Resolved Touran Highline clocks led to ABS and steering faults - after help with coding please.
Resolved
Bri78
Scotland, UK
HUC-2H
Hi all,
Thanks for approving me to join this forum, I have lurked around for years and got a lot of help from the posts but this time I cannot figure it out. I thought that with the knowledge of the guys in here someone might be able to help so registered an account.
My car is a 2010 UK VW Touran 1T2, 1.9tdi. It was a midline model when we bought it 11 years ago and recently I have started to have a play and see what I can upgrade, more for the fun of doing it more so than the functionality sometimes.
First was the ECU. I wanted a remap but money was tight at the time so i cheaped out and bought a pre done ECU from an online company which offered 'stage 1' 145hp. This was supplied 'immo off' so was plug and play really. Noticed a big difference in the car so was pretty happy with it. All good.
Next was the front fog lights as the car never had them. I had to run the additional wires and upgrade the CECM to highline to do so. Fitted the loom, fogs, switch and extra wiring no problem, coding was simple as well with VCDS and they work as OEM with cornering etc. Still all good.
I wanted a MFSW so picked up one from a Passat. Fitted and coded no issues. As I wasn't sure what steering module supported the wheel I upgraded it to highline. I also had to replace the rhs stalk as the controls were no longer required on the side. This was an aftermarket stalk and throws up a fault so I plan to replace it but it works as it should.
Next the clocks / instrument cluster....
I picked up a highline set from eBay which arrived yesterday and wanted to make sure they functioned before leaving feedback. Simple - or so I thought.
Trim and 2 screws out, I pulled them out. Slid the new ones in and turned the key to be greeted with 'Immobilizer active' and a few fault lights. Happy they powered up, I pulled them again and swapped back as didn't have time for coding etc at the time.
Now the problem starts - ABS doesnt work or steering angle sensor. I'll post the autoscan to show the detail.
Tried to clear - no joy.
I dug out an older autoscan from before the swap and compared - same coding so nothing to overwrite.
I then read on here the VINs need to match up - is this correct?
Anyway, I decided to swap back to the old stock ECU so did that this morning. Same faults as expected but the coding must be wrong somewhere. The clocks, ECU and ABS are all the same VIN now. (original factory parts)
It drives but feels uneasy on the steering so need to get this sorted as soon as possible.
Anyone who can help me on this one?
Any suggestions appreciated.
Thanks.
Bri78
Scotland, UK
HUC-2H
Autoscan from yesterday (08/05/25)
Thursday,08,May,2025,22:44:38:53583
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
VIN: WVGZZZ1TZAW035125   License Plate: LT59WDC
Mileage: 217390km-135079mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZAW035125   Mileage: 217390km-135079miles
18-Aux. Heat -- Status: Cannot be reached 1100
56-Radio -- Status: Not registered 0011
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 KH    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  9245
   Revision: --H06---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 6FE7F4A07E4C43E323-803A
   VINID: 9E65EAAAA064A919C00C50421469285D52
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.clb
   Revision: 00H11001
   Coding: 0037574
   Shop #: WSC 01324 020 00200
   VCID: 73EFF8D012646703C7-8026
01486 - System Function Test Activated
   Part No SW: 1K0 820 047 JN    HW: 1K0 820 047 JN
   Component: Climatic PQ35   143 1515
   Revision: 00143034    Serial number: 00000000000000
   VCID: 79F3CAF830081D538D-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000007861632
   Coding: 01890F2100040F0047120C000000000000087B075C00012C000000000000
   Shop #: WSC 40850 222 52212
   VCID: 71E3F2D86878551335-8024
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 190809 021  0501
   Coding: 00038805
   Shop #: WSC 40850
                    Reset counter: 91
                    Mileage: 217393 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.10 V
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 D    HW: 1T0 909 605 D
   Component: 1D AIRBAG VW8   021 0100
   Revision: 02021000    Serial number: 003B9D0DXP6R
   Coding: 0012612
   VCID: 366901C44196322B20-8062
   Subsystem 1 - Serial number: 6332QSME23393D1AJ
   Subsystem 2 - Serial number: 6342QSME49390834G
   Subsystem 3 - Serial number: 6352QSME233642322
   Subsystem 4 - Serial number: 6362QSME23360D14A
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000534
   Shop #: WSC 131071 102 209715
   VCID: 7AF1D5F4350E164B84-802E
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4  0021
   Coding: 00000226
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective
   Part No SW: 1T0 920 964 A    HW: 1T0 920 964 A
   Revision: V0002000    Serial number: VWX7Z0I73N51BV
   Coding: 0000401
   Shop #: WSC 00326 067 57207
   VCID: 346D3BCC57EA203B1E-8060
Address 18: Aux. Heat
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 170809F2001586
   Coding: E9807F06000802008003
   VCID: 66C9918451B682AB50-8032
                    Reset counter: 91
                    Mileage: 217393 km
                    Time: 22:02:08
                    Mileage: 217393 km
                    Time: 22:02:07
   Component: IMMO            VDD 1212
   Part No SW: 1T0 959 701 M    HW: 1T0 959 701 M
   Component: Tuer-SG         008 2010
   Coding: 0000693
   VCID: 418362181858859385-8014
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   Shop #: WSC 01324 785 00200
   VCID: 2F6734A0BECC03E363-807A
                    Fault Status: 11100101
                    Mileage: 217393 km
                    Time: 22:02:05
                    Battery Volts: 14.1 V
                        DU
                    Temperature: 33.0 C
                    Count: 3
                    Steering Angle: 0.00
                    Count: 1
                        SteerAng n.Init
   Coding: 99900A0851034C7F2D06840570081FC690DC80
   VCID: 030FA81042C45783D7-8056
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Shop #: WSC 01324
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Part No SW: 1T0 959 702 M    HW: 1T0 959 702 M
   Coding: 0000693
   VCID: 42816D141D5E9E8B9C-8016
Address 56: Radio
   Part No SW: 1K0 959 703 AK    HW: 1K0 959 703 AK
   Component: Tuer-SG         007 2002
   Coding: 0000144
   Shop #: WSC 01324 020 1012552
   Part No SW: 1K0 959 704 AK    HW: 1K0 959 704 AK
   Coding: 0000144
End-------------------------(Elapsed Time: 01:47)--------------------------
------------------------------10 Faults Found------------------------------
Bri78
Scotland, UK
HUC-2H
Autoscan from April 2025 - before the clock swap.
Tuesday,22,April,2025,23:15:31:53583
Mileage: 216740km-134675mi   Repair Order:
VIN: WVGZZZ1TZAW035125   Mileage: 216740km-134675miles
   Coding: 0000071
   Revision: 00H11001
   Coding: 0037574
   Coding: A0890F2101040F0047120C000000000000087B075C000120000000000000
   Coding: 00038805
   Shop #: WSC 40850
                    Fault Status: 00101010
                    Fault Frequency: 34
                    Reset counter: 101
                    Mileage: 216717 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.15 V
                    Fault Frequency: 22
                    Reset counter: 101
                    Mileage: 216717 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.20 V
                    Fault Frequency: 11
                    Reset counter: 61
                    Mileage: 216717 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
   Coding: 0012612
   Coding: 0000534
   Coding: 00000226
            014 - Defective
   Coding: 0000401
                    Reset counter: 58
                    Mileage: 216717 km
                    Time: 00:27:26
                    Fault Frequency: 37
                    Mileage: 216717 km
                    Time: 00:27:24
   Coding: 0000693
   Revision: 00H17000
   Coding: 99900A0851030C7F2D06840570081FC690DC80
   Coding: 00000000
   Shop #: WSC 01324
   Coding: 0000693
Address 56: Radio
   Coding: 0000144
   Coding: 0000144
------------------------------7 Faults Found-------------------------------
Bri78
Scotland, UK
HUC-2H
Adv info for original ECU
Friday,09,May,2025,11:56:36:53583
                Address 01: Engine
Control Module Part Number: 03G 906 021 MM
  Component and/or Version: R4 1,9L EDC G000SG  0511
           Software Coding: 0000072
            Work Shop Code: WSC 01324
                      VCID: 76E9C1C40116722BE0-8022
Advanced Identification
     Identification: BPG-810
     Revision: --H11---
     Date: 04.09.09
     Test stand number: 1480
     Manufacturer number: 0229
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 00000 000 00000
     Flash Date: 00.00.00
Software
     P0101
     HAXE
Misc.
     Hardware number: 03G 906 021 AN
     Immo Challenge: 41 63 77 06
Car Info
     Chassis Number: WVGZZZ1TZAW035125
VCDS Info:
     Readiness: No script available
Bri78
Scotland, UK
HUC-2H
Adv info for ABS
Friday,09,May,2025,11:58:30:53583
Control Module Part Number: 1K0 907 379 AC
  Component and/or Version: ESP FRONT MK60      0101
           Software Coding: 0037574
     Identification: CTA-000
     Revision: 00H11001
     Date: 27.08.09
     Test stand number: 0102
     Manufacturer number: 0241
Flash Status
Misc.
     Hardware number: 1K0 907 379 AC
VCDS Info:
Bri78
Scotland, UK
HUC-2H
Nice one Uwe, that seems to have done the job. Thanks so much. It did leave a System Function Test error which cleared after I followed the procedure.
Now, guess I need to be more careful and read up on how to fit these clocks now. Look so much better than the midline.
Thanks again.
