2012 Turbo Beetle, Tried to swap a gauge cluster, lost the long coding, repair gauge cluster?
jim101
New York, USA
C?ID=617955
Just got the scan tool, seems to work pretty great!
I made the mistake of trying to swap a gauge cluster in the car because the analog speedometer needle stopped working, found out the hard way that you can't just swap it back.
So I have 3 questions:
1.) How do I figure out the long codes for the modules that got reset? ABS, Electric steering
2.) How do I fix/get the cluster fixed? I imagine its the motor for the actual needle, because the digital part works (Buts its also stuck in kilometers? Tried changing it back to MPH via the ,manual. Is it possible to swap in another cluster at all?
3.) Also the radio went into "SAFE" Mode, can this tool tell me the passcode to unlock it?
Thank you in advance! Jim
VIN: 3VW4A7AT4CM644809 License Plate: 101111
Mileage: 327740km-203648mi Repair Order: 10111
Chassis Type: AT-VW32 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VW4A7AT4CM644809 Mileage: 327740km-203648miles
------------------------------------------------------------------------------- Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 06J 997 028 P HW: 06J 907 309 B
Component: MED17.5.2 TFSI 2 1500
Revision: PAH04--- Serial number:
Coding: 0403010818070160
Shop #: WSC 42021 003 1048576
VCID: 43D491B977998782D28-8016
VINID: 0E69C444746411374610420024F10CBC67
Readiness: 1110 1101
Self-Diagnosis Log
Tuesday,29,April,2025,08:41:57:50681
Page 2
Count: 2
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Shop #: WSC 00066 000 00000
VCID: 2E02D00DC01B1AEA2D6-807A
Reset counter: 143
Date: 2025.04.29.
Time: 03:10:08
Count: 3
Count: 20992
Count: 195
Count: 51456
Fault Status: 01100101
Reset counter: 143
Mileage: 327743 km
Date: 2025.04.29.
Time: 03:10:07
Count: 3
Count: 2
Count: 12800
Count: 279
Count: 51456
Self-Diagnosis Log
Page 3
Reset counter: 143
Mileage: 327743 km
Date: 2025.04.29.
Time: 03:10:07
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 51456
Reset counter: 143
Mileage: 327743 km
Date: 2025.04.29.
Time: 03:10:07
Count: 3
Count: 2
Count: 12800
Count: 270
Count: 51456
Self-Diagnosis Log
Page 4
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 820 047 AL HW: 5C0 820 047 AL
Component: J301 Klimaanlage 0203
Revision: 2001109S Serial number: 00000000879771
VCID: 6A8A1C1D3073B6CA31E-803E
No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C5 937 087 A HW: 5C5 937 087 A
Component: BCM25 JLB H+3 H68 0256
Revision: B6068001 Serial number: 04431093120026
Coding: 3BBC2918088B080000A02800640D84C400C2400F60844000B20004000000
VCID: 303ECE75DA2F0C1A3FA-8064
Subsystem 1 - Part No SW: 5C5 959 801 M HW: 5C5 959 801 M
Component: J386__TSG_FT 011 1032
Coding: 800000
Subsystem 2 - Part No SW: 5C5 959 802 P HW: 5C5 959 802 P
Component: J387__TSG_BT 011 1032
Coding: 800000
Self-Diagnosis Log
Page 5
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM05C3FJ Dataset Number: 5C5003v____ 0086
Coding: 00004233
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3436C2652EB7303A5B2-8060
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000C1CJ0E
Coding: 30304D
Serial number: 3572MSME1770436AZZZV
Serial number: 3582MSME5E29436AZZZ4
Subsystem 4 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME3E086717ZZZ/
Subsystem 5 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME6B226317ZZZX
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5C5 920 950 B HW: 5C5 920 950 B
Component: KOMBI H12 0020
Revision: X0012004 Serial number:
Coding: 250A01
Shop #: WSC 00066 000 00125
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 280E2615E27F44DAE7A-807C
Self-Diagnosis Log
Page 6
Part No SW: 6N0 909 901 HW: 5C5 937 087 A
Component: GW-K-CAN TP20 H68 0256
Revision: B6068001
Coding: 402000
VCID: 70BE0E751AAF4C1A7FA-8024
No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5C5 920 950 B
Component: IMMO H12 0020
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
VCID: 6A8A1C1D3CF3B6CA31E-803E
No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661991949
VCID: 29082311F9F57DD2F84-807C
Self-Diagnosis Log
Page 7
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 372CF5693341DB227E0-8062
Fault Status: 11100101
Mileage: 327743 km
Date: 2025.04.29.
Time: 03:10:08
Battery Volts: 14.5 V
DU
Temperature: 15.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0004
Revision: -----03S Serial number: VWZ4Z6M3328138
Coding: 01000400040002
VCID: 231431399BD9A782B28-8076
Self-Diagnosis Log
Page 8
------------------------------5 Faults Found-------------------------------
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661964120 Dataset Number: 5K0035730E 0001
Coding: 0A10040000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270C2529EF614BA2EE0-8072
End----------(Elapsed Time: 00:51, VBatt start/end: 14.3V/14.3V)-----------
You get them from the scan you did before you started swapping parts. ;)
Have you tried doing Output Tests on it to confirm that it's the motor?
No, but it should come back by itself once it figures out it's in the car that it belongs in.
jim101
New York, USA
C?ID=617955
1.) Unfortunately I learned of this little VW cashgrab a little too late. The new cluster can lockout the abs but the right cluster cant unlock it? Ghetto. Is there a way to decipher what code it needs?
2.) I will try that!
3.) Its been a month or so now, maybe after all the long codes are back in place?
Been known thing since 2009. The late, great Jack discovered it and literally tried to make a federal case out of it, but didn't get very far. Back then, lost ABS coding would trigger a check engine light too, meaning the car wouldn't pass an emissions test. He did succeed in getting VW to change the ECU software so that wouldn't happen, but he did not succeed in getting them to publish a proper coding chart for these ABS modules.
In any case, the lesson for you is: Always run a scan before beginning any work in order to have a baseline.
Yes, there are people here who can build those codings from scratch. I'm not one of them.
Ziddywerks
Northern NJ USA
C?ID=208579
I normally charge for such service but here's a gimme for one module:
Hardware part number:5C0907379C
Part number:5C0907379C
Hardware version number:H31
Software version number:0156
Coding:F14B6016492600FE8F1306E492220041A71800
Ability to flash:Flashable
System name:ESP MK60EC1
jim101
New York, USA
C?ID=617955
Thank you so much it worked and the steering code is gone as well!
My tire pressure sensor system isnt reseting,, but i havent checked it out yet. Here is the resolved VCDS
Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: Release 25.3.1(x64) Data version: 20250415 DS365.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Tuesday,29,April,2025,19:55:30:50681
VIN: 3VW4A7AT4CM644809 License Plate: FFFFFHHHH
Mileage: 327770km-203666mi Repair Order: fgfgf
VIN: 3VW4A7AT4CM644809 Mileage: 327770km-203666miles
Self-Diagnosis Log
Page 2
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V3.clb
U1017 - 000 - - Intermittent
Fault Frequency: 12
Mileage: 327743 km
Date: 2025.04.29.
Time: 04:35:52
RPM: 1871 /min
Load: 14.5 %
Speed: 15.0 km/h
Temperature: 68.0°C
Temperature: 39.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.970 V
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Mileage: 327771 km
Date: 2025.04.29.
Time: 08:24:24
RPM: 804 /min
Load: 27.8 %
Speed: 12.0 km/h
Temperature: 98.0°C
Temperature: 45.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.462 V
Self-Diagnosis Log
Page 3
Self-Diagnosis Log
Page 4
Count: 3
Revision: 00H31001
Coding: F14B6016492600FE8F1306E492220041A71800
Shop #: WSC 00066 123 12345
Reset counter: 147
Mileage: 327774 km
Date: 2025.04.29.
Time: 14:14:44
Count: 3
Count: 32770
Count: 12800
Count: 212
Count: 50176
Count: 256
Reset counter: 147
Mileage: 327774 km
Date: 2025.04.29.
Time: 14:14:44
Count: 3
Count: 32770
Count: 12800
Count: 279
Count: 50176
Count: 256
Self-Diagnosis Log
Page 5
Reset counter: 147
Mileage: 327774 km
Date: 2025.04.29.
Time: 14:14:44
Count: 3
Count: 32770
Count: 12800
Count: 270
Count: 50176
Count: 256
Reset counter: 147
Mileage: 327774 km
Date: 2025.04.29.
Time: 14:14:44
Count: 3
Count: 32770
Count: 12800
Count: 16390
Count: 50176
Count: 256
Self-Diagnosis Log
Page 6
Coding: 800000
Coding: 800000
Self-Diagnosis Log
Page 7
Coding: 00004233
Coding: 30304D
Coding: 250A01
Self-Diagnosis Log
Page 8
Revision: B6068001
Coding: 402000
Revision: 00H22000
Self-Diagnosis Log
Page 9
ROD: UHVNA.rod
End----------(Elapsed Time: 00:50, VBatt start/end: 12.4V/13.9V)-----------
------------------------------6 Faults Found---
Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
