- Aug 18, 2024
- 30
- 1
- Northern Virginia, USA
- C?ID=594802
2016 Audi S4, ~40700 miles.
I was driving through heavy rain and I received the "steering failure" in yellow and then red "steering failure. Do not drive!" a few minutes later, or something to that effect. Damn near almost killed me as I wasn't expecting the wheel to become so stiff in dumping rain on a two-lane road. The electric assist steering certainly isn't like the old manual steering cars with hydraulic systems. I was able to drive it home and then looked under the car the next day. I found that the baffling/boot was no longer connected on the drivers side, so I assume water intrusion killed it.
The car isn't eligible for the extended warranty because it has a branded title (Rebuilt). The accident that damaged the car didn't affect any of the mechanical components, but Audi corporate doesn't seem to care and already dismissed the extended part warranty on the steering box.
Question is: what exactly is broken and what do I need to replace? I understand the rack needs to be replaced, but what about the control module? Is there a way I can "reset" it and see if it still comes up dead? It had several days to dry out. The parking brake works - I don't understand that code.
Sunday,27,April,2025,17:14:47:42314
VCDS Version: 24.7.0.0 (x64)
VIN: WAUDGAFL1GA001177 License Plate:
Mileage: 65520km-40712mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
62 6C 72 A9
VIN: WAUDGAFL1GA001177 Mileage: 65520km-40712miles
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 8K5 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07--- CVN: 14D7E3E6
Coding: 0A190034052600060000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
ROD: EV_ECM30TFS021_AU48.rod
VCID: 3A7B6DF4BDFAD346CD-806E
VINID: 9D19545D159C0574400010471C90F2D3D5
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Coding: 281D1A01
Shop #: WSC 06325 000 00000
VCID: 0919C238A09C08DE94-805C
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 8
Reset counter: 242
Mileage: 65420 km
Date: 2025.04.26
Time: 11:41:38
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x000C
Hex Value: 0xC09A
Hex Value: 0x0000
Reset counter: 242
Mileage: 65527 km
Date: 2025.04.27
Time: 16:21:58
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001A
Hex Value: 0x0297
Hex Value: 0x0000
Part No SW: 8K0 907 064 KM HW: 8K0 907 064 KM
Component: BCM2 2.0 H15 0711
Coding: 0F814040000000000000
VCID: 0501CE088C846CBEF0-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000094137007
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01280520152946
Coding: 6600228000
VCID: 77FDB4C0C6680E2EF2-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001081873102
Coding: 26000091863CAFE0240048C300003D0D0F9C9308A2090221000008004000030100000030000000
VCID: 78FFB7FCCB760156FB-802C
Subsystem 1 - Part No SW: 8K1 955 119 B HW: 8K1 955 119 B Labels: 1KX-955-119.CLB
Component: MITSUBA270415 H19 0461
Serial number: 1504230603924
Coding: 004577
Component: G397_RLFS H06 0004
Serial number: 20318862
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000000805150514
Component: USHL4.2 H30 0030
Serial number: 00000000095Z0B99802C
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 3CB8CBA7000000000001
Part No SW: 8K0 959 655 Q HW: 8K0 959 655 Q
Component: AirbagVW-AU10 H51 0812
Serial number: 003NDD138M88 Dataset Number: 8K0909602S 0001
Coding: 303844354730383131304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4B953830E2605ACE66-801E
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R150000LNH0
Serial number: 6334MSME510A055A9
Serial number: 6344MSME511B6948J
Serial number: 6352QSME16544F46M
Serial number: 6362QSME39583866Q
Serial number: 63732SME684C3678A
Serial number: 63832SME684C3E5CL
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372OE5000E1
Coding: 000016
VCID: 4487130CC73E95B6A7-8010
Part No SW: 8K0 920 983 HW: 8K0 920 983
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 63-664M5G
Coding: 8BB509008301D705020000
VCID: 72EB85D4AD0A6B06C5-8026
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z155150A11
Coding: 80C303FF00
VCID: 4C973B2CEF6E5DF66F-8018
Serial number: 9159866403
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 002203150001031 Dataset Number: 8K0909104D 0025
VCID: 2F6D4CA076B806EE6A-807A
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0077
Revision: AA000000 Serial number: 00000145006518
Coding: 00581B00000000000000
VCID: 3B7568F0BAC0EA4ED6-806E
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0369752517 Dataset Number: 8K0909535J 0029
Coding: 010211
Shop #: WSC 06324 000 00000
VCID: 3F8D1CE0A6D8F66EFA-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0369128828
Coding: 010211
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H10 0305
Coding: 011C13204E00410001
VCID: 56A3D94421A21726C9-8002
Part No SW: 8K0 909 144 P HW: 8K0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0012807362 Dataset Number: 8K0909852L 0026
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 3E7361E4A1D2FF66F1-806A
7341600 - Position Sensor for Motor
C10AD 29 [00001000] - Signal Implausible
Reset counter: 27
Mileage: 65527 km
Date: 2025.04.26
Time: 16:26:54
Write only channel
7341570 - Position Sensor for Motor
C10AD 29 [10001001] - Signal Implausible
Mileage: 65418 km
Date: 2025.04.26
Time: 11:17:17
Write only channel
Revision: 00002001 Serial number: 0368488565
Coding: 0106023A00FA404580B0013200000000
Component: GTO BF H01 0080
Serial number: 00000000000000997965
Subsystem 3 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J245 PS051 H08 0043
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813044491806
VCID: 2D5156A874B474FE58-8078
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H10 0305
VCID: 55A1DE483CA41C3EC0-8000
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000545880
ROD: EV_ParkiBrake_AU48.rod
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156E50F8269933
Coding: 020007010000000001
VCID: 2447B38C277EB5B687-8070
Part No SW: 8R1 035 746 H HW: 8R1 035 746 G
Component: H-BNT-NA H43 0937
Revision: -------- Serial number: 523F00FB005776
Coding: 110200000206A1EF55028B5E00000403140000000000000000
VCID: 3C776BECBFCEED76DF-8068
Subsystem 1 - Part No: 8R0 060 884 CS
Component: NAR 2015 1201
Component: DU7 High H42 0104
Serial number: A130EV0F3364870
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002249970
Component: CD-Database 6208
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H08 0305
Coding: 010C13204000210001
VCID: 59B9D27850BC385EE4-800C
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-JA391UD
Coding: 1000006
VCID: 387F77FC4BF6C1563B-806C
Component: TSG HR H08 0305
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0006
Serial number: 150514201908
VCID: 72EB85D4A50A6B06C5-8026
End-------------------------(Elapsed Time: 04:12)--------------------------
