Hallo guys.
I want to install Blind Spot retrofit to my Golf 8 2022/12. I am searching everywhere some instalation manual but i cant find it.
I found retrofit on Aliexpres you can see it on the foto is like 220€ +- . There is sensors, holder, cables, cover on the mirror and lights to the mirrors. Is it okej for my car ? will be past there ? Where i have to fitt that holder for sensor ? Thank you for any help
Wednesday,16,April,2025,17:29:01:25643
VCDS Version: 25.3.1.0 (x64) HEX-NET2 CB: 0.4671.5
Data version: 20250408 DS365.0
VIN: WVWZZZCD5PW119623 License Plate: AA926PC PO PROBLEME
Mileage: 58812km-36544mi Repair Order:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 4B 52 5F 69
6C 75 A5 D6 D7 8107 C002 C003
VIN: WVWZZZCD5PW119623 Mileage: 58812km-36544miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
8107-Antenna -- Status: OK 0000
Address 01: Engine (J623-DNNA) Labels: None
Part No SW: 5FF 907 115 A HW: 06Q 907 309
Component: R4 2.0l TFS H80 0004
Revision: J5H80000 Dataset Number: 06Q909102D 0009 CVN: 9D432BBD
Coding: 012540322474050B34180000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0115FF907115A 001006
ROD: EV_ECM20TFS0115FF907115A.rod
VCID: 39244016C9DFD072885-806C
VINID: 9E69EAAAA4D41609C10491820C37563218
Readiness: 0010 0001
Part No SW: 0GC 906 557 BK HW: 0GC 300 047 R
Component: GSG DQ381 H06 4161
CVN: A1BC4366
ASAM Dataset: EV_TCMDQ381062 001001
ROD: EV_TCMDQ381062_VW38.rod
VCID: 0740F6EECFAB7682CE1-8052
Subsystem 1 - Part No SW: 5WA 713 033 BB HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20220718000082857302
Subsystem 2 - Part No SW: 5H0 713 059 Q HW: 5H0 713 059 Q
Component: ZSB_SB_Mono H03 0014
Serial number: 92478VH600614
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810600004366486
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 BL HW: 5WA 614 517 N
Component: ESC H13 0133
Serial number: 63481000002841 Dataset Number: V03935383CS 0001 CVN: 01B7675E
Coding: 34FC2C9042214275527D600206C6A1854DB258554AC8670821BCA231018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 1378D2BE8BF3CA22229-8046 SFD
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 H HW: 5WA 959 436 H
Component: Kessy IOBOX 100 0725
Serial number: --------------- Dataset Number: V03935341VY 0001
ASAM Dataset: EV_Kessy37w 004024
ROD: EV_Kessy37w_004.rod
VCID: 59E4E096299F3072A85-800C
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 727 AD HW: 5WA 907 727 AD
Component: Climatronic H02 0440
Serial number: --------------- Dataset Number: V03935358HE 0001
Coding: 002000010210120010100010111111110000131100200000000000000000
ASAM Dataset: EV_ACClimaBHBVW38X 005069
ROD: EV_ACClimaBHBVW38X_VW38.rod
VCID: 1276D7BAB4E9C32A29F-8046
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H02 0003
Serial number: 00000000000001209400
Subsystem 2 - Part No SW: 11A 907 049 HW: 11A 907 049
Component: E265 KPH H02 0183
Serial number: G06S19.08.2200972649
Interior temperature sensor:
Subsystem 3 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002100822072046520
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 AE HW: 5WA 937 086 L
Component: BCM37w_M028 0175
Serial number: BXJ53F280622940 Dataset Number: V03935385NZ 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 147AD1A28EFDCD1A3B3-8040 SFD
Subsystem 1 - Part No SW: 5H1 955 119 A HW: 5H1 955 119 A
Component: FWISCHER_MYJT 003 0051
Serial number: 907453F0402221301706
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 054 0206
Serial number: SBY22M08D18H18M17S04
Subsystem 3 - Part No SW: 5H0 941 193 AK HW: 5H0 941 193 AK
Component: LiSi H06 0008
Serial number: 92471VFT002S2
Subsystem 4 - Part No SW: 5H0 925 200 T HW: 5H0 925 200 T
Component: DiETa H07 0008
Serial number: 92471VG8000AO
Subsystem 5 - Part No SW: 5H0 959 569 C HW: 5H0 959 569 C
Component: DACHKONSOLE 101 0104
Serial number: 000000092413VHA00522
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000010082208490228
Antenna for short-range communication:
Subsystem 7 - Part No SW: 5H0 959 121 A HW: 5H0 959 121 A
Component: R350 NFCTGS 021 0504
Serial number: CB0000AE14
Antenna 2 for short-range communication:
Subsystem 8 - Part No SW: 3G0 980 611 HW: 3G0 980 611
Component: J524 NFCMIKO H09 0062
Serial number: 32200000000001575557
1074443 - Electrical Steering Column Lock
B1248 F3 [00101100] - Terminal Release Implausible
Reset counter: 39
Mileage: 58812 km
Date: 2025.04.16
Time: 14:00:54
Terminal 15 status: OFF
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.5 V
Outside temperature: 25.0 °C
Light switch position: automatic
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5R3 919 298 HW: 5R3 919 298
Component: PLA 12 Kanal H05 1550
Serial number: 000995442322139 Dataset Number: V03935375HP 0001
Coding: 8200022111
ASAM Dataset: EV_EPHVA2CVW3800000 002036
ROD: EV_EPHVA2CVW3800000_VW38.rod
VCID: 55FCECA6458714128CD-8000
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 5WA 907 572 C HW: 5WA 907 572 A
Component: ACC BOSCH MQB H40 0460
Dataset Number: V03935380FG 0001
Coding: 0A8318F5007740451247400800C040C44E4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4ECE03CA605167CA4D7-801A
2068 - Databus
U1123 00 [00101000] - Received Error Message
[FAULT_TSK_IRREV_ERROR]
Mileage: 58799 km
Date: 2025.04.16
Time: 12:36:56
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Mileage: 58803 km
Date: 2025.04.16
Time: 12:44:47
0528 - Databus
U1121 00 [00101000] - Missing Message
[FAULT_TIMEOUT_MOTOR_51]
Mileage: 58803 km
Date: 2025.04.16
Time: 12:44:47
0559 - Databus
[FAULT_KLR_TOUCHINTENSITY_ERROR]
Mileage: 58803 km
Date: 2025.04.16
Time: 12:50:47
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
Mileage: 58803 km
Date: 2025.04.16
Time: 12:44:47
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 L HW: 5WA 959 655 L
Component: AirbagVW40 010 0636
Serial number: 000000003C0J2R8 Dataset Number: V03935376EV 0001
Coding: 88CC008000F0C000000000000000000051540000205400004000F68000130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 6092CD720AC5E1BAEFB-8034 SFD
Subsystem 1 - Part No SW: ----------- HW: 480 050 908 22
Component: SideSensor_Dr 000 0149
Serial number: 35100008B2869994E61A
Subsystem 2 - Part No SW: ----------- HW: 480 052 908 22
Component: SideSensor_Pr 000 0149
Serial number: 3520000792869C10A44$
Subsystem 3 - Part No SW: ----------- HW: 480 000 908 22
Serial number: 357000000009C995216P
Subsystem 4 - Part No SW: ----------- HW: 480 001 108 22
Serial number: 358000000007B854C16R
Subsystem 5 - Part No SW: ----------- HW: 480 052 608 22
Component: FrontSensor_D 000 014A
Serial number: 35500007F2869B042887
Address 17: Instruments (J285) Labels:| 5H0-920-KOM-V1.clb-SRI2
Part No SW: 5H0 920 340 C HW: 5H0 920 340 C
Component: KOMBI 310 7360
Dataset Number: V03935364SX 0001
Coding: 04AC00406B940008018072032000080800300400
ASAM Dataset: EV_DashBoardVDDMQB37W 003035
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 2216877A4449B3AAB9F-8076 SFD
16777020 - Control unit for information electronics 1
U1054 00 [00001001] - No Communication
[TEL_0x28 communication error bap_error_timeout heartbeat]
Reset counter: 19
Mileage: 58812 km
Date: 2025.04.16
Time: 17:20:44
Part No SW: 5WA 907 530 L HW: 5WA 907 530 L
Component: GW2020 High 778 7103
Revision: -------- Serial number: 771049090022217 Dataset Number: V03935371HN 0001
Coding: 0000838D0F00000000000000012303725301611902000300030100000001010000000000000000000000000000000000
GVL: 3D0000000208C09C80008002C800004004004002004400000000000000000044
ASAM Dataset: EV_GatewMQB2020 006012
ROD: EV_GatewMQB2020_006_VW38.rod
VCID: 51F418B6716F7832505-8004 SFD
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 2563890206
Subsystem 3 - Part No SW: 3G0 959 442 AF HW: 3G0 959 442 AF
Component: E221__MFL-PR6 H07 0120
Serial number: PR6-0440079234220344
Subsystem 4 - Part No SW: 5H0 959 542 L HW: 5H0 959 542 L
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA22239150601
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 Q HW: 3Q0 909 059 C
Component: EBKV H09 0309
Serial number: BPA085240822013 Dataset Number: V03935367RC 0001
Coding: 1002C100790000CE39E79C73000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
VCID: 5EEEF38A30B1D74ADD7-800A SFD
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H10 0040
Serial number: 22000177331016 Dataset Number: V03935336NF 0001
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 3236773A14A9232A49F-8066
Part No SW: 5WA 959 760 H HW: 5WA 959 760 H
Component: MEM-FS 009 0362
Serial number: 2242401KA02430 Dataset Number: V03935307MP 0001
Coding: 015892400000A0508803010101010000000000212100000000000000215000
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007VGK17234 Dataset Number: V03935382CW 0001
Coding: 003B03208200040000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 4AC60FDA9C394BEA11F-801E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000062998407
Coding: 110000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 02034800 Dataset Number: V03935358SR 0001
Coding: 0000000000000000000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5WA 907 338 B HW: 5WA 907 338
Component: FCM2020 Low H14 1447
Serial number: 240151222326127 Dataset Number: V03935346BX 0001
Coding: 00000000090007CA01002F10020003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW38X 004012
ROD: EV_MultiModulContiVW38X_004_VW38.rod
VCID: 4DCC04C66D575CD234D-8018 SFD
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007VGC3091E Dataset Number: V03935382CX 0001
Coding: 003B01208E00040000801000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 49C430D6993F40F2185-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000062873975
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 5H0 035 820 K HW: 5H0 035 820
Component: MU-O-ND-EU H58 1985
Serial number: WG8LGM250822000 Dataset Number: V03935368WE 0001
Coding: 23800000000000000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 001002
ROD: EV_MUOIMQB37w_001_VW38.rod
VCID: 2A066F5A3C796BEAF1F-807E SFD
Subsystem 1 - Part No SW: 5H0 919 605 B HW: 5H0 919 605 B
Component: ABT_W_10 H47 2101
Serial number: APUFG329072200010403
Subsystem 2 - Part No SW: V03 959 817 SM HW: -----------
Component: EUR 2022/23 --- 7065
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 C HW: 5H2 907 383
Component: Anhaenger H10 0058
Serial number: 000000000006045 Dataset Number: V03935332HV 0001
Coding: 0100000202001200
ASAM Dataset: EV_TrailFunctGener3Hella 001012
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 30327D321AA5113A3FB-8064
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 D HW: 5WA 980 556 B
Component: RV eCompact H30 0344
Serial number: FCLK20220422010 Dataset Number: V03935359FC 0001
Coding: 02030104E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 010024
ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
VCID: 52F617BA7469032A69F-8006
Part No SW: 5WA 035 284 F HW: 5WA 035 284 C
Component: OCU3HMQB37W H12 0144
Serial number: 0000000203VISM5 Dataset Number: V03935379BN 0001
Coding: 023800109068A8209405460071402E07
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002_VW38.rod
VCID: 49C430D6993F40F2185-801C SFD
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 D HW: 5WA 980 653
Component: MQB MFK 3.0 H09 3403
Serial number: EA8808904222300 Dataset Number: V03935378GE 0001
Coding: 00000888117CC040109F40001030008000438000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005055
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 50F21DB27A65713A5FB-8004
1124459 - Databus
[TIMEOUT_Heckradar_02]
Mileage: 58812 km
Date: 2025.04.16
Time: 17:23:46
1124458 - Databus
[TIMEOUT_Heckradar_01]
Mileage: 58812 km
Date: 2025.04.16
Time: 17:23:46
Part No SW: 992 941 571 AE HW: 992 941 571 A
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 659CDC6615E784921CD-8030
131337 - Databus
U1121 00 [10101100] - Missing Message
[CAN message LED_x_SABL missing]
Reset counter: 0
Mileage: 58806 km
Date: 2025.04.16
Time: 13:16:37
Component: LED1R H08 9202
Address 8107: Antenna (J666) Labels:* None
Part No SW: 5WA 035 741 B HW: 5WA 035 741 B
Component: TrxModulHigh H10 0083
Serial number: 0000000206VIPA2 Dataset Number: V03935364CE 0001
Coding: 02380011040080
ASAM Dataset: EV_TrxMLGEMQB37W 005006
ROD: EV_TrxMLGEMQB37W.rod
VCID: 43D822FEBB139AA2D29-8016 SFD
End----------(Elapsed Time: 01:38, VBatt start/end: 12.2V/12.1V)-----------
------------------------------10 Faults Found------------------------------
Address 13: DTCs cleared
Address 17: DTCs cleared
Address A5: DTCs cleared
Address D6: DTCs cleared
OR NO ?
Is it true?
also I want to try KLR modul to the steering wheel. It’s home already so I hope it’s working.
