Coding the A5-Frt Sens. Drv. Assist
Tricky
C?ID=198156
Hi, having issues coding the A5-Frt Sens. Drv. Assist module on a late KJ Seat. The module doesn't appear to have SFD, and i have tried the Workshop and Importer as 123..... or taking the one from the controller and trying to code with that. Each time i get the following message: Coding Rejected, Error 00:Unknown (0x00). I am trying to change the lane departure default coding from Activated to Last Setting. Any ideas appreciated, thanks.
Chassis Type: KJ-SE27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 55 5F 75 A5 D6 D7
VIN: VSSZZZKJ1RR132764   Mileage: 4298km-2670miles
Address 01: Engine (J623-DUSA)       Labels: None
   Part No SW: 05C 906 012 G    HW: 05C 907 309 F
   Component: R3 1.0l TFS   H80 3592
   Revision: KKH80000    CVN: 7D8B08EC
   Coding: 0119003623440D0800000000000000000000000000000000
   Shop #: WSC 00049 000 00000
   ASAM Dataset: EV_ECM10TFS01105C906012G 001003
   ROD: EV_ECM10TFS01105C906012B_SK27.rod
   VCID: 21183DF9C14CC9A2A04-8074 SFD+SFD2
   VINID: 9A38EAAAA6DA0628810C21C610B161E68B
Address 03: ABS Brakes (J104)       Labels:. 2Q0-614-517.clb
   Part No SW: 2Q0 614 517 CP    HW: 2Q0 614 517 CB
   Component: ESC_Base_vFGS H20 0120
   Serial number: BPA085230224015 Dataset Number: V03935423LV 0002
   Coding: 091B0152B9FEB3
   ASAM Dataset: EV_BrakeBoschMQBA0UNECE 012016
   ROD: EV_BrakeBoschMQBA0UNECE_VW27.rod
   VCID: 7EA226851072565AFD6-802A SFD+SFD2
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 6F0 907 044 M    HW: 6F0 907 044 M
   Component: Climatronic   H05 0812
   Coding: 010100000800010011000800024001150010000000000000000000000000
   Shop #: WSC 00049 770 00125
   ASAM Dataset: EV_ACClimaBHBMQBA0 004028
   ROD: EV_ACClimaBHBMQBA0.rod
   VCID: 3138CDB991AC7922304-8064
   Part No SW: 2Q0 937 090 F    HW: 2Q0 937 090 F
   Component: BCM A0 Std+   H15 0982
   Serial number: 02102406203670 Dataset Number: V03935434TY 0001
   ASAM Dataset: EV_BCMA0 209001
   ROD: EV_BCMA0_209_VW27.rod
   VCID: 3530F9A965C455026CC-8060 SFD+SFD2
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: SAY24M02D29H02M41S31
   Coding: 00194D
   Driver door control module:
   Subsystem 2 - Part No SW: 2Q2 959 405 G    HW: 2Q2 959 163 F
   Component: FHSG_DRV  003 0004
   Serial number: 00000000000075129702
   Coding: 1F0007
   Front passenger door control module:
   Subsystem 3 - Part No SW: 2Q2 959 406 G    HW: 2Q2 959 164 F
   Component: FHSG_PSG  003 0004
   Serial number: 00000000000075080767
   Coding: 05000F
   Subsystem 4 - Part No SW: 5Q0 951 177 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA  006 0501
   Serial number: 0000000000000Q3G6X0U
   Subsystem 5 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000004241650
   Subsystem 6 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000079240710
   Coding: 1D0000
   Subsystem 7 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000079327287
   Coding: 050000
   Part No SW: 5QA 919 283 G    HW: 5QA 919 283
   Component: PDC 4 Kanal   H12 0083
   Serial number: 000150059624051 Dataset Number: V03935365XW 0007
   Coding: 0601050001
   Shop #: WSC 00049 770 00238
   ASAM Dataset: EV_EPHVA14AU3700000 010055
   ROD: EV_EPHVA14AU3700000_010_AU37.rod
   VCID: 4EC2B645E05206DA4D6-801A
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H03 0534
   Dataset Number: V03935360SC 0016
   Coding: 280160C148FF8728749C812560508700000000000000000024
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_VW37.rod
   VCID: 372CF3A17FC8A7127E0-8062 SFD+SFD2
   Part No SW: 5QF 959 655 BN    HW: 5QF 959 655 BN
   Component: Airbag VW23   003 0117
   Revision: --------    Serial number: 003C0T0PAN1KRL Dataset Number: V03935424KS 0001
   Coding: 88CCCCC000000000585400CF008C40540065
   ASAM Dataset: EV_AirbaVW23TS6VW48X 001010
   ROD: EV_AirbaVW23TS6VW48X.rod
   VCID: 231437F1DB50DBB2B28-8076 SFD+SFD2
   Subsystem 1 - Part No SW: -----------    HW: 654 002 202 24
   Component: SideSensor_Df  010 0887
   Serial number: 35700008D389447B266A
   Subsystem 2 - Part No SW: -----------    HW: 654 002 002 24
   Component: SideSensor_Pf  010 0887
   Serial number: 3580000FE4893B54507F
   Subsystem 3 - Part No SW: -----------    HW: 654 000 112 23
   Component: SideSensor_Dr  040 0148
   Serial number: 3510050B2C74BF8F224L
   Subsystem 4 - Part No SW: -----------    HW: 654 002 911 23
   Component: SideSensor_Pr  040 0148
   Serial number: 35200506AC87CED7060O
   Subsystem 5 - Part No SW: -----------    HW: 654 002 101 24
   Component: FrontSensor_D  0A0 0189
   Serial number: 35500506F25DE9CDC44+
   Part No SW: 6F0 920 320 E    HW: 6F0 920 320 E
   Component: KOMBI         614 7850
   Coding: 242401046D840600018862431000000080600124
   ASAM Dataset: EV_DashBoardVDDMQBA0 003060
   ROD: EV_DashBoardVDDMQBA0_003_AU27.rod
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: CU5SIB060324109 Dataset Number: V03935361JJ 0015
   Coding: 0000808D0F00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
   GVL: 3D00000000004080900000004800000000000000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 70BE08BD5A26302A7FA-8024 SFD+SFD2
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H03 2012
   Serial number: 10486F93
   Subsystem 3 - Part No SW: 5FA 919 719 AE    HW: 5FA 919 719 AE
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440059053241178
   Subsystem 4 - Part No SW: 6F0 959 542 A    HW: 6F0 959 542 A
   Component: KLR            089 0023
   Serial number: 3136195AA24049145502
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 AM    HW: 2Q2 909 144 AD
   Component: TRW_G4L_MQBA0 623 6064
   Serial number: 01O2G0GGCB4R068 Dataset Number: V03935424QW 0001
   Coding: 010000000100000101010201010001000000010101
   ASAM Dataset: EV_SteerAssisTRWG4LClass 016018
   ROD: EV_SteerAssisTRWG4LClass.rod
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 2G0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       H03 0420
   Revision: --------    Serial number: -------------- Dataset Number: V03935378GN 0005
   Coding: 06CE000009600200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   ROD: EV_HeadlRegulAUDIMXBAU64X_VW27.rod
   VCID: 290825D9B97C01E2F84-807C
   Part No SW: 575 035 816     HW: 575 035 816
   Component: MU-O-ND-EU    H31 0442
   Serial number: SEZAZ2C0431048  Dataset Number: V03935434N  0001
   Coding: 42700008000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 002001
   ROD: EV_MUOIMQB_002_VW48.rod
   VCID: 58EE501DD296486A97A-800C SFD+SFD2
   Subsystem 1 - Part No SW: 5FJ 919 606 A    HW: 5FJ 919 606 A
   Component: ABT_High-2     381 9313
   Serial number: SEZ6ZHC0650896
   Subsystem 2 - Part No: V03 959 820 GG
   Component: EUR 2024       0095
   Part No SW: 2GA 035 284 B    HW: 2GA 035 284
   Component: OCUClas2023_H H07 0523
   Serial number: 0000000402VIKEA Dataset Number: V03935434WB 0001
   Coding: 04010501000100210000010012002607111112111012100110
   ASAM Dataset: EV_OCUClass2023 001059
   ROD: EV_OCUClass2023_SE27.rod
   VCID: 323AC2B594AA423A49E-8066 SFD+SFD2
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659911240580 Dataset Number: V03935361LW 0016
   Coding: 00030908214E4020089E08001020002000418088600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
   VCID: 3928F59949DCB162884-806C
   Part No SW: 992 941 571 AG    HW: 992 941 571 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 678C63E16FE8F7922E0-8032
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
End----(Elapsed Time: 01:14, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
---------------------------No fault code found.----------------------------
The module itself does not, but the Gateway does and could be blocking things.
Silly question: Hood/bonnet open?
AINils
Germany (AIB)
C?ID=56975
   Coding: 00194D
   Coding: 1F0007
   Coding: 05000F
   Coding: 1D0000
   Coding: 050000
   Coding: 0601050001
   Generator:
In MQB Classic cars with following gateway where a double Index Bx is used, are UNECE cars
You can also easy see if "Component" is named: GW 2023 CLA
These Gateway mean it's a UNECE car, where Gateway blocks the communication.
These Gateway are the same as in MQBw/MQB2020 cars, but only the low variant with different software. Also Plug is different, to the old 3Q0 907 530 Ax, but same as in MQBw cars ;-)
That sounds like a hint for a work-around....?
AINils
Germany (AIB)
C?ID=56975
You got me ..... ;-) Solution in MQB Classic is to create a small adapter between these plugs and change gateway for coding. But this just solve the diagnostic filter "issue", not the UNECE relevant data which are monitored
Tricky
C?ID=198156
Thanks for the response Uwe, yes, I had the bonnet open and a charger connected.
  • Informative
Tricky
C?ID=198156
Thanks AINils, I think I follow. Does that mean if the ‘special’ connector is used we bypass the gateway altogether, or maybe even use a different bus? Either way it sounds a little involved for this change, which I guess is exactly what the factory were looking to achieve.
Cuzoe
C?ID=279487
I don't know about the 15xx software for the 2Q0 camera but my understanding is that software 1423 is the latest without UNECE "issues" and that 1602 is 1423 without UNECE.
Not a VCDS function but a "downgrade" to 1423 would avoid the UNECE "issues" on the camera, though you would still need the special adapter.
That said... maybe none of this is worth the effort for the change you're trying to make. And if your camera has active SWAPs (Sign Recognition or the like) definitely do NOT down/side grade the firmware.
AINils
Germany (AIB)
C?ID=56975
Unpack frf to ODX and check for AES Key.
Non UNECE use 1024
UNECE use 3072
So this is how you can see which SOP they are
UNECE "write protection" is just handled in gateway in MQB classic, so bypass Gateway will let you write changes. But aware all the approval-relevant things will swap to "illegal"
Tricky
C?ID=198156
Thanks Cuzoe and AINils, as you say, may not be worth it for a possible downgrade and the possible side effects. Would be cool though if VCDS could crack the SFD blocker (if it’s even possible) as it makes these later cars pretty much locked down from a coding point of view.
Good though we have added to the knowledge base for others who may get the same issue.
Thanks again all
