VW POLO 2014 TPMS PROBLEM!
Anchiptuning
Bosnia and Herzegovina
C?ID=566813
Friday,25,April,2025,15:41:55:19566
VCDS Version: 25.3.0.4 (x64)  HEX-NET2 CB: 0.4660.5
Data version: 20250311 DS365.0
VIN: WVWZZZ6RZFY110258   License Plate: POLO JANEZ
Mileage: 159849km-99325mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY110258   Mileage: 159849km-99325miles
Address 01: Engine (J623-CUSA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 997 027 F    HW: 04B 907 445
   Component: R3 1.4l TDI   H07 9436
   Revision: 21003001
   Coding: 01114012432401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM14TDI03004B997027F 004003
   ROD: EV_ECM14TDI03004B906027_004_VW26.rod
   VCID: 2E0E629F9093839A2DB-807A
   VINID: 9E69EAAAA1A2A96A41040085209EA65F52
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379     HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08505914140625
   Coding: 21DD2485892433C00916106E0059842491CC90080007C5090C00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
   VCID: 6C8AA897660F318A43F-8038
0608 - TPMS Display
          C1146 F0 [10001001] - Not Available
                    Reset counter: 14
                    Mileage: 159849 km
                    Date: 2025.04.25
                    Time: 15:39:17
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H02 0105
   Serial number:  1407111B-0078 Dataset Number: 6C0032v____ 0009
   Coding: 201000001000000200
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 1D6CB553ED350802841-8048
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 A    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H06 0047
   Serial number: 009249034770 Dataset Number: 6C0063V____ 0115
   Coding: 000008404253005B4B844080B10703080000590257010000000000000000
   ASAM Dataset: EV_BCMA0 004003
   ROD: EV_MQBA0.rod
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU008071441890989
   Coding: 0400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU004071441855827
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY140974RZA
   Serial number: 00000000000029656870
   Subsystem 5 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU009071441901826
   Coding: 0400A0
   Subsystem 6 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU003071441841807
   Coding: 1400A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag01B 001 0330
   Revision: --------    Serial number: 003LM003HS19 Dataset Number: 6C0003V____ 0249
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 313479E381AD9C62309-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 806 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C51608543709B
   Subsystem 2 - Part No SW: -----------    HW: 410 821 806 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A715739A1734J
   Subsystem 3 - Part No SW: -----------    HW: 442 152 706 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A515397A510A6
   Subsystem 4 - Part No SW: -----------    HW: 442 150 907 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A009F15C42047213
Address 17: Instruments (J285)       Labels:| 6C0-920-KOM-V1.clb-SRI3
   Part No SW: 6C0 920 741 A    HW: 6C0 920 741 A
   Component: KOMBI         211 0260
   Coding: 072409002080000800086A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009036
   VCID: 211489A3D14D2CE2A09-8074
          U1014 00 [00001001] - -
                    Fault Frequency: 40
                    Reset counter: 14
                    Mileage: 159764 km
                    Date: 2025.04.21
                    Time: 12:43:14
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H06 0047
   Revision: --------    Serial number: 009249034770 Dataset Number: 6C0067v____ 0034
   Coding: 030000044F0A590071000000000000010001000000000000000000000000
   GVL: 01403C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 659CDDB385E500C21C1-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 61169741322821381046
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 M    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3211
   Serial number: PE7I1202 Dataset Number: 6C0074V____ 0224
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 323676EF84ABA77A493-8066
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H04 0138
   Serial number: VWZAZ2P4546107 Dataset Number: 5G0CV1v____ 0001
   Coding: 02620001BE00000011110001000808001F01048401200100C6
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6E8EA29F5013C39A6DB-803A
   Subsystem 1 - Part No SW: 6C0 919 603 A    HW: 6C0 919 603 A
   Component: ABTm_Std2_Nav  H41 1017
   Serial number: VWZ8Z9PH20082Q
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
End----(Elapsed Time: 00:46, VBatt start/end: 11.7V/11.6V. VIgn 11.8V)-----
------------------------------2 Faults Found-------------------------------
I have a problem with TPMS, MIL ON on the dashboard, I can't reset the TPMS, someone tried to turn it off without success, is there any option to deactivate it, thanks in advance
What is the back story ? Do you know what they actually did or attempted to do?
0608 - TPMS Display
Reset counter: 14
Mileage: 159849 km
Date: 2025.04.25
Time: 15:39:17
is there any option to deactivate it,........
As this is a Safety function, I don't believe the RT forum (others may) would support this.
