If i replace heated windshield on b7 passat with non heated, will it fault code?
scoobykids
C?ID=574407
if i replace heated windshield on b7 passat with non heated, will it throw a fault code?
reason: save money.
current ws is cracked, also scratches easily, i suspect coating.
siLc
Tallinn, Estonia
C?ID=330192
No, because the heating voltage supply is from a simple relay.
And no kidding, a new B7 heated + camera genuine part windscreen replacement is close to 900€.
golfi_vend
Tartu, Estonia
C?ID=195131
I'm not so sure. I remember vaguely that when we retrofitted these and testing BCM with simple relay it for whatever reason gave fault code.
Of course this will happen only if You turn it on. And You can always code them out.
Ziddywerks
Northern NJ USA
C?ID=208579
Code in bcm and call it a day.
scoobykids
C?ID=574407
Luckily, no camera. Its passat type 365 . ebay.de selling heated acousitic for 350 Euro- obv not OEM
scoobykids
C?ID=574407
anyone know where are the wires to the screen seater? top/bottom? left/right?
I would guess top with the IR rain sensor wires, but dont want to take a chance cutting anything
siLc
Tallinn, Estonia
C?ID=330192
Remove the domelight module, look inside and unfasten the ground nut attached to the roof. Remove the glass' ground strap and refasten the nut.
Plus wires are in each lower corner of the glass, under the hood. Look under the waterbox covers.
scoobykids
C?ID=574407
How to remove dome module? Don’t see any screws
scoobykids
C?ID=574407
So you actually did retrofit heated glass with non-heated. How did it turn out?
scoobykids
C?ID=574407
How do I cut glass out without cutting those wires?
siLc
Tallinn, Estonia
C?ID=330192
Remove the wiper arms and covers. Then you can disconnect the heating connectors.
scoobykids
C?ID=574407
Ok. Here are photos of the lower wiring connectors for the heated windscreen in case anyone else ever needs to know. photos
I removed 60A fuse and tested by turning switch on. The switch indicator still lights, but there is no dash warning.
I'm gonna replace screen with non-heated version. I cant see paying an extra 200Euro for a feature I may have used once in the last 18 months and that I have got by without for 40 years!
