2021 Audi RSQ8 network connectivity configuration
KingArthur
Manila, Phillipines
C?ID=590845
wanted to get the car connected to the internet via wifi since car is from the USA and is imported to Manila so the built in Sim module will not work on a different network provider. The only chance of might be getting network connectivity for Key User configuration for 5F and 75.
KingArthur
Manila, Phillipines
C?ID=590845
AutoScan: WU1ARBF13MD033663
Wednesday,30,April,2025,15:34:27:13393
VCDS Version: 25.3.1.1 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WU1ARBF13MD033663   License Plate:
Chassis Type: F1-AU58 (4KL)
Scan: 01 02 03 06 09 13 15 16 17 19 36 3C 42 44 46 52 5F 61 69 6D
          74 75 81 82 A5 A9 BB BC C4 CA CB CC CF D6 D7 DB DC DE
VIN: WU1ARBF13MD033663   Mileage: 10221km-6351miles
74-Chassis Control -- Status: Malfunction 0010
82-Head Up Display -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DHUB)       Labels:. 0P2-907-309-V1.clb
   Part No SW: 4M8 907 557 F    HW: 0P2 907 309 A
   Component: V8 4.0l TFSI  H31 0001
   Revision: 72H31000    CVN: 2A7FC3FB
   Coding: 2A2A0012257E010E342C6000000400000000000000000000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM40TFS0114M8907557F 001002
   ROD: EV_ECM40TFS0114M8907557F.rod
   VCID: 40D233332A00861ACFA-8014
   VINID: 9E50518925810DD5000C31860C62730688
17159 - Databus
          U1123 00 {00101111} - Received Error Message
                    Fault Frequency: 52
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:18
                    Engine speed: 0.00 /min
                    Coolant temperature: 28 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 11.660 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
34208 - Exhaust Pressure Control Valve 2
          P04A0 00 {00100000} - Regulation Fault
                    Mileage: 8400 km
                    Date: 2023.06.12
                    Time: 10:45:35
                    Engine speed: 2042.00 /min
                    Normed load value: 21.2 %
                    Vehicle speed: 71 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 13.040 V
                    Unlearning counter according OBD: 10
                    Engine status: COENG_RUNNING
34209 - Exhaust Pressure Control Valve 2
                    Mileage: 6961 km
                    Date: 2022.12.07
                    Time: 17:29:50
                    Engine speed: 950.00 /min
                    Normed load value: 9.4 %
                    Coolant temperature: 103 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.060 V
34210 - Exhaust Pressure Control Valve 2
          P04A0 00 {00101111} - Regulation Fault
                    Mileage: 5806 km
                    Date: 2022.07.30
                    Time: 11:44:19
                    Engine speed: 1365.00 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 92 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 12.480 V
23765 - Control unit for information electronics 1
          U1054 00 {00100000} - No Communication
          {Information electronics control module 1No Communication}
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:26
                    Engine speed: 1920.50 /min
                    Normed load value: 3.1 %
                    Coolant temperature: 33 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 13.160 V
                    Unlearning counter according OBD: 12
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 49
   Part No SW: 4M8 927 158 F    HW: 0D6 927 156 H
   Component: 0D6 40FSINAR  H06 0004
   Revision: --H06---    CVN: 0EFC6C6900007164
   Coding: 100000
   Shop #: WSC 31414 037 00001
   ASAM Dataset: EV_TCMALX52011 002016
   ROD: EV_TCMALX52011.rod
   VCID: 3FD030CF57FEF9E2B60-806A
   ATF pump:
   Subsystem 1 - Part No SW: 4M0 927 154 AA    HW: 0D7 321 281 B
   Component: V552 ATFP  H02 0830
   Serial number: 2102260421
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M8 907 379 G    HW: 4M8 907 379 G
   Component: ESP9 Premium  H06 0051
   Dataset Number: 4M8909504AC 0001 CVN: C4AC1D44
   Coding: 34AA6A9631A52B9993A45C971A80D6E2F43A892C568CD4C93A586B472F5C91
   ROD: EV_ESP9BOSCHCMP_004_AU58.rod
   VCID: 43D83C3F3B169D02D28-8016
419584 - TPMS Warning; Rear Left Tire
          C1059 00 {00101000} - Flat
                    Mileage: 9809 km
                    Date: 2024.08.23
                    Time: 10:25:50
                    8C 00 88 22 88 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 24
419840 - TPMS Warning; Rear Right Tire
          C105B 00 {00101000} - Flat
                    Mileage: 9809 km
                    Date: 2024.08.23
                    Time: 10:25:50
450048 - Databus
          U1122 00 {00100000} - Implausible Message
          {Signal_FT_Tuer_Status_invalid_(0)_or_Signal_FT_Tuer_Status_QBit_invalid_(1)}
452352 - Databus
          U1123 00 {00101000} - Received Error Message
          {Signal_RCTA_Status_error_(3)}
                    Fault Frequency: 14
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:29
                    80 00 88 13 88 24 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 0F
   Part No SW: 4M8 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0064
   Serial number: 00000436243869 Dataset Number: 4M8909866B  0013
   Coding: 011CB2400001BEA14843010101010000810000070700878700000000000000
   Shop #: WSC 31414 053 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800107032140258656
   Coding: BF2F00
   Valve block 2 in front seat passenger side:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ80010603211147008C
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 JE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 4M8909864A  0007
   Coding: 07001563C0291CDD070E57889CFB9C38131B37510406009701090A001B3316010863090200100000000003030043081858020000C4030104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   VCID: 7AA681DB0C5C1CCAC1E-802E
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0302103002218
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 41022197X81A955555B0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S13.02.2100690823
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00HS02
   Coding: 250000
   Subsystem 5 - Part No SW: 4KE 857 511 C    HW: 4KE 857 511
   Component: Y7_Innenspieg  H05 0003
   Serial number: GX1NR118122023311000
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
   Component: Dachmodul  H42 0416
   Serial number: B01911870
   Coding: 0D0104
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H08 0210
   Serial number: WA145503000093934965
   Coding: 0A0100
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BM05863377
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BM04724933
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BM05884203
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BM05569514
   Front windshield washer pump:
   Subsystem 12 - Part No SW: 4N0 907 605 C    HW: 4N0 907 605 A
   Component: J1100/SWP  H21 0015
   Serial number: 00000000002104200685
   Coding: 040000
405507 - Functional Limitation due to Energy Management
          B10CD 00 {00001000} - -
          {Function limitation due to energy management system}
                    Fault Frequency: 29
                    Reset counter: 230
                    Mileage: 9472 km
                    Date: 2024.03.20
                    Time: 12:25:30
                    average_Voltage_terminals: 11.30 V
                    Outside air temperature sensor-Outside air temperature on CAN: 30.50 °C
                    interior_temperature: Temperature not available
                    Vehicle speed: 0.00 km/h
                    Terminal activation-Terminal 75 status: Not available
                    Terminal activation-Terminal 15 status signal: OFF
                    Terminal activation-Terminal 15 via CAN: Not available
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 4M0 907 561 P    HW: 4K0 907 561
   Component: LRR4R         H12 0500
   Dataset Number: 4M8909863M  0002
   Coding: D7659F5C78082C00010360E00000003E4A1146484401409EA5
   ASAM Dataset: EV_ACCBOSCHAU65X 002031
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 3D2C4AC75DF2EBF2A4C-8068
2342 - Databus
          U1123 00 {00001001} - Received Error Message
          {FAULT_ACA_QF_STATUS_DISPLAY_ERROR}
                    Reset counter: 190
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:20
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 11.5 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 3.000 °
                    Yaw_rate-Data: 0.000 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.186 °
                    Misalignment angle: horiz: fast algorithm: 0.160 °
                    Congestion pilot: status: OFF
                    Outside temperature: 28.50 °C
                    Sensor blindness: radar: no blindness detected
2359 - Sensor for Automatic Distance Control
          C110B F0 {00001000} - Limited Visibility
          {FAULT_SENSOR_DISTURBED}
                    Reset counter: 211
                    Mileage: 7585 km
                    Date: 2023.04.04
                    Time: 17:43:23
                    Control Module temperature: 54 °C
                    Voltage terminal 15: 13.6 V
                    Vehicle speed: 7.27 m/s
                    Longitudinal acceleration: 1.32 m/s²
                    Steering_angle-Data: 4.100 °
                    Yaw_rate-Data: 0.311 rad/s
                    Misalignment angle: horiz: -0.029 °
                    Misalignment angle: horiz: fast algorithm: 0.014 °
                    Outside temperature: 43.00 °C
1127 - Databus
          U1121 00 {00001000} - Missing Message
          {FAULT_TIMEOUT_PSD_04}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:28
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 13.7 V
                    Steering_angle-Data: 77.100 °
                    Yaw_rate-Data: -0.008 rad/s
                    Misalignment angle: horiz: 0.082 °
                    Misalignment angle: horiz: fast algorithm: 0.313 °
                    Outside temperature: 30.50 °C
0935 - Databus
          {FAULT_TRAILOR_LIGHT_DEFECTIVE}
                    Fault Frequency: 20
                    Reset counter: 187
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:20
                    Voltage terminal 15: 11.6 V
                    Adaptive distance regulation: status: ACC_StandBy
   Part No SW: 4N0 959 655 T    HW: 4N0 959 655 T
   Component: AirbagVW31    H02 2844
   Serial number: 0031FM00MFME Dataset Number: 4M8909602BB 0002
   Coding: AEFCFCC000C00000A000003FF20D410000C5
   Shop #: WSC 31414 188 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
   VCID: 4DCC1A07ED525B7234C-8018
   Left seat belt tensioner:
   Serial number: 00AI2020053668300000
   Coding: 02F001
   Right seat belt tensioner:
   Serial number: 00AI2020061794400000
   Coding: 02F001
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D21000FK4JW0N
   Coding: 303136
   Subsystem 4 - Part No SW: -----------    HW: 480 002 602 21
   Serial number: 3570000000042575D15E
   Subsystem 5 - Part No SW: -----------    HW: 480 002 602 21
   Serial number: 3580000000016D85D15P
   Subsystem 6 - Part No SW: -----------    HW: 480 030 103 21
   Serial number: 351002C18639D940ED2J
   Subsystem 7 - Part No SW: -----------    HW: 480 030 103 21
   Serial number: 352002C18620DD404F04
   Subsystem 8 - Part No SW: -----------    HW: 480 032 402 21
   Serial number: 355002C1450A24D0FEAJ
   Subsystem 9 - Part No SW: -----------    HW: 480 032 402 21
   Serial number: 356002C14509AD60EFFY
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 030 103 21
   Component: SideSens_B_Df  002 0149
   Serial number: I0P002C1863A91B0E8BA
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 030 103 21
   Component: SideSens_B_Pf  002 0149
   Serial number: I0Q002C186295900999$
1067776 - Databus
          {NWD: 0x484 NavData_01 Timeout}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
   Part No SW: 4N0 907 129 KF    HW: 4N0 907 129 KF
   Component: Lenks.Modul   H03 0009
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 7F5070CF177E39E2F60-802A
6377472 - Switch for Headlamp Flasher
          B150A 11 {00001000} - Short to Ground
                    Reset counter: 215
                    Mileage: 9368 km
                    Date: 2024.02.22
                    Time: 10:30:30
                    Freeze_Frame_Lever_Indicator-Operation_time_counter: 20539 min
                    Freeze_Frame_Lever_Indicator-Voltage_12V: 13950.00 mV
                    Freeze_Frame_Lever_Indicator-Voltage_5VS: 4893.75 mV
                    Freeze_Frame_Lever_Indicator-Voltage_Flash_Beam_uncompensated: 0 bit
                    Freeze_Frame_Lever_Indicator-Voltage_High_Beam_uncompensated: 0 bit
                    Freeze_Frame_Lever_Indicator-Voltage_TurnIndicator_Channel_A_compensated: 129 bit
                    Freeze_Frame_Lever_Indicator-Voltage_TurnIndicator_Channel_A_uncompensated: 126 bit
                    Freeze_Frame_Lever_Indicator-Voltage_TurnIndicator_Channel_B_compensated: 129 bit
                    Freeze_Frame_Lever_Indicator-Voltage_TurnIndicator_Channel_B_uncompensated: 126 bit
   Part No SW: 4K0 920 790 E    HW: 4K0 920 790 E
   Component: FBenRDW------ H26 0056
   Dataset Number: 4N1909525B  0017
   Coding: 096F63F27E88000802A067609800601008003000
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU58.rod
   VCID: 2F30608F879E0962260-807A
9582602 - Video Cable for Information Electronics 1
          B13B9 01 {00001000} - Electrical Failure
                    Reset counter: 224
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:07:00
16777018 - Control unit for information electronics 1
          U1054 00 {00001000} - No Communication
          {Audio_0x31 communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
16777020 - Control unit for information electronics 1
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
16777022 - Control unit for information electronics 1
          {NAV_SD_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
16777030 - Control unit for information electronics 1
          {BAP_TEL2_0x29 communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
16777058 - Control unit for information electronics 1
          {BAP_OnlineFunctions_0x2A communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 4KL 907 468 C    HW: 4K1 907 468 C
   Component: Gateway       H07 0602
   Serial number: F0265944627221 Dataset Number: 4K0909515M  0061
   Coding: 02030001000406405496000000590132FC9A00C01C0000000900008E02000000
   GVL: F1513C180800000082FC88008100C800110C0070000000000000000000006700
   ASAM Dataset: EV_Gatew31xAU65x 003220
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 50F20373FA60769A5FA-8004
   Subsystem 1 - Part No SW: 4M8 951 523 G    HW: 4M8 951 523 G
   Component: J453 MFL  H07 0004
   Serial number: 20201218140941 31471
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 7588520200210224005C
   Subsystem 3 - Part No SW: 4M8 419 508 A    HW: 4M8 419 508 A
   Component: J1158 KLR  H10 0010
   Serial number: 00000000000000084914
   Coding: FFFFFF
8 Faults Found:
131699 - Control unit for information electronics 1
          {Timeout_Node_0x73_DiagAdress_5F_ZR_High}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:16
131712 - Ride Level Control Module
          U0132 00 {00001000} - No Communications
          {Timeout_Node_0x80_DiagAdress_74_EFP}
                    Reset counter: 228
                    Mileage: 10085 km
                    Date: 2025.04.01
                    Time: 09:39:10
131826 - Ethernet Module for Information Electronics 1
          U1645 00 {00001000} - No Communication
          {Timeout_Node_0xF2_zr2_DiagAdress_005F}
                    Reset counter: 224
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:07:12
131829 - Ethernet Module for Information Electronics 1
          {Timeout_Node_0xF5_zr_DiagAdress_005F}
                    Reset counter: 224
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:07:12
197170 - Control Module for Steering Wheel Touch Detection
          U133E 00 {00001000} - No Communication
          {Break_Down_LIN_Communication_KLR}
                    Reset counter: 227
                    Mileage: 9938 km
                    Date: 2024.10.15
                    Time: 15:35:53
8519683 - Energy Management Active
          U140B 00 {00001000} - -
                    Fault Frequency: 29
                    Reset counter: 230
                    Mileage: 9472 km
                    Date: 2024.03.20
                    Time: 12:25:24
                    EM_vehicle_state: 00 20
                    Static current shut-off stage: Deactivation stage 1
                    Auxiliary heater activation restriction request-Parking heater: Permitted
                    Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
8531970 - Quiescent Current
          U1406 00 {00001000} - Too High
          {Electric_current_Upper_Limit_Value_Exceeded}
                    Fault Frequency: 104
                    Reset counter: 230
                    Mileage: 9299 km
                    Date: 2024.01.27
                    Time: 15:19:23
                    Total static current-current total quiescent current: 188 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
16711991 - Ethernet Databus Branch 2
          U122D 00 {00001000} - No Communication
          {Ethernet_databus_no_communication_port_2}
                    Reset counter: 224
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:07:04
                    Ethernet counter checksum error: branch 2: 0
                    Ethernet counter connection interruptions: branch 2: 1
   Component: MEM-FS        009 0064
   Serial number: 00000435573805 Dataset Number: 4M8909856B  0013
   Coding: 011C9A400001BEA14803010101010000810000070700878700000000004000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ8001070321402586FF
   Coding: BF2F00
   Valve block 2 in front seat driver side:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ800106032111470075
   Part No SW: 4N0 907 566 AL    HW: 4N0 907 566 A
   Component: MRR_HR H24 0587
   Dataset Number: 4M8909535E  0016
   Coding: 1FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001022
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 0052F3336A80461A8FA-8054
1311072 - Restricted Visibility
          C12AA 00 {00001000} - -
                    Fault Frequency: 9
                    Reset counter: 205
                    Mileage: 6507 km
                    Date: 2022.10.15
                    Time: 14:49:10
                    Control Module temperature: 68 °C
                    Voltage terminal 30: 12.80 V
                    Vehicle speed: 52.54 km/h
                    Terminal 15 status: On
                    Voltage terminal 15: Measuring value not available
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS003 0430
   Serial number: YE007UBJ20079 Dataset Number: 4M8909872D  0027
   Coding: 001DCB43520014C2A009A436
   Shop #: WSC 31414 163 00001
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 46DE252B0824A82AF56-8012
196711 - Motor for Window Regulator
          B1487 29 {00001000} - Signal Implausible
                    Reset counter: 224
                    Mileage: 9774 km
                    Date: 2024.07.12
                    Time: 14:48:53
          B1487 54 {00001000} - Missing Calibration / Basic Setting
                    Reset counter: 224
                    Mileage: 9774 km
                    Date: 2024.07.12
                    Time: 14:48:53
   Dataset Number: 4M8909852J  0002
   Coding: B2000101010001
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323669FB94AC248A49E-8066
   Part No SW: 8W1 907 064 BP    HW: 8W1 907 064 P
   Component: BCM2 MLBevo   044 0565
   Dataset Number: 4M8909501J  0035
   Coding: 013400004FB100C0650FA0046C01C80203004000810426502F0400200F04823F001E0681011F35
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018.rod
   VCID: 0C4AD70356C8127AE32-8058
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY203350HJL
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000001648741
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4M8 945 069 C    HW: 4M8 945 069 C
   Component: SHL_li1  H04 0004
   Serial number: 069C2102270000219739
   Subsystem 4 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 38470065
   left tail lamp 2:
   Subsystem 5 - Part No SW: 4M8 945 217 G    HW: 4M8 945 217 G
   Component: SHL_li2  H04 0004
   Serial number: 217G2102150000214336
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 4M8 945 070 C    HW: 4M8 945 070 C
   Component: SHL_re1  H04 0004
   Serial number: 070C2102270000219673
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 4M8 945 218 G    HW: 4M8 945 218 G
   Component: SHL_re2  H04 0004
   Serial number: 218G2102150000214336
131120 - Remote key 1
          B1479 18 {00001000} - Current Too Low
                    Reset counter: 216
                    Mileage: 8773 km
                    Date: 2023.08.25
                    Time: 10:12:02
                    Supply voltages-Terminal 30 power supply: 14.430 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 14.403 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 14.430 V
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 02 80 98 06 E0
                    general_additional_freeze_frame-Vehicle speed: 30.65 km/h
                    key_error_freeze_frame: 01001001 11111111 11111111 11111111
65763 - Protection of Central Locking
          B1691 54 {00001000} - Missing Calibration / Basic Setting
                    Reset counter: 230
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:01:16
                    Supply voltages-Terminal 30 power supply: 11.250 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 11.223 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 11.250 V
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 1
                    general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 E0
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS003 0430
   Serial number: YE007UB214802 Dataset Number: 4M8909873D  0027
   Coding: 001DCB035E0014C2A009A434
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 45DC22273522A332FCC-8010
   Part No SW: 4M2 035 092 A    HW: 4M2 035 092
   Component: MU-TP-NS-US   042 3385
   Serial number: GRO-63310.03.21 Dataset Number: 4M8909545K  0003
   Coding: 15363010804100000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_VW53.rod
   VCID: 270088AFAF6E5122EE0-8072
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 4M8 919 605 J    HW: 4M8 919 605 F
   Component: DU AU536 Top   H32 0055
   Serial number: INX00129122000150655
   Subsystem 2 - Part No: V03 959 808 LC
   Component: MIB3_NA_2021.  0556
   Compact disc data bank:
   Component: Gracenote2     3004
   Multimedia display unit 5:
   Subsystem 4 - Part No SW: 4N0 919 603 J    HW: 4N0 919 603 F
   Component: DU AU651 Bot   H32 0054
   Serial number: INX00131012100170826
   Volume Control 1:
   Subsystem 5 - Part No SW: 4N1 919 616 B    HW: 4N1 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00007521000032135032
   Media socket:
   Subsystem 6 - Part No: 4N1 035 736
005 0005
   Digital Sound System Control Module 2:
   Subsystem 7 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU   H11 0100
   Serial number: HHA-07313.03.2142960
2562 - Navigation System
          B126C F0 {00001001} - Navigation Database Faulty
                    Reset counter: 116
                    Mileage: 5806 km
                    Date: 2022.07.30
                    Time: 11:40:17
                    Voltage terminal 30: 13.2 V
0021 - Functional Limitation due to Energy Management
          {Function restriction via shutoff stage Q2}
                    Fault Priority: 9
                    Reset counter: 224
                    Mileage: 9786 km
                    Date: 2024.07.21
                    Time: 11:06:36
                    Voltage terminal 30: 10.8 V
Address 61: Battery Regul. (J1120)       Labels: 4N0-915-105.clb
   Part No SW: 4N0 915 105 D    HW: 4N0 915 105 D
   Component: BMS_48V_LiIon H09 0206
   Dataset Number: 4N0909480A  0006
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 2B08749FB38675420A8-807E
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W0 907 383 C    HW: 8W0 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000005708 Dataset Number: 8Y0909527B  0007
   Coding: 0200000200001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
660234 - Bulb for Left Brake Light on Trailer
          C10FA 15 {00101111} - Open or Short to Plus
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:18
660490 - Bulb for Right Brake Light on Trailer
          C10FB 15 {00101111} - Open or Short to Plus
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:18
85770 - Tail Lamp on Trailer
          C10DB 15 {00101000} - Open or Short to Plus
                    Mileage: 7174 km
                    Date: 2023.03.18
                    Time: 16:19:39
   Part No SW: 4M8 959 107     HW: 4M8 959 107
   Component: HDSG-Modul    H05 0330
   Revision: --------    Serial number: A2-C765-5000-7 Dataset Number: 4M8909541F
   Coding: 28A0
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_001_AU49.rod
   VCID: 78A29BD332500EDAB7A-802C
Address 74: Chassis Control (J775)       Labels:* 4N0-907-777.clb
   Part No SW: 4M8 907 777 CA    HW: 4M8 907 777 C
   Component: Fahrwerk-SG   H53 2135
   Serial number: 2402211494  Dataset Number: 4M8909576L  0003
   Coding: B85C7050FA44
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 0256F93B648C540A99E-8056
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004132272525
   Coding: 303030
262179 - Databus
          {Timeout_Error_NavData_03}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
                    Internal DTC: 616
262194 - Databus
          {Timeout_Error_NavData_01}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
                    Internal DTC: 617
262195 - Databus
          {Timeout_Error_NavData_02}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
                    Internal DTC: 618
262196 - Databus
          {Timeout_Error_NavPos_01}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:27
                    Internal DTC: 619
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 4K2 035 284 A    HW: 4K2 035 284 B
   Component: CB_H_CAN      041 0236
   Serial number: A983C0MS020606 Dataset Number: 4K0909612G  0012
   Coding: 01E0E0F9C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_VW53.rod
   VCID: 28028B93A2705E5AE7A-807C
   Part No SW: 4N1 713 041 F    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0081
   Revision: 0L0D5012    Serial number: 21012765189552
   ASAM Dataset: EV_GSMWaehlZFAU736 001018
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 29048E97B97A6752F84-807C
Address 82: Head Up Display (J898)       Labels:| 4Nx-919-617-V1.clb
   Part No SW: 4M8 919 617 D    HW: 4M8 919 617 D
   Component: HeadupDisplay H07 5951
   Dataset Number: 4M8909463A  0007
   Coding: 4700E2
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 3E2E4DCB50F4F0EABD6-806A
16777040 - Function Restricted due to Interrupted Communications
          U1110 00 {00001000} - -
          {NAV_0x32 communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:32
16777042 - Function Restricted due to Interrupted Communications
          {AIO_0x2A communication error bap_error_timeout heartbeat}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:32
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* Redir Fail!
   Part No SW: 4K4 907 117 F    HW: 4K4 907 117
   Component: zFAS Var C    H09 0365
   Dataset Number: 4M8909466Q  0041
   Coding: 020188000000000000FBD60000F4C70E139F7600000000D8000000000096D401019BA8000000000000000080000000000000000000000000F980400000000000000078D00080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 003008
   ROD: EV_ZFASAU516_003.rod
12 Faults Found:
2114053 - Databus
          U1123 00 {00001000} - Received Error Message
          {RCTA_01_RCTA_Status}
                    Fault Frequency: 14
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:29
2113631 - Databus
          {Timeout_Mainunit_01}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:30
                    Supply voltages-Supply voltage Terminal 30 - internal: 0.00 V
                    Supply voltages-Terminal 30: 13.80 V
                    Supply voltages-Terminal 30 local: 13.90 V
2114915 - Databus
          {SWA_01_SWA_Status_02}
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:29
221284 - Front Camera for Driver Assist Systems
          C12B3 FD {00001000} - View Temporarily Restricted
          {temp view limitations}
                    Reset counter: 210
                    Mileage: 9060 km
                    Date: 2023.11.25
                    Time: 10:53:42
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 74 °C
                    Vehicle speed: 38.00 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: No
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
282656 - Video Cable for Information Electronics 1
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:33
73735 - Function Limitation due to Restricted Visibility by Radar Sensors
          C12ED 00 {00001000} - -
          {MRR_HR_SensorHeader_MRR_HR_Verschmutzung}
                    Fault Frequency: 9
                    Reset counter: 205
                    Mileage: 6507 km
                    Date: 2022.10.15
                    Time: 14:49:11
                    Pre-crash side: error code: 00 00
                    Crossing assistant: error code: 00 00 00 00
                    Intersection assistant function status: Blindness
                    PreCrash page function status: active
                    KA_Software_Information-KA_Dataset_Type: 00 00
                    KA_Software_Information-KA_Dataset_Version: 08 05
                    KA_Software_Information-KA_DTCs: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    KA_Software_Information-KA_Ignored_External_Errors: 00 00 00 00
                    KA_Software_Information-KA_Ignored_Internal_Errors: 00 00 00 00
                    KA_Software_Information-KA_SWC_Debug: 00 11 31 02 00 00 00 00 00 00 00 00 00 00 00
                    KA_Software_Information-KA_SWC_Version: 29 04
73736 - Function Limitation due to Restricted Visibility by Radar Sensors
          {MRR_HL_SensorHeader_MRR_HL_Verschmutzung}
                    Fault Frequency: 12
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:29
                    KA_Software_Information-KA_SWC_Debug: 00 11 13 02 00 00 00 00 00 00 00 00 00 00 00
4107 - Databus
          {reversibler_Fehler_im_ACC_System}
                    Reset counter: 190
                    Mileage: 7174 km
                    Date: 2023.03.10
                    Time: 14:09:20
65537 - Intersection Assistant
          C12D8 F0 {00001000} - Status Feedback for HMI Implausible
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:41
                    Profile master status intersection assistant-Nominal status: On
                    Profile master status intersection assistant-Actual status:: Malfunction
65542 - Lane Change Assistant
          C12DC F0 {00001000} - Status Feedback for HMI Implausible
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:34
                    Profile master status lane change assistance-Mode: Blindness
                    Profile master status lane change assistance-Nominal status: On
                    Profile master status lane change assistance-Actual status:: Malfunction
65543 - Egress Warning
          C12DD F0 {00001000} - Status Feedback for HMI Implausible
                    Fault Frequency: 14
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:34
                    Profile master status exit warning-Mode: Blindness
                    Profile master status exit warning-Nominal status: On
                    Profile master status exit warning-Actual status:: Malfunction
2117740 - Control unit for information electronics 1
          {ServiceInitialConnectionFail_ETH_Update_EDR}
                    Reset counter: 224
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:40
                    Ethernet signal quality: good: link available
   Part No SW: 4M8 907 159 C    HW: 4K0 907 159
   Component: SAS-GEN 2.5   H08 0001
   Serial number: 210210200479
   ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
   VCID: 3B2844DF43E6E5C29A8-806E
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS005 0430
   Serial number: YE007UBI06376 Dataset Number: 4M8909897D  0027
   Coding: 000DC903000014C2E008A024
   VCID: 48C22B130230BE5A07A-801C
   Component: TSG HBFS005 0430
   Serial number: YE007UBI06771 Dataset Number: 4M8909896D  0027
Address C4: DC/DC Converter (A7)       Labels: 4K0-959-663.clb
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC21086001603 Dataset Number: 4M8909475B  0005
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
   VCID: 75BC92E7254273B2ACC-8020
11491585 - Databus
          {CAN_Message_Radio_01_ tout}
                    Reset counter: 202
                    Mileage: 8673 km
                    Date: 2023.08.08
                    Time: 09:24:31
   Dataset Number: 4M8909469D  0012
   Coding: 228040053632
Address CB: Rear Axle Steering (J1019)       Labels:* 4M0-909-145.clb
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_ Dataset Number: 4M8909904G  0002
   Coding: 42242A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
   VCID: 6FB0A08F471E4962660-803A
Address CC: Starter-Generator (C29)       Labels:* None
   Part No SW: 4N0 903 028 R    HW: 4N0 903 028 R
   Component: BSG-HP1-65    H19 0527
   Serial number: 26022100030341  Dataset Number: 4M8909490A  0004
   Coding: 30000400000000
   ASAM Dataset: EV_Start48VAU651 002007
   ROD: EV_Start48VAU651_002.rod
   VCID: 3A2641DB4CDCDCCA81E-806E
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H24 0587
   Dataset Number: 4M8909468E  0016
   Coding: 1FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001022
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
                    Fault Frequency: 12
                    Reset counter: 205
                    Mileage: 6479 km
                    Date: 2022.10.02
                    Time: 10:37:29
                    Control Module temperature: 63 °C
                    Voltage terminal 30: 12.70 V
                    Vehicle speed: 39.53 km/h
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   Dataset Number: 4M8909471E  0013
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72B6A9FB542C648A89E-8026
   Dataset Number: 4M8909472E  0013
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:| 4N0-907-669.clb
   Part No SW: 4N0 907 669 AL    HW: 4N0 907 669 A
   Component: MRR_VR H24 0587
   Dataset Number: 4M8909482E  0014
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
   ROD: EV_FrontCorneRadarS1AU651_VW53.rod
   VCID: 045AFF237E985A3AAB2-8050
Address DC: Frt Corner Rdar 2 (J1088)       Labels:| 4N0-907-669.clb
   Component: MRR_VL H24 0587
   Dataset Number: 4M8909483E  0015
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
   ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 800000
   VCID: 23189CBFDB56BD02B28-8076
End----(Elapsed Time: 35:42, VBatt start/end: 11.7V/11.3V. VIgn 11.2V)-----
------------------------------60 Faults Found------------------------------
blockmap-5F-4M2-035-092-A_WU1ARBF13MD033663-20250430-1522.CSV
;SW:4M2-035-092-A   HW:4M2-035-092 ---  Information Electr.
;Component:MU-TP-NS-US   042 3385, Coding:15363010804100000000000000000000000000000000000000
;EV_MUTI,001010,EV_MUTI_VW53.rod
;Wednesday,30,April,2025,15:22:11:13393
;VCDS Version: Release 25.3.1 (x64)  Data version: 20250415 DS365.0
;VCID: 270088AFAF6E5122EE0-8072
Group,Description,Actual
IDE00019,Voltage terminal 30,11.50, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,67, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,0, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,60, °C
IDE00767,No. of unscheduled ECU resets,6,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Center speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Right front bass speaker,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Double subwoofer speaker 1,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Double subwoofer speaker 2,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Left rear speaker,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Right rear speaker,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Left front treble speaker 2,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Right front treble speaker 2,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right Front Midrange Speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG256038,Speaker status-loudspeaker_config_channel_25,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Left Front Midrange Speaker,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Left effect speaker,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Right effect speaker,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Left front treble speaker,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Right front treble speaker,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Center speaker 2,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Left front bass speaker,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,OK,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,OK,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,OK,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,OK,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,OK,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,OK,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,OK,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,OK,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,OK,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG256039,Speaker status-loudspeaker_state_channel_25,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,OK,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,OK,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,OK,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,OK,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,OK,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,OK,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,OK,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,OFF,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,59, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,45, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System visually not OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,3C E4 60 C8,
IDE01992-MAS00076,Installation list: current installations-Instrument cluster control module,not installed,
IDE01992-MAS00839,Installation list: current installations-TV Tuner,not installed,
IDE01992-MAS00844,Installation list: current installations-Radio,not installed,
IDE01992-MAS00847,Installation list: current installations-Digital Sound System Control Module,not installed,
IDE01992-MAS00849,Installation list: current installations-Information electronics control module 1,installed,
IDE01992-MAS00850,Installation list: current installations-Information electronics control module 2,not installed,
IDE01992-MAS04300,Installation list: current installations-DVD changer,not installed,
IDE01992-MAS14306,Installation list: current installations-Windshield projection head up display control module,not installed,
IDE01992-SFT00078,Installation list: current installations-Display/operating unit rear right,not installed,
IDE01992-SFT00094,Installation list: current installations-Display/operating unit rear left,not installed,
IDE01992-SFT00200,Installation list: current installations-Auxiliary display/control head 2,not installed,
IDE01992-SFT00222,Installation list: current installations-charging device 1 for mobile end device,installed,
IDE01992-SFT00223,Installation list: current installations-charging device 2 for mobile end device,not installed,
IDE01992-SFT00224,Installation list: current installations-Auxiliary display/control head 1,not installed,
IDE01992-SFT271943,Installation list: current installations-Multimedia system control head,not installed,
IDE01993-MAS00478,Control module reference number-Reserved,00,
IDE01993-MAS14306,Control module reference number-Windshield projection head up display control module,04,
IDE01993-SFT00014,Control module reference number-Media Player 1,70,
IDE01993-SFT00023,Control module reference number-Instrument cluster,02,
IDE01993-SFT00071,Control module reference number-Sound System,6F,
IDE01993-SFT00078,Control module reference number-Display/operating unit rear right,A7,
IDE01993-SFT00086,Control module reference number-Radio,18,
IDE01993-SFT00087,Control module reference number-TV Tuner,6D,
IDE01993-SFT00094,Control module reference number-Display/operating unit rear left,A8,
IDE01993-SFT00095,Control module reference number-Information electronics 1,73,
IDE01993-SFT00127,Control module reference number-Information electronics 2,01,
IDE01993-SFT00200,Control module reference number-Auxiliary display/control head 2,AB,
IDE01993-SFT00222,Control module reference number-charging device 1 for mobile end device,A5,
IDE01993-SFT00223,Control module reference number-charging device 2 for mobile end device,A6,
IDE01993-SFT00224,Control module reference number-Auxiliary display/control head 1,AA,
IDE01993-SFT33032,Control module reference number-Control unit for hood ornament,C3,
IDE01993-SFT271943,Control module reference number-Multimedia system control head,03,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG170421,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG170421,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG170421,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG170421,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02182-MAS01167,Remote control for volume-Actuation time,0 s,
IDE02182-ENG170421,Remote control for volume-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,5,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,28, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,24, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,22, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,21, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,12,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,22,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,12,
IDE02384-MAS00076,Status of event memory-Instrument cluster control module,OK,
IDE02384-MAS00839,Status of event memory-TV Tuner,OK,
IDE02384-MAS00844,Status of event memory-Radio,OK,
IDE02384-MAS00847,Status of event memory-Digital Sound System Control Module,OK,
IDE02384-MAS00849,Status of event memory-Information electronics control module 1,Malfunction,
IDE02384-MAS00850,Status of event memory-Information electronics control module 2,OK,
IDE02384-MAS04300,Status of event memory-DVD changer,OK,
IDE02384-MAS14306,Status of event memory-Windshield projection head up display control module,OK,
IDE02384-SFT00078,Status of event memory-Display/operating unit rear right,OK,
IDE02384-SFT00094,Status of event memory-Display/operating unit rear left,OK,
IDE02384-SFT00200,Status of event memory-Auxiliary display/control head 2,OK,
IDE02384-SFT00222,Status of event memory-charging device 1 for mobile end device,OK,
IDE02384-SFT00223,Status of event memory-charging device 2 for mobile end device,OK,
IDE02384-SFT00224,Status of event memory-Auxiliary display/control head 1,OK,
IDE02384-SFT271943,Status of event memory-Multimedia system control head,OK,
IDE02384-ENG147282,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG176424,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG176458,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG176476,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG176459,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG176512,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG152743,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG147299,Status of event memory-ECU Dtc Bit 7,OK,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG170421,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,0,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Not available,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,163, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,No signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,02,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG170421,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG170421,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG170421,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02766,Malfunction status,00 00,
IDE02766,Malfunction status,00 80,
IDE02766-ENG249300,Malfunction status-amount_communication_errors,1,
IDE03150-MAS00076,Readiness for bus sleep mode-Instrument cluster control module,Wake,
IDE03150-MAS00839,Readiness for bus sleep mode-TV Tuner,Wake,
IDE03150-MAS00844,Readiness for bus sleep mode-Radio,sleep,
IDE03150-MAS00847,Readiness for bus sleep mode-Digital Sound System Control Module,Wake,
IDE03150-MAS00849,Readiness for bus sleep mode-Information electronics control module 1,Wake,
IDE03150-MAS00850,Readiness for bus sleep mode-Information electronics control module 2,Wake,
IDE03150-MAS04300,Readiness for bus sleep mode-DVD changer,Wake,
IDE03150-MAS14306,Readiness for bus sleep mode-Windshield projection head up display control module,sleep,
IDE03150-SFT00078,Readiness for bus sleep mode-Display/operating unit rear right,sleep,
IDE03150-SFT00094,Readiness for bus sleep mode-Display/operating unit rear left,sleep,
IDE03150-SFT00200,Readiness for bus sleep mode-Auxiliary display/control head 2,sleep,
IDE03150-SFT00222,Readiness for bus sleep mode-charging device 1 for mobile end device,sleep,
IDE03150-SFT00223,Readiness for bus sleep mode-charging device 2 for mobile end device,sleep,
IDE03150-SFT00224,Readiness for bus sleep mode-Auxiliary display/control head 1,sleep,
IDE03150-SFT271943,Readiness for bus sleep mode-Multimedia system control head,sleep,
IDE03150-ENG147328,Readiness for bus sleep mode-Sleep Bit 0,sleep,
IDE03150-ENG176564,Readiness for bus sleep mode-Sleep Bit 1,sleep,
IDE03150-ENG176563,Readiness for bus sleep mode-Sleep Bit 2,sleep,
IDE03150-ENG176562,Readiness for bus sleep mode-Sleep Bit 3,sleep,
IDE03150-ENG176561,Readiness for bus sleep mode-Sleep Bit 4,sleep,
IDE03150-ENG176560,Readiness for bus sleep mode-Sleep Bit 5,sleep,
IDE03150-ENG152747,Readiness for bus sleep mode-Sleep Bit 6,sleep,
IDE03150-ENG147327,Readiness for bus sleep mode-Sleep Bit 7,sleep,
IDE03477-MAS00106,GPS time-Year,2025,
IDE03477-MAS00107,GPS time-Month,4,
IDE03477-MAS00108,GPS time-Day,30,
IDE03477-MAS00109,GPS time-Hours,7,
IDE03477-MAS00110,GPS time-Minutes,24,
IDE03477-MAS00111,GPS time-Seconds,48,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,Not available,
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,Not available,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,95,
IDE03880-MAS03425,MOST address-Physical address,1024,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,25, min
IDE04317-MAS00108,Total system run time-Day,20, d
IDE04317-MAS00109,Total system run time-Hours,5, H
IDE04317-MAS00110,Total system run time-Minutes,26, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG117822,Bus identification-BusIdentifier,|Bus Identifier|Bus master|Optical data bus|Optical data bus|Optical data bus|Optical data bus|Optical data bus|Optical data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|MIB data bus|Unknown (0)|Unknown (0)|Unknown (0)|Unknown (0)|Unknown (0)|Unknown (0)|Unknown (0)|,
IDE04484,Regional codes,FE,
IDE04484,Regional codes,Not available,
IDE04484-MAS01632,Regional codes-Status,not active,
IDE04484-MAS03230,Regional codes-Optical drive,0,
IDE04543-MAS00866,Authorization level for protection of minors-system origin,0,
IDE04543-MAS03778,Authorization level for protection of minors-Active media source,Not available,
IDE04546-IDE00301,Calibration of navigation-Distance,25.34, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,not calibrated,
IDE04640,Over-temperature protection for amplifier,0,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,2760, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE05106-MAS01167,Diagnostic connection for external audio sources-Actuation time,0 s,
IDE05106-ENG170421,Diagnostic connection for external audio sources-IoReached Status,Output diagnostic test not active,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05108-MAS01167,Test image display unit 2 for multimedia system-Actuation time,0 s,
IDE05108-ENG170421,Test image display unit 2 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05109-MAS01167,Test image display unit 3 for multimedia system-Actuation time,0 s,
IDE05109-ENG170421,Test image display unit 3 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05277-MAS04210,Available changes in regional codes-Available changes DVD,5,
IDE05277-MAS04211,Available changes in regional codes-Available changes Blue-Ray,5,
IDE05277-MAS04285,Available changes in regional codes-Regional codes DVD,1,
IDE05277-MAS04286,Available changes in regional codes-Blue-ray regional codes,1,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,Not available,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,NOT-DEFINED,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,NOT-DEFINED,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,NOT-DEFINED,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,NOT-DEFINED,
IDE05596-MAS00106,Last time GPS position outside map-Year,2025,
IDE05596-MAS00107,Last time GPS position outside map-Month,4,
IDE05596-MAS00108,Last time GPS position outside map-Day,17,
IDE05596-MAS00109,Last time GPS position outside map-Hours,12,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,57,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,45,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,Not available,
IDE05700-MAS04393,USB connection-USB device class,Not available,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,Not available,
IDE05700-MAS06173,USB connection-Protocol,Not available,
IDE05700-MAS06174,USB connection-Product ID,Not available,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,55, %
IDE05726,Dimmer terminal 58xd,21.73, %
IDE05814,Individualization characteristic,65 EA 60 97 B8,
IDE06028-MAS02317,Control head button operation-Button code 1,Not available,
IDE06028-MAS02318,Control head button operation-Button code 2,Not available,
IDE06028-MAS04151,Control head button operation-Joystick,Not available,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,Not available,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Current,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,0, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,0, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,0, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,59, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,0, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,51, °C
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,51, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,32, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,46, °C
IDE06857-IDE00668,Microphone for vehicle noise-Microphone voltage consumption,6.10, mA
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,E1,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07839-MAS01424,Processor temperature-max.value,70, °C
IDE07839-MAS01425,Processor temperature-min.value,15, °C
IDE07839-MAS02238,Processor temperature-Current,60, °C
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
IDE11034-MAS01482,Satellite radio: module information-Hardware version,0          ,
IDE11034-MAS11961,Satellite radio: module information-Serial number,57MQRD4J,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,8E D0 88 00 35 37 4D 51 52 44 34 4A 00 02 98 02 8A 38 64 68 F5 31 71 89 05 FE 18 02 2E 03 20 44 E8 F8 E6 0B 1C 87 00 0A 00 C9 00 0A 00 0A 00 C9 00 0A,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,11.46.1    ,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,SXE_DL_V1.3,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,-----------,
IDE11034-MAS11966,Satellite radio: module information-Database Version,3.1.22     ,
IDE11034-ENG249454,Satellite radio: module information-apogee_traffic,-----------,
IDE11034-ENG249326,Satellite radio: module information-canadian_fuel,-----------,
IDE11034-ENG249344,Satellite radio: module information-channel_arts,-----------,
IDE11034-ENG249291,Satellite radio: module information-ev_stations,-----------,
IDE11034-ENG249490,Satellite radio: module information-fuel_stations,-----------,
IDE11034-ENG249493,Satellite radio: module information-internal_sxm,1.6.6.5    ,
IDE11034-ENG249368,Satellite radio: module information-movies,-----------,
IDE11034-ENG249268,Satellite radio: module information-Parking,-----------,
IDE11034-ENG249458,Satellite radio: module information-phonetics,-----------,
IDE11034-ENG249496,Satellite radio: module information-safety_alerts,-----------,
IDE11034-ENG176820,Satellite radio: module information-States,-----------,
IDE11034-ENG249463,Satellite radio: module information-stocks,-----------,
IDE11034-ENG249431,Satellite radio: module information-sxm_pics,-----------,
IDE11034-ENG249499,Satellite radio: module information-tabular_weather,-----------,
IDE11034-ENG249467,Satellite radio: module information-weather_alerts,-----------,
IDE11504,Satellite radio tuner: pre-activated subscription,Yes,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 73|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 17|FF 14 00 00 00 00 00 00 00 00 00 00 00 03 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|7|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|28 63 BD 12 ED 3D|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,82,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10
IDE12277-MAS01632,External optical drive (USB): status-Status,Open circuit,
IDE12625,IP network: current link deceleration: branch 1,65535, ns
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
IDE12806-MAS00076,Diagnostic capability of the bus interface-Instrument cluster control module,Control module/bus interface diagnostics capable,
IDE12806-MAS00839,Diagnostic capability of the bus interface-TV Tuner,Control module/bus interface not diagnostics capable,
IDE12806-MAS00844,Diagnostic capability of the bus interface-Radio,Control module/bus interface not diagnostics capable,
IDE12806-MAS00847,Diagnostic capability of the bus interface-Digital Sound System Control Module,Control module/bus interface not diagnostics capable,
IDE12806-MAS00849,Diagnostic capability of the bus interface-Information electronics control module 1,Control module/bus interface diagnostics capable,
IDE12806-MAS00850,Diagnostic capability of the bus interface-Information electronics control module 2,Control module/bus interface not diagnostics capable,
IDE12806-MAS04300,Diagnostic capability of the bus interface-DVD changer,Control module/bus interface not diagnostics capable,
IDE12806-MAS14306,Diagnostic capability of the bus interface-Windshield projection head up display control module,Control module/bus interface diagnostics capable,
IDE12806-SFT00078,Diagnostic capability of the bus interface-Display/operating unit rear right,Control module/bus interface not diagnostics capable,
IDE12806-SFT00094,Diagnostic capability of the bus interface-Display/operating unit rear left,Control module/bus interface not diagnostics capable,
IDE12806-SFT00200,Diagnostic capability of the bus interface-Auxiliary display/control head 2,Control module/bus interface not diagnostics capable,
IDE12806-SFT00222,Diagnostic capability of the bus interface-charging device 1 for mobile end device,Control module/bus interface diagnostics capable,
IDE12806-SFT00223,Diagnostic capability of the bus interface-charging device 2 for mobile end device,Control module/bus interface not diagnostics capable,
IDE12806-SFT00224,Diagnostic capability of the bus interface-Auxiliary display/control head 1,Control module/bus interface not diagnostics capable,
IDE12806-SFT271943,Diagnostic capability of the bus interface-Multimedia system control head,Control module/bus interface not diagnostics capable,
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECU ID
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13420-MAS01632,Navigation data bank: status-Status,valid,
IDE13420-ENG98502,Navigation data bank: status-Data,|Country Code,Version number|00 09 45
IDE13623-MAS01632,Interface for external media 2: status-Status,OK,
IDE13939-MAS01167,Display unit test image in the Instrument cluster control module-Actuation time,0 s,
IDE13939-ENG170421,Display unit test image in the Instrument cluster control module-IoReached Status,Output diagnostic test not active,
IDE13940-MAS17168,Multimedia display unit 1 operating sensors-Touchscreen: touch recognition,not detected,
IDE13940-MAS17169,Multimedia display unit 1 operating sensors-Touchscreen: activation,Not operated,
IDE14045-MAS17168,Multimedia display unit 2 operating sensors-Touchscreen: touch recognition,not detected,
IDE14045-MAS17169,Multimedia display unit 2 operating sensors-Touchscreen: activation,Not operated,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG170421,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14142-IDE09193,External sound amplifier: temperature status-Temperature sensor 1,53, °C
IDE14142-IDE09194,External sound amplifier: temperature status-Temperature sensor 2,58, °C
IDE14142-IDE09195,External sound amplifier: temperature status-Temperature sensor 3,70, °C
IDE14142-IDE09196,External sound amplifier: temperature status-Temperature sensor 4,Measured value not available or parameter outside measur.range,
IDE14142-IDE09197,External sound amplifier: temperature status-Temperature sensor 5,Measured value not available or parameter outside measur.range,
IDE14142-MAS17875,External sound amplifier: temperature status-Function level,0,
IDE14142-MAS17876,External sound amplifier: temperature status-Temperature sensor 6,Measured value not available or parameter outside measur.range,
IDE14142-MAS17877,External sound amplifier: temperature status-Temperature sensor 7,Measured value not available or parameter outside measur.range,
IDE14142-MAS17878,External sound amplifier: temperature status-Temperature sensor 8,Measured value not available or parameter outside measur.range,
IDE14143,External sound amplifier: supply voltage,11.40, V
IDE14144-MAS00849,Automotive audio bus (A2B): protocol version-Information electronics control module 1,1.16,
IDE14144-MAS17874,Automotive audio bus (A2B): protocol version-External sound amplifier,1.30,
IDE14145-MAS17168,Multimedia display unit 3 operating sensors-Touchscreen: touch recognition,not detected,
IDE14145-MAS17169,Multimedia display unit 3 operating sensors-Touchscreen: activation,Not operated,
IDE14146-MAS01159,Digital Transmission Content Protection (DTCP) device certificate-Version number,0,
IDE14146-MAS01779,Digital Transmission Content Protection (DTCP) device certificate-Length,0,
IDE14146-MAS06742,Digital Transmission Content Protection (DTCP) device certificate-Certificate type,0,
IDE14146-MAS18364,Digital Transmission Content Protection (DTCP) device certificate-SRM ID (System Renewability Message),0,
IDE14344-MAS19021,Automotive audio bus (A2B): status-Master activation status,activated,
IDE14344-MAS19042,Automotive audio bus (A2B): status-Startup behavior,optimized,
IDE14344-MAS19046,Automotive audio bus (A2B): status-Master bus status,electrically OK,
IDE14344-MAS19050,Automotive audio bus (A2B): status-Master Versions ID,Deactivated,
IDE14344-MAS19051,Automotive audio bus (A2B): status-Slave 1 Name,External sound amplifier,
IDE14344-MAS19052,Automotive audio bus (A2B): status-Slave 2 Name,Emergency call module and communication unit,
IDE14344-MAS19053,Automotive audio bus (A2B): status-Slave 3 Name,Deactivated,
IDE14344-MAS19054,Automotive audio bus (A2B): status-Slave 4 Name,Deactivated,
IDE14344-MAS19055,Automotive audio bus (A2B): status-Slave 5 Name,Deactivated,
IDE14344-MAS19056,Automotive audio bus (A2B): status-Slave 6 Name,Deactivated,
IDE14344-MAS19057,Automotive audio bus (A2B): status-Slave 7 Name,Deactivated,
IDE14344-MAS19058,Automotive audio bus (A2B): status-Slave 8 Name,Deactivated,
IDE14344-MAS19059,Automotive audio bus (A2B): status-Slave 9 Name,Deactivated,
IDE14344-MAS19060,Automotive audio bus (A2B): status-Slave 1 Status,electrically OK,
IDE14344-MAS19061,Automotive audio bus (A2B): status-Slave 2 Status,Not available,
IDE14344-MAS19062,Automotive audio bus (A2B): status-Slave 3 Status,Deactivated,
IDE14344-MAS19063,Automotive audio bus (A2B): status-Slave 4 Status,Deactivated,
IDE14344-MAS19064,Automotive audio bus (A2B): status-Slave 5 Status,Deactivated,
IDE14344-MAS19065,Automotive audio bus (A2B): status-Slave 6 Status,Deactivated,
IDE14344-MAS19066,Automotive audio bus (A2B): status-Slave 7 Status,Deactivated,
IDE14344-MAS19067,Automotive audio bus (A2B): status-Slave 8 Status,Deactivated,
IDE14344-MAS19068,Automotive audio bus (A2B): status-Slave 9 Status,Deactivated,
IDE14344-MAS19069,Automotive audio bus (A2B): status-Slave 1 Versions ID,Deactivated,
IDE14344-MAS19070,Automotive audio bus (A2B): status-Slave 2 Versions ID,Deactivated,
IDE14344-MAS19071,Automotive audio bus (A2B): status-Slave 3 Versions ID,Deactivated,
IDE14344-MAS19072,Automotive audio bus (A2B): status-Slave 4 Versions ID,Deactivated,
IDE14344-MAS19073,Automotive audio bus (A2B): status-Slave 5 Versions ID,Deactivated,
IDE14344-MAS19074,Automotive audio bus (A2B): status-Slave 6 Versions ID,Deactivated,
IDE14344-MAS19075,Automotive audio bus (A2B): status-Slave 7 Versions ID,Deactivated,
IDE14344-MAS19076,Automotive audio bus (A2B): status-Slave 8 Versions ID,Deactivated,
IDE14344-MAS19077,Automotive audio bus (A2B): status-Slave 9 Versions ID,Deactivated,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,0, min
IDE14733-MAS00111,SDARS subscription status-Seconds,0, s
IDE14733-MAS10690,SDARS subscription status-Activation condition,active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,0,
IDE14734-MAS01766,SDARS Service Status-Traffic data,freely available (free to air),
IDE14734-MAS19037,SDARS Service Status-Audio Service,active,
IDE14734-MAS19040,SDARS Service Status-Travel link,freely available (free to air),
IDE15385-MAS06854,Patch version for information electronics-Version,0000,
IDE15386-MAS20717,Time stamp for software update-Update 1,no update started,
IDE15386-MAS20723,Time stamp for software update-Update start date,--.--.----,
IDE15386-MAS20723,Time stamp for software update-Update start date,--.--.---,
IDE15386-MAS20723,Time stamp for software update-Update start date,-.------:-,
IDE15386-MAS20724,Time stamp for software update-Update start time,---:--:-,
IDE15386-MAS20724,Time stamp for software update-Update start time,--:--:--,
IDE15386-MAS20724,Time stamp for software update-Update start time,-:----.,
IDE15386-MAS20725,Time stamp for software update-Update end date,---.--.---,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.--.----,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.---.---,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.------:,
IDE15386-MAS20725,Time stamp for software update-Update end date,--.Ý,
IDE15386-MAS20726,Time stamp for software update-Update end time,---:--:-,
IDE15386-MAS20726,Time stamp for software update-Update end time,--:--:--,
IDE15386-MAS20726,Time stamp for software update-Update end time,--:----.,
IDE15386-MAS20726,Time stamp for software update-Update end time,öb,
IDE15386-MAS20727,Time stamp for software update-Update 2,no update started,
IDE15386-MAS20728,Time stamp for software update-Update 3,no update started,
IDE15386-MAS20729,Time stamp for software update-Update 4,no update started,
IDE15386-MAS20730,Time stamp for software update-Update 5,no update started,
IDE15386-MAS20731,Time stamp for software update-Update 6,no update started,
IDE15386-MAS20732,Time stamp for software update-Update 7,no update started,
IDE15386-MAS20733,Time stamp for software update-Update 8,no update started,
IDE15386-MAS20734,Time stamp for software update-Update 9,no update started,
IDE15386-MAS20735,Time stamp for software update-Update 10,no update started,
IDE15386-MAS20736,Time stamp for software update-Update 11,no update started,
IDE15386-MAS20737,Time stamp for software update-Update 12,no update started,
IDE15386-MAS20738,Time stamp for software update-Update 13,no update started,
IDE15386-MAS20739,Time stamp for software update-Update 14,no update started,
IDE15386-MAS20740,Time stamp for software update-Update 15,no update started,
IDE15386-MAS20741,Time stamp for software update-Update 16,no update started,
IDE15386-MAS20742,Time stamp for software update-Update 17,no update started,
IDE15386-MAS20743,Time stamp for software update-Update 18,no update started,
IDE15386-MAS20744,Time stamp for software update-Update 19,no update started,
IDE15386-MAS20745,Time stamp for software update-Update 20,no update started,
IDE15386-MAS20746,Time stamp for software update-Update 21,no update started,
IDE15386-MAS20747,Time stamp for software update-Update 22,no update started,
IDE15386-MAS20748,Time stamp for software update-Update 23,no update started,
IDE15386-MAS20749,Time stamp for software update-Update 24,no update started,
IDE15386-MAS20750,Time stamp for software update-Update 25,no update started,
IDE15386-MAS20751,Time stamp for software update-Update 26,no update started,
IDE15386-MAS20752,Time stamp for software update-Update 27,no update started,
IDE15386-MAS20753,Time stamp for software update-Update 28,no update started,
IDE15386-MAS20754,Time stamp for software update-Update 29,Unknown (45)
IDE15386-MAS20755,Time stamp for software update-Update 30,Unknown (45)
IDE15386-MAS20756,Time stamp for software update-Update 31,Unknown (45)
IDE15386-MAS20757,Time stamp for software update-Update 32,Unknown (45)
IDE15386-MAS20758,Time stamp for software update-Update 33,Unknown (45)
IDE15386-MAS20759,Time stamp for software update-Update 34,Unknown (45)
IDE15386-MAS20760,Time stamp for software update-Update 35,Unknown (45)
IDE15386-MAS20761,Time stamp for software update-Update 36,Unknown (45)
IDE15386-MAS20762,Time stamp for software update-Update 37,Unknown (45)
IDE15386-MAS20763,Time stamp for software update-Update 38,Unknown (45)
IDE15386-MAS20764,Time stamp for software update-Update 39,Unknown (45)
IDE15386-MAS20765,Time stamp for software update-Update 40,Unknown (45)
IDE15386-MAS20766,Time stamp for software update-Update 41,Unknown (45)
IDE15386-MAS20767,Time stamp for software update-Update 42,Unknown (45)
IDE15386-MAS20768,Time stamp for software update-Update 43,Unknown (45)
IDE15386-MAS20769,Time stamp for software update-Update 44,Unknown (45)
IDE15386-MAS20770,Time stamp for software update-Update 45,Unknown (45)
IDE15386-MAS20771,Time stamp for software update-Update 46,Unknown (45)
IDE15386-MAS20772,Time stamp for software update-Update 47,Unknown (45)
IDE15386-MAS20773,Time stamp for software update-Update 48,Unknown (45)
IDE15386-MAS20774,Time stamp for software update-Update 49,Unknown (45)
IDE15386-MAS20775,Time stamp for software update-Update 50,Unknown (45)
IDE15507-MAS07130,Container for software application: identification-Number of ID steps,31,
IDE15507-ENG98502,Container for software application: identification-Data,||sha256:7ec|sha256:d79|sha256:d0c|sha256:6c9|sha256:a68|sha256:dd8|sha256:511|sha256:ff8|sha256:f4d|sha256:e8c|sha256:773|sha256:517|sha256:92c|sha256:d09|sha256:582|sha256:860|sha256:34d|sha256:b69|sha256:96e|sha256:553|sha256:cd9|sha256:11c|sha256:528|sha256:304|sha256:e49|sha256:b36|sha256:db8|sha256:440|sha256:4af|sha256:925|sha256:d4d|,
IDE15508-MAS07130,Container for software application: detailed information-Number of ID steps,7,
IDE15508-ENG98502,Container for software application: detailed information-Data,|Service_ID,version_major
IDE15509-ENG255359,Container for software application: system resources-apps_RAM,204,
IDE15509-ENG255554,Container for software application: system resources-cpu_usage_apps,0, %
IDE15509-ENG255555,Container for software application: system resources-cpu_usage_total,28, %
IDE15509-ENG255735,Container for software application: system resources-free_memory,5234,
IDE15509-ENG255736,Container for software application: system resources-free_RAM,116,
IDE15509-ENG256092,Container for software application: system resources-number_of_containers,7,
IDE15509-ENG256093,Container for software application: system resources-number_of_images,31,
IDE15509-ENG256095,Container for software application: system resources-number_of_used_ports,12,
IDE15509-ENG256555,Container for software application: system resources-used_memory,377,
IDE15509-ENG256556,Container for software application: system resources-used_RAM,4903,
IDE15942-MAS01167,Left front treble speaker motor: Status-Actuation time,0 s,
IDE15942-ENG170421,Left front treble speaker motor: Status-IoReached Status,Output diagnostic test not active,
IDE15943-MAS01167,Right front treble speaker motor: Status-Actuation time,0 s,
IDE15943-ENG170421,Right front treble speaker motor: Status-IoReached Status,Output diagnostic test not active,
IDE15951,Joker button: function assignment,31084431849909859,
IDE15974,Joker button 2: function assignment,31084431849909859,
MAS00775-IDE03619,Multimedia display unit 2-System condition,On,
MAS00775-IDE05228,Multimedia display unit 2-Operating hour counter,397, H
MAS00775-MAS00110,Multimedia display unit 2-Minutes,27, min
MAS00775-MAS01634,Multimedia display unit 2-Supply voltage,11.40, V
MAS00775-MAS02200,Multimedia display unit 2-Highest measured temperature,60, °C
MAS00775-MAS02201,Multimedia display unit 2-Temperature,36, °C
MAS00775-MAS03691,Multimedia display unit 2-Dimming,100, %
MAS00778-IDE03619,Multimedia display unit 1-System condition,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,397, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,27, min
MAS00778-MAS01634,Multimedia display unit 1-Supply voltage,11.50, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,64, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,37, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,98.70, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,39,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,39,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),Not available,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,Not available,
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,32,
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS17268,Functions which can be activated: connection error counter,1,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 04 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,not OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,12,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG151179,Error_code_external_optical_usb_drive,Not available,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Available,
ENG179902-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG179902-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,00 04 01 00,
ENG179902-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,Available,
ENG179902-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,not OK,
ENG179902-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG179902-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG179902-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition met,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,12,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG249161-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,15 s,
ENG249161-ENG170421,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
ENG249168-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG249168-ENG170421,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249169-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG249169-ENG170421,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG249171-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG249171-ENG170421,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG249172-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG249172-ENG170421,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG249173-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG249173-ENG170421,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG249174-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG249174-ENG170421,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG249175-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG249175-ENG170421,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG249176-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG249176-ENG170421,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG249177-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG249177-ENG170421,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG249178-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG249178-ENG170421,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249179-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG249179-ENG170421,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249180-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG249180-ENG170421,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249197-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG249197-ENG170421,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG249198-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG249198-ENG170421,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 01:16
KingArthur
Manila, Phillipines
C?ID=590845
adpmap-75-4K2-035-284-A_WU1ARBF13MD033663-20250430-1526.CSV
;SW:4K2-035-284-A   HW:4K2-035-284-B ---  Telematics
;Component:CB_H_CAN      041 0236, Coding:01E0E0F9C04080F6E0
;EV_ConBoxHighAU49X,001004,EV_ConBoxHighAU49X_VW53.rod
;Wednesday,30,April,2025,15:26:50:13393
;VCID: 28028B93A2705E5AE7A-807C
IDE00001-MAS00951-Production mode-Bluetooth,not active ,3
IDE00001-MAS03782-Production mode-WLAN,not active ,3
IDE00001-MAS17528-Production mode-Mobile communications network: configuration,not active ,3
IDE00761-MAS19772-Run-on time-Online data connection,240 H,6
IDE00761-MAS19773-Run-on time-SMS availability,384 H,6
IDE00761-MAS19774-Run-on time-Home network search,30 min,6
IDE00761-MAS19776-Run-on time-Ping frequency of data connection to back end,7 min,6
IDE00768-Country identification: country of sale,CA ,2
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,not active ,1
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06425-Dynamometer mode: functional,Unknown (0xF1),1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE10082-MAS17529-Telephone functions configuration-Support for second telephone,On ,1
IDE10082-MAS17530-Telephone functions configuration-Support parallel phone calls,On ,1
IDE10082-MAS17531-Telephone functions configuration-Support for call holding function,OFF ,1
IDE11638-Bluetooth Audio Codec,00 ,1
IDE13338-Basic functions connect,not activated ,1
IDE14089-Bluetooth Low Energy,On ,1
IDE14093-MAS13846-Emergency call module and communication unit: configuration-Internet access via WiFi,Not available ,2
IDE14093-MAS17936-Emergency call module and communication unit: configuration-WLAN 5GHz,On ,2
IDE14093-MAS17940-Emergency call module and communication unit: configuration-MAP SMS,On ,2
IDE14093-MAS17941-Emergency call module and communication unit: configuration-MAP e-mail,On ,2
IDE14093-MAS17942-Emergency call module and communication unit: configuration-MAP Instant Messaging,On ,2
IDE14093-MAS17943-Emergency call module and communication unit: configuration-Sms via SIM,OFF ,2
IDE14093-MAS17944-Emergency call module and communication unit: configuration-Sms via eSIM,OFF ,2
IDE14093-MAS17945-Emergency call module and communication unit: configuration-Bluetooth headset telephone,OFF ,2
IDE14093-MAS20485-Emergency call module and communication unit: configuration-WLAN Client Mode 2.4 GHz,OFF ,2
IDE14093-MAS20486-Emergency call module and communication unit: configuration-WLAN Client Mode 5 Ghz,OFF ,2
IDE14093-MAS20487-Emergency call module and communication unit: configuration-WiFi hotspot 2.4 Ghz,On ,2
IDE14093-MAS20488-Emergency call module and communication unit: configuration-WiFi Hotspot 5 Ghz,On ,2
IDE14159-MAS17894-Emergency call module and communication unit: basic functions-Language transfer via LTE (VoLTE),On ,1
IDE14159-MAS17895-Emergency call module and communication unit: basic functions-Satellite navigation (GPS),On ,1
IDE14159-MAS17896-Emergency call module and communication unit: basic functions-Satellite navigation (Galileo),On ,1
IDE14159-MAS17897-Emergency call module and communication unit: basic functions-Satellite navigation (Glonass),On ,1
IDE14159-MAS17898-Emergency call module and communication unit: basic functions-Satellite navigation (Beidou),On ,1
IDE15335-MAS20504-Vehicle name information electronics-Prefix,Audi_MMI_ ,42
IDE15335-MAS20505-Vehicle name information electronics-Postfix 2.4 GHz, ,42
IDE15335-MAS20506-Vehicle name information electronics-Postfix 5 GHz,_5GHz ,42
IDE15361-MAS13846-WLAN settings-Internet access via WiFi,activated ,4
IDE15361-MAS20496-WLAN settings-Channel number for 2.4 GHz WLAN,6 ,4
IDE15361-MAS20497-WLAN settings-Channel number for 5 GHz WLAN,0 ,4
IDE15361-MAS20498-WLAN settings-Password synchronization,Synchronized ,4
IDE15361-MAS20499-WLAN settings-2.4 GHz band visibility,visible ,4
IDE15361-MAS20500-WLAN settings-5 GHz band visibility,visible ,4
IDE15361-MAS20501-WLAN settings-2.4 GHz band bandwidth,Channel width 20 MHz ,4
IDE15361-MAS20502-WLAN settings-5 GHz band bandwidth,Channel width 40 MHz ,4
IDE15361-MAS20507-WLAN settings-IP configuration validity period (DHCP),72 H,4
IDE15362-MAS20508-Smartphone configuration-Apple CarPlay Wireless,On ,1
IDE15362-MAS20509-Smartphone configuration-Google Android Auto Wireless,OFF ,1
IDE15362-MAS20510-Smartphone configuration-Baidu CarLife Wireless (Android),OFF ,1
IDE15362-MAS20511-Smartphone configuration-Baidu CarLife Wireless (iOS),OFF ,1
IDE15384-Backup battery for emergency call: number of cells,Two cells ,1
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG179020-eCall_Configuration,AUTO ,1
ENG251749-Protection_CSR_1024_WakeUp,40 ,1
ENG251750-Protection_RH850_WakeUp,40 ,1
Elapsed Time: 00:08
Westbury, UK
@KingArthur please stop posting the scan etc multiple times - and using the code tags wrong - I've tidied it a couple of times & CBA to do it any more :banghead:
KingArthur
Manila, Phillipines
C?ID=590845
Sorry, 1st time to post. thanks for tidying up & pointing it out. I thought i was post ing 5f & 75 maps & adaptations hence the 4 post.
Westbury, UK
Removed multiple scans, leaving just 1 scan and the 5F and 75 adaptations :thumbs:
KingArthur
Manila, Phillipines
C?ID=590845
Is there a way to eliminate open exhaust, loud start ups specially in the mornings?
Fix whatever is ailing the Exhaust Pressure Control Valve(s)?
KingArthur
Manila, Phillipines
C?ID=590845
Can we trick the temp sensor or bypass to signal normal temp readings?
I think that is programed into the CanBus system ; my 2024 RS5 does just that on cold start-ups : when vehicle is started initially, you can hear the exhaust (sound) valves cycle once. They are open, momentarily and then close.
If you post a channel map of the Address 01: Engine, someone may comment on a potential tweak (??).
KingArthur
Manila, Phillipines
C?ID=590845
awesome! lets try that.
also saw an adaptation of exhaust flap in basic settings, maybe this can be modified?
heres a scan of channel map address 01:
;SW:4M8-907-557-F   HW:0P2-907-309-A ---  Engine
;Component:V8 4.0l TFSI  H31 0001, Coding:2A2A0012257E010E342C6000000400000000000000000000
;EV_ECM40TFS0114M8907557F,001002,EV_ECM40TFS0114M8907557F.rod
;Monday,16,June,2025,16:13:47:13393
;VCDS Version: Release 25.3.1 (x64)  Data version: 20250604 DS365.0
;VCID: 40D233332A00861ACF9-8014
IDE04158-Activation of start/stop function,active ,1
IDE06726-Timing deviation after chain replacement: intake bank 1,0.00 °,2
IDE06727-Timing deviation after chain replacement: intake bank 2,0.00 °,2
IDE06728-Timing deviation after chain replacement: exhaust bank 1,0.00 °,2
IDE06729-Timing deviation after chain replacement: exhaust bank 2,0.00 °,2
IDE06730-Timing deviation after other repairs: intake bank 1,0.00 °,2
IDE06731-Timing deviation after other repairs: intake bank 2,0.00 °,2
IDE06732-Timing deviation after other repairs: exhaust bank 1,0.00 °,2
IDE06733-Timing deviation after other repairs: exhaust bank 2,0.00 °,2
IDE06734-Timing deviation: current value intake bank 1,0.00 °,2
IDE06735-Timing deviation: current value intake bank 2,0.00 °,2
IDE06736-Timing deviation: current value exhaust bank 1,0.00 °,2
IDE06737-Timing deviation: current value exhaust bank 2,0.00 °,2
IDE06738-Chain elongation: no. of valid initial values: intake bank 1,0 ,1
IDE06739-Chain elongation: no. of valid initial values: intake bank 2,0 ,1
IDE06740-Chain elongation: no. of valid initial values: exhaust bank 1,0 ,1
IDE06741-Chain elongation: no. of valid initial values: exhaust bank 2,0 ,1
IDE06742-Chain elongation: initial values valid: intake bank 1,not active ,1
IDE06743-Chain elongation: initial values valid: intake bank 2,not active ,1
IDE06744-Chain elongation: initial values valid: exhaust bank 1,not active ,1
IDE06745-Chain elongation: initial values valid: exhaust bank 2,not active ,1
Elapsed Time: 00:06
