Can no longer turn off ESP
State-808
C?ID=522224
Hi All, After recently having some crash damage repaired by a non VW Workshop.
The "Adaptive Cruise Control Radar" was replaced.
Since then I have noticed the I can no longer turn off ESP (to stop the wheels spinning while in Mud/Snow)
Method used to turn off ESP
Ignition ON, then Warning lights ON, then depress the gas pedal 5 times = ESP OFF
It worked in the past but not any more?
Could this be connected to the Auto repair? (new ACC unit)
No faults found by VCDS
2017 VW T6 Multivan
State-808
C?ID=522224
Wednesday,07,May,2025,15:10:50:14270
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WV2ZZZ7HZJH037065   License Plate: HM
Mileage: 120700km-74999mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 18 19 25 55 5F 61 69 6E 0B
VIN: WV2ZZZ7HZJH037065   Mileage: 120700km-74999miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CJKB)       Labels:. 06J-907-309-V2.clb
   Part No SW: 06J 906 021 AC    HW: 06J 907 309 C
   Component: 2.0l R4 T-FSI H03 2032
   Revision: ELH03---    Serial number: 00000000000000 CVN: 069D5DD9
   Coding: 0119001B435401080000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TFS01106J906021AC 001005
   ROD: EV_ECM20TFS01106J906021AC.rod
   VCID: 6694B42ED8E4B6DA156-8032
   VINID: 9E60AAAAA1D8A9A6000C70061442F5F034
   Revision: 00000000    Serial number: 62087000002046
   Coding: 307E4398256584850C75C27CA48721D378F500
   Shop #: WSC 02739 790 50316
   VCID: 3FDA414AE7FEC712B60-806A
   Serial number: 30071713470034
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA4FC4EA0740E1AFD6-802A
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E0 907 040 R    HW: 7E0 907 040 R
   Component: ClimatronicT5 H04 0613
   Revision: 00001K04
   Coding: 0004000103
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis_VN75.rod
   VCID: 323C187E24AC1A7A49E-8066
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Component: Heckbedienung  H11 0303
   Serial number: BHB-0010108170015284
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 206172101
   Coding: 62A8393A0A21201301280F602CEB8FD4C0D47389604579603304003F0860
   Shop #: WSC 02739 022 119508
   VCID: 2B02051A03064BB20A8-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 280717 04  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU002081772141558
   Coding: 0400A1
   Subsystem 3 - Part No SW: 7E0 959 802 R    HW: 7E0 959 802 R  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU002081772140338
   Coding: 1400A1
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39170001879460037274
   Coding: B4FFFF
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261717800587
   Coding: 118009
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BED772E12A6162704-8024
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Serial number: 2209240465A1A8 Dataset Number: V03935300XV 0001
   Coding: 00004800FE0779
   ROD: EV_ACCBEGVW361.rod
   VCID: 3634246EC8C4065A656-8062
   Part No SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Component: VW10Airbag01V H08 0018
   Revision: --------    Serial number: 003V40039LM7 Dataset Number: 7E0003V____ 0912
   Coding: 000000000000000000000000000000003156
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B22355AF3E6DB329A8-806E
   Serial number: 3495ZRB400M59OGCGPQ
   Serial number: 3505ZRB400659GF2Q1CA
   Serial number: 3515ZRB400M59OGCC22N
   Serial number: 3525ZRB400O59OGCF8C2
   Part No SW: 7E0 920 870 R    HW: 7E0 920 870 R
   Component: KOMBI         H03 1107
   Coding: 140F010200
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 38282A56C2D0F02A77A-806C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 C    HW: 7E0 963 272 C
   Component: STH-T5GP2     003 0009
   Coding: 4401
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2C00060606884C8A032-8078
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042205
   VCID: 6888BA16D270A0AA27A-803C
   Component: IMMO          H03 1107
   VCID: 6A8CC01ECCFC92BA31E-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FCA020001000000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC_VW46.rod
   VCID: 3A2C305EFCDCE23A81E-806E
   Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Component: MU-E--ER      056 7205
   Serial number: 11071700011436 Dataset Number: V03935266VJ 0001
   Coding: 06570000BE00000041110001000000001F0000C40000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2A0C001E0C7C52BAF1E-807E
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 332B1A59
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 758857000017072400C6
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000449944386
   Coding: 410D000103000000
   VCID: 323C187E242C1A7A49E-8066
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 J    HW: 7E5 919 037 J
   Component: Dachdisplay   H17 0200
   Revision: 10100013    Serial number: 503357
   Coding: 000102
   Shop #: WSC 02759 790 00000
   VCID: 38282A56C250F02A77A-806C
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
---------------------------No fault code found.----------------------------
AINils
Germany (AIB)
C?ID=56975
Did you maybe have an older scan, where you surely know ESP off is working?
Coding is fine, maybe an updated firmware during service. But can't find a TPI in this case
State-808
C?ID=522224
Here's a Scan from 2 years ago
Thursday,18,May,2023,14:08:20:14270
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
VIN: WV2ZZZ7HZJH037065   Mileage: 73130km-45440miles
   VCID: 6694B42ED8E4B6DA957-8032
   VCID: 3FDA414AE7FEC712361-806A
   Coding: 01
   VCID: 7EA4FC4EA0740E1A7D7-802A
   Revision: 00001K04
   Coding: 0004000103
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 323C187E24AC1A7AC9F-8066
   Slave 1:
   VCID: 2B02051A03064BB28A9-807E
   Coding: 0228DD
   Coding: 0400A1
   Coding: 1400A1
   Coding: B4FFFF
   Coding: 118009
   VCID: 71BED772E12A6162F05-8024
   Serial number: 2407170452A209 Dataset Number: 7E0114v____ 0009
   Shop #: WSC 01383 790 50316
   VCID: 3634246EC8C4065AE57-8062
   VCID: 3B22355AF3E6DB321A9-806E
   Coding: 140F010200
   VCID: 38282A56C2D0F02AF7B-806C
   Coding: 4401
   VCID: 2C00060606884C8A833-8078
   Revision: B9082001
   Coding: 042205
   VCID: 6888BA16D270A0AAA7B-803C
   VCID: 6A8CC01ECCFC92BAB1F-803E
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2C305EFCDCE23A01F-806E
   VCID: 2A0C001E0C7C52BA71F-807E
   Coding: 332B1A59
   VCID: 323C187E242C1A7AC9F-8066
   Coding: 000102
   VCID: 38282A56C250F02AF7B-806C
End----(Elapsed Time: 01:42, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
The only difference I see is the dataset in the ACC radar.
Now: 7E0114v____ 0009
Old: V03935300XV 0001
State-808
C?ID=522224
Is a possible cause the ACC Radar not being an original VW Part ?
The new part number looks radically different. :confused:
Sebastian
Magdeburg, Germany
HN0-nnnnnn
A different dataset in the ACC should not have any influence on this, as this is a development function in the ESP and not meant for end users in the first place. Safety checks etc. are usually limited at best for these scenarios. Most likely we're looking at a user error here.
The part number, software and hardware level is identical. So either you are looking at different scans than we are or there is some communication error in this thread. 😉
State-808
C?ID=522224
:D haha... I love it. I wish it was, that would be an easy fix. In the mean time I've been back to the Workshop that did the work, as expected have no clue.:cool:
Two of there Mechanics/workers also tried the procedure (after checking online YouTube videos) to no avail :thanks:
State-808
C?ID=522224
Does one think a diagnostic by a VW Dealer would find the fault.
Do they have more resources?:confused:
Do you think that VW Dealer would admit that not being able to turn off ESP is actually a "fault"?
2kaa52
Ceska Republica, Praha
C?ID=319193
The different ACC dataset has a Bit that enable/disable this function.
Because of updated EU regulation this is diasabled now as Standard.
The size of this dataset is very small, so there is a good Chance to find that Bit and reactivate it.
State-808
C?ID=522224
Thanks @2kaa52 that sounds promising, a good starting point.
What I don't get is the new "EU regulation" which prevents this funtion?
Is this the case on new cars too? So no one will be able to turn off ESP?
2kaa52
C?ID=319193
Not really New, since some years it is so, Cars willbe delivered without that, for older Cars which have it, it will be turned Off when this Cars get a ECU configuration ( when unit replacement, accident repair etc.)
If you find a T6 which is Made for a Land outside EU, i can try to get the dataset for it ( with active esp Off function ) , then it can be loaded to your Car, or the differences between Datasets can be checked and yours can be modified.
A VIN of outside T6, which has ACC, is needed.
AINils
Germany (AIB)
C?ID=56975
Don't think ESP off will be handled in a ACC Dataset as cars without can't be configured. Also in the MQB Dataset there is no cinfiguration for it.
This is a ESP Software related thing. But in my experience this function wasn't available in Transporter cars in past
State-808
C?ID=522224
Yes it is or was 100% I used it in Winter 2023, after seeing the YouTube video on how deactivate in 2022 (which I tested immediately after seeing the video)
