Values that could explain something are in posts #21 and #26. If you don't provide facts, you can't say anything for sure. I have a feeling that your has experienced some "story". And that's why it's not working correctly.
Is such a story possible?: Audi went to a service where they were able to change only some operating fluids. Most likely only the oil because the brake fluid hasn't been changed for many years. (That's why the hydraulic pistons in the brakes got stuck, which led to the brakes losing power and had to be replaced). One of the previous owners wanted to "improve" the for more performance or there was a problem with AdBlue. For some reason (maybe due to the inability to find the real cause), the software was manipulated. And that's why the need for regeneration is now symbolized. (IDE00434 Particle filter: soot mass calculated 26.12 g). But regeneration apparently won't start.
If you have the opportunity to talk to the previous owners. Perhaps especially with the following:
That way you can learn more about your car's history. And consider the erudition of your service if they tell you that Eolys is checked "by eye". There must be no such fluid in your car! The is regenerated in a different way. Be sure to check the part number that you have on your bill from the repair. Something like G 052143xx is unacceptable.
Forgot , Yes it is a CVUA engine.
I have got all service protocols . All done by the book by authorized Audi service partner. Nothing about G052143
Saturday,03,May,2025,17:13:23:38398
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 24.7.0.0 (x64)
VIN: WAUZZZ4G7JN070847 License Plate:
Mileage: 132698km-82454mi Repair Order:
Address 01: Engine (4G0 907 589 F)
17:13:20
IDE00021 Engine RPM 0 /min
IDE00025 Coolant temperature 13 °C
IDE00167 Exhaust temperature 1 bank 1 15.0 °C
IDE00169 Exhaust temperature 2 bank 1 18.3 °C
IDE00427 Particle filter: difference pressure -1 hPa
IDE00433 Particle filter: oil ash volume 0.00 l
IDE00434 Particle filter: soot mass calculated 4.86 g
IDE00435 Particle filter: soot mass measured 1.29 g
IDE02229 Exhaust gas temperature sensor 1 17.8 °C
IDE02233 Exhaust gas temperature sensor 2 18.3 °C
IDE02234 Exhaust gas temperature sensor 3 17.3 °C
IDE02236 Exhaust gas temperature sensor 4 18.3 °C
17:20:42
IDE00021 Engine RPM 969 /min
IDE00025 Coolant temperature 14 °C
IDE00167 Exhaust temperature 1 bank 1 15.3 °C
IDE00427 Particle filter: difference pressure 3 hPa
IDE02229 Exhaust gas temperature sensor 1 84.8 °C
IDE02233 Exhaust gas temperature sensor 2 35.9 °C
IDE02234 Exhaust gas temperature sensor 3 20.1 °C
IDE02236 Exhaust gas temperature sensor 4 18.7 °C
17:23:21
IDE00021 Engine RPM 821 /min
IDE00025 Coolant temperature 34 °C
IDE00167 Exhaust temperature 1 bank 1 38.0 °C
IDE00169 Exhaust temperature 2 bank 1 58.0 °C
IDE00434 Particle filter: soot mass calculated 4.89 g
IDE00435 Particle filter: soot mass measured 1.42 g
IDE02229 Exhaust gas temperature sensor 1 174.1 °C
IDE02233 Exhaust gas temperature sensor 2 98.2 °C
IDE02234 Exhaust gas temperature sensor 3 78.7 °C
IDE02236 Exhaust gas temperature sensor 4 58.5 °C
17:24:48
IDE00021 Engine RPM 1811 /min
IDE00025 Coolant temperature 41 °C
IDE00167 Exhaust temperature 1 bank 1 61.9 °C
IDE00169 Exhaust temperature 2 bank 1 60.6 °C
IDE00427 Particle filter: difference pressure 12 hPa
IDE00434 Particle filter: soot mass calculated 4.90 g
IDE00435 Particle filter: soot mass measured 1.43 g
IDE02229 Exhaust gas temperature sensor 1 198.6 °C
IDE02233 Exhaust gas temperature sensor 2 119.1 °C
IDE02234 Exhaust gas temperature sensor 3 129.7 °C
IDE02236 Exhaust gas temperature sensor 4 60.6 °C
