- Jun 26, 2014
- 446
- 396
- Netherlands
- C?ID=150535
AutoScan: WVGZZZA1ZLV127723
blockmap-01-05E-906-018-AT_WVGZZZA1ZLV127723-20250425-1258.CSV
blockmap-02-0CW-300-050-J_WVGZZZA1ZLV127723-20250425-1259.CSV
blockmap-03-5Q0-614-517-DL_WVGZZZA1ZLV127723-20250425-1300.CSV
blockmap-05-3Q0-959-435-N_WVGZZZA1ZLV127723-20250425-1300.CSV
blockmap-08-5G1-907-044-AR_WVGZZZA1ZLV127723-20250425-1301.CSV
blockmap-09-5Q0-937-084-DG_WVGZZZA1ZLV127723-20250425-1301.CSV
blockmap-10-5QA-919-294-G_WVGZZZA1ZLV127723-20250425-1302.CSV
blockmap-13-2Q0-907-572-R_WVGZZZA1ZLV127723-20250425-1302.CSV
blockmap-15-3Q0-959-655-CM_WVGZZZA1ZLV127723-20250425-1302.CSV
blockmap-17-17A-920-790-B_WVGZZZA1ZLV127723-20250425-1256.CSV
blockmap-19-3Q0-907-530-AC_WVGZZZA1ZLV127723-20250425-1257.CSV
blockmap-2B-2Q0-905-861-A_WVGZZZA1ZLV127723-20250425-1303.CSV
blockmap-3C-2Q0-907-686-A_WVGZZZA1ZLV127723-20250425-1303.CSV
blockmap-42-5Q4-959-593-K_WVGZZZA1ZLV127723-20250425-1303.CSV
blockmap-44-3Q0-909-144-M_WVGZZZA1ZLV127723-20250425-1303.CSV
blockmap-4B-3Q0-907-338-E_WVGZZZA1ZLV127723-20250425-1303.CSV
blockmap-52-5Q4-959-592-K_WVGZZZA1ZLV127723-20250425-1304.CSV
blockmap-5F-3Q0-035-864-C_WVGZZZA1ZLV127723-20250425-1304.CSV
blockmap-75-5NA-035-284-C_WVGZZZA1ZLV127723-20250425-1304.CSV
blockmap-A5-3Q0-980-654-L_WVGZZZA1ZLV127723-20250425-1305.CSV
blockmap-D6-7P5-941-591-AJ_WVGZZZA1ZLV127723-20250425-1305.CSV
blockmap-D7-7P5-941-591-AJ_WVGZZZA1ZLV127723-20250425-1305.CSV
blockmap-OBD_WVGZZZA1ZLV127723-20250425-1315.CSV
Friday,25,April,2025,12:55:14:35871
VCDS Version: 25.3.1.1 (x64) HEX-NET CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WVGZZZA1ZLV127723 License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 75 A5
BB BC D6 D7
VIN: WVGZZZA1ZLV127723 Mileage: 92414km-57423miles
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AT HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9971
Revision: 8AH20000 CVN: 8B1B5A39
Coding: 0125003223641D0830000000000000000000000000000000
Shop #: WSC 27020 006 1048576
ASAM Dataset: EV_ECM15TFS01105E906018AT 004004
ROD: EV_ECM15TFS01105E906018AT_004.rod
VCID: 77BEFBBDCE415B23FB-8022
VINID: 9E65EAAAA441A9C9810871C20C672442C3
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1911
Revision: 00005009 Serial number: CU502002166296 CVN: ABB5E1C0
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021.rod
VCID: 3C342491B7E7B87BD6-8068
Part No SW: 5Q0 614 517 DL HW: 5Q0 614 517 BP
Component: ESC H35 0113
Revision: 00000000 Serial number: 60470000001459
Coding: 46FA6A7DA0222473477E0602E2C62562560524E26047A4733822F078D2A24B0B00000523525212121035351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7EB0EE99E17B6A6BB8-802A
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0542191943 Dataset Number: V03935301VA 0001
Coding: 132C0C0723
Shop #: WSC 00020 999 00000
ROD: EV_KessyHellaMQBAB_VW27.rod
VCID: 45C24175C42DF9B3B9-8010
Part No SW: 5G1 907 044 AR HW: 5G1 907 044 AR
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 060200042001100D1105000C00101036
ASAM Dataset: EV_ACClimaBHBVW37X 006151
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 78BCF881C35F545BF2-802C
Air quality sensor:
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H42 0312
Serial number: 02002005300173 Dataset Number: V03935302B 0001
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 004C90619B8F1C9BCA-8054
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY20M02D12H17M35S44
Coding: 0018DD
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY200200F3F
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000953728
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 R HW: 5Q1 953 569 B
Component: Lenks.Modul H23 0170
Serial number: 0100300120200C106333
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058320052 Dataset Number: V03935306ND 0001
Coding: 0471055811
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50EC60210B6F2C1B1A-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Dataset Number: V03935314EN 0001
Coding: 320467C25CFF8748949C810580408700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43C65F6DCA19C78397-8016
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2P25V4R5 Dataset Number: V03935298UN 0001
Coding: 88CCC0C0000000005C5400CF000840000065
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B56B74DA2C94FC3AF-805E
Subsystem 1 - Part No SW: ----------- HW: 454 001 501 20
Serial number: 3570000000078098424E
Subsystem 2 - Part No SW: ----------- HW: 454 001 501 20
Serial number: 35800000000B21152342
Subsystem 3 - Part No SW: ----------- HW: 454 802 001 20
Serial number: 35100676AB11A000000I
Subsystem 4 - Part No SW: ----------- HW: 454 802 201 20
Serial number: 3520023A5D51A000000G
Subsystem 5 - Part No SW: ----------- HW: 454 802 401 20
Serial number: 3550037F9ED1A000000%
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4193
Coding: 05A400186F8C00080188630B5001000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 2600E6F9596B12AB90-8072
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000751010 Dataset Number: V03935301GP 0001
Coding: 030100046F085600FB100258180F00010001070000000000000000000000
GVL: 01463C000000060040CC80008000C80000000000000200000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70ACC0A1AB2F0C1B3A-8024
Generator:
Component: 5-01-14-01-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0025
Serial number: 0352023215802439FF2B
Coding: 2F0000
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 2357654005
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 20000015471014
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 312A05A560A5451375-8064
Address 3C: Lane Change (J1086) Labels:| 2Qx-907-686-V1.clb
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H05 0052
Serial number: 00000541909243 Dataset Number: V03935321CS 0001
Coding: 50014500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW27.rod
VCID: 383C388183DF945B32-806C
Subsystem 1 - Part No SW: 2Q0 907 685 A HW: 2Q0 907 685 A
Component: HRE3_Kl15_Slv H05 0052
Serial number: 00000542982823
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000405148136 Dataset Number: V03935313VT 0001
Coding: 003B1220D000028000001000
VCID: 4DD279551C5D01F371-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000038493834
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Dataset Number: V03935312TA 0001
Coding: 951F0000
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 14022010800545 Dataset Number: V03935304ZR 0001
Coding: 000000070900204201000900000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 373E3BBD8EC19B233B-8062
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000405265362 Dataset Number: V03935313WJ 0001
Coding: 003B1020DC00028000001000
VCID: 4CD47451E74708FB66-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000038990487
Coding: 190000
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 853 0876
Serial number: Dataset Number: V03935311FY 0001
Coding: 02720601BE0000004111000100080A001F0500E4012000008E
ROD: EV_MUStd4CDELP_VW27.rod
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHX0570639
Subsystem 2 - Part No SW: V03 959 820 QC HW: -----------
Component: ECE DL1 2024 --- 2110
B201A 00 {00001001} - -
{Check software version management}
Reset counter: 223
Mileage: 92244 km
Date: 2025.04.24
Time: 19:51:38
Voltage terminal 30: 13.3 V
Status_Software_Version_Management-module_name: C
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0827
Revision: -------- Dataset Number: V03935298KU 0001
Coding: 02720601EA42180D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D322995ACFDB173E1-8068
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H13 0610
Serial number: 20022011P22635 Dataset Number: V03935320SY 0001
Coding: 0002070600000401002213548150A90098000E20002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40CC5061DB0FDC9B8A-8014
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AJ HW: 7P5 941 591 A
Component: LED1L H07 0011
ROD: EV_LED_PLUS_L_KEBODAVW416_VW27.rod
VCID: 04449C718F9700BBEE-8050
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0011
End----------(Elapsed Time: 01:48, VBatt start/end: 13.4V/12.9V)-----------
-------------------------------1 Fault Found-------------------------------
;SW:05E-906-018-AT HW:05E-907-309-H --- Engine
;Component:R4 1.5l TFS H20 9971, Coding:0125003223641D0830000000000000000000000000000000
;EV_ECM15TFS01105E906018AT,004004,EV_ECM15TFS01105E906018AT_004.rod
;Friday,25,April,2025,12:58:12:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 77BEFBBDCE415B23FB-8022
Group,Description,Actual
IDE00019,Voltage terminal 30,12.840, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,712, /min
IDE00025,Coolant temperature,69, °C
IDE00078,Time since engine start,320, s
IDE00083,Throttle valve position (absolute),11.0, %
IDE00084,Absolute load value,18, %
IDE00085,Normed load value,27.8, %
IDE00086,Accelerator pedal position,14.1, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,22.6, Nm
IDE00102,Control Module temperature,29.6, °C
IDE00148,Mean injection time,0.6584, ms
IDE00151,Oil fill level,56.540, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,334.5, °C
IDE00172,A/C compressor torque,20.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-25.00, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-24.97, °
IDE00178,Camshaft adjustment intake bank 1: specified value,22.00, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.14, °
IDE00182,Camshaft adaptation intake bank 1: phase position,-0.48, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-0.11, °
IDE00187,Coolant temperature at engine start,35.8, °C
IDE00188,Fuel high-pressure: actual value,17.014, MPa
IDE00190,Charge air pressure: specified value,269.53, hPa
IDE00191,Charge air pressure: actual value,1027.03, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,15.9, °C
IDE00194,Coolant temperature at radiator output: specified value,103.5, °C
IDE00196,Engine oil temperature,41.6, °C
IDE00201,High fuel pressure: specified value,17.000, MPa
IDE00202,Low fuel pressure: specified value,225.7, kPa
IDE00304,Fuel level,41.00, l
IDE00348,Intake air temperature,28, °C
IDE00349,Throttle valve position: normed,0.4, %
IDE00350,Air mass: specified value,7.0, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,45.8, °C
IDE00358,Limitation: torque,1000.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00371,Fuel consumption,0.61, l/h
IDE00375,Generator: load signal,48.35, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,720.2, mV
IDE00393,Accelerator pedal: sensor voltage 2,363.6, mV
IDE00394,Camshaft position: start of phase window,40.50, °
IDE00406,Camshaft RPM,359.0, /min
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00434,Particle filter: soot mass calculated,0, mg
IDE00436,Particle filter: kilometers since last regeneration,24672067, m
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0)
IDE00474,Ambient air pressure,102, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,6.5, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,1,
IDE00541,Acceleration,0.000, m/s²
IDE00554,Absolute vapor pressure in tank ventilation system,99515, kPa abs
IDE00556,Outside temperature,13, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.999 Lambda / -0.023 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.715, V
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,0.4, %
IDE00584,Distance driven since erasing DTC memory,169, km
IDE00588,Fuel tank fill level,82.0, %
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,1.5, Degrees
IDE00594,Absolute intake pressure,26, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,-10.9, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,4,
IDE00604,Short term adaptation of mixture formation bank 1,7.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,11.8, %
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00000,
IDE00773,Terminal 15 status via CAN,1,
IDE00950-ENG188621,A/C compressor status-Bits 0-7,0,
IDE01378,Fuel high pressure: control deviation,0.0160, MPa
IDE01385-ENG188621,Wear index-Bits 0-7,0,
IDE01386-ENG188621,Soot index-Bits 0-7,0,
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.718, V
IDE01650,Throttle valve position 2,11, %
IDE01774,Status misfire recognition,False result,
IDE01774-ENG127289,Status misfire recognition-Test_Program_B TRUE UBYTE,0,
IDE01775-ENG188621,Misfires per 1000 revolutions of cylinder 1-Bits 0-7,0,
IDE01776-ENG188621,Misfires per 1000 revolutions of cylinder 2-Bits 0-7,0,
IDE01777-ENG188621,Misfires per 1000 revolutions of cylinder 3-Bits 0-7,0,
IDE01778-ENG188621,Misfires per 1000 revolutions of cylinder 4-Bits 0-7,0,
IDE01869,Long-term fuel trim bank 1 at idle,-1.59, %
IDE01873,Test of catalytic converter: measured value,9.2087,
IDE01876,Adaptation of loss torque,-0.1, Nm
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,32.683, %
IDE01899,Load value: corrected specified value,66.19, %
IDE01901,Lost torque adaptation: idle,-0.1, Nm
IDE01902,Lost torque adaptation A/C compressor,-0.1, Nm
IDE01903,Lost torque adaptation driving mode,-1.3, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.6, Nm
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,1.0000,
IDE01922,Vehicle distance driven,92414, km
IDE01923,Control module distance driven,92227443, m
IDE01928,Close cam shaft angle at quantity control valve,34.2, °
IDE01929,Open cam shaft angle at quantity control valve,-4.0, °
IDE01930,High pressure regulation: adaptation value,-0.168, MPa
IDE01932,High pressure pump injection volume,-10.76, mm³
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,41,
IDE01975-ENG188621,Numb.of misfir.: cylinder 1-Bits 0-7,198,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,220,
IDE01976-ENG188621,Numb.of misfir.: cylinder 2-Bits 0-7,23,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,37,
IDE01977-ENG188621,Numb.of misfir.: cylinder 3-Bits 0-7,1,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,25,
IDE01978-ENG188621,Numb.of misfir.: cylinder 4-Bits 0-7,206,
IDE02117,Relative load value,16.85, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,-0.8, %
IDE02211,Brake pressure,-0.06, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02742,Oil pressure actual value,213.6, kPa
IDE02756,Number of manual engine starts,11695,
IDE02757,Number of automatic engine starts,7990,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,1683,
IDE03010-MAS01627,Number of prevented stop processes-Steering,3053,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,1,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,14,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery performance too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,2411,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,1633,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,18,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,9,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,17,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,380,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery performance too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,7,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,291,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,0.00, °
IDE03246,Neutral position sensor: upper adaptation value,0, mV
IDE03247,Neutral position sensor: lower adaptation value,0, mV
IDE03262,Adapt of angle sensor 1 f throttle valve,0.522, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.467, V
IDE03328,Transmission neutral position sensor voltage,0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03375-ENG188621,Adaptation status of neutral position sensor-Bits 0-7,0,
IDE03377,Coolant temp at radiator output: unconditioned voltage,3689.6, mV
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03493-ENG121091,Driver's door status-Dsplb Drv Door Act Opn,0,
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping requirements for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping requirements for active participants-Air Conditioning,not active,
IDE03587-MAS00127,Stopping requirements for active participants-brakes,not active,
IDE03587-MAS00506,Stopping requirements for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping requirements for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping requirements for active participants-Transmission,not active,
IDE03587-MAS01106,Stopping requirements for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping requirements for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping requirements for active participants-Steering,not active,
IDE03587-MAS02237,Stopping requirements for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping requirements for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping requirements for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping requirements for active participants-Motor,not active,
IDE03587-MAS06709,Stopping requirements for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping requirements for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping requirements for active participants-Front sensor for drivers assistant systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-Air Conditioning,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-brakes,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Transmission,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for drivers assistant systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication malfunction,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,0.000, m/s²
IDE03711,Mass flow through throttle valve,6.5, kg/h
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,49.445, %
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,708.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,1,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,148.1, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,38.129, %
IDE03932,Charge pressure actuator: specified position,160.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3175.2, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,1,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.99557,
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE04002,Charge air pressure control,BP_A act:102.7, kPa
IDE04010,Engine torque: normalized,9.0, %
IDE04011,Nominal torque,250, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:16850/--- kPa,
IDE04044,Charge pressure control valve,WG_A cmd/act:---/98 % / WG_B cmd/act:---/--- %,
IDE04045,Exhaust gas pressure,EP1:102.26, kPa
IDE04083,Coolant temperatures,ECT 1:69 °C / ECT 2:71 °C,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1535.8, mV
IDE04278,Bypass valve f high press turboch turbine inlet: target value,99.99, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,98.72, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,-10.93, %
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,2,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,3135.4, mV
IDE04410,Intake manifold pressure: specified value,280.00, hPa
IDE04604,Accelerator pedal travel,0.00, %
IDE04629,AVS operating condition,1,
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04670,Crankshaft signal evaluation: status,EPMHCRS_GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04693,Increasing desired torque intervention of ESP,-54623.5, Nm
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04820,Fuel content due to degassing of engine oil,0.00, %
IDE04859-ENG112933,Brake booster pump activation condition-Bbkvp,0,
IDE04887,Powertrain target torque,-12.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,6.1, Nm
IDE04937,Sensor for engine block temperature: raw value,69.6, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,10418, s
IDE05213,Activation pulse duty factor for tank vent valve for diag,99.998, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,3.85,
IDE05215,EVAP valve diagnosis result correlation factor,1.99,
IDE05240-ENG188621,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG188621,A/C compressor release status-Bits 0-7,1,
IDE05332-ENG188621,Heat request from heater to thermal management-Bits 0-7,2,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,16.55, %
IDE05449,O2 sensor 2: B1: internal resistance limit,10240, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,-0.00378,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,719.92, °C
IDE05470,Cat converter oxygen storage capacity,552.3, mg
IDE05474,Main cat converter OSC age correction factor,0.90625,
IDE05479,Misfire recognition reference moment,5.750, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05484,Servo pump desired actual torque for idle control,0.0, Nm
IDE05485-ENG188621,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05497,Adaptation value of the charge pressure control,0.00, hPa
IDE05761-ENG121419,Nominal operating condition: partial engine operation-Bhmbs,0,
IDE05762-ENG121418,Engine operating status partial engine operation-Bhmb,0,
IDE05767,Number of switch-overs during partial engine operation,0,
IDE05928,Fuel consumption since DTC memory last erased,5.125, l/100km
IDE05941-ENG112665,Enable condition: camshaft control-Bnws,1,
IDE05950,Charge pressure control adaptation value 1,25.3125, hPa
IDE05951,Charge pressure control adaptation value 2,-16.875, hPa
IDE05952,Charge pressure control adaptation value 3,0, hPa
IDE06014,Charge pressure control adaptation value 0,70.3125, hPa
IDE06020,Intake air temperature in intake manifold bank raw value,28.8, °C
IDE06021,Intake air temperature before throttle valve: raw value,27.8, °C
IDE06039,Required RPM at idle speed,718.0, /min
IDE06040,High fuel pressure: regulator output value,-0.2060, MPa
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,36,
IDE06045-ENG188621,Output diagnostic test status-Bits 0-7,0,
IDE06049,Pressure in brake booster: raw value,266, hPa
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06112-ENG188621,Test of cylinder deactivation-Bits 0-7,5,
IDE06192,Knock sensor: cylinder 2: voltage,0.0047592, V*ms
IDE06193,Knock sensor: cylinder 3: voltage,0.0058220, V*ms
IDE06194,Knock sensor: cylinder 4: voltage,0.0069923, V*ms
IDE06195,Knock sensor: cylinder 1: voltage,0.0038811, V*ms
IDE06198-ENG188621,Tank vent valve: diagnostic status-Bits 0-7,164,
IDE06255,Vehicle lateral acceleration,-0.04, g
IDE06256,Vehicle lateral acceleration: raw value,-0.03, g
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06567,Frequency counter deactivate start/stop function,115,
IDE06568,Stop prevention by driver frequency counter,20876,
IDE06569,Frequency counter vehicle standstill,42557,
IDE06570,Oil level and oil temp. sensor: oil temperature in oil pan,42.5, °C
IDE06610,Frequency counter vehicle standstill with stop,11373,
IDE06702-ENG188621,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7,0,
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06704-ENG188621,Drivetrain coordinator: brake fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06758,Air mass since engine start,1.1559, kg
IDE06799-ENG188621,A/C compressor status: HW input-Bits 0-7,0,
IDE06800,A/C main switch status,Correct result,
IDE06800-ENG127289,A/C main switch status-Test_Program_B TRUE UBYTE,1,
IDE06828,Coolant recirc. pump 2: spec. value,64.51, %
IDE06944,A/C compressor: load current: act. value,0.00, A
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06956-ENG188621,Driver-side belt buckle status-Bits 0-7,2,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,0.0, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,0, km
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,94,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07076,AVS valve stroke position intake,0,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07078,AVS result of last switch-over: intake,10,
IDE07079,AVS result of last switch-over: exhaust,10,
IDE07164,Number injections,9436,
IDE07224-ENG188621,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG188621,Bit string for status of oil level-Bits 0-7,0,
IDE07238,Status of power transfer,0.00,
IDE07240-ENG188621,Status transition of engine control module sequencing-Bits 0-7,0,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,6.23, %
IDE07549,Engine temp. mangmt. actuator: actual value of angle,6.34, %
IDE07550,Engine temp. management actuator: raw value,884.6, mV
IDE07620-ENG188621,Status momentary default during stability intervention-Bits 0-7,0,
IDE07693,Maximum supply pressure low-pressure fuel pump,0.0, kPa
IDE07697,System test status of fuel supply,32,
IDE07796-ENG188621,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Bits 0-7,0,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE07908,Coolant fan activation requested by A/C,0.00, %
IDE07963-ENG188621,Cam piece counter position malfunction-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,2,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,2,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,2,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,2,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09319-ENG188621,Pre-ignition action counter injection cut-off-Bits 0-7,0,
IDE09320-ENG188621,Pre-ignition action counter fill level limit-Bits 0-7,0,
IDE09529,Fuel mass flow rate due to degassing of eng. oil,0.0, mg/s
IDE09531,Total mass of gasoline and alcohol in oil,0.02, g
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.08, s
IDE09925-ENG188621,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09926-ENG188621,Outlet camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,1.65, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,-0.40, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-0.13, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,-1.45, °
IDE10042,Outlet camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10042-ENG127372,Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,138.4, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,91686, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,91592, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,2,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,141.3, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,90186, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,90165, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,2,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,68.8, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,88686, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,88606, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,2,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,71.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,87186, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,87093, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,2,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,70.4, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,85686, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,85663, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,2,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,73.2, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,84186, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,84176, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,2,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,78.9, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,82686, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,82674, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,2,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,85.1, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,81186, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,81186, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,5,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,3,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,88.6, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,79686, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,79653, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,2,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,91.5, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,78186, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,78153, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,2,
IDE10302,Time since engine start,357.8, s
IDE10303,Integrated air masse at first engine start,1.1719, kg
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10580,Engine oil level: test method 1,122.3, %
IDE10581,Engine oil level: test method 2,122.6, %
IDE10582,Engine oil level: test method 3,0.0, %
IDE10633,Clutch protection function: reduced torque,3267.7, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0.0, 1/min/s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,15.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,50, ml/mm
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,863,
IDE11116,Start/stop driver request: counter internal-motor restart,630,
IDE11203,Oil pressure setpoint,214.5, kPa
IDE11267,Oil level: max. value: relative,122.6, %
IDE11268,Oil level: min. value: relative,119.6, %
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,1,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,0,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,101,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,2,
IDE11330,Oil press. control valve: activation pulse duty factor,52.86, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11541-ENG188621,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635-ENG188621,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11929,I share of PID control of fully variable oil pump,-2.10, %
IDE11931,Heated oxygen sensor bank 1 sensor 1: positioning intervention rear cat controller,0.00003,
IDE12044-ENG188621,Crankshaft Position adapt.: write attempt counter-Bits 0-7,1,
IDE12074-ENG188621,Position adapt. of intake camshaft bank 1: counter-Bits 0-7,1,
IDE12077-ENG188621,Position adapt. of outlet camshaft bank 1: counter-Bits 0-7,1,
IDE12078-ENG188621,Position adapt. of camshafts cyl: individual bank 1: counter-Bits 0-7,1,
IDE12105,Temperature sensor for cylinder block: uncond. voltage value,1471.2, mV
IDE12106,Temperature sensor for cylinder block,71.7, °C
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,-11.90, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,-20.08, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,-25.18, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,-17.24, %
IDE12210,Particle filter: water mass,5.8, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000020,
IDE12460,Low pressure procedure: pressure regulation valve open,0.00, kPa
IDE12461,Pressure regulator valve pulse duty factor,0.00, %
IDE12462,Pressure regulator valve opening pressure,0.0, kPa
IDE12463,Pressure regulator valve minimum pulse duty factor,False result,
IDE12463-ENG127289,Pressure regulator valve minimum pulse duty factor-Test_Program_B TRUE UBYTE,0,
IDE12464,Rail pressure at end of test,0.000, MPa
IDE12468-ENG188621,Login counter of the simulation interface-Bits 0-7,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,10073, mg
IDE13086,Particle filter: maximum soot build-up reached,13446, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,0,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE13945,Mixture variations without lambda controller interference,0.00000,
IDE14152,Oil level: maximum value: compensated,17.932, mm
IDE14153,Oil level: minimum value: compensated,35.444, mm
IDE14534,Knock control: error status,0,
IDE14753,Particulate filter: loading stage,0,
IDE14755,Particulate filter: blockage ratio calculated: relative,29.4,
IDE14756,Particulate filter: blockage ratio calculated: absolute,0.0,
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.4, %
IDE14767,Particulate filter: soot load calculated,0.0, %
IDE80106,Analysis 106,00 03 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7E BC 00 06 00 00 00 00 FF FF B4 15 00 1A 00 00 00 00 00 00 00 00,
MAS15845,Fuel: tank fill level,41.0, l
MAS15866,High pressure buildup gradient during pressure limitation valve opening test,0.000, MPa/revolution
MAS15883,Maximum fuel high-pressure with extended value range,0.000, MPa
MAS16066,Exhaust gas temperature at the probe before PreCat bank 1: model value,268.5, °C
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,Correct result,
MAS16222-ENG127289,Heated oxygen sensor bank 1 probe 1: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,Correct result,
MAS16223-ENG127289,Heated oxygen sensor bank 1 probe 2: status 2G-Test_Program_B TRUE UBYTE,1,
MAS16287,High pressure buildup process with engine of: extended range,0.000, MPa/s
MAS16299,Heated oxygen sensor 1 probe 1: status dew point end,Correct result,
MAS16299-ENG127289,Heated oxygen sensor 1 probe 1: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16300,Heated oxygen sensor 1 probe 2: status dew point end,Correct result,
MAS16300-ENG127289,Heated oxygen sensor 1 probe 2: status dew point end-Test_Program_B TRUE UBYTE,1,
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16688,Throttle 1: bank 1: diagnostic value normed: leak detection,-0.0039,
MAS16834,Particle filter threshold rate of blockage calculated,3.0000,
MAS16835,Particle filter rate of blockage calculated,1.0625,
MAS17030,Engine control module hardware timer: self-diagnosis status,1,
MAS17031,Radiator shutter 1: actual position,255, %
MAS17060,Characteristics cooling module 1: end stage activation,0.00, %
MAS17189,Exhaust pressure sensor 1: raw value,1025.9, hPa
MAS17191,Characteristics cooling module: target position,6.23, %
MAS17192,Characteristics cooling module: upper mechanical stop,4567.8, mV
MAS17193,Characteristics cooling module: lower mechanical stop,432.8, mV
ENG119898,Actual_section_of_standard_test,0,
ENG157506-ENG188621,AVS_Cam_element_position_error_counter_lift_0-Bits 0-7,0,
ENG157507-ENG188621,AVS_Cam_element_position_error_counter_lift_1-Bits 0-7,0,
ENG157508-ENG188621,AVS_Cam_element_position_error_counter_manifold_pressure_diagnosis-Bits 0-7,0,
ENG157509-ENG188621,AVS_Cam_element_position_error_counter_misfire_detection-Bits 0-7,0,
ENG121428-ENG188621,AVS_counter_error_debonce-Bits 0-7,0,
ENG121428-ENG188621,AVS_counter_error_debonce-Bits 0-7,2,
ENG121429-ENG188621,AVS_counter_error_limphome-Bits 0-7,0,
ENG121426-ENG188621,AVS_counter_sporadic_diagnosis_errors-Bits 0-7,0,
ENG121427-ENG188621,AVS_counter_sporadic_switch_errors-Bits 0-7,0,
ENG112670-ENG112664,Brake_booster_start_request_combustion_engine-Bbkvs ta,0,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG168741,DTEV r p In Mnf Mes Estim,3.85,
ENG247045,Engine Exhaust Flow Rate,7.2, kg/h
ENG151174,Engine Friction - Percent Torque,7.0, %
ENG157850,Evap_purge_system_bank_1_cross_correlation_maximum_engine_load_gradient,0.00, hPa
ENG157851,Evap_purge_system_bank_1_cross_correlation_maximum_engine_speed_gradient,0.0, /min
ENG157852,Evap_purge_system_bank_1_cross_correlation_measured_mean_amplitude,46.4, hPa
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG158050-ENG188621,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG158051-ENG188621,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG158052-ENG188621,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG158155,Rba Io Sig Rtc st Diag Stop Count er,255,
ENG139760,Thr Vlv u Sens1 B1,0.557, V
ENG139761,Thr Vlv u Sens2 B1,4.423, V
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG158334,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG158335,Virtual_SigXSet_TiEngOff_tiDiagRef,155, s
ENG158336,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,10396, s
ENG158337,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8378211, s
ENG158338,Virtual_SigXSet_TiOff_tiStrtEnd_Off,10420, s
Elapsed Time: 00:50
;SW:0CW-300-050-J HW:0AM-927-769-E --- Auto Trans
;Component:GSG DQ200G2_M H05 1911, Coding:0014
;EV_TCMDQ200021,001001,EV_TCMDQ200021.rod
;Friday,25,April,2025,12:59:06:35871
;VCID: 3C342491B7E7B87BD6-8068
IDE00008,Software version,1911,
IDE00018,Voltage terminal 15,12.4, V
IDE00019,Voltage terminal 30,12.7, V
IDE00021-ENG99543,Engine speed-Engine RPM,706, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,718, /min
IDE00023,Transmission output speed,0, /min
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1047.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,37, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Driving direction-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,-0.60, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,12.9, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,30, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,33, °C
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,16.00, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,15.98, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,14.60, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,14.57, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,598.1, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,598.0, mA
IDE02784-ENG120853,Sub-transmission 1 Valve Current: actual value AD value-Current_Valve_Transmission_Part_1_Actual_AD_Value,1469,
IDE02785-ENG120854,Pulse duty factor of valve for partial transmission 1-Duty_Factor_Valve_Transmission_Part_1,0.0, %
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,577.4, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,577.0, mA
IDE02788-ENG120855,Sub-transmission 2 Valve Current: actual value AD value-Current_Valve_Transmission_Part_2_Actual_AD_Value,1466,
IDE02789-ENG120856,Pulse duty factor of valve for partial transmission 2-Duty_Factor_Valve_Transmission_Part_2,0.0, %
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-68.55, Nm
IDE02794-ENG120857,Actual position clutch 1 duty cycle factor 1-Clutch_1_Actual_Position_Duty_Factor_1,13.5, %
IDE02795-ENG120858,Actual position clutch 1 duty cycle factor 2-Clutch_1_Actual_Position_Duty_Factor_2,85.8, %
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,324.9, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,327.0, mA
IDE02798-ENG120859,Clutch 1 Valve Current: actual value AD value-Current_Valve_Clutch_1_Actual_AD_Value,721,
IDE02799-ENG120860,Duty cycle of valve for clutch 1-Duty_Factor_Valve_Clutch_1,0.4, %
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02803-ENG120861,Actual position clutch 2 duty cycle factor 1-Clutch_2_Actual_Position_Duty_Factor_1,14.6, %
IDE02804-ENG120862,Actual position clutch 2 duty cycle factor 2-Clutch_2_Actual_Position_Duty_Factor_2,84.7, %
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,306.7, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,302.0, mA
IDE02807-ENG120863,Clutch 2 Valve Current: actual value AD value-Current_Valve_Clutch_2_Actual_AD_Value,630,
IDE02808-ENG120864,Duty cycle of valve for clutch 2-Duty_Factor_Valve_Clutch_2,3.8, %
IDE02820,Transmission mileage,91789.8, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,60.00, bar
IDE02822-ENG120865,Pressure supply threshold 2-Pressure_Supply_Threshold_2,42.00, bar
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02826-ENG120866,Basic setting sequence index-Basic_Settings_Flow_Index,0,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid EOL,
IDE02860-ENG120867,Status of basic setting data clutch travel pressure characteristic-State_Of_Basic_Adjustmentdata_Clutch_Controltravel_Pressure_Characteristic,2,
IDE02862-ENG103213,Production data transmission-Aggregatekennzeichnung (Getriebe),006,
IDE02862-ENG103083,Production data transmission-Baudatum,200227,
IDE02862-ENG104019,Production data transmission-Getriebekennbuchstabe,UAG,
IDE02862-ENG99175,Production data transmission-Kassel,K,
IDE02862-ENG101707,Production data transmission-Kennung der Montagelinie,R02,
IDE02862-ENG103830,Production data transmission-Lfd.-Nr,0633,
IDE02863-ENG120868,Specified position of gear adjuster A-Gearpositioner_A_Commanded_Position,28.88, mm
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,8.91, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,2637,
IDE02866-ENG120869,AD Value 2 of Actual Position of Gear Actuator A-Gearpositioner_A_Actual_Position_AD_Value_2,2844,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,734.2, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,734.0, mA
IDE02869-ENG120870,AD value of actual current of gear Solen.val. A-Gearpositioner_A_Valve_Actual_Current_AD_Value,1569,
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,56.6, %
IDE02871-ENG120872,Specified position of gear positioner B-Gearpositioner_B_Commanded_Position,-0.32, mm
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.32, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,2797,
IDE02874-ENG120873,AD Value 2 of Actual Position of Gear Actuator B-Gearpositioner_B_Actual_Position_AD_Value_2,1351,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,528.4, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,529.0, mA
IDE02877-ENG120874,AD value of actual current of gear Solen.val. B-Gearpositioner_B_Valve_Actual_Current_AD_Value,999,
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,2.1, %
IDE02879-ENG120876,Specified position of gear positioner C-Gearpositioner_C_Commanded_Position,-0.18, mm
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,-0.18, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,2670,
IDE02882-ENG120877,AD Value 2 of Actual Position of Gear Actuator C-Gearpositioner_C_Actual_Position_AD_Value_2,1400,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,503.9, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,509.0, mA
IDE02885-ENG120878,AD value of actual current of gear Solen.val. C-Gearpositioner_C_Valve_Actual_Current_AD_Value,1200,
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,0.0, %
IDE02887-ENG120880,Specified position of gear positioner D-Gearpositioner_D_Commanded_Position,28.37, mm
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,8.32, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,2785,
IDE02890-ENG120881,AD Value 2 of Actual Position of Gear Actuator D-Gearpositioner_D_Actual_Position_AD_Value_2,2769,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,741.9, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,743.0, mA
IDE02893-ENG120882,AD value of actual current of gear Solen.val. D-Gearpositioner_D_Valve_Actual_Current_AD_Value,1508,
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,57.0, %
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03008-ENG122550,Stop process prevented-GE_StartStopp_Info,Stop release,
IDE03008-ENG122551,Stop process prevented-MO_StartStopp_Status,1,
IDE03008-ENG122546,Stop process prevented-Stopp-Verbot-Grund 1,not active,
IDE03008-ENG122547,Stop process prevented-Stopp-Verbot-Grund 2,not active,
IDE03008-ENG122548,Stop process prevented-Stopp-Verbot-Grund 3,not active,
IDE03008-ENG122549,Stop process prevented-Stopp-Verbot-Grund 4,not active,
IDE03008-ENG122552,Stop process prevented-Stopp-Verbot-Grund 5,not active,
IDE03008-ENG122553,Stop process prevented-Stopp-Verbot-Grund 6,not active,
IDE03008-ENG122554,Stop process prevented-Stopp-Verbot-Grund 8,not active,
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,0,
IDE03154-ENG120884,Set clutch default data: Status-Clutch_Default_Data_Setting_Status,3,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03157-ENG120885,Set clutch movemt. press. charac. curve def. data: status-Clutch_Controltravel_Pressure_Characteristic_Default_Data_Setting_Status,3,
IDE03159-ENG120886,Start clutch fast adaptation: Status-Clutch_Fastadaption_Starting_Status,0,
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03161-ENG120887,Clutch fast adaptation basic characteristics remaining number-Remaining_Numbers_Clutch_Fastadaption_Basic_Characteristic,0,
IDE03162-ENG120888,Clutch fast adaptation basic characteristics remaining mileage-Remaining_Km_Clutch_Fastadaption_Basic_Characteristic,0, km
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03166-ENG120889,Protective function temp. clutch 1 protect. level 2 number-Protective_Function_Temperature_Clutch_1_Protection_2_Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03170-ENG120890,Protective function temp. clutch 2 protect. level 2 number-Protective_Function_Temperature_Clutch_2_Protection_2_Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,91208.7, km
IDE03172-ENG100789,Driving Strategy Percentage Driving in D or S w/Cruise-Q003 Driving Time Ecological,99, %
IDE03173-ENG103567,Driving Strategy Percentage Driving in S w/o cruise-Q004 Driving Time Sporty,0, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,1, %
IDE03180-ENG103176,Number of standard trips-General Denominator,1679,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,6,
IDE03189-ENG110524,Number of prevented stop processes (statistics)-Basic setting,not active,
IDE03189-ENG159578,Number of prevented stop processes (statistics)-Demontagestellung,not active,
IDE03189-ENG159577,Number of prevented stop processes (statistics)-Drucksensorausfall,not active,
IDE03189-ENG159579,Number of prevented stop processes (statistics)-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE03189-ENG110508,Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots,0.0, km
IDE03189-ENG159710,Number of prevented stop processes (statistics)-Motorstoppverbote Anzahl Stoppverbote,0,
IDE03189-ENG110525,Number of prevented stop processes (statistics)-Stop prohibition via application,not active,
IDE03189-ENG159576,Number of prevented stop processes (statistics)-Temperaturbedingung,not active,
IDE03189-ENG122385,Number of prevented stop processes (statistics)-unsortierte Gangsteller im Stand,not active,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,32, °C
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01447,Driving profile selection-Act.val.,11,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS01448,Driving profile selection-Specified value,11,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-67.50, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,1.6, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,1, km
IDE06244-ENG120895,Clutch 2: target position (mm)-Clutch_2_Commanded_Position_mm,0.0, mm
IDE06245-ENG120896,Clutch 1: adapt.: basic char.: uneven road surface recog-Clutch_1_adaption_basic_characteristic_active_rough_road_detection,3498,
IDE06246-ENG120897,Clutch 2: adapt.: basic char.: uneven road surface recog-Clutch_2_adaption_basic_characteristic_active_rough_road_detection,6726,
IDE06247-ENG120898,Clutch 1: target position (mm)-Clutch_1_Commanded_Position_mm,0.0, mm
IDE06281-ENG120909,Clutch 1: actual position (mm)-Clutch_1_Actual_Position_mm,1.3, mm
IDE06282-ENG120910,Clutch 2: actual position (mm)-Clutch_2_Actual_Position_mm,1.8, mm
IDE06283-ENG120908,Clutch 2: adaptation: clutch end position closed (mm)-Clutch_2_adaption_upper_stop_closed_mm,26.2, mm
IDE06284-ENG120907,Clutch 2: adaptation: clutch end position open (mm)-Clutch_2_adaption_upper_stop_open_mm,1.8, mm
IDE06285-ENG120911,Clutch 1 adaptation basic characteristics point 0 position (mm)-Clutch_1_adaption_basic_characteristic_point_0_mm,9.0, mm
IDE06286-ENG120912,Clutch 1 adaptation basic characteristics point 1 position (mm)-Clutch_1_adaption_basic_characteristic_point_1_mm,11.4, mm
IDE06287-ENG120906,Clutch 1 adaptation basic characteristics point 3 position (mm)-Clutch_1_adaption_basic_characteristic_point_3_mm,23.3, mm
IDE06288-ENG120899,Clutch 2 adaptation basic characteristics point 0 position (mm)-Clutch_2_adaption_basic_characteristic_point_0_mm,11.3, mm
IDE06289-ENG120900,Clutch 2 adaptation basic characteristics point 1 position (mm)-Clutch_2_adaption_basic_characteristic_point_1_mm,14.0, mm
IDE06290-ENG120902,Clutch 2 adaptation basic characteristics point 2 position (mm)-Clutch_2_adaption_basic_characteristic_point_2_mm,22.0, mm
IDE06291-ENG120901,Clutch 2 adaptation basic characteristics point 3 position (mm)-Clutch_2_adaption_basic_characteristic_point_3_mm,24.6, mm
IDE06292-ENG120903,Clutch 1: adaptation: clutch end position open (mm)-Clutch_1_adaption_upper_stop_open_mm,1.4, mm
IDE06293-ENG120904,Clutch 1: adaptation: clutch end position closed (mm)-Clutch_1_adaption_upper_stop_closed_mm,25.3, mm
IDE06294-ENG120905,Clutch 1 adaptation basic characteristics point 2 position (mm)-Clutch_1_adaption_basic_characteristic_point_2_mm,18.0, mm
IDE06425,Dynamometer mode: functional,not activated,
IDE10730-MAS11247,Clutch valves QPV engagement point current offsets-K1 QPV engagement point current offset low,61.7, mA
IDE10730-MAS11248,Clutch valves QPV engagement point current offsets-K1 QPV engagement point current offset high,43.9, mA
IDE10730-MAS11249,Clutch valves QPV engagement point current offsets-K2 QPV engagement point current offset low,66.3, mA
IDE10730-MAS11250,Clutch valves QPV engagement point current offsets-K2 QPV engagement point current offset high,49.6, mA
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,24,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,82,
IDE11208-ENG127895,Pressure supply: number of activation requests-Pressure supply number of switch on request,391504,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,91789.8, km
IDE13855-MAS17011,Clutch 1: unsteady friction value detector-Clutch 1 quantity of total detections (wet-cold oscillation),1467,
IDE13855-MAS17013,Clutch 1: unsteady friction value detector-All driving with intervention on clutch 1,9682, km
IDE13855-MAS17015,Clutch 1: unsteady friction value detector-Clutch 1 maximum slippage,167.4, /min
IDE13855-MAS17017,Clutch 1: unsteady friction value detector-Clutch 1 vehicle-km-status during last active intervention,91860, km
IDE13856-MAS17012,Clutch 2: unsteady friction value detector-Clutch 2 quantity of total detections (wet-cold oscillation),105,
IDE13856-MAS17014,Clutch 2: unsteady friction value detector-All driving with intervention on clutch 2,183, km
IDE13856-MAS17016,Clutch 2: unsteady friction value detector-Clutch 2 vehicle-km-status during last active intervention,92020, km
IDE13856-MAS17018,Clutch 2: unsteady friction value detector-Clutch 2 maximum slippage,94.4, /min
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,9241, km
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,65535,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,0, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,0,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,-10.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,P,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80007-ENG101090,Analysis 7-Snapshot 1 Commanded Gear,GANG N,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,0, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,0, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,0, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,0, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,-20.48, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-20.48, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,-20.48, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,-20.48, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,0, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,0, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-50, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,0.0, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,0.0, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,-60, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,65535,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,0, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,0,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,-10.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,New,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2 Commanded Gear,GANG N,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG N,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,-20.48, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,-20.48, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,-20.48, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-20.48, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,0, mA
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,-50, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,0.0, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,0.0, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,-60, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,-60, °C
IDE80067-ENG127857,Analysis 67-Snapshot 1 clutch 1 actual position,-41.0, mm
IDE80068-ENG127858,Analysis 68-Snapshot 1 clutch 2 actual position,-41.0, mm
IDE80069-ENG127859,Analysis 69-Snapshot 2 clutch 1 actual position,-41.0, mm
IDE80070-ENG127860,Analysis 70-Snapshot 2 clutch 2 actual position,-41.0, mm
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,3332174.7, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,2092154.0, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,1335665.6, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,415171.4, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,20814.7, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80078-ENG127867,Analysis 78-Temperature hybrid time in range 6,0.0, s
IDE80079-ENG127868,Analysis 79-Temperature hybrid time in range 7,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,90, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,6957869.9, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,238096.2, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,15.0, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,0.0, s
IDE80085-ENG127874,Analysis 85-Clutch 1 temperature time in range 4,0.0, s
IDE80086-ENG127875,Analysis 86-Clutch 1 temperature time in range 5,0.0, s
IDE80087-ENG127863,Analysis 87-Clutch 1 temperature time in range 6,0.0, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,164, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,6861947.6, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,333079.9, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,954.2, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,0.0, s
IDE80093-ENG127864,Analysis 93-Clutch 2 temperature time in range 4,0.0, s
IDE80094-ENG127865,Analysis 94-Clutch 2 temperature time in range 5,0.0, s
IDE80095-ENG127866,Analysis 95-Clutch 2 temperature time in range 6,0.0, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,179, °C
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,52698,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,119470,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,151317,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,146166,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,107146,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,62366,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,27899,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,14570,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,3209,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,635,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,654,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,21,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,692,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,17,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,5,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,1959,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80135-ENG163713,Analysis 135-Snapshot 1 freewheeling status,Freilauf inaktiv aber möglich,
IDE80136-ENG163714,Analysis 136-Snapshot 2 freewheeling status,Freilauf inaktiv aber möglich,
IDE80137-ENG167891,Analysis 137-Mode A FID event memory entry 1,FF FF,
IDE80137-ENG167892,Analysis 137-Mode A FID event memory entry 2,FF FF,
IDE80137-ENG167893,Analysis 137-Mode A FID event memory entry 3,FF FF,
IDE80137-ENG167894,Analysis 137-Mode A FID event memory entry 4,FF FF,
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,44.47, bar
IDE80261-ENG127834,Pressure supply: act. press.: AD value-Pressure supply actual pressure AD value,2527,
IDE80262-ENG127829,Pressure supply: spec. RPM-Pressure supply commanded speed,2152, /min
IDE80263-ENG127885,Pressure supply: act. RPM-Pressure supply actual speed,0, /min
IDE80264-ENG127836,Pressure supply: PWM pulse duty cycle-Pressure supply PWM duty factor,0.0, %
IDE80265-ENG127855,Pressure supply: act. current-Pressure supply actual current,0.0, mA
IDE80266-ENG127835,Pressure supply: spec. condition-Pressure supply commanded state,0,
IDE80267-ENG127877,Pressure supply: act. condition-Pressure supply actual state,15,
IDE80268-ENG127886,Pressure supply: number of start requests by E-motor-Pressure supply number of switch on request electrical oil pump,65535,
IDE80269-ENG127893,Pressure supply: last error condition of driver-Pressure supply last driver state,0,
IDE80270-ENG127887,Pressure supply: number of time-out errors-Pressure supply number of timeout errors,0,
IDE80271-ENG127888,Pressure supply: number of synchronization errors-Pressure supply number of synchronisation errors,0,
IDE80272-ENG127889,Pressure supply: number of overcurrent errors-Pressure supply number of overcurrent errors,0,
IDE80273-ENG127890,Pressure supply: number of remaining driver errors-Pressure supply number of remaining driver errors,0,
IDE80274-ENG127837,Pressure supply: max. runtime vs. serv.life-Pressure supply maximum duration over lifetime,16, s
IDE80275-ENG127891,Pressure supply: max. runtime during controlled mode-Pressure supply maximum duration in controlled operating mode,10, s
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,92414, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,0,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80281-ENG98675,Mechatronics identification DQ200-Construction version,E2,
IDE80281-ENG120772,Mechatronics identification DQ200-Endnummer,026,
IDE80281-ENG112382,Mechatronics identification DQ200-Index,C ,
IDE80281-ENG120774,Mechatronics identification DQ200-Lfd. Nr. pro Tag,1619,
IDE80281-ENG120775,Mechatronics identification DQ200-Linienkennung,K,
IDE80281-ENG120773,Mechatronics identification DQ200-production day,200226,
IDE80281-ENG120777,Mechatronics identification DQ200-Prüfzeichen,2,
IDE80281-ENG120776,Mechatronics identification DQ200-Ventilkennung,D,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,21.3, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,142.6, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,250.0, Nm
IDE80286-ENG127831,Clutch 1 Adaption clutch end position closed-Clutch 1 adaption upper stop closed,25.3, mm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.9, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,15.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,149.2, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,250.0, Nm
IDE80293-ENG127861,Clutch 2 Adaption clutch end position closed-Clutch 2 adaption upper stop closed,26.2, mm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.7, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,25462,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,92410, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter,23554,
IDE80299-ENG127884,Clutch 2 Adaption kiss point part 1: vehicle odometer reading-Clutch 2 adaption part 1 vehicle mileage,92410, km
IDE80300-ENG127852,Friction energy: clutch 1-Clutch 1 frictional energy,000000057157, * 20 kJ
IDE80301-ENG127856,Friction energy: clutch 2-Clutch 2 frictional energy,000000052556, * 20 kJ
IDE80302-ENG122492,Selector lever information-Datenstand,H8,
IDE80302-ENG111628,Selector lever information-Part Number,5Q1713025BH ,
IDE80302-ENG98856,Selector lever information-Programmability,0 ,
IDE80302-ENG122491,Selector lever information-Programm-Stand, 3 ,
IDE80303-ENG127833,Overall software description-Software full name,U19,
IDE80305-ENG125922,Parameter set description-Data set name,0CW300050J_1911_UJJD,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
IDE80309-ENG127892,Pressure supply: max. error display during start request-Pressure supply maximum number of errors during switch on request,0,
IDE80310-ENG127838,Pressure supply: max. delay until transition to regular oper.-Pressure supply maximum delay until transition into controlled operating mode,0.2, s
IDE80311-ENG127851,Pressure supply: max. switch-on period for applicable range-Pressure supply maximum relative switch on duration over applicational window,0, %
IDE80312-ENG122524,CAN bus installation information-ACC_06,installed,
IDE80312-ENG122528,CAN bus installation information-BEM_05,installed,
IDE80312-ENG113024,CAN bus installation information-Charisma_01,installed,
IDE80312-ENG122522,CAN bus installation information-EPB_01,installed,
IDE80312-ENG122525,CAN bus installation information-GRA_ACC_01,not installed,
IDE80312-ENG122511,CAN bus installation information-TSK_06,installed,
ENG122362,Abbruchcode Grundeinstellung,0,
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,8, °C
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,80 04 2A 5C,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,80 04 27 40,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,80 04 12 F2,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,80 04 10 B4,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 30 00 1E,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,U19,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,13.2, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,13.0, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,26, °C
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Odometer reading,0, km
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,5,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,1,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,BB,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,0,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Odometer reading,655350, km
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Odometer reading,655350, km
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Odometer reading,655350, km
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Odometer reading,655350, km
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,14 10 BC A7,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,F2 D2 F8 57,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,AB B5 E1 C0,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,4C F5 31 99,
ENG103827,Clutch 1 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG99333,Clutch 1 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG102537,Clutch 1 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG102732,Clutch 2 adaption basic characteristic range 1 quick adaptions remaining km,0, km
ENG101931,Clutch 2 adaption basic characteristic range 2 quick adaptions remaining km,0, km
ENG100136,Clutch 2 adaption basic characteristic range 3 quick adaptions remaining km,0, km
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG103186,Clutch center central plate temperature,33, °C
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,0.0, Nm
ENG100625,Coolant temperature,71, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,0.0, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,0.0, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,0.0, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,0.0, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,0.0, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,0.0, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,0.0, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,0.0, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG98602,Driver intention torque,0.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG122533-ENG122530,Druckversorgung Anlauf Historie 2-Druckversorgung Anlauf Historie Fehler-ID,0,
ENG122533-ENG122531,Druckversorgung Anlauf Historie 2-Druckversorgung Anlauf Historie Index,0,
ENG122533-ENG159829,Druckversorgung Anlauf Historie 2-Fehlertyp vor evtl. Abbruch,kein_Fehler,
ENG122533-ENG159825,Druckversorgung Anlauf Historie 2-Flag Druckniveau bei Motorstart,P <= 20 bar,
ENG122533-ENG159826,Druckversorgung Anlauf Historie 2-Flag minimale Spannung unterschritten,Umin >= 9V,
ENG122533-ENG159827,Druckversorgung Anlauf Historie 2-Max. Spannungseinbruch (indiziert) im Motorlauf,U <= 0.5V,
ENG122533-ENG159830,Druckversorgung Anlauf Historie 2-Relativer zeitlicher Abstand relativ zum Motorlauf,T <= 100ms,
ENG122533-ENG159828,Druckversorgung Anlauf Historie 2-Zustand vor evtl. Abbruch,Do not cancel,
ENG120789,Druckversorgung Anlaufadaption zurücksetzen Status,0,
ENG101251,Empty,Empty,
ENG98756,Engine torque,24.0, Nm
ENG104230,Engine torque loss,24.0, Nm
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG120792,Fahrzeug-km-Stand letzte Veränderung der Anlaufadaption,655350, km
ENG120780,Fehler EEPROM Lesefehler Bits 0...15,00 00,
ENG120781,Fehler EEPROM Lesefehler Bits 16...31,00 00,
ENG120782,Fehler EEPROM Lesefehler Bits 32...47,00 00,
ENG120783,Fehler EEPROM Lesefehler Bits 47...63,00 00,
ENG120799,Gangsteller A Adaption Flags,00 0F,
ENG100414,Gangsteller A Adaption Neutralposition,-0.2, mm
ENG120797,Gangsteller A Ventil adaptierter Mittenstrom,530.0, mA
ENG120798,Gangsteller A Ventil adaptierter Nulllagenoffset,-4.9, mA
ENG120801,Gangsteller Adaption Synchronposition G1 Abbruch ursache,00 B0,
ENG120800,Gangsteller Adaption Synchronposition G1 Abbruch zähler,21,
ENG120810,Gangsteller Adaption Synchronposition G2 Abbruch ursache,00 F4,
ENG120809,Gangsteller Adaption Synchronposition G2 Abbruch zähler,0,
ENG120803,Gangsteller Adaption Synchronposition G3 Abbruch ursache,00 00,
ENG120802,Gangsteller Adaption Synchronposition G3 Abbruch zähler,0,
ENG120812,Gangsteller Adaption Synchronposition G4 Abbruch ursache,00 F4,
ENG120811,Gangsteller Adaption Synchronposition G4 Abbruch zähler,0,
ENG120819,Gangsteller Adaption Synchronposition G5 Abbruch ursache,00 B4,
ENG120818,Gangsteller Adaption Synchronposition G5 Abbruch zähler,1,
ENG120828,Gangsteller Adaption Synchronposition G6 Abbruch ursache,00 00,
ENG120827,Gangsteller Adaption Synchronposition G6 Abbruch zähler,5,
ENG120821,Gangsteller Adaption Synchronposition G7 Abbruch ursache,00 B4,
ENG120820,Gangsteller Adaption Synchronposition G7 Abbruch zähler,0,
ENG120830,Gangsteller Adaption Synchronposition GR Abbruch ursache,00 B0,
ENG120829,Gangsteller Adaption Synchronposition GR Abbruch zähler,123,
ENG126196-ENG126242,Gangsteller Ausbaulage-Zustand Welle 1 GS 13,1,
ENG126196-ENG126243,Gangsteller Ausbaulage-Zustand Welle 1 GS 57,N,
ENG126196-ENG126244,Gangsteller Ausbaulage-Zustand Welle 2 GS 24,N,
ENG126196-ENG126245,Gangsteller Ausbaulage-Zustand Welle 2 GS 6R,R,
ENG120786,Gangsteller Ausbaulage Status,0,
ENG120787,Gangsteller Ausbaulage Zustand / Abbruchcode,0,
ENG120808,Gangsteller B Adaption Flags,00 0F,
ENG100089,Gangsteller B Adaption Neutralposition,-0.3, mm
ENG120806,Gangsteller B Ventil adaptierter Mittenstrom,530.0, mA
ENG120807,Gangsteller B Ventil adaptierter Nulllagenoffset,-1.5, mA
ENG120817,Gangsteller C Adaption Flags,00 0F,
ENG103055,Gangsteller C Adaption Neutralposition,-0.2, mm
ENG120815,Gangsteller C Ventil adaptierter Mittenstrom,530.0, mA
ENG120816,Gangsteller C Ventil adaptierter Nulllagenoffset,-20.4, mA
ENG120826,Gangsteller D Adaption Flags,00 0F,
ENG101354,Gangsteller D Adaption Neutralposition,0.2, mm
ENG120824,Gangsteller D Ventil adaptierter Mittenstrom,530.0, mA
ENG120825,Gangsteller D Ventil adaptierter Nulllagenoffset,-6.4, mA
ENG120788,Gangsteller Defaultdaten setzten Status,3,
ENG120804,Gangsteller Einlegen Zähler G1,52698,
ENG120813,Gangsteller Einlegen Zähler G2,53934,
ENG120805,Gangsteller Einlegen Zähler G3,20245,
ENG120814,Gangsteller Einlegen Zähler G4,15094,
ENG120822,Gangsteller Einlegen Zähler G5,41610,
ENG120831,Gangsteller Einlegen Zähler G6,62366,
ENG120823,Gangsteller Einlegen Zähler G7,27899,
ENG120832,Gangsteller Einlegen Zähler GR,14570,
ENG126195-ENG126242,Gangsteller Neutral-Zustand Welle 1 GS 13,1,
ENG126195-ENG126243,Gangsteller Neutral-Zustand Welle 1 GS 57,N,
ENG126195-ENG126244,Gangsteller Neutral-Zustand Welle 2 GS 24,N,
ENG126195-ENG126245,Gangsteller Neutral-Zustand Welle 2 GS 6R,R,
ENG120784,Gangsteller Neutral Status,0,
ENG120785,Gangsteller Neutral Zustand / Abbruchcode,0,
ENG110510,Gear actuator adaption engaged position G1,8.9, mm
ENG110511,Gear actuator adaption engaged position G2,9.2, mm
ENG110512,Gear actuator adaption engaged position G3,-9.0, mm
ENG99484,Gear actuator adaption engaged position G4,-8.6, mm
ENG110513,Gear actuator adaption engaged position G5,9.6, mm
ENG110514,Gear actuator adaption engaged position G6,-8.0, mm
ENG110515,Gear actuator adaption engaged position G7,-8.3, mm
ENG110516,Gear actuator adaption engaged position GR,8.4, mm
ENG110517,Gear actuator adaption synchro position G1,3.2, mm
ENG110518,Gear actuator adaption synchro position G2,2.0, mm
ENG110519,Gear actuator adaption synchro position G3,-3.6, mm
ENG99198,Gear actuator adaption synchro position G4,-2.7, mm
ENG110520,Gear actuator adaption synchro position G5,2.7, mm
ENG110521,Gear actuator adaption synchro position G6,-2.1, mm
ENG110522,Gear actuator adaption synchro position G7,-3.0, mm
ENG110523,Gear actuator adaption synchro position GR,2.6, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung i.O.,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung i.O.,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,16.692,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,9.975,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,6.432,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,4.472,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,3.329,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,2.662,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,2.234,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,16.970,
ENG99720,Height info,1020, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,23.0, Nm
ENG99582,Intake air temperature,29, °C
ENG122357-ENG122524,Kommunikationsstatus Datenbus 1 MQB-ACC_06,received,
ENG122357-ENG122528,Kommunikationsstatus Datenbus 1 MQB-BEM_05,received,
ENG122357-ENG113024,Kommunikationsstatus Datenbus 1 MQB-Charisma_01,received,
ENG122357-ENG122523,Kommunikationsstatus Datenbus 1 MQB-Diagnose_01,received,
ENG122357-ENG122522,Kommunikationsstatus Datenbus 1 MQB-EPB_01,received,
ENG122357-ENG122513,Kommunikationsstatus Datenbus 1 MQB-ESP_02,received,
ENG122357-ENG122514,Kommunikationsstatus Datenbus 1 MQB-ESP_05,received,
ENG122357-ENG110808,Kommunikationsstatus Datenbus 1 MQB-ESP_07,received,
ENG122357-ENG122515,Kommunikationsstatus Datenbus 1 MQB-ESP_10,received,
ENG122357-ENG122516,Kommunikationsstatus Datenbus 1 MQB-ESP_19,received,
ENG122357-ENG122517,Kommunikationsstatus Datenbus 1 MQB-ESP_20,received,
ENG122357-ENG122518,Kommunikationsstatus Datenbus 1 MQB-ESP_21,received,
ENG122357-ENG122519,Kommunikationsstatus Datenbus 1 MQB-Gateway_72,received,
ENG122357-ENG122520,Kommunikationsstatus Datenbus 1 MQB-Gateway_74,received,
ENG122357-ENG122525,Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01,Unknown,
ENG122357-ENG131312,Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01,Unknown,
ENG122357-ENG110802,Kommunikationsstatus Datenbus 1 MQB-Kombi_01,received,
ENG122357-ENG122521,Kommunikationsstatus Datenbus 1 MQB-Kombi_02,received,
ENG122357-ENG110799,Kommunikationsstatus Datenbus 1 MQB-LWI_01,received,
ENG122357-ENG122512,Kommunikationsstatus Datenbus 1 MQB-Motor_04,received,
ENG122357-ENG122502,Kommunikationsstatus Datenbus 1 MQB-Motor_07,received,
ENG122357-ENG122503,Kommunikationsstatus Datenbus 1 MQB-Motor_11,received,
ENG122357-ENG122504,Kommunikationsstatus Datenbus 1 MQB-Motor_12,received,
ENG122357-ENG122505,Kommunikationsstatus Datenbus 1 MQB-Motor_14,received,
ENG122357-ENG122506,Kommunikationsstatus Datenbus 1 MQB-Motor_16,Unknown,
ENG122357-ENG122507,Kommunikationsstatus Datenbus 1 MQB-Motor_17,received,
ENG122357-ENG122529,Kommunikationsstatus Datenbus 1 MQB-Motor_18,Unknown,
ENG122357-ENG122508,Kommunikationsstatus Datenbus 1 MQB-Motor_20,received,
ENG122357-ENG122509,Kommunikationsstatus Datenbus 1 MQB-Motor_26,received,
ENG122357-ENG137653,Kommunikationsstatus Datenbus 1 MQB-Motor_35,received,
ENG122357-ENG122510,Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01,received,
ENG122357-ENG122526,Kommunikationsstatus Datenbus 1 MQB-OBD_01,received,
ENG122357-ENG122511,Kommunikationsstatus Datenbus 1 MQB-TSK_06,received,
ENG122357-ENG122527,Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03,received,
ENG120833,Kupplung 1 Adaption Grundkennline P1 Abbruch Zähler,0,
ENG100960,Kupplung 1 Adaption Grundkennlinie Bereich 1 Abbruch Ursache,00 00,
ENG99364,Kupplung 1 Adaption Grundkennlinie Bereich 1 Abbruch Zähler,0,
ENG104076,Kupplung 1 Adaption Grundkennlinie Bereich 1 Fahrzeug-km-Stand,92414, km
ENG99297,Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG102029,Kupplung 1 Adaption Grundkennlinie Bereich 2 Abbruch Ursache,00 00,
ENG103907,Kupplung 1 Adaption Grundkennlinie Bereich 2 Abbruch Zähler,0,
ENG99304,Kupplung 1 Adaption Grundkennlinie Bereich 2 Fahrzeug-km-Stand,92413, km
ENG102630,Kupplung 1 Adaption Grundkennlinie Bereich 2 Schnelladaptionen verbleibende Anzahl,0,
ENG103806,Kupplung 1 Adaption Grundkennlinie Bereich 3 Abbruch Ursache,00 00,
ENG100083,Kupplung 1 Adaption Grundkennlinie Bereich 3 Abbruch Zähler,0,
ENG102504,Kupplung 1 Adaption Grundkennlinie Bereich 3 Fahrzeug-km-Stand,92409, km
ENG100314,Kupplung 1 Adaption Grundkennlinie Bereich 3 Schnelladaptionen verbleibende Anzahl,0,
ENG120834,Kupplung 1 Adaption Grundkennlinie P1 Abbruch Ursache,00 00,
ENG99148,Kupplung 1 Adaption Grundkennlinie P1 km-Stand,92413, km
ENG120835,Kupplung 1 Adaption Kisspoint Teil 2 Erfolgszähler,0,
ENG120836,Kupplung 1 Adaption Kisspoint Teil 2 Fahrzeug-km-Stand,655350, km
ENG120839,Kupplung 1 Adaption Kisspoint Teil 2 Fehler ursache,0,
ENG120838,Kupplung 1 Adaption Kisspoint Teil 2 Fehler zähler,0,
ENG120840,Kupplung 1 Adaption Kisspoint Teil 2 Fehlerursache kumuliert,0,
ENG120837,Kupplung 1 Adaption Kisspoint Teil 2 verbleibende Schnelladaptionen,0,
ENG120841,Kupplung 1 Adaption Kupplungsendlage Erfolgszähler,3647,
ENG120842,Kupplung 1 Adaption Kupplungsendlage Fahrzeug-km-Stand,92360, km
ENG120843,Kupplung 1 Adaption Kupplungsendlage Fehlerzähler,2,
ENG120793,Kupplung 1 Ventil adaptierter Mittenstrom,510.0, mA
ENG120794,Kupplung 1 Ventil adaptierter Nulllagenoffset,-20.6, mA
ENG120917,Kupplung 1 Weg des P1 aus der letzten Grundeinmessung,11.40, mm
ENG99330,Kupplung 2 Adaption Grundkennlinie Bereich 1 Abbruch Ursache,00 00,
ENG101409,Kupplung 2 Adaption Grundkennlinie Bereich 1 Abbruch Zähler,0,
ENG103271,Kupplung 2 Adaption Grundkennlinie Bereich 1 Fahrzeug-km-Stand,92414, km
ENG100826,Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl,0,
ENG103246,Kupplung 2 Adaption Grundkennlinie Bereich 2 Abbruch Ursache,00 00,
ENG102885,Kupplung 2 Adaption Grundkennlinie Bereich 2 Abbruch Zähler,0,
ENG100753,Kupplung 2 Adaption Grundkennlinie Bereich 2 Fahrzeug-km-Stand,92414, km
ENG102173,Kupplung 2 Adaption Grundkennlinie Bereich 2 Schnelladaptionen verbleibende Anzahl,0,
ENG102648,Kupplung 2 Adaption Grundkennlinie Bereich 3 Abbruch Ursache,00 00,
ENG103978,Kupplung 2 Adaption Grundkennlinie Bereich 3 Abbruch Zähler,0,
ENG102303,Kupplung 2 Adaption Grundkennlinie Bereich 3 Fahrzeug-km-Stand,92410, km
ENG102820,Kupplung 2 Adaption Grundkennlinie Bereich 3 Schnelladaptionen verbleibende Anzahl,0,
ENG103369,Kupplung 2 Adaption Grundkennlinie P1 Abbruch Zähler,0,
ENG100946,Kupplung 2 Adaption Grundkennlinie P1 km-Stand,92413, km
ENG102345,Kupplung 2 Adaption Grundkennlinie P1 Zähler Abbruch Ursache,00 00,
ENG120844,Kupplung 2 Adaption Kisspoint Teil 2 Erfolgszähler,0,
ENG120845,Kupplung 2 Adaption Kisspoint Teil 2 Fahrzeug-km-Stand,655350, km
ENG120848,Kupplung 2 Adaption Kisspoint Teil 2 Fehler ursache,0,
ENG120847,Kupplung 2 Adaption Kisspoint Teil 2 Fehler zähler,0,
ENG120849,Kupplung 2 Adaption Kisspoint Teil 2 Fehlerursache kumuliert,0,
ENG120846,Kupplung 2 Adaption Kisspoint Teil 2 verbleibende Schnelladaptionen,0,
ENG120850,Kupplung 2 Adaption Kupplungsendlage Erfolgszähler,3517,
ENG120851,Kupplung 2 Adaption Kupplungsendlage Fahrzeug-km-Stand,92370, km
ENG120852,Kupplung 2 Adaption Kupplungsendlage Fehlerzähler,29,
ENG120795,Kupplung 2 Ventil adaptierter Mittenstrom,520.0, mA
ENG120796,Kupplung 2 Ventil adaptierter Nulllagenoffset,-12.2, mA
ENG120918,Kupplung 2 Weg des P1 aus der letzten Grundeinmessung,10.30, mm
ENG130280,Kupplung Adaption Kissp. max init. Beschleunigungsmoment Betrag,-0.6740, Nm
ENG120919,Laufzeit des Elektromotors,1012284.3, s
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,83.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,0, km
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.3, %
ENG102748,Selector lever error flags,00 00,
ENG101057,Specified idle speed,710, /min
ENG100803,Speed: output,0, /min
ENG122358-ENG122550,Start Stopp Statusinformationen aktuell-GE_StartStopp_Info,Stop release,
ENG122358-ENG122551,Start Stopp Statusinformationen aktuell-MO_StartStopp_Status,1,
ENG122358-ENG122500,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1,0,
ENG122358-ENG122501,Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2,0,
ENG122358-ENG122546,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 1,not active,
ENG122358-ENG122547,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 2,not active,
ENG122358-ENG122548,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 3,not active,
ENG122358-ENG122549,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 4,not active,
ENG122358-ENG122552,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 5,not active,
ENG122358-ENG122553,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 6,not active,
ENG122358-ENG122554,Start Stopp Statusinformationen aktuell-Stopp-Verbot-Grund 8,not active,
ENG120790,Status Anlaufadaption,00 00,
ENG122360-ENG122542,Status der Sonderfunktionen-Launch Control,Funktion nicht freigegeben,
ENG122360-ENG103585,Status der Sonderfunktionen-Segeln,Funktion freigegeben,
ENG122360-ENG122543,Status der Sonderfunktionen-Speicherdruckabbau,Funktion freigegeben,
ENG122361,Temperatur Hybrid,31, °C
ENG123021-ENG123022,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 0,6323156.4, s
ENG123021-ENG123023,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 1,861664.0, s
ENG123021-ENG123024,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 2,11188.5, s
ENG123021-ENG123025,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 3,0.0, s
ENG123021-ENG123026,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 4,0.0, s
ENG123021-ENG123027,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 5,0.0, s
ENG123021-ENG123028,Temperatur Kupplung Zentralplatte Zeit in Bereich 0-6-Zeit in Bereich 6,0.0, s
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG101346,Version info driving strategy,FEJRMRHEH.039,
ENG109005,Voltage Common Highside 1,12.9, V
ENG99955,Voltage Common Highside 2,12.9, V
ENG120913,xNm-Punkte für Welle 1: 1. Gang,5.8, mm
ENG120914,xNm-Punkte für Welle 1: 3. Gang,15.8, mm
ENG120915,xNm-Punkte für Welle 1: 5. Gang,6.6, mm
ENG120916,xNm-Punkte für Welle 1: 7. Gang,18.0, mm
ENG126197,xNm-Punkte für Welle 2: 2. Gang,8.6, mm
ENG126198,xNm-Punkte für Welle 2: 4. Gang,20.1, mm
ENG126199,xNm-Punkte für Welle 2: 6. Gang,10.5, mm
ENG126200,xNm-Punkte für Welle 2: R. Gang,21.5, mm
ENG120791,Zähler Adaptionausblendung,10,
ENG130281,Zähler für erfolgte Umschaltungen auf alte Kisspoint Adaption,0,
ENG122356-ENG122545,Zähler Systemdruckabbau-Zähler Systemdruckabbau erfolgreich,11062,
ENG122356-ENG122544,Zähler Systemdruckabbau-Zähler Systemdruckabbau erwartet,11211,
Elapsed Time: 00:50
;SW:5Q0-614-517-DL HW:5Q0-614-517-BP --- ABS Brakes
;Component:ESC H35 0113, Coding:46FA6A7DA0222473477E0602E2C62562560524E26047A4733822F078D2A24B0B00000523525212121035351919323200
;EV_Brake1UDSContiMK100IPB,049012,EV_Brake1UDSContiMK100IPB_049_VW27.rod
;Friday,25,April,2025,13:00:02:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 7EB0EE99E17B6A6BB8-802A
Group,Description,Actual
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,A127723,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.00000, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,1,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,1311,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,1794,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2025,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,25,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,11,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,12,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,17,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,14,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,16,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,18,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,59,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,41,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,52,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,45,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,9,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,57,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,6,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,32,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,30,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,37,
IDE03127,Prevented stop processes (ring memory),Inclination limit,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2024,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,10,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,8,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,11,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,23,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,26,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,5,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,8,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,16,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,15,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,17,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,27,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,37,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,25,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,16,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,21,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,14,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,13,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,1,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,23,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,47,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,18,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.000, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.928, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-0.758, bar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,-0.40, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 04 2020,
IDE04442-IDE00010,Vacuum sensor-Serial number,00 06 D6 07 F4,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,Available,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,5,
IDE04442,Vacuum sensor,-0.75, bar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,0,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.09810, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,0.03924, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.39240, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.180, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,38.894, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,38.894, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,92258, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXDRAD00029,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,26, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00012,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-759, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,-0.40, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,756, mbar
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,8.5, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,8.5, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,11601,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,11601,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,92063, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Available,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Slope,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),-1, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,Available,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,253,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,253,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,253,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,253,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,92138, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,84711, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,92075, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,92075, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,89560, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,84434, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,84404, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,84403, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,Available,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,Condition met,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,On,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,131633,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,543640,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,10723,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,24827,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 33 32 35 32 30 33 30 30 30 30 36 32 30 32 31 36 30 30 35 42 33 2F 02 02 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,99.9936, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,107.806, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,100.775, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,12096,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,102.337, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,19174,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,105.462, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,5800,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,103.9, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,10169,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,8.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,8.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,8.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,8.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00210-IDE80007,Parking Brake-Analysis 7,1988, km
MAS00210-IDE80008,Parking Brake-Analysis 8,92138, km
MAS00210-IDE80009,Parking Brake-Analysis 9,92414, km
MAS00210-IDE80010,Parking Brake-Analysis 10,0, km
MAS00210-IDE80011,Parking Brake-Analysis 11,92414, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG167752,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG167753,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG167754,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG167755,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG167756,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG167757,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Not available due to specific system,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG157353-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
;SW:3Q0-959-435-N HW:3Q0-959-435-N --- Acc/Start Auth.
;Component:VWKESSYMQB 037 1307, Coding:132C0C0723
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB_VW27.rod
;Friday,25,April,2025,13:00:19:35871
;VCID: 45C24175C42DF9B3B9-8010
IDE00019,Voltage terminal 30,12.921, V
IDE00021,Engine speed,710.0, /min
IDE00021-MAS02248,Engine speed-Signal state,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal state,valid,
IDE00096-MAS02248,Selector lever position-Signal state,Current,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver door,closed,
IDE02408-MAS00219,Individual door locking: status-Front Passenger Door,closed,
IDE02408-MAS00220,Individual door locking: status-Rear left door,closed,
IDE02408-MAS00221,Individual door locking: status-Rear right door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,54,
IDE02419,Proximity sensor frt.pass. door: number of triggers,240,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,31,
IDE02422-MAS01483,Driver door handle: version information-Software version,17,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,AA,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,31,
IDE02423-MAS01483,ass. door handle: version information-Software version,17,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,AA,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,00,
IDE02424-MAS01483,Left rear door handle: version information-Software version,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,00,
IDE02425-MAS01483,Right rear door handle: version information-Software version,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,Yes,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,Yes,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,Yes,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72h-Signaling counter left rear door,0,
IDE02485,72h-Signaling counter right rear door,0,
IDE02495,Service-Key: Number of activations,4346,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal state,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,5,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,14,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2023,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,6,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,4,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,7,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,23,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,11,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,23,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,28,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,39,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,24,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,34,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,10,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,ID sensor not found,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,ID sensor not found,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Missing from ECM,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Missing from ECM,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Missing from ECM,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Empty,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,UID_MONITORING,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,UID_SEARCH,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,A2,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,KEY_MINDER,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,ENTRY_WITHOUT_PROXIMITY,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,DRIVER_FRONT,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,A4,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,62,
IDE05204,Manufacturer production data door handle drivers door,1F 07 21 9A 62,
IDE05205,Manufacturer production data door handle front pass.door,1F 07 21 9A 52,
IDE05206,Manufacturer production data door handle left rear,00 00 00 00 00,
IDE05207,Manufacturer production data door handle right rear,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,100,
IDE08440,Recommendation energy management,no restriction,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2020,
IDE80258-MAS00107,Immobilizer status-Month,3,
IDE80258-MAS00108,Immobilizer status-Day,6,
IDE80258-MAS00109,Immobilizer status-Hours,11,
IDE80258-MAS00110,Immobilizer status-Minutes,19,
IDE80258-MAS00111,Immobilizer status-Seconds,27,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,0,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,26,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,228,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,92414, km
MAS01493,Engine running,active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop active in Start/Stop mode,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG160891,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG160890,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG160889,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG160888,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,12.921, V
ENG139762,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG245551,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2024,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2025,
ENG125220-MAS00107,History last automatic terminal switch off-Month,4,
ENG125220-MAS00107,History last automatic terminal switch off-Month,6,
ENG125220-MAS00107,History last automatic terminal switch off-Month,5,
ENG125220-MAS00108,History last automatic terminal switch off-Day,7,
ENG125220-MAS00108,History last automatic terminal switch off-Day,17,
ENG125220-MAS00108,History last automatic terminal switch off-Day,28,
ENG125220-MAS00108,History last automatic terminal switch off-Day,5,
ENG125220-MAS00108,History last automatic terminal switch off-Day,21,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,4,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,13,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,17,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,9,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,22,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,13,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,56,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,16,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,43,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,16,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,55,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,38,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,2,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,58,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,81480, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,81659, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,82260, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,92138, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,81191, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG249150-MAS00111,History_low_voltage-Seconds,0, s
ENG249150-MAS00111,History_low_voltage-Seconds,2766715, s
ENG249150-ENG249469,History_low_voltage-Function_restriction_n,With_function_restriction,
ENG249150-ENG249453,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG249150-ENG249295,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG249150-ENG249381,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG249150-ENG249352,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG249150-ENG249461,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG249150-ENG249401,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG249150-ENG249354,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG249150-ENG249339,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG249150-ENG249350,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG157998-MAS00106,lf_shutdowns-Year,2000,
ENG157998-MAS00106,lf_shutdowns-Year,2021,
ENG157998-MAS00106,lf_shutdowns-Year,2023,
ENG157998-MAS00107,lf_shutdowns-Month,0,
ENG157998-MAS00107,lf_shutdowns-Month,11,
ENG157998-MAS00107,lf_shutdowns-Month,2,
ENG157998-MAS00108,lf_shutdowns-Day,13,
ENG157998-MAS00108,lf_shutdowns-Day,0,
ENG157998-MAS00108,lf_shutdowns-Day,19,
ENG157998-MAS00109,lf_shutdowns-Hours,10,
ENG157998-MAS00109,lf_shutdowns-Hours,16,
ENG157998-MAS00109,lf_shutdowns-Hours,0,
ENG157998-MAS00110,lf_shutdowns-Minutes,0,
ENG157998-MAS00110,lf_shutdowns-Minutes,10,
ENG157998-MAS00110,lf_shutdowns-Minutes,15,
ENG157998-MAS00111,lf_shutdowns-Seconds,0,
ENG157998-MAS00111,lf_shutdowns-Seconds,37,
ENG157998-MAS00111,lf_shutdowns-Seconds,52,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,72659, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,13253, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,15,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,92144, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,92144, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,92138, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,92138, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,92138, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,92138, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,92138, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,92093, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,92093, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,92093, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,92093, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,92093, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,92138, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,92138, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,92138, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,92138, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,92138, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,92138, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,92138, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,92138, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,19,
ENG157420-ENG161149,Scan_cycle_data-Retry_count_n -6,9,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,9,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,9,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,11,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,9,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,10,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,9,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,63,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,9,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,10,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,9,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,9,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,9,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,10,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,9,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,10,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,26,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,9,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,19,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,Driver_door,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,rear_left_door,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,Driver_door,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,Driver_door,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,Passenger_door,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,rear_right_door,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,Passenger_door,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Reset_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Reset_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Reset_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Reset_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Reset_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Reset_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Set_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Reset_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Reset_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Reset_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2025,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,4,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,25,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00109,service_key_internal_status-Hours,9,
ENG129035-MAS00110,service_key_internal_status-Minutes,41,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,2,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK.,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG139702-ENG140253,WFS_key_signature-clap_15_activateing_signature,02,
ENG139702-ENG140248,WFS_key_signature-signature_key_1,05 70,
ENG139702-ENG140249,WFS_key_signature-signature_key_2,02 73,
ENG139702-ENG140250,WFS_key_signature-signature_key_3,00 00,
ENG139702-ENG140251,WFS_key_signature-signature_key_4,00 00,
ENG139702-ENG140252,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:19
;SW:5G1-907-044-AR HW:5G1-907-044-AR --- Auto HVAC
;Component:Climatronic H04 2401, Coding:060200042001100D1105000C00101036
;EV_ACClimaBHBVW37X,006151,EV_ACClimaBHBVW37X_006_VW27.rod
;Friday,25,April,2025,13:01:02:35871
;VCID: 78BCF881C35F545BF2-802C
IDE00019,Voltage terminal 30,12.9, V
IDE00021,Engine speed,700, /min
IDE00025,Coolant temperature,74, °C
IDE00198,Refrigerant pressure,4.8, bar
IDE00767,No. of unscheduled ECU resets,63,
IDE00965,Compressor shut-off condition,Compressor switch-on reduction,
IDE00966,Compressor current: actual value,0.000, A
IDE00967,Compressor current: specified value,0.000, A
IDE00968,Compressor speed,800, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,13.5, °C
IDE00974,Outside air temperature internally calculated,12.5, °C
IDE00976,Left front vent temperature,26.3, °C
IDE00977,Right front vent temperature,26.3, °C
IDE00981,Footwell vent temperature,34.7, °C
IDE00982,Temperature downstream of evaporator,17.3, °C
IDE00983,Inside temperature,25.5, °C
IDE00984,Sun intensity left,90, W/m²
IDE00985,Sun intensity right,90, W/m²
IDE00987,Blower voltage: specified value,4.4, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,96,
IDE00994,Actual value for fresh air/recirculation air flow flap,33.0, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,94,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,213,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,38,
IDE00998,Left temperature flap - actual value,80,
IDE00998,Left temperature flap - actual value,26.0, %
IDE00999,Temperature door left - Specified value,80,
IDE01040,Left Temperature Control Door - cold stop,26,
IDE01041,Left temperature flap: warm stop,231,
IDE01042,Right temperature flap: actual value,85,
IDE01042,Right temperature flap: actual value,28.0, %
IDE01043,Temperature door right - Specified value,85,
IDE01044,Right temperature flap: cold stop,27,
IDE01045,Right temperature flap: warm stop,231,
IDE01050,Front air distribution flap: actual value,29.5, %
IDE01050,Front air distribution flap: actual value,87,
IDE01051,Air distribution door front - Specified value,89,
IDE01052,Front air distribution flap: air outlet stop,235,
IDE01053,Front air distribution flap: footwell air outlet stop,25,
IDE01054,Defroster flap: actual value,79.0, %
IDE01054,Defroster flap: actual value,185,
IDE01055,Defrost door - Specified value,186,
IDE01056,Defroster flap: stop open,228,
IDE01057,Defroster flap: stop closed,19,
IDE01063,Status of recirculation air,recirc. due to back pressure portion,
IDE01066,Convertible top status,Closed,
IDE01076,Time since ignition off,172, min
IDE01217-MAS01447,Left heated seat stage-Act.val.,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Act.val.,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,4.4, V
IDE01227,Blower current,2.00, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, min
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,16807,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,2,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Parking heater,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01443,Left push-and-rotary knob counter,0,
IDE01444,Right push-and-rotary knob counter,0,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxil. heat mode,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05009,Start process requested-A/C request: auxil. heat mode,not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,171,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,2189,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,1396,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),35,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),238,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxil. heat mode,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,2,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,139,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),8,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),53,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxil. heat mode,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2025,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,24,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,46,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,37,
IDE03127,Prevented stop processes (ring memory),Interior vent difference to setting,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2025,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,1,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,12,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,17,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,24,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,37,
IDE03128,Requested start processes (ring memory),Interior vent difference to setting,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04797,Center push-and-rotary knob counter,0,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,5,
IDE04805-MAS01448,Driving profile selection-Specified value,5,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,232,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,24.7, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,24.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,39.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,9.8, °C
IDE06235,Potentiometer for rear vent temperature,255,
IDE07991-MAS04446,A/C clutch-Relay activation status,not active,
IDE12141-MAS00106,History memory: parking heater-Year,2127,
IDE12141-MAS00107,History memory: parking heater-Month,15,
IDE12141-MAS00108,History memory: parking heater-Day,31,
IDE12141-MAS00109,History memory: parking heater-Hours,31,
IDE12141-MAS00110,History memory: parking heater-Minutes,63,
IDE12141-MAS00111,History memory: parking heater-Seconds,63,
IDE12141-MAS02526,History memory: parking heater-Activation,Measuring value not available,
IDE12141-MAS04390,History memory: parking heater-Active source,Measuring value not available,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,13,
Elapsed Time: 00:13
;SW:5Q0-937-084-DG HW:5Q0-937-084-CF --- Cent. Elect.
;Component:BCM MQBAB M+ H42 0312, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,020001,EV_BCMBOSCH_020_VW27.rod
;Friday,25,April,2025,13:01:21:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 004C90619B8F1C9BCA-8054
Group,Description,Actual
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded/not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded/not installed,
IDE00550-IDE00047,Identification of parameterization-Parameter set version,12 01,
IDE00844-MAS07314,Switch for engine hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for engine hood-Bonnet_Magnetic_Lock,Measuring value not available,
IDE00973,Outside temperature,13.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded/not installed,
IDE01066,Convertible top status,not coded/not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded/not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded/not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded/not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded/not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlocking button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded/not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS02447,Tailgate condition-Release,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not active,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,No,
IDE02515,Low beam,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not coded/not installed,
IDE02711,Rear wiper,not active,
IDE02743,High Beam,|Connector number,Connector terminal number
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,73,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,177, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,No malfunction,
IDE02857-ENG128455,Activation current-Cockpittaster_2,No malfunction,
IDE02857-ENG128456,Activation current-Cockpittaster_3,No malfunction,
IDE02857-ENG128457,Activation current-Cockpittaster_4,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,144, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,16.3, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,12.8, V
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,21.00, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,16.00, °C
IDE03504,Personalized settings,|profile,Comfort opening
IDE03638,Stationary cornering lamp,|Connector number,Connector terminal number
IDE04213,Central locking button,not coded/not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded/not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE02515,Expanded freeze frame conditions-Low beam,Not operated,
IDE04347-IDE04639,Expanded freeze frame conditions-Last wake-up cause,Kessy Prompt Wire,
IDE04347-IDE07956,Expanded freeze frame conditions-redundant signal line,infinite,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,13.5, °C
IDE04347-MAS02462,Expanded freeze frame conditions-Automatic high beam assist,operated,
IDE04347-MAS02788,Expanded freeze frame conditions-CAN,On,
IDE04347-MAS03835,Expanded freeze frame conditions-Position lamps,Not operated,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.8, V
IDE04347-MAS06466,Expanded freeze frame conditions-Parking light left,Not operated,
IDE04347-MAS06467,Expanded freeze frame conditions-Parking light right,Not operated,
IDE04347-MAS14232,Expanded freeze frame conditions-Light switch: zero setting,Not operated,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04925,Daytime running lights,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Duty cycle,20.50, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded/not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded/not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,212200,
IDE05045-MAS05878,Front wiper module-Stage,Stage 1,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05533,Heater for nozzles,active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded/not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded/not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beam,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,Not operated,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not active,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,No,
IDE05824-MAS04583,DWA Vehicle inclination sensor: angle-Reference angle: X-axis,-19.40, °
IDE05824-MAS04584,DWA Vehicle inclination sensor: angle-Reference angle: Y-axis,-1.80, °
IDE05824-MAS04585,DWA Vehicle inclination sensor: angle-Reference angle: Z-axis,Implausible,
IDE05824-MAS04586,DWA Vehicle inclination sensor: angle-Angle difference: X-axis,0.00, °
IDE05824-MAS04587,DWA Vehicle inclination sensor: angle-Angle difference: Y-axis,0.00, °
IDE05824-MAS04588,DWA Vehicle inclination sensor: angle-Angle difference: Z-axis,Implausible,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not active,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded/not installed,
IDE05828-MAS06608,DWA History data for alarm triggering-Cause for last alarm activation,No alarm,
IDE05828-MAS06609,DWA History data for alarm triggering-Cause for second-to-last alarm activation,No alarm,
IDE05828-MAS06610,DWA History data for alarm triggering-Cause for third-to-last alarm activation,No alarm,
IDE05828-MAS06611,DWA History data for alarm triggering-Cause for fourth-to-last alarm activation,No alarm,
IDE05828-MAS06613,DWA History data for alarm triggering-Number of alarm activations,0,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date
IDE05830-MAS02282,Rear Spoiler-Position,not coded/not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded/not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded/not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded/not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded/not installed,
IDE05832,DWA Number of alarms triggered in anti-theft warn.system sensor,2,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Odometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,26000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,5388, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,terminal
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.6, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,25.0, °C
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.9, °C
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,0.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,105.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,100.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,40, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded/not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded/not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,OFF,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded/not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded/not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,Not operated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,On,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded/not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded/not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded/not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded/not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded/not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded/not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-ENG247157,Wireless transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG247187,Wireless transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,30.00, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,798.7, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Release,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Norming,not normed,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Not operated,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,Closed,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left head area heater-Operating condition,not coded/not installed,
IDE08125-MAS06651,Left head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08125-MAS06652,Left head area heater-Blower motor: speed,not coded/not installed,
IDE08125-MAS06653,Left head area heater-Indicator light for head area heater,not coded/not installed,
IDE08126-MAS01458,Right head area heater-Operating condition,not coded/not installed,
IDE08126-MAS06651,Right head area heater-PTC heater element: current consumption,not coded/not installed,
IDE08126-MAS06652,Right head area heater-Blower motor: speed,not coded/not installed,
IDE08126-MAS06653,Right head area heater-Indicator light for head area heater,not coded/not installed,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded/not installed,
IDE08211-MAS03129,History data control module reset-Reset counter,14,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08343,Immobilizer Challenge,C8 87 D7 E5,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,736, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,688, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,23, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,23, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,23, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,22, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded/not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded/not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded/not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,not installed / not active,
IDE11134-IDE02515,Light sequence HU test result-Low beam,not installed / not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,not installed / not active,
IDE11134-IDE02743,Light sequence HU test result-High Beam,not installed / not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,not installed / not active,
IDE11134-IDE03638,Light sequence HU test result-Stationary cornering lamp,not installed / not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,not installed / not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,not installed / not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,not installed / not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,327670, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,327670, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded/not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded/not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded/not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded/not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded/not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded/not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded/not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,not installed,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,Intermittent operation,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded/not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded/not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded/not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,Movement sensor faulty,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,Movement sensor faulty,
IDE14172-MAS03695,Remote key movement information-Key 4,Movement sensor faulty,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Head area heater-Crash status,not coded/not installed,
IDE80251-MAS06646,Head area heater-Head area heater left: specified level,not coded/not installed,
IDE80251-MAS06647,Head area heater-Head area heater right: specified level,not coded/not installed,
IDE80251-MAS06648,Head area heater-Continuation at terminal 15 on,not coded/not installed,
IDE80251-MAS06649,Head area heater-Left front seat occupation status,not coded/not installed,
IDE80251-MAS06650,Head area heater-Right front occupation status,not coded/not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.85, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.85, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.90, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.85, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,12.85, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,12.90, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.38, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00043-ENG250713,Terminal 30 power supply-Messauswertung Pruefspannung Wischerablagenheizung,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,13,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,49,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,228,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,92414, km
MAS00829-MAS00244,Access/start authorization-Prompt wire,operated,
MAS00829-MAS01763,Access/start authorization-Signal Strength,-61,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281,Back-up lamp,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge level,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,NOT-DEFINED,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Head area heater,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,175,
MAS01490-MAS05795,Energy management-Rear seat heater,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-down,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Front seat heating,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,126, %
MAS01597-MAS02447,Sunroof-Release,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Norming,not normed,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded/not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
ENG116910,Control unit internal measured value (supplier),00 00 00 05 1A 00 0D 00 1A 00 1A 00 1A 00 67 01 60 23 53 00 00 00 00 00 00 00 00 00 00 00 00 02 00 02 00 09 7B 94 00 00 0C 13 00 00 00 03 00 00 00 03 00 00 00 00 55 50 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 0A 06 0B 00 00 00 00 00 00 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 04 00 00 00 00 00 00 50 64 09 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 08 81 14 4F 00 00 10 00 04 4C 20 34 00 20 00 00 40 08 00 02 6B 1F 00 00 09 91 AC A3 00 3B 00 00 00 00 00 00 00 00 00 00 03 00 08 01 00 00 00 00 01 00 00 00 4A 08 00 00 00 8F,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,2,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin C14 Kessy Weckleitung,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,1293,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,2122,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|6|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG247080-IDE10662,light_swich_module-Light switch (button module),not coded/not installed,
ENG247080-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded/not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,active,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded/not installed,
ENG116909-ENG114950,LIN activity-LIN 5,not coded/not installed,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 30 00 50 7E 7F 50 50 7E 50 50 50 7F 50 50 50 50 14 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 78 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Account,Key number
ENG126652-MAS03692,Personalized_key__Setting-Key 1,1,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,1,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Konto,Perso_Steuerung
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|19|0|10|0|19|0|19|0|19|0|,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,04 03 18,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 05 00 1A 00 0C 00 0C 00 0C 00 0C 66 00 A4 A3 00 00 00 00 00 00 00 00 00 00 00 00 00 88 00 03 00 04 21 50 00 00 0C 13 00 00 00 03 00 00 0C 13 00 00 00 00 55 50 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 10 06 0C 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 00 00 00 00 00 00 4E 64 07 17 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 04 00 09 01 02 0B 00 00 00 00 04 4C 20 34 00 20 00 00 00 00 00 00 00 00 00 00 08 13 0A EB 00 3B 00 00 00 00 00 00 00 00 00 00 01 00 01 05 00 00 00 00 01 00 00 00 73 07 00 00 00 8F,
ENG116790-MAS00711,Supply voltage history-Odometer reading,90147, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.3, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,13.3, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.8, V
ENG116791,Temperatures,13.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG161085,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG161099,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG161147,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG161254,Valeo_Entwickler_MWB-WakeUp2,OFF,
Elapsed Time: 00:44
blockmap-10-5QA-919-294-G_WVGZZZA1ZLV127723-20250425-1302.CSV
;SW:5QA-919-294-G HW:5QA-919-294 --- Park/Steer Assist
;Component:PDC 8 Kanal H08 0061, Coding:0471055811
;EV_EPHVA18AU3700000,009046,EV_EPHVA18AU3700000_009_VW27.rod
;Friday,25,April,2025,13:02:09:35871
;VCID: 50EC60210B6F2C1B1A-8004
IDE00018,Voltage terminal 15,12.5, V
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00974,Outside air temperature internally calculated,8.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,Malfunction,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,Malfunction,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,Malfunction,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,Malfunction,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,Malfunction,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,Malfunction,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,Malfunction,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 1,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 7,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Parking aid button,Not operated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,12.5, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio lowering request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,Parking aid active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Driving direction,forward,
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,No shut-off requirement,
IDE01943,Turn signal lamp,Not operated,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,08 11,
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,08 11,
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,08 1A,
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,08 16,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,97, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,39, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,44, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,50, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,26, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,1, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,87, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,1,
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,0,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2023,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2057,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2026,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2000,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2014,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,8,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,7,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,9,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,14,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,2,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,27,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,7,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,14,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,16,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,48,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,57,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,4,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,22,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,0,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,30,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,1,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-20.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,8.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,34.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,3.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,3.8, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,0.3, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,6.2, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,4.4, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,6.2, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,4.7, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,4.4, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-5.0, m
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,19,
MAS01426,Rear parking aid buzzer: volume,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 1,
MAS01428,Front parking aid buzzer: volume,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 7,
MAS10122,ARA operating condition,Initialization,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
MAS16451-IDE11215,Personalization 5-Automatic Activation,activated,
MAS16451-IDE11217,Personalization 5-Show parking space,not activated,
MAS16451-MAS01426,Personalization 5-Rear parking aid buzzer: volume,Stage 4,
MAS16451-MAS01427,Personalization 5-Speaker frequency for rear park assist,Stage 1,
MAS16451-MAS01428,Personalization 5-Front parking aid buzzer: volume,Stage 4,
MAS16451-MAS01429,Personalization 5-Speaker frequency for front park assist,Stage 7,
MAS16451-MAS06197,Personalization 5-Profile 5,not active,
MAS16451-MAS12843,Personalization 5-Maneuvering brake function,activated,
MAS16452-IDE11215,Personalization 6-Automatic Activation,activated,
MAS16452-IDE11217,Personalization 6-Show parking space,not activated,
MAS16452-MAS01426,Personalization 6-Rear parking aid buzzer: volume,Stage 4,
MAS16452-MAS01427,Personalization 6-Speaker frequency for rear park assist,Stage 1,
MAS16452-MAS01428,Personalization 6-Front parking aid buzzer: volume,Stage 4,
MAS16452-MAS01429,Personalization 6-Speaker frequency for front park assist,Stage 7,
MAS16452-MAS06198,Personalization 6-Profile 6,not active,
MAS16452-MAS12843,Personalization 6-Maneuvering brake function,activated,
MAS16453-IDE11215,Personalization 7-Automatic Activation,activated,
MAS16453-IDE11217,Personalization 7-Show parking space,not activated,
MAS16453-MAS01426,Personalization 7-Rear parking aid buzzer: volume,Stage 4,
MAS16453-MAS01427,Personalization 7-Speaker frequency for rear park assist,Stage 1,
MAS16453-MAS01428,Personalization 7-Front parking aid buzzer: volume,Stage 4,
MAS16453-MAS01429,Personalization 7-Speaker frequency for front park assist,Stage 7,
MAS16453-MAS06199,Personalization 7-Profile 7,not active,
MAS16453-MAS12843,Personalization 7-Maneuvering brake function,activated,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,90, %
Elapsed Time: 00:14
;SW:2Q0-907-572-R HW:2Q0-907-572-B --- Auto Dist. Reg
;Component:ACCCONTIMQB H03 0372, Coding:320467C25CFF8748949C810580408700000000000000000004
;EV_ACCMRRCONTIVW376,003016,EV_ACCMRRCONTIVW376_003_VW27.rod
;Friday,25,April,2025,13:02:26:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 43C65F6DCA19C78397-8016
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,12.8, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,43, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,Not operated,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG161056,ACC operating lever signal-distance_control_minus,Not operated,
IDE01794-ENG161057,ACC operating lever signal-distance_control_plus,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,VW_MFL_Gen2,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG161234,ACC operating lever signal-tip_down_in_step_1,Not operated,
IDE01794-ENG161235,ACC operating lever signal-tip_down_in_step_2,Not operated,
IDE01794-ENG161236,ACC operating lever signal-tip_up_in_step_1,Not operated,
IDE01794-ENG161237,ACC operating lever signal-tip_up_in_step_2,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,5E E4 09 56,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead starts driving: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead starts driving: ACC off,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,4,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead starts driving: ACC passive,4003,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead starts driving: ACC off,1093,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off disabled,3,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead starts driving: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead starts driving: ACC passive,602,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead starts driving: ACC off,98,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,83 D8 A9 C6 A2 5F 95 2F 9A C7 07 19 CE 81 32 39 60 7F 0F D0 B2 94 86 3E 82 8C 6E 19 B5 2D 10 04 55 7F E1 1D 37 CC AA 45 46 81 1C 27 FC 2B F2 07 70 6D DB 7B B4 F2 A4 92 00 FF C0 96 82 48 8D E2 81 FD 83 D6 B5 E3 F7 E4 67 2E D3 F9 9D 81 9C E5 C9 71 C8 76 21 BE 13 C4 26 06 D9 15 EE 1A 8D A0 DF 31 66 C3 AA 82 99 AD 2B 38 92 4F BD C5 D6 3C C2 2A 6C 5C AB 63 ED 39 D2 0E B5 FA 98 58 37 EF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Act.val.,5,
IDE04805-MAS01448,Driving profile selection-Specified value,5,
IDE05228,Operating hour counter,73215, min
IDE05814,Individualization characteristic,65 C7 DD F0 E4,
IDE06307-MAS00106,Stop prevention history data-Year,2025,
IDE06307-MAS00107,Stop prevention history data-Month,4,
IDE06307-MAS00108,Stop prevention history data-Day,25,
IDE06307-MAS00109,Stop prevention history data-Hours,9,
IDE06307-MAS00110,Stop prevention history data-Minutes,52,
IDE06307-MAS00111,Stop prevention history data-Seconds,54,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Vehicle ahead starts driving: ACC passive,
IDE06308-MAS00106,Start request history data-Year,2025,
IDE06308-MAS00107,Start request history data-Month,4,
IDE06308-MAS00108,Start request history data-Day,25,
IDE06308-MAS00109,Start request history data-Hours,9,
IDE06308-MAS00110,Start request history data-Minutes,44,
IDE06308-MAS00111,Start request history data-Seconds,55,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,Vehicle ahead starts driving: ACC passive,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,-0.067, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,2020,
IDE09380-MAS00107,Performed adjustment-Month,3,
IDE09380-MAS00108,Performed adjustment-Day,6,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.06, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.24, °
IDE09906,Vertical deadjustment,-0.641, °
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,-56.400, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,-0.215, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,Wiper active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,-0.067, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,-1.286, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2025,
IDE10903-MAS00107,Expanded ambient data 2-Month,4,
IDE10903-MAS00108,Expanded ambient data 2-Day,24,
IDE10903-MAS00109,Expanded ambient data 2-Hours,17,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,23,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,31,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,92242, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,-0.060, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,0.240, °
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,99, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,99, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,77, %
IDE10903-ENG277837,Expanded ambient data 2-Blindness_indicator_7,0, %
IDE10903-ENG277838,Expanded ambient data 2-Blindness_indicator_8,26, %
IDE10903-ENG277839,Expanded ambient data 2-Blindness_indicator_bit_1,1,
IDE10903-ENG277840,Expanded ambient data 2-Blindness_indicator_bit_2,0,
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,10,
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,-0.070, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-0.640, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.060, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,0.240, °
IDE12062,Counter for terminal 15 reset,11782,
ENG254667,Freeze_Frame_Dataset_Sensor_01,FF FF 66 B8 FF F5 80 69 FF FA 00 18 00 00 69 00 29 0A 00 04 9D 10 C0 C8 C9 38 00 59 00 06 00 58 00 00 00 00,
ENG254668,Freeze_Frame_Dataset_Sensor_02,FF FF 66 B8 FF FC 39 99 FF FA 00 18 01 00 0D 00 00 0A 00 04 AB 30 C1 21 EE 4A 4F 3F 5B 4F 22 3B 00 0F 00 00,
ENG254669,Freeze_Frame_Dataset_Sensor_03,FF FF 66 8B FF F4 82 AF FF FA 00 18 01 FD CC FF 29 0A 00 05 A1 48 CA 62 2B BE 00 63 00 63 00 4D 00 1A 80 00,
ENG254670,Freeze_Frame_Dataset_Sensor_04,FF FF 6F 9C FF FA 73 20 FF FA 00 18 01 00 04 FF F4 0A 00 03 F0 54 B8 ED 39 60 4F 58 00 01 00 2A 60 5F 00 00,
ENG254671,Freeze_Frame_Dataset_Sensor_05,FF FF 6F 9C FF F4 96 D9 FF FA 00 18 01 FF D9 FF EC 0A 00 04 22 3C BB 5D A4 6A 4E 48 00 63 56 52 14 61 00 00,
ENG254672,Freeze_Frame_Dataset_Sensor_06,FF FE E5 64 FF FA E5 FE FF FA 00 18 01 FF 63 FF A6 0A 00 04 74 C0 BD ED CA B6 00 63 00 63 00 2C 00 05 80 00,
ENG254673,Freeze_Frame_Dataset_Sensor_07,FF FF 66 B8 FF FA E5 FE FF FA 00 18 00 00 0A FF FD 0A 00 04 77 F8 BE 05 B3 A0 00 63 00 63 00 63 00 45 80 00,
ENG254674,Freeze_Frame_Dataset_Sensor_08,FF FF 66 B8 FF FA E5 FE FF FA 00 18 00 00 35 00 2F 0A 00 04 78 00 BE 05 C2 42 00 62 00 62 00 00 00 00 80 00,
ENG254675,Freeze_Frame_Dataset_Sensor_09,FF FF 66 B8 FF FA E5 FE FF FA 00 18 00 01 80 00 34 0A 00 04 78 10 BE 05 CA 92 00 63 00 63 00 00 00 01 80 00,
ENG254676,Freeze_Frame_Dataset_Sensor_10,FF FF 66 B8 FF F5 80 69 FF FA 00 18 00 FF 6F FF B6 0A 00 04 9A A0 C0 BD CB 60 00 63 00 63 00 00 00 00 80 00,
ENG254677,Freeze_Frame_Dataset_Sensor_11,FF FF 66 B8 FF F5 80 69 FF FA 00 18 00 FF 1A FF A5 0A 00 04 9A F4 C0 BD DC 4E 00 63 00 63 00 27 00 35 80 00,
ENG254678,Freeze_Frame_Dataset_Sensor_12,FF FF 66 B8 FF F5 80 69 FF FA 00 18 00 00 07 FF FF 0A 00 04 9C BC C0 C8 BA 88 00 63 00 63 00 5D 00 1D 80 00,
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,4311, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,4248, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,63, min
ENG131993,Operating_time_ACC_active_timegap_1,293, min
ENG131994,Operating_time_ACC_active_timegap_2,270, min
ENG131995,Operating_time_ACC_active_timegap_3,3743, min
ENG131996,Operating_time_ACC_active_timegap_4,2, min
ENG131997,Operating_time_ACC_active_timegap_5,2, min
ENG132001,Operating_time_ACC_active_v-delta_0,0, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,4311, min
Elapsed Time: 00:16
;SW:3Q0-959-655-CM HW:3Q0-959-655-CM --- Airbags
;Component:Airbag VW21 006 0720, Coding:88CCC0C0000000005C5400CF000840000065
;EV_AirbaVW21TS6VW48X,001014,EV_AirbaVW21TS6VW48X_VW27.rod
;Friday,25,April,2025,13:02:48:35871
;VCID: 0B56B74DA2C94FC3AF-805E
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.8, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,no measured value present,
IDE01102,Driver thorax airbag igniter ohm value,2.3, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.2, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.1, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,no measured value present,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,no measured value present,
IDE01114,Driver side belt force limiter igniter ohm value,no measured value present,
IDE01115,side belt force limiter igniter ohm value,no measured value present,
IDE01116,driver side rear belt tensioner igniter ohm value,2.1, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.1, Ohm
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,400.0, Ohm
IDE01197,Key switch contact 1 ohm value,680.0, Ohm
IDE01198,Key switch contact 2 ohm value,1600.0, Ohm
IDE01200,Driver seat position sensor current value,no measured value present,
IDE01201,Frt.pass. seat position sensor current value,no measured value present,
IDE01205,Safety belt switch 2nd row driver side ohm value,Too Small,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,Too Small,
IDE01207,Safety belt switch center 2nd row ohm value,Too Small,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,not installed,
IDE01358,Right pedestrian protection igniter,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,no measured value present,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,no measured value present,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03730,Driver airbag release valve igniter ohm value,no measured value present,
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,no measured value present,
IDE03800,Driver airbag release valve igniter,not installed,
IDE03801,Frt.pass. airbag release valve igniter,not installed,
IDE06034,Rollover protection trigger: driver side,not installed,
IDE06035,Rollover protection trigger: front passenger side,not installed,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE10187,Supply voltage {V},12.8, V
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,not installed,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger side airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,not installed,
MAS00012,Front passenger knee airbag igniter,not installed,
MAS00013,Driver side seat belt tension igniter,correct,
MAS00014,Front passenger side seat belt tension igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,not installed,
MAS00016,Front passenger seat belt tensioner igniter 2,not installed,
MAS00017,Driver's Belt Force Limiter,not installed,
MAS00018,Front passenger side belt force limiter igniter,not installed,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00022,Battery Interrupt Igniter,not installed,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupied recognition,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,On,
MAS00033,Key switch terminal 2,On,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:14
;SW:17A-920-790-B HW:17A-920-790-B --- Instruments
;Component:KOMBI 503 4193, Coding:05A400186F8C00080188630B5001000000000906
;EV_DashBoardVDDMQBA0,001042,EV_DashBoardVDDMQBA0_001_VW27.rod
;Friday,25,April,2025,12:56:33:35871
;VCID: 2600E6F9596B12AB90-8072
IDE00019,Voltage terminal 30,12.8, V
IDE00021,Engine speed,726.00, /min
IDE00025,Coolant temperature,74.25, °C
IDE00191,Charge air pressure: actual value,8.00, %
IDE00196,Engine oil temperature,37, °C
IDE00301,Distance,92414, km
IDE00310,Outside temperature,12.5, °C
IDE00316-IDE00500,Time-Hour,12, H
IDE00316-IDE00501,Time-Minute,56, min
IDE00316-MAS00111,Time-Seconds,32, s
IDE00317-IDE00502,Date-Year,2025, yr
IDE00317-IDE00503,Date-Month,4, Months
IDE00317-IDE00504,Date-Day,25, d
IDE00510,ESI: distance driven from inspection,276, km
IDE00511,ESI: time from inspection,9, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,300, km
IDE00520,Photo transistor,146,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,27130, km
IDE00698,ESI: remaining running time,658, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,1864, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2040, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2100, mm
IDE00935,ESI: Theoretical service interval,27400, km
IDE01076,Time since ignition off,10356, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,8.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,E4,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,2346,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,365, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,200, km
IDE03352,FIX: Time since last time-dependent inspection,9, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assist,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,7.5, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,47.5, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,50.7, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,8.6, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,16.8, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,35.4, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,35.4, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,17.2, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,19.7, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,47.5, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,50.7, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,20.2, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,15.6, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,47.5, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,50.7, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,16.3, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,92200,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,91900,
IDE03472-MAS06155,Volume after refueling-Third to last distance,91400,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,91000,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,102, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-5, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,1419,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2293,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,41.1, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,97, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,39.8, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-39.8, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,39.8, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,39.8, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,39.8, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.03,
IDE03474-ENG101623,Calculated volume-reference_volume,39.8, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,113,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,12, H
IDE03477-IDE00501,GPS time-Minute,56, min
IDE03477-IDE00501,GPS time-Minute,52, min
IDE03477-IDE00502,GPS time-Year,2025, yr
IDE03477-IDE00503,GPS time-Month,4, Months
IDE03477-IDE00504,GPS time-Day,25, d
IDE03477-MAS00111,GPS time-Seconds,37, s
IDE03477-MAS00111,GPS time-Seconds,59, s
IDE03477-MAS03493,GPS time-last synchronization year,2025, yr
IDE03506,Distance: high resolution,05 82 21 DD,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 61,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0F,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0F,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 61,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,BF F0 75 3D,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,3F F0 75 3D,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,0F F0 77 F0,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,4F F0 02 43,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 77 F0,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 02 43,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF F0 03 B0,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,BF F0 ED 20,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,3F F0 ED 20,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,0F F0 F8 46,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,4F F0 04 0F,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,8F F0 F8 46,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,CF F0 04 0F,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,8F F1 23 76,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,CF F0 05 6C,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,4F F0 06 C6,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,0F F1 5D D8,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,8F F1 5D D8,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,CF F0 06 C6,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,8F F1 67 EA,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,CF F0 07 3F,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,4F F0 07 3F,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,0F F1 67 EA,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,86 0D F6 E0,
IDE08240,Transponder ID Key 2,85 0A F6 E0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,72 FB 6A 5F,
IDE08343,Immobilizer Challenge,BA 7A 5D 85,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,C3 C8 31 95 87 B7 51 03 F5 44 E3 1A 48 18 DC 16,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,3F 3F 50 EC,
IDE14186-MAS17993,Communication transponder-Phase value,16,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
MAS00077-ENG99298,Immobilizer-State,02 01 03 73 02 00 00 00 15 00,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG250331-ENG250595,Condition_check_1-State_info_1,4,
ENG250331-ENG250481,Condition_check_1-State_info_2,1,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG250332-ENG250595,Condition_check_2-State_info_1,4,
ENG250332-ENG250481,Condition_check_2-State_info_2,1,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,95, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,94, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,95, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,94, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,37, km
ENG99439,Instrument_recorder,06 41 93 00 46 50 4B 45 56 57 07 39 53 31 08 41 43 35 44 0B 65 33 63 30 37 31 5F 06 00 0C 00 29 00 0A 00 00 02 E2 00 00 00 00 00 00 00 64 00 06 32 27 99 1F 56 28 00 C6 00 1E 00 00 02 88 00 00 00 0B 00 00 00 04 00 05 D6 00 4A C2 4C E8 00 B4 00 1F 00 00 02 8F 00 00 00 01 00 00 00 08 00 06 1F 7F 5A 7B CF 38 00 B0 00 1F 00 00 01 E8 00 00 00 00 00 00 00 3C 00 06 23 40 A6 29 79 98 00 B0 00 1F 00 00 01 DD 00 00 00 00 00 00 00 02 00 05 FE 15 F9 E9 3D 70 01 38 00 13 00 00 03 12 00 00 00 00 00 00 00 26 00 06 32 CB 4A DD 60 A0 00 24 00 08 00 00 C1 01 00 00 00 11 00 00 00 0B 00 06 2F 85 0B B9 AA A8 00 C6 00 1E 00 00 02 88 00 00 00 02 00 00 00 03 00 06 1F 7F 5A 7B CF 38 01 46 00 14 00 00 00 F6 00 00 00 01 80 00 00 17 00 00 00 00 00 00 B7 98 00 94 00 1A 00 00 0D 18 00 00 00 00 00 00 00 00 00 05 C0 63 B4 B6 F9 F8 00 9C 00 19 00 00 01 8A 00 00 00 00 00 00 00 00 00 05 C0 63 B4 B6 F9 F8 00 7A 00 16 00 00 07 9B 00 00 00 00 00 00 00 01 00 06 2A 2C 74 BD 04 40 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 47 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 03 03 03 03 03 03 03 03 03 03 18 00 14 00 46 01 F6 00 00 00 01 00 00 00 00 00 00 00 98 B7 00 00 13 00 38 01 12 03 00 00 00 00 00 00 CB 32 06 00 A0 60 DD 4A 0A 00 29 00 E2 02 00 00 00 00 00 00 27 32 06 00 28 56 1F 99 08 00 24 00 01 C1 00 00 11 00 00 00 85 2F 06 00 A8 AA B9 0B 16 00 7A 00 9B 07 00 00 00 00 00 00 2C 2A 06 00 40 04 BD 74 1F 00 B0 00 E8 01 00 00 00 00 00 00 40 23 06 00 98 79 29 A6 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 27 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 41 93 00 46 50 4B 45 56 57 07 39 53 31 09 47 43 5F 56 57 0B 00 00 00 F9 00 0F 00 00 04 A0 00 00 00 00 00 02 00 06 33 99 D3 50 1A FE 00 00 04 5F 00 84 00 8B 00 5E 00 00 00 00 00 00 00 06 17 45 15 01 71 8C 00 00 02 2D 00 54 00 00 00 77 00 00 00 00 00 04 00 05 E4 DC FA 5B CF B1 00 00 00 F5 00 0F 00 00 01 E2 00 00 00 01 00 00 00 06 24 39 61 D7 2A 1C 00 00 00 F5 00 0F 00 00 01 E2 00 00 00 02 00 00 00 06 18 F0 5B FD EE 5B 00 00 00 F5 00 0F 00 00 01 E2 00 00 00 03 00 00 00 05 F4 BF 18 5B DE 84 00 00 00 F5 00 0F 00 00 01 E2 00 00 00 04 00 00 00 06 22 9C C1 77 12 8B 00 00 02 1F 00 52 00 00 00 4C 00 00 00 00 00 17 00 05 E5 EC 09 1A 9C A4 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 01 00 01 00 05 EE D3 B3 74 D9 4C 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 02 00 00 00 05 B2 2D 6E 38 54 84 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 03 00 00 00 05 B2 2D 6E 38 54 D0 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 04 00 00 00 05 B2 2D 6E 38 55 1C 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 05 00 00 00 05 ED EC C9 FD 84 AC 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 06 00 00 00 05 B4 51 33 BF E9 A5 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 07 00 00 00 05 DF 71 91 12 38 30 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 08 00 00 00 05 B4 51 33 BF EB 2F 00 00 00 F8 00 0F 00 00 01 FA 00 00 00 09 00 00 00 05 B4 51 33 BF EB 7D 00 00 00 F8 00,
ENG107920-ENG98868,onboard_computer-Range,737, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,5.1, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,5.2, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,4.9, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,737, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,117,
ENG103405,read_out_measured_value_block,92,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,4346,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_Trigger,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:27
;SW:3Q0-907-530-AC HW:3Q0-907-530-C --- CAN Gateway
;Component:GW MQB High 442 4388, Coding:030100046F085600FB100258180F00010001070000000000000000000000
;EV_GatewNF,013026,EV_GatewNF_VW27.rod
;Friday,25,April,2025,12:57:16:35871
;VCID: 70ACC0A1AB2F0C1B3A-8024
IDE00019,Voltage terminal 30,12.6, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2025-04-22-15:25*00.0*01*09065***
2025-04-22-15:17*16.3*01**
2025-04-21-22:53*24.0*01**
2025-03-04-14:10*00.0*01*00157***
2025-03-04-13:28*00.0*01**
2023-05-30-14:17*00.1*01**
2000-01-01-00:00*00.0*00*00000***
2000-01-01-00:00*00.0*00**
2000-01-01-00:00*00.0*00**|,
IDE00057,History data 2,|Life Cycle Data String|2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00*00000**
2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**
2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**|,
IDE00058,History data 3,|Life Cycle Data String|2024-08-09-13:26*0*1*070*040*0-0-1-1-1-0-0*0*0*00.0*00.0**
2024-08-09-13:18*0*1*069*040*0-0-1-1-1-0-0*1*0*00.0*00.0**
2024-08-09-13:17*0*1*069*039*0-0-1-1-1-0-0*0*0*00.0*00.0**
2023-06-27-08:22*0*1*078*048*0-0-1-1-1-0-0*0*0*00.0*00.0**
2023-06-27-07:59*0*1*077*048*0-0-1-1-1-0-0*0*0*00.6*00.0**
2023-06-27-07:55*0*1*077*047*0-0-1-1-1-0-0*0*0*00.6*00.0**
2023-06-26-15:44*0*1*071*043*0-0-1-1-1-0-0*0*0*00.1*00.0**
2023-06-26-15:40*0*1*071*043*0-0-1-1-1-0-0*0*0*00.0*00.0**
2023-06-23-11:45*0*1*071*044*0-0-0-0-1-0-0*0*0*00.1*00.0**
2023-06-23-11:45*0*1*071*044*0-0-0-0-1-0-0*1*0*00.1*00.0**|,
IDE00059,History data 4,|Life Cycle Data String| 0000000km*01*059*JCB*1111111111*10007*06463*010.7*000.0*000.0**
2000-01-01-00:00*00*---*---*----------*00000*00000*000.0*000.0*000.0**
2000-01-01-00:00*00*---*---*----------*00000*00000*000.0*000.0*000.0**|,
IDE00060,History data 5,|Life Cycle Data String|2000-01-01-00:00*0*+0.000*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**
2000-01-01-00:00*0*+0.000*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**|,
IDE00061,History data 6,|Life Cycle Data String|2025-04-25-09:51*037*+16*-000.3*00.10*0.02*000**
2025-04-25-08:56*039*+16*+000.5*00.80*0.01*000**
2025-04-25-07:54*038*+17*+000.6*00.80*0.00*000**
2025-04-24-23:12*040*+25*+000.9*00.60*0.00*000**
2025-04-24-20:18*039*+25*+001.4*00.50*0.00*000**
2025-04-24-19:45*037*+26*+000.3*00.10*0.00*000**
2025-04-24-17:02*039*+22*+001.2*00.40*0.00*000**
2025-04-24-12:31*036*+23*+000.5*00.10*0.00*000**
2025-04-24-09:39*034*+23*+000.3*00.00*0.00*000**
2025-04-24-05:58*038*+20*+000.9*00.20*0.00*000**|,
IDE00062,History data 7,|Life Cycle Data String|2025-04-25-09:59*040*+000.3*002.7*00.0*00.0**
2025-04-25-09:44*038*+000.3*000.0*00.0*00.0**
2025-04-25-08:45*036*+000.4*000.0*00.0*00.0**
2025-04-24-23:50*036*+000.3*008.0*00.0*00.0**
2025-04-24-20:54*037*+000.3*002.2*00.0*00.0**
2025-04-24-19:52*035*+000.3*000.3*00.0*00.0**
2025-04-24-17:28*037*+000.3*002.2*00.0*00.0**
2025-04-24-17:28*039*+000.1*000.0*00.0*00.0**
2025-04-24-12:42*033*+000.2*004.3*00.0*00.0**
2025-04-24-09:43*035*+000.2*002.7*00.0*00.0**|,
IDE00063,History data 8,|Life Cycle Data String|2025-04-25-07:55*4*17*00*00*99*2025-04-24-23:51*01**
2025-04-24-23:13*4*17*00*00*99*2025-04-24-20:55*01**
2025-04-24-19:46*4*17*00*00*99*2025-04-24-17:30*01**|,
IDE00064,History data 9,|Life Cycle Data String|2020-03-06-00:00*100*100*100*100*00000*12.80*+21*02*01*12.70*00000*00000**
2025-04-03-00:10*061*078*063*027*06435*12.30*+10*05*01*03.90*00815*06525**
2025-03-04-13:24*053*069*061*020*06419*12.30*+07*06*01*04.00*00815*06525**
2025-01-31-12:42*054*072*068*023*06374*12.40*+04*06*01*04.00*00813*06509**
2025-01-03-11:50*055*072*073*025*06325*12.40*+02*06*01*03.90*00811*06487**
2024-12-05-05:39*056*073*076*031*06268*12.50*+09*06*01*03.90*00807*06456**
2024-11-07-05:35*057*073*069*026*06200*12.40*+06*06*01*03.95*00796*06376**
2024-10-09-15:09*059*075*066*032*06109*12.30*+20*06*01*03.85*00774*06221**
2024-09-11-10:34*062*078*067*033*06027*12.30*+14*05*01*03.85*00752*06074**
2024-08-14-05:59*069*082*075*044*05958*12.50*+30*05*01*03.65*00740*05985**
2024-07-17-05:42*061*080*074*038*05837*12.40*+21*05*01*03.85*00713*05783**
2024-06-18-17:45*060*078*071*036*05742*12.40*+37*05*01*03.70*00690*05613**|,
IDE00065,History data 10,|Life Cycle Data String|2000-01-01-00:00*0*000.0*0000.0*0*000.0*0000.0*00.00*0000000**
2000-01-01-00:00*00*00.0*00.00*000.0**|,
IDE00066,History data 11,|Life Cycle Data String|2025-04-25-09:56*000*000*000*006*0055*008*00.0*00.6*073*037*073*037*04*00636*01715*00018*00200*07234**
2025-04-25-09:44*000*000*000*028*0142*048*00.0*00.4*070*036*075*039*05**
2025-04-25-07:54*000*000*000*050*0236*051*00.0*00.8*071*035*072*038*01**
2025-04-24-23:13*000*000*000*037*0126*037*00.0*01.1*072*037*074*040*01**
2025-04-24-20:36*000*000*000*018*0081*035*00.0*00.6*075*038*076*039*01**|,
IDE00067,History data 12,|Life Cycle Data String|2025-04-22-15:58*0-0-0-1-0-0-1-0**
2025-04-17-19:46*0-0-0-1-0-0-0-0**
2025-04-17-19:42*0-0-0-1-0-0-0-0**
2025-04-15-23:01*0-0-0-1-0-0-1-0**
2025-04-15-23:00*0-0-0-1-0-0-1-0**
00086*00000*00000*02145*00000*00012*01011*00000**
2024-12-17-15:43*0-0-0-0-0-1-0-0**
2024-11-26-16:10*0-0-0-0-0-1-0-0**
2024-11-23-15:54*0-0-0-0-0-1-0-0**
2024-11-16-20:42*0-0-0-0-0-1-0-0**
2024-11-08-12:40*0-0-0-0-0-1-0-0**
00000*00000*00000*00003*00000*00034*00000*00000**
2025-04-22-15:53*1*060*026*+15*06*025*-46.57*11.3*1**
2025-04-17-19:40*1*070*033*+14*06*025*-37.84*11.6*1**
2025-04-15-23:12*1*061*028*+16*06*025*-33.02*12.1*1**
2025-04-15-23:03*1*060*027*+16*06*025*+19.14*14.7*1**
2025-04-15-22:58*2*056*024*+15*06*025*-05.59*11.9*0**
00989*00181*00003**|,
IDE00068,History data 13,|Life Cycle Data String|2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
2000-01-01-00:00*0-0-0-0-0*000.0**|,
IDE00069,History data 14,|Life Cycle Data String|2025-04-25-12:52*3*00026*0000*0008*00.00*00000c*+23*0003.0*0001.1*0000.2**
2025-04-25-09:51*3*00017*0000*0008*00.14*01800c*+16**
2025-04-25-08:56*3*00015*0024*0008*00.80*07800e*+17**
2025-04-25-07:54*3*00027*0000*0007*00.85*03800c*+19**
2025-04-24-23:12*3*00257*0084*0007*00.63*07800f*+27**
00305*00103*00009*00000*00000**
2000-01-01-00:00*000.0*00.0*00.0*0000.0**
2000-01-01-00:00*000.0*00.0*00.0**
2000-01-01-00:00*000.0*00.0*00.0**|,
IDE00071,History data 16,|Life Cycle Data String| 0092414km**
00022*00157*11441*00153*00000**
04804*00165*00046*00015**
39190*02692*00033*00000**
01529*06843*00769*02501**
08518*02435*00665**
00000*00000*00000*00000**
00361*00009*00000**
00017*00007*00000**
00004*00001*00000**
02344*00946*00677*00527*00429*00332*00520*00323*00202*00313*00000**|,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,10,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,220,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,59392,
IDE01459,Energy management heat output control status,Stage 1,
IDE01805,History data 19,|Life Cycle Data String|2000-01-01-00:00*00000*000*000*+00**
00000*00000*00000*00000**|,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.0, H
IDE01807-MAS00106,History data 21-Year,2000,
IDE01807-MAS00107,History data 21-Month,1,
IDE01807-MAS00108,History data 21-Day,1,
IDE01807-MAS00109,History data 21-Hours,0, H
IDE01807-MAS00110,History data 21-Minutes,0, min
IDE01807-MAS14375,History data 21-Cycle counter,0,
IDE01807-MAS14376,History data 21-ECU 1,Node_0x-- $-- (empty entry),
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.0, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Node_0x-- $-- (empty entry),
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,1.0, H
IDE01810-MAS00106,History data 24-Year,2025,
IDE01810-MAS00107,History data 24-Month,3,
IDE01810-MAS00108,History data 24-Day,19,
IDE01810-MAS00109,History data 24-Hours,3, H
IDE01810-MAS00110,History data 24-Minutes,33, min
IDE01810-MAS14375,History data 24-Cycle counter,11734,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,32,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Extended data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,36,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,00 00 00 00,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,0,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Unknown,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,00 00 00 00,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,0,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Unknown,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 00 00,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,0,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Unknown,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,1B 00 00 0E,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,1,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Comfort data bus,
IDE01812-MAS01468,History data 26-Terminal 15,9,
IDE01812-MAS03173,History data 26-Powertrain data bus,12,
IDE01812-MAS03174,History data 26-Comfort data bus,36567,
IDE01812-MAS03175,History data 26-Extended data bus,33953,
IDE01812-MAS03177,History data 26-Infotainment data bus,1,
IDE01812-MAS03178,History data 26-Suspension data bus,71,
IDE01812-MAS03180,History data 26-Local data bus,368,
IDE01812-MAS05686,History data 26-Data bus diagnostics,11,
IDE01812-MAS14374,History data 26-Totals,65535,
IDE01813-MAS03173,History data 27-Powertrain data bus,0,
IDE01813-MAS03174,History data 27-Comfort data bus,15560,
IDE01813-MAS03175,History data 27-Extended data bus,1447,
IDE01813-MAS03177,History data 27-Infotainment data bus,0,
IDE01813-MAS03178,History data 27-Suspension data bus,16,
IDE01813-MAS14374,History data 27-Totals,17081,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,65535,
IDE01814-MAS03175,History data 28-Extended data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,23,
IDE01814-MAS14374,History data 28-Totals,65535,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.2, H
IDE01816-MAS00106,History data 30-Year,2021,
IDE01816-MAS00107,History data 30-Month,6,
IDE01816-MAS00108,History data 30-Day,26,
IDE01816-MAS00109,History data 30-Hours,11, H
IDE01816-MAS00110,History data 30-Minutes,57, min
IDE01816-MAS14375,History data 30-Cycle counter,3944,
IDE01816-ENG151642,History data 30-Bus_1,Extended data bus,
IDE01816-ENG151644,History data 30-Bus_2,Suspension data bus,
IDE01816-ENG151646,History data 30-Bus_3,Powertrain data bus,
IDE01816-ENG151648,History data 30-Bus_4,Unknown (80)
IDE01816-ENG151650,History data 30-Bus_5,Infotainment data bus,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,0.2, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,2.8, H
IDE01817-MAS00106,History data 31-Year,2025,
IDE01817-MAS00107,History data 31-Month,4,
IDE01817-MAS00108,History data 31-Day,25,
IDE01817-MAS00109,History data 31-Hours,12, H
IDE01817-MAS00110,History data 31-Minutes,52, min
IDE01817-MAS14375,History data 31-Cycle counter,11785,
IDE01817-MAS14376,History data 31-ECU 1,Electronic central electric,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.0, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Multifunction module on the second bus connection,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Driver's door electronics,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Passenger's door electronics,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Interface for access/start system,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2025,
IDE01818-MAS00107,History data 32-Month,4,
IDE01818-MAS00108,History data 32-Day,25,
IDE01818-MAS00109,History data 32-Hours,10, H
IDE01818-MAS00110,History data 32-Minutes,2, min
IDE01818-MAS14375,History data 32-Cycle counter,11785,
IDE01818-MAS14391,History data 32-Alerting ECU,Driver's door electronics,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,1.0, H
IDE01819-MAS00106,History data 33-Year,2025,
IDE01819-MAS00107,History data 33-Month,3,
IDE01819-MAS00108,History data 33-Day,19,
IDE01819-MAS00109,History data 33-Hours,3, H
IDE01819-MAS00110,History data 33-Minutes,33, min
IDE01819-MAS14375,History data 33-Cycle counter,11734,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 0E,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,2.8, H
IDE01820-MAS00106,History data 34-Year,2025,
IDE01820-MAS00107,History data 34-Month,4,
IDE01820-MAS00108,History data 34-Day,25,
IDE01820-MAS00109,History data 34-Hours,12, H
IDE01820-MAS00110,History data 34-Minutes,52, min
IDE01820-MAS14375,History data 34-Cycle counter,11785,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 32,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2000,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,11786,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01827,Specified generator voltage,13.0, V
IDE01828,Generator DF Signal,48.400, %
IDE01829,Generator exciter current,2.375, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Valeo GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82 - 140A,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01834,Battery voltage,12.915, V
IDE01836,Battery current,0.581, A
IDE01837,Temperature of battery sensor,24, °C
IDE01838,Battery temperature,23, °C
IDE01839,Battery charge level,73, %
IDE01841,Battery internal resistance,6.0, mOhm
IDE01842,Usable battery charge,39, Ah
IDE01843,Battery voltage at rest,12.4, V
IDE01844,Increase idle speed request,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01849,Previous journey duration,0.0, H
IDE01852,Static current measurement: result,10, mA
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,active,
IDE01855,Generator current,25.2, A
IDE01948,Battery internal resistance not normed,6.0, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,50 37 52 77,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG137113,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG137115,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG137116,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG137117,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG137118,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG137119,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG137120,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG137121,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG137114,Play protection status-function_calls_counter_1,0,
IDE02578-ENG137122,Play protection status-function_calls_counter_2,0,
IDE02578-ENG137123,Play protection status-function_calls_counter_3,0,
IDE02578-ENG137124,Play protection status-function_calls_counter_4,0,
IDE02578-ENG137125,Play protection status-function_calls_counter_5,0,
IDE02578-ENG137126,Play protection status-function_calls_counter_6,0,
IDE02578-ENG137127,Play protection status-function_calls_counter_7,0,
IDE02578-ENG137128,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-Increase idle speed request,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Withdrawable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Withdrawable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,86,
IDE03010-IDE01844,Number of prevented stop processes-Increase idle speed request,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Withdrawable battery charge too low,12,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,1011,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,2145,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Withdrawable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,34,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,3,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2025,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,4,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,22,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,17,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,15,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,23,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,42,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,58,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,46,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,Possible standing time too short,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,Battery state of charge too low,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,Possible standing time too short,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,Possible standing time too short,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,Possible standing time too short,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2024,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,12,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,11,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,23,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,16,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,26,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,17,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,8,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,16,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,20,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,15,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,12,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,40,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,43,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,42,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,10,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,54,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,Standing time timed out,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,Standing time timed out,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,Standing time timed out,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,Standing time timed out,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,Standing time timed out,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,59, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,EFB,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,No malfunction,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,E2 3A 02 CD 87,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-Odometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-Odometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-Odometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine Control Module,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-Odometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,ECONOMY,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,no function,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,no function,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,no function,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,no function,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,no function,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,no function,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,no function,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,105680,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,14,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,510,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,128,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2024,
IDE06230-MAS00107,Break recommend.: last message-Month,8,
IDE06230-MAS00108,Break recommend.: last message-Day,25,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,55,
IDE06230-MAS00111,Break recommend.: last message-Seconds,12,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 2,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,76,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Act.val.,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,44,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Act.val.,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,36,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Act.val.,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,Request by Engine Control Module,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,not active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Phase 1,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,25, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,12.9, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,Initialization,
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.40,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not detected,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not detected,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.90, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.75, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,800, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,800, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,6567.8, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,6463.3, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,INDIVIDUAL,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Not Used,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Not Used,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,BB 9A C5 A4,
IDE08346-MAS06117,Generator Analysis-Specified voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.9, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,56, °C
IDE08347,adapted battery capacity,105, Ah
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multifunction steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for electrical outlet,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,01 2F,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,01 3E,
IDE08685-SFT271901,Status LIN user-Generator,active,
IDE08685-SFT271921,Status LIN user-Multifunction steering wheel control module,active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for electrical outlet,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,not active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,not active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09561,Static current last LIN sleep phase,-1.700, A
IDE09562,Range extension counter: stage 2,0,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,7,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11679-MAS02246,Electrical compressor: prohibition on turning-on 48V-Timeout,not active,
IDE11679-MAS09519,Electrical compressor: prohibition on turning-on 48V-Message error,not active,
IDE11679-MAS09541,Electrical compressor: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11679-MAS09542,Electrical compressor: prohibition on turning-on 48V-Error status init. error,not active,
IDE11679-MAS09544,Electrical compressor: prohibition on turning-on 48V-No component function,not active,
IDE11679-MAS09545,Electrical compressor: prohibition on turning-on 48V-Sequence error,not active,
IDE11679-MAS13455,Electrical compressor: prohibition on turning-on 48V-48 V voltage measurement error,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No component function,
IDE11683-MAS13708,Engine electronics: status of 48V network-Error status of electrical compressor,No error recognized,
IDE11683-MAS13715,Engine electronics: status of 48V network-Electro compressor mode,Standby-mode,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS10933,48V activation restriction-Roll stabilization,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11911-SFT271913,48V activation restriction-Auxiliary Air Heater Control Module/PTC,active,
IDE11911-SFT272141,48V activation restriction-Electrical compressor,not active,
IDE12084,Component protection participant status,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 11 00 00 00 4E 20 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 11 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Release,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Release,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,254,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,254,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,254,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,Initialization,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function is not active,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0000000*2000-01-01-00:00:00*0*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0000000*2000-01-01-00:00:00*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0000000*2000-01-01-00:00:00*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*2000-01-01-00:00:00*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0000000*2000-01-01-00:00:00*0*,
IDE14265,Battery display: source of initiation,0,
IDE14424,Historical data info status,11101101 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,12,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,57,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,54,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,227,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,92414, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,6,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine running,Engine running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
SFT271901,Generator,-,
SFT271901-ENG250861,Generator-alternator_family,35,
SFT271901-ENG245985,Generator-asic_manufacturer,30 31,
SFT271901-ENG250451,Generator-asic_variant,30 34,
SFT271901-ENG171470,Generator-Manufacturer,30 31,
SFT271901-ENG99001,Generator-Variant,31 34,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,active,
ENG137076-ENG118763,EM_battery_analog_monitoring-actual_difference_voltage,0.000, V
ENG137076-ENG118760,EM_battery_analog_monitoring-battery_analog_voltage,0.0, V
ENG137076-ENG118765,EM_battery_analog_monitoring-battery_off_counter,0,
ENG137076-ENG118764,EM_battery_analog_monitoring-battery_off_status_intern,connected,
ENG137076-ENG118761,EM_battery_analog_monitoring-battery_voltage_filtered,4.0, V
ENG137076-ENG118762,EM_battery_analog_monitoring-voltage_difference,0.00, V
ENG106123,EM_blAlternator On,On,
ENG106124,EM_blAlternator Valid,Yes,
ENG106140,EM_Current_Control_Recu,active,
ENG151180,EM_electrical_system_current,23.834, A
ENG118437,EM_IAlternatorReserve,74.6, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,450, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,77, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,62, %
ENG106157,EM_RecuMode_Engine,Neutral,
ENG118780-ENG246261,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,1,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,1,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,1,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,1,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,1,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,1,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,1,
ENG118780-ENG167301,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,1,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,1,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,1,
ENG118780-ENG167323,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,1,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,1,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG252593,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG167381,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG167382,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,101E,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2030,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,----,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,6710,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,9112,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0500,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,----,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG163716,Gateway app. software identification-software_version_mv-em,0503,
ENG118782-ENG163717,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,----,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0660,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0400,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7210,
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60040,
ENG151185-ENG140447,MV-EM_48V_electrical_system_components-48V_Ptc_installed,installed,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140444,MV-EM_48V_electrical_system_components-eAbc_installed,not installed,
ENG151185-ENG140445,MV-EM_48V_electrical_system_components-eAv_installed,installed,
ENG151185-ENG140443,MV-EM_48V_electrical_system_components-eAws_installed,installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,Unknown (234)
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,Unknown (136)
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,57974, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,Initialization,
ENG151187-ENG140428,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_back_48V_actual_voltage,0.00, V
ENG151187-ENG140427,MV-EM_48V_electrical_system_diagnosis_typ_2-eAbc_front_48V_actual_voltage,0.00, V
ENG151187-ENG140429,MV-EM_48V_electrical_system_diagnosis_typ_2-eAv_48V_actual_voltage,0.00, V
ENG151187-ENG140426,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_back_48V_actual_voltage,0.00, V
ENG151187-ENG140425,MV-EM_48V_electrical_system_diagnosis_typ_2-eAws_front_48V_actual_voltage,0.00, V
ENG151187-ENG140430,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltag,Initialization,
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,12.70, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,-204.0, A
ENG151192,MV-EM_dc_power_desired,-6325, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,63.50, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,-511, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,not active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG250370-ENG250534,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:50
;SW:2Q0-905-861-A HW:2Q0-905-861-A --- Steer. Col. Lock
;Component:ELV-MQBB H08 0021, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW27.rod
;Friday,25,April,2025,13:03:05:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 312A05A560A5451375-8064
Group,Description,Actual
IDE00019,Voltage terminal 30,12.8,
IDE00021,Engine speed,719.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-outdated,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,1,
IDE01766-MAS03715,Distance impulses-Right front wheel,1,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,11131,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Not adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00109,Standard - ambient data 1-Hours,13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,3,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,5,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,228,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Not confirmed,
Elapsed Time: 00:04
;SW:2Q0-907-686-A HW:2Q0-907-686-A --- Lane Change
;Component:HRE3_Kl15_Mst H05 0052, Coding:50014500
;EV_HREntryHellaGen3Kl15,001009,EV_HREntryHellaGen3Kl15_001_VW27.rod
;Friday,25,April,2025,13:03:12:35871
;VCID: 383C388183DF945B32-806C
IDE00018,Voltage terminal 15,12.80, V
IDE00102,Control Module temperature,32.0, °C
IDE00925,Yaw rate,0.15, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,1,
IDE01766-MAS01854,Distance impulses-Right front,1,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,-32768.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Positive,
IDE02219,Steering wheel angle: sign,38.40,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,12.80, V
IDE05065,lane change assist. 2: temperature,34.0, °C
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,passive,
IDE05067-MAS10332,Functional status of lane change assist.-Parking assistant,passive,
IDE05070,Curve radius,384, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,2,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,882,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05087,Dynamic angle offset lane change assist. 1,-1.20, °
IDE05088,Dynamic angle offset lane change assist. 2,-0.30, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG170421,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG170421,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG170421,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS01487,Lane keeping warning system-LED,yellow,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,0.26, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Left,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG170421,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation is available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,Not available,
MAS08785-IDE03619,Parking aid-System condition,System off,
MAS12659-IDE00007,VW/Audi part numbers of sub-bus users-VW/Audi part number,2Q0907685A ,
MAS12659-MAS01170,VW/Audi part numbers of sub-bus users-Subsystem designation,Unknown (1595)
MAS12659-ENG170217,VW/Audi part numbers of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12659-ENG170218,VW/Audi part numbers of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12659-ENG170221,VW/Audi part numbers of sub-bus users-SubSystem Node Address,06 3B,
MAS12660-IDE00016,Hardware version number of sub-bus users-Hardware version,H05,
MAS12660-MAS01170,Hardware version number of sub-bus users-Subsystem designation,Unknown (1595)
MAS12660-ENG170217,Hardware version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12660-ENG170218,Hardware version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12660-ENG170221,Hardware version number of sub-bus users-SubSystem Node Address,06 3B,
MAS12661-IDE00008,Software version number of sub-bus users-Software version,0052,
MAS12661-MAS01170,Software version number of sub-bus users-Subsystem designation,Unknown (1595)
MAS12661-ENG170217,Software version number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12661-ENG170218,Software version number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12661-ENG170221,Software version number of sub-bus users-SubSystem Node Address,06 3B,
MAS12662-IDE00012,Hardware part number of sub-bus users-Hardware part number,2Q0907685A ,
MAS12662-MAS01170,Hardware part number of sub-bus users-Subsystem designation,Unknown (1595)
MAS12662-ENG170217,Hardware part number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12662-ENG170218,Hardware part number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12662-ENG170221,Hardware part number of sub-bus users-SubSystem Node Address,06 3B,
MAS12663-IDE00010,Series number of sub-bus users-Serial number,00000542982823 ,
MAS12663-MAS01170,Series number of sub-bus users-Subsystem designation,Unknown (1595)
MAS12663-ENG170217,Series number of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12663-ENG170218,Series number of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12663-ENG170221,Series number of sub-bus users-SubSystem Node Address,06 3B,
MAS12665-MAS00966,FAZIT identifications of sub-bus users-Manufacturer index location,HLH-45F,
MAS12665-MAS00968,FAZIT identifications of sub-bus users-Day of manufacture,28.02.20,
MAS12665-MAS00969,FAZIT identifications of sub-bus users-Manufacturer- test stand number,6CA2,
MAS12665-MAS00970,FAZIT identifications of sub-bus users-Running manufacturer number,0214,
MAS12665-MAS01170,FAZIT identifications of sub-bus users-Subsystem designation,Unknown (1595)
MAS12665-ENG170217,FAZIT identifications of sub-bus users-Number Of Expected SubSystem Identification,1,
MAS12665-ENG170218,FAZIT identifications of sub-bus users-Number Of Retrieved SubSystem Identification,1,
MAS12665-ENG170221,FAZIT identifications of sub-bus users-SubSystem Node Address,06 3B,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|06 3B
MAS12667-ENG299102,Specified installation of sub-bus users-SubSystems coded,|SubSystem coded Bit 0,SubSystem coded Bit 1
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|1|,
MAS13422-IDE00013,System description of sub bus participant-System designation,HRE3_Kl15_Slv,
MAS13422-MAS01170,System description of sub bus participant-Subsystem designation,Unknown (1595)
MAS13422-ENG170217,System description of sub bus participant-Number Of Expected SubSystem Identification,1,
MAS13422-ENG170218,System description of sub bus participant-Number Of Retrieved SubSystem Identification,1,
MAS13422-ENG170221,System description of sub bus participant-SubSystem Node Address,06 3B,
Elapsed Time: 00:05
;SW:5Q4-959-593-K HW:5Q4-959-593-K --- Door Elect, Driver
;Component:TSG FS 007 0485, Coding:003B1220D000028000001000
;EV_DCU2DriveSideMAXHCONT,001005,EV_DCU2DriveSideMAXHCONT_VW27.rod
;Friday,25,April,2025,13:03:22:35871
;VCID: 4DD279551C5D01F371-8018
IDE00310,Outside temperature,13.50, °C
IDE01992-MAS12276,Installation list: current installations-Front door control module,can be reached,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,can be reached,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Driver Side Door Control Module,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.80, V
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.80, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,active,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,89, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,4520,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,11.00, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,11.00, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,13.00, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,10.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,12.00, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,18, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Not available,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
MAS01872,Rear lid remote release button,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,0, %
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
;SW:3Q0-909-144-M HW:3Q0-909-144-L --- Steering Assist
;Component:EPS_MQB_ZFLS 507 5082, Coding:951F0000
;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
;Friday,25,April,2025,13:03:34:35871
;VCID: 3C342491B7E7B87BD6-8068
IDE00018,Voltage terminal 15,12.92, V
IDE00019,Voltage terminal 30,12.79, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,699, /min
IDE00102,Control Module temperature,24.0, °C
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,04,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,06,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,71,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,13,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assist-System status,operational,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,0.000, Nm
IDE02006-MAS03095,Lane assist-Function status,activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,17.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,243.4, °
IDE03682-MAS03083,motor position sensor-Cosine signal,0.535, V
IDE03682-MAS03211,motor position sensor-Sine signal,1.662, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,-100, %
IDE03725-MAS03001,Steering Assistance-Mode,Unknown (3)
IDE03725-MAS03095,Steering Assistance-Function status,activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,48.6, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,0.022, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,0.022, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.1, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.1, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,-0.039, Nm
IDE04184,Steering assistance: engine output,100.000, %
IDE04185,Terminal 30 voltage filtered,12.84, V
IDE04187,Steering torque: raw value 1,62.402, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-66.211, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,62.402, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-66.113, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.40, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.1, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,0.0, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,-0.1, A
IDE04194,Steering assistance: electromotor power,-0.80, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,38.9, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-1.0, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.96, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,Yes,
IDE04459,Steering angle sensor: offset index mark mechanical middle,-0.01, mm
IDE04460,Steering angle sensor: offset straight line running,0.1, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,operational,
IDE04765-MAS03095,Counter steer support-Function status,activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine speed,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,operational,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,80.47, mm
IDE05162-MAS01850,Software end stop-Right,-80.48, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,672160,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,665382,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,0,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,36497,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,36497,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,6955922,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,1615,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,1477,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,1435,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,170047,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.048, Nm
IDE06678-MAS03095,Pull compensation-Function status,activated,
IDE07399,Engine type,2,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,39,
MAS00976-IDE80003,Counter-Analysis 3,3410419804,
MAS00976-IDE80004,Counter-Analysis 4,574798,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
ENG168891-ENG169036,Strain_detection-Calculated_worm_gear_temperature,26.0, °C
ENG168891-ENG169118,Strain_detection-High_count_worm_gear_alt,574798,
ENG168891-ENG169133,Strain_detection-KlimaSensor02_alt,1,
ENG168891-ENG169169,Strain_detection-Low_count_worm_gear_alt,3410419804,
ENG168891-ENG169177,Strain_detection-Mileage_counter,0, km
ENG168891-ENG169189,Strain_detection-OBD_FStatus_ATemp,kein Fehler/Init/nicht verbaut,
ENG168891-ENG102605,Strain_detection-outside_temperature,13.5, °C
ENG168891-ENG168990,Strain_detection-revolutions_per_minute_electric_motor,1, /min
ENG168891-ENG157280,Strain_detection-Steering_angle,38.9, °
ENG168891-ENG168991,Strain_detection-steering_moment,0.015, Nm
ENG168891-ENG168992,Strain_detection-Steering_Support_Engine_Commanded_Torque,0.002, Nm
ENG168891-ENG169223,Strain_detection-Strain_detection_per_cent,0.0000043171, %
Elapsed Time: 00:08
;SW:3Q0-907-338-E HW:3Q0-907-338-E --- Multifunc. Module
;Component:FCM MQB Low 003 0367, Coding:000000070900204201000900000000000000000000000000000000000000
;EV_MultiModulContiVW48X,003003,EV_MultiModulContiVW48X_003_VW27.rod
;Friday,25,April,2025,13:03:46:35871
;VCID: 373E3BBD8EC19B233B-8062
IDE00019,Voltage terminal 30,12.8, V
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,38.90, °
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG161283,Processor load-Software_component_AFS_MXB,10, %
IDE01717-ENG161295,Processor load-Total_system_FCM,24, %
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,5268, lx
IDE02515,Low beam,OFF,
IDE02743,High Beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,30.00, %
IDE03616,Motor status,On,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-10.8, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,8.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,8.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Stationary cornering lamp-Dim static left AFS light,102.0, %
IDE03638-IDE03718,Stationary cornering lamp-Dim static right AFS light,102.0, %
IDE03640,Dynamic AFS light,On,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),27.60, %
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Act.val.,not coded/not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,not coded/not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Act.val.,not coded/not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,not coded/not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE08447,Driving axis angle,-120.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-High Beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-static AFS light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,both sides,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,-500.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-500.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-10.00, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-15.00, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,-120.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-10.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-15.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,-120.0, '
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,-5.00, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,-9.00, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-5.00, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-9.00, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,-300.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-5.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-9.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,-300.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-5.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-9.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,-400.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,-400.0, mm
IDE08715,Func. status matrix high beam,not active,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of first warning,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of second warning,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of third warning,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,0,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2025,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,4,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,25,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,18,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,52,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,48,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,251,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2025,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,4,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,25,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,18,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,52,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,48,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,251,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2025,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,4,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,25,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,18,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,52,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,48,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,251,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2011,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2000,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,1,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,0,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,1,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,0,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,0,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,4,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,1,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,0,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,0,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,9.000000, °
ENG157518-ENG161284,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0170,
ENG157518-ENG161297,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7200,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,Malfunction,
Elapsed Time: 00:10
;SW:5Q4-959-592-K HW:5Q4-959-592-K --- Door Elect, Pass.
;Component:TSG BFS 007 0485, Coding:003B1020DC00028000001000
;EV_DCU2PasseSideMAXHCONT,001005,EV_DCU2PasseSideMAXHCONT_VW27.rod
;Friday,25,April,2025,13:04:01:35871
;VCID: 4CD47451E74708FB66-8018
IDE00310,Outside temperature,13.00, °C
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Rear Passenger Door Control Module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.80, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.90, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,4520,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,79.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,18, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,0.00, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:08
;SW:3Q0-035-864-C HW:3Q0-035-864-C --- Information Electr.
;Component:MU-S-N-ER 853 0876, Coding:02720601BE0000004111000100080A001F0500E4012000008E
;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW27.rod
;Friday,25,April,2025,13:04:12:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 312A05A560A5451375-8064
Group,Description,Actual
IDE00019,Voltage terminal 30,12.9, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,702.00, /min
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,5.30, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,25.50, mA
IDE00767,No. of unscheduled ECU resets,0, counts
IDE00916-IDE02127,Speaker status-Left front speaker,Condition not met,
IDE00916-IDE02128,Speaker status-Right front speaker,Condition not met,
IDE00916-IDE02129,Speaker status-Left rear speaker,Condition not met,
IDE00916-IDE02130,Speaker status-Right rear speaker,Condition not met,
IDE00916-ENG117413,Speaker status-loudspeaker_channel_10,Measuring value not available,
IDE00916-ENG117414,Speaker status-loudspeaker_channel_11,Measuring value not available,
IDE00916-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE00916-ENG117416,Speaker status-loudspeaker_channel_13,Measuring value not available,
IDE00916-ENG117417,Speaker status-loudspeaker_channel_14,Measuring value not available,
IDE00916-ENG117418,Speaker status-loudspeaker_channel_15,Measuring value not available,
IDE00916-ENG117419,Speaker status-loudspeaker_channel_16,Measuring value not available,
IDE00916-ENG117408,Speaker status-loudspeaker_channel_5,Measuring value not available,
IDE00916-ENG117409,Speaker status-loudspeaker_channel_6,Measuring value not available,
IDE00916-ENG117410,Speaker status-loudspeaker_channel_7,Measuring value not available,
IDE00916-ENG117411,Speaker status-loudspeaker_channel_8,Measuring value not available,
IDE00916-ENG117412,Speaker status-loudspeaker_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,OFF,
IDE01442-MAS06123,Pressing a button-Eject button,Not operated,
IDE01698-MAS07206,Status audio signal outputs-Audio signal output channel 1,Measuring value not available,
IDE01698-MAS07207,Status audio signal outputs-Audio signal output channel 2,Measuring value not available,
IDE01698-MAS07208,Status audio signal outputs-Audio signal output channel 3,Measuring value not available,
IDE01698-MAS07209,Status audio signal outputs-Audio signal output channel 4,Measuring value not available,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,11,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01767-MAS00941,Status of telephone-Telephone baseplate diagnostic,not connected,
IDE01767-MAS00955,Status of telephone-Handset in handset holder (cradle),not selected,
IDE01767-MAS01806,Status of telephone-Handset holder (cradle),not connected,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,82, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01768-MAS03991,Status of antenna 1 for radio-Reception level antenna 1,46, dBµV
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,45, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS04344,Status of antenna 2 for radio-Reception level antenna 2,46, dBµV
IDE01770-MAS01632,Status of GPS antenna-Status,electrically OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,23, mA
IDE01868-MAS00839,Ring break diagnostic result-TV Tuner,Not available,
IDE01868-MAS00840,Ring break diagnostic result-Media Player: Position 1,Not available,
IDE01868-MAS00844,Ring break diagnostic result-Radio,Not available,
IDE01868-MAS00847,Ring break diagnostic result-Digital Sound System Control Module,Not available,
IDE01868-MAS00849,Ring break diagnostic result-Information electronics control module 1,System OK,
IDE01868-MAS00850,Ring break diagnostic result-Information electronics control module 2,Not available,
IDE01868-MAS02840,Ring break diagnostic result-Instrument cluster display,Not available,
IDE01868-MAS14306,Ring break diagnostic result-Windshield projection head up display control module,Not available,
IDE01868-ENG117473,Ring break diagnostic result-MOST_Component_10,Not available,
IDE01868-ENG117474,Ring break diagnostic result-MOST_Component_11,Not available,
IDE01868-ENG117475,Ring break diagnostic result-MOST_Component_12,Not available,
IDE01868-ENG117476,Ring break diagnostic result-MOST_Component_13,Not available,
IDE01868-ENG117477,Ring break diagnostic result-MOST_Component_14,Not available,
IDE01868-ENG117478,Ring break diagnostic result-MOST_Component_15,Not available,
IDE01868-ENG117479,Ring break diagnostic result-MOST_Component_16,Not available,
IDE01868-ENG117480,Ring break diagnostic result-MOST_Component_17,Not available,
IDE01868-ENG117481,Ring break diagnostic result-MOST_Component_18,Not available,
IDE01868-ENG117482,Ring break diagnostic result-MOST_Component_19,Not available,
IDE01868-ENG117483,Ring break diagnostic result-MOST_Component_20,Not available,
IDE01868-ENG117472,Ring break diagnostic result-MOST_Component_9,Not available,
IDE01992-ENG147302,Installation list: current installations-ECU present Bit 0,not installed,
IDE01992-ENG151629,Installation list: current installations-ECU present Bit 0 Main_Unit,installed,
IDE01992-ENG176482,Installation list: current installations-ECU present Bit 1,not installed,
IDE01992-ENG151628,Installation list: current installations-ECU present Bit 1 reserved,not installed,
IDE01992-ENG152005,Installation list: current installations-ECU present Bit 10 SmartControlCarrier2,not installed,
IDE01992-ENG152004,Installation list: current installations-ECU present Bit 11 WirelessCharger1,not installed,
IDE01992-ENG152003,Installation list: current installations-ECU present Bit 12 WirelessCharger2,not installed,
IDE01992-ENG152002,Installation list: current installations-ECU present Bit 13 Multimedia Operating Unit,not installed,
IDE01992-ENG152001,Installation list: current installations-ECU present Bit 14 Head-up Display,not installed,
IDE01992-ENG152022,Installation list: current installations-ECU present Bit 15,not installed,
IDE01992-ENG176468,Installation list: current installations-ECU present Bit 2,not installed,
IDE01992-ENG151627,Installation list: current installations-ECU present Bit 2 Sound_System,not installed,
IDE01992-ENG176474,Installation list: current installations-ECU present Bit 3,not installed,
IDE01992-ENG151626,Installation list: current installations-ECU present Bit 3 TV_Tuner,not installed,
IDE01992-ENG176502,Installation list: current installations-ECU present Bit 4,not installed,
IDE01992-ENG151625,Installation list: current installations-ECU present Bit 4 DVD_Changer,not installed,
IDE01992-ENG176449,Installation list: current installations-ECU present Bit 5,not installed,
IDE01992-ENG151624,Installation list: current installations-ECU present Bit 5 RearSeatEntertainment,not installed,
IDE01992-ENG152746,Installation list: current installations-ECU present Bit 6,not installed,
IDE01992-ENG151991,Installation list: current installations-ECU present Bit 6 MOST Kombi-Display,installed,
IDE01992-ENG147289,Installation list: current installations-ECU present Bit 7,not installed,
IDE01992-ENG151990,Installation list: current installations-ECU present Bit 7 SmartDisplayCarrier1,not installed,
IDE01992-ENG152007,Installation list: current installations-ECU present Bit 8 SmartDisplayCarrier2,not installed,
IDE01992-ENG152006,Installation list: current installations-ECU present Bit 9 SmartControlCarrier1,not installed,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,Yes,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,No,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,27,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,8,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,26,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,16,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,49, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,48, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,48, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,46, dBµV
IDE02384-ENG147282,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG151635,Status of event memory-ECU Dtc Bit 0 Main_Unit,Malfunction,
IDE02384-ENG176424,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG151634,Status of event memory-ECU Dtc Bit 1 reserved,OK,
IDE02384-ENG151996,Status of event memory-ECU Dtc Bit 10 SmartControlCarrier2,OK,
IDE02384-ENG151995,Status of event memory-ECU Dtc Bit 11 WirelessCharger1,OK,
IDE02384-ENG151994,Status of event memory-ECU Dtc Bit 12 WirelessCharger2,OK,
IDE02384-ENG151993,Status of event memory-ECU Dtc Bit 13 Multimedia Operating Unit,OK,
IDE02384-ENG151992,Status of event memory-ECU Dtc Bit 14 Head-up Display,OK,
IDE02384-ENG152021,Status of event memory-ECU Dtc Bit 15,OK,
IDE02384-ENG176458,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG151633,Status of event memory-ECU Dtc Bit 2 Sound_System,OK,
IDE02384-ENG176476,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG151632,Status of event memory-ECU Dtc Bit 3 TV_Tuner,OK,
IDE02384-ENG176459,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG151631,Status of event memory-ECU Dtc Bit 4 DVD_Changer,OK,
IDE02384-ENG176512,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG151630,Status of event memory-ECU Dtc Bit 5 Rear_Seat_Entertainment,OK,
IDE02384-ENG152743,Status of event memory-ECU Dtc Bit 6,OK,
IDE02384-ENG152017,Status of event memory-ECU Dtc Bit 6 MOST Kombi-Display,OK,
IDE02384-ENG147299,Status of event memory-ECU Dtc Bit 7,OK,
IDE02384-ENG152016,Status of event memory-ECU Dtc Bit 7 SmartDisplayCarrier1,OK,
IDE02384-ENG151998,Status of event memory-ECU Dtc Bit 8 SmartDisplayCarrier2,OK,
IDE02384-ENG151997,Status of event memory-ECU Dtc Bit 9 SmartControlCarrier1,OK,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE03150-ENG147328,Readiness for bus sleep mode-Sleep Bit 0,Bus sleep mode,
IDE03150-ENG151641,Readiness for bus sleep mode-Sleep Bit 0 Main_Unit,End busstat,
IDE03150-ENG176564,Readiness for bus sleep mode-Sleep Bit 1,Bus sleep mode,
IDE03150-ENG151640,Readiness for bus sleep mode-Sleep Bit 1 reserved,Bus sleep mode,
IDE03150-ENG152013,Readiness for bus sleep mode-Sleep Bit 10 SmartControlCarrier2,Bus sleep mode,
IDE03150-ENG152012,Readiness for bus sleep mode-Sleep Bit 11 WirelessCharger1,Bus sleep mode,
IDE03150-ENG152011,Readiness for bus sleep mode-Sleep Bit 12 WirelessCharger2,Bus sleep mode,
IDE03150-ENG152010,Readiness for bus sleep mode-Sleep Bit 13 Bedienteil vorne,Bus sleep mode,
IDE03150-ENG152009,Readiness for bus sleep mode-Sleep Bit 14 Head-up Display,Bus sleep mode,
IDE03150-ENG152008,Readiness for bus sleep mode-Sleep Bit 15,Bus sleep mode,
IDE03150-ENG176563,Readiness for bus sleep mode-Sleep Bit 2,Bus sleep mode,
IDE03150-ENG151639,Readiness for bus sleep mode-Sleep Bit 2 Sound_System,Bus sleep mode,
IDE03150-ENG176562,Readiness for bus sleep mode-Sleep Bit 3,Bus sleep mode,
IDE03150-ENG151638,Readiness for bus sleep mode-Sleep Bit 3 TV_Tuner,Bus sleep mode,
IDE03150-ENG176561,Readiness for bus sleep mode-Sleep Bit 4,Bus sleep mode,
IDE03150-ENG151637,Readiness for bus sleep mode-Sleep Bit 4 DVD_Changer,Bus sleep mode,
IDE03150-ENG176560,Readiness for bus sleep mode-Sleep Bit 5,Bus sleep mode,
IDE03150-ENG151636,Readiness for bus sleep mode-Sleep Bit 5 RearSeatEntertainment,Bus sleep mode,
IDE03150-ENG152747,Readiness for bus sleep mode-Sleep Bit 6,Bus sleep mode,
IDE03150-ENG152000,Readiness for bus sleep mode-Sleep Bit 6 MOST Kombi-Display,End busstat,
IDE03150-ENG147327,Readiness for bus sleep mode-Sleep Bit 7,Bus sleep mode,
IDE03150-ENG151999,Readiness for bus sleep mode-Sleep Bit 7 SmartDisplayCarrier1,Bus sleep mode,
IDE03150-ENG152015,Readiness for bus sleep mode-Sleep Bit 8 SmartDisplayCarrier2,Bus sleep mode,
IDE03150-ENG152014,Readiness for bus sleep mode-Sleep Bit 9 SmartControlCarrier1,Bus sleep mode,
IDE03151-ENG117815,TP CAN identifier-ECUs TP-CAN-Identifier,|ECU TP-CAN-Identifier-Request Bit 0,ECU TP-CAN-Identifier-Response Bit 0|1907
IDE03477-MAS00106,GPS time-Year,2025,
IDE03477-MAS00107,GPS time-Month,4,
IDE03477-MAS00108,GPS time-Day,25,
IDE03477-MAS00109,GPS time-Hours,11,
IDE03477-MAS00110,GPS time-Minutes,4,
IDE03477-MAS00111,GPS time-Seconds,19,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,255, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,255, %
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,5F,
IDE03880-MAS03425,MOST address-Physical address,04 00,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,11, min
IDE04317-MAS00108,Total system run time-Day,91, d
IDE04317-MAS00109,Total system run time-Hours,8, H
IDE04317-MAS00110,Total system run time-Minutes,20, min
IDE04329,Status of all SWaP functions,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-ENG117822,Bus identification-BusIdentifier,|Bus Identifier|Busmaster|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|MOST-Infotainment|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|Bus unknown|,
IDE04344-ENG103664,Control module assignment-ECU IDs,|ECU ID,ECM name|5F
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Bluetooth,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,variable,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,SBC ,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04544,Media type in optical drive,Not available,
IDE04545-IDE01588,Vehicle status-Driving direction,Measuring value not available,
IDE04545-IDE01714,Vehicle status-Status reverse gear,not selected,
IDE04545-IDE01766,Vehicle status-Distance impulses,0,
IDE04545-IDE03684,Vehicle status-Vehicle stopped,Yes,
IDE04546-IDE00301,Calibration of navigation-Distance,0.480, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04547,Traffic information,OFF,
IDE04605-MAS01779,Navigation: Corrected position-Length,005°30'02.10"E,
IDE04605-MAS01780,Navigation: Corrected position-Width,051°45'57.79"N,
IDE04607-IDE03661,Angle of turn sensor for navigation-Rotation rate,-3.6, °/s
IDE04607-ENG117452,Angle of turn sensor for navigation-gyro_sensor_x_acceleration,20.08, m/s²
IDE04607-ENG117453,Angle of turn sensor for navigation-gyro_sensor_y_acceleration,20.08, m/s²
IDE04607-ENG117454,Angle of turn sensor for navigation-gyro_sensor_z_acceleration,20.08, m/s²
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,Yes,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,No,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.3, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,4380, /min
IDE04748,Counter for microphone over control,0,
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,58 16 D7 60 BF E9,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05536-MAS01632,GPS almanac-Status,valid,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2025,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,4,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,25,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,10,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,52,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,59,
IDE05596-MAS00106,Last time GPS position outside map-Year,2024,
IDE05596-MAS00107,Last time GPS position outside map-Month,11,
IDE05596-MAS00108,Last time GPS position outside map-Day,23,
IDE05596-MAS00109,Last time GPS position outside map-Hours,14,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,3,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,14,
IDE05597-IDE03615,Bluetooth: Paired device 1-Variant,õdj/yS21 van MarisamsungSM-G991B--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-IDE04768,Bluetooth: Paired device 1-Bluetooth: device address,F0 F5 64 6A 2F 79,
IDE05597-MAS01483,Bluetooth: Paired device 1-Software version,õdj/yS21 van MarisamsungSM-G991B--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS02159,Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP),F0 F5,
IDE05597-MAS02160,Bluetooth: Paired device 1-Hands free profile (HFP),F0 F5,
IDE05597-MAS03159,Bluetooth: Paired device 1-Manufacturer,õdj/yS21 van MarisamsungSM-G991B--ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05597-MAS04326,Bluetooth: Paired device 1-Device name,S21 van Mari
samsung
SM-G991B
IDE05597-ENG117431,Bluetooth: Paired device 1-A2DP,F0 F5,
IDE05597-ENG117440,Bluetooth: Paired device 1-ACTIVESYNCML,F0 F5,
IDE05597-ENG105233,Bluetooth: Paired device 1-AT,F0 F5,
IDE05597-ENG117432,Bluetooth: Paired device 1-AVRCP,F0 F5,
IDE05597-ENG117434,Bluetooth: Paired device 1-DUN,F0 F5,
IDE05597-ENG106692,Bluetooth: Paired device 1-FTP,F0 F5,
IDE05597-ENG117435,Bluetooth: Paired device 1-HIDP,F0 F5,
IDE05597-ENG117429,Bluetooth: Paired device 1-HSP,F0 F5,
IDE05597-ENG117437,Bluetooth: Paired device 1-IRMC,F0 F5,
IDE05597-ENG101499,Bluetooth: Paired device 1-map,F0 F5,
IDE05597-ENG117436,Bluetooth: Paired device 1-OBEX,F0 F5,
IDE05597-ENG117439,Bluetooth: Paired device 1-OPP,F0 F5,
IDE05597-ENG117433,Bluetooth: Paired device 1-PAN,F0 F5,
IDE05597-ENG108174,Bluetooth: Paired device 1-PBAP,F0 F5,
IDE05597-ENG117427,Bluetooth: Paired device 1-SDAP,F0 F5,
IDE05597-ENG117428,Bluetooth: Paired device 1-SPP,F0 F5,
IDE05597-ENG117438,Bluetooth: Paired device 1-SYNCML,F0 F5,
IDE05598-IDE03615,Bluetooth: Paired device 2-Variant,--
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE05598-IDE04768,Bluetooth: Paired device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05598-MAS01483,Bluetooth: Paired device 2-Software version,--
IDE05598-MAS02159,Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP),00 00,
IDE05598-MAS02160,Bluetooth: Paired device 2-Hands free profile (HFP),00 00,
IDE05598-MAS03159,Bluetooth: Paired device 2-Manufacturer,--
IDE05598-MAS04326,Bluetooth: Paired device 2-Device name,--
IDE05598-ENG117431,Bluetooth: Paired device 2-A2DP,00 00,
IDE05598-ENG117440,Bluetooth: Paired device 2-ACTIVESYNCML,00 00,
IDE05598-ENG105233,Bluetooth: Paired device 2-AT,00 00,
IDE05598-ENG117432,Bluetooth: Paired device 2-AVRCP,00 00,
IDE05598-ENG117434,Bluetooth: Paired device 2-DUN,00 00,
IDE05598-ENG106692,Bluetooth: Paired device 2-FTP,00 00,
IDE05598-ENG117435,Bluetooth: Paired device 2-HIDP,00 00,
IDE05598-ENG117429,Bluetooth: Paired device 2-HSP,00 00,
IDE05598-ENG117437,Bluetooth: Paired device 2-IRMC,00 00,
IDE05598-ENG101499,Bluetooth: Paired device 2-map,00 00,
IDE05598-ENG117436,Bluetooth: Paired device 2-OBEX,00 00,
IDE05598-ENG117439,Bluetooth: Paired device 2-OPP,00 00,
IDE05598-ENG117433,Bluetooth: Paired device 2-PAN,00 00,
IDE05598-ENG108174,Bluetooth: Paired device 2-PBAP,00 00,
IDE05598-ENG117427,Bluetooth: Paired device 2-SDAP,00 00,
IDE05598-ENG117428,Bluetooth: Paired device 2-SPP,00 00,
IDE05598-ENG117438,Bluetooth: Paired device 2-SYNCML,00 00,
IDE05599-IDE03615,Bluetooth: Paired device 3-Variant,--
IDE05599-IDE04768,Bluetooth: Paired device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05599-MAS01483,Bluetooth: Paired device 3-Software version,--
IDE05599-MAS02159,Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP),00 00,
IDE05599-MAS02160,Bluetooth: Paired device 3-Hands free profile (HFP),00 00,
IDE05599-MAS03159,Bluetooth: Paired device 3-Manufacturer,--
IDE05599-MAS04326,Bluetooth: Paired device 3-Device name,--
IDE05599-ENG117431,Bluetooth: Paired device 3-A2DP,00 00,
IDE05599-ENG117440,Bluetooth: Paired device 3-ACTIVESYNCML,00 00,
IDE05599-ENG105233,Bluetooth: Paired device 3-AT,00 00,
IDE05599-ENG117432,Bluetooth: Paired device 3-AVRCP,00 00,
IDE05599-ENG117434,Bluetooth: Paired device 3-DUN,00 00,
IDE05599-ENG106692,Bluetooth: Paired device 3-FTP,00 00,
IDE05599-ENG117435,Bluetooth: Paired device 3-HIDP,00 00,
IDE05599-ENG117429,Bluetooth: Paired device 3-HSP,00 00,
IDE05599-ENG117437,Bluetooth: Paired device 3-IRMC,00 00,
IDE05599-ENG101499,Bluetooth: Paired device 3-map,00 00,
IDE05599-ENG117436,Bluetooth: Paired device 3-OBEX,00 00,
IDE05599-ENG117439,Bluetooth: Paired device 3-OPP,00 00,
IDE05599-ENG117433,Bluetooth: Paired device 3-PAN,00 00,
IDE05599-ENG108174,Bluetooth: Paired device 3-PBAP,00 00,
IDE05599-ENG117427,Bluetooth: Paired device 3-SDAP,00 00,
IDE05599-ENG117428,Bluetooth: Paired device 3-SPP,00 00,
IDE05599-ENG117438,Bluetooth: Paired device 3-SYNCML,00 00,
IDE05600-IDE03615,Bluetooth: Paired device 4-Variant,--
IDE05600-IDE04768,Bluetooth: Paired device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05600-MAS01483,Bluetooth: Paired device 4-Software version,--
IDE05600-MAS02159,Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP),00 00,
IDE05600-MAS02160,Bluetooth: Paired device 4-Hands free profile (HFP),00 00,
IDE05600-MAS03159,Bluetooth: Paired device 4-Manufacturer,--
IDE05600-MAS04326,Bluetooth: Paired device 4-Device name,--
IDE05600-ENG117431,Bluetooth: Paired device 4-A2DP,00 00,
IDE05600-ENG117440,Bluetooth: Paired device 4-ACTIVESYNCML,00 00,
IDE05600-ENG105233,Bluetooth: Paired device 4-AT,00 00,
IDE05600-ENG117432,Bluetooth: Paired device 4-AVRCP,00 00,
IDE05600-ENG117434,Bluetooth: Paired device 4-DUN,00 00,
IDE05600-ENG106692,Bluetooth: Paired device 4-FTP,00 00,
IDE05600-ENG117435,Bluetooth: Paired device 4-HIDP,00 00,
IDE05600-ENG117429,Bluetooth: Paired device 4-HSP,00 00,
IDE05600-ENG117437,Bluetooth: Paired device 4-IRMC,00 00,
IDE05600-ENG101499,Bluetooth: Paired device 4-map,00 00,
IDE05600-ENG117436,Bluetooth: Paired device 4-OBEX,00 00,
IDE05600-ENG117439,Bluetooth: Paired device 4-OPP,00 00,
IDE05600-ENG117433,Bluetooth: Paired device 4-PAN,00 00,
IDE05600-ENG108174,Bluetooth: Paired device 4-PBAP,00 00,
IDE05600-ENG117427,Bluetooth: Paired device 4-SDAP,00 00,
IDE05600-ENG117428,Bluetooth: Paired device 4-SPP,00 00,
IDE05600-ENG117438,Bluetooth: Paired device 4-SYNCML,00 00,
IDE05601-IDE03615,Bluetooth: Paired device 5-Variant,--
IDE05601-IDE04768,Bluetooth: Paired device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05601-MAS01483,Bluetooth: Paired device 5-Software version,--
IDE05601-MAS02159,Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP),00 00,
IDE05601-MAS02160,Bluetooth: Paired device 5-Hands free profile (HFP),00 00,
IDE05601-MAS03159,Bluetooth: Paired device 5-Manufacturer,--
IDE05601-MAS04326,Bluetooth: Paired device 5-Device name,--
IDE05601-ENG117431,Bluetooth: Paired device 5-A2DP,00 00,
IDE05601-ENG117440,Bluetooth: Paired device 5-ACTIVESYNCML,00 00,
IDE05601-ENG105233,Bluetooth: Paired device 5-AT,00 00,
IDE05601-ENG117432,Bluetooth: Paired device 5-AVRCP,00 00,
IDE05601-ENG117434,Bluetooth: Paired device 5-DUN,00 00,
IDE05601-ENG106692,Bluetooth: Paired device 5-FTP,00 00,
IDE05601-ENG117435,Bluetooth: Paired device 5-HIDP,00 00,
IDE05601-ENG117429,Bluetooth: Paired device 5-HSP,00 00,
IDE05601-ENG117437,Bluetooth: Paired device 5-IRMC,00 00,
IDE05601-ENG101499,Bluetooth: Paired device 5-map,00 00,
IDE05601-ENG117436,Bluetooth: Paired device 5-OBEX,00 00,
IDE05601-ENG117439,Bluetooth: Paired device 5-OPP,00 00,
IDE05601-ENG117433,Bluetooth: Paired device 5-PAN,00 00,
IDE05601-ENG108174,Bluetooth: Paired device 5-PBAP,00 00,
IDE05601-ENG117427,Bluetooth: Paired device 5-SDAP,00 00,
IDE05601-ENG117428,Bluetooth: Paired device 5-SPP,00 00,
IDE05601-ENG117438,Bluetooth: Paired device 5-SYNCML,00 00,
IDE05602-MAS01763,Bluetooth: connected device 1-Signal Strength,0,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,23417609646399854,
IDE05603-MAS01763,Bluetooth: connected device 2-Signal Strength,Not available,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,0,
IDE05604-MAS01763,Bluetooth: connected device 3-Signal Strength,Not available,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,0,
IDE05605-MAS01763,Bluetooth: connected device 4-Signal Strength,Not available,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,0,
IDE05606-MAS01763,Bluetooth: connected device 5-Signal Strength,Not available,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,OK,
IDE05700-MAS03159,USB connection-Manufacturer,FF FF,
IDE05700-MAS04393,USB connection-USB device class,FF,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,FF,
IDE05700-ENG111957,USB connection-usb_product_id,FF FF,
IDE05700-ENG111955,USB connection-usb_protocol,FF,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,93.22, %
IDE05814,Individualization characteristic,94 11 34 7D 40,
IDE06028-MAS02317,Control head button operation-Button code 1,FF,
IDE06028-MAS02318,Control head button operation-Button code 2,FF,
IDE06028-MAS04151,Control head button operation-Joystick,00,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-1,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06425,Dynamometer mode: functional,not activated,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07938,Cause of system start,Data bus,
IDE07939,Last cause of system start,Data bus,
IDE08530-MAS00106,Connection status online basic services-Year,2025.0, yr
IDE08530-MAS00107,Connection status online basic services-Month,4, Months
IDE08530-MAS00108,Connection status online basic services-Day,25, d
IDE08530-MAS00109,Connection status online basic services-Hours,10, H
IDE08530-MAS00110,Connection status online basic services-Minutes,59, min
IDE08530-MAS07131,Connection status online basic services-ID steps,0,
IDE08530-MAS07132,Connection status online basic services-Code status,200,
IDE08530-ENG151979,Connection status online basic services-Server_HTTP_Status_Code_Textual,Data connection established,
IDE08531-MAS00106,Connection status online license services-Year,2000.0, yr
IDE08531-MAS00107,Connection status online license services-Month,1, Months
IDE08531-MAS00108,Connection status online license services-Day,1, d
IDE08531-MAS00109,Connection status online license services-Hours,0, H
IDE08531-MAS00110,Connection status online license services-Minutes,0, min
IDE08531-MAS07132,Connection status online license services-Code status,65535,
IDE08531-MAS07134,Connection status online license services-ID services,10,
IDE08531-MAS07135,Connection status online license services-Activation status,Not available,
IDE08531-MAS07136,Connection status online license services-Exp. year,0, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,1, Months
IDE08531-MAS07138,Connection status online license services-Exp. day,1, d
IDE08531-ENG151979,Connection status online license services-Server_HTTP_Status_Code_Textual,Not available,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardware version,---,
IDE10479-MAS01483,Interface for external media: identification-Software version,----,
IDE10479-MAS04970,Interface for external media: identification-Part Number,-----------,
IDE10843-ENG126986,Function module: identification-Function_module_identification,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Not available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2025,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,25,
MAS00464-MAS00109,Standard - ambient data 1-Hours,13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,34,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,228,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,92414, km
MAS00481-ENG117777,BAP-BAP_Function_ID,FF,
MAS00778-IDE03619,Multimedia display unit 1-System condition,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,1908, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,14, min
MAS00778-MAS00362,Multimedia display unit 1-Battery voltage,12.9, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,73, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,39, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-IDE04058,Bluetooth-Bluetooth: devices found,0,
MAS00951-MAS04324,Bluetooth-Bluetooth: connected devices,1,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,100.1, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,45, dBµV
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,46, dBµV
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),65535, kHz
MAS01760-ENG117356,Radio Tuner 1-iboc_audio_signal,Not available,
MAS01760-ENG117358,Radio Tuner 1-iboc_count,0,
MAS01760-ENG117355,Radio Tuner 1-iboc_error_rate,255,
MAS01760-ENG117357,Radio Tuner 1-iboc_service,no tuned IBOC Audio Service,
MAS01761-MAS01763,Radio Tuner 2-Signal Strength,46, dBµV
MAS01991-IDE00010,Card reader-Serial number,19 F7 A0 C4,
MAS01991-IDE01001,Card reader-Application,AP,
MAS01991-MAS01632,Card reader-Status,connected,
MAS01991-MAS03159,Card reader-Manufacturer,09,
MAS01991-MAS03375,Card reader-Major version,2,
MAS01991-MAS03376,Card reader-Minor version,0,
MAS01991-MAS03959,Card reader-Write-protection,not activated,
MAS01991-MAS04388,Card reader-Card type,MIBST,
MAS01991-MAS13476,Card reader-Manufacturing date: month,8, Months
MAS01991-MAS13477,Card reader-Manufacturing date: year,2019, yr
MAS03121,Ring break diagnostic line status,Supply voltage,
MAS03780-IDE00010,Card reader 2-Serial number,FF FF FF FF,
MAS03780-IDE01001,Card reader 2-Application,--,
MAS03780-MAS01632,Card reader 2-Status,not connected,
MAS03780-MAS03159,Card reader 2-Manufacturer,FF,
MAS03780-MAS03375,Card reader 2-Major version,15,
MAS03780-MAS03376,Card reader 2-Minor version,15,
MAS03780-MAS03959,Card reader 2-Write-protection,Not available,
MAS03780-MAS04388,Card reader 2-Card type,-----,
MAS03780-MAS13476,Card reader 2-Manufacturing date: month,15, Months
MAS03780-MAS13477,Card reader 2-Manufacturing date: year,2255, yr
MAS03782-ENG117422,WLAN-IP_Address,192.168.189.78,
MAS03782-ENG117423,WLAN-IP_Subnetmask,255.255.255.0,
MAS03782-ENG117421,WLAN-MAC_Address,58 16 D7 60 BF EA,
MAS04324-MAS04326,Bluetooth: connected devices-Device name,23417609646399854,
MAS04324-MAS04327,Bluetooth: connected devices-Bluetooth connection profile,Hands free profile (HFP),
MAS04325-MAS04326,Bluetooth: Paired devices-Device name,23417609646399854,
MAS04325-MAS04327,Bluetooth: Paired devices-Bluetooth connection profile,Hands free profile (HFP),
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,OK,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,OK,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,OK,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,OK,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,OK,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,OK,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,OK,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,OK,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,OK,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,OK,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,OK,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,OK,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,9,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,10,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,25, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,4, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,25, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,12, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,51, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,57, s
ENG117869-ENG117441,Nav._Calculated_Direction-driving direction corrected,348, °
ENG117869-ENG98933,Nav._Calculated_Direction-Status,OK,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,65535,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,65535,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,26624,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,65535,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,65535,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,31744,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,65535,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,65535,
ENG117858-MAS01424,System_Temperature_Sensor_2-max.value,63, °C
ENG117858-MAS01425,System_Temperature_Sensor_2-min.value,-9, °C
ENG117858-MAS02238,System_Temperature_Sensor_2-Current,41, °C
ENG117860-MAS01424,System_Temperature_Sensor_4-max.value,57, °C
ENG117860-MAS01425,System_Temperature_Sensor_4-min.value,-13, °C
ENG117860-MAS02238,System_Temperature_Sensor_4-Current,30, °C
ENG117862-MAS01424,System_Temperature_Sensor_6-max.value,60, °C
ENG117862-MAS01425,System_Temperature_Sensor_6-min.value,-9, °C
ENG117862-MAS02238,System_Temperature_Sensor_6-Current,37, °C
Elapsed Time: 00:28
;SW:5NA-035-284-C HW:5NA-035-284-C --- Telematics
;Component:OCULowMQBLGE H19 0827, Coding:02720601EA42180D3F1CBE000045400382E608
;EV_OCULowMQBLGE,004049,EV_OCULowMQBLGE_004_VW27.rod
;Friday,25,April,2025,13:04:43:35871
;VCID: 3D322995ACFDB173E1-8068
IDE00019,Voltage terminal 30,13.0, V
IDE00102,Control Module temperature,33, °C
IDE00608,Fuel type,Petrol,
IDE00667,Microphone status,electrically OK,
IDE00668,Microphone voltage consumption,4.9, mA
IDE00672,Roadside Assistance Button,Not operated,
IDE00673,Information Service Button -E450-,Not operated,
IDE01215,Dimmer terminal 58d,93.30, %
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,8, m
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,8,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,Open circuit,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,2, mA
IDE01971,Lowest recorded control module temperature,9, °C
IDE01972,Highest recorded control module temperature,44, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,84, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,-100, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02486,Data logger triggering,Measuring value not available,
IDE03348-MAS01586,Speed warning-Alarm,65535,
IDE03348,Speed warning,655.35, km/h
IDE03477-MAS00111,GPS time-Seconds,44,
IDE04293-ENG159758,Operating state for emer call module-remaining_time,60, min
IDE04293-ENG99298,Operating state for emer call module-State,registerstate_registered,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Available,
IDE04605-MAS01779,Navigation: Corrected position-Length,005°30'02.09"E,
IDE04605-ENG123297,Navigation: Corrected position-error_value,100, m
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03877,SIM card-SIM ID,89314404000786856691,
IDE04750-MAS03878,SIM card-SIM IMSI,204047125056748,
IDE04750-MAS04226,SIM card-Telephone number, ,
IDE04750-MAS08401,SIM card-SIM intern,Available,
IDE04750-MAS08402,SIM card-SIM extern,Not available,
IDE04750-ENG159798,SIM card-UICCID,7400011598282519241019F026A535,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,358509106549304,
IDE06644,Vehicle positioning system,Measuring value not available,
IDE07940-IDE07007,Status of activation for online services-Air conditioning/heating function via remote control,not activated,
IDE07940-IDE07909,Status of activation for online services-Remote control for vehicle locking,not activated,
IDE07940,Status of activation for online services,not activated,
IDE07940-IDE07974,Status of activation for online services-Transmission of navigation targets,not activated,
IDE07940-IDE07975,Status of activation for online services-Remote control for charging function of high-voltage battery,not activated,
IDE07940-IDE07976,Status of activation for online services-Info call,not activated,
IDE07940-IDE08155,Status of activation for online services-Vehicle state report,not activated,
IDE07940-IDE08158,Status of activation for online services-Roadside assistance / schedule agreement for service,not activated,
IDE07940-MAS04219,Status of activation for online services-Parking heater,not activated,
IDE07940-MAS08370,Status of activation for online services-Position monitoring (Geofencing),not activated,
IDE07940-MAS08371,Status of activation for online services-Remote control for speed warning,not activated,
IDE07940-MAS08372,Status of activation for online services-Remote control for vehicle shutdown,not activated,
IDE07940-MAS08373,Status of activation for online services-Remote control for vehicle location,not activated,
IDE07940-MAS08374,Status of activation for online services-Remote control for lights and horn,not activated,
IDE07940-MAS08375,Status of activation for online services-Distance statistics display,not activated,
IDE07940-MAS08376,Status of activation for online services-Display vehicle state,not activated,
IDE07940-MAS08377,Status of activation for online services-Remote control for departure time programming,not activated,
IDE07940-MAS08448,Status of activation for online services-Manual distress call,activated,
IDE07940-MAS08449,Status of activation for online services-Automatic roadside assistance,activated,
IDE07940-MAS12635,Status of activation for online services-Automatic workshop schedule,not activated,
IDE07940-MAS12636,Status of activation for online services-Autom. search function,not activated,
IDE08159-IDE07007,Status of online services-Air conditioning/heating function via remote control,not active,
IDE08159-IDE07975,Status of online services-Remote control for charging function of high-voltage battery,not active,
IDE08159-IDE08158,Status of online services-Roadside assistance / schedule agreement for service,not active,
IDE08159-MAS04219,Status of online services-Parking heater,not active,
IDE08159-MAS08370,Status of online services-Position monitoring (Geofencing),not active,
IDE08159-MAS08371,Status of online services-Remote control for speed warning,not active,
IDE08159-MAS08372,Status of online services-Remote control for vehicle shutdown,not active,
IDE08159-MAS08373,Status of online services-Remote control for vehicle location,not active,
IDE08159-MAS08374,Status of online services-Remote control for lights and horn,not active,
IDE08159-MAS08377,Status of online services-Remote control for departure time programming,not active,
IDE08159-MAS08448,Status of online services-Manual distress call,not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 DA 73 00 00 00 00 00 08 02 00,
IDE08343,Immobilizer Challenge,F8 CD 16 2C,
IDE08530-MAS00106,Connection status online basic services-Year,2255, yr
IDE08530-MAS00107,Connection status online basic services-Month,255, Months
IDE08530-MAS00108,Connection status online basic services-Day,255, d
IDE08530-MAS00109,Connection status online basic services-Hours,255, H
IDE08530-MAS00110,Connection status online basic services-Minutes,255, min
IDE08530-MAS07131,Connection status online basic services-ID steps,255,
IDE08530-MAS07132,Connection status online basic services-Code status,65535,
IDE08531-MAS00106,Connection status online license services-Year,2255, yr
IDE08531-MAS00107,Connection status online license services-Month,255, Months
IDE08531-MAS00108,Connection status online license services-Day,255, d
IDE08531-MAS00109,Connection status online license services-Hours,255, H
IDE08531-MAS00110,Connection status online license services-Minutes,255, min
IDE08531-MAS07132,Connection status online license services-Code status,16777215,
IDE08531-MAS07134,Connection status online license services-ID services,65535,
IDE08531-MAS07136,Connection status online license services-Exp. year,2255, yr
IDE08531-MAS07137,Connection status online license services-Exp. month,255, Months
IDE08531-MAS07138,Connection status online license services-Exp. day,255, d
IDE11307-ENG160003,eCall battery status-Battery_Charge_Level,75, %
IDE11307-ENG160002,eCall battery status-Battery_Charge_Status,normal,
IDE12732,Button for ERA/Glonass test,Not available,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,73,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,00,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,49,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,1831, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,24,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,204,
MAS04394-IDE07699,Connection status-Mobile network operator,4,
MAS04394-MAS03991,Connection status-Reception level antenna 1,-100, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,EDGE,
MAS04394-MAS08407,Connection status-Data connection,not active,
MAS04394-MAS08408,Connection status-Number of hours to next event,0,
MAS04394-MAS08409,Connection status-Number of minutes to next event,0,
MAS04394-MAS08410,Connection status-Number of seconds to next event,0,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,61494,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS06413,Audio signal output,electrically OK,
MAS08178-IDE02493,Crash information-Automatic door unlocking,No,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08178-MAS08956,Crash information-Automatic emergency call activated:Fuel shut-off,No,
MAS08179,List of last telephone numbers,|||||||,
MAS08180,Remote-controlled horn and lights,0, s
MAS08181-MAS01779,Area restriction configuration-Length,4294967295, m
MAS08181-MAS01780,Area restriction configuration-Width,4294967295, m
MAS08181-MAS08776,Area restriction configuration-tolerance,65535, m
MAS08181-MAS08778,Area restriction configuration-Rotation angle,65535, °
MAS08181-MAS08779,Area restriction configuration-Zone type,Not available,
MAS08181-MAS08780,Area restriction configuration-Area type,Not available,
MAS08200,Emergency call speaker status,electrically OK,
MAS13812-MAS00106,Minimum data set-Year,2000, yr
MAS13812-MAS00107,Minimum data set-Month,1,
MAS13812-MAS00108,Minimum data set-Day,1,
MAS13812-MAS00109,Minimum data set-Hours,0,
MAS13812-MAS00110,Minimum data set-Minutes,0,
MAS13812-MAS00111,Minimum data set-Seconds,0,
MAS13812-MAS00713,Minimum data set-Petrol,not installed,
MAS13812-MAS00716,Minimum data set-Diesel,not installed,
MAS13812-MAS00717,Minimum data set-Petroleum gas,not installed,
MAS13812-MAS00718,Minimum data set-Natural gas,not installed,
MAS13812-MAS00720,Minimum data set-Battery / electric,not installed,
MAS13812-MAS01078,Minimum data set-Vehicle model,not_available,
MAS13812-MAS01779,Minimum data set-Length,
MAS13812-MAS01780,Minimum data set-Width,
MAS13812-MAS02489,Minimum data set-Vehicle Identification Number (VIN),
MAS13812-MAS03131,Minimum data set-Hydrogen,not installed,
MAS13812-ENG98553,Minimum data set-Direction,0,
MAS13812-ENG167215,Minimum data set-Message_Identifier,0,
MAS13812-ENG161136,Minimum data set-Position_Reliability,false,
MAS13812-ENG161230,Minimum data set-Test_Call,false,
MAS13812-ENG161238,Minimum data set-Trigger_Type,manual,
MAS13812-ENG99027,Minimum data set-Version,0,
ENG123206-ENG123337,Antenna_Switch-GPS_Antenna_Switch,external,
ENG123206-ENG123336,Antenna_Switch-GSM_Antenna_Switch,external,
ENG123207-IDE01588,Calculated_Position_And_Direction_Areal_Update-Driving direction,348, °
ENG123207-MAS01632,Calculated_Position_And_Direction_Areal_Update-Status,Available,
ENG123207-MAS01779,Calculated_Position_And_Direction_Areal_Update-Length,005°30'02.09"E,
ENG123207-MAS01780,Calculated_Position_And_Direction_Areal_Update-Width,051°45'57.79"N,
ENG123207-ENG123297,Calculated_Position_And_Direction_Areal_Update-error_value,100, m
ENG157333-ENG159412,eCall_Last_Valid_Position_N-Heading,348, °
ENG157333-ENG159329,eCall_Last_Valid_Position_N-Latitude,051°45'57.79"N,
ENG157333-ENG159328,eCall_Last_Valid_Position_N-Longitude,005°30'02.09"E,
ENG157334-ENG159329,eCall_Last_Valid_Position_N-1-Latitude,051°45'57.17"N,
ENG157334-ENG159328,eCall_Last_Valid_Position_N-1-Longitude,005°30'02.32"E,
ENG157335-ENG159329,eCall_Last_Valid_Position_N-2-Latitude,000°00'00.00"N,
ENG157335-ENG159328,eCall_Last_Valid_Position_N-2-Longitude,000°00'00.00"E,
ENG157299-ENG161128,eCall_MSD_Position_Confidence-MSD_Position_Confidence,true,
ENG157336-ENG159412,eCall_MSD_Position_N-Heading,348, °
ENG157336-ENG159329,eCall_MSD_Position_N-Latitude,051°45'57.79"N,
ENG157336-ENG159328,eCall_MSD_Position_N-Longitude,005°30'02.09"E,
ENG157337-ENG159333,eCall_Passengers-Passenger,1,
ENG137225-ENG161033,eCall_Position_Confidence-Actual_Position_Confidence,100, m
ENG157338-ENG159329,eCall_Second_Last_MSD_Position-Latitude,051°45'57.17"N,
ENG157338-ENG159328,eCall_Second_Last_MSD_Position-Longitude,005°30'02.32"E,
ENG157339-ENG159329,eCall_Third_Last_MSD_Position-Latitude,000°00'00.00"N,
ENG157339-ENG159328,eCall_Third_Last_MSD_Position-Longitude,000°00'00.00"E,
ENG157340-ENG161252,eCall_Unsuccessful_Background_Searches-Unsuccessful_Background_Searches,0,
ENG123208-MAS00106,Geofencing_schedule_start_time-Year,2127,
ENG123208-MAS00107,Geofencing_schedule_start_time-Month,15,
ENG123208-MAS00108,Geofencing_schedule_start_time-Day,0,
ENG123208-MAS00109,Geofencing_schedule_start_time-Hours,31,
ENG123208-MAS00110,Geofencing_schedule_start_time-Minutes,63,
ENG123208-MAS00111,Geofencing_schedule_start_time-Seconds,63,
ENG123209-MAS00106,Geofencing_schedule_stop_time-Year,2127,
ENG123209-MAS00107,Geofencing_schedule_stop_time-Month,15,
ENG123209-MAS00108,Geofencing_schedule_stop_time-Day,0,
ENG123209-MAS00109,Geofencing_schedule_stop_time-Hours,31,
ENG123209-MAS00110,Geofencing_schedule_stop_time-Minutes,63,
ENG123209-MAS00111,Geofencing_schedule_stop_time-Seconds,63,
ENG117867-ENG117773,GPS_Count_Satellite_Phase_Lock_Counter-satellites,0,
ENG123212-ENG123347,GPS_Dilution_of_precision-geometric_dilution_of_precision,76,
ENG123212-ENG123346,GPS_Dilution_of_precision-horizontal_dilution_of_precision,44,
ENG123212-ENG123296,GPS_Dilution_of_precision-Initiation,initialized,
ENG123212-ENG123348,GPS_Dilution_of_precision-positional_dilution_of_precision,68,
ENG123212-ENG123345,GPS_Dilution_of_precision-time_dilution_of_precision,34,
ENG123212-ENG123344,GPS_Dilution_of_precision-vertical_dilution_of_precision,52,
ENG117868-ENG117773,GPS_Satellite_Code_Lock_Counter-satellites,0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,10.15.176.22,
ENG117869-IDE01588,Nav._Calculated_Direction-Driving direction,348, °
ENG117869-MAS01632,Nav._Calculated_Direction-Status,Available,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,0,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,0,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,0, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,0,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,No malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,0,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,0,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,0,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,0,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,0,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,0,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,0,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,0,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,0,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,1,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,0, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,No malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,0, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,0,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,0, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,No malfunction,
ENG123204,Outgoing_call_line_state,Idle,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,0,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,0,
ENG157421-ENG123307,Scan_Network_List-Radio_Cell_Number,0,
ENG157421-ENG159651,Scan_Network_List-reception_level,N/A---
ENG123210-MAS00106,Speed_alert_schedule_start_time-Year,2127,
ENG123210-MAS00107,Speed_alert_schedule_start_time-Month,15,
ENG123210-MAS00108,Speed_alert_schedule_start_time-Day,0,
ENG123210-MAS00109,Speed_alert_schedule_start_time-Hours,31,
ENG123210-MAS00110,Speed_alert_schedule_start_time-Minutes,63,
ENG123210-MAS00111,Speed_alert_schedule_start_time-Seconds,63,
ENG123211-MAS00106,Speed_alert_schedule_stop_time-Year,2127,
ENG123211-MAS00107,Speed_alert_schedule_stop_time-Month,15,
ENG123211-MAS00108,Speed_alert_schedule_stop_time-Day,0,
ENG123211-MAS00109,Speed_alert_schedule_stop_time-Hours,31,
ENG123211-MAS00110,Speed_alert_schedule_stop_time-Minutes,63,
ENG123211-MAS00111,Speed_alert_schedule_stop_time-Seconds,63,
ENG157498,USB_Port_Activation_State,not activated,
ENG123193-ENG123341,Vehicle_Health_Report-Collection_Period,Not available,
ENG123193-ENG123342,Vehicle_Health_Report-Day_at_month_for_report,255,
ENG123193-ENG123343,Vehicle_Health_Report-Day_at_week_for_report,Not available,
ENG123193-ENG123339,Vehicle_Health_Report-Distance_Based_Distance,4294967295, km
ENG123193-ENG123338,Vehicle_Health_Report-Distance_Based_Start_Mileage,4294967295, km
ENG123193-ENG123340,Vehicle_Health_Report-Maintenance_Based_Distance,4294967295, km
Elapsed Time: 00:15
blockmap-A5-3Q0-980-654-L_WVGZZZA1ZLV127723-20250425-1305.CSV
;SW:3Q0-980-654-L HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H13 0610, Coding:0002070600000401002213548150A90098000E20002000
;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002.rod
;Friday,25,April,2025,13:05:04:35871
;VCID: 40CC5061DB0FDC9B8A-8014
IDE00018,Voltage terminal 15,12.7, V
IDE00102,Control Module temperature,34, °C
IDE00326-MAS02471,Steering wheel angle-Sign,Positive,
IDE00326,Steering wheel angle,38.9, °
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.16, °/s
IDE00973,Outside temperature,8.5, °C
IDE01968,Dynamic calibration: yaw angle offset,-0.027, °
IDE01969,Dynamic calibration: pitch angle offset,-0.336, °
IDE01970,Dynamic calibration: roll angle offset,-0.413, °
IDE01971,Lowest recorded control module temperature,-13, °C
IDE01972,Highest recorded control module temperature,81, °C
IDE02057,Dynamic calibration: status,Passive values stored,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Clear view,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,15007, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,20,
IDE04125,Visibility,Not assigned,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,unknown Object_1_distance,
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,unknown Object_2_distance,
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,unknown Object_1_horizontal_angle,
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,unknown Object_2_horizontal_angle,
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,unknown Object_1_vertical_angle,
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,unknown Object_2_vertical_angle,
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.410, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-0.034, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.177, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1388, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Calibration not yet performed,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,Calibration not yet performed,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2020,
IDE10664-MAS00107,Current initial calibration: details-Month,3,
IDE10664-MAS00108,Current initial calibration: details-Day,6,
IDE10664-MAS00109,Current initial calibration: details-Hours,14,
IDE10664-MAS00110,Current initial calibration: details-Minutes,14,
IDE10664-MAS00111,Current initial calibration: details-Seconds,52,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVGZZZA1ZLV127723,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1388,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,643,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,357,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,5,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,8,
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,No,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,No malfunction,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:38
;SW:7P5-941-591-AJ HW:7P5-941-591-A --- Light Ctrl Left 2
;Component:LED1L H07 0011, Coding:
;EV_LED_PLUS_L_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416_VW27.rod
;Friday,25,April,2025,13:05:45:35871
;VCDS Version: Release 25.3.1 (x64) Data version: 20250415 DS365.0
;VCID: 04449C718F9700BBEE-8050
Group,Description,Actual
IDE00030-FSS01408,Status of actuator test-Status,not active,
IDE00325,Diagnostic mode,Extended Session,
IDE00767-ENG145196,No. of unscheduled ECU resets-Test_Program_Watchdog_reset,0,
IDE03680-MAS01468,Supply voltages-Terminal 15,12.7, V
IDE03680-MAS09374,Supply voltages-Terminal 56b,0.1, V
IDE03680-MAS09375,Supply voltages-Terminal 56a,0.0, V
IDE03680-MAS09376,Supply voltages-Supply via vehicle elec. sys. ctrl. unit,0.0, V
IDE03680-MAS10129,Supply voltages-Daytime driving light supply,0.0, V
IDE03680-MAS12194,Supply voltages-Supply for logic,12.7, V
IDE03680-ENG166115,Supply voltages-Terminal_30g,12.9, V
IDE06926-ENG159697,History memory: reset counter-reset_reason,not defined,
IDE06926-ENG139695,History memory: reset counter-Timestamp,19 04 19 0D 02,
IDE08742-IDE09773,Operating time-Side marker lamps,0.00, H
IDE08742-MAS02923,Operating time-Highway light,0.00, H
IDE08742-MAS09325,Operating time-Daytime running lights,90.83, H
IDE08742-MAS13654,Operating time-Auxiliary high beam,0.00, H
IDE08742-ENG159696,Operating time-all_weather_light,0.00, H
IDE08742-ENG167223,Operating time-City_light 4,0.00, H
IDE08742-ENG159688,Operating time-Control_module,286.33, H
IDE08742-ENG251669,Operating time-High_beam,8.08, H
IDE08742-ENG251668,Operating time-Low_beam,110.08, H
IDE08742-ENG166111,Operating time-Position_light,109.83, H
IDE08742-ENG251667,Operating time-Static_Cornering_Light,0.00, H
IDE08742-ENG159751,Operating time-Tourist_light,0.00, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.08, H
IDE09770-MAS02526,High side channel 1-Activation,Channel not used,
IDE09770-MAS04136,High side channel 1-Current,Channel not used,
IDE09770-MAS09022,High side channel 1-PWM value,0.0, %
IDE09771-MAS02526,High side channel 2-Activation,Channel not used,
IDE09771-MAS04136,High side channel 2-Current,Channel not used,
IDE09771-MAS09022,High side channel 2-PWM value,0.0, %
IDE09772-MAS01340,High side channel 3-Functions,no function,
IDE09772-MAS09022,High side channel 3-PWM value,0.0, %
IDE09774-IDE09773,Number of activations-Side marker lamps,0,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS09325,Number of activations-Daytime running lights,1893,
IDE09774-MAS13654,Number of activations-Auxiliary high beam,0,
IDE09774-ENG159696,Number of activations-all_weather_light,0,
IDE09774-ENG167208,Number of activations-city_light,0,
IDE09774-ENG251669,Number of activations-High_beam,1830,
IDE09774-ENG159986,Number of activations-High_beam_excess_temperature,0,
IDE09774-ENG159984,Number of activations-High_beam_excess_temperature_protection,0,
IDE09774-ENG251668,Number of activations-Low_beam,733,
IDE09774-ENG159985,Number of activations-Low_beam_excess_temperature,0,
IDE09774-ENG159983,Number of activations-Low_beam_excess_temperature_protection,0,
IDE09774-ENG166111,Number of activations-Position_light,1671,
IDE09774-ENG251667,Number of activations-Static_Cornering_Light,0,
IDE09774-ENG159751,Number of activations-Tourist_light,0,
IDE09774-ENG166116,Number of activations-Turn_indicator,51136,
IDE09795-MAS09342,Operating times for motor of headlight range adjustment-between 0% and 30%,0.00, H
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,11.00, H
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,187.00, H
IDE09828-MAS00890,Head lamp variant-via CAN,E0 74,
IDE09828-ENG159688,Head lamp variant-Control_module,E0 74,
IDE10048-IDE09768,Supply information-LED channel 1,Not Used,
IDE10048-IDE09769,Supply information-LED channel 2,Terminal_30g,
IDE10048-IDE09771,Supply information-High side channel 2,Terminal_30g,
IDE10048-IDE09772,Supply information-High side channel 3,Terminal 15,
IDE10048-IDE11123,Supply information-High side channel 4,Terminal 15,
IDE10048-MAS01968,Supply information-Fan,Not Used,
IDE10048-MAS09754,Supply information-LED channel 3,Terminal_30g,
IDE10048-MAS09755,Supply information-Matrixbeam channels,Not Used,
IDE10048-MAS16122,Supply information-LED channel 4,Terminal_30g,
IDE10048-ENG161277,Supply information-Highside_channel 1,Terminal_30g,
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,24, °C
IDE10165-MAS01340,LED channel 1: Master 1-Functions,Low_beam,
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,100.0, %
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,1,
IDE10167-FSS01570,LED channel 1: Slave-Temperature,-50, °C
IDE10167-MAS01340,LED channel 1: Slave-Functions,Low_beam,
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS09022,LED channel 1: Slave-PWM value,100.0, %
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,4,
IDE10168-FSS01570,LED channel 2: Master-Temperature,24, °C
IDE10168-MAS01340,LED channel 2: Master-Functions,High_beam,
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS09022,LED channel 2: Master-PWM value,100.0, %
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,1,
IDE10169-FSS01570,LED channel 2: Slave-Temperature,99, °C
IDE10169-MAS01340,LED channel 2: Slave-Functions,no function,
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS09022,LED channel 2: Slave-PWM value,100.0, %
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,4,
IDE10170-FSS01570,LED channel 3: Master-Temperature,30, °C
IDE10170-MAS01340,LED channel 3: Master-Functions,Position_light / Daytime_running_light,
IDE10170-MAS04136,LED channel 3: Master-Current,474, mA
IDE10170-MAS09022,LED channel 3: Master-PWM value,100.0, %
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,3,
IDE10173-MAS09336,Operating times in temperature ranges-between 95°C and 105°C,0.00, H
IDE10173-MAS09337,Operating times in temperature ranges-between 105°C and 115°C,0.00, H
IDE10173-MAS09338,Operating times in temperature ranges-over 115°C,0.00, H
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,200.33, H
IDE10205,Control module version,plus,
IDE10206-MAS09945,Headlamp fan-Fan 1: current,not installed,
IDE10206-MAS09946,Headlamp fan-Fan 2: current,not installed,
IDE10206-MAS11628,Headlamp fan-Fan 1: activation,not installed,
IDE10206-MAS11629,Headlamp fan-Fan 2: activation,not installed,
IDE10282-IDE10165,LED channels: voltages-LED channel 1: Master 1,0.00, V
IDE10282-IDE10168,LED channels: voltages-LED channel 2: Master,0.00, V
IDE10282-IDE10170,LED channels: voltages-LED channel 3: Master,17.00, V
IDE10282-IDE13678,LED channels: voltages-LED channel 4: Master,0.00, V
IDE10282-ENG167217,LED channels: voltages-Channel _1_Slave,0.00, V
IDE10282-ENG167218,LED channels: voltages-Channel _2_Slave,0.00, V
IDE10864-MAS11561,Control mod. temperatures-Power supply for the LED headlamp,25, °C
IDE10864-MAS11562,Control mod. temperatures-Power output module for matrix headlamp,0, °C
IDE11123-MAS02526,High side channel 4-Activation,Channel not used,
IDE11123-MAS04136,High side channel 4-Current,Channel not used,
IDE11123-MAS09022,High side channel 4-PWM value,0.0, %
IDE11124-IDE10205,Headlamp Range Control Motor-Control module version,plus,
IDE11124-ENG145201,Headlamp Range Control Motor-Test_Program_Inclination_of_low_beam,8.00, mm
IDE11124-ENG145200,Headlamp Range Control Motor-Test_Program_Motor_position_percentage_of_maximum_adjustment_travel,68.80, %
IDE13678-FSS01570,LED channel 4: Master-Temperature,30, °C
IDE13678-MAS01340,LED channel 4: Master-Functions,Turn_indicator,
IDE13678-MAS04136,LED channel 4: Master-Current,0, mA
IDE13678-MAS09022,LED channel 4: Master-PWM value,0.0, %
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,1,
MAS00468,Unlearning counter,228,
Elapsed Time: 00:04
;SW:7P5-941-591-AJ HW:7P5-941-591-A --- Light Ctrl Right 2
;Component:LED1R H07 0011, Coding:
;EV_LED_PLUS_R_KEBODAVW416,001003,EV_LED_PLUS_L_KEBODAVW416_VW27.rod
;Friday,25,April,2025,13:05:51:35871
IDE03680-ENG166115,Supply voltages-Terminal_30g,12.8, V
IDE08742-MAS09325,Operating time-Daytime running lights,479.50, H
IDE08742-ENG159688,Operating time-Control_module,1481.33, H
IDE08742-ENG251669,Operating time-High_beam,21.67, H
IDE08742-ENG251668,Operating time-Low_beam,496.83, H
IDE08742-ENG166111,Operating time-Position_light,502.25, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.17, H
IDE09774-MAS09325,Number of activations-Daytime running lights,18967,
IDE09774-ENG251669,Number of activations-High_beam,5046,
IDE09774-ENG251668,Number of activations-Low_beam,4818,
IDE09774-ENG166111,Number of activations-Position_light,17730,
IDE09774-ENG166116,Number of activations-Turn_indicator,230908,
IDE09795-MAS09343,Operating times for motor of headlight range adjustment-between 30% and 60%,127.83, H
IDE09795-MAS09344,Operating times for motor of headlight range adjustment-above 60%,882.17, H
IDE10165-FSS01570,LED channel 1: Master 1-Temperature,27, °C
IDE10168-FSS01570,LED channel 2: Master-Temperature,27, °C
IDE10170-FSS01570,LED channel 3: Master-Temperature,31, °C
IDE10173-MAS09378,Operating times in temperature ranges-between -40°C and 95°C,1001.83, H
IDE10282-IDE10170,LED channels: voltages-LED channel 3: Master,17.33, V
IDE13678-FSS01570,LED channel 4: Master-Temperature,31, °C
Elapsed Time: 00:04
;33-OBD2
;Friday,25,April,2025,13:15:28:35871
03,Fuel system 1/2 status,Closed loop
04,Calculated load value,17.6 %,17.6 %
05,Engine coolant temperature,103 °C,103 °C
06,Short Term Trim - Bank 1,3.1 %
07,Long Term Trim - Bank 1,-6.3 %
0B,Intake Manifold Absolute Pressure,26 kPa abs
0C,Engine RPM,926 /min,932 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,-1.0 Degrees
0F,Intake air temperature,41 °C
11,Absolute Throttle Position,11.8 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.695 V
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,1359 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,11.8 %
2F,Fuel Level Input,80.0 %
30,Warm-ups since DTC cleared,5
31,Distance since DTC cleared,169 km
33,Barometric pressure,102 kPa abs
34,Bank 1 Sensor 1 Status,1.010 Lambda,-0.008 mA
3C,B1S1 Cat. Temp.,348.0 °C
42,Control module voltage,12.820 V,12.600 V
43,Absolute Load Value,17 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,1.2 %
46,Ambient Air Temp,16 °C
47,Absolute Throttle Position B,12 %
49,Accelerator Pedal Position D,14.1 %,14.1 %
4A,Accelerator Pedal Position E,14.5 %
4C,Commanded Throttle Actuator Control,1.6 %
51,Fuel type,Gasoline
53,Abs. evap. vapour press.,99550 kPa abs
56,Long term sec. O2 trim bank 1/3,-0.8 %
62,Torque actual,8.0 %
63,Torque Reference,250 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
67,Engine Coolant Temp,ECT 1:103 °C,ECT 2:104 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:16890/--- kPa
70,Boost Press Ctrl A/B,BP_A act:102.8 kPa
72,Wastegate Ctrl A/B,WG_A cmd/act:---/99 %,WG_B cmd/act:---/--- %
73,Exhaust Press 1/2,EP1:103.29 kPa
8B,Aftertreatment status,PF_Regen:Status:N,PF_Load: 0.0 %
8E,Eng. friction %torque,5.0 %
9E,Exhaust flow rate,8.8 kg/h
A4,Transm gear,N
Type 02 - VIN : WVGZZZA1ZLV127723 (Address E8)
Type 04 - Calibration ID : 05E018AT9971BEAJ (Address E8)
Type 04 - Calibration ID : 0CW300050J 1911 (Address E9)
Type 06 - Calibration Verification Number : 8B1B5A39 (Address E8)
Type 06 - Calibration Verification Number : ABB5E1C0 (Address E9)
Type 08 - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 560
Ignition cycle count : 2774
Catalyst monitor bank 1 : 843 / 557
Catalyst monitor bank 2 : 0 / 0
O2 Sensor monitor bank 1 : 831 / 560
O2 Sensor monitor bank 2 : 0 / 0
EGR-VVT monitor : 1410 / 560
AIR monitor : 0 / 0
EVAP monitor : 0 / 0
Secondary O2 Sensor monitor bank 1 : 817 / 557
Secondary O2 Sensor monitor bank 2 : 0 / 0
Air Fuel Ratio Imbalance Monitor bank 1 : 0 / 0
Air Fuel Ratio Imbalance Monitor bank 2 : 0 / 0
Particulate Filter Monitor bank 1 : 0 / 0
Particulate Filter Monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
