Short Lived SRI Reset (VW Caddy Maxi 2015)
timangus
Edinburgh, UK
C?ID=491580
Using the SRI reset function ostensibly works, but for me I find that an oil change/service reminder shows up on the dash after only a short time/mileage, but when I look at the values in the SRI reset log, they don't appear to be any where near the limits, so I don't understand why the service reminder reappears so quickly. This is a UK vehicle, 1.6 diesel engine.
Here are the logs prior to performing the SRI reset. 700km is obviously less than 10000km and 134d is obviously less than 730d.
Sunday,27,April,2025,15:25:57:61284
VCDS Version: 25.3.0.4 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
VIN: WV1ZZZ2KZFX143056   License Plate: PL15BOH
Mileage: 65670km-40805mi   Repair Order:
VCDS Release 25.3.0:  SRI Reset-SRI1.CLB
Control Module Part Number: 2K0 920 966 C       Labels:  .*5K0-920-xxx-17.clb-SRI1
Component:KOMBI         H03 0905, Coding:480800
Channel        Description                                                     Current val.                                                    New val.
IDE00342-ESI: Resetting ESI        ESI: Service Status                                             Warning active                                                  ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance SINCE last Oil Service                            600 km                                                          ---
IDE00511-ESI: time from inspection        ESI: Time SINCE last Oil Service                                134 d                                                           ---
        ESI: Minimum Distance to Oil Service(s)                         ---                                                             ---
        ESI: Maximum Distance to Oil Service(s)                         ---                                                             ---
        ESI: Minimum Time to Oil Service(s)                             ---                                                             ---
        ESI: Maximum Time to Oil Service(s)                             ---                                                             ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance SINCE last mileage-dependent Inspection           700 km                                                          ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time SINCE last time-dependent Inspection                  134 d                                                           ---
IDE03349-FIX: Max. distance until next mileage-related inspection                                       FIX: Max. Distance to mileage-dependent Inspection(s)           10000 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Max. Time to time-dependent Inspection(s)                  730 d                                                           ---
IDE01153-SIA: maximum value of distance to service                                                      SIA/SID: Maximum Distance to Service/Inspection                 0 km                                                            ---
IDE01154-SIA: maximum value of time to service                                                          SIA/SID: Maximum Time to Service/Inspection                     365 d                                                           ---
*IDE00935-ESI: Theoretical service interval                                                             ESI/INFO: Theoretical Oil Service Interval                      N/A                                                             ---
*IDE00697-ESI: remaining distance        ESI/INFO: Remaining Distance to Oil Service                     N/A                                                             ---
*IDE00698-ESI: remaining running time        ESI/INFO: Remaining Time to Oil Service                         N/A                                                             ---
*IDE00695-ESI: service exceedance in km        ESI/INFO: Oil Service Exceedance                                N/A                                                             ---
*IDE00696-ESI: service exceedance in days                                                               ESI/INFO: Oil Service Exceedance                                N/A                                                             ---
*IDE00819-Day counter        INFO: Day Counter (since Delivery Inspection)                   3542 d                                                          ---
IDE00301-Distance        INFO: Vehicle/Odomoter Mileage                                  65670 km                                                        ---
IDE00517-ESI: soot entry        ESI/INFO: Soot Entry                                            400 km                                                          ---
IDE00518-ESI: thermal load        ESI/INFO: Thermal Load                                          300 km                                                          ---
IDE00515-ESI: oil quality        ESI/INFO: Oil Quality                                           poor oil quality                                                ---
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level                             ESI/CODING: Oil Level Evaluation                                Oil level evaluation                                            ---
IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID                     ESI/CODING: ESI-SIA/SID ON/OFF                                  ESI or SIA ON                                                   ---
IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID               ESI/CODING: ESI or SIA/SID                                      Extended Service Intervals (ESI)                                ---
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure                          ESI/CODING: Oil Pressure Warning                                dynamic oil pressure                                            ---
IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver                 ESI/CODING: Remote Clock Receiver                               without remote clock receiver                                   ---
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality                           ESI/CODING: Oil Quality                                         poor oil quality                                                ---
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG                                   ESI/CODING: Oil Level & Thermal Sensor                          Oil level thermal sensor connected to instrument cluster        ---
Here are the logs after the reset:
Sunday,27,April,2025,15:28:05:61284
VIN: WV1ZZZ2KZFX143056   License Plate: POSTSRI
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)
IDE00342-ESI: Resetting ESI        ESI: Service Status                                             Resetting                                                       ---
IDE00510-ESI: distance driven from inspection                                                           ESI: Distance SINCE last Oil Service                            0 km                                                            ---
IDE00511-ESI: time from inspection        ESI: Time SINCE last Oil Service                                0 d                                                             ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                                  FIX: Distance SINCE last mileage-dependent Inspection           0 km                                                            ---
IDE03352-FIX: Time since last time-dependent inspection                                                 FIX: Time SINCE last time-dependent Inspection                  0 d                                                             ---
*IDE00697-ESI: remaining distance        ESI/INFO: Remaining Distance to Oil Service                     0 km                                                            ---
*IDE00698-ESI: remaining running time        ESI/INFO: Remaining Time to Oil Service                         365 d                                                           ---
IDE00517-ESI: soot entry        ESI/INFO: Soot Entry                                            0 km                                                            ---
IDE00518-ESI: thermal load        ESI/INFO: Thermal Load                                          0 km                                                            ---
It looks as you would anticipate, but I fully expect that in a short time the service reminder will show up again, as this has happened several times before and I don't understand why; can any one explain? Maybe something to do with IDE00517-ESI: soot entry or IDE00518-ESI: thermal load? i.e. the service reminder is warning of something else?
Here's an autoscan incase relevant:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 3D 42 44 46 52 5F
VIN: WV1ZZZ2KZFX143056   Mileage: 65670km-40805miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8013
   Revision: --H43---    Serial number: 00000000000000 CVN: 563A1DB3
   Coding: 00114014032500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
   ROD: EV_ECM16TDI02103L906023B_003.rod
   VCID: 76B41AB3E849CBFAA5B-8022
   VINID: 9E606AAAA09BA96A01103005183BDEB495
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 633C400D092603FDC60B02E9901FC081A0000020
   Shop #: WSC 35110 377 08192
   VCID: 0450707BAE15E96AABF-8050
   Part No SW: 7N0 907 426 DA    HW: 7N0 907 426 DA
   Component: AC Manuell    H20 0707
   Revision: 00001002
   Coding: 0010004002
   Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
   Component: BCM PQ35 B+   122 0174
   Revision: BB122001
   Coding: 611A581A8025186B08000082900000640301728852028060648000000040
   VCID: 72BC26A384A1D7DA893-8026
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 09041  26  0512
   Coding: 009795
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0045
   Revision: --------    Serial number: 32961220000425
   Coding: 308001
   ASAM Dataset: EV_EPHVA14VW3680000 001005
   ROD: EV_EPHVA14VW3680000.rod
   VCID: 3A2CCE839CD16F9A813-806E
   Component: VW10Airbag02Q H07 0013
   Revision: --------    Serial number: 003HL00WLJL5 Dataset Number: 2KC003v____ 0285
   Coding: 000000000000000000000000000000003251
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3536DDBFB5CF80E26C1-8060
   Part No SW: 1K5 953 521 BG    HW: 5K0 953 569 AC
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150411200306
   Coding: 0080060000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 73B223A7FB3BDED2825-8026
   Part No SW: 2K0 920 966 C    HW: 2K0 920 966 C
   Component: KOMBI         H03 0905
   Coding: 480800
   VCID: 3038ECAB4AADA5CA3F7-8064
   Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1653
   Revision:   H57       Serial number: 220415F1000113
   Coding: 357401
   VCID: 7EA40293C0F983BAFDB-802A
   Component: IMMO          H03 0905
   VCID: 6A8C3EC3ACF11F1A313-803E
Address 3D: Special Function        Labels: None
   Part No SW: 1F9 909 919 B    HW: 1F9 909 919 B
   Component: MultifunctionDevice 0072
   Revision: 00H03000    Serial number: 00000000000728
   Coding: 01003B
   VCID: 372AD7B7A34372F27ED-8062
   Subsystem 2 - Part No: 7E0 959 442
   Component: E221__MFL-DC1
   Coding: 03211263
   Shop #: WSC 12345
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48C8A44BDEBD0D0A077-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 392ED18F95576482889-806C
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 47CAA777D3A302720ED-8012
   Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
   Component: MU-S-D-ER     H41 0478
   Serial number: VWZAZ2U1674508 Dataset Number: V03935269PZ 0001
   Coding: 063307003C0000001111110100880A401F0100D60020010003
   Shop #: WSC 00020 999 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2C00F8DB6685C12A03F-8078
          U1400 00 [00001000] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 105
                    Mileage: 64907 km
                    Date: 2024.11.25.
                    Time: 12:28:30
                    Voltage terminal 30: 8.2 V
15360768 - Component Protection
          U1101 00 [00001001] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 168
                    Mileage: 59465 km
                    Date: 2021.12.24.
                    Time: 19:11:59
                    Voltage terminal 30: 11.7 V
End----(Elapsed Time: 00:55, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
------------------------------2 Faults Found-------------------------------
Thanks!
NEtech
Denmark
C?ID=56995
Looks like somebody changed different channel values manually.
IDE01153-SIA: maximum value of distance to service 0 km
Should be 15000 km
That should be your problem.
IDE03349-FIX: Max. distance until next mileage-related inspection 10000 km
That is very low for Mileage related Inspection (Filter, etc.), should be 30000
timangus
Edinburgh, UK
C?ID=491580
Oh OK, I'll give that a try, thanks! Why would that not just kick in immediately though? Perhaps there is some minimum mileage that must occur before service reminders are enabled? Anyway I expect you're right, thanks again.
Westbury, UK
My experience is that it can take up to 500 miles before the service due changes to a meaningful value.
timangus
Edinburgh, UK
C?ID=491580
Well that would certainly tally with my experience, it's round about the 500 mile mark when it reoccurs.
TTT
C?ID=547002
And this after reset?
timangus
Edinburgh, UK
C?ID=491580
Yes.
Actually, just noticed some of the values have an asterisk in front of them, what does that mean?
TTT
C?ID=547002
No idea.
I'm embarrassed to admit that I don't know either. Let me see if I can get @RTSupport to chime in here.
Eric
HC800000
That's when the script calls for reading a measuring value and not an adaptation channel. Disclaimer: I'm not responsible for the script contents ;)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The reason why I added these additional meas. values is because we are otherwise missing data, which isn't available as adaptation channels and helps us to determine what is and isn't the problem in cases like this. In addition it helps us understand the actual calculation of flexible intervals better and correlate it to customer issues like service remember stay on after a service already being reset and last but not least, this helps on the warranty maintenance side even after factory warranty is expired to document whether or not the owners/drivers have exceeded their intervals beyond a reasonable amount (a recent maximum I came across was 120000 km exceedance w/o an oil change, where the shop in question asked for assistance in order to verify how long the customer must have ignored the message).
When checking the VIN, the car is PR-QG1 (flexible Intervals) and PR-QI6 (flexible Interval of 30000 km or 2 years) while the data above indicates that IDE00515 is set to "poor oil quality" indicating the car has been put on fixed intervals at some point either intentionally or by accident due to a manual / button reset via the instrument cluster or car menu. The actual internal settings have not been changed though, meaning IDE00492 still shows the vehicle being initially set to ESI (Extended Service Intervals) which is why you end up with some mismatch in the data like IDE00935, IDE00697 and IDE00698 behaving illogically. This won't have any influence on the fixed interval calculation but appears to lead to confusion in this thread. 😉
The basic issue (i.e. service reminder active after a reset service) is expected once you look at the values and Niels has pointed that our already. IDE01153 was incorrectly set. With the VW Commercial vehicles there were a a lot of changes resulting in different intervals for MY <= 2010, MY 2011-2012, MY 2013 and => MY 2014. In this case (MY 2015) and the correlating interval (PR-QI4/QI6/QI7), the first inspection would need to happen after 30000 km or 2 years, followed by 30000 km or an annual inspection from there on (es usual, whichever threshold is hit first and the extended inspection will not be specially handled here and must be determined based on previous intervals/mileage). This also means that IDE03350 is definitely not correctly set for either flexible or fixed intervals, because the vehicle certainly has had more than one service events before.
Long story short, several service event related values are off and make little sense. This wouldn't happen if they were either manually reset via the dashboard or via VCDS. So somebody or something screwed up the settings before. In order to rectify the situation, what you want is to decide whether or not you want to keep it on fixed intervals or if you want to put it back onto flexible intervals. Let us know and we'll provide the proper values, also make sure to include the date and mileage for the most recent oil service and inspection (2 dates & mileages please if they did not fall together).
timangus
Edinburgh, UK
C?ID=491580
Thanks for the very detailed reply, that clears things up. It must have been something the dealer I bought it from did, because in my ownership it's always had this behaviour, and prior to the dealership's involvement the van was owned by a large national company that are very likely to have followed servicing guidelines closely. In my ownership I've only ever used VCDS to (rather frequently) reset it, though I think one time I might have used OBDeleven instead; regardless as I say it's behaved like this since I got it, so it doesn't seem likely that this is a factor.
Anyway, from how I use it, it probably makes more sense to use flexible intervals going forward. I've just done an oil change/service so today's date is fine for the most recent inspection. Thanks again.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Change the following channels in the proposed order:
  1. IDE00515 = good oil quality
  2. IDE00512 = 15000 km
  3. IDE00513 = 30000 km
  4. IDE00827 = 365 d
  5. IDE00514 = 730 d
  6. IDE03349 = 30000 km
  7. IDE03350 = 365 d
  8. IDE00510 = Adjust to Distance since Oil Change
  9. IDE00511 = Adjust to Time/Days since Oil Change
  10. IDE03351 = Adjust to Distance since Inspection
  11. IDE03352 = Adjust to Time/Days since Inspection
In rare case you may need to cycle the ignition between steps 1 and 2, in order for the cluster to properly enable the channels for step 2-5. Let us know if this worked, once done you should see "---" for the distance 'til next oil service, that is expected for ~500 km after the reset and will be re-calculated based on the values in IDE00517 & IDE00518 along the way.
timangus
Edinburgh, UK
C?ID=491580
It all appears to have taken as far as I can tell. I'll need to drive it a bit before I know if it's ultimately worked obviously, will let you know if it re-occurs. Cheers.
Tuesday,29,April,2025,18:21:31:61284
VIN: WV1ZZZ2KZFX143056   License Plate: RTADVICE
IDE00512-ESI: minimum value km-driving distance/inspection                                              ESI: Minimum Distance to Oil Service(s)                         15000 km                                                        ---
IDE00513-ESI: maximum value km-driving distance/inspection                                              ESI: Maximum Distance to Oil Service(s)                         30000 km                                                        ---
IDE00827-ESI: minimum value of time between inspections                                                 ESI: Minimum Time to Oil Service(s)                             365 d                                                           ---
IDE00514-ESI: maximum value of time between inspections                                                 ESI: Maximum Time to Oil Service(s)                             730 d                                                           ---
IDE03349-FIX: Max. distance until next mileage-related inspection                                       FIX: Max. Distance to mileage-dependent Inspection(s)           30000 km                                                        ---
IDE03350-FIX: Maximum time until next time-dependent inspection                                         FIX: Max. Time to time-dependent Inspection(s)                  365 d                                                           ---
        SIA/SID: Maximum Distance to Service/Inspection                 ---                                                             ---
        SIA/SID: Maximum Time to Service/Inspection                     ---                                                             ---
*IDE00819-Day counter        INFO: Day Counter (since Delivery Inspection)                   3544 d                                                          ---
IDE00515-ESI: oil quality        ESI/INFO: Oil Quality                                           good oil quality                                                ---
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality                           ESI/CODING: Oil Quality                                         good oil quality                                                ---
