2013 VW Golf TDI - Scanned - Issues
debacle007
C?ID=604477
BEFORE WIPE
Friday,02,May,2025,19:16:29:19109
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WVWZZZAUZDP034975   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP034975   Mileage: 138046km-85777miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 4944
   Revision: 84H22---    CVN: 046582D2
   Coding: 01110012034505092000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM16TDI01104L906021M 002007
   ROD: EV_ECM16TDI01104L997021.rod
   VCID: 2F3CCC931799E622260-807A
   VINID: 9E69EAAAA465A948000C4247146D96C18C
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00101111] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 137316 km
                    Date: 2025.04.18
                    Time: 16:39:34
                    Engine speed: 0.00 /min
                    Coolant temperature: 13 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 11.860 V
                    Limitation: accelerator pedal: 110.9 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Revision: 00000000    Serial number:
   Coding: 01FA8AA120230A700380060701C82580510450C06080A4F3F448F024C0
   Shop #: WSC 00028 028 00024
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
   VCID: 7DA026DB8D75C4B2E4C-8028
8196 - Databus
          U1121 00 [10001001] - Missing Message
          [FCAN : ACC_10 message is not received]
                    Reset counter: 106
                    Mileage: 137316 km
                    Date: 2025.04.18
                    Time: 16:39:34
Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
   Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
   Component: AC Manuell    H01 0503
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   ASAM Dataset: EV_ACManueBHBVW37X 002017
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 323AC5E704ABCBCA49E-8066
329220 - Motor for Air Distribution Flap
          B109D 71 [00001000] - Actuator Stuck
                    Reset counter: 154
                    Mileage: 137470 km
                    Date: 2025.04.22
                    Time: 14:30:42
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011233900757 Dataset Number: 5G0063v____ 0001
   Coding: 03000842C24102730FA44080B10403281000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 43D49023AB117242D28-8016
   Component: WWS    121120  042 0551
   Serial number:         121206044701
   Coding: 0E4DD5
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y13M01D07H08M33S28S1
   Coding: 00A8DD
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY123170UAD
   Serial number: 00000000000055615242
135944 - Terminal 15 Signal
          B12E5 12 [00001000] - Short to Plus
                    Fault Frequency: 100
                    Reset counter: 179
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:48:56
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 0
                    Voltage: 13.3 V
                    Outside temperature: 11.0 °C
524556 - Internal Control Module Memory Check Sum Error
          B2000 96 [00001001] - Component Internal Failure
          [Notlaufpfad->elektrischer Fehler im Stromkreis]
                    Mileage: 116448 km
                    Date: 2024.02.23
                    Time: 15:05:39
                    Terminal 15 status: On
                    OFF: Not operated
                    Voltage: 14.7 V
                    Outside temperature: 9.5 °C
934149 - Rain/Light Recognition Sensor
          B1366 76 [00001000] - Incorrect Mounting Position
                    Reset counter: 171
                    Mileage: 137654 km
                    Date: 2025.04.26
                    Time: 15:04:59
                    OFF: Not operated
                    Voltage: 14.6 V
                    Outside temperature: 14.5 °C
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R015URU Dataset Number: 5G0003v____ 0067
   Shop #: WSC 00028 028 00063
   VCID: 4ACABD078C3BA30A11E-801E
   Left seat belt tensioner:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677A07011350939
   Coding: 333135
   Right seat belt tensioner:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676A08011340854
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 357670000008317D7C0-
   Subsystem 4 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 35867000000D632C7C0+
   Subsystem 5 - Part No SW: -----------    HW: 480 400 801 13
   Serial number: 3516502B30D5D654B37H
   Subsystem 6 - Part No SW: -----------    HW: 480 400 301 13
   Serial number: 3526502B90D3771292AB
   Subsystem 7 - Part No SW: -----------    HW: 480 401 512 12
   Serial number: 3556502AF0CAF163F25Y
   Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 08011308491303 Dataset Number: ----------
   Coding: 0D00
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 7BA428C39361CA82DA8-802E
   Part No SW: 5G0 920 960 A    HW: 5G0 920 960 A
   Component: KOMBI         236 0555
   Coding: 27A402002780260001882A01040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 270C24B33F69BE62EE0-8072
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [00001001] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:09
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:06
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:06
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1109
   Revision: --------    Serial number: 0000239640 Dataset Number: 5G0067v____ 1020
   Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
   GVL: 01503C0000000000400C80000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 3436C3FFFEBFC5FA5B2-8060
   Generator:
H13 0035
   Serial number: 02120004951700120291
   Coding: 2C0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2945298701
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [00001000] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 146
                    Mileage: 137316 km
                    Date: 2025.04.18
                    Time: 15:46:11
                    Terminal 30 power supply: 12.0 V
                    Terminal 15: OFF
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [00001001] - Performance
          [Globaler Timeout CAN-Extended]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:08
                    Terminal 30 power supply: 14.3 V
                    Terminal 15: On
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000048004659  Dataset Number: 5G0222v____ 0034
   Coding: 003002208001028000001000
   VCID: 55F05E7B5585FCF28CC-8000
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000501696
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Dataset Number: 5G0074v____ 0120
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D20E6DBCDF504B2A4C-8068
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000048020162  Dataset Number: 5G0157v____ 0035
   Coding: 003000208001028000801000
   VCID: 7F5CDCD38779D6A2F60-802A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000532281
   Coding: 050000
   Part No SW: 5G0 035 820     HW: 5G0 035 820
   Component: MU-S-D-ER     039 0142
   Serial number: V5C00301130355 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730000FF0000002111120100A800001F0100060100010001
   ASAM Dataset: EV_MUStd4CPASE 002036
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 5EE2415720B33FAADD6-800A
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H44 0020
   Serial number: VWZ8Z9M24015X8
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:12
                    Voltage terminal 30: 14.5 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 238
                    Mileage: 133708 km
                    Date: 2025.02.25
                    Time: 18:41:12
End----------(Elapsed Time: 01:15, VBatt start/end: 12.1V/12.1V)-----------
------------------------------13 Faults Found------------------------------
AFTER WIPE
Friday,02,May,2025,19:22:19:19109
          U0235 00 [00100111] - -
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:31
                    Coolant temperature: 73 °C
                    Intake air temperature: 60 °C
                    Voltage terminal 30: 12.140 V
8196 - Databus
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:30
   Revision: 00001K06
   Coding: 0E4DD5
   Coding: 00A8DD
                    Mileage: 116448 km
                    Date: 2024.02.23
                    Time: 15:05:39
                    OFF: Not operated
                    Voltage: 14.7 V
   Coding: 333135
   Coding: 333135
   Coding: 0D00
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:32
16776960 - Databus
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:29
16776961 - Databus
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:29
   Generator:
   Component: E221__MFL-DC1  H13 0035
   Coding: 2C0000
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:29
                    Terminal 15: On
   Coding: 0D0000
   Coding: 81
   Coding: 050000
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:32
                    Voltage terminal 30: 11.9 V
                    Reset counter: 140
                    Mileage: 138046 km
                    Date: 2025.05.02
                    Time: 19:20:32
End----------(Elapsed Time: 01:13, VBatt start/end: 12.1V/12.1V)-----------
------------------------------9 Faults Found-------------------------------
Hi Folks
The 2nd of my 3 VCDS keys triggered on my wife's bestie's beloved Golf. From what I can gather, the front distance sensor anti-crash doodah has failed, causing multiple weird, interesting errors. I haven't driven the car into a wall to test this in practice yet...
Could I get a learned view of the above codes, please? I have given a before and after code clear. I'm also interested to see what's causing the stop-start to not function, there are a couple of battery management codes. Alternator is outputting fine, and the big AGM battery looks fairly new. I have it on the NOCO just now to see if that helps.
Many thanks in advance for helping me figure out this wee puzzle.
Brian
Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
Jef
HQ
  • Haha
debacle007
C?ID=604477
Ah shoot, sorry, I have updated it!
Brian
Well, the ACC sensor is completely off-line. Check power, ground, and CAN bus connections to it.
In addition, the BCM looks to be failing.
Any chance this car had a water ingress problem?
debacle007
C?ID=604477
It was inevitable, I suppose, the mounts are going to disintegrate when I take it apart, or maybe I go to the effort of bumper off to get the plug.
Oh? Could that be causing the random intermittent faults, including the car not turning off sometimes until the key is fully removed? The car has been owned since new and never flooded, but we are in north-east Scotland, so plenty of salty air. Can the BCM just be straight replaced on these or are they protected?
Cheers
Brian
Good question. Thread title says "2012", so I was thinking PQ style BCM, but it's not; it's a MQB one, and indeed:
WVWZZZAUZDP034975 <- That is a 2013 model car. TBH, I'm not sure whether that BCM is involved with Component Protection or not.
debacle007
C?ID=604477
It is indeed 2013! It has a very subtle private plate on it seems. My bad for making assumptions there.
