Passenger side mirror dipping with reversing
shawns
C?ID=113907
From http://a6retrofit.tripod.com/articles/a5vagcodes.html
Enabling reverse mirror tilt on cars without memory seats: Go to module 52 Door Elect, Pass., Long Coding, Byte 4. If the byte has value 40 (cars without electrically folding mirrors), change it to 4C. If the byte has value 50 (cars with folding or folding/dimming mirrors), change it to 5C. Afterwards when reversing and the mirror knob is in passenger position the passenger side mirror will tilt while on reverse to better show the curb. Without memory seats it is currently not known if the tilt can be adjusted, it seems to default to a standard amount according to reports (see links below, thanks to EuroDan and Unisurfer). It was reported by -V- (here in Finnish: http://www.ultimatevw.com/keskustelu/index.php?cmd=aihe&id=10753&sivu=185) that 4C won't work in some cars, but value 44 instead does. This probably has to do with equipment levels. Ross-Tech has updated their VCDS/VAG-COM software data to include relevant bits with descriptions, so you can more easily try different combinations.​
This is a well documented tweak for B8 but has been typically reported as not remembering the starting position for the mirror. For my 2014 A4 the starting position is definitely remembered (verified with several different starting positions). Not sure if this is a different module for the newer A4.
Dana, let me know if you'd like a .lbl file for the passenger side door. The current scan from the last autoscan (before I changed the coding ) is blelow
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011C03204000410001
   Shop #: WSC 02391 785 00200
   VCID: 55AB6B643CB34EB6981-8000
Shawn
killep2
C?ID=214777
Hi,
So the conclusion is?
Works or not ?
need to change something exclude the bits you just describe ?
Shawn ,
We shouldn't need a map set from those door modules because that coding chart appears to be complete but please let us know if that works in this car. My B8 page is pretty limited.
Igor,
That won't work on a Golf based car like yours.
-Dana
killep2
C?ID=214777
Hi,
Just wondering why the Superb has this option .... it's not Golf based ?
Very strange
A Superb is a whole lot closer to a Golf than a B8 Audi is! ;)
killep2
C?ID=214777
So I dont understand.
Who told that I have Audi ?:)
I have Skoda Octavia !!
The OP owns a B8 platform Audi and his scan clip, link and references point to A5/A4 B8/Q5, many for A6/A8/Q7
jlhk
Hong Kong
C?ID=275448
I knew this is a 2014 thread, but may i ask if this dipping function can be turned on on the driver side mirrow as well please? Thanks in advance.
