631.35    2.3    631.35    2.3    631.07    5.3
    631.91    0    631.91    4.5    631.91    2.3    631.91    2.3    631.63    5.3
    632.49    0    632.49    4.5    632.49    2.3    632.49    2.3    632.19    5.3
    633.03    0    633.03    4.5    633.03    2.3    633.03    2.3    632.75    5.3
    633.56    0    633.56    4.5    633.56    4.5    633.56    4.5    633.29    4.5
    634.11    0    634.11    4.5    634.11    4.5    634.11    4.5    633.83    6.8
    634.66    0    634.66    3.8    634.66    4.5    634.66    4.5    634.38    6.8
    635.22    0    635.22    3.8    635.22    4.5    635.22    4.5    634.95    6.8
    635.76    2.3    635.76    3.8    635.76    4.5    635.76    4.5    635.49    6.8
    636.3    2.3    636.3    3.8    636.3    4.5    636.3    4.5    636.03    6.8
    636.86    2.3    636.86    3.8    636.86    3.8    636.86    3.8    636.58    6
    637.39    2.3    637.39    3    637.39    3.8    637.39    3.8    637.12    6
    637.94    2.3    637.94    3    637.94    3.8    637.94    3.8    637.66    6
    638.49    1.5    638.49    3    638.49    3.8    638.49    3.8    638.23    6
    639.05    1.5    639.05    3    639.05    3.8    639.05    3.8    638.77    6
    639.62    1.5    639.62    3    639.62    3    639.62    3    639.34    5.3
    640.17    0    640.17    0    640.17    0    640.17    0    639.9    5.3
    640.71    0    640.71    0    640.71    0    640.71    0    640.44    0
    641.27    0    641.27    0    641.27    0    641.27    0    641    0
    641.83    0    641.83    0    641.83    0    641.83    0    641.55    0
    642.38    1.5    642.38    2.3    642.38    3    642.38    3    642.1    0
    642.94    1.5    642.94    1.5    642.94    3    642.94    3    642.66    5.3
    643.5    0    643.5    0    643.5    0    643.5    0    643.21    0
    644.06    0    644.06    0    644.06    0    644.06    0    643.78    0
    644.59    0    644.59    0    644.59    0    644.59    0    644.32    0
    645.13    0    645.13    0    645.13    0    645.13    0    644.86    0
    645.69    1.5    645.69    1.5    645.69    3    645.69    3    645.41    0
    646.24    1.5    646.24    1.5    646.24    3    646.24    3    645.96    5.3
    646.8    0.8    646.8    1.5    646.8    3    646.8    3    646.52    5.3
    647.35    0    647.35    0    647.35    0    647.35    0    647.07    0
    647.92    0    647.92    0    647.92    0    647.92    0    647.63    0
    648.47    2.3    648.47    0.8    648.47    3    648.47    3    648.2    5.3
    649.02    2.3    649.02    0    649.02    3    649.02    3    648.75    5.3
    649.55    2.3    649.55    0    649.55    2.3    649.55    2.3    649.28    4.5
    650.1    2.3    650.1    0    650.1    1.5    650.1    1.5    649.82    4.5
    650.65    2.3    650.65    0    650.65    0.8    650.65    0.8    650.38    4.5
    651.21    1.5    651.21    0    651.21    0    651.21    0    650.93    4.5
    651.76    0.8    651.76    0    651.76    0    651.76    2.3    651.48    4.5
    652.32    0    652.32    0    652.32    0    652.32    2.3    652.04    3.8
    652.87    0    652.87    0    652.87    0    652.87    2.3    652.6    3
    653.43    0    653.43    0    653.43    0    653.43    2.3    653.15    2.3
    654    0    654    0    654    0    654    2.3    653.72    4.5
    654.53    0    654.53    0    654.53    0    654.53    2.3    654.27    4.5
    655.08    0    655.08    0    655.08    0    655.08    0    654.8    0
    655.61    0    655.61    0    655.61    0    655.61    0    655.35    0
    656.14    0    656.14    0    656.14    0    656.14    0    655.88    0
    656.7    0    656.7    0    656.7    0    656.7    0    656.42    0
    657.24    0    657.24    0    657.24    0    657.24    0    656.97    0
    657.79    0    657.79    0    657.79    0    657.79    0    657.51    0
    658.34    0    658.34    0    658.34    0    658.34    0    658.07    0
    658.89    0    658.89    0    658.89    0    658.89    0    658.62    0
    659.44    0    659.44    0    659.44    0    659.44    0    659.17    0
    660.01    0    660.01    0    660.01    0    660.01    0    659.72    0
    660.57    0    660.57    0    660.57    0    660.57    0    660.29    0
    661.13    0    661.13    0    661.13    0    661.13    1.5    660.85    4.5
    661.66    0    661.66    0    661.66    0    661.66    0.8    661.4    4.5
    662.23    0    662.23    0    662.23    0    662.23    0    661.95    4.5
    662.78    0    662.78    0    662.78    0    662.78    0    662.51    4.5
    663.33    0    663.33    0    663.33    0    663.33    0    663.05    3
    663.88    0    663.88    0    663.88    0    663.88    2.3    663.61    2.3
    664.42    2.3    664.42    2.3    664.42    2.3    664.42    2.3    664.15    4.5
    664.95    2.3    664.95    2.3    664.95    2.3    664.95    4.5    664.68    6.8
    665.51    2.3    665.51    2.3    665.51    2.3    665.51    4.5    665.22    6.8
    666.05    2.3    666.05    2.3    666.05    2.3    666.05    4.5    665.78    6.8
    666.6    2.3    666.6    2.3    666.6    2.3    666.6    4.5    666.33    6.8
    667.17    1.5    667.17    1.5    667.17    1.5    667.17    4.5    666.88    6.8
    667.71    1.5    667.71    1.5    667.71    1.5    667.71    4.5    667.45    6.8
    668.26    1.5    668.26    1.5    668.26    1.5    668.26    3.8    667.98    6
    668.8    1.5    668.8    1.5    668.8    1.5    668.8    3.8    668.52    6
    669.35    1.5    669.35    1.5    669.35    1.5    669.35    3.8    669.07    6
    669.92    0.8    669.92    1.5    669.92    0.8    669.92    3.8    669.63    6
    670.47    0.8    670.47    0.8    670.47    3    670.47    3.8    670.2    6
    671.02    0.8    671.02    2.3    671.02    3    671.02    3    670.76    5.3
    671.58    0.8    671.58    2.3    671.58    3    671.58    3    671.3    5.3
    672.13    3.8    672.13    2.3    672.13    3    672.13    3    671.85    5.3
    672.7    0    672.7    0    672.7    0    672.7    0    672.41    0
    673.25    0    673.25    0    673.25    0    673.25    0    672.98    0
    673.8    0    673.8    0    673.8    0    673.8    0    673.52    0
    674.33    3.8    674.33    1.5    674.33    3    674.33    3    674.06    0
    674.86    0    674.86    0    674.86    0    674.86    0    674.59    5.3
    675.41    0    675.41    0    675.41    0    675.41    0    675.13    0
    675.96    0    675.96    0    675.96    0    675.96    0    675.68    0
    676.53    0    676.53    0    676.53    0    676.53    0    676.24    0
    677.09    3.8    677.09    1.5    677.09    2.3    677.09    3    676.81    0
    677.62    3.8    677.62    1.5    677.62    1.5    677.62    3    677.36    4.5
    678.16    3.8    678.16    0.8    678.16    0.8    678.16    2.3    677.89    3.8
    678.71    3.8    678.71    0    678.71    0    678.71    1.5    678.43    3
    679.26    3.8    679.26    2.3    679.26    0    679.26    3    678.99    4.5
    679.83    3.8    679.83    2.3    679.83    2.3    679.83    3    679.54    4.5
    680.37    3.8    680.37    2.3    680.37    2.3    680.37    3    680.11    4.5
    680.91    3.8    680.91    2.3    680.91    2.3    680.91    3    680.64    4.5
    681.46    3    681.46    1.5    681.46    2.3    681.46    2.3    681.18    4.5
    682.01    3    682.01    1.5    682.01    1.5    682.01    2.3    681.74    3.8
    682.58    0    682.58    0    682.58    0.8    682.58    0    682.29    3
    683.13    0    683.13    0    683.13    0    683.13    0    682.86    0
    683.66    0    683.66    0    683.66    0    683.66    0    683.39    0
    684.21    0    684.21    0    684.21    0    684.21    0    683.93    0
    684.78    0    684.78    0    684.78    0    684.78    0    684.5    0
    685.34    0    685.34    0    685.34    0    685.34    0    685.06    0
    685.91    0    685.91    0    685.91    0    685.91    0    685.62    0
    686.45    0    686.45    0    686.45    0    686.45    0    686.18    0
    687.01    0    687.01    0    687.01    0    687.01    0    686.72    0
    687.58    3    687.58    0.8    687.58    0.8    687.58    1.5    687.29    0
    688.12    3    688.12    0.8    688.12    0.8    688.12    0.8    687.86    2.3
    688.68    3    688.68    0    688.68    0    688.68    0    688.39    1.5
    689.22    3    689.22    0    689.22    0    689.22    0    688.95    0.8
    689.79    3    689.79    0    689.79    0    689.79    2.3    689.52    0
    690.33    3    690.33    0    690.33    0    690.33    2.3    690.06    0
    690.89    2.3    690.89    0    690.89    0    690.89    2.3    690.62    2.3
    691.44    2.3    691.44    0    691.44    4.5    691.44    2.3    691.16    2.3
    692.01    2.3    692.01    0    692.01    4.5    692.01    2.3    691.73    2.3
    692.55    2.3    692.55    0    692.55    4.5    692.55    2.3    692.28    2.3
    693.09    2.3    693.09    0    693.09    4.5    693.09    1.5    692.82    4.5
    693.62    1.5    693.62    0    693.62    4.5    693.62    1.5    693.35    4.5
    694.18    1.5    694.18    0    694.18    3.8    694.18    1.5    693.9    4.5
    694.74    1.5    694.74    0    694.74    3.8    694.74    1.5    694.46    4.5
    695.31    1.5    695.31    0    695.31    3.8    695.31    1.5    695.03    4.5
    695.85    1.5    695.85    0    695.85    3.8    695.85    0.8    695.59    3
    696.39    0.8    696.39    0    696.39    3.8    696.39    0    696.12    2.3
    696.94    0    696.94    0    696.94    3.8    696.94    2.3    696.66    1.5
    697.49    0    697.49    2.3    697.49    3    697.49    2.3    697.22    3.8
    698.04    0    698.04    2.3    698.04    3    698.04    2.3    697.78    3.8
    698.58    2.3    698.58    2.3    698.58    3    698.58    2.3    698.31    3.8
    699.11    0    699.11    2.3    699.11    3    699.11    2.3    698.84    3.8
    699.66    0    699.66    0    699.66    0    699.66    0    699.38    0
    700.23    0    700.23    0    700.23    0    700.23    0    699.94    0
    700.78    0    700.78    0    700.78    0    700.78    0    700.52    0
    701.33    0    701.33    0    701.33    0    701.33    0    701.05    0
    701.88    0    701.88    0    701.88    0    701.88    0    701.6    0
    702.45    0    702.45    0    702.45    0    702.45    0    702.16    0
    702.98    2.3    702.98    2.3    702.98    3    702.98    2.3    702.72    3.8
    703.52    2.3    703.52    2.3    703.52    3    703.52    1.5    703.25    3
    704.07    2.3    704.07    1.5    704.07    2.3    704.07    0.8    703.8    2.3
    704.64    2.3    704.64    0.8    704.64    0.8    704.64    0    704.35    1.5
    705.2    0    705.2    0    705.2    0    705.2    0    704.92    0
    705.76    0    705.76    0    705.76    0    705.76    0    705.48    0
    706.31    0    706.31    0    706.31    0    706.31    0    706.04    0
    706.85    2.3    706.85    0    706.85    0.8    706.85    0    706.58    0
    707.41    0.8    707.41    0    707.41    0    707.41    0    707.13    0.8
    707.96    0    707.96    0    707.96    0    707.96    0    707.68    4.5
    708.52    0    708.52    0    708.52    0    708.52    0    708.24    0
    709.07    0    709.07    0    709.07    0    709.07    0    708.79    0
    709.62    0    709.62    0    709.62    0    709.62    0    709.35    0
    710.18    0.8    710.18    0    710.18    0    710.18    0    709.9    4.5
    710.75    0.8    710.75    0    710.75    0    710.75    2.3    710.46    4.5
    711.31    0.8    711.31    0    711.31    0    711.31    2.3    711.03    6
    711.86    0.8    711.86    0    711.86    0    711.86    2.3    711.59    6
    712.4    0    712.4    0    712.4    0    712.4    2.3    712.13    6
    712.96    0    712.96    0    712.96    0    712.96    2.3    712.68    6
    713.51    0    713.51    0    713.51    0    713.51    1.5    713.23    6
    714.08    0    714.08    0    714.08    0    714.08    1.5    713.8    5.3
    714.62    0    714.62    0    714.62    0    714.62    0    714.35    0
    715.17    0    715.17    0    715.17    0    715.17    0    714.9    0
    715.73    0    715.73    0    715.73    0    715.73    0    715.45    0
    716.29    0    716.29    0    716.29    0    716.29    0    716.02    0
    716.82    0    716.82    0    716.82    0    716.82    0    716.56    0
    717.36    0    717.36    0    717.36    0    717.36    1.5    717.09    0
    717.92    0    717.92    0    717.92    0    717.92    1.5    717.65    5.3
    718.47    0    718.47    0    718.47    2.3    718.47    1.5    718.2    5.3
    719.03    0    719.03    0    719.03    2.3    719.03    1.5    718.76    5.3
    719.58    2.3    719.58    0    719.58    4.5    719.58    3    719.3    6
    720.13    2.3    720.13    2.3    720.13    4.5    720.13    3    719.86    6
    720.67    2.3    720.67    2.3    720.67    4.5    720.67    3    720.4    6
    721.2    2.3    721.2    2.3    721.2    4.5    721.2    3    720.93    6
    721.76    2.3    721.76    2.3    721.76    4.5    721.76    3    721.47    6
    722.3    1.5    722.3    2.3    722.3    3.8    722.3    2.3    722.03    5.3
    722.86    1.5    722.86    1.5    722.86    3.8    722.86    2.3    722.59    5.3
    723.43    1.5    723.43    1.5    723.43    3.8    723.43    2.3    723.15    5.3
    723.99    1.5    723.99    1.5    723.99    3.8    723.99    2.3    723.71    5.3
    724.55    1.5    724.55    1.5    724.55    3.8    724.55    2.3    724.28    5.3
    725.1    1.5    725.1    1.5    725.1    3    725.1    1.5    724.83    5.3
    725.64    0.8    725.64    1.5    725.64    3    725.64    1.5    725.37    4.5
    726.19    0.8    726.19    0.8    726.19    3    726.19    1.5    725.91    4.5
    726.77    0.8    726.77    0.8    726.77    3    726.77    1.5    726.48    4.5
    727.32    0.8    727.32    0.8    727.32    3    727.32    1.5    727.05    4.5
    727.86    0.8    727.86    0.8    727.86    2.3    727.86    1.5    727.59    4.5
    728.41    0    728.41    0.8    728.41    2.3    728.41    0.8    728.13    3.8
    728.98    0    728.98    0    728.98    0    728.98    0    728.7    3.8
    729.52    0    729.52    0    729.52    0    729.52    0    729.25    0
    730.08    0    730.08    0    730.08    0    730.08    0    729.81    0
    730.63    0    730.63    0    730.63    0    730.63    0    730.35    0
    731.18    0    731.18    0    731.18    0    731.18    0    730.91    0
    731.74    0    731.74    0    731.74    2.3    731.74    0.8    731.46    0
    732.31    0    732.31    0    732.31    2.3    732.31    0.8    732.03    3.8
    732.87    0    732.87    0    732.87    2.3    732.87    0.8    732.59    3.8
    733.42    2.3    733.42    0    733.42    2.3    733.42    3    733.15    5.3
    733.96    2.3    733.96    0    733.96    4.5    733.96    3    733.69    5.3
    734.53    2.3    734.53    0    734.53    4.5    734.53    5.3    734.24    5.3
    735.09    2.3    735.09    0    735.09    4.5    735.09    5.3    734.81    5.3
    735.63    2.3    735.63    0    735.63    4.5    735.63    5.3    735.36    5.3
    736.16    2.3    736.16    0    736.16    4.5    736.16    5.3    735.89    4.5
    736.69    1.5    736.69    0    736.69    4.5    736.69    5.3    736.42    4.5
    737.22    0.8    737.22    2.3    737.22    3.8    737.22    4.5    736.95    4.5
    737.75    0    737.75    2.3    737.75    3    737.75    4.5    737.48    4.5
    738.29    2.3    738.29    2.3    738.29    3    738.29    4.5    738.02    4.5
    738.85    2.3    738.85    2.3    738.85    3    738.85    4.5    738.57    3.8
    739.4    2.3    739.4    2.3    739.4    3    739.4    4.5    739.12    3.8
    739.97    2.3    739.97    1.5    739.97    3    739.97    4.5    739.68    3.8
    740.52    0    740.52    0    740.52    0    740.52    0    740.25    0
    741.05    0    741.05    0    741.05    0    741.05    0    740.78    0
    741.58    0    741.58    0    741.58    0    741.58    0    741.31    0
    742.12    0    742.12    0    742.12    0    742.12    0    741.85    0
    742.68    0    742.68    0    742.68    0    742.68    0    742.4    0
    743.23    0    743.23    0    743.23    0    743.23    0    742.95    0
    743.8    0    743.8    0    743.8    0    743.8    0    743.51    0
    744.32    0    744.32    0    744.32    0    744.32    0    744.06    0
    744.86    0    744.86    0    744.86    0    744.86    0    744.59    0
    745.42    0    745.42    0    745.42    0    745.42    0    745.15    0
    745.98    0    745.98    0    745.98    0    745.98    0    745.7    0
    746.55    0    746.55    0    746.55    0    746.55    0    746.25    0
    747.1    0    747.1    0    747.1    0    747.1    0    746.82    0
    747.62    0    747.62    0    747.62    0    747.62    0    747.35    0
    748.16    2.3    748.16    1.5    748.16    2.3    748.16    3.8    747.89    3.8
    748.73    2.3    748.73    1.5    748.73    2.3    748.73    3.8    748.44    3.8
    749.26    2.3    749.26    0.8    749.26    4.5    749.26    3    749    3.8
    749.81    1.5    749.81    0.8    749.81    4.5    749.81    3    749.53    3.8
    750.36    1.5    750.36    0.8    750.36    4.5    750.36    3    750.09    3
    750.91    1.5    750.91    0.8    750.91    4.5    750.91    3    750.64    3
    751.48    1.5    751.48    0.8    751.48    4.5    751.48    3    751.19    3
    752.04    1.5    752.04    1.5    752.04    3.8    752.04    2.3    751.76    3
    752.58    1.5    752.58    1.5    752.58    3.8    752.58    2.3    752.32    3.8
    753.13    3    753.13    4.5    753.13    3.8    753.13    2.3    752.86    3
    753.69    0    753.69    0    753.69    0    753.69    0    753.41    3
    754.24    0    754.24    0    754.24    0    754.24    0    753.97    0
    754.79    0    754.79    0    754.79    0    754.79    0    754.52    0
    755.33    3    755.33    4.5    755.33    3.8    755.33    2.3    755.07    3
    755.87    0    755.87    0    755.87    0    755.87    0    755.6    0
    756.41    0    756.41    0    756.41    0    756.41    0    756.14    0
    756.96    0    756.96    0    756.96    0    756.96    0    756.69    0
    757.52    0    757.52    0    757.52    0    757.52    0    757.25    0
    758.09    0    758.09    0    758.09    0    758.09    0    757.8    0
    758.63    0    758.63    0    758.63    0    758.63    0    758.35    0
    759.18    0    759.18    0    759.18    0    759.18    0    758.91    0
    759.74    0    759.74    0    759.74    0    759.74    0    759.46    0
    760.31    0    760.31    0    760.31    0    760.31    0    760.03    0
    760.85    0    760.85    0    760.85    0    760.85    0    760.59    0
    761.41    0    761.41    0    761.41    0    761.41    0    761.13    0
    761.98    0    761.98    0    761.98    0    761.98    0    761.7    0
    762.55    0    762.55    0    762.55    0    762.55    0    762.26    0
    763.08    0    763.08    0    763.08    0    763.08    0    762.81    0
    763.63    0    763.63    0    763.63    0    763.63    0    763.35    0
    764.18    0    764.18    0    764.18    0    764.18    0    763.91    0
    764.75    0    764.75    0    764.75    0    764.75    0    764.46    0
    765.31    0    765.31    0    765.31    0    765.31    0    765.03    0
    765.87    0    765.87    0    765.87    0    765.87    0    765.59    0
    766.43    0    766.43    0    766.43    0    766.43    0    766.15    0
    766.99    0    766.99    0    766.99    0    766.99    0    766.71    0
    767.54    0    767.54    0    767.54    0    767.54    0    767.27    0
    768.11    0    768.11    0    768.11    0    768.11    0    767.82    0
    768.66    0    768.66    0    768.66    0    768.66    0    768.39    0
    769.19    0    769.19    0    769.19    0    769.19    0    768.92    0
    769.74    0    769.74    0    769.74    0    769.74    0    769.46    0
    770.29    0    770.29    0    770.29    0    770.29    0    770.01    0
    770.84    0    770.84    0    770.84    0    770.84    0    770.57    0
    771.4    0    771.4    0    771.4    0    771.4    0    771.13    0
    771.97    0    771.97    0    771.97    0    771.97    0    771.69    0
    772.53    0    772.53    0    772.53    0    772.53    0    772.25    0
    773.08    0    773.08    0    773.08    0    773.08    0    772.81    0
    773.63    0    773.63    0    773.63    0    773.63    0    773.35    0
    774.16    0    774.16    0    774.16    0    774.16    0    773.89    0
    774.69    0    774.69    0    774.69    0    774.69    0    774.43    0
    775.26    0    775.26    0    775.26    0    775.26    0    774.98    0
    775.81    0    775.81    0    775.81    0    775.81    0    775.54    0
    776.37    0    776.37    0    776.37    0    776.37    0    776.08    0
    776.91    0    776.91    0    776.91    0    776.91    0    776.64    0
    777.48    0    777.48    0    777.48    0    777.48    0    777.19    0
    778.01    0    778.01    0    778.01    0    778.01    0    777.74    0
    778.56    0    778.56    0    778.56    0    778.56    0    778.29    0
    779.11    3    779.11    4.5    779.11    3.8    779.11    2.3    778.84    3
    779.65    0    779.65    0    779.65    0    779.65    0    779.39    0
    780.19    3    780.19    4.5    780.19    3.8    780.19    2.3    779.92    3
    780.76    3    780.76    4.5    780.76    3.8    780.76    2.3    780.47    3
    781.32    3    781.32    4.5    781.32    3.8    781.32    2.3    781.04    5.3
    781.87    0    781.87    0    781.87    0    781.87    0    781.61    5.3
    782.42    0    782.42    0    782.42    0    782.42    0    782.15    0
    782.97    0    782.97    0    782.97    0    782.97    0    782.69    0
    783.52    0    783.52    0    783.52    0    783.52    0    783.24    0
    784.09    0    784.09    0    784.09    0    784.09    0    783.8    0
    784.65    0    784.65    0    784.65    0    784.65    0    784.37    0
    785.21    0    785.21    0    785.21    0    785.21    0    784.93    0
    785.77    0    785.77    0    785.77    0    785.77    0    785.5    0
    786.34    0    786.34    0    786.34    0    786.34    0    786.05    0
    786.88    0    786.88    0    786.88    0    786.88    0    786.61    0
    787.44    0    787.44    0    787.44    0    787.44    0    787.16    0
    787.97    0    787.97    0    787.97    0    787.97    0    787.7    0
    788.52    0    788.52    0    788.52    0    788.52    0    788.24    0
    789.05    0    789.05    0    789.05    0    789.05    0    788.78    0
    789.6    0    789.6    0    789.6    0    789.6    0    789.33    0
    790.16    0    790.16    0    790.16    0    790.16    0    789.88    0
    790.73    0    790.73    0    790.73    0    790.73    0    790.45    0
    791.28    0    791.28    0    791.28    0    791.28    0    791.01    0
    791.81    0    791.81    0    791.81    0    791.81    0    791.55    0
    792.36    0    792.36    0    792.36    0    792.36    0    792.08    0
    792.91    0    792.91    0    792.91    0    792.91    0    792.63    0
    793.48    0    793.48    0    793.48    0    793.48    0    793.2    0
    794.03    0    794.03    0    794.03    0    794.03    0    793.75    0
    794.56    3    794.56    4.5    794.56    3.8    794.56    2.3    794.3    0
    795.1    3    795.1    4.5    795.1    3.8    795.1    2.3    794.83    5.3
    795.66    3    795.66    4.5    795.66    3    795.66    1.5    795.38    5.3
    796.21    3    796.21    4.5    796.21    2.3    796.21    0.8    795.93    5.3
    796.78    3    796.78    4.5    796.78    1.5    796.78    0    796.5    5.3
    797.33    3    797.33    4.5    797.33    1.5    797.33    0    797.06    4.5
    797.88    3    797.88    4.5    797.88    3.8    797.88    0    797.6    4.5
    798.43    3    798.43    4.5    798.43    3.8    798.43    0    798.15    4.5
    798.99    2.3    798.99    3.8    798.99    3.8    798.99    0    798.71    4.5
    799.55    2.3    799.55    3.8    799.55    3.8    799.55    0    799.26    4.5
    800.07    2.3    800.07    3.8    800.07    3.8    800.07    0    799.81    4.5
    800.62    2.3    800.62    3.8    800.62    3    800.62    0    800.35    4.5
    801.18    2.3    801.18    3.8    801.18    3    801.18    2.3    800.9    3.8
    801.72    2.3    801.72    3.8    801.72    3    801.72    2.3    801.46    3.8
    802.26    2.3    802.26    3    802.26    3    802.26    2.3    801.99    3.8
    802.83    1.5    802.83    3    802.83    3    802.83    2.3    802.54    3.8
    803.37    1.5    803.37    3    803.37    3    803.37    2.3    803.1    3.8
    803.91    1.5    803.91    3    803.91    2.3    803.91    1.5    803.64    3
    804.44    1.5    804.44    3    804.44    2.3    804.44    1.5    804.17    3
    805    0    805    0    805    0    805    0    804.72    0
    805.55    0    805.55    0    805.55    0    805.55    0    805.28    0
    806.12    0    806.12    0    806.12    0    806.12    0    805.85    0
    806.65    0    806.65    0    806.65    0    806.65    0    806.39    0
    807.19    0    807.19    0    807.19    0    807.19    0    806.92    0
    807.76    0    807.76    0    807.76    0    807.76    0    807.48    0
    808.3    0    808.3    0    808.3    0    808.3    0    808.03    0
    808.88    0    808.88    0    808.88    0    808.88    0    808.58    0
    809.43    0    809.43    0    809.43    0    809.43    0    809.15    0
    809.99    0    809.99    0    809.99    0    809.99    0    809.71    0
    810.53    0    810.53    0    810.53    0    810.53    0    810.26    0
    811.08    0    811.08    0    811.08    0    811.08    0    810.8    0
    811.62    0    811.62    0    811.62    0    811.62    0    811.34    0
    812.15    0    812.15    0    812.15    0    812.15    0    811.88    0
    812.69    0    812.69    0    812.69    0    812.69    0    812.42    0
    813.24    0    813.24    0    813.24    0    813.24    0    812.97    0
    813.8    0    813.8    0    813.8    0    813.8    0    813.52    0
    814.38    0    814.38    0    814.38    0    814.38    0    814.09    0
    814.92    0    814.92    0    814.92    0    814.92    0    814.65    0
    815.47    0    815.47    0    815.47    0    815.47    0    815.19    0
    816.04    0    816.04    0    816.04    0    816.04    0    815.76    0
    816.6    0    816.6    0    816.6    0    816.6    0    816.32    0
    817.16    0    817.16    0    817.16    0    817.16    0    816.89    0
    817.7    0    817.7    0    817.7    0    817.7    0    817.43    0
    818.24    0    818.24    0    818.24    0    818.24    0    817.97    0
    818.81    0    818.81    0    818.81    0    818.81    0    818.52    0
    819.37    0    819.37    0    819.37    0    819.37    0    819.09    0
    819.91    0    819.91    0    819.91    0    819.91    0    819.64    0
    820.44    0    820.44    0    820.44    0    820.44    0    820.17    0
    820.97    0    820.97    0    820.97    0    820.97    0    820.7    0
    821.52    0    821.52    0    821.52    0    821.52    0    821.24    0
    822.07    0    822.07    0    822.07    0    822.07    0    821.8    0
    822.64    0    822.64    0    822.64    0    822.64    0    822.35    0
    823.18    0    823.18    0    823.18    0    823.18    0    822.91    0
    823.72    0    823.72    0    823.72    0    823.72    0    823.46    0
    824.27    0    824.27    0    824.27    0    824.27    0    823.99    0
    824.84    0    824.84    0    824.84    0    824.84    0    824.56    0
    825.4    0    825.4    0    825.4    0    825.4    0    825.12    0
    825.97    0    825.97    0    825.97    0    825.97    0    825.69    0
    826.5    0    826.5    0    826.5    0    826.5    0    826.23    0
    827.04    0    827.04    0    827.04    0    827.04    0    826.77    0
    827.59    0    827.59    0    827.59    0    827.59    0    827.32    0
    828.15    0    828.15    0    828.15    0    828.15    0    827.87    0
    828.71    0    828.71    0    828.71    0    828.71    0    828.44    0
    829.26    0    829.26    0    829.26    0    829.26    0    828.99    0
    829.82    0    829.82    0    829.82    0    829.82    0    829.54    0
    830.36    0    830.36    0    830.36    0    830.36    0    830.09    0
    830.89    0    830.89    0    830.89    0    830.89    0    830.63    0
    831.45    0    831.45    0    831.45    0    831.45    0    831.17    0
    832    0    832    0    832    0    832    0    831.72    0
    832.54    0    832.54    0    832.54    0    832.54    0    832.26    0
    833.09    0    833.09    0    833.09    0    833.09    0    832.82    0
    833.65    0    833.65    0    833.65    0    833.65    0    833.37    0
    834.22    0    834.22    0    834.22    0    834.22    0    833.94    0
    834.77    0    834.77    0    834.77    0    834.77    0    834.49    0
    835.32    0    835.32    0    835.32    0    835.32    0    835.05    0
    835.86    0    835.86    0    835.86    0    835.86    0    835.59    0
    836.4    0    836.4    0    836.4    0    836.4    0    836.14    0
    836.94    0    836.94    0    836.94    0    836.94    0    836.67    0
    837.49    0    837.49    0    837.49    0    837.49    0    837.22    0
    838.05    0    838.05    0    838.05    0    838.05    0    837.77    0
    838.61    0    838.61    0    838.61    0    838.61    0    838.34    0
    839.16    0    839.16    0    839.16    0    839.16    0    838.88    0
    839.73    0    839.73    0    839.73    0    839.73    0    839.44    0
    840.29    0    840.29    0    840.29    0    840.29    0    840.01    0
    840.82    0    840.82    0    840.82    0    840.82    0    840.56    0
    841.37    0    841.37    0    841.37    0    841.37    0    841.09    0
    841.91    0    841.91    0    841.91    0    841.91    0    841.63    0
    842.47    0    842.47    0    842.47    0    842.47    0    842.19    0
    843.02    0    843.02    0    843.02    0    843.02    0    842.75    0
    843.59    0    843.59    0    843.59    0    843.59    0    843.31    0
    844.15    0    844.15    0    844.15    0    844.15    0    843.88    0
    844.68    0    844.68    0    844.68    0    844.68    0    844.42    0
    845.22    0    845.22    0    845.22    0    845.22    0    844.95    0
    845.76    0    845.76    0    845.76    0    845.76    0    845.48    0
    846.32    0    846.32    0    846.32    0    846.32    0    846.04    0
    846.87    0    846.87    0    846.87    0    846.87    0    846.6    0
    847.41    0    847.41    0    847.41    0    847.41    0    847.13    0
    847.96    0    847.96    0    847.96    0    847.96    0    847.69    0
    848.52    0    848.52    0    848.52    0    848.52    0    848.24    0
    849.08    0    849.08    0    849.08    0    849.08    0    848.81    0
    849.61    0    849.61    0    849.61    0    849.61    0    849.34    0
    850.15    0    850.15    0    850.15    0    850.15    0    849.88    0
    850.71    0    850.71    0    850.71    0    850.71    0    850.43    0
    851.28    0    851.28    0    851.28    0    851.28    0    850.99    0
    851.84    0    851.84    0    851.84    0    851.84    0    851.56    0
    852.4    0    852.4    0    852.4    0    852.4    0    852.12    0
    852.94    0    852.94    0    852.94    0    852.94    0    852.67    0
    853.47    0    853.47    0    853.47    0    853.47    0    853.2    0
    854.03    0    854.03    0    854.03    0    854.03    0    853.74    0
    854.58    0    854.58    0    854.58    0    854.58    0    854.31    0
    855.11    0    855.11    0    855.11    0    855.11    0    854.84    0
    855.65    0    855.65    0    855.65    0    855.65    0    855.38    0
    856.21    0    856.21    0    856.21    0    856.21    0    855.93    0
    856.76    0    856.76    0    856.76    0    856.76    0    856.49    0
    857.33    0    857.33    0    857.33    0    857.33    0    857.04    0
    857.89    0    857.89    0    857.89    0    857.89    0    857.61    0
    858.45    0    858.45    0    858.45    0    858.45    0    858.17    0
    859.01    0    859.01    0    859.01    0    859.01    0    858.73    0
    859.57    0    859.57    0    859.57    0    859.57    0    859.3    0
    860.11    0    860.11    0    860.11    0    860.11    0    859.85    0
    860.64    1.5    860.64    3    860.64    2.3    860.64    1.5    860.38    3
    861.18    1.5    861.18    3    861.18    2.3    861.18    2.3    860.92    3
    861.73    1.5    861.73    3    861.73    2.3    861.73    2.3    861.46    5.3
    862.3    1.5    862.3    2.3    862.3    2.3    862.3    2.3    862.01    5.3
    862.86    1.5    862.86    2.3    862.86    2.3    862.86    2.3    862.57    5.3
    863.41    1.5    863.41    2.3    863.41    2.3    863.41    2.3    863.14    5.3
    863.98    0.8    863.98    2.3    863.99    1.5    863.99    1.5    863.71    4.5
    864.51    0    864.51    2.3    864.51    0.8    864.51    0.8    864.24    3.8
    865.04    0    865.04    2.3    865.04    0    865.04    0    864.78    3
    865.58    0    865.58    2.3    865.58    0    865.58    0    865.31    2.3
    866.15    0    866.15    2.3    866.15    0    866.15    0    865.87    2.3
    866.68    0    866.68    1.5    866.68    0    866.68    0    866.42    1.5
    867.21    0    867.21    0.8    867.21    0    867.21    0    866.95    3.8
    867.75    0    867.75    0    867.75    0    867.75    0    867.48    3.8
    868.3    0    868.3    0    868.3    0    868.3    0    868.02    3.8
    868.87    0    868.87    0    868.87    0    868.87    0    868.59    3.8
    869.42    0    869.42    0    869.42    0    869.42    0    869.15    3.8
    869.98    0    869.98    0    869.98    0    869.98    0    869.69    3.8
    870.51    0    870.51    0    870.51    0    870.51    0    870.25    3
    871.05    0    871.05    0    871.05    0    871.05    0    870.78    2.3
    871.61    0    871.61    0    871.61    0    871.61    0    871.33    4.5
    872.16    0    872.16    0    872.16    0    872.16    0    871.89    4.5
    872.73    0    872.73    0    872.73    0    872.73    0    872.44    0
    873.28    0    873.28    0    873.28    0    873.28    0    873.01    0
    873.83    0    873.83    0    873.83    0    873.83    0    873.55    0
    874.38    0    874.38    0    874.38    0    874.38    0    874.11    0
    874.95    0    874.95    0    874.95    0    874.95    0    874.66    0
    875.5    0    875.5    0    875.5    0    875.5    0    875.23    0
    876.05    0    876.05    0    876.05    0    876.05    0    875.77    0
    876.58    0    876.58    0    876.58    0    876.58    0    876.31    0
    877.14    0    877.14    0    877.14    0    877.14    0    876.85    0
    877.69    0    877.69    0    877.69    0    877.69    0    877.42    0
    878.22    0    878.22    0    878.22    0    878.22    0    877.95    0
    878.75    0    878.75    0    878.75    0    878.75    0    878.48    0
    879.29    0    879.29    0    879.29    0    879.29    0    879.02    0
    879.85    0    879.85    0    879.85    0    879.85    0    879.57    0
    880.42    0    880.42    0    880.42    0    880.42    0    880.14    0
    880.98    0    880.98    0    880.98    0    880.98    0    880.7    0
    881.54    0    881.54    0    881.54    0    881.54    0    881.26    0
    882.11    0    882.11    0    882.11    0    882.11    0    881.83    0
    882.67    0    882.67    0    882.67    0    882.67    0    882.39    0
    883.2    0    883.2    0    883.2    0    883.2    0    882.94    0
    883.74    0    883.74    0    883.74    0    883.74    0    883.47    0
    884.29    0    884.29    0    884.29    0    884.29    0    884.01    0
    884.85    0    884.85    0    884.85    0    884.85    0    884.57    0
    885.42    0    885.42    0    885.42    0    885.42    0    885.14    0
    885.96    0    885.96    0    885.96    0    885.96    0    885.69    0
    886.51    0    886.51    0    886.51    0    886.51    0    886.23    0
    887.08    0    887.08    0    887.08    0    887.08    0    886.79    4.5
    887.61    0    887.61    0    887.61    0    887.61    0    887.35    4.5
    888.15    0    888.15    0    888.15    0    888.15    0    887.88    4.5
    888.71    0    888.71    0    888.71    0    888.71    0    888.43    4.5
    889.25    0    889.25    0    889.25    0    889.25    0    888.99    4.5
    889.78    0    889.78    0    889.78    0    889.78    0    889.52    4.5
    890.33    0    890.33    0    890.33    0    890.33    0    890.06    3.8
    890.91    0    890.91    0    890.91    0    890.91    0    890.61    3
    891.47    0    891.47    0    891.47    0    891.47    0    891.19    2.3
    892.02    0    892.02    0    892.02    0    892.02    0    891.75    3.8
    892.58    0    892.58    0    892.58    0    892.58    0    892.31    3.8
    893.14    0    893.14    0    893.14    0    893.14    0    892.87    3.8
    893.68    0    893.68    0    893.69    0    893.69    0    893.42    3.8
    894.22    0    894.22    0    894.22    0    894.22    0    893.95    3.8
    894.78    0    894.78    0    894.78    0    894.78    2.3    894.5    3.8
    895.33    0    895.33    0    895.33    0    895.33    2.3    895.05    3.8
    895.9    0    895.9    0    895.9    0    895.9    2.3    895.63    5.3
    896.46    0    896.46    0    896.46    0    896.46    2.3    896.18    5.3
    897.01    0    897.01    0    897.01    0    897.01    2.3    896.74    5.3
    897.54    0    897.54    0    897.54    0    897.54    1.5    897.28    5.3
    898.08    0    898.08    0    898.08    0    898.08    1.5    897.81    5.3
    898.63    0    898.63    0    898.63    0    898.63    0    898.36    5.3
    899.17    0    899.17    0    899.17    0    899.17    0    898.9    0
    899.7    0    899.7    0    899.7    0    899.7    0    899.43    0
    900.23    0    900.23    0    900.23    0    900.23    0    899.96    0
    900.77    0    900.77    0    900.77    0    900.77    0    900.5    0
    901.33    0    901.33    0    901.33    0    901.33    0    901.05    0
    901.86    0    901.86    0    901.86    0    901.86    0    901.59    0
    902.42    0    902.42    0    902.42    0    902.42    0    902.14    0
    902.97    0    902.97    0    902.97    0    902.97    0    902.69    0
    903.52    0    903.52    0    903.52    0    903.52    0    903.24    0
    904.09    0    904.09    0    904.09    0    904.09    0    903.8    0
    904.65    0    904.65    0    904.65    0    904.65    0    904.37    0
    905.17    0    905.17    0    905.17    0    905.17    0    904.91    0
    905.71    0    905.71    0    905.71    0    905.71    0    905.44    0
    906.27    0    906.27    0    906.27    0    906.27    0    905.99    0
    906.82    0    906.82    0    906.82    0    906.82    0    906.55    0
    907.37    0    907.37    0    907.37    0    907.37    0    907.11    0
    907.91    0    907.91    0    907.91    0    907.91    0    907.64    0
    908.45    0    908.45    0    908.45    0    908.45    0    908.19    0
    908.99    0    908.99    0    908.99    0    908.99    0    908.72    0
    909.55    0    909.55    0    909.55    0    909.55    0    909.27    0
    910.1    0    910.1    0    910.1    0    910.1    0    909.83    0
    910.65    0    910.65    0    910.65    0    910.65    0    910.38    0
    911.21    0    911.21    0    911.21    0    911.21    0    910.93    0
    911.76    0    911.76    0    911.76    0    911.76    0    911.49    0
    912.32    0    912.32    0    912.32    0    912.32    0    912.04    0
    912.88    0    912.88    0    912.88    0    912.88    0    912.6    0
    913.43    0    913.43    0    913.43    0    913.43    0    913.15    0
    914    0    914    0    914    0    914    0    913.72    0
    914.54    0    914.54    0    914.54    0    914.54    0    914.27    0
    915.1    0    915.1    0    915.1    0    915.1    0    914.82    0
    915.65    0    915.65    0    915.65    0    915.65    0    915.37    0
    916.21    0    916.21    0    916.21    0    916.21    1.5    915.93    0
    916.76    0    916.76    0    916.76    0    916.76    1.5    916.48    5.3
    917.33    0    917.33    0    917.33    0    917.33    1.5    917.05    5.3
    917.86    0    917.86    0    917.86    0    917.86    1.5    917.6    5.3
    918.39    0    918.39    0    918.39    0    918.39    1.5    918.13    4.5
    918.94    0    918.94    0    918.94    0    918.94    1.5    918.66    3.8
    919.47    0    919.47    0    919.47    0    919.47    1.5    919.2    3
    920.01    0    920.01    0    920.01    0    920.01    1.5    919.74    2.3
    920.57    0    920.57    0    920.57    0    920.57    1.5    920.28    2.3
    921.11    0    921.11    0    921.11    0    921.11    1.5    920.83    2.3
    921.67    0    921.67    0    921.67    0    921.67    0.8    921.4    2.3
    922.23    0    922.23    0    922.23    0    922.23    0    921.95    2.3
    922.77    0    922.77    0    922.77    0    922.77    0    922.49    2.3
    923.29    0    923.29    0    923.29    0    923.29    0    923.03    1.5
    923.83    0    923.83    0    923.83    0    923.83    0    923.56    0.8
    924.39    0    924.39    0    924.39    0    924.39    0    924.11    0
    924.94    0    924.94    0    924.94    0    924.94    0    924.67    0
    925.51    0    925.51    0    925.51    0    925.51    0    925.22    0
    926.07    0    926.07    0    926.07    0    926.07    0    925.79    0
    926.62    0    926.62    0    926.62    0    926.62    0    926.35    0
    927.16    0    927.16    0    927.16    0    927.16    0    926.9    0
    927.72    0    927.72    0    927.72    0    927.72    0    927.44    0
    928.27    0    928.27    0    928.27    0    928.27    0    927.99    0
    928.81    0    928.81    0    928.81    0    928.81    0    928.54    0
    929.36    0    929.36    0    929.36    0    929.36    0    929.08    0
    929.92    2.3    929.92    0    929.92    2.3    929.92    2.3    929.63    0
    930.47    2.3    930.47    0    930.47    2.3    930.47    2.3    930.2    2.3
    931    2.3    931    0    931    2.3    931    2.3    930.73    2.3
    931.53    0    931.53    0    931.53    0    931.53    0    931.26    2.3
    932.08    0    932.08    0    932.08    0    932.08    0    931.8    0
    932.64    0    932.64    0    932.64    0    932.64    0    932.35    0
    933.19    0    933.19    0    933.19    0    933.19    0    932.92    0
    933.74    0    933.74    0    933.74    0    933.74    0    933.46    0
    934.3    0    934.3    0    934.3    0    934.3    0    934.02    0
    934.85    2.3    934.85    0    934.85    2.3    934.85    2.3    934.57    0
    935.42    0    935.42    0    935.42    0    935.42    0    935.15    2.3
    935.95    0    935.95    0    935.95    0    935.95    0    935.68    0
    936.48    0    936.48    0    936.48    0    936.48    0    936.22    0
    937.02    0    937.02    0    937.02    0    937.02    0    936.75    0
    937.57    0    937.57    0    937.57    0    937.57    0    937.3    0
    938.13    0    938.13    0    938.13    0    938.13    0    937.86    0
    938.67    0    938.67    0    938.67    0    938.67    0    938.39    0
    939.21    0    939.21    0    939.21    0    939.21    0    938.94    0
    939.77    0    939.77    0    939.77    0    939.77    0    939.49    0
    940.32    0    940.32    0    940.32    0    940.32    0    940.04    0
    940.88    0    940.88    0    940.88    0    940.88    0    940.6    0
    941.44    0    941.44    0    941.44    0    941.44    0    941.15    0
    942    0    942    0    942    0    942    0    941.72    0
    942.56    0    942.56    0    942.56    0    942.56    0    942.28    0
    943.12    0    943.12    0    943.12    0    943.12    0    942.84    0
    943.68    0    943.68    0    943.68    0    943.68    0    943.4    0
    944.25    0    944.25    0    944.25    0    944.25    0    943.96    0
    944.81    0    944.81    0    944.81    0    944.81    0    944.53    0
    945.37    2.3    945.37    0    945.37    2.3    945.37    2.3    945.09    0
    945.93    2.3    945.93    0    945.93    1.5    945.93    1.5    945.65    2.3
    946.48    1.5    946.48    0    946.48    1.5    946.48    0.8    946.21    1.5
    947.04    0.8    947.04    0    947.04    0.8    947.04    0    946.76    1.5
    947.58    0    947.58    0    947.58    0    947.58    0    947.31    0.8
    948.11    0    948.11    0    948.11    0    948.11    0    947.84    0
    948.65    0    948.65    0    948.65    0    948.65    0    948.38    0
    949.21    0    949.21    0    949.21    0    949.21    0    948.93    0
    949.77    0    949.77    0    949.77    0    949.77    0    949.48    0
    950.3    0    950.3    0    950.3    0    950.3    0    950.03    0
    950.82    0    950.82    0    950.82    0    950.82    0    950.56    0
    951.35    0    951.35    0    951.35    0    951.35    0    951.09    0
    951.89    0    951.89    0    951.89    2.3    951.89    0    951.62    0
    952.44    0    952.44    0    952.44    2.3    952.44    0    952.16    2.3
    953    0    953    0    953    2.3    953    0    952.72    2.3
    953.55    0    953.55    0    953.55    2.3    953.55    0    953.28    2.3
    954.12    0    954.12    0    954.12    2.3    954.12    0    953.83    2.3
    954.68    0    954.68    0    954.68    0    954.68    0    954.4    2.3
    955.22    0    955.22    0    955.22    0    955.22    0    954.94    0
    955.78    0    955.78    0    955.78    0    955.78    0    955.51    0
    956.33    0    956.33    0    956.33    0    956.33    0    956.06    0
    956.88    0    956.88    0    956.88    0    956.88    0    956.61    0
    957.45    0    957.45    0    957.45    0    957.45    0    957.16    0
    957.99    0    957.99    0    957.99    0    957.99    0    957.72    0
    958.55    0    958.55    0    958.55    0    958.55    0    958.27    0
    959.11    0    959.11    0    959.11    0    959.11    0    958.83    0
    959.64    0    959.64    0    959.64    0    959.64    0    959.37    0
    960.19    0    960.19    0    960.19    0    960.19    0    959.91    0
    960.75    0    960.75    0    960.75    1.5    960.75    0    960.47    2.3
    961.3    0    961.3    0    961.3    0.8    961.3    0    961.02    1.5
    961.85    0    961.85    0    961.85    0    961.85    0    961.58    0.8
    962.41    0    962.41    0    962.41    0    962.41    0    962.13    0
    962.97    0    962.97    0    962.97    0    962.97    0    962.7    0
    963.52    0    963.52    0    963.52    0    963.52    0    963.24    0
    964.08    0    964.08    0    964.08    0    964.08    0    963.8    0
    964.63    0    964.63    0    964.63    0    964.63    0    964.35    0
    965.21    0    965.21    0    965.21    0    965.21    0    964.92    2.3
    965.78    0    965.78    0    965.78    0    965.78    0    965.49    2.3
    966.34    0    966.34    0    966.34    0    966.34    0    966.06    2.3
    966.87    0    966.87    0    966.87    0    966.87    0    966.61    2.3
    967.42    0    967.42    0    967.42    0    967.42    0    967.14    2.3
    967.96    0    967.96    0    967.96    0    967.96    0    967.69    2.3
    968.52    0    968.52    0    968.52    0    968.52    0    968.24    2.3
    969.08    0    969.08    0    969.08    0    969.08    0    968.8    1.5
    969.62    0    969.62    0    969.62    0    969.62    0    969.34    0
    970.19    0    970.19    0    970.19    0    970.19    0    969.9    0
    970.72    0    970.72    0    970.72    0    970.72    0    970.45    0
    971.25    0    971.25    0    971.25    0    971.25    0    970.99    0
    971.79    0    971.79    0    971.79    0    971.79    0    971.52    0
    972.35    0    972.35    0    972.35    0    972.35    0    972.07    0
    972.9    0    972.9    0    972.9    0    972.9    0    972.62    0
    973.45    0    973.45    0    973.45    0    973.45    0    973.18    0
    974.01    0    974.01    0    974.01    0    974.01    0    973.73    0
    974.58    0    974.58    0    974.58    0    974.58    0    974.29    0
    975.14    0    975.14    0    975.14    0    975.14    0    974.86    0
    975.71    0    975.71    0    975.71    0    975.71    0    975.42    0
    976.28    0    976.28    0    976.28    0    976.28    0    976    0
    976.84    0    976.84    0    976.84    0    976.84    0    976.56    0
    977.4    0    977.4    0    977.4    0    977.4    0    977.12    1.5
    977.96    0    977.96    2.3    977.96    0    977.96    0    977.68    5.3
    978.5    0    978.5    2.3    978.5    2.3    978.5    0    978.23    6
    979.07    0    979.07    2.3    979.07    2.3    979.07    2.3    978.79    6
    979.64    0    979.64    2.3    979.64    4.5    979.64    2.3    979.36    6
    980.21    0    980.21    0    980.21    0    980.21    0    979.91    6
    980.73    0    980.73    1.5    980.73    4.5    980.73    2.3    980.46    6
    981.28    0    981.28    1.5    981.28    4.5    981.28    2.3    981    5.3
    981.84    0    981.84    1.5    981.84    3.8    981.84    1.5    981.56    5.3
    982.37    0    982.37    1.5    982.37    3.8    982.37    1.5    982.1    5.3
    982.91    0    982.91    0    982.91    0    982.91    0    982.64    5.3
    983.47    0    983.47    0    983.47    0    983.47    0    983.2    0
    984.03    0    984.03    0    984.03    0    984.03    0    983.76    0
    984.58    0    984.58    0    984.58    0    984.58    0    984.31    0
    985.15    0    985.15    0    985.15    0    985.15    0    984.86    0
    985.7    0    985.7    0    985.7    0    985.7    0    985.44    0
    986.23    0    986.23    0    986.23    0    986.23    0    985.96    0
    986.78    0    986.78    0    986.78    0    986.78    0    986.5    0
    987.33    0    987.33    0    987.33    0    987.33    0    987.05    0
    987.88    0    987.88    0    987.88    0    987.88    0    987.61    0
    988.46    0    988.46    0    988.46    0    988.46    0    988.16    0
    988.98    0    988.98    0    988.98    0    988.98    0    988.72    0
    989.51    0    989.51    0    989.51    0    989.51    0    989.25    0
    990.05    0    990.05    0    990.05    0    990.05    0    989.78    0
    990.6    0    990.6    0    990.6    0    990.6    0    990.33    0
    991.16    0    991.16    0    991.16    0    991.16    0    990.88    0
    991.71    0    991.71    0    991.71    0    991.71    0    991.44    0
    992.26    0    992.26    0    992.26    0    992.26    0    991.98    0
    992.8    0    992.8    0    992.8    0    992.8    0    992.53    0
    993.36    0    993.36    0    993.36    0    993.36    0    993.07    0
    993.92    0    993.92    0    993.92    0    993.92    0    993.64    0
    994.49    0    994.49    0    994.49    0    994.49    0    994.21    0
    995.06    0    995.06    0    995.06    0    995.06    0    994.78    0
    995.61    0    995.61    0    995.61    0    995.61    0    995.34    0
    996.16    0    996.16    0    996.16    0    996.16    0    995.88    0
    996.71    0    996.71    0    996.71    0    996.71    0    996.43    0
    997.27    0    997.27    0    997.27    0    997.27    0    996.99    0
    997.82    0    997.82    0    997.82    0    997.82    0    997.54    0
    998.36    0    998.36    0    998.36    0    998.36    0    998.09    0
    998.91    0    998.91    0    998.91    0    998.91    0    998.63    0
    999.46    0    999.46    0    999.46    0    999.46    0    999.18    0
    1000.01    0    1000.01    1.5    1000.01    3    1000.01    1.5    999.74    5.3
    1000.58    0    1000.58    1.5    1000.58    3    1000.58    1.5    1000.29    5.3
    1001.11    0    1001.11    1.5    1001.11    3    1001.11    1.5    1000.85    5.3
    1001.64    0    1001.64    0.8    1001.64    1.5    1001.64    1.5    1001.38    5.3
    1002.18    0    1002.18    0    1002.18    0.8    1002.18    1.5    1001.91    4.5
    1002.75    0    1002.75    0    1002.75    0    1002.75    0    1002.47    0
    1003.28    0    1003.28    0    1003.28    0    1003.28    0    1003.02    0
    1003.82    0    1003.82    0    1003.82    0    1003.82    0    1003.55    0
    1004.36    0    1004.36    0    1004.36    0    1004.36    0    1004.1    0
    1004.89    0    1004.89    0    1004.89    0    1004.89    0    1004.63    0
    1005.43    0    1005.43    0    1005.43    0    1005.43    0    1005.16    0
    1005.98    0    1005.98    0    1005.98    0    1005.98    0    1005.71    0
    1006.55    0    1006.55    0    1006.55    0    1006.55    0    1006.26    0
    1007.11    0    1007.11    0    1007.11    0    1007.11    0    1006.83    0
    1007.67    0    1007.67    0    1007.67    0    1007.67    0    1007.39    0
    1008.23    0    1008.23    0    1008.23    0    1008.23    0    1007.95    0
    1008.78    0    1008.78    0    1008.78    0    1008.78    0    1008.5    0
    1009.33    0    1009.33    0    1009.33    0    1009.33    0    1009.06    0
    1009.9    0    1009.9    0    1009.9    0    1009.9    0    1009.61    0
    1010.47    0    1010.47    0    1010.47    0    1010.47    0    1010.18    0
    1010.99    0    1010.99    0    1010.99    0    1010.99    0    1010.73    0
rvralph64
Fresno, CA, USA
C?ID=566690
Hi Uwe,
I cleared the fault code and ran the auto scan 3 more times, twice while driving and once again when parked while engine still on. No more fault code for G66. That's weird, and yes I did get a no response to throttle, sluggish response when I hit the gas pedal incident so I believe that the two are not related. I say that because I am getting a good clean report but I still experience the intermittent no response to throttle.
See report below, again I ran it three times after clearing the G66 fault code with MIL.
Friday,16,May,2025,16:27:49:07661
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: 3VWSF31Y96M303780   License Plate:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWSF31Y96M303780   Mileage: 230180km-143027miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 B    HW: Hardware No
   Component: NB/C R5 AT      G   7615
   Revision: --------    Serial number: VWZ5Z0E7248079
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 2809E8896EE2C59AE7B-513C
   VINID: 0E69E35830692467430031C80042D560E0
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 Q
   Coding: 0019978
   VCID: 382938C9BE42551A77B-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AL
   Component: 01 AIRBAG VW71      0711
   Coding: 0012337
   VCID: 015F952DAD18D4D2805-513C
   Subsystem 1 - Part No: 1C0 959 339 F
   Component: BF-Gewichtsens. 006 0007
Address 17: Instruments        Labels: None
   Part No: 1C0 920 501 P
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 11234
   Shop #: WSC 22539
   VCID: 2517E1BD1CF0D8F2DCD-4B00
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255 C
   Component:  VSG  NBC           3601
   VCID: 40D95029E6921DDACFB-513C
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: 3B2327C58A747E029A9-4B00
   Subsystem 1 - Part No: 1Y1959801C
   Component: 6J Tõrsteuer.FS KLO 0005
   Subsystem 2 - Part No: 1Y1959802D
   Component: 6J Tõrsteuer.BF KLO 0005
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tõrsteuer.HL KLO 0005
   Subsystem 4 - Part No: 1Y0959812
   Component: 6J Tõrsteuer.HR KLO 0005
End----------(Elapsed Time: 04:25, VBatt start/end: 13.4V/13.3V)-----------
---------------------------No fault code found.----------------------------
Hopefully this works better.
I'm seeing considerably more ignition retardation there than I'd personally be happy with. What kind of fuel are you running?
Yeah, that doesn't sound like it's just timing being pulled.
rvralph64
Fresno, CA, USA
C?ID=566690
I just filled it up with 87 octane, regular from a reputable gas station,no cheap stuff but that did cross my mind to try Premium grade on the next tank. The car had been sitting for 6 months until I got it. I am going to add a bottle of fuel injector cleaner and go back and read through the auto scan reports. I do remember removing the throttle body and cleaned it really good, it had a lot of carbon build up. I wouldn't have done that for no reason so it probably threw a code that prompted me to do that. I am also thinking of measuring the MAF. I read a post that talked about how the MAF could be causing the performance issue. It said that it should read 120 g/s.
Bad gas in the tank could be the reason for the G66 and maybe it's diluted out by me filling the tank? This is the only thing I can think of why the G66 code didn't return on my last drive.
Another thing I noticed when I removed the intake manifold is oil in the line from the PCV valve. The previous owner said he replaced the valve cover with the new PVC valve. I saw posts claiming this can cause performance issues but I don't think this is related but needs to be addressed anyway. I will send you the auto scan that prompted me to clean out the throttle body.
rvralph64
Fresno, CA, USA
C?ID=566690
Hi Uwe,
Check this out. I went out for a test drive and again it at times refused to accelerate when I stomped on the pedal. It is a random occurence, it doesn't always do it and even when I ran the autoscan I got a clean report. No more G66 fault code!
I strongly believe this is a fuel delivery issue. If it was a bad MAP sensor, I would get a fault code but nothing so I suspect a bad fuel filter or pump. I don't see a fuel regulator on the 2.5L unless it's not in the usual place on the fuel rail.
The mystery deepens but it makes it even more interesting.
Thanks!
Saturday,17,May,2025,19:00:02:07661
VIN: 3VWSF31Y96M303780   License Plate: 2006 LT BLUE
Mileage: 230220km-143052mi   Repair Order:
VIN: 3VWSF31Y96M303780   Mileage: 230220km-143052miles
   Coding: 0000003
   Part No SW: 09G 927 750 CG    HW: 09G 927 750 CG
   Component: AQ 250 6F           0759
   Revision: 00H27000    Serial number:
   Coding: 0000008
   VCID: 78A9F8C9FEC2951AB7B-513C
   Coding: 0019978
   Coding: 0012337
   Coding: 11234
   Shop #: WSC 22539
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 09149
   VCID: 70B9C0E993B2CD5A7FB-4B00
Address 25: Immobilizer        Labels: 1C0-920-xxx-25.clb
   Part No SW: 1C0 920 501 P    HW: 1C0 920 501 P
   Component: IMMO                X007
   Revision: xxxxxxxx    Serial number: VWZ5Z0E7248079
   Shop #: WSC 41876 001 1048576
   VCID: 2517E1BD19F0D8F2DCD-513C
   Coding: 00256
   Shop #: WSC 00066
End----(Elapsed Time: 03:50, VBatt start/end: 11.9V/11.8V. VIgn 11.6V)-----
Dr Sheldon
Windsor UK
C?ID=334979
A scope on o2 B1S1, MAF, MAP & TPS as you stomp on the pedal would give some good valuable information ?
rvralph64
Fresno, CA, USA
C?ID=566690
Hi Dr Sheldon,
I don't have a scope or is that a function in VCDS?
Dr Sheldon
Windsor UK
C?ID=334979
Hi Dr Sheldon,
A scope (oscilloscope) would be ideal however VCDS has the "Graph" facility which I have found to be a good tool - Use that.
