HID Headlamp Headache - Need Advice
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
Broken driver's headlamp lens -> water -> corrosion -> new assembly -> new modules -> new bulbs -> one problem:
the left low bulb continues to throw short to plus error, and will not come on.
What I think I know:
- pin 6 is not getting power
UPDATE: the wire at terminal 6 DOES carry power at when beams switched on. (pulled wire from D connector and tested with dmm)
Why I think I know this:
   Address 09: Cent. Elect.  (5Q0 937 087 AA)
14:40:02
  IDE02515   Low beam |Connector number,Connector terminal number,Duty cycle,Signal state,Diagnosis|Plug C,5,100.00,active,Open circuit or short to positive|Connector B,1,100.00,active,normal|
  IDE02588-IDE01715   Terminal signals and start release-Status terminal S active
  IDE02588-IDE01716   Terminal signals and start release-Terminal 50 status OFF
  IDE02588-IDE06027   Terminal signals and start release-Terminal S status via CAN active
  IDE08949-MAS07873   Operating current: light driver-Conn. pin 6 220 mA
  IDE08949-MAS07874   Operating current: light driver-Conn. pin 7 5550 mA
  MAS00043-IDE00019   Terminal 30 power supply-Voltage terminal 30 10.65 V
  MAS00043-IDE05967   Terminal 30 power supply-Voltage terminal 30 left 10.70 V
  MAS00043-IDE05968   Terminal 30 power supply-Voltage terminal 30 right 10.55 V
Saturday,26,April,2025,13:07:34:16415
VCDS Version: 25.3.1.1 (x64)  HEX-NET2 CB: 0.4671.5
Data version: 20250415 DS365.0
If this is the case, what do I do? My understanding is that this draws from terminal c5 on j519 but I don't want to just swap that module out like I've seen many people do with similar problems.
If this may not be the case, can you help me think through additional testing - I'm willing to repeat any other diagnosis I've done, I'm all out of ideas, patience, and sanity.
VIN: 3VW547AU6HM023082   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
VIN: 3VW547AU6HM023082   Mileage: 88063km-54719miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 9C0 BB0 1    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 76BAE45B
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00200
   ASAM Dataset: EV_ECM20TFS0205G09C0BB01 001003
   ROD: EV_ECM20TFS0205G09C0BB01.rod
   VCID: 3D2C573DEDF5AF12A4C-8068
   VINID: 0E69C5107465198740083008082DCEAB21
Readiness: 1110 1101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52386000000789
   Coding: 01FA6BA15422096F4077020841C56880D62A90024082163600630001400903
   Shop #: WSC 01369 210 40505
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035.rod
   VCID: 75BC8F1D95453752ACC-8020
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0413980629 Dataset Number: V03935230CZ 0006
   Coding: 032C0C
   Shop #: WSC 12345 123 61029
   ROD: EV_KessyHellaMQBAB_002_VW37.rod
   VCID: 3B285925F3E1A1229A8-806E
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 00020004200100000000000000000002
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 48C236E9B237FABA07A-801C
262914 - Refrigerant Pressure
          B10AB F0 [00001001] - Too Low
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:15
                    Outside temperature: 24.5 ∞C
                    Engine speed: 0 /min
                    Temperature downstream of evaporator: 35.7 ∞C
                    System run time-Terminal 15 on: 255 s
          B10CD 00 [00001001] - -
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:13
                    Voltage terminal 30: 10.9 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865822081600VV Dataset Number: V03935240CJ 0001
   Coding: 00010A464041A04169E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00074
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AA69C21BC5B582AC1E-802E
   Component: WWS    150620  043 0551
   Serial number:         150723130518
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [00001001] - Open or Short to Plus
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:15
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beam: operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 11.3 V
   Serial number: 003GCR05S9DR Dataset Number: V03935221QH 0001
   Shop #: WSC 00066 790 07027
   VCID: 47C035D5BF29F5C20E0-8012
   Serial number: IBH000000000005UPYIT
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 408 16
   Serial number: 35700000000C8398CD1
   Subsystem 3 - Part No SW: -----------    HW: 480 002 408 16
   Serial number: 35800000000AB1357D1O
   Subsystem 4 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3510002B32076361535K
   Subsystem 5 - Part No SW: -----------    HW: 480 400 608 16
   Serial number: 3520002AB21FBE83A32G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 708 16
   Serial number: 3550002AB215E1E52071
   Subsystem 7 - Part No SW: -----------    HW: 480 402 708 16
   Serial number: 3560002AF215E1E182AD
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160908500617
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045AE2D9CE9F1EDAAB2-8050
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD09122980CF0502087A001000000000000000
   VCID: 2D0C677D3D953F9214C-8078
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:13
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 01081610801068 Dataset Number: V03935242HR 0001
   Coding: 0101000830085900FB00002B080F00000001050000000000000000000000
   GVL: 01503C5000000600400C10008000480000000000000000000000000000000000
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CAA9A39B66F661AD32-8028
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001933710076394
   Coding: 30FFFF
   Revision: 00000000    Serial number: 16000136713010
   Coding: 5500000000000000
   Shop #: WSC 00066 790 00323
   VCID: 343A7219DEBF6E5A5B2-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00028.07.16 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 300916060502MG Dataset Number: V03935249RC 0001
   Coding: 003E13200000020000000000
   VCID: 43D821C58B11D9E2D28-8016
   Serial number: 00000000000013948081
   Coding: 011000
65799 - Door Warning / Entry Lighting
          B1775 01 [00001001] - Electrical Failure
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:13
   Dataset Number: V03935242JU 0001
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A265C21FCDB982A81E-806E
   Serial number: 300916060503SR Dataset Number: V03935249RE 0001
   VCID: 42D624C1940BD0EAD9E-8016
   Serial number: 00000000000013938764
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021801010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D22EC99A07C2FACFA-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
5275220 - Headlight
          C107E 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.26
                    Time: 16:05:16
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Serial number:                Dataset Number: V03935247DB 0001
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:58
                    Voltage terminal 30: 11.5 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 140 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
          U1111 00 [00001001] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 149
                    Mileage: 88063 km
                    Date: 2025.04.24
                    Time: 20:12:18
                    BAP-BAP_Function_ID: 02
Address 75: Telematics (J949)       Labels:. 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   ROD: EV_OCULowMQB_VW37.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160812201427
   VCID: 6B88A965C301F1A24A8-803E
End----(Elapsed Time: 01:56, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
------------------------------8 Faults Found-------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Verify wiring is ok. When you say NEW do you really mean NEW or NEW"used"?
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
The assembly (and male pins from it) are new, Hella assembly. AFS and DRL are new (used). The ballast module is new, although the problem presented with prior ballast, in both the old broken assembly and the new Hella assembly. That's what led me to believe it was a problem on the car side. HOWEVER, I'm willing to re-test all of my assumptions.
downtime
Finland
C?ID=280813
Are the modules from which car originally? If the dataset is incorrect it will flag short to plus error (as one symptom)
  • Informative
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
Purportedly from similar trim of MK7 GTI, but I know that these things don't always line up even if the part number is the same.
My understanding is that if the part is correct, it can be recoded - however, I could see that if it can't be communicated with how could you recode it lol
I don't see the parameter information for any of the slave modules. I figure next step would be wrangle the bad headlight onto the right-side harness* and do advanced ID, which would allow me to compare at least the data for j745.
advanced ID of the functional right headlight:
Monday,28,April,2025,08:44:35:16415
VCDS Version: Release 25.3.1 (x64)
Control Module Part Number:
  Component and/or Version:
           Software Coding:
            Work Shop Code:
                      VCID: 55ED0257AC414933C9-FFFE
Advanced Identification/FAZIT
     Identification: SME-RBG
     Revision: --------
     Date: 04.08.16
     Manufacturer number: 0007
     Test stand number: 3411
Flash Status
     Programming Attempts(application): 0/0
     Successful Attempts(application): 0/0
     Programming Attempts(data): 2
     Successful Attempts(data): 2
     Programming Status: 00000000
     Flash Date: 00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK)
     Flash Tool Code(data): 50316 790 01383
Misc.
     Hardware number: 7P6 907 357 A
     Workshop System Name: J745
     Workshop ID (Adaptation): 00000 000 00000
     Workshop ID (Coding): 50316 790 01383
     Equipment/PR Code: 00000000000000000000E845
     Dataset Version: 0021
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: 001120
Car Info
     Chassis Number: -----------------
     Engine code: ----
VCDS Info:
     Labels: 7P6-907-357.clb
* You may ask why my bumper isn't completely dropped and I cannot freely remove the right headlight to easily attach the left to that harness. This is because I have no foresight and did not understand the lengths I'd need to go to in switching a broken headlamp out at a cost less than the $1300+ for factory assembly. Joke is on me, I'm certainly approaching that sum.
Dr Sheldon
Windsor UK
C?ID=334979
Surprising how it adds up ??
Suprising why a plastic Box with a lens and a bulb should be priced at $1300
Production cost of that ??? $100 ?? more ??
downtime
Finland
C?ID=280813
           Software Coding:
            Work Shop Code:
     Revision: --------
     Date: 04.08.16
Flash Status
Misc.
Car Info
     Engine code: ----
VCDS Info:
Yes, the slave modules are flashed via service42 and not written via normal write dataset function. That’s why no dataset info is shown.
But if they’re from similar car, should be just fine and most probably you really have a bad connection somewhere
  • Informative
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
Interesting thing though, that code without dataset info was from the FUNCTIONAL right headlight. Even more interesting, I plugged the new headlamp into the right hand side loom, then ran advanced ID. This time the dataset info showed up. This is the kind of thing that has been driving me nuts.
Monday,28,April,2025,12:12:34:16415
Control Module Part Number: 7P6 907 357 D
  Component and/or Version: AFS-ECU       H07 0090
           Software Coding: 021801010B000400
            Work Shop Code: WSC 01383
     Revision: --------
     Date: 04.08.16
Flash Status
Misc.
Car Info
     Engine code: ----
VCDS Info:
downtime
Finland
C?ID=280813
     Revision: --------
     Date: 04.08.16
Flash Status
Misc.
Car Info
     Engine code: ----
VCDS Info:
Sorry I don't understand what you are trying to say? I don' see any difference in your advanced IDs this vs previous one. Both show 7P6 module dataset number : V03935205NP
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
You're right, they're the same. I think I may have understated how nuts I've been.
Anyway, I've done some more stuff and below is current state. I appreciate everyone's patience.
I had removed wires 6 (dipped power, yellow), 9 (turn signal, black+green), 11 (xenon shutter, yellow/white?) from the car side connector to test current (which is how I confirmed I had rail current at wire 6). I re-inserted the wires yesterday, an exercise in frustration.
The fresh auto scan, condensed for clarity:
Tuesday,29,April,2025,12:12:13:16415
VIN: 3VW547AU6HM023082   Mileage: 88072km-54725miles
                    Reset counter: 150
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 18:15:41
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Low beam: operated
                    Voltage: 11.1 V
                    Outside temperature: 26.5 ∞C
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [00001001] - Open or Short to Plus
                    Reset counter: 151
                    Mileage: 88064 km
                    Date: 2025.04.29
                    Time: 08:23:23
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Low beam: Not operated
                    last_wakeup: Pin A31 Lock/Unlock Taster: Tankklappenr¸ckmeldung
                    Voltage: 13.9 V
                    Outside temperature: 19.0 ∞C
   Coding: 2E0000
   Coding: 2E0000
9574144 - Bulb for Low Beam Headlamp Left
          B1217 00 [00001000] - -
                    Reset counter: 191
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 18:15:42
To me, that sure looks like I didn't get wire 9 seated correctly, which is honestly refreshing because it's the clearest cause-effect relationship I've had with the car recently.
My next steps: check the wiring in that car-side connector again. Any tips on inserting those back in? The consenus I've seen is 'grab as many connectors and leads from scrap cars as possible so you can just solder wires together'. Which I guess is cheaper than the $90 insertion tool from TE.
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
Hey, I checked that wire, got it seated correctly, and the blinker fault disappeared. So this is where it stands now: no short to plus, no central electrics fault. Just 'Bulb for Low Beam Headlamp Left'. This feels closer than I've been!
Address 09: Cent. Elect.  (J519)	Labels: 5Q0-937-08X-MV1.clb
	Revision: --------
	ROD: EV_BodyContrModul1UDSBosc_015.rod
	VCID: 7AB751EB3DF2D11954D57E-802F
	Subsystem 1 - 	Part No SW: 5G1-955-119-A	Labels: 5Qx-955-119-V1.clb
	Component: WWS    150620043 0551
	Serial Number:         150723130518
No fault codes found.
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Revision: --------
	VCID: 40C3E3031BAE4BC95A91FC-8015
	Subsystem 1 - 	Part No SW: 5N0-941-329	Labels: 3D0-941-329.clb
	Coding: 2E0000
	B1217 00 [009] - -
		Reset Counter: 151
		Mileage: 88063 km
		Date: 2025.04.28
		Time: 18:15:42
downtime
Finland
C?ID=280813
If those are xenons, maybe the bulb itself is going bad? Those are D1S bulbs which have integrated ballast so could be very well that the ballast has gone bad and it's dead. One thing you can try is to swap the bulbs from working to non working and see if it clears the error
yinz_ian
Pittsburgh, PA, USA
C?ID=545317
I am following up on rule 5, as much as it pains me.
5 Conduct a quality Check of your work and verify you fixed it!
Always follow up reporting back to the Forum to help the next guy.
I changed the bulb (for the fifth time overall I believe), no change.
I went to change the ballast for a second time, with an OEM from Hella.
And I thought, for the seventh or eighth time, why the headlamp assembly wouldn't have both wires for the ballast. . . .
I reached my hand in the hole and tugged gently on some wires within, and pulled out the second (white fitting) connector for the ballast.
I fitted it, attached the headlamp, scanned, cleared codes, scanned. . . clean. The light works. The light probably would have worked the very first time.
Thursday,01,May,2025,13:02:47:16415
Readiness: 1010 0101
   Coding: 032C0C
   Revision: 00001K03
                    Reset counter: 150
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 16:48:00
                    Outside temperature: 31.0 °C
                    Temperature downstream of evaporator: 28.0 °C
                    System run time-Terminal 15 on: 152 s
          B10CD 00 [00001000] - -
                    Reset counter: 190
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 18:11:29
                    Voltage terminal 30: 10.8 V
   Coding: 30305A
   Coding: 0400
16776973 - Databus
                    Reset counter: 150
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 16:48:00
   Generator:
   Coding: 30FFFF
   Coding: 0001
   Coding: 011000
                    Fault Frequency: 13
                    Reset counter: 151
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 16:48:00
65639 - Motor for Window Regulator
          B1487 29 [00001000] - Signal Implausible
                    Reset counter: 191
                    Mileage: 88072 km
                    Date: 2025.04.29
                    Time: 08:46:38
   Coding: 8102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW0197J
                    Reset counter: 150
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 16:48:38
                    Voltage terminal 30: 11.7 V
                    SDARS_tuner_status_2-Antenna current: 141 mA
                    Reset counter: 150
                    Mileage: 88063 km
                    Date: 2025.04.28
                    Time: 16:48:04
   Dataset Number: V03935236TB 0001
   Coding: 02730002C2821A017F1E06000000
Thank you for humoring me. My next project is fixing the A/C, so I think you all get a break from me for a bit.
