2014 Audi A6 allroad 3.0 bitdi with glow plug spiral flickering and MOT failure for soot
Yves
Belgium
Hi,
My cas recently developped an issue with the flickering glow plug spiral coming up. I read the ECU (see below). It points to a turbo control valve/solenoid.
Could these 2 problems (solenoid and DPF failed test) be interrelated?
Thursday,24,April,2025,20:44:31:20499
VCDS Version: 25.3.0.3 (x64)  HEX-V2 CB: 0.4660.4
Data version: 20250301 DS365.0
VIN: WAUZZZ4GXEN168390   License Plate: 11111
Mileage: 227777km-141534mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 34 3B 42 44 46 47 52 53
          55 56 5F 62 69 6D 72 8F 90 A9 C0
VIN: WAUZZZ4GXEN168390   Mileage: 227777km-141534miles
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 G    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0003
   Revision: 57H25---    CVN: 158EDADA
   Coding: 722A403225360B020000
   Shop #: WSC 29138 004 1048576
   ASAM Dataset: EV_ECM30BTD0114G0907589G 001003
   ROD: EV_ECM30BTD0114G0907589G.rod
   VCID: 3828D7DB12D68AFA770-806C
   VINID: 9D196AAAA117A157811880C900BB66489E
11859 - Boost Pressure Control Valve/Solenoid (Bank 2)
          P004A 00 [00101100] - Open Circuit
                    Mileage: 227752 km
                    Date: 2025.04.24
                    Time: 20:03:58
                    Engine speed: 2284.50 /min
                    Vehicle speed: 95 km/h
                    Coolant temperature: 92  C
                    Intake air temperature: 20  C
                    Voltage terminal 30: 14.440 V
                    Actuator for low press turbocharger: activation: 94.99 %
                    Bypass valve f high press turboch turbine inlet: target value: 101.00 %
                    Bypass valve f high press turboch turbine inlet: actual value: 99.34 %
                    Bypass valve f high press turboch turbine inlet: offset closed: 1.39 %
                    Bypass valve for high press turboch turbine inlet: activation: 94.99 %
                    Bypass valve for high press turboch turbine inlet: uncond volt: 4231.6 mV
                    Charge air pressure: actual value: 1112.0 hPa
4481 - Cruise Control Switch (E45)
          P0568 00 [00100000] - Implausible Signal
                    Mileage: 227767 km
                    Date: 2025.04.24
                    Time: 20:27:46
                    Engine speed: 713.50 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 90  C
                    Intake air temperature: 19  C
                    Voltage terminal 30: 14.280 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 128
                    Cruise Control System (CCS): status-Bits 0-7: 13
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4812 - Engine Control Module Incorrectly Coded
          P1612 00 [00101111] - -
                    Engine speed: 0.00 /min
                    Coolant temperature: -40  C
                    Intake air temperature: -40  C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    selected gear-Bits 0-7: 0
   Part No SW: 4G0 997 749 A    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H18 1001
   Revision: --H18---    CVN: BB008EF0
   VCID: 392ED2DF29DC93F288E-806C
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 49A7DF0592E5FBA0FB00
   Shop #: WSC 27207 004 1048576
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2CCDD32CDA98EA814-806E
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0551
   Coding: 05A92F06000000000000
   Shop #: WSC 02391 785 00200
   VCID: 7CA00BCB66EE66DAD38-8028
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AK    HW: 4G0 820 043 AK
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 19051400111373
   Coding: 3602000829
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 6888479B02F6DA7A270-803C
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001881634
   Coding: 2600201040749FE0898100C300001D0C0F9C67082E090201000004606101
   VCID: 6E8431832092044A6DC-803A
   Component: WWS57X 140513  H37 0080
   Serial number:         140515060643
   Coding: 0045F7
   Serial number: 63432408
   Coding: 02006C
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 21 05 2014  00000080
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 3988CC27000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031414700783
   Coding: 89C30C
   Shop #: WSC 57281 001 1048576
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004_AU57.rod
   VCID: 71BE2AFF312C1BB270E-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00J3DJ6 Dataset Number: 4G0909602H  0002
   Coding: 3032343631334E303435554A304C34473053
   VCID: 3634D9E318C27C8A65C-8062
   Serial number: 3575HRB40612L7IMDPDZ
   Serial number: 3585HRB405V2LFGM48H6
   Serial number: 3515JRB401452K1SI0O6
   Serial number: 3525JRB401052JN4PP5D
   Serial number: 3554VRB401I5109OA91$
   Serial number: 3564VRB401G5109OP8LT
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140523000126
   Coding: 000035
   VCID: 3038EFFBFA2652BA3F0-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G9 920 950 L    HW: 4G9 920 950 L
   Component: TDieRdw   Nv  H58 0622
   Revision: 29131237    Serial number: 658210514596022
   Coding: 13A620081B410008050600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001403282 Dataset Number: 4G0909515H  0067
   Coding: 00CD077D00
   GVL: FDA3E900FE65600D3000
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BC25F3342A20AA894-8026
   Serial number: 6914783403
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140318000000000002A4
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02018264747464545425363E00
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Dataset Number: 4G0909553F  0034
   Coding: 008001
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_AU57.rod
   VCID: 2E04F183E092444A2DC-807A
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA8207C88$ Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0507
   Coding: 011C17005C00628002080002
   VCID: 47CAA4276FA8F5020EA-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0003551508 Dataset Number: 4G0909852K  0030
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323CE5F3F4AA60AA494-8066
   Revision: 00002001    Serial number: 0336785080
   Coding: 01000E3820B93095832009042A010F470000000000000000000000000000
   Subsystem 1 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO29453579
   Coding: 901F00
   Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO29451342
   Coding: 801F00
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 10
                    Mileage: 227742 km
                    Date: 2025.04.24
                    Time: 19:51:37
02615 - Fuel Tank Cap; Lock
                    Reset counter: 10
                    Mileage: 227754 km
                    Date: 2025.04.24
                    Time: 20:06:00
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0019962
   VCID: 25160EAFB5E40712DC6-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 02603140027313
   Component: TSG BF        H03 0507
   Coding: 011C17005E00628002080002
   VCID: 46D4A92368A2EC0AF5C-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001071004 Dataset Number: 4G0909522D  0007
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D06F68FED943F52146-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140521-0002-054
   Coding: 11226F101002A300
   ROD: EV_HeadlRegulBasic_AU35.rod
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227EU0E8013732
   Coding: 010003010000000001
   VCID: 261409A3C8E20C0AD5C-8072
   Part No SW: 4G0 035 666 L    HW: 4G0 035 666 H
   Component: H-BN-EU       H52 0814
   Revision: --------    Serial number: 189E30EB002983
   Coding: 080100050003B1ED0590AB3E00000003E00001020200000000
   VCID: 313EEAFFF12C5BB230E-8064
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED004M8V8
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NEM000H0
   Component: CD-Database  5950
                    Reset counter: 10
                    Mileage: 227737 km
                    Date: 2025.04.24
                    Time: 19:37:32
                    Voltage: 11.70 V
   Component: TSG HL        H03 0507
   Coding: 010815004000628002080002
   VCID: 49CEA21F79BC037218E-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H07 0072
   Revision: 5G001001    Serial number: 00000135966549
   Coding: 0109080000000000
   VCID: 71BE2AFF31AC1BB270E-8024
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 140400914 Dataset Number: 4G0909541D  0027
   Coding: 097205C011
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 3536DEEF05C477926C6-8060
   Component: TSG HR        H03 0507
   Dataset Number: 4G0909614C  0001
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EEAFFF1AC5BB230E-8064
   Dataset Number: 4G0909615C  0001
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140505200622
   VCID: 2B02F897D38031620A2-807E
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0007
   Serial number: 140425200330
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS_VW37.rod
   VCID: 241013ABBE5EFE1ACB8-8070
End----------(Elapsed Time: 02:13, VBatt start/end: 12.1V/12.2V)-----------
------------------------------6 Faults Found-------------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Yes and No !!
With that "11859 - Boost Pressure Control Valve/Solenoid (Bank 2)" fault present i would expect the DPF not to regenerate however a DPF DTC should be set if the DPF was in such a condition where it failed an MOT in a European Country - Belgium !
How is that tested in Belgium ? In the Uk it is a Smoke Test with a refractometer type thing.
Moving on !! You have a DTC for Turbo ....Valve - I would fix that first !! It just makes sense to do so ?
  • Agree
Yves
Belgium
They have testing equipment that count the number of particles. 2M where the limit is 1M
Would you happen to have a part number for that valve. By the looks of what I can see on the engine and where the vacuum lines go from the waste gate actuator, there are 2 of them.
NEtech
Denmark
C?ID=56995
Strange Coding, try: 322A403225360B020000
Dr Sheldon
Windsor UK
C?ID=334979
Bank 2 will be on the Left if you stand behind the car looking at it !! On a LHD car it will be the drivers side.
Swap them over - What you got now ?
Yves
Belgium
Yves
Belgium
All, can I assume this fault refers to the electronic unit on the back of the turbo's. It has partnumber 805713-0008 & serialnumber RE400336 printed on it.
I looks as if it is just mounted with 3 bolts to the turbo but not sure if a lot more is involved in setting it up once a new unit would be installed. Thanks for the advice.
PS: I have also looked for other faults but not sure where to begin. Nothing pops up at least.
Yves
Belgium
According to my garage it's the turbo's and they think they need to be replace. The price is just out of this world, so I'm going to sell the car as is. My loss unfortunately.
