Touareg Fuel Tank Fault Warning
Express Service
C?ID=581842
Hi
We have a Touareg with a fuel tank warning, please see below VCDS scan and advise on which checks will need to be carried out
Thanks in advance
Monday,28,April,2025,11:27:20:31799
VCDS Version: 25.3.0.2 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250228 DS364.1
VIN: WVGZZZCRZKD032874   License Plate: DV19HDU
Mileage: 100955km-62730mi   Repair Order:
Chassis Type: CR-VW53 (4N2)
Scan: 01 02 03 06 09 13 15 16 17 19 2B 36 42 44 46 52 5F 6C 6D 81
          A5 AC BB BC CA D6 D7 DE
VIN: WVGZZZCRZKD032874   Mileage: 100955km-62730miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DENA)       Labels: None
   Part No SW: 760 907 401 N    HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0002
   Revision: CAH26---    CVN: 9CCCCE8FFA9EEAC78947E11D8947E11D00000000D6C3ECFE
   Coding: 292A40320366050334180000000400000000000000000000
   Shop #: WSC 58804 004 1048576
   ASAM Dataset: EV_ECM30TDI011760907401N 001002
   ROD: EV_ECM30TDI011760907401M.rod
   VCID: 20128C37EA34207AAF1-8174
   VINID: 9E65EAAAA4E2A9B5000C220710C1A19218
   Part No SW: 760 927 158 B    HW: 0D5 927 156 N
   Component: 0D5  30TDIRdW H05 1003
   Revision: --H05---    CVN: 4559B166
   Coding: 100000
   Shop #: WSC 31414 040 00001
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011.rod
   VCID: 1F108FCBD74A1F8296B-814A
Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-V1.clb
   Part No SW: 4M6 907 379 N    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0850
   Dataset Number: V03935288DV 0001 CVN: 7AE34000
   Coding: 1DA731B730A50B989EA64898008152E2E93AE1B88C0CD07912004A47975C87
   ROD: EV_ESP9BOSCHCMP_004_VW53.rod
   VCID: 48C234972244383A071-811C
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000367137674 Dataset Number: V03935279EX 0001
   Coding: 0138B8000000A88188000101210100008900000707008F8F00000000015000
   Shop #: WSC 31414 050 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3D2C55437D866D92A47-8168
   Valve block 1 in front seat passenger side:
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ8001020219402581E1
   Coding: BF2F00
Address 09: Cent. Elect. (J519)       Labels:* 4N0-907-063-V2.clb
   Part No SW: 4N0 907 063 GG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0653
   Dataset Number: V03935293PD 0001
   Coding: 07501B43E17B0009074D16085BAE8C40800B30100000009301100A0079245A011BC500BB02B6C6170000010000D1201B1802000044010104000000000000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 79A48153292E91B2C8F-812C
   Subsystem 1 - Part No SW: 762 955 113     HW: 762 955 113
   Component: WIPER 060219  011 0420
   Serial number: VZ1SKA 1002021060219
   Serial number: 22542248X81A955555A0
   Coding: 02006D
   Subsystem 3 - Part No SW: 762 941 633     HW: 762 941 633
   Component: E1 - LTM  H06 0054
   Serial number: 13S21.02.1900140002
   Subsystem 4 - Part No SW: 3G0 857 511 AL    HW: 3G0 857 511 AL
   Serial number: GX1CE112111820810419
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 760 947 105 S    HW: 760 947 105 S
   Component: Dachelektroni  H32 0057
   Serial number: 00000512790000000000
393731 - Motor for Recirculation Flap
          B1092 07 [00001000] - Mechanical Failure
                    Mileage: 100953 km
                    Date: 2025.04.28
                    Time: 10:05:30
                    average_Voltage_terminals: 13.20 V
                    Outside air temperature sensor-Outside air temperature on CAN: 19.00 �C
                    interior_temperature: 19.00 �C
                    Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 760 907 561 B    HW: 760 907 561 A
   Component: LRR4R         H04 0330
   Dataset Number: V03935277PN 0001
   Coding: 32657F4358000400000020A000000010051246484401009E00
   ASAM Dataset: EV_ACCBOSCHAU65X 002022
   ROD: EV_ACCBOSCHAU65X_VW53.rod
   VCID: 1B68BBDBC35203A27A3-814E
   Part No SW: 4M0 959 655 J    HW: 4M0 959 655 J
   Component: AirbagVW31    H07 2710
   Serial number: 003YQM00JVU- Dataset Number: V03935282PM 0001
   Coding: 88CCC0C00C800000585400EF308D41A80065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   VCID: 42D626BF0478126AD95-8116
   Subsystem 1 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 357000000001C571693G
   Subsystem 2 - Part No SW: -----------    HW: 480 001 402 19
   Serial number: 35800000000B3D89993
   Subsystem 3 - Part No SW: -----------    HW: 480 032 102 19
   Serial number: 351001C1C29B9D60BFF/
   Subsystem 4 - Part No SW: -----------    HW: 480 032 102 19
   Serial number: 352001C1C293DD5119EK
   Subsystem 5 - Part No SW: -----------    HW: 480 031 211 18
   Component: FrontSensor_D  002 0189
   Serial number: 355001C180E5D6204E6D
   Subsystem 6 - Part No SW: -----------    HW: 480 031 211 18
   Component: FrontSensor_P  002 0189
   Serial number: 356001C180EDD220BE9S
   Subsystem 7 - Part No SW: -----------    HW: 480 032 901 19
   Component: PedP_Sensor_D  002 014A
   Serial number: 228001C18A14BCF14DFY
   Subsystem 8 - Part No SW: -----------    HW: 480 032 901 19
   Component: PedP_Sensor_P  002 014A
   Serial number: 229001C18A153C605A45
   Subsystem 9 - Part No SW: -----------    HW: 480 032 901 19
   Component: PedP_Sensor_C  002 014A
   Serial number: 230001C18F5E697029FN
   Subsystem 10 - Part No SW: -----------    HW: 480 002 101 19
   Serial number: I0M0000000038CE0D6BL
   Subsystem 11 - Part No SW: -----------    HW: 480 002 101 19
   Serial number: I0N0000000025CE0D6BI
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 760 953 507 B    HW: 760 953 507 B
   Component: Lenks.Modul   H03 0006
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 1C6AB8C7C65C049A739-8148
   Part No SW: 762 920 790 A    HW: 762 920 790 A
   Component: FBenRDW       H12 0208
   Coding: A5A731C26F94260001A86322B0804808E4000080
   Shop #: WSC 31414 032 00001
   ROD: EV_DashBoardAU65X_VW53.rod
   Control head driving profile:
   Subsystem 1 - Part No SW: 760 927 531 F    HW: 760 927 531 F
   Component: E881 BedieFPA  001 0460
   Serial number: 000000091171SAM00152
   Part No SW: 4N2 907 468 AB    HW: 4N2 907 468 AB
   Component: Gateway       H14 0037
   Revision: 8P030005    Serial number: 0588P523319220 Dataset Number: V03935286DQ 0001
   Coding: 0301000300008E407F07000000DB0532581E000700000000037D078E10000100
   GVL: 71503C000804020000BC88000002C80010080000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003150
   ROD: EV_CGateCONTIAU491_003_VW53.rod
   Subsystem 1 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180002643330089027
   Coding: 2FFFFF
   Serial number: 4506540505
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000422047006
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343A70674ECCACDA5B9-8160
   Serial number: 00000367136315 Dataset Number: V03935279EW 0001
   Coding: 01389A400000A48188000101210100008900000707008F8F00000000015000
   Valve block 1 in front seat driver side:
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ80010601194025807D
   Coding: BF2F00
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0189
   Serial number: YE007SAQ2618B Dataset Number: V03935284AJ 0001
   Coding: 003F9A00DE01040000013082
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 3E2E524F7080768ABDD-816A
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0505
   Dataset Number: V03935295QY 0001
   Coding: B4110101000100
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 3236767FB4D8A2EA495-8166
   Part No SW: 4N0 907 064 BP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0145
   Dataset Number: V03935297TG 0001
   Coding: 01352C006FB0004873A9A0047C00080203024000145704502F0400000508803F001F31D4010001
   ASAM Dataset: EV_BCM2CONTIAU651 008007
   ROD: EV_BCM2CONTIAU651_008_VW53.rod
   VCID: 7EAE924F3000B68AFDD-812A
   ID - sensor:
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY190151FGR
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000334753
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11498290
   Rear spoiler control module:
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0189
   Serial number: YE007SAQ30069 Dataset Number: V03935284AD 0001
   Coding: 003F9A00DE01040000013080
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
Address 5F: Information Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb
   Part No SW: 760 035 063 D    HW: 760 035 063
   Component: MU-H-LND-EU   046 2869
   Dataset Number: V03935289GN 0001
   Coding: 02350601FF00000043110101C08808301F0206E601A00400BF
   ROD: EV_MUHigGen2pALPI_VW53.rod
   VCID: 1276D6FF149842EA295-8146
   Subsystem 1 - Part No SW: 762 919 618     HW: 762 919 618
   Component: ABT_Prem_R  H40 5211
   Serial number: VWZ6ZGW0520097
   Subsystem 2 - Part No: V03 959 816 TC
   Component: MIB2P_EU_Q324  0750
   Compact disc data bank:
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 762 927 341     HW: 762 927 341
   Component: VW536LLB  H06 0109
   Serial number: 2019011600000007
   Media socket:
   Subsystem 5 - Part No SW: 5G0 035 953 D    HW: 0
H08 0014
   Component: RVC Compact   H15 0250
   Dataset Number: V03935282PH 0001
   Coding: 0135060122002011000040
   ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
   VCID: 3338737B4BC2ABE2423-8166
   Part No SW: 4M0 959 107 E    HW: 4M0 959 107 C
   Component: HDSG-Modul    H14 0170
   Revision: --------    Serial number: A2-C756-6240-5 Dataset Number: V03935273HC 0001
   Coding: 1778
   VCID: 353C4D6345B6B5D26C7-8160
   Part No SW: 762 713 041 B    HW: 4M2 713 041 G
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19012550701980
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 1174D9F3119EB9F210F-8144
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* 4N0-907-107-V2.clb
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Dataset Number: V03935296NT 0001
   Coding: 04C2860000000000000806000090042C18075300000000000000000000000000000000000000000000000000000000000000000000000000000040000000000000001004000000700000004000000000008040000020
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F506F4B370ABF82F6B-812A
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H05 0006
   Dataset Number: V03935263ES 0001
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0188
   Serial number: YE007RLL0701D Dataset Number: V03935284AG 0001
   Coding: 003E92000000040000013080
   VCID: 40D22CB70A74007ACF1-8114
   Component: TSG HBFS003 0188
   Serial number: YE007RLL07019 Dataset Number: V03935284AE 0001
   Part No SW: 4K0 907 594 AA    HW: 4K0 907 594
   Dataset Number: V03935282CP 0001
   Coding: 588040753602
   VCID: 73B8B37B0B42EBE2823-8126
   Part No SW: 7P5 941 591 BH    HW: 7P5 941 591 B
   Component: LED1L         H07 0009
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
   VCID: 0358E3BB5BE2DB62923-8156
   Component: LED1R         H07 0009
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 A    HW: 4N0 035 502 A
   Component: WLC Front     H10 0061
   Coding: 400000
   VCID: 2216863FE438326AB95-8176
End----(Elapsed Time: 02:22, VBatt start/end: 11.5V/11.6V. VIgn 11.7V)-----
-------------------------------1 Fault Found-------------------------------
That is an HVAC code in central electrics, odd? Anyway, fuel filler motor failure is rife across the VAG range from Polo to Q8, you need
Filler pot 760 809 857 E £108
Motor 8V0 862 159 £32.40
Both plus VAT.
The painted door unclips and is transferred to the new unit.
There's no longer a separate HVAC module; functionality has has been integrated into BCM1.
However, I see no faults at all regarding the fuel tank system, and I'd expect the filler stuff to be controlled by BCM2...?
I hadn't noticed that and we look after a couple of Toerag 3's now.
Express Service
C?ID=581842
Both plus VAT.
Thanks for this information, it has solved the issue!
Sadly, we don't get them on this side of the pond.
