Fault Code after installing a new ABS module (2020 Audi A6)
Pouswiv
Florida, USA
C?ID=619159
this is the full scan
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 25.3.1(x64) Data version: 20250415 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Friday,09,May,2025,12:31:09:64261
VIN: WAUD8AF23LN038965 License Plate: L3QDE
Mileage: 72123km-44815mi Repair Order:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 09 15 16 17 19 22 36 3C 42 44 46 52 5F 6C 75 80 81
A5 BB BC CA CF D6 D7 DE
VIN: WAUD8AF23LN038965 Mileage: 72123km-44815miles
80-Batt. reg. aux. accum. -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Self-Diagnosis Log
Page 2
LF_MVB_BUS_INTC_DIAG: 256
Part No SW: 4K0 906 259 A HW: 06L 907 425 C
Component: R4 2.0l TFSI H15 0007
Revision: --H15--- CVN: 976BC4A4
Coding: 0A6500322326010E34282000000400000000000000000000
Shop #: WSC 46472 005 1048576
ASAM Dataset: EV_ECM20TFS0204K0906259A 001009
ROD: EV_ECM20TFS0204K0906259A.rod
VCID: 2F3CCD645792FC22260-807A
VINID: 9D19542115820DC7800C824614BD541C8F
38468 - Implausible Data Received from ESP Control Module
U0416 00 [00101111] - -
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:37
Engine speed: 0.00 /min
Coolant temperature: 102 °C
Intake air temperature: 42 °C
Voltage terminal 30: 12.324 V
Engine: operating status: ES
ECU_STATE: ENG_STOP
ACC variants (coding): CCS
Drivetrain coordinator: brake fault status-ESP system error: No
23039 - Implausible Data Received from ABS Control Module
U0415 00 [00101111] - -
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Self-Diagnosis Log
Page 3
Vehicle speed: 255 km/h
Coolant temperature: 86 °C
Intake air temperature: 78 °C
Voltage terminal 30: 11.777 V
LF_MVB_PDU_INTC_DIAG_1: 0
LF_MVB_PDU_INTC_DIAG_2: 49152
LF_MVB_PDU_INTC_DIAG_3: 1571
LF_MVB_PDU_INTC_DIAG_4: 0
LF_MVB_PDU_INTC_DIAG_5: 0
LF_MVB_PDU_INTC_DIAG_6: 61472
37295 - Vehicle Speed Sensor
P0501 00 [10101000] - Implausible Signal
Mileage: 72063 km
Date: 2025.05.08
Time: 20:46:12
Engine speed: 1767.50 /min
Normed load value: 51.0 %
Coolant temperature: 97 °C
Intake air temperature: 57 °C
Voltage terminal 30: 14.140 V
FAC_TPS_1_SAE: 65.234375 %
FUP_H_SAE: 19970.0 kPa
MAP_MES_SAE: 111 kPa
Engine: operating status: PL
TAA: 29.500 °C
T_AST_SAE: 153 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
Readiness: 0000 0100
Self-Diagnosis Log
Page 4
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4K0 927 153 G HW: 0HK 927 156 B
Component: 0CJ 20TFSINAR H01 0003
Revision: --H01--- Serial number: 0000001386 CVN: 15A0B61500000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 3138CB1C41A6EAD2304-8064
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Self-Diagnosis Log
Page 5
Part No SW: 4N0 907 379 AG HW: 4N0 907 379 P
Component: ESP9 Premium H06 0853
CVN: 15B681ED
Coding: 18AA41972CA50B9E11A74897208252D2F53988188234D08812044A4BAF9C11
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 7DA0272CCD7EDEB2E4C-8028
7 Faults Found:
13762560 - Component protection
U1114 00 [00101111] - GFA key
[KS_GFA_Key]
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
75 00 03 00 C2 24 00 50 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
15361024 - Component Protection
U1101 00 [00101111] - Active
[KS_EC_other_error]
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
13697024 - Component Protection
U1100 00 [00101111] - No Basic Setting
[KS_Start_key]
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Self-Diagnosis Log
Page 6
411392 - Data Set Missing
U1118 00 [10101111] - -
[RKA_parameter_dataset_empty]
Mileage: 72058 km
Date: 2025.05.08
Time: 19:17:19
79 00 07 00 C2 24 00 50 00 00
452352 - Databus
U1123 00 [00101111] - Received Error Message
[Signal_RCTA_Status_error_(3)]
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
16060416 - Control Module
U3510 00 [10101111] - Missing Calibration / Basic Setting
[ESC_Dataset_empty_detected]
66 00 00 00 00 00 00 00 00 00
4210432 - Wheel Speed Sensors
C003F 00 [01101000] - Rotation Direction Implausible
Mileage: 72063 km
Date: 2025.05.08
Time: 20:46:12
8E 00 03 09 89 24 00 50 00 00
Self-Diagnosis Log
Page 7
Self-Diagnosis Log
Page 8
Outside air temperature sensor-Outside air temperature on CAN: 30.50 °C
Part No SW: 4N0 907 063 KG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0691
Dataset Number: 4K0909514E 0028
Coding: 07000363E0691CCD070486081CAE9C2A130B37110006009701000A0039321A01086108324257050800000100000300180002000004010100000000000000000Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016.rod
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001909060408676
Coding: 7DC727
Serial number: 23763113X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 C HW: 4K1 941 501 C
Component: E1 - LTM H09 0086
Serial number: 14S11.09.1900691142
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00J002
Coding: 250000
Subsystem 5 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE126071923611161
Interior Light Module:
Subsystem 6 - Part No SW: 4K0 947 135 AH HW: 4K0 947 135 AH
Component: Dachmodul H42 0416
Serial number: Q00812574
Coding: 0D0104
Subsystem 7 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA139591000076117744
Coding: 0A0700
Self-Diagnosis Log
Page 9
[Brake control module: received error value in signal ESP system status]
Fault Frequency: 9
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:50
average_Voltage_terminals: 11.80 V
interior_temperature: 33.00 °C
Vehicle speed: 0.00 km/h
196903 - Databus
[RCTA/SWA control module: received error value in signal RCTA_status]
Fault Frequency: 9
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:50
65896 - Databus
[Automatic high beam assist control module: high beam assist error value]
Fault Frequency: 13
Reset counter: 148
Self-Diagnosis Log
Friday,09,May,2025,12:31:10:64261
Page 10
Date: 2025.05.08
Date: 2025.05.08
Time: 20:33:01
average_Voltage_terminals: 11.70 V
Outside air temperature sensor-Outside air temperature on CAN: 32.50 °C
Self-Diagnosis Log
Page 11
Part No SW: 4N0 959 655 K HW: 4N0 959 655 K
Component: AirbagVW31 H12 2720
Serial number: 003YUM00VMLY Dataset Number: 4K0909602AF 0002
Coding: BFCCF0C000C00000A000003FF20D410000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
VCID: 44D692C8EE146F7AEB2-8010
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019272043800000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019273115800000
Coding: 04F001
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D19000C9T7I0F
Coding: 303134
Subsystem 4 - Part No SW: ----------- HW: 480 002 410 19
Serial number: 35700000000C5D84B24V
Subsystem 5 - Part No SW: ----------- HW: 480 002 310 19
Serial number: 3580000000000944F14A
Subsystem 6 - Part No SW: ----------- HW: 480 032 910 19
Component: SideSensor_Dr 002 0149
Serial number: 351002C00B214C409A3-
Subsystem 7 - Part No SW: ----------- HW: 480 032 910 19
Component: SideSensor_Pr 002 0149
Serial number: 352002C00E7A55112E30
Self-Diagnosis Log
Page 12
Subsystem 8 - Part No SW: ----------- HW: 480 031 710 19
Component: FrontSensor_D 002 0149
Serial number: 355002C00E12C5D03B24
Subsystem 9 - Part No SW: ----------- HW: 480 031 710 19
Component: FrontSensor_P 002 0149
Serial number: 356002C00E1284806C52
1055238 - Databus
[NWD: 0x11E ESP_08 error value ESC_Bremsdruckgradient]
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
1071877 - Databus
[NWD: 0x1A2 ESP_15 error value VZM_Status]
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
B13BC F2 [10001001] - No function
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:48
1055237 - Databus
U1123 00 [10001001] - Received Error Message
[NWD: 0x11E ESP_08 error value ESP_v_ref]
Self-Diagnosis Log
Page 13
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
Part No SW: 4N0 907 129 M HW: 4N0 907 129 M
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 3B24E93493EA10829A8-806E
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 870 B HW: 4K0 920 870 B
Component: TBenUS------- H09 0241
Dataset Number: 4K0909525E 0030
Coding: 8BE620C3E888D7050203E16098800B0008002000
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2B04D974638A80020A8-807E
Self-Diagnosis Log
Page 14
Address 22: AWD (J492) Labels:| 0CJ-927-749.clb
Part No SW: 4K0 907 468 L HW: 4K0 907 468 C
Component: Gateway H05 0262
Serial number: 1YF04091060001 Dataset Number: 4K0909515E 0036
Coding: 020100050020064029870000005B0132CC38000710000000097D078E10000000
GVL: E1D13C000000000000DC08008002C800100C0000004000000000000000000100
ASAM Dataset: EV_Gatew31xAU65x 003190
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 3D20E72C8DFE1EB2A4C-8068
Subsystem 1 - Part No SW: 4K0 951 523 J HW: 4K0 951 523 J
Component: E221__MFL H06 0010
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 74186313001910100479
U1101 00 [00001001] - Active
[KS_Active_1]
Reset counter: 109
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
Self-Diagnosis Log
Page 15
Part No SW: 4K0 927 755 A HW: 0CJ 927 749 A
Component: C8_DL3_N_SD1 H01 0007
Serial number: 19220A5796
Coding: 110C0000
ASAM Dataset: EV_AWDCQUOD31 001052
ROD: EV_AWDCQUOD31.rod
VCID: 3334C114BBBAD8C2428-8066
29727 - Implausible Data Received from ABS Control Module
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Battery voltage: 11.690 V
Engine current: 0.0000 A
Internal system status: 05
Actuator angle: actual value: -0.125000
Processor load: 81 %
Stack store: 00 00 00
Engine speed: 0 /min
Operating time: 90 min
Ambient temperature: 27.5 °C
End stage temperature: 51 °C
HW KL15 Debounce Time: 30 ms
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 1
SW KL15 Timeout: 0
System condition: 00 00
XCP-DAQ OdtEntryCount: 0
UDS Session: OBDII And VW Default Diagnostic Session
Standard Seed and Key unlocked: 0
Advanced Seed and Key unlocked: 0
XCP Calibration activated: 0
XCP Measurement active: 0
DEV_X_06 enabled: 0
Reserved: FF FF FF FF FF FF
Unlearning counter according OBD-OBD unlearning counter: 40
Solenoid Current-SolenoidCurrent: 0.0000 A
Sensor Speed: 0 /min
NM-State: NM_STATE_NORMAL_OPERATION
Self-Diagnosis Log
Page 16
Reset reason-ResetReason: FF 00 00 00
DTC Subcode (FR_ESP_21_SIGNAL_ERROR)-DTC SubCode: Signal not valid
29736 - Implausible Data Received from ABS Control Module
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 1
SW KL15 Timeout: 0
DEV_X_06 enabled: 0
Wakeup-Reason-Wakeup Reason: Power_Up
DTC Subcode (FR_ESP_08_SIGNAL_ERROR)-DTC SubCode: Signal not valid
29919 - Implausible Data Received from Engine Control Module
U0401 00 [00101000] - -
Self-Diagnosis Log
Page 17
Mileage: 72063 km
Date: 2025.05.08
Time: 20:46:12
Battery voltage: 14.163 V
Vehicle speed: 24.00 km/h
Engine speed: 1851 /min
Operating time: 93 min
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 1
SW KL15 Timeout: 0
DEV_X_06 enabled: 0
Unlearning counter according OBD-OBD unlearning counter: 39
Solenoid Current-SolenoidCurrent: 0.0117 A
Sensor Speed: 824 /min
DTC Subcode (FR_MOTOR_16_SIGNAL_ERROR)-DTC SubCode: Signal not valid
32070 - Implausible Data Received from ABS Control Module
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Self-Diagnosis Log
Page 18
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 1
SW KL15 Timeout: 0
DEV_X_06 enabled: 0
DTC Subcode (FR_ESP_22_SIGNAL_ERROR)-DTC SubCode: Signal not valid
33481 - VIN via Databus
C0546 00 [00101000] - Not stored or incompatible
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
Self-Diagnosis Log
Page 19
Combined KL15: 1
HW KL15 Filtered: 1
HW KL15 Raw: 1
SW KL15: 1
SW KL15 Timeout: 0
DEV_X_06 enabled: 0
Unlearning counter according OBD-OBD unlearning counter: 38
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 00000391886388 Dataset Number: 4K8909856VD 0001
Coding: 015C1A400000B4010003010101010000000000000000000000000000004000
VCID: 7BA42934D36AD082DA8-802E
Self-Diagnosis Log
Page 20
Part No SW: 4N0 907 566 H HW: 4N0 907 566 A
Component: MRR_HR H16 0267
Dataset Number: 4K8909535D 0023
Coding: 0F1B00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_AU58.rod
1191961 - Databus
[databus error value received - ESP_15_VZM_Status]
Reset counter: 108
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
Control Module temperature: 70 °C
Voltage terminal 30: 11.90 V
Terminal 15 status: On
Voltage terminal 15: Measuring value not available
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS002 0430
Serial number: YE007SIJ0531A Dataset Number: 4K8909872C 0035
Coding: 001FCB0052001480A001A032
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 46D288C0D8285D6AF56-8012
Self-Diagnosis Log
Page 21
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 4K0909852K 0002
Coding: 94002101010000
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323AC41044A0D1CA49E-8066
5258753 - Steering End Stops Not Learned
C10AC F0 [00001000] -
[IFSD_EAL_NOT_LEARNED]
Reset counter: 148
Mileage: 72063 km
Date: 2025.05.08
Time: 20:43:15
FreezeFrame_mw_1216_EAL-Steering wheel angle: 0.00 °
FreezeFrame_mw_1216_EAL-EventType: 00 00
FreezeFrame_mw_1216_EAL-SCU_motor_angle_BUS: 0.00 °
Self-Diagnosis Log
Page 22
Part No SW: 4N0 907 064 DD HW: 4N0 907 064 D
Component: BCM2 MLBevo H15 0202
Dataset Number: 4K8909501H 0042
Coding: 013400004FB000C0650FA0006C01000203024000810026502F0400000B04823F001E0101000011
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_AU49.rod
VCID: 74B60208FE349FFA9B2-8020
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY192701881
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000031763540
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14107436
Rear spoiler control module:
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS002 0430
Serial number: YE007SIJ15202 Dataset Number: 4K8909873C 0035
Coding: 001FCB005E001480A001A030
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 45D08FCCE52E5672FCC-8010
Self-Diagnosis Log
Page 23
Reset counter: 149
Part No SW: 4K0 035 202 D HW: 4K0 035 202 A
Component: MU-H-LNS-US 053 2711
Dataset Number: 4K0909545F 0037
Coding: 01850102FF0A000041220001061C00302F0006E403F00804CE
VCID: 1F1C3DA427326CA2960-804A
Subsystem 1 - Part No: V03 959 804 CH
Component: MIB2P_NA_Q120 0446
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4K1 919 604 H HW: 4K1 919 604 F
Component: DU AU58x Top H71 0171
Serial number: BHB00117101903200895
Compact disc data bank:
Component: Gracenote2 3008
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000107773009
Multimedia display unit 5:
Subsystem 5 - Part No SW: 4K1 919 603 H HW: 4K1 919 603 F
Component: DU AU58x Bot H71 0171
Serial number: BHB00117101903130483
Media socket:
Subsystem 6 - Part No SW: 4N0 035 726 A HW: 4N0 035 726
Component: MediaConnectL 014 0133
Serial number: 051900619480013
Reset counter: 108
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:59
Voltage terminal 30: 11.9 V
Self-Diagnosis Log
Page 24
Satellite radio tuner status-Audio Signal: Available
Satellite radio tuner status-Antenna current: 109 mA
Satellite radio tuner status-Reception quality: optimum_signal
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 05
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 05
U1111 00 [00001000] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 149
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
Voltage terminal 30: 11.8 V
BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H18 0250
Dataset Number: 4K0909460B 0010
Coding: 0285010102002001C20040
ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
Self-Diagnosis Log
Page 25
Address 80: Batt. reg. aux. accum. (A1) Labels: 8W0-915-101.clb
Part No SW: 4K1 035 283 C HW: 4K1 035 283 B
Component: ConBox H09 0233
Serial number: 005CCA12F120890 Dataset Number: 4K0909612D 0016
Coding: 01C020FE4040800000
ROD: EV_ConBoxAU651_002.rod
VCID: 280E2678727CAB1AE7A-807C
458759 - Control Module Incorrectly Coded
U1014 00 [00001000] - -
[ECU_coded_wrong]
Fault Frequency: 29
Reset counter: 149
Mileage: 72071 km
Date: 2025.05.08
Time: 20:55:15
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0127
Serial number: 19000115371003
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 609E7E585ACC135AEFA-8034
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.290 40139
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
Self-Diagnosis Log
Page 26
Part No SW: 4KE 907 107 AK HW: 4N0 907 107 F
Component: zFAS Var A H08 0293
Dataset Number: 4K0909466N 0049
Coding: 02018600000000000030060000000524119D5600000000000000000000000000001900000000000000000000000000000000000000000000000080000000000Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 084E46F892BC8B1AC7A-805C
2114024 - Databus
[Motor_16_TSK_Steigung_02]
Reset counter: 148
Mileage: 72063 km
Date: 2025.05.08
Time: 20:46:12
2114770 - Databus
[ESP_15_VZM_Status]
Reset counter: 108
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
221264 - Front Camera for Driver Assist Systems
C12FA F2 [00001000] - System Limits Exceeded
Fault Frequency: 13
Reset counter: 148
Mileage: 72063 km
Date: 2025.05.08
Time: 20:33:00
4157 - Databus
[ESP_Error]
Self-Diagnosis Log
Page 27
Reset counter: 108
Reset counter: 108
Mileage: 72063 km
Date: 2025.05.08
Time: 20:26:49
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS004 0430
Serial number: YE007SIS17651 Dataset Number: 4K8909897C 0036
Coding: 000FCB0000001480E000A020
VCID: 48CE86F8D23C4B1A07A-801C
Component: TSG HBFS004 0430
Serial number: YE007SIL14209 Dataset Number: 4K8909896C 0036
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 4K0909469G 0018
Coding: 268040058101
VCID: 75B03F0CF54E86F2ACC-8020
Self-Diagnosis Log
Page 28
Component: MRR_HL H16 0267
Dataset Number: 4K8909468D 0023
Coding: 0F1B00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_AU58.rod
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0031
Dataset Number: 4K0909471K 0020
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BA0410842091CA89E-8026
Dataset Number: 4K0909472K 0020
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4K0 035 502 B HW: 4K0 035 502 B
Component: WLC Front H14 0061
Coding: 800000
VCID: 201E3E581A4C535AAFA-8074
End----------(Elapsed Time: 02:06, VBatt start/end: 12.3V/12.3V)-----------
------------------------------32 Faults Found------------------------------
That's going to have be dealt with by ODIS with an on-line connection to the servers on Audi's mothership.
PS: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
Pouswiv
Florida, USA
C?ID=619159
Thank you, I'm new to the forum. Does that mean I have to go to the Dealer or Is it something I can find someone to help me with as off right now I only have ESC/ABS malfunction and Parking brake malfunction. light on the dashboard
I'm afraid Audi dealer only ; or, a independent (specialist with VW / Audi ) who has access to Audi servers via the ODIS set-up. ("dealer software")
Pouswiv
Florida, USA
C?ID=619159
Thank you I will bring to the Dealer, I though I did something wrong with the ABS Module Coding. I basically took the code from the previous Module.
Mari
C?ID=150535
Component Protection has nothing to do with your coding, it's something to prevent swap of parts between cars... it's a way for dealers to earn some money...
Supposedly it was implemented to reduce the market for stolen parts, but we realistically it's more like "Dealer Profit Protection".
Pouswiv
Florida, USA
C?ID=619159
Is safe it to drive it like that for a while? I’m almost sure they will Quote me an arm and a leg but on a process buying a house closing in 30 days.
Nothing in life is "Safe".
That said, I do not know what the behavior of the ABS will be in its current condition.
Pouswiv
Florida, USA
C?ID=619159
That’s a fair statement. Thank you.
davisev5225
C?ID=263265
Federal motor regulations will require that all critical safety functions will work as designed with or without clearing that component protection, but all "optional" features may not work as expected (or at all).
... meaning you can drive it legally, but you probably won't have the full suite of capabilities, particularly anything relating to driver assistance/convenience rather than emergency braking functions.
iichel
Netherlands, Operation Market Garden
C?ID=284912
The solution has already been given, I'm just here to say FU to VAG for putting CP on any random part now.
It's on the news every day almost, massive thefts of ESP blocks, second most stolen part after airbags, radios, radars, front camera's, can gateways and front cameras :facepalm:
:thumbs:
They get stolen because there's a huge demand for them. There's a huge demand for them because they fail incessantly.
Pouswiv
Florida, USA
C?ID=619159
:thumbs:
I would understand if it was just for 2nd hand parts. I bought the parts with my vin# directly from them. They should make this as an exception.
Agreed. A reasonable compromise would be if brand-new part from the dealer matched itself to the first car it's installed in.
