2014 Audi A8L TDI (D4), Adaptive Cruise Control does not work (ACC and Audi Braking guard: Unavailable).
Andy_Beezy
Virginia, USA
C?ID=618599
Hello. Long time listener, first time caller. I was a degen for many years and had a knockoff VCDS scan tool (I was poor, but not an excuse. I know). I then went to OBD11 and now I finally took the plunge and got an official RT Scan Tool.
But now to the real issue at hand. I bought a 2014 Audi A8L TDI about 2 months ago and never had working Cruise Control (ACC and Audi Braking guard: Unavailable). Little did I know that the ACC system is far more complicated than any other system I've ever worked with. I scoured the internet and about every forum I could find, but I was still unable to fix my issue. So I did what any defeated person would do, I went to the Audi dealership and had them "troubleshoot" it. After about a day of diagnostic, they told me the right front radar sensor was bad and needed to be replaced and they could get it here in 5 days for the low, low cost of $6k.
So I went on Ebay and bought both front radar sensors for about $350. Then I found out about CP and that the dealership had to remove it. I rescanned the system and it came back with the same faults with an additional CP fault. I put the old sensors back in and ran it. The original codes appeared and the CP was gone. I then decided to just replace the right sensor (the one Audi said was faulty) and it came back with the same faults, but did not show the CP fault. I never really saw a sensor bad fault, it only showed a bunch of missing messages or faults with limitations in other systems.
I have since put my original radar modules back in and I'm holding on to the used ones.
I've attached my scan below and I hope anyone can steer me in the right direction.
Wednesday,07,May,2025,13:10:36:41515
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WAURMAFD2EN006630   License Plate:
Mileage: 288048km-178984mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 34 36 3B 3C 42 46
          47 48 52 53 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8A 8B
          8D 8E 8F 90 AC
VIN: WAURMAFD2EN006630   Mileage: 288048km-178984miles
48-Seat, Rear, DS -- Status: OK 0000
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: OK 0000
85-On Board Cam. -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CPNA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 907 401 F    HW: 4G0 907 401 E
   Component: 3.0TDI FSA    H14 0013
   Revision: 58H14---    CVN: E4E7E825B09F27B738D3FF8238D3FF8288B145BC
   Coding: 0A2A4012056601050000
   Shop #: WSC 45351 001 1048576
   ASAM Dataset: EV_ECM30TDI0114H0907401F 002015
   ROD: EV_ECM30TDI0114H0907401F_002.rod
   VCID: 270C2550CF673682EE0-8072
   VINID: 9D196275159409578000618300649A62C2
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00100111] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:13
                    Engine speed: 0.00 /min
                    Coolant temperature: 85 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 12.180 V
                    Cruise Control System (CCS): status-Bits 0-7: 244
                    selected gear-Bits 0-7: 0
Readiness: 0 0 0 1 1
   Part No SW: 4H1 927 158 AM    HW: 0BK 927 156 AG
   Component: 0BK 30 TDIUSA H16 1008
   Revision: --H16---    CVN: E0C660FA
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002020
   VCID: 7BA42920636F4262DA8-802E
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 60E5F30006A7CF00E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 3436C21C0EB14D1A5B2-8060
0386 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_ACC_05_Timeout]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 1F
                    F-Type: 5B
                    Uz: 9A
0650 - Function Restricted due to Missing Message(s)
          [ComScl_PDU_ACC_10_Timeout]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:19
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 21
                    F-Type: 30
                    Uz: 9A
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 DD
   Component: BCM2 2.0      H35 0510
   Coding: 0DA72046000000000000
   VCID: 6E821074209D27CA6D6-803A
   Serial number: 0213000279934011
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000074583176
   Coding: C018B60085047201010001010101112131313333283333
   VCID: 3530FF18054B54126CC-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0130
   Coding: 368122FE7C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 29082368D97300F2F84-807C
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001917628
   Coding: 09072091077C9FE38B000804A0003800009CD3088E0001218001085C7B00
   Shop #: WSC 41751 006 1048576
   VCID: 6FBC0D7027972EC2660-803A
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 130704  H35 0080
   Serial number:         130816092031
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10340456
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 05 09 2013  00000210
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R7PXG03
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000009091300010822
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000013091300010891
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106231000004266434
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 21480BC6000000000001
01319 - Control Module for Distance Control (J428)
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031326400675
   Coding: A80B0E
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004_AU64.rod
   VCID: 71B80B0831233832704-8024
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [00001001] - Open or Short to Ground
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
12727552 - Databus
          [Steuergerät für Abstandsdistanzregelung - ACC_02_FR - kein Signal/keine Kommunikation]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H45 0042
   Revision: --------    Serial number: 003JS001LTFU Dataset Number: 4H0909602D  0004
   Coding: 303143303230303030314A55304C34483053
   VCID: 372CF5101FC7A6027E0-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1381608RST
   Serial number: 3575HRB400C50KUAIGR2
   Serial number: 3585HRB400A50KUA9GAI
   Serial number: 3515JRB405126M6ML974
   Serial number: 3525JRB405126M6M4PA7
   Serial number: 3554VRB406526M6KGP8Y
   Serial number: 3564VRB406726M6K50IB
1050368 - Databus
          [CAN: 0x323 PCF_01 Timeout]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:12
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815MII0006F
   Coding: 0004BC
   VCID: 382EF62C1259A97A77A-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0010
   Serial number: 23 05 2013  C1084561
   Part No SW: 4H0 920 880 A    HW: 4H0 920 880 A
   Component: TDieUSAACC--- H50 0515
   Revision: 36081079    Serial number: 658270813592010
   Coding: 0B4608015740D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU64.rod
   VCID: 280E266CC27939FAE7A-807C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
   Component: Analoguhr D4  H05 0225
   Serial number: 2130826000637
16776960 - Function Restricted due to Missing Message(s)
          [ACC_02_FR keine Kommunikation]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
16776961 - Function Restricted due to Missing Message(s)
          [ACC_04_FR keine Kommunikation]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000001095689 Dataset Number: 4H0909515F  0071
   Coding: 00CD077D00
   GVL: FFA7E94CFAE3F7FEC000
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 72BA04043425032A89E-8026
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 50241L17041911998030
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 A    HW: 8K0 959 663 A
   Serial number: 13245002409011200181
   Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
   Component: FLA           H04 0020
   Revision: AB001001
   Coding: 04018B6B74745D545420363E00
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 L    HW: 4H0 919 158 L
   Component: Klima Fond    H16 0200
   Coding: 2600000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck_AU64.rod
   VCID: 3928F32829D3B072884-806C
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Dataset Number: 4H0909553G  0036
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2E02D074E09D67CA2D6-807A
0002 - Function Restricted due to Missing Message(s)
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000074583151
   Coding: C018BF8085857201030001010101112131313333203333
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA77014LJA
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E02D074EC1D67CA2D6-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0050
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F13.09.1300H02000AMS15794ÿ
   Subsystem 4 - Serial number: S15794ÿ
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0273
   Revision: --------    Serial number: 0000075846769
   Coding: 011F1F005E0062C202003017
   VCID: 48CE86EC62B9D9FA07A-801C
   Revision: 00002001    Serial number: 0314396189
   Coding: 0106023A00FA759FB0A0C784020301070000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0081
   Serial number: 00000000000000263768
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 334400092183
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000830010
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 335200094095
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 334400092186
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 335200094117
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84380225
   Part No SW: 4H0 035 465 C    HW: 4H0 035 465 B
   Component: BO G3 D4      H09 0180
   Revision: 09000000    Serial number: 0020056
   VCID: 26122854C8ED2F8AD56-8072
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 03007130024709
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000073904394
   Coding: C01892808500700D0B00392038193A2039203B3B202020
   VCID: 323AC404F425432A49E-8066
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0273
   Revision: --------    Serial number: 0000074578323
   Coding: 011F1F005E0062C202003006
   VCID: 3C26EA3C2661855A932-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000815091 Dataset Number: 4H0909522C  0011
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B04D960D38F12E20A8-807E
327936 - Function Restricted due to Missing Message(s)
          [FC_ACC_05_MESSAGE_TIMEOUT]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
                    Voltage terminal 30: 12.4 V
                    Internal Fault ID: 86
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 035 082 G    HW: 4H0 035 082
   Revision: AB001007    Serial number: 155I30D7574248
   Coding: 020007010003000001
   VCID: 25102F58B5EB2492DCC-8070
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000073910665
   Coding: C01896808500700D0B00392038193A2039203B3B382020
   Part No SW: 4H0 035 746 F    HW: 4H0 035 746 F
   Component: H-BNT-NA      H40 0735
   Revision: --------    Serial number: 183I20D7513478
   Coding: 020200000001F9EF7D168B1E00000003140001000000000000
   VCID: 2B04D960D30F12E20A8-807E
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDDC900RV9H
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000129736
   Component: CD-Database  5298
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:17
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0276
   Revision: --------    Serial number: 0000075580884
   Coding: 010F1F00420062C202003006
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0105824
   Coding: 020A000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   VCID: 2C06DA7CD68115DA032-8078
9617993 - Proximity Camera
          B145C 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
                    Voltage terminal 30: 12.1 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 235300228 Dataset Number: 4H0909541E  0022
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6E821074201D27CA6D6-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000123328 Dataset Number: 4F0000000__ U001
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63947140FBDF9AA2F28-8036
   Component: TSG HR        H06 0276
   Revision: --------    Serial number: 0000075580755
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 G    HW: 4H0 035 774 G
   Component: H-BN-NA       H40 0736
   Revision: --------    Serial number: 188IW0D7503101
   Coding: 02020000000100400100000400001300000000000000000000
   VCID: 2D00D778ED1B1CD214C-8078
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDD120152K3
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDD120152J2
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238MIK00029
   Subsystem 5 - Part No: 8R0 060 884 BD
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5015    Serial number: SN130805  0500
   ROD: EV_GSM2x3Mono_AU64.rod
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H10 0042
   Serial number: 0K84AE40100329
   Coding: 1200
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 323AC404F4A5432A49E-8066
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001316900034
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4H0909547E  0033
   Coding: E9060000
   Shop #: WSC 36196 001 1048576
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 26122854C86D2F8AD56-8072
0724 - Function Restricted due to Missing Message(s)
          [ACC_timeout]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:12
                    Outside temperature: -34.5 °C
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 77.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00012920005402 Dataset Number: 4H0909880D  0019
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt_AU64.rod
   VCID: 2F3CCD70E7976EC2260-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00012920153402 Dataset Number: 4H0909881D  0019
   Coding: 366FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00012921037801 Dataset Number: 4H0909882D  0014
   Coding: 306F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002_AU64.rod
8 Faults Found:
94720 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
                    Voltage terminal 15: 12.247 V
                    Velocity_vehicle_reference: -0.00 m/s
94976 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_QDCPSS_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
95232 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_QEPBACC_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
95488 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
77312 - Function Restricted due to Missing Message(s)
          [FAULT_CIM_TIMEOUT_LRRM_TRIG]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
                    Voltage terminal 15: 12.251 V
77568 - Function Restricted due to Missing Message(s)
          [FAULT_CIM_TIMEOUT_LRRM_DEJU]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:08
144896 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_US_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
82688 - Function Restriction due to Faults in Other Modules
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:31:07
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00012921050001 Dataset Number: 4H0909883D  0014
   Coding: 306F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000120309137
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0046 - Function Restricted due to Missing Message(s)
          [ACC_timeout]
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
                    Outside temperature: 31.5 °C
                    Voltage terminal 15: 12.3 V
                    Control Module temperature: 47.0 °C
   Dataset Number: 4H0909614C  0003
   Coding: 0066F609031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3138CB08F1A37832304-8064
12583680 - Function Restricted due to Missing Message(s)
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
12583693 - Function Restricted due to Missing Message(s)
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
   Dataset Number: 4H0909615C  0003
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
                    Reset counter: 76
                    Mileage: 288048 km
                    Date: 2025.05.07
                    Time: 12:21:11
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H09 0010
   Revision: 00000000    Serial number: 131980225 Dataset Number: 4H0909571D  0014
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 03:56, VBatt start/end: 12.3V/12.3V)-----------
------------------------------27 Faults Found------------------------------
Oh boy.... so how much do you know about the ACC system in your A8?
If it's says no coms with a unit, have you checked for power\grounds\data connections\wires at said module?
Do you have wiring diagrams, tools and skills to do all this?
Andy_Beezy
Virginia, USA
C?ID=618599
I can definitely do the power and ground checks pretty easily. I have the Audi Service manual for the car, but I don't have the wiring diagrams. I wish I did so I could at least check for continuity to the busses. I did look at the connectors on both front sensors but I didn't have the common corrosion issues like everyone else seems to have.
I'd also suggest you source and read some of the SSPs that discuss what you have.
Here are two of them to get you started down some path.
Self-Study Program 970103
The 2011 Audi A8 Convenience Electronics and Networking Systems
Self-Study Program 970203
The 2011 Audi A8 Driver Assistance Systems
We can direct you to the WD's and I'm sure the forum would help out, but it all may be a mute point.
Why, because of component protection . So if it turns out that one of those components is faulty and it has CP, you will need to go to the dealer anyway. It may not be 6K in cost, but you need to realize that the dealer may not accept used parts and you'll have to purchase brand new ; it can and does happen.
I would check with the dealer and ask the service manager if you supplied "used" parts, will they remove the CP and calibrate this system for you.
The WD's are a $35.00 subscription for a day ; You can download all the files for your VIN (use the VIN function on the erWin web-site) . It will only take you about 30-45 minutes.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
You should also understand that this is one of Audi's most advanced vehicles and will be quite a journey for you ; but hey, if this is your desire jump in...... but be prepared for a dead end regarding any dealer involvement. (and sometimes there is no other way around a dealer visit).
Andy_Beezy
Virginia, USA
C?ID=618599
Stefdds,
Thank you for pointing me there and the support. I really appreciate it! I know it'll be an undertaking, but I like fixing things, plus other than just reading a scan from the diagnostic tool, i don't think the tech went any further.
I'll try and get all the wiring diagrams I think I'll need.
SaVAGeSoot,
Thank you. These are great. I read through both of those and at least now know what components work together. I can at least try and see if I get any continuity between the left J850 and the right J428.
The main thing I was curious about was the fact I didn't get CP on the right sensor with the used part in. Which means it's either a bad part or the wiring could be suspect.
OK, great. I just want to give you a tip regarding the erWin download.
I would suggest you download everything for your VIN / vehicle. Audi organizes the information in a unique way and you may leave a file behind not realizing some of the information you need is with another heading or title. The titles can be confusing or vague.
So, in general what you will see when you enter your VIN is (what I'm calling) a main box or menu with the main titles ; there maybe 5 or 6 of these "titles". Start with the top one what ever it is, click on it, and notice that Lower on the page (you may need to scroll downward) you will see a list of files for that (first) heading. Click on each one separately to download it , each will take about 30-45 seconds or so. Then go to the next file and download all of them.
Now, go back up to the Main box again, and click on the next main title. See below for how many files it shows below, on the lower part of the page. Repeat as above.
Do that for each Title, you can peruse them later and figure out the contents of each. Also, once downloaded and you open one for example, look to the upper left area / margin and click on the icons: one is a thumbnail view and the other is more of a descriptive index with the sections shown in that file.
The file is loaded with hyperlinks, which makes finding items a whole lot easier. So, click around a bit also. Let us know how you make out!
Andy_Beezy
Virginia, USA
C?ID=618599
I just downloaded a ton of manuals from erWin. I took a cursory glance over the wiring diagram and found the connections i need to check for J428 and J850. I also did a lot of reading on the FlexRay system, but I don't know if I'll be able to read the data lines. Unfortunately I don't have an oscilloscope, nor do I really remember how to use one anymore (I was an aircraft electrician what feels like a lifetime ago). The cool thing is I can read most of what I need off the J533 bus isolation plug in the trunk.
Andy_Beezy
Virginia, USA
C?ID=618599
I found a great video on troubleshooting CAN BUS issues with just a multimeter.
Uhm.. Virtually all VAG cars (including yours!) use a Gateway with a "blind" diagnostic CAN bus that only goes to the Gateway, so doing electrical checks on the CAN bus at the OBD-II connector is worthless unless you have no diagnostic communications with anything at all, which is clearly not the case.
Why not just start with the basics, and confirm the things that you can, with the tools that you do have.
Check basic things like fuses\power\grounds & continuity.... see if that yields anything.
Andy_Beezy
Virginia, USA
C?ID=618599
Alright, I finally got some down time and did some troubleshooting. I'll do some documentation just for anyone that will inevitably be here in the future.
Here is what is on each connector:
J428 (t8a 8 pin connector to the US passenger side RADAR sensor (the book lists this as the left side sensor or the "distance regulation module"))
1- Ground (brown) - goes to ground connection 1 (456) on front bumper wiring harness
5- CAN Bus high (pink) - goes to pin 3 on J850
6- CAN Bus low (green) - goes to pin 4 on J850
8- Power (red and black) - goes to positive connection 1 (C45)
J850 (t8b 8 pin connector to US driver side RADAR sensor (the book lists this is the right side sensor or the "distance regulation module 2"))
3- CAN Bus high (pink) - goes to pin 5 on J428
4- CAN Bus low (green) - goes to pin 6 on J428
5- CAN Bus high (pink) - goes to pin 26 on t32f on J533 (in the trunk in my A8)
6- CAN Bus low (green) - goes to pin 10 on J533 t32f on J533 (in the trunk on my A8)
The modules receive 12vdc through the 10A fuse in slot 9 on fuse panel f. (For 2014 models)
I did make some major headway on my car. Everything wiring wise checked out on both connectors other than the ground on J428. I now need to remove the front bumper and find the ground connection 456 in the bumper harness. I jumpered a wire in the back of pin 1 and grounded it out. After I did this almost all of the missing message codes went away and I was actually able to select the adaptive CC options in the "car" menu on the display. Before I did any of this it was always grayed out. I then got the "Audi brake assist and ACC not available" message any time I tried to play with the CC switch on the column.
Now my question is, if it's out of calibration will it actually populate a code for it? I never got a "calibration required" from the ACC.
This feels like a major victory and I'm approaching a solution to this problem.
Thank you guys again for pointing me to the wiring diagrams and the self study manuals. They were absolutely necessary in understanding the complexities of the ACC integration.
Ziddywerks
Northern NJ USA
C?ID=208579
You got yourself an actual lemon there. Let's ask the obvious questions first. Was the vehicle ever in an accident where the front end took a hit?
Andy_Beezy
Virginia, USA
C?ID=618599
I'm pretty sure the CARFAX said that it had an accident and received minor damage. I tried to ask the dealer if he knew any more about it, but they didn't.
After I got RT I also saw why every time I used the parking aid you'd get an audible beep saying the front sensors didn't work. It's because the right front sensor had a fault. I'm assuming these issues presented themselves and the PO didn't care enough to fix them, or they aren't related and just happenstance.
Either way, I gotta get it fixed.
Ziddywerks
Northern NJ USA
C?ID=208579
I will assume that the harness is fucked and or damaged from the hit possibly causing intermittent communications issues. This car is a buyback.
Andy_Beezy
Virginia, USA
C?ID=618599
Yeah. I knew it was a buyback. It got branded when Audi bought it back for the emissions. It was in the paperwork when I got it.
Andy_Beezy
Virginia, USA
C?ID=618599
Okay. I didn't take the bumper off, but I was able to find the severed ground wire. It looked as though it had been smashed or ripped causing the break. I made a temporary semi-permanent ground so that way I could test it while it was all back together. I would imagine I now need an alignment. Will it say it needs one or will it just say that there is a fault due to a restriction in another module?
Here is my new vehicle scan:
Friday,06,June,2025,19:00:23:41515
VCDS Version: 25.3.1.2 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250604 DS365.0
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8A
          8B 8D 8E 8F 90 AC
VIN: WAURMAFD2EN006630   Mileage: 289615km-179958miles
   VCID: 270C2550CF673682EE3-8072
15474 - Particulate Matter Sensor
          P24AE 00 [10101111] - Electrical Malfunction
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 18:00:10
                    Engine speed: 741.50 /min
                    Normed load value: 49.8 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 13.860 V
                    Exh u PP Ds Batt Snsr Raw: 13.9 V
                    Com i PP Ds IDE Raw: 0.000 µA
                    Exh i PP Ds IDE Shnt Circ: 0.0 µA
                    Exh st PP Ds St Ma-Bits 0-7: 2
                    Particle sensor: surface temperature: 605.85 °C
                    Particle sensor: heat voltage: 0.00 V
Readiness: 1 1 0 1 1
   Coding: 000002
   VCID: 7BA42920636F4262DAB-802E
   VCID: 3436C21C0EB14D1A5B1-8060
   VCID: 6E821074209D27CA6D5-803A
   VCID: 3530FF18054B54126CF-8060
   Coding: 368122FE7C
   VCID: 29082368D97300F2F87-807C
   VCID: 6FBC0D7027972EC2663-803A
   Coding: 0045F7
   Coding: 025523
   Coding: 100000
   Coding: 100000
   Coding: 020300
   Coding: A80B0E
   VCID: 71B80B0831233832707-8024
                    Reset counter: 131
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 17:56:41
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H19 0410
   Serial number: 00000000000000 Dataset Number: 4H0909863D  0030
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002_AU64.rod
   VCID: 2A0ADC64DC750BEAF1D-807E
          [FAULT_CIS_US_FAIL]
                    Reset counter: 131
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 18:53:39
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 13.909 V
   VCID: 372CF5101FC7A6027E3-8062
   Coding: 0004BC
   VCID: 382EF62C1259A97A779-806C
   VCID: 280E266CC27939FAE79-807C
   Analog_clock:
   Coding: 00CD077D00
   GVL: FFAFE94CFAE3F7FEC000
   VCID: 72BA04043425032A89D-8026
   Voltage stabilizer:
          U1101 00 [00001000] - Active
                    Reset counter: 171
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 17:56:44
                    Voltage terminal 30: 14.1 V
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 47 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Revision: AB001001
   Coding: 2600000000
   VCID: 3928F32829D3B072887-806C
   Coding: 008002
   VCID: 2E02D074E09D67CA2D5-807A
   ROD: EV_SARA2.rod
   Coding: 0000002
   VCID: 2E02D074EC1D67CA2D5-807A
   VCID: 48CE86EC62B9D9FA079-801C
   Coding: 020200
   Coding: 070000
   Coding: 020200
   Coding: 020200
   Coding: 020200
   VCID: 26122854C8ED2F8AD55-8072
   VCID: 323AC404F425432A49D-8066
   VCID: 3C26EA3C2661855A931-8068
   VCID: 2B04D960D38F12E20AB-807E
   VCID: 25102F58B5EB2492DCF-8070
   VCID: 2B04D960D30F12E20AB-807E
   VCID: 2C06DA7CD68115DA031-8078
                    Reset counter: 131
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 17:56:52
   Coding: 0210044100
   VCID: 6E821074201D27CA6D5-803A
   Coding: 200000
   ROD: EV_Ambie.rod
   VCID: 63947140FBDF9AA2F2B-8036
   VCID: 2D00D778ED1B1CD214F-8078
   Coding: 1200
   VCID: 323AC404F4A5432A49D-8066
   Coding: E9060000
   VCID: 26122854C86D2F8AD55-8072
   Coding: 766FF2
   VCID: 2F3CCD70E7976EC2263-807A
   Coding: 366FF2
   Coding: 306F00
   Coding: 7E01020201
          [FAULT_CIS_US_FAIL]
                    Reset counter: 131
                    Mileage: 289615 km
                    Date: 2025.06.06
                    Time: 18:54:06
                    Control Module temperature: 55 °C
                    Voltage terminal 15: 13.763 V
   Coding: 306F00
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   VCID: 3138CB08F1A37832307-8064
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 03:48, VBatt start/end: 14.1V/14.0V)-----------
------------------------------6 Faults Found-------------------------------
Andy_Beezy
Virginia, USA
C?ID=618599
So nothing I read about in the Self-Study Programs or even after looking through the wiring diagrams suggests that the Parking Aid System assists the ACC and Audi Braking System communicate with each other, but could that be where the "fault in other modules" is? Is there a way to decipher what other module it's referring to?
Andy_Beezy
Virginia, USA
C?ID=618599
I fixed it!!!! For future reference the ACC somehow uses the park aid sensors. It's not in any literature that I've read, but once I fixed that issue, the ACC faults went away.
If anyone in the future needs to pull one of the right or left outside parking sensors, the maintenance manual actually tells you to pull the left or right headlight. Once I read that, finding the problem was cake.
My car definitely spent some time sitting with the previous owner. Maybe for a winter or perhaps longer at some point. My damaged wiring wasn't due to a crash or fender bender. It was likely due to a rat mouse. There was a lot of leaves and some fabric tucked next to that harness and a lot of chew marks.
I repaired the broken wires and now we're back in business!
