P0697 on a 2015 Volkswagen Golf TDI indicates a fault in the sensor reference voltage "C" circuit.
rigelcosto
Hialeah, FL, USA
C?ID=538637
Hello Everyone!
I cleared the code 2 weeks ago after noticing the battery connection was loosened. Battery recharged and installed back. After that, the code never appeared again until 3 days ago. Recent MIL on indicates ECU sensor reference voltage C - open circuit. Using VCDS I tested all those sensors, some of them has no voltage at all, is that normal? Anyone seen this before ?
EGR TEmp sensor 1 B1:raw voltage 0.0mV (no the same that 0mV like others below)
EGR TEmp sensor 2 B1:raw voltage 3807.2mV
NOx sensor before SCR catalytic converter 0mV
NOx sensor after SCR catalytic converter 0mV
Glow_period_control_unit_calculated_glow... 0mV
Glow_period_control_unit_enercy_integrat... 0mV
Thankyou for any pointers / help given !!
rigelcosto
Hialeah, FL, USA
C?ID=538637
Tuesday,22,April,2025,15:13:16:35756
VCDS Version: 25.3.1.1 (x64)  HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: 3VW2A7AU1FM028814   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 47 52 55 5F 75
VIN: 3VW2A7AU1FM028814   Mileage: 135500km-84195miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---    CVN: B5ADD45238D3FF82
   Coding: 011D0012032410080000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B2324CBA3ED1A129A8-806E
   VINID: 0E69C244746505674008820110E1C4792C
4125 - Sensor Reference Voltage C
          P0697 00 [10101111] - Open Circuit
                    Mileage: 135500 km
                    Date: 2025.04.22
                    Time: 15:09:27
                    Engine speed: 983.50 /min
                    Normed load value: 37.3 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 64 °C
                    Voltage terminal 30: 13.340 V
                    Turbocharger 1 turbine input: temp. sensor 1: B1: raw value: 255.8 °C
                    Turbocharger 1 turbine output: temp. sensor 1: B1: raw value: 216.5 °C
                    Particulate filter input: temp. sensor 1: bank 1: raw value: 203.2 °C
                    Particulate filter output: temp. sensor 1: bank 1: raw value: 195.3 °C
                    EGR temp. sensor 2: B1: raw value: 89.5 °C
                    Shut-off timer: last engine shut-off time: 3 s
Readiness: 1 1 0 1 0
rigelcosto
Hialeah, FL, USA
C?ID=538637
Ok thank you, it should be that sensor, because otherwise multiple sensors were affected.
rigelcosto
Hialeah, FL, USA
C?ID=538637
Hi guys, after a while, I came back with my story about this code. After reviewing all sensors available in the exhaust system, no physical damage was noticed. But the code is still there. Solution: Add DPF cleaner, available in auto parts, to the diesel tank. Run the car for about 30 miles, in 4th gear, 60 M/H, and the problem was solved.
DPF cleaner in the fuel tank fixed electrical problems? I don't think so!
rigelcosto
Hialeah, FL, USA
C?ID=538637
I have not said that. I think that the differences between the sensors before and after the DPF were reading different voltages, and it can be interpreted as an open circuit, no idea, but for sure it solves the code.
NEtech
Denmark
C?ID=56995
Also look at the thick engine wiring harness, is touching somewhere.
rigelcosto
Hialeah, FL, USA
C?ID=538637
I had reviewed that car all over the engine bay, all cables were moved, and 3 sensors were replaced (OEM parts) because of physical damage, and the code was still there. I read something about this matter related to the DPF filter and went to autoparts for the foam version of the cleaner, but ended up using the other one that is added to the fuel tank. Problem solved until now, 12K miles after.
