- Nov 29, 2023
- 13
- -1
- London, UK
- C?ID=603508
we have a issue, just after few second driving the car this error message comes up on info display with hazard light in cluster (see picture), after messing about a bit, I've noticed when I open and close door this error pops up and disappears, and comes back when I open and close the door again, first I thought it might be the DSG microswitch but now I'm not so sure, could it be door sensors?.
Any idea where I should look for.
Wednesday,30,April,2025,16:04:36:01672
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WVWZZZ6RZGU019937 License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 02 03 08 09 13 15 17 19 44 5F
VIN: WVWZZZ6RZGU019937 Mileage: 86019km-53449miles
5F-Information Electr. -- Status: Not registered 0011
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 DF HW: 04E 907 309 AF
Component: R4 1.2l TFS H22 9015
Revision: R4H22--- CVN: 1E571289
Coding: 01250012230411080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027DF 001007
ROD: EV_ECM12TFS01104E906027DF.rod
VCID: 6B8418BB530598D24A5-803E
VINID: 9E69EAAAA1A2A979400492431C5AECD9E1
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 048 S HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 6501
Revision: 00043014 Serial number: CU501506125138 CVN: 0000EB84
ROD: EV_TCMDQ200021.rod
VCID: 4CC6BB27364B7FEA23F-8018
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08506716150726 Dataset Number: V03935226BE 0124
Coding: 23DD2885892433C9111D106C0058C41491CC88080005C7F90700
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
VCID: 372CF4CB5FCDEC327ED-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H03 0108
Serial number: 1507221B-0944 Dataset Number: V03935222XQ 0010
Coding: 200100011000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1D600663DD31A662841-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 189 C HW: 6C0 937 189
Component: BCM PQ26 Hi4N H08 0086
Serial number: 001618001286 Dataset Number: V03935227FS 0315
Coding: 03001840425300534D844000400703081000580251010000000000000000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005.rod
VCID: 3138CAD3B1A93202309-8064
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 802 CH HW: 6R0 959 802 CH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 9612
Serial number: KU0KU016071551972034
Coding: 1400A1
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 801 CF HW: 6R0 959 801 CF Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 9612
Serial number: KU0KU022071552033519
Coding: 0400A1
Subsystem 3 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serial number: KU0KU020071552012258
Coding: 1400A0
Subsystem 4 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU014081552263967
Coding: 0400A0
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 15071503213084 Dataset Number: V03935220RG 0014
Coding: 02001000FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A2AEDFF6CDFF15A813-806E
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag00R 001 0360
Revision: -------- Serial number: 003RJ004FWP$ Dataset Number: V03935219AL 0391
Coding: 88CCC000000000005C0000CA008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3632F9CF58C7153A65B-8062
Subsystem 1 - Part No SW: ----------- HW: 410 822 307 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00A11AF863081CQ
Subsystem 2 - Part No SW: ----------- HW: 410 822 307 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H009D1AF863140E-
Subsystem 3 - Part No SW: ----------- HW: 442 150 808 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00BB1C3DEB4C19%
Subsystem 4 - Part No SW: ----------- HW: 442 151 308 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A009F1BF9E21F06$
Address 17: Instruments (J285) Labels:| 6C0-920-KOM-V1.clb-SRI3
Part No SW: 6C0 920 940 G HW: 6C0 920 940 G
Component: KOMBI 202 2310
Coding: 272409082100260E02880A011000000000000000
VCID: 280E27B7827373CAE77-807C
Part No SW: 6C0 909 901 HW: 6C0 937 189
Component: GW MQB A0 H08 0086
Revision: -------- Serial number: 001618001286 Dataset Number: V03935009T0043
Coding: 030000046F0A560071000000000000010001010000000000000000000000
GVL: 01403C0000000000400080000000C00000000000000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 65906E83B5E1AEA21C1-8030
Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 52211L16532821489815
66304 - Databus
U1124 00 [00001001] - Additional Installations Detected
[Mehrverbau CAN]
Reset counter: 224
Mileage: 86019 km
Date: 2024.12.02
Time: 03:51:36
Terminal 30 power supply: 12.3 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3232
Serial number: CF840532 Dataset Number: V03935224VJ 0548
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6E8211AF60176DFA6DB-803A
1074688 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[DEM_SUPPLY_LOST_NO_ENG_CRANK_FAULT]
Reset counter: 6
Engine speed: 0 /min
Vehicle speed: 6.97 km/h
Terminal 15 status: Terminal 15 off
Voltage terminal 30: 0.00 V
Power steering current consumption: 0.00 A
max.value: 255.99 A
End stage temperature: 215 °C
Steering assistance: engine output: 0.00 %
Engine angle: 511.984 °
Electric motor speed: 32767 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.00 Nm
Status: Measuring value not available
End----------(Elapsed Time: 00:51, VBatt start/end: 12.2V/12.2V)-----------
------------------------------2 Faults Found-------------------------------
