2014 VW Golf 7 newly replaced DQ200 Clutch basic setting stuck at 192 0 0
SiriusBlack
Hong Kong (Not China)
C?ID=494130
Dear All,
I got a problem about I replaced a new DQ200 clutch (gen2) on my 2014 Golf 7, everything follows Luk's guide and tools.
When I do the basic setting, it stuck at 192, 0, 0 and valid. Even I tried to start the Engine, the status nor ang calibration movment can be heard.
Any idea ?
Regards
SiriusBlack
C?ID=494130
Address 02: Auto Trans (0CW 300 045 )
13:30:37
IDE00102-ENG102028 Control Module temperature-Control modul temperature 87 °C
IDE00322-ENG100540 Status of basic setting-Basic Settings Status 192
IDE02740-ENG99750 Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1 50 °C
IDE02775-ENG101304 Status of basic setting data-State Of Basic Adjustmentdata valid
IDE02824-ENG99279 Main status of abort code basic setting-Basic Settings Main Status 0
IDE03169-ENG104175 Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers 0
IDE04612-ENG101246 Clutch temperature air / splash oil-Centrifugal oil temperature 56 °C
SiriusBlack
C?ID=494130
Monday,05,May,2025,13:58:57:19482
VCDS Version: 25.3.1.0 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250408 DS365.0
VIN: WVWZZZAUZEW006257   License Plate:
Mileage: 116952km-72670mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZEW006257   Mileage: 116952km-72670miles
02-Auto Trans -- Status:  OK 0000
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: R4 1.4l TFS   H08 9171
   Revision: WAH08---    CVN: F2944A0C
   Coding: 01250032230401082000
   ASAM Dataset: EV_ECM14TFS01104E906016G 002013
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 2615FEEBA863CC9AD57-8072
   VINID: 9E69EAAAA465A959C00060851C14514F93
Readiness: 0000 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5243
   Revision: 00043014    Serial number: CU501305025252 CVN: 00006919
   Shop #: WSC 69905 136 139810
   ROD: EV_TCMDQ200021.rod
   VCID: 76B5EEAB3843FC1AA57-8022
   Revision: 00000000    Serial number: 612330000002EC
   Coding: 01FA8AA1242011720379060541CA2980512488C0608294F300220038C102
   VCID: 7BA3FF9F0361A172DA9-802E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00120214200100011005000000101000
   VCID: 6695BEEB68E30C9A157-8032
   Air quality sensor:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [00001000] - -
                    Reset counter: 94
                    Mileage: 116952 km
                    Date: 2025.05.05
                    Time: 13:52:27
                    Voltage terminal 30: 13.0 V
                    Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011313502006 Dataset Number: 5G0063v____ 0001
   Coding: 03101A46C24122FB0BA44080B10C0728100A000000000000000000000000
   Shop #: WSC 00078 790 12345
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77ABE3AF3F498512BE1-8022
   Component: WWS    130509  042 0551
   Serial number:         130516040607
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M05D18H09M35S55S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131003CEW
   Serial number: 00000000000056720264
   Sunroof control module:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO21787065
   Coding: 181801
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231313400389 Dataset Number: 5G0039v__A_ 0008
   Coding: 0031051011
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   VCID: 3B233F9F43E161729A9-806E
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Component: AirbagVW20    011 0361
   Serial number: 003F5R051MYQ Dataset Number: 5G0003v____ 0075
   VCID: 40D948732A0702AACFB-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 405 13
   Serial number: 35767000000765714D0S
   Subsystem 2 - Part No SW: -----------    HW: 480 001 405 13
   Serial number: 35867000000695414D0S
   Subsystem 3 - Part No SW: -----------    HW: 480 401 105 13
   Serial number: 351650299105066381D/
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 13
   Serial number: 3526502B51050663928-
   Subsystem 5 - Part No SW: -----------    HW: 480 401 105 13
   Serial number: 3556502991050660F1E6
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 15051304400462 Dataset Number: ----------
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 79AFE597095D9362C85-802C
   Part No SW: 5G0 920 861 B    HW: 5G0 920 861 B
   Component: KOMBI         204 3360
   Coding: 27AD190A2B80000E01086E00000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 2809F0D3A277DAEAE7B-807C
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000594591 Dataset Number: 5G0067v____ 1407
   Coding: 030100342B086400EF00024A1C0F00010001000000000000000000000000
   GVL: 01543C0000000000400C10000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   Generator:
   Subsystem 2 - Part No SW: 1EA 959 442 A    HW: 1EA 959 442 A
   Component: MFL  H03 0217
   Serial number: 17038312070902200100
   Coding: 0E0001
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2743710403
8782082 - ROD - Unknown Error Code
          - 00 [00001001]
                    Fault Frequency: 56
                    Reset counter: 54
                    Mileage: 116908 km
                    Date: 2025.05.05
                    Time: 07:43:43
                    Terminal 30 power supply: 14.3 V
                    Terminal 15: On
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 03051306071293 Dataset Number: 5G0222v____ 0036
   Coding: 003B0220D001040000001000
   VCID: 3FDB4B8F57F97D52B61-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001384794
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: 5G0074v____ 0128
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D2731875DF56F42A4D-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 03051306070745 Dataset Number: 5G0157v____ 0037
   Coding: 003B0020DE01040000801000
   VCID: 3E25368B50F3745ABD7-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001451608
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Revision: --------    Serial number: -------------- Dataset Number: 5G0036v____ 0015
   Coding: 029E00000B000200
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-LND-EU   040 1367
   Serial number: A578L0EB001080 Dataset Number: 8S0909545B  0019
   Coding: 02730001FF00000011111101028D00101F0106C6318001007F
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: 343114A36EBFAE0A5B3-8060
   Subsystem 1 - Part No SW: 5G6 919 606 A    HW: 5G6 919 606 A
   Component: ABT_High-2  163 9216
   Serial number: VWZ6ZWX3610309
   Subsystem 2 - Part No SW: V03 959 809 P    HW: -----------
   Component: ECE 2021/2022  --- 0192
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [00001001] - Open Circuit
                    Reset counter: 52
                    Mileage: 116908 km
                    Date: 2025.05.05
                    Time: 07:43:45
                    Voltage terminal 30: 14.5 V
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
3073 - Cellular Antenna
          B1053 13 [00001001] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 52
                    Mileage: 116908 km
                    Date: 2025.05.05
                    Time: 07:43:45
3084 - GSM antenna 2
          B1533 13 [00001001] - Open Circuit
                    Reset counter: 52
                    Mileage: 116908 km
                    Date: 2025.05.05
                    Time: 07:43:45
End----------(Elapsed Time: 01:28, VBatt start/end: 12.2V/12.2V)-----------
SiriusBlack
C?ID=494130
22:12:02
  IDE00008   Software version 5243
  IDE02825-ENG100313   Substatus of abort code basic setting-Basic Settings Sub Status 0
  IDE02860-ENG120867   Status of basic setting data clutch travel pressure characteristic-State_Of_Basic_Adjustmentdata_Clutch_Controltravel_Pressure_Characteristic 1
  IDE04612-ENG101246   Clutch temperature air / splash oil-Centrifugal oil temperature 71  C
  IDE06283-ENG120908   Clutch 2: adaptation: clutch end position closed (mm)-Clutch_2_adaption_upper_stop_closed_mm 20.3 mm
  IDE06287-ENG120906   Clutch 1 adaptation basic characteristics point 3 position (mm)-Clutch_1_adaption_basic_characteristic_point_3_mm 17.2 mm
  IDE06291-ENG120901   Clutch 2 adaptation basic characteristics point 3 position (mm)-Clutch_2_adaption_basic_characteristic_point_3_mm 15.9 mm
  IDE06293-ENG120904   Clutch 1: adaptation: clutch end position closed (mm)-Clutch_1_adaption_upper_stop_closed_mm 20.6 mm
  IDE80260-ENG127862   Pressure supply: act. press.-Pressure supply actual pressure 46.17 bar
SiriusBlack
C?ID=494130
And just got one more error :
10807 - Clutch 2
          P177C 00 [01001000] - Tolerance Limit Reached
                    Mileage: 117046 km
                    Date: 2025.05.06
                    Time: 21:16:43
                    Engine speed: 13323.00 /min
                    Engine torque: 216 Nm
                    Vehicle speed: 84 km/h
                    Control Module temperature: 83  C
                    CURRENT pressure: -5.5 bar
                    selected gear: GANG_UNDEFINIERT
                    Driving position: d
                    Accelerator pedal position: 0.0 %
                    DTC memory status: 45056
We do not have any experience with this dry clutch unit but that DTC looks like an issue with the shims. This may not be the best video on the topic but it may shed light on the procedure:
SiriusBlack
C?ID=494130
Thank you, my mechanic said, the K1 shim even used the thickest one, seems just OK.
Which DTC links to the shims issue ?
Thank you
