The Engine ECU has fried itself!
Went to start the car and it wouldn't start and smoke came from under hood.
No problem with vehicle prior to this.
Inspected the ECU and found very strong burning smell from ECU.
Scan tool could not communicate with ECU at this time.
Purchased 2nd hand ECU and fitted to vehicle, same part number and Trans type.
Engine initially started and then stopped and won't restart and getting "Immobiliser Active" on instrument display.
Scanned car.
First scan below. 19 faults.
Cleared the Fault codes and rescanned,
2nd scan below. 4 faults.
Car will still not start after clearing faults.
25:Immobiliser has "no codes"
How can I find the codes for the Immobiliser and any other codes I will need please?
Thank you in advance for any assistance.
Regards, Laurie.
Scan #1. Prior to clearing Fault codes.
Scan #2. After clearing Fault codes.
Scanned car.
Regards, Laurie.
Wednesday,30,April,2025,11:05:17:32966
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
VIN: WVGZZZ5NZBW019926 License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 52 53 56 62 72
77
VIN: WVGZZZ5NZBW019926 Mileage: 162010km-100668miles
01-Engine -- Status: Sporadic communication error 1000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 06J 906 026 FH HW: 06J 906 026 DA
Component: MED17.5 7327
Revision: AAH18--- Serial number:
Coding: 0423000C240F0160
Shop #: WSC 01324 020 00200
VCID: 75E1A5AC1C41F033E9-8020
VINID: 9E65EAAAA15EA929C004924218D13BDC4E
Readiness: 1110 0101
Part No SW: 0BH 300 011 G HW: 0BH 927 711 C
Component: DSG DQ500-7A H04 1406
Revision: 00H04V01 CVN: 84C87CF2
ROD: EV_TCMDQ500021.rod
VCID: 2643B2E05967CBAB90-8072
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 P HW: 5N0 614 109 P
Component: J104 C4 450 V13A 0006
Revision: --H28--- Serial number: 00000004150487
Coding: 0006468
VCID: 387F6C984BD34D5B32-806C
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:08
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 174
Hex Value: 0x0000
00576 - Terminal 15
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:40:10
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 01011111
Count: 127
Hex Value: 0x0000
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:40:10
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00001003
Coding: 0000001002
VCID: 000FC4789B83C59BCA-8054
U1111 00 [00001000] - -
Reset counter: 98
Mileage: 162012 km
Date: 2025.04.30.
Time: 09:20:06
9481748 - High Pressure Sensor
B10AE 14 [00001000] - Open or Short to Ground
Reset counter: 98
Mileage: 162012 km
Date: 2025.04.30.
Time: 09:40:22
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 40180A3B802518C040080080B400002441513088536D89605C8000000040
VCID: 356165AC9CC1B03329-8060
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14121 012 0203
Serial number: N2955119 ∞203!
Coding: 009795
Component: RLS 200511 05 54 0403
Coding: 03304D
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 58
Mileage: 162013 km
Date: 2019.09.21.
Time: 00:21:05
Voltage: 13.55 V
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__202 VW10 HI 1918
Revision: 22014000 Serial number: 003K0P99S6Z6
Coding: 0012338
VCID: 4C9720482F4BD1FB66-8018
Subsystem 1 - Serial number: 6332MTS606781031
Subsystem 2 - Serial number: 6342MTS659461021
Subsystem 3 - Serial number: 6351HTS6QPBR0AKJ
Subsystem 4 - Serial number: 6361HTS65DKR0AKJ
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:40:07
Fault Status: 11100001
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:09
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110505101125
Coding: 1882140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF3BA80E177B36BB8-802A
365080 - Controls in Steering Wheel
U108E 00 [00001001] - No Communications
Reset counter: 58
Mileage: 162013 km
Date: 2025.04.30.
Time: 18:51:48
Part No SW: 5N0 920 872 HW: 5N0 920 872
Component: KOMBI H20 0420
Coding: 110F00
VCID: 6FED97C4B61DCAE323-803A
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 180511F2002044
Coding: 356003
VCID: 306F54B863A3951B7A-8064
Fault Status: 00110100
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:07
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
Reset counter: 10
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:07
01312 - Powertrain Data Bus
Reset counter: 10
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:07
Ign. Timing: 4.7 ∞BTDC
Raw, Form. N/A: 000 000 000
Component: IMMO H20 0420
VCID: 6ADB86D08DFF2FCB74-803E
9456128 - Engine Control Module (ECM) not Authorized
B104A 00 [00001001] - -
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669955398
VCID: 285FBCD85B73DDDBA2-807C
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2112
Coding: 0000700
VCID: 366362A041C7BB2B20-8062
Part No: 5N0 909 144 M
Component: EPS_ZFLS Kl. 201 3201
Revision: 00H20000
Shop #: WSC 01324 785 00200
VCID: 3B7573947AE56643DF-806E
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:20:07
Voltage: 12.00 V
DU
Temperature: 27.0∞C
RPM: 1498 /min
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.5 V
PD
Temperature: 25.0∞C
Count: 2
Steering Angle: 0.00∞
SteerAng n.Init
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0000700
VCID: 377D6FA446CD42233B-8062
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000351900
Coding: 0023057
VCID: 33655BB452B5AE0307-8066
Fault Frequency: 28
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 17:36:02
Voltage: 12.00 V
Count: 71
Hex Value: 0x1260
Hex Value: 0x0011
Hex Value: 0x0202
00576 - Terminal 15
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:39:53
Voltage: 12.40 V
Count: 52
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 00101101
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:40:06
Voltage: 12.00 V
Count: 160
Hex Value: 0x1273
Hex Value: 0x0081
Hex Value: 0x1010
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 052 0213
Revision: 00000001 Serial number: VWZ1Z3P0320922
Coding: 0100044004000C
VCID: 2345ABF422553E83F7-8076
00625 - Vehicle Speed Signal
Reset counter: 98
Mileage: 162012 km
Date: 2019.09.21.
Time: 09:40:12
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01324 020 1012552
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
VCID: 3979699C70D95453CD-806C
Part No SW: 5K0 035 730 B HW: 5K0 035 730 B
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007660009703 Dataset Number: 5K0035730B 0001
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 2447A8E82F5B39BB8E-8070
End-------------------------(Elapsed Time: 03:04)--------------------------
------------------------------19 Faults Found------------------------------
Wednesday,30,April,2025,11:09:48:32966
77
Coding: 0006468
Revision: 00001003
Coding: 0000001002
Revision: BA011001
Coding: 009795
Coding: 03304D
Coding: 0012338
Mileage: 162013 km
Date: 2019.09.21.
Time: 18:58:58
Coding: 1882140000
Reset counter: 58
Mileage: 162013 km
Date: 2025.04.30.
Time: 18:58:56
Coding: 110F00
Coding: 356003
Coding: 0000005
Coding: 0000700
Revision: 00H20000
000 - - - MIL ON
Mileage: 162013 km
Date: 2019.09.21.
Time: 18:58:57
Battery Volts: 12.4 V
DD
Temperature: 27.0∞C
Count: 2
SteerAng n.Init
Coding: 0000700
Coding: 0023057
Coding: 0000144
Coding: 0000144
ROD: UHVNA.rod
End-------------------------(Elapsed Time: 02:48)--------------------------
------------------------------4 Faults Found-------------------------------
