I am working on a 2015 VW Jetta TDI. We were driving the car, and all at once it seemed like it went into neutral and we weren't able to drive at all until we reset the codes, and could drive fine at low speeds until I punched it and it jumped out of gear again. Am I looking at a bad transmission or a sensor, or a wiring issue? I am seeing a U0235, P0771, P2711, and a P0702 code. Thanks in advance for your help.
Wednesday,30,April,2025,10:25:11:12893
VCDS Version: 25.3.1.1 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: 3VWLA7AJ2FM234718 License Plate:
Mileage: 230180km-143027mi Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 04 05 08 09 15 17 19 25 2B 2E 37 44 47 56 75 77
VIN: 3VWLA7AJ2FM234718 Mileage: 230180km-143027miles
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 E HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9465
Revision: 8AH20--- CVN: 2A6481520000000000000000
Coding: 011D0012042410085000
Shop #: WSC 02131 444 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002
ROD: EV_ECM20TDI01104L997016B.rod
VCID: 353C49F705C253726CC-8060
VINID: 0E69DC44745A0967420C41C12062AB7D2E
17262 - Terminal 30
U140A 00 [00100000] - Open Circuit
[Terminal 30Open circuit]
4629 - ECM Power Relay Load Circuit
P068A 00 [00100000] - Opens Too Early
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4517
Revision: 05652104 Serial number: 00001407180354
Shop #: WSC 44551 111 44551
VCID: 251C99B7B9E223F2DCC-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Reset counter: 37
Mileage: 228571 km
Date: 2019.07.18.
Time: 02:30:32
17155 - Shift Solenoid 5 (N92)
P0771 - 000 - Implausible Signal or Stuck Off - Intermittent - MIL ON
Fault Status: 10100000
Fault Frequency: 11
Mileage: 230180 km
Date: 2019.09.10.
Time: 07:37:37
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 005 - - Intermittent
Fault Status: 00100101
Mileage: 230181 km
Date: 2019.09.10.
Time: 07:43:36
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
P0702 - 002 - - Intermittent
Reset counter: 8
Mileage: 230181 km
Date: 2019.09.10.
Time: 07:43:52
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492500FE851202E592210042A1100012
Shop #: WSC 00066 000 00000
VCID: 045AE4331E183AFAAB2-8050
Reset counter: 175
Mileage: 230181 km
Date: 2019.09.10.
Time: 00:02:56
Count: 2
Count: 12
Count: 12800
Count: 16390
Count: 48896
Count: 1535
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0347897011 Dataset Number: 160116v____ 0002
Coding: 030C0C
Shop #: WSC 00066 000 00147
ROD: EV_KESSYPQ35G_A02_VW32.rod
VCID: 372043FF1FCEA1627E0-8062
Part No SW: 1K8 907 044 E HW: 1K8 907 044 E
Component: Climatronic H05 0102
Revision: 00001K02
Coding: 0010019002
Shop #: WSC 00066 000 00121
VCID: 31347DE7F1AA7F52304-8064
9672723 - Heated Seat; Front Left
B1398 13 [00001001] - Open Circuit
Fault Frequency: 19
Reset counter: 66
Mileage: 190941 km
Date: 2022.11.23.
Time: 04:18:03
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H74 0725
Revision: B8074001 Serial number: 27011267140067
Coding: 7B994B9A08AB0B0008382080240884C50F86700E60A40050B0A050022844
Shop #: WSC 64176 001 1048576
VCID: 303278E3FA20765A3FA-8064
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14102585140912160231
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140918173013
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Serial number: WRH000CFNT6
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Serial number: 2261422300802356AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14202587140923220239
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14102586140916185929
Coding: 800000
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD02GHYC Dataset Number: 160003V____ 0313
Coding: 00004B33
Shop #: WSC 00066 790 00185
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72B6B2EB342C044A89E-8026
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140001HDSO0O
Coding: 303345
Serial number: 3572MSME4D742B46ZZZ1
Serial number: 3582MSME24752B46ZZZZ
Serial number: 3516KSME44756030ZZZI
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1B606030ZZZH
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME1B4B3330ZZZU
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME565F3330ZZZZ
Part No SW: 5C6 920 954 A HW: 5C6 920 954 A
Component: KOMBI H04 0807
Coding: 270A01
VCID: 2C0A6C93D68812BA032-8078
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H74 0725
Revision: B8074001
Coding: 102200
VCID: 70B2B8E33AA0365A7FA-8024
Component: IMMO H04 0807
Coding: 000007
VCID: 6A86AA8B1CFCCC8A31E-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000222098001
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: 303278E3FAA0765A3FA-8064
Address 2E: Media Player 3
Part No SW: 1Q0 035 274 B HW: 1Q0 035 274 B
Component: RNS315-NAR H81 0500
Serial number: VWZAZ2P0439708
Coding: 040900610100060000008000
ROD: EV_RNS315NARV2UDS_VW32.rod
VCID: 29049587D97A0792F84-807C
Component: NAR_V6N 0051
Reset counter: 183
Mileage: 190879 km
Date: 2022.11.21.
Time: 17:42:17
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 307 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392445C7255AB712884-806C
Part No SW: 5C6 035 456 A HW: 5C6 035 456 A
Component: KonzernAmp10K H08 6815
Revision: -------- Serial number: EAA098A0165965 Dataset Number: 560050v____ 1607
ROD: EV_AudioVerst10KanalSTT3_VW32.rod
VCID: 261E9EBBC86428EAD56-8072
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140527 Dataset Number: V03935196FH 0010
Coding: 02630102C2423A007F1606000000
Shop #: WSC 01383 790 50316
ROD: EV_OCULow_001_VW12.rod
VCID: 53F8176FAB766D42628-8006
2103041 - Control Module
B1788 F0 [00001001] - Start Prohibition Deactivated
Fault Priority: 8
Reset counter: 175
Mileage: 230181 km
Date: 2025.04.30.
Time: 22:54:50
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666568298 Dataset Number: 5N0035729E 0001
Coding: 0A100300A0010110
ROD: EV_UHVUMI.rod
VCID: 323672EBF4AC444A49E-8066
End----(Elapsed Time: 02:11, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
------------------------------10 Faults Found------------------------------
