The VCDS information seems to refer to exhaust pressure sensors - G450. The 2020 Amarok only has a G505 pressure differential sensor for the DPF. Can VCDS be used to adapt a new such sensor and, if so, are the procedures the same as for the G450 or are there different procedures?
Thursday,24,April,2025,15:44:21:50182
VCDS Version: 25.3.1.1 (x64) HEX-V2 CB: 0.4671.4
Data version: 20250415 DS365.0
VIN: WV1ZZZ2HZLH017917 License Plate:
Chassis Type: 2H-VN81 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 5F 61 65 69 0B
VIN: WV1ZZZ2HZLH017917 Mileage: 24290km-15093miles
Address 01: Engine (J623-DDXE) Labels:. 059-907-309-V1.clb
Part No SW: 2H6 907 311 F HW: 059 907 309 J
Component: 3.0l V6 TDI H23 0002
Revision: 9AH23--- CVN: 93018E858947E11D8947E11DD6C3ECFE
Coding: 012A4032233601030001
Shop #: WSC 02776 790 50316
ASAM Dataset: EV_ECM30TDI0112H6907311F 001003
ROD: EV_ECM30TDI011_VN81.rod
VCID: 2B03094E838970320A8-807E
VINID: 9E606AAAA098A9C6000472411C1A1C505A
5188 - Particle Filter
P2463 00 [00100000] - Excessive Soot Accumulation
Mileage: 23702 km
Date: 2025.02.28.
Time: 14:50:17
Engine speed: 926.50 /min
Normed load value: 46.3 %
Coolant temperature: 73 C
Intake air temperature: 40 C
Voltage terminal 30: 14.300 V
P Flt Ld fac Ash Cor: 0.9821
Particul.filter diff.pressure: 10 hPa
Exh t Adap T Oxi Cat Ds: 115.7 C
Exh t Adap TP Flt Ds: 177.5 C
Current operating mode_2-Bits 0-7: 0
5189 - Particulate Trap Bank 1
P2002 00 [00100000] - Efficiency Below Threshold
Mileage: 24244 km
Date: 2025.04.24.
Time: 09:46:27
Engine speed: 2035.50 /min
Normed load value: 48.6 %
Vehicle speed: 36 km/h
Coolant temperature: 94 C
Intake air temperature: 28 C
Voltage terminal 30: 12.680 V
Ambient temperature: 15.5 C
DPF: offset for differential pressure: 2 hPa
Particle filter: soot mass measured: 49.07 g
Particle filter: soot mass calculated: 36.27 g
Particle filter: kilometers since last regeneration: 419530 m
Particle filter field regeneration: cancel conditions-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels:| 0CM-325-025.clb
Part No SW: 2H0 927 158 N HW: 0DR 325 025 B
Component: 0CM 30TDIRdW H22 1003
Revision: --H22--- CVN: 87E8B232
ASAM Dataset: EV_TCMAL450211 002011
ROD: EV_TCMAL450211_002_VN81.rod
VCID: 3829260242DFCBAA77A-806C
Address 03: ABS Brakes (J104) Labels: 2H6-907-37x-MK100ESC.clb
Part No SW: 2H6 907 379 A HW: 2H6 907 379
Component: ESC H06 0310
Revision: 00000000 Serial number: 60090000000212
Coding: 207364B64995B69C04AB26A492576D85390000
ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
ROD: EV_Brake1ESCCONTIVN817GP_008.rod
VCID: 343112325EB72FCA5B2-8060
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 23012013470228
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F01A207B359AFD6-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 2H6 907 040 B HW: 2H6 907 040 B
Component: ClimatronicT5 H04 0613
Revision: 00001K05
Coding: 0000000003
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis_VN81.rod
VCID: 2615F87A986B4D5AD56-8072
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 2602 018200602
Coding: 240002380C61140093380F316CCB86D4B280654F60CE7160310000030803
Shop #: WSC 66305 000 145055
VCID: 343112325E372FCA5B2-8060
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 171219 05 50 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 802 EJ HW: 6R0 959 802 EJ Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2332
Serial number: 13202844200114142418
Subsystem 3 - Part No SW: 6R0 959 801 EF HW: 6R0 959 801 EF Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2332
Serial number: 13202847200114105941
Subsystem 4 - Part No: 5C0 951 171
Component: Sensor, DWA 0 005 0502
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Subsystem 6 - Part No: 5C0 951 171
Subsystem 7 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H02 0103
Serial number: 39190003705010060031
Coding: A5FFFF
Subsystem 8 - Part No SW: 6R0 959 811 P HW: 6R0 959 811 P
Component: J388__TSG_HL 022 1334
Serial number: 13102709200116044227
Subsystem 9 - Part No SW: 6R0 959 812 P HW: 6R0 959 812 P
Component: J389__TSG_HR 022 1334
Serial number: 13102708200117232940
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28232002200624
Coding: 31810E
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN81.rod
VCID: 71BFDB2661255AE2704-8024
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 R HW: 6C0 959 655 R
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003G0AIVC72D Dataset Number: V03935317HH 0001
Coding: 88C0C00000000000400000CA008800000065
Shop #: WSC 02774 790 50316
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_SK31.rod
VCID: 42DD44EA1403917AD9E-8016
Serial number: 349007C52791A000000Q
Serial number: 350000556791A0000008
Serial number: 355001980991A000000H
Serial number: 35600CB85991A000000-
Part No SW: 2H6 920 983 A HW: 2H6 920 983 A
Component: KOMBI H04 2030
Coding: 431E000300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
VCID: 30391E22AAAF13EA3FA-8064
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Component: GW-K-CAN TP20 H84 0772
Revision: BB084001
Coding: 742303
VCID: 6889B642527F9B2A27A-803C
Component: IMMO H04 2030
Coding: 000002
VCID: 6A8DCC4A4CF3A93A31E-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 B HW: 2H0 927 771
Component: Quersperre H04 0018
Revision: 11001001 Serial number: 4DG 05.12.19 00
ASAM Dataset: EV_QuersUDSAAMVN817 002001
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2D070756BD9D7E0214C-8078
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0478
Serial number: VWZAZ2X0223270 Dataset Number: V03935270BE 0001
Coding: 06180701BE00000011111101008808001F0100D6002001004F
ROD: EV_MUStd4CTSAT_VN81.rod
VCID: 2517FF76E56D4642DCC-8070
Subsystem 1 - Part No SW: 5NA 919 866 CS HW: -----------
Component: ECE1 2023/24 --- 2010
Part No SW: 7E0 907 534 HW: 7E0 937 089 D
Component: Batt.regelung H84 0772
Coding: 330B18AF
Shop #: WSC 02776 790 00000
Subsystem 1 - Part No SW: 2H6 915 181 HW: 2H6 915 181
Component: J367-BDMConti H03 1051
Serial number: 7497540991200106023A
Part No SW: 2H6 907 273 HW: 5Q0 907 273
Component: RDKBERU30 H04 0003
Serial number: 40000000048890
ASAM Dataset: EV_RDKBERU30 006003
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 6C81CA524607B70A432-8038
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000538952588
Coding: 010D000100000000
VCID: 30391E22AA2F13EA3FA-8064
End----------(Elapsed Time: 02:17, VBatt start/end: 12.5V/12.4V)-----------
------------------------------2 Faults Found-------------------------------
