On the screen that you made a video of, did you notice that there is a [Log] button?Apologies, I’m not fully clued up on how to make a log.
See also:
https://www.ross-tech.com/vcds/tour/logging.php
Honestly, I didn’t think of it at the time. I pressed the graph button but not the log. I’ll give it a shot tomorrow.On the screen that you made a video of, did you notice that there is a [ Log ] button?
See also:
Yes it is possible but are they "passing too much fuel" or the right amount ?Is it possible that the pressure is low because the 3 & 4 injectors are passing so much fuel?
Yes you do ! Your understanding of the fuelling strategy in that engine is poor. (At the moment)I don’t need lectures,
How much is "Almost" ?On cranking, 1&2 injectors have almost no leak off
Why ? Can we see the Diagnostic process and the measurements made that led to that decision please?
Source of replacement parts ?
Sorry, I went to bed.Still a valid request ?!
I didn’t time it unfortunately, just took shaky videos and saw that two injectors were clearly different from the others.Yes it is possible but are they "passing too much fuel" or the right amount ?
This is not a nursery / kids guessing game, it is a car !
How many mL of fuel per 10 seconds of cranking ? Measurements ! Accuracy ! - Better still block 3 & 4 off ! Will it fire on 1 and 2 ?
Does rail Pressure improve ?
I meant lectures on why I didn’t replace the injectors along with the other parts. Happy to learn about the fuelling strategy.Yes you do ! Your understanding of the fuelling strategy in that engine is poor. (At the moment)
I quoted this bit twice somehow. So…apologies for the lack of exact information but it was this sequence-ish.Still a valid request ?!
A scan is not only about faults, it's about telling us the setup of the vehicle and what hardware/software it has - that's all important information.I don’t think the scan would help because there are no faults showing.
I’ll get it from my laptop and post it up shortly.A scan is not only about faults, it's about telling us the setup of the vehicle and what hardware/software it has - that's all important information.
Wednesday,09,April,2025,20:45:58:11279
VCDS Version: 24.7.0.0 (x64)
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 47 52 55 5F A5 A9
Mileage: 249655km-155128miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 ED HW: 04L 907 309 A
Component: R4 2,0L EDC H22 8240
Revision: 81H22--- CVN: BF1E8D5D
Coding: 02190012030501083000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TDI01104L906021ED 002010
ROD: EV_ECM20TDI01104L906021ED_002.rod
VCID: 6BD2159E82A9FFCE06-803E
VINID: 92296AAAA5A601604000824920FF439CAA
5211 - Fuel Rail/System Pressure
P0087 00 [01100101] - Too Low
Mileage: 249648 km
Date: 2025.04.08
Time: 17:25:04
Engine RPM: 2296.50 /min
Normed load value: 76.9 %
Vehicle speed: 20 km/h
Coolant temperature: 85 °C
Intake air temperature: 83 °C
Voltage terminal 30: 14.720 V
Unlearning counter according OBD: 80
Fuel temperature sensor 1: B1: raw value: 57.6 °C
Mean injection quantity: 38.67 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high pressure sensor: actual value: 278600 hPa
Fuel high pressure sensor: nominal value: 1674400 hPa
Pressure control valve adaptation factor: 1.1335
Fuel level: 8.00 l
5212 - Fuel Rail/System Pressure
Mileage: 249648 km
Date: 2025.04.08
Time: 17:25:08
Engine RPM: 2297.00 /min
Normed load value: 100.0 %
Intake air temperature: 85 °C
Fuel temperature sensor 1: B1: raw value: 57.9 °C
Mean injection quantity: 20.60 mg/stroke
Fuel high pressure sensor: actual value: 249100 hPa
Fuel high pressure sensor: nominal value: 1317500 hPa
Fuel level: 8.00 l
20557 - Heater support pump
P16C7 00 [00100000] - locked
Part No SW: 8S0 907 379 B HW: 8S0 907 379 B
Component: ESC H31 0504
Revision: 00000000 Serial number: 63474000000510
Coding: 13AA108D1A9915B1009A006DC299830624C80858A8000043C16024
ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
ROD: EV_Brake1UDSContiMK100IPB_052.rod
VCID: 40889232DBAFCC9683-8014
16401 - Tire Pressure Warning
C102D 00 [00001000] - -
Reset counter: 19
Mileage: 247712 km
Date: 2025.03.09
Time: 11:08:38
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0355054959 Dataset Number: 8S0909577D 0001
Coding: 000F0F1620
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB.rod
VCID: 77FA39EECEE14B2EF2-8022
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0030
Revision: 20009000 Serial number: 14110000009000
Coding: 411040002011101100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6CD0168287A7F8F60F-8038
Humidity sensor: exterior:
Rear A/C Control Head 1:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H06 0020
Serial number: 00000000000000006168
Rear A/C Control Head 2:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H06 0020
Serial number: 00000000000000006194
Rear A/C Control Head 3:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H06 0020
Rear A/C Control Head 4:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H06 0020
Rear A/C Control Head 5:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H06 0020
Serial number: 00000000000000006223
332038 - Position Sensor for Side Defrost Flap; Left
B1661 15 [00001000] - Open or Short to Plus
Reset counter: 24
Mileage: 249305 km
Date: 2025.04.01
Time: 13:21:21
Voltage terminal 30: 14.6 V
Outside temperature: 16.0 °C
Defrost flap motor for left side window: actual value: 0.00 %
Defrost flap motor for left side window: actual value: 949
Defrost flap motor for left side window: spec. value: 900
Part No SW: 5Q0 937 084 BR HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0136
Serial number: 01011435100893 Dataset Number: 8S0909514B 0026
Coding: 07054D46C20106FD03044004B31807A80080000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 091E4F16A8154DDE94-805C
Subsystem 1 - Part No SW: 8S2 955 119 A HW: 8S2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: 43x RL 140703 032 0371
Serial number: 00000001407010600503
Coding: 1BC7F7
Component: G397_RLFS H06 0002
Serial number: 23572266
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 23 10 2014 00000081
Subsystem 4 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143210PE8
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000031448399
B1263 01 [00001001] - Electrical Failure
Fault Frequency: 68
Reset counter: 253
Mileage: 221783 km
Date: 2023.11.19
Time: 13:10:52
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 12.6 V
Outside temperature: 11.0 °C
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 88
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.2 V
Outside temperature: 7.0 °C
786954 - Heater for Spray Nozzles
B1224 15 [00001000] - Open or Short to Plus
Reset counter: 25
Mileage: 248911 km
Date: 2025.03.30
Time: 09:45:57
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.4 V
Outside temperature: 9.5 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 E HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0051
Revision: -------- Serial number: 39291435201968 Dataset Number: 8S0909526A 0012
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_002_AU37.rod
VCID: 3B72E5DEB249AF4ED6-806E
U1400 00 [00001000] - -
Reset counter: 38
Mileage: 249655 km
Date: 2025.04.09
Time: 19:32:08
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 009 0870
Serial number: 003M7R007ZY6 Dataset Number: 8S0909602A 0026
Coding: 88CCF0C00C8000005C5000CFC0C800000065
VCID: 4D96BB061CFD11FE78-8018
Subsystem 1 - Part No SW: ----------- HW: 480 001 312 14
Serial number: 357000000008236D321A
Subsystem 2 - Part No SW: ----------- HW: 480 001 312 14
Serial number: 358000000009E36D321O
Subsystem 3 - Part No SW: ----------- HW: 480 012 909 14
Component: SideSensor_Dr 004 0108
Serial number: 351001A01DD52E032EEF
Subsystem 4 - Part No SW: ----------- HW: 480 400 409 14
Serial number: 3550002A9175A8D2A116
Subsystem 5 - Part No SW: ----------- HW: 480 400 409 14
Component: FrontSensor_P 001 6149
Serial number: 3560002AB175A8D1A08E
Subsystem 6 - Part No SW: ----------- HW: 480 400 411 14
Component: PedP_Sensor_C 001 6149
Serial number: 2300002A51860BC3807Z
Subsystem 7 - Part No SW: ----------- HW: 480 001 911 14
Serial number: I0M000000007416D221X
Subsystem 8 - Part No SW: ----------- HW: 480 001 911 14
Serial number: I0N000000006A68C2212
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8S0 907 129 R HW: 8S0 907 129 R
Component: Lenks. Modul H07 0140
Revision: -------- Serial number: 91335NLG01470
Coding: 0008
ASAM Dataset: EV_SMLSKLOMQB 019002
ROD: EV_SMLSKLOMQB_010_SE37.rod
VCID: 499E8F16E8950DDE54-801C
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 HW: 8S0 920 790
Component: FBenRDW H32 0295
Coding: 240D0110298406000123E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001023
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 76E434EAC9EB3226E9-8022
Part No SW: 8S0 907 468 A HW: 8S0 907 468
Component: GW MQB TT3 012 0203
Revision: -------- Serial number: 26111410801437 Dataset Number: 8S0909515A 0015
Coding: 030100040F0276004B000268080000000000000000000000000000000001
GVL: 01543C1000000600408C10000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 011002
ROD: EV_GatewContiAU33X_011.rod
VCID: 3E74ECCAA15BBA66F1-806A
Generator:
Subsystem 2 - Part No SW: 8S0 951 523 B HW: 8S0 951 523 B
Component: J453 MFL H06 0001
Serial number: 20140916124500 RD311
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 9118435003
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000306487001
Coding: 0100000000000000
ROD: EV_ELVMarquMQBB_VW37.rod
VCID: 71EE07F6A085151E3C-8024
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 061214BL40690A Dataset Number: 8S0909872B 0016
Coding: 001346224001040100001402
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 428C983AD5A3DE8695-8016
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Dataset Number: 8S0909852B 0007
Coding: 8103
VCID: 377AF9EE8E618B2E32-8062
Address 47: Sound System
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 161214BLG0308A Dataset Number: 8S0909873B 0016
Coding: 001346224C01040100001402
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 418E9736D0A5C59E8C-8014
Component: MxB-ECU 001 0100
Revision: -------- Serial number: -------------- Dataset Number: 8S0909865C 0023
Coding: 03DE00102B230200
Shop #: WSC 15017 002 1048576
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
VCID: 3460CEE29F17603617-8060
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 8S0 980 653 HW: 5Q0 980 653
Component: MQB_MFK H06 0002
Serial number: 10000179191 Dataset Number: 8S0909466A 0012
Coding: 0001010001010305000501000000010100
ROD: EV_MFKBoschAU370.rod
VCID: 7AFC20DAFDF356468D-802E
Part No SW: 8S0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0004
Serial number: 141116201218
End-------------------------(Elapsed Time: 05:45)--------------------------
Tuesday,06,May,2025,18:07:32:11279
VCDS Version: 25.3.1.0 (x64)
Data version: 20250408 DS365.0
VCID: 6BD2159E82A9FFC30E-803E
VCID: 40889232DBAFCC9B8B-8014
C1146 02 [00001000] - Signal Failure
Reset counter: 38
Mileage: 249655 km
Date: 2025.04.11
Time: 15:28:37
Coding: 000F0F1620
VCID: 77FA39EECEE14B23FA-8022
VCID: 6CD0168287A7F8FB07-8038
VCID: 091E4F16A8154DD39C-805C
Coding: 1BC7F7
Coding: 00005D
Coding: 0000050001
VCID: 3B72E5DEB249AF43DE-806E
VCID: 4D96BB061CFD11F370-8018
Coding: 0008
ROD: EV_SMLSKLOMQB_019_VW37.rod
VCID: 499E8F16E8950DD35C-801C
VCID: 76E434EAC9EB322BE1-8022
VCID: 3E74ECCAA15BBA6BF9-806A
Generator:
VCID: 71EE07F6A085151334-8024
VCID: 428C983AD5A3DE8B9D-8016
Coding: 8103
VCID: 377AF9EE8E618B233A-8062
Part No SW: 8S0 035 465 A HW: 8S0 035 465
Component: MIB2_amp_P_TT H06 0190
Revision: 00000001 Serial number: AUZ8ZAEH7002CPX Dataset Number: 8S0909510B 0012
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 3362CDFE9A19670306-8066
VCID: 418E9736D0A5C59384-8014
VCID: 3460CEE29F17603B1F-8060
Coding: E01800
Coding: E01800
Coding: E01800
Coding: E01800
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8S0 035 021 M HW: 8S0 035 021
Component: MU-H-LND-EU 041 1339
Serial number: A578L0EB001002 Dataset Number: 8S0909545B 0019
Coding: 013304010000000011111102000800132F0000E3007000009E
Subsystem 1 - Part No SW: V03 959 801 ET HW: -----------
Component: ECE 2015 --- 0105
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 L
Component: ControlUnit_H H21 0206
Serial number: C1000026101400010158
Compact disc data bank:
Component: Gracenote2 --- 1008
VCID: 7AFC20DAFDF3564B85-802E
End-------------------------(Elapsed Time: 04:58)--------------------------
-------------------------------1 Fault Found-------------------------------
Again, didn’t think measuring them was overly important at this point because of the obvious difference. I get that you work in minute detail, and will try to keep that in mind.
I don’t have any blanking plugs, I’ll have to get hold of some or make something up.
Engine cut out while driving. It would crank but not fire. Fuel was showing as around 1/4 of a tank
Daughter phoned me, I told her to get to a safe place and call the AA
Police came, got her to a safe area. It was on the A472.
AA man arrived and towed her home. He had scanned the car and told me it had low rail pressure. We tipped him a 20 and off he went.
Hand eye checks to look for anything obvious. Put in 20 litres of fresh diesel from new cans.
I scanned using VCDS low fuel pressure-I can check back later for specific codes if required but my VCDS is on a standalone tablet so I don’t have them to hand.
Checked voltage at FP sensor, from memory it was 0.7v when cranking
Checked FPR had signal voltage and for switching (don’t have the figures now)
Checked fuel pump was priming, it was.
Tried to start it using Easy Start, it did.
Took off the HPFP solenoid, (after being told about it on here) and found some swarf
Swore a bit, drank some Whisky. I have a little detail on this. It was 150 ml of Arran single malt Scotch whisky, separated over 3 equal glasses, decanted from a 700ml bottle. No added mixers or ice. It was a non chill filtered, natural coloured number with a hint of ripe figs and sweet cherries having an ABV of 55.8%
Bought a reconditioned HPFP from AGNG Diesel
Bought a Bosch FPR from creston27 on eBay
Bought a Gates timing belt kit and Bosch fuel filter from Carpartsinmotion
Bought a Genuine tensioner from OEM VAG Parts on eBay
Bought engine locking kit, cam sprocket tool and HPFP removal socket from eBay.
Bought a bore scope
Replaced the HPFP, timing belt, water pump etc
Cleaned fuel pipes, HP manifold and hoses then pumped clean fuel through them
Replaced fuel filter
Scanned again, no faults
Pressure as per the poor video I posted earlier
Checked leak off from injectors. Image and video as above. Had to use hoses as I found none of the adaptors from the test kit I bought would fit.
I think that the 2 that are leaking fuel are clogged with swarf and the ones not returning are serviceable. I’m going to replace the 4.So are the 2 that are not returning clogged up with swarf ?
The reconditioned pump is Bosch, as is the FPR.So nothing genuine in that car anymore ?
All I got from that block of scrap text was
Good Man !!
It’s about the only thing I took notice of, clearly.This is why I think that injectors 3 & 4 are faulty…So are the 2 that are not returning clogged up with swarf?
Wednesday,14,May,2025,18:09:35:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
04L 906 021 ED,ADVMB,R4 2.0L EDC H22 8240,
,,G067,F0,G068,F0,G112,F0,G130,F0,G158,F0,G582,F0,G583,F0,G584,F0,G585,F0,G586,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE00405,TIME,Loc. IDE00406,TIME,Loc. IDE00589,TIME,Loc. IDE01378,TIME,Loc. IDE02228,TIME,Loc. IDE07818,TIME,Loc. IDE07819,TIME,Loc. IDE07820,TIME,Loc. IDE07821,TIME,Loc. IDE07822,,,,,
,STAMP,Crankshaft speed (RPM),STAMP,Camshaft RPM,STAMP,Fuel pressure,STAMP,Fuel high pressure: control deviation,STAMP,Fuel pressure regulator valve: specified value rail pressure,STAMP,Fuel high pressure sensor: actual value,STAMP,Fuel high pressure sensor: unconditioned voltage,STAMP,Fuel high pressure sensor: nominal value,STAMP,Fuel metering valve: activation,STAMP,Fuel pressure regulator valve: activation,,,,,
,, /min,, /min,, kPa rel,, hPa,, hPa,, hPa,, mV,, hPa,, %,, %,,,,,
,1.93,0.0,0.01,0.0,0.20,170,0.41,298300,0.64,850000,0.88,1700,1.06,503.2,1.28,300000,1.50,24.75,1.71,30.36,,,,,
,4.07,268.0,2.14,0.0,2.36,170,2.56,298300,2.78,850000,3.00,44700,3.22,835.6,3.43,376400,3.64,30.53,3.88,36.82,,,,,
,6.26,859.0,4.29,137.8,4.51,54200,4.74,126900,4.96,1014700,5.18,359300,5.39,1275.6,5.63,449000,5.83,29.81,6.04,32.82,,,,,
,8.47,0.0,6.48,449.0,6.70,29740,6.93,6100,7.15,633300,7.39,359300,7.62,1187.4,7.81,300000,8.03,33.15,8.25,36.05,,,,,
Wednesday,14,May,2025,18:10:13:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,0.01,0.0,0.21,214.5,0.43,170,0.64,298300,0.86,850000,1.08,1700,1.29,503.2,1.50,300000,1.71,8.50,1.95,40.87,,,,,
,2.18,187.0,2.41,0.0,2.60,27590,2.81,-36500,3.02,593600,3.24,391600,3.48,1187.4,3.72,396800,3.95,32.70,4.17,32.34,,,,,
,4.36,311.5,4.58,157.5,4.79,35390,5.01,45000,5.23,630800,5.44,448000,5.67,1265.8,5.88,390700,6.10,33.79,6.32,33.44,,,,,
,6.54,288.0,6.75,145.3,6.97,42920,7.21,-15700,7.44,650400,7.64,348500,7.86,1119.2,8.08,388400,8.30,33.08,8.51,32.58,,,,,
,8.74,285.5,8.97,142.8,9.21,34850,9.46,54900,9.66,676300,9.88,335100,10.10,1153.4,10.32,386900,10.53,32.70,10.75,31.36,,,,,
,10.97,283.5,11.20,141.8,11.39,28400,11.62,37500,11.83,446700,12.04,200700,12.27,811.2,12.49,300000,12.73,34.02,12.98,17.28,,,,,
,13.20,0.0,13.41,141.8,13.62,170,13.83,298300,14.05,4700,14.27,1700,14.48,503.2,14.71,300000,14.91,33.86,15.13,7.08,,,,,
,15.36,0.0,15.57,141.8,15.79,170,16.00,298300,16.24,0,16.46,1700,16.65,503.2,16.87,300000,17.09,33.53,17.30,7.18,,,,,
,17.51,0.0,17.75,141.8,17.98,170,18.22,298300,18.40,0,18.63,1700,18.84,503.2,19.03,300000,19.25,33.48,19.50,7.28,,,,,
Wednesday,14,May,2025,18:12:02:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,0.90,0.0,1.12,0.0,1.33,14150,1.55,137700,1.77,603900,1.98,418400,0.02,503.2,0.23,300000,0.47,24.89,0.73,30.70,,,,,
,3.13,252.0,3.34,124.8,3.55,41030,3.78,-49100,4.00,622100,4.26,348500,2.25,1172.8,2.46,374200,2.71,30.94,2.90,35.27,,,,,
,5.45,277.5,5.66,138.8,5.87,35660,6.09,31200,6.30,675600,6.51,364600,4.48,1114.2,4.75,384100,4.99,30.05,5.21,33.26,,,,,
,7.71,278.5,7.95,139.0,8.14,34580,8.35,30400,8.57,678200,8.80,343200,6.75,1133.8,6.99,385100,7.26,29.99,7.50,34.68,,,,,
Wednesday,14,May,2025,18:14:26:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,0.35,0.0,0.59,0.0,0.81,170,1.01,298300,1.23,850000,1.45,1700,1.66,508.2,1.88,354400,2.10,30.06,0.14,30.65,,,,,
,2.58,257.0,2.77,128.0,2.98,37000,3.20,-25300,3.42,615100,3.63,426500,3.85,1265.8,4.12,382500,4.35,30.89,2.34,32.83,,,,,
,4.87,272.0,5.10,135.5,5.33,37540,5.55,-21000,5.76,635600,5.98,391600,6.19,1251.2,6.41,384300,6.63,30.12,4.61,33.60,,,,,
,7.12,275.5,7.36,137.8,7.59,35390,7.78,19400,8.00,670700,8.22,378000,8.43,1114.2,8.65,383800,8.86,30.12,6.86,33.80,,,,,
Wednesday,14,May,2025,18:25:02:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,0.65,0.0,0.87,0.0,1.08,170,1.30,298300,1.54,850000,1.78,1700,2.02,503.2,0.01,300000,0.23,25.09,0.44,30.78,,,,,
,2.88,243.5,3.10,121.0,3.31,29480,3.54,80000,3.79,740900,4.02,327100,4.23,1143.6,2.24,355000,2.45,31.99,2.66,38.73,,,,,
,5.10,265.0,5.32,132.5,5.53,41580,5.78,-20700,6.04,717600,6.29,300100,6.55,1373.2,4.43,378300,4.65,29.97,4.87,31.49,,,,,
,7.42,271.5,7.65,135.8,7.86,45600,8.08,-71500,8.30,641200,8.55,431900,8.80,1114.2,6.78,381900,7.01,30.09,7.22,32.42,,,,,
Wednesday,14,May,2025,18:27:33:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,0.80,0.0,1.06,0.0,1.28,450,1.51,336600,1.71,400000,1.94,372700,2.14,1080.0,0.14,300000,0.35,25.24,0.58,30.90,,,,,
,3.07,256.5,3.31,127.0,3.56,34320,3.82,56100,4.04,721000,4.28,327100,4.48,1104.4,2.35,372500,2.57,29.96,2.82,31.95,,,,,
,5.35,267.0,5.58,133.8,5.81,37270,6.04,32400,6.28,683600,6.48,370000,6.69,1275.6,4.69,379900,4.91,30.36,5.13,32.98,,,,,
,7.57,82.0,7.80,134.0,8.06,27060,8.31,42900,8.54,867000,8.78,235600,8.98,913.8,6.91,380300,7.13,26.34,7.35,29.18,,,,,
Wednesday,14,May,2025,19:49:31:11279-VCID:6BD2159E82A9FFC30E-803E,VCDS Version: Release 25.3.1 (x64),Data version: 20250408 DS365.0
,1.28,0.0,1.51,0.0,1.74,170,1.95,298300,2.16,850000,0.13,1700,0.36,503.2,0.58,300000,0.80,24.95,1.02,30.60,,,,,
,3.49,0.0,3.69,0.0,3.90,170,4.12,298300,4.33,850000,2.38,1700,2.60,503.2,2.82,300000,3.03,24.95,3.25,30.61,,,,,
,5.66,238.0,5.88,117.5,6.09,29740,6.31,255100,6.51,1157600,4.55,1700,4.78,503.2,5.01,347000,5.25,31.21,5.44,38.27,,,,,
,7.80,248.0,8.02,123.5,8.25,37540,8.50,-700,8.69,593000,6.74,421100,6.94,1221.6,7.16,371600,7.38,30.60,7.59,33.92,,,,,
,10.03,264.5,10.28,132.5,10.50,42920,10.75,-48600,10.94,611200,8.91,423800,9.13,1246.0,9.36,378600,9.58,30.36,9.78,33.74,,,,,
,12.28,267.0,12.53,133.3,12.75,29480,13.00,-8200,13.19,771500,11.16,391600,11.38,1177.8,11.60,380600,11.82,30.31,12.03,33.79,,,,,
,14.54,0.0,14.78,133.3,14.99,4210,15.20,263300,15.41,850000,13.41,187300,13.63,767.2,13.85,300000,14.06,25.35,14.27,31.31,,,,,
Blocked off 3 & 4, it didn’t fire but the high pressure control deviation is no longer showing minus figures. It has risen to 46000 hPa with 3 & 4 blocked, and 48300 with all 4 blocked.Yes it is possible but are they "passing too much fuel" or the right amount ?
from minus 16300 to minus 48600
