I have a 2014 VW Passat TDI that had all 4 injectors replaced by the dealer under the dieselgate extended emissions warrantee about 1.5 years ago. Recently the car began to knock and run rough intermittently until recently when it became more permanent. CEL came on and gave me a code for over pressure detected on cylinder #1. Ran VCDS and checked the injector quantity deviation which looked like this at 94deg C;
cyl #1 1.38 mg/stroke
Cyl #2 .026 mg/stroke
cyl. #3 -1.37 mg/stroke
cyl. #4 -0.27 mg/stroke
Given this I decided to change injector on cyl #1.
After doing so there was essentially no change. Entered the new injector with VCDS and all just not sure where to look after this. Fuel pressure regulator, HPFP? Any help would be greatly appreciated. Just to mention, some of the faults listed are from me unplugging injector 1 and 3.
Inserting my Auto-scan here;
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 25.3.1(x64) Data version: 20250415 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,09,May,2025,15:59:35:29142
VIN: 1VWCN7A30EC060671 License Plate:
Mileage: 218240km-135608mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCN7A30EC060671 Mileage: 218240km-135608miles
Self-Diagnosis Log
Page 2
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number: CVN: D240C61F38D3FF82
Coding: 001D0012042400008000
Shop #: WSC 04998 444 00000
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B24E92B63E2BDB29A8-806E
VINID: 0669D37874430154C018018704DB070DFD
8203 - Cylinder 1 Internal Pressure Sensor
P13D0 00 [01100101] - Implausible Signal
Mileage: 218227 km
Date: 2025.04.30.
Time: 07:48:18
Engine speed: 1261.00 /min
Vehicle speed: 18 km/h
Coolant temperature: 100 °C
Intake air temperature: 31 °C
Voltage terminal 30: 14.040 V
Maximum cylinder 1 cylinder pressure: 35.641 bar
Cylinder 1 max pressure position in deceleration mode: 1.03 °
Cylinder_pressure_offset_cylinder_1: -3.656 bar
Malfunction status of combustion chamber pressure of cylinder 1-Bits 0-7: 32
Group run time cylinder pressure sensor 1: -2.2 μs
5075 - Fuel Injector for Cylinder 1 (N30)
P1237 00 [01100000] - Open Circuit
Mileage: 218241 km
Date: 2025.05.06.
Time: 13:35:56
Engine speed: 871.00 /min
Normed load value: 49.8 %
Coolant temperature: 31 °C
Intake air temperature: 20 °C
Self-Diagnosis Log
Page 3
Allowed number of injections-Bits 0-7: 3
Injection release status-Bits 0-7: 56
Desired injection characteristic-Bits 0-7: 56
Mean injection quantity: 12.27 mg/stroke
Rail pressure regulation: status-Bits 0-7: 15
Fuel high-pressure: actual value: 366100 hPa
Control Module temperature: 23.6 °C
5077 - Fuel Injector for Cylinder 3 (N32)
P1239 00 [01100000] - Open Circuit
Mileage: 218241 km
Date: 2025.05.06.
Time: 13:51:04
Engine speed: 831.50 /min
Normed load value: 45.9 %
Coolant temperature: 77 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.340 V
Mean injection quantity: 11.68 mg/stroke
Fuel high-pressure: actual value: 368600 hPa
Control Module temperature: 33.1 °C
8735 - Cylinder 1
P0301 00 [01100100] - Misfire Detected
Mileage: 218226 km
Date: 2025.04.30.
Time: 07:46:16
Engine speed: 766.00 /min
Normed load value: 74.9 %
Coolant temperature: 96 °C
Intake air temperature: 37 °C
Self-Diagnosis Log
Page 4
Unlearning counter according OBD: 72
Mean injection quantity: 20.28 mg/stroke
Air mass: actual value (mg/stroke): 465.0 mg/stroke
Fuel temperature: 35.7 °C
Oxygen sensor 1 bank 1: lambda actual value: 1.580
Pressure control valve adaptation factor: 1.0887
Component: GSG DSG AG6 521 9437
Revision: 05652104 Serial number: 00001310011309
Shop #: WSC 09003 957 00200
VCID: 14766297227C92CA3B2-8040
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F5492800FAA31103EB921A0042A1100012
VCID: 7EA2203F30F0689AFD6-802A
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00086000 Serial number: 0194589948 Dataset Number: 5K0116v____ 560E
Coding: 130C0C
ROD: EV_KESSYPQ35G_A02_VW41.rod
VCID: 3436C2174EBC72CA5B2-8060
Self-Diagnosis Log
Page 5
Part No SW: 561 907 044 AF HW: 561 907 044 AF
Component: Climatronic H03 0606
Revision: 00001K02
Coding: 0030019012
VCID: 5BE449AB83A29DB2BA8-800E
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0173
Revision: BL122001
Coding: EF200E1B982B08D4098802012600854800F1A086458015B064806000BC70
VCID: 78AE362712D456AAB7A-802C
Self-Diagnosis Log
Page 6
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM03N6H% Dataset Number: 560003v__A_ 0126
Coding: 00004D4A
Shop #: WSC 35518 003 1048576
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B03F1305462BC2ACC-8020
Serial number: 6940000Y1300010L7D0D
Coding: 303047
Serial number: 3572MSME3A13617DZZZ.
Serial number: 3582MSME1D42147EZZZ/
Serial number: 3516KSME2B184F28ZZZ/
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME526B2229ZZZT
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME4D25032AZZZX
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME2F07032AZZZY
Self-Diagnosis Log
Page 7
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130913101323
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA027333D767382E4C-8028
Component: E221__MFL-YVJ H07 0022
Coding: E20000
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1E6200BFD030C89A9D6-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 23111303001092
Coding: 461000
VCID: 7BA4292B23E27DB2DA8-802E
Self-Diagnosis Log
Page 8
Component: IMMO H04 0811
Coding: 000007
VCID: 6A8A1C6F5CF8F43A31E-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000212318004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW41.rod
VCID: 303ECE07BAA44EEA3FA-8064
Address 2E: Media Player 3
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000082234242
Coding: 00581B0000000000000021010100202020202120202020
VCID: 221A344FE4C8EC7AB9E-8076
Self-Diagnosis Log
Page 9
Part No SW: 3C0 035 684 Q HW: 3C0 035 684 J
Component: RNS-MID H21 5382
Revision: AB001001 Serial number: VWZ6Z7N6164053
Coding: 04090042010000A6000B
VCID: 3138CB03B12E47E2304-8064
Subsystem 1 - Part No: 7L6 919 859
Component: NAR V6 7963
Fault Frequency: 193
Reset counter: 20
Mileage: 211528 km
Fault Status: 00100111
Reset counter: 19
Mileage: 213499 km
Date: 2019.08.01.
Time: 17:42:34
Self-Diagnosis Log
Page 10
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0007581193
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C660AB7C62CDA8A732-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630131126093523
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 3928F323655E8FA2884-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H07 6813
Revision: -------- Serial number: EAA098A0090032 Dataset Number: 560050v____ 5607
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 2612285F8860105AD56-8072
9457664 - Function limitation due to excessive temperature
B1050 00 [00001000] - -
[Funktioneinschränkung durch Übertemperatur]
Reset counter: 8
Mileage: 215697 km
Date: 2025.03.31.
Time: 19:35:58
Self-Diagnosis Log
Page 11
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FBC0D7B679A1112660-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011318702116
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0007623009
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D6007B3DD36D38284C-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14102631131126134247
Coding: 800000
Self-Diagnosis Log
Page 12
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Fault Frequency: 194
Reset counter: 235
Mileage: 211528 km
Reset counter: 19
Mileage: 213499 km
Date: 2019.08.01.
Time: 17:42:34
Self-Diagnosis Log
Page 13
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0086
Serial number: 000003554140510
Coding: 02140102C2423A007F1606000000
ROD: EV_OCULow_001_VW41.rod
VCID: 53F4A18BEB7255F2628-8006
12670464 - Databus
[CAN TO brake]
Reset counter: 19
Mileage: 215697 km
Date: 2025.04.01.
Time: 19:33:27
0035 - Databus
[CAN TO Airbag]
Reset counter: 19
Mileage: 215697 km
Date: 2025.04.01.
Time: 19:33:27
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Fault Priority: 8
Reset counter: 235
Mileage: 218241 km
Date: 2025.05.09.
Time: 15:57:58
Self-Diagnosis Log
Page 14
------------------------------12 Faults Found------------------------------
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665503279 Dataset Number: 5N0035729A 0001
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E02D07FA090581A2D6-807A
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
