Hello!
I have a 2013 A8l 3.0 that I recently bought. It has issues with the air suspension. It has 6 trouble codes. I fear someone did the "delete all adaptations" while trying to fix it previously since it has the "module not coded" error.
Any help is much appreciated!
Here is the full code:
Friday,09,May,2025,09:25:53:38462
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WAURGAFD4DN002603 License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 3B 42 46 47 52
53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAURGAFD4DN002603 Mileage: 191787km-119170miles
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4H0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0005
Revision: --H07--- CVN: 9C4BF5E0
Coding: 0A2A0034052E01060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214H0907551G 001006
ROD: EV_ECM30TFS0214H0907551G.rod
VCID: 2E02D06A509E269A2D6-807A
VINID: 9D19625D15941147800021800C6FFB8733
Part No SW: 4H1 927 158 AR HW: 0BK 927 156 AG
Component: 0BK 30TFSIUSA H16 1005
Revision: --H16--- CVN: 33721114
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002018
VCID: 005E5ED2BA8A60EA8FA-8054
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 D HW: 4H0 907 379 D
Component: ESP PREMIUM H10 0352
Coding: 80E5F30001A7CF00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3334C11EBBBC0B72428-8066
0675 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_HL_Error]
Reset counter: 136
Mileage: 191460 km
Date: 2025.05.03
Time: 17:10:23
VzRef: 0B
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 12
F-Path: 39
F-Type: 24
Uz: AF
0676 - Function Restriction due to Faults in Other Modules
[Net_Fahrwerk_03_FA_Niveau_Druck_HR_Error]
Reset counter: 136
Mileage: 191539 km
Date: 2025.05.05
Time: 19:08:57
VzRef: 41
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 12
F-Path: 39
F-Type: 1F
Uz: B4
0677 - Function Restriction due to Faults in Other Modules
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Error]
Reset counter: 135
Mileage: 191460 km
Date: 2025.05.03
Time: 17:09:51
VzRef: 2F
Bit Info 1: 40
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 12
F-Path: 39
F-Type: 1A
Uz: AC
0678 - Function Restriction due to Faults in Other Modules
[Net_Fahrwerk_03_FA_Niveau_Druck_VR_Error]
Reset counter: 133
Mileage: 191460 km
Date: 2025.05.03
Time: 17:09:47
VzRef: 30
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 06
Bit Info 4: 12
F-Path: 39
F-Type: 0F
Uz: AD
0776 - Function Restriction due to Implausible Message(s)
U1112 00 [00001001] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_HL_Invalid]
Fault Frequency: 30
Reset counter: 107
Mileage: 191465 km
Date: 2025.05.03
Time: 20:41:23
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 23
Uz: 97
0778 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Invalid]
Reset counter: 135
Mileage: 191520 km
Date: 2025.05.05
Time: 08:43:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 19
Uz: 98
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H32 0510
Coding: 0DA72046000000000000
Shop #: WSC 45048 000 1048576
VCID: 6E82106A909E669A6D6-803A
Serial number: 2312000096412005
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000029368636
Coding: 0018320000047201000001010101112131313333282020
Shop #: WSC 02313 785 00200
VCID: 3436C202BE320C4A5B2-8060
03334 - Motor for Head Rest Adjustment
Fault Status: 01100101
Reset counter: 91
Mileage: 191456 km
Date: 2025.05.03
Time: 14:51:06
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 G HW: 4H0 820 043 G
Component: Klima 4 Zonen H20 0120
Coding: 668122BE78
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 241632420E529CCACB2-8070
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001322500
Coding: 02002091163C9FE1CB008807A0003908009CD30886000121800008406000
VCID: 6C861A62A682948A432-8038
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120202 H35 0080
Serial number: 120305013349
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10255688
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 D HW: 4H0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 14 05 2012 00000944
Component: USHL4.2 H30 0030
Serial number: 0000002274555R1R1X02
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103086000001307737
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 1CA8CA26000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061213800546
Coding: A80302
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003_AU64.rod
VCID: 77AC350EEF442752BE0-8022
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001A45R Dataset Number: 4H0909602D 0004
Coding: 303143303230303030344A55304C34483053
VCID: 372CF50EAFC4E7527E0-8062
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R1220703HFM
Serial number: 3575HRB405J1D5MSA1R
Serial number: 3585HRB405T1BBH44O7L
Serial number: 3515JRB4057197FGF1O3
Serial number: 3525JRB4057197FG21GQ
Serial number: 3554VRB401E4UE20DPU8
Serial number: 3564VRB401E4UE20FHT2
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LEB00011
Coding: 000434
VCID: 382EF632A25AE82A77A-806C
Subsystem 1 - Part No SW: 4H0 951 528 K HW: 4H0 951 528 K
Component: E221 - MFL H09 0009
Serial number: 30 03 2012 B1045451
Part No SW: 4H0 920 920 G HW: 4H0 920 920 G
Component: TBenUSA------ H71 0515
Revision: 35081077 Serial number: 658160512592059
Coding: 0B6608011B40D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 29082376697041A2F84-807C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1120426001092
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AB HW: 4H0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000531735 Dataset Number: 4H0909515F 0064
Coding: 00CD075200
GVL: FFA3E848FE63E0CC8000
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 71B80B1681207962704-8024
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970393740
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 12086002304011200410
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H16 0120
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
VCID: 3138CB1641A03962304-8064
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_003_AU64.rod
677388 - Ride-Height System; Plausibility Error
C1046 00 [00001000] - -
Fault Frequency: 24
Reset counter: 147
Mileage: 191536 km
Date: 2025.05.05
Time: 16:43:32
455692 - Sensor for Ride-Height
C1048 07 [00001000] - Mechanical Failure
Reset counter: 145
Mileage: 191546 km
Date: 2025.05.05
Time: 19:19:31
C10C8 00 [00001001] - -
Fault Frequency: 63
Reset counter: 107
Mileage: 191536 km
Date: 2025.05.05
Time: 16:33:25
367877 - Ride Height Not Learned
C1044 00 [00001001] - -
Reset counter: 95
Mileage: 191536 km
Date: 2025.05.05
Time: 16:33:25
266752 - Control module not coded
U1013 00 [00001001] - -
Reset counter: 95
Mileage: 191536 km
Date: 2025.05.05
Time: 16:33:25
38144 - No End-of-Line Programming
B2013 00 [00001001] - -
[keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
Reset counter: 95
Mileage: 191536 km
Date: 2025.05.05
Time: 16:33:25
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000029368598
Coding: 00183B0000057201000001010101112131313333202020
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0020
Revision: -------- Serial number: EJ1BPA3101MC9%0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 6C861A62A602948A432-8038
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000127587712
Coding: 011F1F005E0062C202003006
Shop #: WSC 02312 785 00200
VCID: 48CE86F2D2BA98AA07A-801C
Revision: 00002001 Serial number: 0175812819
Coding: 0106023A00FA759FB0B0C7840203010F0000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000084647
Subsystem 3 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J245 007C H06 0005
Serial number: 219200072664
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BR HW: 4H0 947 135 BR
Component: Dachelektroni H11 0080
Serial number: A2012000000000567961
Coding: 070000
Subsystem 5 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J394 0014 H06 0005
Serial number: 219200072898
Coding: 020200
Subsystem 6 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J392 006A H06 0005
Serial number: 219200072685
Coding: 020200
Subsystem 7 - Part No SW: 4H4 959 591 HW: 4H4 959 591
Component: J867 00E0 H06 0005
Serial number: 219200072882
Coding: 020200
Subsystem 8 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84378449
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000052721
Coding: 030000
VCID: 1D6007A62DB8AD0284C-8048
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000127590921
VCID: 3C26EA229662C40A932-8068
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000355266 Dataset Number: 4H0909522C 0010
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B04D97E638C53B20A8-807E
335360 - Function Restricted due to Missing Message(s)
U1111 00 [00000000] - -
[FC_BCM2_02_MESSAGE_TIMEOUT]
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 120521-0004-045
Coding: 12116F33701AA500
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU57.rod
VCID: 323AC41A44A6027A49E-8066
H02 0009
Coding: 1C0000
H02 0009
Coding: 1C0000
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [10001001] - -
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Fault Frequency: 16
Reset counter: 95
Mileage: 190861 km
Date: 2025.04.25
Time: 17:13:11
Part No SW: 4H0 035 082 D HW: 4H0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 155DJ0C7520002
Coding: 020007010000000001
VCID: 221A345A14C692FAB9E-8076
Part No SW: 4H0 035 746 C HW: 4H0 035 746 C
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 183EQ0C7500135
Coding: 020200000001F1EF45128B1E00000003140001000000000000
VCID: 280E267272FA78AAE7A-807C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300ENR4
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000081128
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000127532968
Coding: 010F1F00400062C202003006
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J24D0K2
Coding: 1080003
VCID: 2612284A74EE6EDAD56-8072
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 131200492 Dataset Number: 4H0909541D 0019
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D20E7268DF8CD02A4C-8068
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000072806 Dataset Number: 4F0000000__ U001
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6394715E4BDCDBF2F28-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000127532971
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5013 Serial number: SN120411 0388
ROD: EV_GSM2x3Mono_AU64.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 G HW: 4H0 907 182 G
Component: IVB H08 0042
Serial number: 00005932049901 Dataset Number: 4H0909880D 0019
Coding: 602FF2
ROD: EV_IVBDriveSideFrnt_AU64.rod
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00005932142502 Dataset Number: 4H0909881D 0019
Coding: 202FF2
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Dataset Number: 4H0909614C 0002
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
Dataset Number: 4H0909615C 0002
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:57, VBatt start/end: 14.7V/14.6V)-----------
------------------------------15 Faults Found------------------------------
