Tuesday,29,April,2025,19:07:11:32319
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WVGEK9BP5CD006500 License Plate:
Mileage: 188511km-117135mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
6C 6D 72
VIN: WVGEK9BP5CD006500 Mileage: 188511km-117135miles
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H17 0008
Revision: 56H17--- CVN: 66FD96005C3E0D045C3E0D04
Coding: 292A4012232600050000
Shop #: WSC 01017 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 36353485B8C09E4A656-8062
VINID: 9E65D56C94A015350000614000F5AD1F23
19189 - Fuel Injector #1 (N30)
P0263 00 [01100000] - Contribution/Balance Fault
8863 - Particulate Filter
P2459 00 [01100000] - Regeneration Frequency
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 3407
Serial number: CVN: CB5A7D50
Coding: 001368
Shop #: WSC 63213 003 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 3039029D5AA4B07A3FA-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 J HW: 7P0 907 379 A
Component: MK25A H36 0433
Revision: -------- Serial number: 431910010EC010 Dataset Number: 7P0012v____ 7P16
Coding: 5B7613C349242559DAF9C89392D2A4407300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 008001
ROD: EV_ESPMK25A00800.rod
VCID: 44D15E4DFE1C3CDAEB2-8010
Part No SW: 4H0 907 064 JK HW: 4H0 907 064 JK
Component: BCM2 2.0 H44 0582
Coding: 09860010000000000000
Shop #: WSC 25568 001 1048576
VCID: 7BA3E5B1C3E28322DA8-802E
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0511000059727009
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000246869014
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
VCID: 7EA5ECA5D070960AFD6-802A
0267 - Sensor for Refrigerant Pressure and Temperature
B10C2 21 [00001000] - Signal Amplitude Too Low
Fault Frequency: 30
Reset counter: 198
Mileage: 186396 km
Date: 2025.03.30
Time: 13:40:25
0269 - Control Circuit for A/C Compressor
B10A9 29 [00001000] - Signal Implausible
Reset counter: 197
Mileage: 188453 km
Date: 2025.04.28
Time: 19:27:35
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [00001000] - -
Reset counter: 197
Mileage: 184052 km
Date: 2025.02.12
Time: 17:24:47
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001135930
Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
VCID: 6B83D5F1B38213A24A8-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 111109 31 0020
Serial number: 90243400111118235750
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10275636
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000001111110115
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0VF807
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: -------- Serial number: 003L0000VRHD Dataset Number: 7P6003v____ 0983
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 41DF5759E10E29F2C04-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1190206XAX
Serial number: 3575LRB405H0TGJG41FX
Serial number: 3585LRB405P0U20S4HN3
Serial number: 3515RRB405B0TQM6B15R
Serial number: 3525RRB40590TQM6FPJP
Serial number: 3555NRB40510R8AC213N
Serial number: 3565NRB40510R8ACL927
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KKL0008U
Coding: 000015
Shop #: WSC 63333 003 1048576
VCID: 36353485B8409E4A656-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0129535
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658151111593010
Coding: 8B7733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 47CB4941CF2A17C20E0-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000312336
Coding: 0001037500
GVL: FB0F40451D77000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 38293ABDB2D4683A77A-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650699372
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000018145400
Coding: 0058130000004001000001010101202020202121202020
Shop #: WSC 62953 001 1048576
VCID: 34310E8DAE3C8C5A5B2-8060
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000122204615
Coding: 011D07205E00453005080000
VCID: 44D15E4DFE9C3CDAEB2-8010
Revision: 00002001 Serial number: 0524495941
Coding: 0106123A28B9509480A00620010000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 148148430
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO1403127Z
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO13364281
Coding: 191100
014 - Defective
Fault Status: 01101110
Reset counter: 189
Mileage: 178549 km
Date: 2024.10.20
Time: 16:28:17
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000122406193
VCID: 3B2325B1836243229A8-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11A30002EF Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0009
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1E6ADC66C841AD32-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G0 035 080 B HW: 4G0 035 080
Component: Radio U SIRIU H53 0076
Revision: AB001007 Serial number: 158H-0J2502109
Coding: 020007020100000001
Shop #: WSC 22166 004 1048576
VCID: 1D67CB293DB62D1284C-8048
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445B70K7532599
Coding: 010200050040E1EE41020B0C00000003F0000101
VCID: 372B3981BF4A67427E0-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79005A3
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: -------- Serial number: 0000122366083
Coding: 011C07200000253005080000
VCID: 3A2D20B58C587A2A81E-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000053801 Dataset Number: 7P6096v____ 0017
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB51A197FA5F02B60-806A
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J192087
Coding: 0100001
VCID: 372B3981B34A67427E0-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001 Serial number: 319100192 Dataset Number: 7P6959107A D043
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202137
ROD: EV_HeckkTouar.rod
VCID: 3D272BA99DF64D12A4C-8068
Component: TSG HR H09 0167
Revision: -------- Serial number: 0000122365926
End----------(Elapsed Time: 02:06, VBatt start/end: 12.4V/12.1V)-----------
------------------------------6 Faults Found-------------------------------
