I have coded my VW Tiguan 2019 for an aftermarket towbar with PF Jones vehicle specific electronics. I got an ACC fault and cornering headlights as below. I have also included the coding I used that I found on a Tiguan forum:
Some of the abbreviations in VCDS are based on German words which make it hard to figure out what it
relates too but documented below.
Note - Before you change any of the other coding you need to enable 69-Trailer in module 19 Can Gateway
in the first instance.
19 Can Gateway, Installation list, enable 69 trailer
09 Central electrics, long coding, ENG122979-ENG141968 -- Networking - Anhaengeranschlussgeraet
(not installed / installed)
Anhaengeranschlussgeraet = Trailer Connection Device
01 Engine, long coding, Byte 5 - Bit 4
Trailer Installed
Change Hex Value from 01100110 to 01110110 as no vcds descriptions
for my module
03 ABS Brakes, adaptations, Vehicle & Trailer Stabilisation to Activated
10 Park/Steer Assist, long coding,
Byte 3
01 Trailer Hitch Installed (manually removable
69 Trailer, long coding, Byte 1- Bit 0-7 = Country Code - set to ROW
69 Trailer, long coding, Byte 6 - Bit 0-2 = Set to 03 PlatformCoding, MQB ☆ Can't see this option in VCDS on mine ☆
A5 - Frnt Sens.Drv.Assist, long coding, Byte 5 - Bit 4 - 0=Not Coded 1=Coded
AAG = Trailer Hitch Control Module / Steuergerät für Anhänger
(Anhängeranschlussgerät)
13 - Auto dist reg, long coding, byte 3 bit 3 control module for towing sensor
6D Trunk Elect, long coding, byte 1 bit 7 - Trailer installed
6C back up cam, long coding, Byte 4 - Bit 0 - equipment_ahk, installed
AHK - Trailer Hitch (Alt: Draw Bar) / Anhängerkupplung
Trailer Installed
for my module
Byte 3
Sunday,04,May,2025,21:52:45:20993
VCDS Version: 24.7.1.0 HEX-V2 CB: 0.4643.4
VIN: WVGZZZ5NZKW873045 License Plate: T18 SJN
Mileage: 79078km-49136mi Repair Order: 4.5.25
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 42 44 4B 52
5F 69 6C 6D 75 A5 CA D6 D7
VIN: WVGZZZ5NZKW873045 Mileage: 79078km-49136miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 J HW: 03N 907 309
Component: R4 2.0l BTD H24 6584
Revision: A1H24--- CVN: 7D06D85237C5C2A218229D33D6C3ECFE
Coding: 01250032037605083000
ASAM Dataset: EV_ECM20BTD01103N906026J 004004
ROD: EV_ECM20BTD01103N906026J.rod
VCID: 323D1E9EE4AA418A99F-8066
VINID: 9E65EAAAA15EA9B9C81C3004142496805B
Readiness: 1110 1011
Part No SW: 0DL 300 012 T HW: 0GC 927 711 G
Component: GSG DQ500 H06 3004
Revision: 00H06V07 CVN: 90C178AB
VCID: 3A2D36BE3CDAB9CA51F-806E
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 60369000003767
Coding: 0AEE939A50270B6F4777070462C86950C90AD0E2E0469675386250F8D22A4A0B00402F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 79AFE9B2795C72D2185-802C
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0507612322 Dataset Number: V03935287SA 0001
Coding: 132C2C0723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: 43D34B5A4B10F802029-8016
Subsystem 1 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11475672
Address 08: Auto HVAC (E87) Labels:| 5G0-907-044.clb
Part No SW: 5NA 907 044 N HW: 5NA 907 044 N
Component: AC Automat H35 4301
Revision: 20K10000 Serial number: 00000E01240220
Coding: 0012012420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 4ACD667E6C3A294AC1F-801E
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001905002335 Dataset Number: V03935292U 0001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F0A6766E47FA033-8028
Subsystem 1 - Part No SW: 5NC 955 119 A HW: 5NC 955 119 A Labels: 1KX-955-119.CLB
Component: 326 RL 300119 033 0372
Serial number: 00000001901250302815
Component: RLHS 052 0107
Serial number: S5Y19M02D22H17M06S25
Coding: 00A8DD
Serial number: 000000000ZY190021TU0
Serial number: 00000000000046070236
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000013021904220283
Part No SW: 3Q0 919 298 E HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0046
Serial number: 002401197498031 Dataset Number: V03935296UM 0001
Coding: 0331663951
ASAM Dataset: EV_EPHBO2CVW3260000 010019
ROD: EV_EPHBO2CVW3260000_VW37.rod
VCID: 3FDB47AA27F89CE2661-806A
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Dataset Number: V03935284RN 0001
Coding: 320467CB58FF8728749C810580408700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 42DD4E5E540AF10A09F-8016
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 108
Mileage: 79078 km
Date: 2025.05.04
Time: 21:38:17
Voltage terminal 15: 12.3 V
Control Module temperature: 47 C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: -0.09 m/s
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 07021941350770 Dataset Number: V03935295HY 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292CB602D6ABDAA7B-806C
Part No SW: 5Q0 959 655 BT HW: 5Q0 959 655 BT
Component: AirbagVW21 007 0403
Serial number: 003FNR51CPM4 Dataset Number: V03935282LF 0001
Coding: 98CCC0C00C8000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 1373BB1A7BF0A882F29-8046
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 5NC857705C0045T00528
Coding: 80000D
Right seat belt tensioner:
Component: BeltPretRevFR 106 1040
Serial number: 5NC857706C0045T01250
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 402 19
Serial number: 357000000001A631693B
Subsystem 4 - Part No SW: ----------- HW: 480 001 402 19
Serial number: 3580000000041A2C483H
Subsystem 5 - Part No SW: ----------- HW: 480 401 902 19
Component: SideSensor_Dr 003 6149
Serial number: 3510001C72E838F172BE
Subsystem 6 - Part No SW: ----------- HW: 480 401 802 19
Component: SideSensor_Pr 004 6149
Serial number: 3520001282C009B3C68+
Subsystem 7 - Part No SW: ----------- HW: 480 401 902 19
Component: FrontSensor_D 004 6149
Serial number: 3550001122C009B1952P
Subsystem 8 - Part No SW: ----------- HW: 480 400 802 19
Component: PedP_Sensor_D 004 6149
Serial number: 2280001262BFB753B4DH
Subsystem 9 - Part No SW: ----------- HW: 480 400 802 19
Component: PedP_Sensor_P 004 6149
Serial number: 2290001262BFB752E4EL
Subsystem 10 - Part No SW: ----------- HW: 480 400 802 19
Component: PedP_Sensor_C 004 6149
Serial number: 2300001262BFB754137.
Subsystem 11 - Part No SW: ----------- HW: 480 000 202 19
Serial number: I0M000000003406C183Y
Subsystem 12 - Part No SW: ----------- HW: 480 000 202 19
Serial number: I0N000000004406C183-
Part No SW: 5NA 920 790 D HW: 5NA 920 790 D
Component: KOMBI 508 1701
Coding: 24A400187F840600018863031001000800000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001026
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 04011910521949 Dataset Number: V03935293BA 0001
Coding: 030500345F017300FB17225E9A0F00010001070000000000000000000000
GVL: 01C63C0008000600C08C80008002CC0010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CAEE3012256ABD7-803A
Generator:
Component: 0-00-03-00-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29190000123220019036
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5QA 915 181 E HW: 5QA 915 181 E
Serial number: 3065970005
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00009.01.19 Dataset Number: v1260x015G0 0000
Coding: 0101
VCID: 4CC16066664E377AF33-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH08 0014
VCID: 45D755424524C6322CD-8010
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000021457005
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 33331B9A1BB04882929-8066
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SB120318 Dataset Number: V03935290TD 0001
Coding: 003F1A20D001048000001000
VCID: 44D148464E1EFF3A3B3-8010
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000027606612
Coding: 0D0000
Part No SW: 5QF 909 144 B HW: 5QF 909 144 A
Component: EPS_MQB_ZFLS 507 5582
Dataset Number: V03935288SX 0001
Coding: 93170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 49CF5972693C2252C85-801C
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 03021910800287 Dataset Number: V03935275YQ 0001
Coding: 00000005090008CE07104F010A0000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3537258215C456B2BCD-8060
13705999 - Databus
U1123 00 [10001001] - Received Error Message
[Kamera_FDD_Funktionsstatus_Fehler received error status]
Reset counter: 108
Mileage: 79078 km
Date: 2025.05.04
Time: 21:38:17
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007SA828791 Dataset Number: V03935290TN 0001
Coding: 003F1020DC01048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000027509327
Coding: 050000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number: Dataset Number: V03935281HF 0001
Coding: 02730601FF00000051110101008808001F0506E6012000008E
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHW0471549
Subsystem 2 - Part No SW: 5NA 919 866 DP HW: -----------
Component: ECE1 2024 --- 2110
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: ConWysTrailer H14 0137
Serial number: 00000181563668
Coding: 0100000200000000
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG047317 Dataset Number: V03935263ZZ 0001
Coding: 01230600A30F20000000408C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
VCID: 392F29B239DCB2D2585-806C
Part No SW: 5Q0 959 107 Q HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0266
Revision: -------- Serial number: 32313493700000 Dataset Number: V03935268KJ 0001
Coding: 0AA8
VCID: 46D5524E7822CD2A257-8012
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: -------- Dataset Number: V03935287ZQ 0001
Coding: 02230601EA42380D3F1CBE020045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW32.rod
VCID: 3D273DA22DF48EF274D-8068
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 26101815K21490 Dataset Number: V03935296DH 0001
Coding: 0003070600000401000213458050A90094000E200040
VCID: 3C2130A636EE87FA433-8068
0646 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
[Variant_coding_failure]
Reset counter: 108
Mileage: 79078 km
Date: 2025.05.04
Time: 21:38:17
Control Module temperature: 33 C
Outside temperature: 7.0 C
Vehicle speed: 0.00 km/h
System run time: 181.3 s
Voltage terminal 15: 12.0 V
mid: 00 29
Status of camera: System malfunction
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935292ET 0001
Coding: 708040732602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7E582554416B27CD-8020
Part No SW: 7P5 941 572 AG HW: 7P5 941 572 A
Component: LED1L H07 0008
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 005984561A86231A5FB-8054
Component: LED1R H07 0008
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:10, VBatt start/end: 12.2V/12.2V)-----------
