- Apr 8, 2025
- 8
- 0
- Ayr, Scotland, UK
- C?ID=186698
Hello, first time posting, I have a Crafter and 4 recurring faults, the one I need help with is Terminal 30 on start up, voltage drops to 9 V and causes MIL, starter is not sluggish, new Battery coded, checked all connections and cleaned, dont want to replace starter if not needed, any ideas?
Many thanks
Many thanks
Address 01: Engine Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 EK HW: 04L 907 445 C
Component and/or Version: R4 2.0l TDI H01 6391
Software Coding: 001940106304010800000000000000000000000000000000
Work Shop Code: WSC 00069 790 00021
ASAM Dataset: EV_ECM20TDI03004L906056EK 005014 (VN54)
ROD: EV_ECM20TDI03004L906056EK_005.rod
VCID: 7AAA2D6E0C54196AC1E-802E
23871 - EGR System
P0401 00 [01100100] - Insufficient Flow
Fault Frequency: 52
Mileage: 333113 km
Date: 2025.05.03
Time: 15:35:00
Engine speed: 1792.75 /min
Normed load value: 37.3 %
Vehicle speed: 54 km/h
Coolant temperature: 91 C
Intake air temperature: 20 C
Voltage terminal 30: 12.570 V
EGR travel diagnosis: strongly increased NOx emission: 0.00 kg/h
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -101.17 %
EGR travel diagnosis: marginally increased NOx emission: -35.20 kg/h
Mass airflow sensor 1 bank 1 airflow: raw value: 456.7 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 80.19 %
Charge press. ctrl deviation after throttle valve bank 1-Pressure_16_signed_10_mbar: 3.9 mbar
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 0.873 V
31168 - Control Circuit for Reductant Tank Heating
P202A 00 [01100100] - Open Circuit
Mileage: 333137 km
Date: 2025.05.03
Time: 15:54:46
Engine speed: 1784.50 /min
Normed load value: 38.8 %
Vehicle speed: 86 km/h
Coolant temperature: 90 C
Intake air temperature: 17 C
Voltage terminal 30: 12.648 V
Outside temperature sensor 1: B1: raw value: 17.5 C
Exhaust temperature bank 1: S1/S2/S3/S4: / ---/---/---/-40 C
Sensor for reducing agent tank temperature: temperature: 24.1 C
Reducing agent metering system heating circuit 2: actual current: 0.311 A
Reducing agent metering system heating circuit 1: actual current: 0.000 A
Reducing agent fill level sensor: act. value: 100 mm
27277 - System Voltage
P0562 00 [00100111] - Too Low
Mileage: 333112 km
Date: 2025.05.03
Time: 15:34:42
Engine speed: 2122.25 /min
Normed load value: 32.2 %
Vehicle speed: 46 km/h
Voltage terminal 30: 12.625 V
Air mass at air mass meter 1: 118.8 kg/h
Standardized air flow ratio: 1.208 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -116.13 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 78.50 %
Charge air pressure: specified value: 1.493 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1148 mbar
Mean injection quantity: 7 mg/stroke
Index of current engine mode: 0
Index of next requested engine mode: 0
Index of engine target mode: 0
28656 - Terminal 30
U140A 00 [00100111] - Open Circuit
[Terminal 30Open circuit]
Mileage: 333140 km
Engine speed: 0.00 /min
Coolant temperature: 88 C
Intake air temperature: 0 C
Voltage terminal 30: 12.375 V
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.57 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.003 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1015 mbar
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 8
Index of next requested engine mode: 11
Index of engine target mode: 11
Readiness: N/A
Sunday,11,May,2025,20:02:47:46091
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
