- Apr 29, 2025
- 11
- 1
- Virginia, USA
- C?ID=631680
Hello everyone,
Recently, I did a head and timing job on my 2014 jetta SE, and when I started it back up, my dash resembled a Christmas tree! I was doing the job as I had time, so the car sat a few weeks until completion. As I ran the VCDS, i am showing zeroed out ABS long coding.
Additionally, I replaced the seats and sent belts. Hence the abundance of safety restraint codes.
Here is a copy of my read out.
Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 25.3.1(x64) Data version: 20250415 DS365.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,29,April,2025,18:33:38:56830
VIN: 3VWD17AJ5EM363989 License Plate: Mileage: 237560km-147612mi Repair Order:
Chassis Type: AJ-VW36 (6N0) Scan: 01 02 03 08 09 15 17 19 25 2E 44 56
VIN: 3VWD17AJ5EM363989 Mileage: 237560km-147612miles
01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 2E-Media Player 3 -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 070 F HW: 06K 907 425 Component: Simos12.2 H09 6275 Revision: --H09--- Serial number: 00000000000000 CVN: 903D2E1B Coding: 001A0012242400170000 Shop #: WSC 00066 000 00201 ASAM Dataset: EV_ECM18TFS02006K906070F 001009 ROD: EV_ECM18TFS02006K906070F.rod VCID: 2D5AC3117CCCC0F351-8078 VINID: 0E69D404745A1557431832482499EC5A92
No fault code found. Readiness: 1110 1101
Self-Diagnosis Log Tuesday,29,April,2025,18:33:38:56830 Page 2
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
Part No SW: 09G 927 749 A HW: 09G 927 749 A Component: AISIN AG6 G3 101 2547 CVN: C246682C Coding: 000348 Shop #: WSC 00066 000 00201 ASAM Dataset: EV_TCMAQ250031 001004 ROD: EV_TCMAQ250031_001.rod VCID: 3776E1798E907A233B-8062
Page 3
Count: 2
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL Component: ESP MK60EC1 H31 0152 Revision: 00H31001 Coding: 00000000000000000000000000000000000000 Shop #: WSC 00066 000 00000 VCID: 7DFA3351E42C9073A1-8028
3 Faults Found: 01042 - Control Module; Not Coded
000 - -Freeze Frame:
Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 92 Mileage: 237561 km Time Indication: 0 Date: 2019.09.20. Time: 02:19:20
Count: 7 Count: 12 Count: 4096 Count: 195 Count: 44800 Count: 0 Count: 256 Count: 0
005 - No or Incorrect Basic Setting / Adaptation Freeze Frame:
Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 92 Mileage: 237561 km Time Indication: 0 Date: 2019.09.20. Time: 02:19:20
Count: 2 Count: 12 Count: 4096 Count: 279 Count: 44800 Count: 0 Count: 256
00778 - Steering Angle Sensor (G85) 00778 - Steering Angle Sensor (G85)
Count: 2 Count: 12 Count: 4096 Count: 295 Count: 44800 Count: 0 Count: 256 Count: 0
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BD HW: 5C0 820 047 BD Component: J301 Klimaanlage 0204 Revision: 2001012S Serial number: 00000001695295 Shop #: WSC 00066 000 00000 VCID: 63CE6529A2884683B7-8036
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 5C0 937 087 J HW: 5C0 937 087 A Component: BCM25 JLB H3 H34 0411 Revision: B2034001 Serial number: 08018218130114 Coding: 7B994B3808AB0B0000302000240884D400C2502E60004000300010002000 Shop #: WSC 00066 123 12345
Part No SW: 561 959 655 HW: 561 959 655 Component: AirbagVW11 008 0210 Serial number: 003RXM0818Y7 Dataset Number: 5C6003V____ 0017 Coding: 8CCCF000000000005000001AC20800000065 Shop #: WSC 00066 790 00168 ASAM Dataset: EV_AirbaVW11SMEVW411 001002 ROD: EV_AirbaVW11SMEVW411.rod VCID: 63CE65296A884683B7-8036
Seat occupied recognition: Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A Component: BF-Gewichtss. H05 0016 Serial number: IBH000000000001BSUZM Coding: 303339
Crash sensor for side airbag: driver side: Subsystem 2 - Part No SW: -----------HW: -----------Component: SideSensor_Df --- ---- Serial number: -------------------$
Crash sensor for side airbag: passenger side: Subsystem 3 - Part No SW: -----------HW: -----------Component: SideSensor_Pf --- ---- Serial number: -------------------$
Rear Side Airbag Crash Sensor (on driver's side): Subsystem 4 - Part No SW: -----------HW: -----------Component: SideSensor_Dr --- ---- Serial number: -------------------$
Passenger side rear thorax airbag crash sensor: Subsystem 5 - Part No SW: -----------HW: -----------Component: SideSensor_Pr --- ---- Serial number: -------------------$
Crash sensor for front airbag: driver side: Subsystem 6 - Part No SW: -----------HW: -----------Component: FrontSensor_D --- ---- Serial number: -------------------$
Crash sensor for front airbag: passenger side: Subsystem 7 - Part No SW: -----------HW: -----------Component: FrontSensor_P --- ---- Serial number: -------------------$
10 Faults Found: 9438491 - Igniter for Driver head airbag
B1005 1B [10001001] - Resistance Too High MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Mileage: 237561 km Mileage: 237561 km Date: 2025.04.29. Time: 02:19:19
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [10001001] - Resistance Too High MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 237561 km Date: 2025.04.29. Time: 02:19:19
9443349 - Rear Side Airbag Crash Sensor (on driver's side) B1018 15 [10001001] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 237561 km Date: 2025.04.29. Time: 02:19:22
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [10001001] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
9443605 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 15 [10001001] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
9451029 - Crash sensor side airbag; passenger side B1036 15 [10001001] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Time: 02:19:22 Time: 02:19:22
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [10001001] - Open or Short to Plus MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 237561 km Date: 2025.04.29. Time: 02:19:21
9444117 - Front Passenger's Front Airbag Crash Sensor B101B 15 [10001001] - Open or Short to Plus
9445973 - Seat occupied recognition control module B1022 55 [10001001] - Not Configured MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Reset counter: 92 Mileage: 237561 km Date: 2025.04.29. Time: 02:19:19
B13BC F2 [10001001] - No function MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 2 Fault Frequency: 1 Mileage: 237561 km Date: 2025.04.29. Time: 02:19:18
Part No SW: 5C6 920 953 B HW: 5C6 920 953 B Component: KOMBI H04 0809 Serial number: 00000000000000 Coding: 270A01 Shop #: WSC 00066 000 00201 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod VCID: 2C5CCE1547D6C9FB46-8078
Part No SW: 6N0 909 901 HW: 5C0 937 087 A Component: GW-K-CAN TP20 H34 0411 Revision: B2034001 Coding: 102200 Shop #: WSC 00066 123 12345 VCID: 70E41A65A37EED1B3A-8024
Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO
H04 0809
Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW32.rod VCID: 6AD0080D8DA217CB74-803E
1 Fault Found: 9456433 - Key
B104B 31 [00001001] - No Signal Confirmed - Tested Since Memory Clear Freeze Frame:
Fault Priority: 1 Fault Frequency: 1 Reset counter: 92 Mileage: 237561 km Date: 2025.04.29. Time: 02:24:05
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7664920711 Coding: 010100 Shop #: WSC 00066 000 00000 VCID: 2B5ECD094AD8CEC34F-807E
Part No: 1K0 909 144 R Component: EPS_ZFLS Kl. 69 3501 Revision: 00H22000 Shop #: WSC 02069 000 90108 VCID: 3972E74170846C53CD-806C
1 Fault Found: 03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON Freeze Frame:
Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 237561 km Time Indication: 0 Date: 2019.09.20. Time: 02:19:19
Battery Volts: 12.6 V
DD
Temperature: 25.0°C Count: 2 Steering Angle: 0.00° Count: 1
SteerAng n.Init
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H Component: Radio Prem-8 H07 0009 Revision: -----12S Serial number: VWZ4Z7P3606858 Coding: 05000440010006 Shop #: WSC 00066 790 07030 VCID: 2D5AC31174CCC0F351-8078
1 Fault Found: 02635 - Tuner Not Enabled/Activated
Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 92 Mileage: 237561 km Time Indication: 0 Date: 2019.09.20. Time: 02:19:19
------------------------------16 Faults Found------------------------------
