- Apr 24, 2025
- 15
- 6
- Fort Worth, TX, USA
- C?ID=374176
I have suddenly developed an issue that is seemingly related to the ECU communications. This is an issue that I haven't previously encountered in 20 years of VW ownership, so I'm not totally sure what to do next.
I drove the car home Wednesday evening without issue, but when I tried to start it Thursday morning, the car would start and then it would appear that the ECU immobilizer turns it off after a second. I can throw a rev into it, so it's also responsive to inputs. The cluster immo light turns off as usual pre-ignition and does not come on after shut down. I've checked a handful of ECU related fuses (11, 32, 34, iirc), but am curious about any other recommendations. I also disconnected the ground cable from the battery for a handful of minutes with no change. I considered clearing all faults and seeing if it made a difference, but I have not had that opportunity yet. I will get to do more diagnostics this afternoon and tomorrow. Since the engine still fires, I'm hoping this is a fuse, relay, or grounding issue.
A lot of the codes I'm not concerned with - this is an autocross/track car, so the airbag codes are because of the racing steering wheel and racing seat in the car. Similarly, 17881 for the EVAP LDP is because the pump is removed. Some of the Cent Lock codes are interesting (to my knowledge, the car has never been crashed...).
I would really, really, really like to resolve this today, as there is an autocross on Sunday that I desperately wanted to participate in.
Thursday,24,April,2025,17:23:05:38139
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: TRUWT28N921032462 License Plate:
Mileage: 138,263 Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine Labels: 06A-906-032-AMU.lbl
Part No: 8N0 906 018 AN
Component: 1.8L R4/5VT G 0004
Coding: 06710
Shop #: WSC 79929
VCID: 7DA7F9C3C4E82152E4C-513C
TRUWT28N921032462 AUZ5Z0B4076141
18056 - Powertrain Data Bus
P1648 - 35-00 - Failure
17881 - EVAP Leak Detection Pump
P1473 - 35-00 - Open Circuit
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-A.lbl
Part No: 8N0 907 379 H
Component: ESP ALLRAD MK60 0101
Coding: 0022544
Shop #: WSC 01236 785 00200
VCID: 41DF4533FD9085B2C04-513C
01312 - Powertrain Data Bus
014 - Defective
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00140
Shop #: WSC 08259
VCID: 2809F8977BEA54FAE7A-2578
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
Address 15: Airbags Labels: 8N0-959-655.lbl
Part No: 8N0 959 655 A
Component: Airbag Front+Seite 5000
Coding: 01103
Shop #: WSC 01236
VCID: 3E253ECF896EFA4ABD6-513C
33-00 - Resistance Too Low
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N1 920 980 A
Component: KOMBI+WEGFAHRS. M73 D04
Coding: 07244
Shop #: WSC 35883
VCID: 34311CE7B722201A5B2-4B00
37-00 - Faulty
49-00 - No Communications
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 C
Component: HALDEX LSC ECC 0010
VCID: 2019E0B713DAACBAAFA-4B00
Address 35: Centr. Locks Labels:. 8Nx-962-267.clb
Part No: 8N8 962 267 A
Component: Central Lock/Alarm D06
Coding: 15976
Shop #: WSC 08213
VCID: 3FDB43CB8E64F342B60-4EEA
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N8 951 177
Component: Innenraumueberw. D09
Coding: 00001
VCID: 7CA1F4C7DFF2285AD32-50AE
01463 - Alarm triggered by Sensor for anti-theft alarm System
35-00 - -
Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00005
Shop #: WSC 01236
VCID: 6597B1A34C7889921CC-5184
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 186 H
Component: concert II NP2 0050
Coding: 00202
VCID: 2517F1A30CF84992DCC-4E20
00878 - Connection to Speaker Front Left
00879 - Connection to Speaker Front Right
00857 - CD Changer Unit (R41)
End----(Elapsed Time: 02:39, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
------------------------------17 Faults Found------------------------------
but I fixed it with the least possible amount of unintended consequences: when we have K-line results, do not re-enable the filter/model selection after the Save/Print/Copy button is pressed, which I think was the behavior pre-"improvement"
