Audi Q7 2015 TDI V8 - Crank and no start
JoelG
Australia
C?ID=615191
Hi All, I'm new here and looking for some advice. I'm located in Australia so having a couple issues getting manuals from erWin but will sort that out soon. Managed to get bits here and there but need to get the full manuals.
Have been trawling the forums for a few weeks now, some great info in here.
Background. Had car for 12 months. Services up to date. Went for a drive the other day and it stopped, lost all power and engine had fully stopped, no weird sounds, it was as if you had turned the key off. Battery power, gauges etc all seemed to be ok. Pulled to side of road, car cranked over but didn't start. Had car towed back to home. It sat there for a month before I had time to look at it.
Steps taken so far.
  1. After sitting for a month the battery was low, charged battery, car cranks over no start. It has not fired up once since it died.
  2. Procured VCDS. Love it. Checked codes etc. lots of errors found but nothing that looked clear to me to be the problem. Note no fuel pressure DTC's or fuel related faults logged...
  3. Went back to basics, check, power, fuel, compression.
  4. Checked battery, not perfect but, maintaining +11v when cranking. Have also hooked it up to secondary power to ensure minimal voltage drop. No change. Also visually inspected battery. It was fitted by Audi when I bought car from dealer. Had its service test attached to it still etc. I'm not sure about battery it's still a little low for me, I am cranking it over a lot so maybe its ok.
  5. Pulled every fuse I could find and checked them. This added some extra faults in the VCDS scan but no fuse issues. I'm no expert on where everything is in the Q7 so used some online guides to find them. Have not tested relays.
  6. Checked fuel flow, low pressure pump, tested volume and pressure with manual gauge. Could also see that VCDS reports 250kpa fuel pressure with pump running using the fule pump test. Not sure what the actual specified flow rate and pressure is supposed to be but looked good to me. Solid fuel flow. Replaced inline fuel filter. No glitter to be found.
  7. When cranking over VCDS seems to show low, high fuel pressure. It hits the 250kpa the same as I get when just doing a fuel test in VCDS when not cranking over. (see attached logging from last time I cranked it over)
  8. Thought maybe stuck open injector. Pulled glow plugs, no obvious sign of any cylinder been flooded.
  9. While there did a compression test on all 8, they were basically all the same so felt that logically they must all be ok.
  10. Borrowed a common rail high pressure tester - VCDS seems correct - very low pressure when cranking over.
  11. Did a visual inspection of the high-pressure pump as best you can without removing anything can see that the belt looks ok, have not pulled it it.
  12. Probably done other things but this is where I am at. I have cleared codes and don't have the very first scan I did. Should have kept it. Current scan and logs below
From what I can tell it's a high fuel pressure problem. What are my options at this point that I have not looked at. High pressure fuel pump stuffed? Fuel pressure or Fuel Meter valve faulty? Dead ECU? Thanks for any advice.
Logs from last crank over attempt.
Friday09May
2025
16:36:54:53036-VCID:382EF6A582DF790A77A-806CVCDS Version: Release 25.3.1 (x64)Data version: 20250415 DS365.0
4L0 910 409 QADVMB4.2TDI EDC17 H40 0001
G021F0G026F0G040F0G055F0G117F0G118F0G133F0G190F0G225F0G256
MarkerTIMELoc. IDE00188TIMELoc. IDE00201TIMELoc. IDE00357TIMELoc. IDE00371TIMELoc. IDE00475TIMELoc. IDE00476TIMELoc. IDE00589TIMELoc. IDE01378TIMELoc. IDE02228TIMELoc. IDE03892
STAMPFuel high-pressure: actual valueSTAMPHigh fuel pressure: specified valueSTAMPFuel temperatureSTAMPFuel consumptionSTAMPFuel Pressure Regulator ValveSTAMPFuel Metering ValveSTAMPFuel pressureSTAMPFuel high pressure: control deviationSTAMPFuel pressure regulator valve: specified value rail pressureSTAMPFuel high pressure sensor: unconditioned voltage
hPa hPa °C l/h % % kPa hPa hPa mV
0.93
300000
1.18
16.2
0.03
6.32
0.28
8.37
0.36
300000
0.59
498.4
2.19
300000
2.43
16.2
1.28
6.32
1.53
8.37
1.61
300000
1.84
498.4
3.46
300000
3.7
16.2
2.56
6.32
2.79
8.37
2.9
300000
3.14
498.4
4.77
300000
5.01
16.2
3.83
6.32
4.06
8.38
4.16
300000
4.41
498.4
6.01
300000
6.23
16.2
5.13
6.32
5.35
8.38
5.44
300000
5.69
498.4
7.32
300000
7.54
16.2
6.35
6.32
6.58
8.38
6.69
300000
6.94
498.4
8.56
300000
8.79
16.2
7.66
6.32
7.88
8.38
7.97
300000
8.2
498.4
9.82
340000
10.04
16.2
8.92
6.34
9.14
8.38
9.25
340000
9.48
1600000
9.72
498.4
11.06
340000
11.28
16.7
10.16
1.76
10.26
33.35
10.38
44.82
10.47
340000
10.69
620900
10.95
498.4
12.29
340000
12.5
17.1
11.38
1.86
11.48
42.26
11.6
46.01
11.72
340000
11.95
758400
12.19
503.2
13.57
2500
13.69
340000
13.82
17.2
12.62
2.33
12.72
70.02
12.84
44.18
12.95
250
13.09
337500
13.22
837500
13.45
503.2
14.82
2500
14.94
340000
15.03
17.2
13.91
2.93
14.03
68.97
14.16
44.68
14.25
250
14.38
337500
14.48
725000
14.69
503.2
16.1
2500
16.22
340000
16.34
17
15.16
3.19
15.27
70.41
15.39
44.72
15.51
250
15.63
337500
15.73
670900
15.97
503.2
17.37
2500
17.5
340000
17.62
16.6
16.47
3.53
16.58
70.5
16.69
44.47
16.83
250
16.92
337500
17.04
545900
17.26
503.2
18.66
2500
18.76
340000
18.88
16.1
17.76
3.63
17.86
70.89
17.99
44.59
18.1
250
18.22
337500
18.33
666700
18.54
503.2
19.92
2500
20.04
340000
20.16
15.6
18.97
3.35
19.09
71.25
19.21
44.28
19.33
250
19.44
337500
19.57
704200
19.79
503.2
21.14
2500
21.27
340000
21.36
15.1
20.25
3.91
20.38
71.42
20.48
44.88
20.59
250
20.71
337500
20.84
662500
21.04
503.2
22.4
2500
22.51
340000
22.64
14.8
21.49
4.12
21.59
71.56
21.72
44.74
21.84
250
21.96
337500
22.08
800000
22.3
503.2
23.65
2500
23.77
340000
23.86
14.5
22.73
3.57
22.83
71.14
22.94
44.67
23.05
250
23.17
337500
23.3
500000
23.53
503.2
24.91
2500
25
340000
25.12
14.3
23.99
3.68
24.09
72.53
24.21
44.94
24.33
250
24.44
337500
24.57
787500
24.79
503.2
26.2
2500
26.33
340000
26.44
14.2
25.26
3.91
25.36
71.93
25.48
44.71
25.6
250
25.72
337500
25.85
500000
26.09
503.2
27.43
2500
27.55
340000
27.64
14.2
26.53
4.12
26.66
72.97
26.75
44.98
26.89
250
26.97
337500
27.1
779200
27.33
503.2
28.65
2500
28.77
340000
28.86
14.2
27.77
3.92
27.87
72.24
27.99
45.02
28.09
250
28.2
337500
28.33
687500
28.55
503.2
29.87
2500
30
300000
30.11
14.2
28.98
3.66
29.08
73.99
29.18
45.37
29.29
250
29.39
337500
29.52
662500
29.75
503.2
31.12
2500
31.23
300000
31.36
14.2
30.24
18.23
30.46
37.01
30.58
250
30.68
297500
30.8
150000
31.02
503.2
32.36
2500
32.47
300000
32.59
14.2
31.45
18.42
31.68
36.83
31.8
250
31.9
297500
32.02
503.2
33.6
2500
33.72
300000
33.84
14.2
32.7
18.1
32.93
35.82
33.04
250
33.14
297500
33.28
503.2
34.91
2500
35.01
300000
35.13
14.3
33.98
18.03
34.21
35.65
34.33
250
34.44
297500
34.57
503.2
36.11
2500
36.24
300000
36.36
14.3
35.22
17.99
35.47
35.5
35.57
250
35.69
297500
35.79
503.2
Full auto scan:
Friday,09,May,2025,16:59:10:53036
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.5
VIN: WAUZZZ4L9DD010107   License Plate:
Mileage: 235870km-146562mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 11 31 15 16 17 18 19 28 34 36 42 46 47
          4F 52 55 56 57 5F 62 69 6C 6D 6F 72
VIN: WAUZZZ4L9DD010107   Mileage: 235870km-146562miles
Address 01: Engine (J623-CCFC)       Labels:. 057-907-409-V1.clb
   Part No SW: 4L0 910 409 Q    HW: 4L0 907 409 A
   Component: 4.2TDI EDC17  H40 0001
   Revision: 55H40---    Serial number:                CVN: B5857724
   Coding: 2A2A4012C53600020000
   Shop #: WSC 30371 000 1048576
   ASAM Dataset: EV_ECM42TDI1114L0910409Q 001001
   ROD: EV_ECM42TDI1114L0910409Q.rod
   VCID: 382EF6A582DF790A77A-806C
   VINID: 9D196AAAA11C2545000400401C0704FAE6
Address 02: Auto Trans (J217)       Labels:| 0C8-927-7XX-V1.clb
   Part No SW: 0C8 927 750 AA    HW: 0C8 927 750 AA
   Component: AL1000 AISIN  001 2100
   Serial number:                CVN: D6A967BC
   Coding: 001178
   Shop #: WSC 41173 004 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 6B8419E9830902924A8-803E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0103600
   Shop #: WSC 31414 790 00001
   VCID: 3436C29592379D6A5B2-8060
                    Reset counter: 12
                    Mileage: 235870 km
                    Date: 2025.05.09
                    Time: 17:52:49
                    Count: 325
                    Count: 297
                    Count: 45056
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702004489
   Coding: 0000151
   VCID: 25102FD129EDF4E2DCC-8070
   Subsystem 1 - Part No: 4F0 910 132 C
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Subsystem 3 - Part No: 4F0 910 220 F
   Component: FBSAUDIC6 IDG   H01 0053
Address 08: Auto HVAC (J255)       Labels: 4L0-910-043.clb
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
   Revision: 00---026    Serial number: 00000000340611
   Coding: 01028458
   VCID: 25102FD125EDF4E2DCC-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0123121
   VCID: 6E8210FDBC9BF7BA6D6-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55901103301730
   Coding: 29011F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3436C2959EB79D6A5B2-8060
Address 11: Engine II (J624)       Labels:. 057-907-409-V1.clb
   Revision: 55H40---    Serial number:                CVN: 110CF501
   ASAM Dataset: EV_ECM42TDI2114L0910409Q 001001
   ROD: EV_ECM42TDI2114L0910409P.rod
Address 15: Airbags        Labels: 4L0-910-655.clb
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D09GFRF
   Coding: 0014128
   VCID: 2E02D0FD7C1BB7BA2D6-807A
   Subsystem 1 - Serial number: 6332QSME3E192168J
   Subsystem 2 - Serial number: 6342QSME49192266F
   Subsystem 3 - Serial number: 6352QSME2719195EP
   Subsystem 4 - Serial number: 6362QSME5817204CH
   Subsystem 5 - Serial number: 63734SME4A183870%
   Subsystem 6 - Serial number: 63834SME6016404AX
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90055121260122
   Coding: 0112142
   VCID: 280E26E55EFFE98AE7A-807C
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels:. 4L0-920-KOM-V3.clb
   Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
   Component: KOMBIINSTR.   H35 0316
   Revision: 00000000    Serial number: NGA413V7D
   Coding: B356630400010008010704
   VCID: 323AC48D6423935A49E-8066
Address 18: Aux. Heat        Labels: 4L0-910-105.clb
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000001
   VCID: 609E7EC5764F51CAEFA-8034
00456 - Control Module for Access and Start Control (J518)
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0058
   Revision: LB600036    Serial number: 3600L1271400A0
   Coding: 00C303
   VCID: 3E22E0BDA07B473ABD6-806A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790882915
                    Reset counter: 12
                    Mileage: 235870 km
                    Date: 2025.05.09
                    Time: 17:52:48
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 7
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AA
   Revision: 00---010    Serial number: 00000000339579
   Coding: 0000006
   VCID: 688E66E59E7F298A27A-803C
Address 34: Level Control        Labels: 4L0-910-553.clb
   Part No SW: 4L0 910 553 J    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7860
   Revision: --H04001    Serial number: 15.1528-0143.2
   Coding: 0015520
   VCID: 3138CB816D25A842304-8064
            013 - Check DTC Memory
                    Fault Status: 11101101
                    Reset counter: 12
                    Mileage: 235870 km
                    Date: 2025.05.09
                    Time: 17:55:27
                    Error Code: 98
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00000035058539
   Coding: 00781B00000011110000
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000034829966
   Coding: 011C52205E41440004
   VCID: 48CE8665F2BF098A07A-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01802633700000
   Coding: 3539341
   VCID: 382EF6A58E5F790A77A-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000024298
   Coding: 030000
   VCID: 290823E149F5D082F84-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000649271
   Coding: 0011001
   VCID: 5EE2403D4C3B673ADD6-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000034536087
   VCID: 47CC8559FFA106F20E0-8012
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 120723-0002-084
   Coding: 11476F1010000400
   ROD: EV_HeadlRegulBasic_AU35.rod
   VCID: 42DA944DD40323DAD9E-8016
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227G.0C7615462
   Coding: 040003010000000000
   VCID: 21183BC131C518C2A04-8074
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 A    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0510
   Revision: R0043000    Serial number: 06801100761001
   Coding: 07000000
   Shop #: WSC 31414 000 90108
   VCID: 2B04D9E94309C2920A8-807E
   Part No SW: 4L2 035 754 E    HW: 4L2 035 754 D
   Component: H-BN-RW       H44 0528
   Revision: --------    Serial number: 221GM0C7501234
   Coding: 180A0106000493EF410023456F632003FC0000020100000000
   VCID: 2F3CCDF97711BEB2260-807A
   Subsystem 1 - Part No: 8R0 060 884 AJ
   Component: ROW 2012  0403
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130D30CS160816
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002027577
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000034863447
   Coding: 010850204041230004
   VCID: 46D2885DF8AB1FFAF56-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Revision: 2A001001    Serial number: 00000180506761
   Coding: 0300000000000000
   VCID: 3138CB816125A842304-8064
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0049970
   Coding: 020C000001000100010102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6E8210FDB01BF7BA6D6-803A
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C861AF58A8705AA432-8038
   Subsystem 2 - Serial number: 6ó
   Subsystem 3 - Serial number: RD07.08.12--H57001002F0111ÿ
   Subsystem 4 - Serial number: 2F0111ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 128665029-----
   Coding: 0003587
   VCID: 261228DD54EBFFFAD56-8072
   Component: J_245_EE16_SKB10H12 0220
   Component: J_394_EE16_SKB10H12 0220
   Component: J_392_EE16_SKB10H12 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000034863533
End----(Elapsed Time: 02:14, VBatt start/end: 12.5V/12.5V. VIgn 0.0V)------
------------------------------5 Faults Found-------------------------------
Use VPN and don't search using the actual VIN... just select the same vehicle configuration based on the dropdown menus, etc.
It appears so.... you didn't log RPM... I see all other kinds of useless MVBs there.
Are you getting fuel to the filter and past it? Or where did you measure your flow at?
Did you properly bleed the fuel system after the filter change?
JoelG
Australia
C?ID=615191
Thanks for the tips on the VPN and VIN. I'll sort that.
Yep some 100% random not useful stuff logged :), was just playing with what I could see, should have removed the fluff and should have had RPM in that one! I'll do an update. Tested flow and pressure manually after filter and from what I understand I did a proper bleed of the fuel system. During the week probably have run electric fuel pump 30+ min in total over the many times I've been having a look at it.
Derek
UK (ilexa)
C?ID=56983
Even if you don't click save, VCDS saves a backup of the scan in case it may be useful
Check the directory/folder "C:\Ross-Tech\VCDS\Scans"
Best regards
Derek
