Hi everyone,
I am hoping you can assist me. Please see below for the background:
Vehicle: 2021 Audi (b9.5) SQ5 Premium Plus (with Air Suspension)
Situation: Replaced Rear Left Headlight Leveling Sensor and installed adjustable lowering links.
Issue: The Rear Left Headlight Leveling Sensor was replaced successfully and so were the lowering links (at stock height), however, the shop adjusted the lowering links and post adjustment, the car was sitting too low and threw a bunch of codes. So, they re-adjusted the lowering links to OEM height and cleared all the codes. After that, they informed me that I now have a “Air Suspension: Service Mode” light on my dash and are unable to clear it. When I run the VCDS Auto Scan, the most relevant error I see is the following:
Address 74 - Chassis: 196609 - Basic Setting of Deflected Position not Performed
Attaching the entire Auto Scan further below.
VCDS: HEX V2 - Purchased from FCP Euro and registered the device with the Transaction ID provided.
Research: I searched through Google and the Ross Tech forum, and tried to apply the following potential solutions in the following posts, however, they did not work:
With that being said, I found the following URL that contains clean Maps of a similar vehicle (Thanks Jef):
https://forums.ross-tech.com/index.php?threads/31335/#post-263774 (2022 Audi SQ5)
So, I compared my adaptations with the ones from the clean map above, and the only difference I noticed is that the following adaptations for my car I have “0” for Stored Values and a clean one has percentages. Below are the ones in question:
So, I tried to update the above adaptations with a new value but I am receiving the following error:
www.flickr.com
So, based on the above, I need a Security Code.
I believe if I update the above values, I am confident I can remove myself from “Service Mode”, but I do not have the Security Code to have Edit rights for the aforementioned adaptations. How can I get the Security Code?
And if anyone has any other ideas on how I can calibrate the car without Adaptations mode, so that the stored values are updated, please let me know.
Thank you in advance.
Auto scan below:
- https://forums.ross-tech.com/index.php?threads/48874/#post-396984
- https://forums.ross-tech.com/index.php?threads/7718/page-4#post-318723
- https://forums.ross-tech.com/index.php?threads/46573/
- https://forums.ross-tech.com/index.php?threads/41725/#post-342656
- https://forums.ross-tech.com/index.php?threads/38268/
- https://forums.ross-tech.com/index.php?threads/34194/#post-287775
- https://forums.ross-tech.com/index.php?threads/31530/#post-272518
IDE08997-IDE04195-Raw values: height sensors when deflected-Left front level ctrl sys sensor: adaptation value (deflected),
IDE08997-IDE04198-Raw values: height sensors when deflected-Right front level ctrl sys sensor: adaptation value (deflected),
IDE08997-IDE04201-Raw values: height sensors when deflected-Left rear level ctrl sys sensor: adaptation value (deflected),
IDE08997-IDE04204-Raw values: height sensors when deflected-Right rear level ctrl sys sensor: adaptation value (deflected),
Thierry A has shared 1 photo with you!
Auto scan below:
Sunday,27,April,2025,16:35:48:49717
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.5
Data version: 20250415 DS365.0
VIN: WA1B4AFY0M2004781 License Plate:
Chassis Type: FY-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 19 32 36 3C 42 44 46 52 5F 6C 6D
74 75 81 8B A5 A9 BB BC CA CF D6 D7 DE
VIN: WA1B4AFY0M2004781 Mileage: 66915km-41579miles
74-Chassis Control -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels:. 06M-907-309-V1.clb
Part No SW: 80A 907 559 G HW: 06M 907 309 G
Component: V6 3.0l TFSI H11 0002
Revision: B8H11000 CVN: 21BB5EF1
Coding: 2A2A0032256E090E34200000000000000000000000000000
ASAM Dataset: EV_ECM30TFS01180A907559G 001002
ROD: EV_ECM30TFS01180A907559G.rod
VCID: 3334C1A82BB94BC2428-8066
VINID: 9D10521115A901D0800041C80447D2E060
17156 - Databus
U1123 00 [00101111] - Received Error Message
Fault Frequency: 13
Mileage: 66875 km
Date: 2025.04.25
Time: 16:39:36
Engine speed: 0.00 /min
Coolant temperature: 27 °C
Intake air temperature: 27 °C
Voltage terminal 30: 11.780 V
Drivetrain coordinator: brake function status-Bits 0-7: 32
Acceleration: 0.000 m/s²
Readiness: 0000 0100
Part No SW: 80A 927 158 K HW: 0D5 927 156 N
Component: 0D5 30TFSINAR H05 0002
Revision: --H05--- CVN: 979E30F7
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011.rod
VCID: 3436C2B42EB74CFA5B2-8060
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb
Part No SW: 80A 907 379 S HW: 80A 907 379 H
Component: ESP9 Premium H17 0838
Dataset Number: 80B909504AB 0011 CVN: 60FC8FD5
Coding: 1CAA14BE30A20A9A93A558995A7E52A2E5359A38280C50C91A5A4A45A7AC59
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 3FDC9D9817F19FA2B60-806A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 T HW: 80A 820 043 T
Component: Klima Zone 3 H60 0270
Coding: 6608090D5544000D10000100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 2E02D0DCC09B662A2D6-807A
Subsystem 1 - Part No SW: 4M1 820 021 C HW: 4M1 820 021 C
Component: J126 FLuftV H09 0004
Serial number: 00000000000004798340
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H04 0010
Serial number: A3A1042E00PAG0MUFU04
Subsystem 3 - Part No SW: 80A 919 158 HW: 80A 919 158
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W1 907 063 AG HW: 8W1 907 063 G
Component: BCM1 MLBevo H10 0712
Dataset Number: 80C909514A 0008
Coding: 07000763E0691CCD050D87099CAE9CB9110B35490000009401010A00200016010861013B0257090000000000000000000000000000000000000000000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_BCM1BOSCHAU651 017002
ROD: EV_BCM1BOSCHAU651_017.rod
VCID: 01585B6021852952804-8054
Subsystem 1 - Part No SW: 80B 955 119 A HW: 80B 955 119
Component: 426 LL 200814 040 0581
Serial number: 00000002008122101042
Coding: FFC7F7
Serial number: 24902173X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 31 08 2020 02440428
Subsystem 4 - Part No SW: 4N0 907 410 C HW: 4M0 907 410 A
Component: USHL5 GX1 H12 0300
Serial number: 0000009600373Z00FU02
Coding: 250000
Subsystem 5 - Part No SW: 4KE 857 511 C HW: 4KE 857 511
Component: Y7_Innenspieg H05 0003
Serial number: GX1NR114082023310066
Interior Light Module:
Subsystem 6 - Part No SW: 80A 947 135 BJ HW: 80A 947 135
Component: Dachmodul H42 0415
Serial number: Q00019437
Coding: 0D0101
Subsystem 7 - Part No SW: 80A 907 705 A HW: 80A 907 705
Component: J866-EVLS-SG H07 0200
Serial number: WA140922000080310747
Coding: 0A0700
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 80A 907 561 C HW: 8W0 907 561
Component: LRR4 H12 0451
Dataset Number: 80B909863J 0004
Coding: B57787F258FFEC06747861A1
ASAM Dataset: EV_ACCBOSCHAU49X 003024
ROD: EV_ACCBOSCHAU49X_003_AU49.rod
VCID: 280E26C4E27F381AE7A-807C
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_ALIGNMENT_NOT_OK]
Reset counter: 121
Mileage: 66875 km
Date: 2025.04.25
Time: 16:39:34
Control Module temperature: 45 °C
Voltage terminal 15: 11.8 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 T HW: 80A 959 655 T
Component: AirbagVW30 004 0703
Serial number: 0032SM00N8FF Dataset Number: 80A909602AA 0010
Coding: AECCFCC000800000A000003FF20C400000C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001044
VCID: 44D692747E17FC7AEB2-8010
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2040
Serial number: 80A857705M0073U00695
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2040
Serial number: 80A857706M0077U00747
Coding: 80000D
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H12 0022
Serial number: IBH0000D20000D9FW607
Coding: 303039
Subsystem 4 - Part No SW: ----------- HW: 480 002 804 20
Serial number: 35700000000259CC284Q
Subsystem 5 - Part No SW: ----------- HW: 480 001 507 20
Serial number: 358000000004B6FC694/
Subsystem 6 - Part No SW: ----------- HW: 480 031 107 20
Component: SideSensor_Dr 002 0149
Serial number: 351002C08A026EC0CCDQ
Subsystem 7 - Part No SW: ----------- HW: 480 031 107 20
Component: SideSensor_Pr 002 0149
Serial number: 352002C0809AF1A07F1E
Subsystem 8 - Part No SW: ----------- HW: 480 030 807 20
Component: FrontSensor_D 002 0149
Serial number: 355002C08D8E60813ADP
Subsystem 9 - Part No SW: ----------- HW: 480 030 807 20
Component: FrontSensor_P 002 0149
Serial number: 356002C08D866A70B8AT
Central crash sensor X/Y:
Subsystem 10 - Part No SW: ----------- HW: 480 020 607 20
Component: CentrSensorXY 005 0108
Serial number: I0O0001B0F48758761B/
1060617 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
Reset counter: 124
Mileage: 66875 km
Date: 2025.04.25
Time: 16:39:34
1060614 - Databus
[NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
Reset counter: 124
Mileage: 66875 km
Date: 2025.04.25
Time: 16:39:34
Part No SW: 80A 907 129 DH HW: 80A 907 129 DH
Component: Lenks.Modul H03 0009
VCID: 71B80BA0112539D2704-8024
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 790 K HW: 8W5 920 790 K
Component: FBenRDW------ H09 0161
Coding: 87EF3EC57EA8D7050280636018000B0008003000
ASAM Dataset: EV_DashBoardAU65X 002025
ROD: EV_DashBoardAU65X_002_AU49.rod
VCID: 4ACABC4C5C332A0A11E-801E
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 80C 907 468 F HW: 80B 907 468 B
Component: Gateway H06 0613
Serial number: 1JF04174484801 Dataset Number: 8W0909515VC 0002
Coding: 030300010000064054070000005900327C9A0001980000000100008E00000000
GVL: 01503C500800000040DCC8008002C800110C0000000000000000000000006500
ASAM Dataset: EV_Gatew31xAU65x 003250
ROD: EV_Gatew31xAU65x_AU49.rod
Subsystem 1 - Part No SW: 83A 951 523 L HW: 83A 951 523 L
Component: J453 MFL H07 0004
Serial number: 20200312234714 31919
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 8109797400
Subsystem 3 - Part No SW: 4M8 419 508 A HW: 4M8 419 508 A
Component: J1158 KLR H10 0008
Serial number: 00000000000000004831
Coding: FFFFFF
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0060
Revision: 5WK12700 Serial number: 605005516202007
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 79A8338049557192C84-802C
Part No SW: 4M6 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0064
Serial number: 12A14023300173 Dataset Number: 80B909856C 0012
Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
VCID: 7BA4298843694382DA8-802E
Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb
Part No SW: 80A 907 566 B HW: 80A 907 566
Component: MRR1Rear H22 0441
Revision: -------- Dataset Number: 80B909535C 0005
Coding: 0EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 2C06DAD4F687143A032-8078
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS002 0425
Serial number: CLSM1THB004BJ Dataset Number: 80B909872F 0044
Coding: 005F8B005E00148000010032
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 46D2887C482BCE6AF56-8012
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 80B909852M 0001
Coding: B0002101000101
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323AC4ACD4A342CA49E-8066
Part No SW: 4N0 907 064 EP HW: 4N0 907 064 P
Component: BCM2 MLBevo H16 0224
Dataset Number: 80C909501A 0008
Coding: 013400004FB100C0650BA0006C009802030040008104A6502F0000000504803F001E0681000A11
ASAM Dataset: EV_BCM2CONTIAU651 011009
ROD: EV_BCM2CONTIAU651_011.rod
ID - sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY201751UDT
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000048440104
Subsystem 4 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 14689716
Rear spoiler control module:
left tail lamp 2:
Subsystem 6 - Part No SW: 80A 945 429 A HW: 80A 945 429 A
Component: T2 LH SAE H10 0403
Serial number: 0D2
Right rear tail lamp 2:
Subsystem 7 - Part No SW: 80A 945 430 A HW: 80A 945 430 A
Component: T2 RH SAE H10 0403
Serial number: 0IN
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS002 0425
Serial number: CLSM1THH006LS Dataset Number: 80B909873F 0044
Coding: 005F8B005E00148000010030
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 45D08F70752DC572FCC-8010
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 80A 035 050 H HW: 80A 035 050
Component: MU-TH-NS-US 042 3696
Serial number: 8VV-DDM04.09.20 Dataset Number: 8W1909545G 0200
Coding: 14260000804220000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_VW53.rod
VCID: 1E62001CB03BF6AA9D6-804A
Multimedia display unit 1:
Subsystem 1 - Part No SW: 80B 919 620 HW: 80B 919 620
Component: CenterDisplay H41 0160
Serial number: AUZ8Z9L6H00AN5
Subsystem 2 - Part No: V03 959 807 CN
Component: MIB3_NA_Q319 0366
Compact disc data bank:
Component: Gracenote2 3004
Volume Control 1:
Subsystem 4 - Part No SW: 80B 919 616 A HW: 80B 919 616 A
Component: LSR-Q5PA H20 0103
Serial number: ALJAL230032000020018
Media socket:
Subsystem 5 - Part No: 8W0 035 708 A
009 0007
Digital Sound System Control Module 2:
Subsystem 6 - Part No SW: 8Y0 035 465 HW: 8Y0 035 465
Component: B_A_3_P_0_AU H10 0140
Serial number: YJL-26025.08.2066610
Part No SW: 8W0 907 428 A HW: 4M0 907 428
Component: Areaview 2 H16 0106
Serial number: C854609JJ001192 Dataset Number: 80B909460L 0017
Coding: 02240602BA0FA10038004000
ASAM Dataset: EV_CamSysRVAV2CE2MLBPA 001001
ROD: EV_CamSysRVAV2CE2MLBPA_001.rod
VCID: 3E22E09C10FB96AABD6-806A
Part No SW: 8W8 959 107 D HW: 8W8 959 107
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C748-5750-8 Dataset Number: 80B909541D 0010
Coding: 0730
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 80A 907 777 AK HW: 80A 907 777 C
Component: Fahrwerk-SG H37 1253
Serial number: 0307200157 Dataset Number: 80B909576S 0001
Coding: 14603032F8
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 7AAA2C8C4C537A8AC1E-802E
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130987841
Coding: 303030
3342340 - Function block
B2003 00 [10001001] - -
[Function_block_reference_level]
Reset counter: 121
Mileage: 66875 km
Date: 2025.04.25
Time: 22:23:51
Internal DTC: 103
3342342 - Function block
[Function_block_preliminary_stage_service]
Reset counter: 124
Mileage: 66915 km
Date: 2025.04.26
Time: 20:14:34
Internal DTC: 105
C10C5 00 [10001001] - -
Reset counter: 121
Mileage: 66875 km
Date: 2025.04.25
Time: 22:23:51
Internal DTC: 641
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 4KE 035 283 F HW: 4KE 035 283 B
Component: CB_H_NAR 039 0372
Serial number: A971G0LS023737 Dataset Number: 8W0909612F 0022
Coding: 01E0E0F8C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_AU49.rod
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 M HW: 80B 713 041 M
Component: GSM-LL H10 0077
Revision: 0L0D5012 Serial number: 20200729000867
ROD: EV_GSMWaehlZFAU736.rod
VCID: 270C25F8EF613762EE0-8072
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 C HW: 8W0 907 541
Dataset Number: 80B909885F 0002
ASAM Dataset: EV_ACC2BOSCHAU49X 003024
ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
VCID: 261228FCE86B2E6AD56-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 F HW: 80A 907 217 D
Component: BVS H21 0070
Dataset Number: 80B909466F 0036
Coding: 0404020600000204022000AEAD0000FEA0F0C0200020
ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 290823C0F9750112F84-807C
Part No SW: 80A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 200131200348
VCID: 688E66C422FFF81A27A-803C
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS004 0425
Serial number: CLSM1THM00DQ2 Dataset Number: 80B909897G 0045
Coding: 000F89000000148040000020
VCID: 48CE8644423FD81A07A-801C
Component: TSG HBFS004 0425
Serial number: CLSM1THM00DPZ Dataset Number: 80B909896G 0045
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: 80B909469G 0012
Coding: 22804004260C
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B03FB0654D15F2ACC-8020
Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb
Part No SW: 80A 907 590 B HW: 80A 907 590
Revision: --------
Coding: 0EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
Part No SW: 4K0 941 572 DD HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0040
Dataset Number: 80B909471E 0010
ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
ROD: EV_LMSLeftHELLAAU58X_AU37.rod
VCID: 73B401A86B390BC2828-8026
Dataset Number: 80B909472E 0010
ASAM Dataset: EV_LMSRightHELLAAU58X 001015
ROD: EV_LMSRightHELLAAU58X_AU37.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 80A 035 502 B HW: 80A 035 502 B
Component: WLC Front H14 0061
Coding: 800000
VCID: 1A6A0C0CAC139A8A61E-804E
End----------(Elapsed Time: 02:18, VBatt start/end: 12.1V/12.0V)-----------
------------------------------7 Faults Found-------------------------------
